LT2-S5-FB-BK
LT2-S5-FB-BK
    TECHFLEX
    LACINGTAPEBRDPOLYESTER
LT2-S5-FB-BK 数据手册
TERMINATIONS & BUNDLING Technical Data Sheet T  ype I Polyamide (Nylon) Lacing Tape -67ºF to 250ºF (-55ºC to 121ºC) T  ype III TFE-Fluorocarbon (Teflon) Lacing Tape -99ºF to 450ºF (-73ºC to 232ºC) T  ype IV Fiberglass (Glass) Lacing Tape -67ºF to 800ºF (-55ºC to 427ºC) T  ypeV Meta Aramid (Nomex) Lacing Tape -67ºF to 500ºF (-55ºC to 260ºC)  MIL-T-43435 While cable ties are the most common method of wire dressing, there is an alternate method known as cable lacing. This method has been used on aircraft, ships, and military equipment for many years. Lacing Tape meets Military Specification MIL-T-43435 and is made of braided Nylon, Polyester, TFE-Fluorocarbon, Fiberglass or Flexo NX. The basic concept of lacing is to use a flat cord to tie the cable bundle together. While lacing may be somewhat of a lost art - it’s easy to learn, and you will be lacing your bundling projects in no time. Why lacing tape? Lasts longer than cable ties. Cable ties turn brittle and degrade over time due to environmental exposure and loss of plasticizers. A roll of lacing tape can manage any size cable bundle, from a couple of 22AWG wires to a fistful of heavy power cables. Cable ties leave a sharp edge where the tail was cut off that can snag or get hung up. Some applications such as aerospace and aviation may specify laced harnesses as a design requirement. Lacing tape is ideal for lashing wires or cables to ladder bars, conduit and other wire management solutions. Unlike cable ties, the insulation on wires bundled with lacing tape has less chance of cold flowing and shorting. No sharp edges to cut installer’s hands when reaching into a tightly packed wiring cavity. Lacing tape is available in a wide range of materials, sizes and finishes to accommodate any engineering requirement. MIL Finishes: Finish A = No Finish Finish B = Wax Finish C = Synthetic Elastomer (Rubber) Finish Finish D = TFE-Fluorocarbon Finish Finish G = Liquid Nylon® Cut Cleanly Scissors www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Cable lacing - easy to learn, quite inexpensive, looks more attractive, and is a superior method of bundling wires in your boat. Colors Available: Natural (NT), Red (RD), Brown (BR), Black (BK). www.techflex.com T  ype II Polyester (Dacron) Lacing Tape -99ºF to 350ºF (-73ºC to 177ºC) Cable Lacing - Inexpensive Method of Wire Dressing No Finish FINISH A TERMINATIONS & BUNDLING Technical Data Sheet Material Mil Spec Size Break Strength Min Max Min Max Bulk Spool Available Colors LT1-S1-FA-** A-A-52080 MIL-T-43435 TYPE I A-A-52080 MIL-T-43435 TYPE I A-A-52080 MIL-T-43435 