156-00072
156-00072
    HELLERMAN(海尔曼太通)
156-00072 数据手册
156-00072 Article Number: 156-00072 Heavy Duty Fir Tree with Cable Tie, 9" Length, Mount Hole Dia .04"-.62", PA66HIRHSUV, Black, 100/pkg Download drawing Download spec sheet Base Data Local Order Number 156-00072 Type WSSFT9B Color Black (BK) Features and Benefits • The “H” profile provides a broad surface contact to minimize the pinching of bundles. • Heavy duty fir tree mounts are equipped with a friction tab that will hold the tie in the mount, allowing them to be preassembled prior to installation. • Designed specifically for HellermannTyton 120 - 250 lb. cable ties for heavy duty applications. Product Description HellermannTyton heavy duty fir tree mounts are designed with heavy duty applications in mind. These are optimized for up to 3 to 1 extraction versus insertion force to make assembly fast and easy. These mounts are sold as an assembly with a cable tie. Short Description Heavy Duty Fir Tree with Cable Tie, 9" Length, Mount Hole Dia .04"-.62", PA66HIRHSUV, Black, 100/pkg Product Dimensions Minimum Tensile Strength (Imperial) 120.0 lbs Minimum Tensile Strength (Metric) 534 N Length L (Imperial) 9.0 " Length L (Metric) 228.0 mm Fixation Method Fir Tree Identification Plate Position none Tie Closure plastic pawl Variant Inside Serrated Width W (Imperial) 0.5 " Width W (Metric) 12.7 mm Width W2 (Imperial) 0.51 " Width W2 (Metric) 13.0 mm Height H (Imperial) 1.1 " Height H (Metric) 28.5 mm Height H2 (Imperial) 0.73 " Height H2 (Metric) 18.4 mm Bundle Diameter Max. (Imperial) 2.3 " Bundle Diameter Max. (Metric) 57.0 mm Disc Diameter (Imperial) 0.9 " Disc Diameter (Metric) 21.6 mm Panel Thickness Max. (Imperial) 0.62 " Panel Thickness Max. (Metric) 15.8 mm Panel Thickness Min. (Imperial) 0.04 " Panel Thickness Min. (Metric) 1.0 mm Mounting Hole Diameter D (Metric) 8.75 - 9.25 mm Mounting Hole Diameter D Min. 0.34 " (Imperial) Mounting Hole Diameter D Max.0.36 " (Imperial) Mounting Hole Diameter D Min. (Metric) Mounting Hole Diameter D Max.9.25 mm (Metric) 8.75 mm Logistics and Packaging Quantity Per bag Package Quantity (Metric) 100 Carton Quantity 500 Material and Specifications Material Polyamide 6.6 high impact modified, heat stabilized, UV resistant (PA66HIRHS) Material Shortcut PA66HIRHSUV Flammability UL94 HB Operating Temperature -65°F to +212°F (-54°C to +100°C) ROHS Compliant Yes © HellermannTyton 2015
156-00072 价格&库存
很抱歉,暂时无法提供与“156-00072”相匹配的价格&库存,您可以联系我们找货
