35653
35653
    DESCO
    CONN SPLICE CLOSED 10-22AWG
35653 数据手册
Features: Made in America • • • • • • • D-Ring fastening is ideal for bundling trays and IC tubes Adjustable, releasable and reusable - easy to install Low charging meets ANSI/ESD S20.20 and ANSI/ESD S541 Custom sizes available Operating Temperature: 300°F (149°C) max Melting Temperature: 459°F (237°C) Straps should be tested regularly to make sure they retain their ESD properties • Made in America 35653 Low Charging Cable Tie, Non-Stretch D-Ring, 3/4 in (19 mm) x 18 in (457 mm) 35654 Low Charging Tie, Non-Stretch D-Ring, 3/4 in (19 mm) x 20 in (19 mm) 35655 Low Charging Cable Tie, Non-Stretch D-Ring, 3/4 in (19 mm) x 24 in (609 mm) 35656 Low Charging Cable Tie, Non-Stretch D-Ring, 3/4 in (19 mm) x 30 in (762 mm) Specifications and procedures subject to change without notice. Unless otherwise noted, tolerance is ±10%. *Trays not included LOW CHARGING CABLE TIES 3651 WALNUT AVE., CHINO, CA 91710 PHONE: (951) 627-2453 • FAX: (951) 755-8848 WEBSITE: MendaPump.com © 2017 Desco Industries Inc. Employee Owned DRAWING NUMBER: 35653 DATE: April 2017
35653 价格&库存
很抱歉,暂时无法提供与“35653”相匹配的价格&库存,您可以联系我们找货