TYPE I A-A-52080 MIL-T-43435 TYPE I A-A-52080 MIL-T-43435 TYPE I A-A-52080 MIL-T-43435 TYPE I A-A-52080 MIL-T-43435 TYPE I A-A-52080 MIL-T-43435 TYPE I A-A-52080 MIL-T-43435 TYPE I A-A-52080 MIL-T-43435 TYPE I A-A-52080 MIL-T-43435 TYPE I A-A-52080 MIL-T-43435 TYPE I A-A-52080 MIL-T-43435 TYPE I A-A-52080 MIL-T-43435 TYPE I A-A-52080 MIL-T-43435 TYPE I A-A-52081 MIL-T-43435 TYPE II A-A-52081 MIL-T-43435 TYPE II A-A-52081 MIL-T-43435 TYPE II A-A-52081 MIL-T-43435 TYPE II A-A-52081 MIL-T-43435 TYPE II A-A-52081 MIL-T-43435 TYPE II A-A-52081 MIL-T-43435 TYPE II A-A-52081 MIL-T-43435 TYPE II A-A-52081 MIL-T-43435 TYPE II A-A-52081 MIL-T-43435 TYPE II A-A-52081 MIL-T-43435 TYPE II A-A-52081 MIL-T-43435 TYPE II A-A-52081 MIL-T-43435 TYPE II A-A-52081 MIL-T-43435 TYPE II A-A-52081 MIL-T-43435 TYPE II A-A-52083 MIL-T-43435 TYPE IV A-A-52083 MIL-T-43435 TYPE IV A-A-52083 MIL-T-43435 TYPE IV A-A-52083 MIL-T-43435 TYPE IV Nylon 1 135lbs .180” .220” .013” .019” 750’ NT & BK Nylon 2 80lbs .099” .121” .012” .018” 750’ NT & BK Nylon 3 50lbs .077” .094” .011” .017” 1,500’ NT & BK Nylon 4 25lbs .054” .066” .009” .015” 1,500’ NT & BK Nylon 5 15lbs .045” .055” .006” .014” 1,500’ NT & BK Nylon 1 135lbs .180” .220” .013” .019” 750' NT & BK Nylon 2 80lbs .099” .121” .012” .018” 750' NT & BK Nylon 3 50lbs .077” .094” .011” .017” 1,500’ NT & BK Nylon 4 25lbs .054” .066” .009” .015” 1,500’ NT & BK Nylon 5 15lbs .045” .055” .006” .014” 1,500’ NT & BK Nylon 1 135lbs .180” .220” .013” .019” 750’ NT & BK Nylon 2 80lbs .099” .121” .012” .018” 750’ NT & BK Nylon 3 50lbs .077” .094” .011” .017” 1,500’ NT & BK Nylon 4 25lbs .054” .066” .009” .015” 1,500’ NT & BK Nylon 5 15lbs .045” .055” .006” .014” 1,500’ NT & BK Polyester 1 135lbs .180” .220” .013” .019” 750’ NT & BK Polyester 2 80lbs .099” .121” .012” .018” 750’ NT & BK Polyester 3 50lbs .077” .094” .011” .017” 1,500’ NT & BK Polyester 4 25lbs .054” .066” .009” .015” 1,500’ NT & BK Polyester 5 15lbs .045” .055” .006” .014” 1,500’ NT & BK Polyester 1 135lbs .180” .220” .013” .019” 750' NT, RD, & BK Polyester 2 80lbs .099” .121” .012” .018” 750' NT, RD, & BK Polyester 3 50lbs .077” .094” .011” .017” 1,500' NT, RD, & BK Polyester 4 25lbs .054” .066” .009” .015” 1,500' NT, RD, & BK Polyester 5 15lbs .045” .055” .006” .014” 1,500' NT, RD, & BK Polyester 1 135lbs .180” .220” .013” .019” 750’ NT, RD, & BK Polyester 2 80lbs .099” .121” .012” .018” 750’ NT, RD, & BK Polyester 3 50lbs .077” .094” .011” .017” 1,500’ NT, RD, & BK Polyester 4 25lbs .054” .066” .009” .015” 1,500’ NT & BK Polyester 5 15lbs .045” .055” .006” .014” 1,500’ NT, RD, & BK Fiberglass 1 200lbs .203” .248” .013” .019” 750’ Natural (NT) Fiberglass 2 100lbs .099” .121” .013” .019” 750’ Natural (NT) Fiberglass 3 75lbs .077” .094” .013” .019” 1,500’ Natural (NT) Fiberglass 4 50lbs .054” .066” .013” .019” 1,500’ Natural (NT) LT1-S2-FA-** LT1-S3-FA-** LT1-S4-FA-** Wax Finish FINISH B LT1-S1-FB-** LT1-S2-FB-** LT1-S3-FB-** LT1-S4-FB-** LT1-S1-FC-** FINISH C Synthetic Rubber LT1-S5-FB-** LT1-S2-FC-** LT1-S3-FC-** LT1-S4-FC-** LT1-S5-FC-** No Finish FINISH A LT2-S1-FA-** LT2-S2-FA-** LT2-S3-FA-** LT2-S4-FA-** LT2-S5-FA-** FINISH B Wax Finish LT2-S1-FB-** LT2-S2-FB-** LT2-S3-FB-** LT2-S4-FB-** LT2-S1-FC-** FINISH C Synthetic Rubber LT2-S5-FB-** LT2-S2-FC-** LT2-S3-FC-** LT2-S4-FC-** LT2-S5-FC-** LT4-S1-FD-NT TFE Thickness Mil Spec LT1-S5-FA-** FINISH D Width Part # LT4-S2-FD-NT LT4-S3-FD-NT LT4-S4-FD-NT No Finish FINISH A TERMINATIONS & BUNDLING Technical Data Sheet Material Mil Spec Size Break Strength Min Max Min Max Bulk Spool Available Colors LT3-S2-FA-BR A-A-52082 MIL-T-43435 TYPE III A-A-52082 MIL-T-43435 TYPE III A-A-52084 MIL-T-43435 TYPE V A-A-52084 MIL-T-43435 TYPE V A-A-52084 MIL-T-43435 TYPE V A-A-52084 MIL-T-43435 TYPE V A-A-52084 MIL-T-43435 TYPE V A-A-52084 MIL-T-43435 TYPE V A-A-52084 MIL-T-43435 TYPE V A-A-52084 MIL-T-43435 TYPE V A-A-52084 MIL-T-43435 TYPE V A-A-52084 MIL-T-43435 TYPE V A-A-52084 MIL-T-43435 TYPE V A-A-52084 MIL-T-43435 TYPE V TFE-Flurocarbon 2 30lbs .108” .132” .009” .014” 750’ Brown (BR) TFE-Flurocarbon 4 15lbs .059” .072” .009” .014” 1,500’ Brown (BR) Flexo NX 51 85lbs .180” .220” .013” .019” 750’ Natural (NT) Flexo NX 2 50lbs .099” .121” .011” .017” 750’ Natural (NT) Flexo NX 3 35lbs .068” .083” .009” .015” 1,500’ Natural (NT) Flexo NX 4 25lbs .050” .061” .007” .013” 1,500’ Natural (NT) Flexo NX 1 85lbs .180” .220” .013” .019” 750’ Natural (NT) Flexo NX 2 50lbs .099” .121” .011” .017” 750’ Natural (NT) Flexo NX 3 35lbs .068” .083” .009” .017” 1,500’ Natural (NT) Flexo NX 4 25lbs .050” .061” .007” .013” 1,500’ Natural (NT) Flexo NX 1 85lbs .180” .220” .013” .019” 750’ Natural (NT) Flexo NX 2 50lbs .099” .121” .011” .017” 750’ Natural (NT) Flexo NX 3 35lbs 068” .083” .009” .017” 1,500’ Natural (NT) Flexo NX 4 25lbs .050” .061” .007” .013” 1,500’ Natural (NT) LT3-S4-FA-BR No Finish FINISH A LT5-S2-FA-NT LT5-S3-FA-NT LT5-S4-FA-NT LT5-S1-FC-NT FINISH C Synthetic Rubber LT5-S2-FC-NT LT5-S3-FC-NT LT5-S4-FC-NT LT5-S1-FG-NT FINISH G Thickness Mil Spec LT5-S1-FA-NT Liquid Nylon® Width Part # LT5-S2-FG-NT LT5-S3-FG-NT LT5-S4-FG-NT © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex®’s only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-30 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
LT2-S5-FB-BK 价格&库存
很抱歉,暂时无法提供与“LT2-S5-FB-BK”相匹配的价格&库存,您可以联系我们找货
