156-00591
156-00591
    HELLERMAN(海尔曼太通)
    CABLETIE/EDGECLIP50LB7.9"
156-00591 数据手册
Specification Sheet Part Number: 156-00591 Product Image Cable Tie & Edge Clip, 8.0" Long, EC20, 3-6 mm Panel, 50lb, PA66UV/PA66HIRHSUV, Black, 100/pkg Article Number 156-00591 Type T50REC20 Color Black (BK) Features & Benefits • Edge Clip applies easily to plastic and metal sheets without the need for a mounting hole. • Edge Clip provides low insertion force and high extraction force ideal for assembly environments. • Two piece assembly allows the mount to slide along the strap ensuring proper orientation. Quantity Per bag Product Description This cable tie and edge clip assembly is ideal for use where holes are not acceptable or where adhesives will fail due to temperature problems. Edge clips are widely used for fixing and bundling cables and wires within automotive, trucking, heavy equipment, solar panel, wind power, and white goods equipment manufacturing. Short Description Cable Tie & Edge Clip, 8.0" Long, EC20, 3-6 mm Panel, 50lb, PA66UV/PA66HIRHSUV, Black, 100/pkg Global Part Name T50REC20-PA66UV/PA66HIRHS-BK Minimum Tensile Strength (Imperial) 50.0 Minimum Tensile Strength (Metric) 225 Length L (Imperial) 8.0 Length L (Metric) 202.0 Fixation Method EdgeClip, top, assembled, 2 piece Identification Plate Position none Variant Inside Serrated Width W (Imperial) 0.18 Width W (Metric) 4.6 Bundle Diameter Min (Imperial) 0.20 Bundle Diameter Min (Metric) 5.0 Bundle Diameter Max (Imperial) 2.0 Bundle Diameter Max (Metric) 50.0 Thickness T (Imperial) 0.05 Thickness T (Metric) 1.2 Height H (Imperial) 0.05 Height H (Metric) 1.2 Panel Thickness Min(Imperial) 0.12 Panel Thickness Max(Imperial) 0.24 Panel Thickness Min (Metric) 3.0 Panel Thickness Max (Metric) 6.0 Material Polyamide 6.6, high impact modified, heat stabilized (PA66HIRHS) Polyamide 6.6 UV-stabilized (PA66UV) Material Shortcut PA66HIRHS PA66UV Material Cable Tie Polyamide 6.6 UV-stabilized (PA66UV) Flammability UL 94 HB Operating Temperature (Metric) -40°F to +230°F (-40°C to +110°C) -40°F to +185°F (-40°C to +85°C) ROHS Complaint Yes Package Quantity(Imperial) 100 Package Quantity (Metric) 100 Customs Number 3926909987 © 2019 HellermannTyton. All Rights Reserved. Contact Us RoHS/WEEE Compliance Disclaimer Terms and Conditions
156-00591 价格&库存
很抱歉,暂时无法提供与“156-00591”相匹配的价格&库存,您可以联系我们找货
