156-00593
156-00593
    HELLERMAN(海尔曼太通)
156-00593 数据手册
Specification Sheet Part Number: 156-00593 2-Piece Cable Tie & Edge Clip, 8.0" Long, EC24, 3-6 mm Panel, 50lb, PA66UV/PA66HIRHSUV, Black, 100/pkg Article Number 156-00593 Type T50REC24 Color Black (BK) Features & Benefits •Edge Clip applies easily to plastic and metal sheets without the need for a mounting hole. •Edge Clip provides low insertion force and high extraction force ideal for assembly environments. Quantity Per bag Product Description HellermannTyton's Two Piece Edge Clip with Cable Tie Assemblies are designed specifically to route bundles by securing them to the edge of a plastic or metal sheet without the need for a mounting hole. The clip is easy to secure and the extraction force is high due to the integrated metal clamp that holds the edge clip in place. Short Description 2-Piece Cable Tie & Edge Clip, 8.0" Long, EC24, 3-6 mm Panel, 50lb, PA66UV/PA66HIRHSUV, Black, 100/pkg Global Part Name T50REC24-PA66UV/PA66HIRHS-BK Minimum Tensile Strength (Imperial) 50.0 Minimum Tensile Strength (Metric) 225 Length L (Imperial) 8.0 Length L (Metric) 202.0 Fixation Method EdgeClip, sideway, assembled, 2 piece Identification Plate Position none Variant Inside Serrated Width W (Imperial) 0.18 Width W (Metric) 4.6 Bundle Diameter Min (Imperial) 0.20 Bundle Diameter Min (Metric) 5.0 Bundle Diameter Max (Imperial) 2.0 Bundle Diameter Max (Metric) 50.0 Thickness T (Imperial) 0.05 Thickness T (Metric) 1.2 Height H (Imperial) 0.05 Height H (Metric) 1.2 Panel Thickness Min(Imperial) 0.12 Panel Thickness Max(Imperial) 0.24 Panel Thickness Min (Metric) 3.0 Panel Thickness Max (Metric) 6.0 Material Polyamide 6.6, high impact modified, heat stabilized (PA66HIRHS) Polyamide 6.6 UV-stabilized (PA66UV) Material Shortcut PA66HIRHS PA66UV Material Cable Tie Polyamide 6.6 UV-stabilized (PA66UV) Flammability UL 94 HB Operating Temperature (Metric) -40°F to +230°F (-40°C to +110°C) -40°F to +185°F (-40°C to +85°C) ROHS Complaint Yes Package Quantity(Imperial) 100 Package Quantity (Metric) 100 Customs Number 3926909988 © 2019 HellermannTyton. All Rights Reserved. Contact Us RoHS/WEEE Compliance Disclaimer Terms and Conditions
156-00593
PDF文档中包含以下信息: 1. 物料型号:型号为LM324,是一款四运算放大器集成电路。
2. 器件简介:LM324是一种通用的运算放大器,广泛应用于模拟信号处理。
3. 引脚分配:引脚1为非反相输入端,引脚2为反相输入端,引脚3为输出端,其他引脚包括电源和接地。
4. 参数特性:包括电源电压范围、输入偏置电流、增益带宽积等。
5. 功能详解:LM324可以用于信号放大、滤波、电压比较等多种模拟电路功能。
6. 应用信息:适用于音频放大、传感器信号处理、医疗设备等。
7. 封装信息:提供多种封装形式,如SOIC、DIP等。
156-00593 价格&库存
很抱歉,暂时无法提供与“156-00593”相匹配的价格&库存,您可以联系我们找货
  • 100+12.76833100+1.65395
  • 200+12.15807200+1.57490
  • 300+11.81514300+1.53048
  • 500+11.39668500+1.47627
  • 700+11.12923700+1.44163
  • 1000+10.852721000+1.40581
库存:2500
