150-76080
150-76080
    HELLERMAN(海尔曼太通)
    CABLETIE/EDGECLIP30LB5.9"
150-76080 数据手册
085_113_chapter 1.3_prod 07_uk.qxp 31.07.2007 11:51 Seite 85 Cable Ties and Fixings Cable Ties and Fixings F i x i n g Ti e s 1.3 One Piece Fixing Ties One Piece Fixing Ties bring together a solution for the need to bundle a product whilst at the same time providing a fixing solution HellermannTyton’s one piece fixing ties offer the ideal combination of high specification materials and superior design to give the perfect solution for both bundling and installation of cable bundles, hoses or pipes. Long acknowledged as the market leader for innovative fixings, HellermannTyton has now met the challenges set by the autom otive, aviation, domestic appliance and electrical industries by combining the best “fixing design“ with the best “cable tie design“ – to produce the new One Piece Fixing Ties. The additional seal protects against the ingress of moisture or dirt. One Piece Fixing Ties with Arrowhead and Disc Features and Benefits A simple one piece bundling and fixing tie with an arrowhead mount. When inserted into the hole the arrowhead locks into place and the 'disc', between the fixing and the head of the cable tie, covers the hole and minimises the ingress of dust, dirt and water, whilst adjusting for variations in panel thickness thereby ensuring a secure fixing at all times. The RT versions are releasable and reusable, ideal for the removal or addition of cables after the initial installation is complete. The T50SST type has a small 'tab' placed below the head which gives additional protection against axial forces and is particularly useful to assist retention on convoluted tubing. Application With a diverse range of fixing possibilities this range of fixing ties are ideal for use in many different industries, for example: automotive, aerospace, white goods manufacture and panel building. Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °C to +85 °C Continuous, (+105 °C for 500 h) Flammability UL94 V2 Material Data Material Polyamide 6.6 Heat Stabilised (PA66HS) Operating Temperature -40 °C to +105 °C Continuous, (+145 °C for 500 h) Flammability UL94 V2 85 085_113_chapter 1.3_prod 07_uk.qxp 1.3 31.07.2007 11:51 Seite 86 Cable Ties and Fixings F i x i n g Ti e s One Piece Fixing Ties with Arrowhead and Disc Common head/fixing design. The flexible 'discs' adjusts to take up variations in panel thickness - ensuring a firm fixing at all times. One piece fixing tie with arrowhead and disc, standard design. Special design without a gap between head and bundle; T50MD7. Material Data Material Polyamide 4.6 (PA46) Operating Temperature -40 °C to +150 °C for 5000 h, (+195 °C for 500 h) Flammability UL94 V2, Limited Fire Hazard, Halogen free, Low smoke generation, Low generation of toxic gases and corrosive acid Technical Table Article-No. Type Length Width Bundle Disc Min. Tensile (L) (W) Ø max. Ø Strength (N) Hole Ø 6.3-7.5 Panel Panel Thickness Thickness max. min. 0.6 1.8 Material Colour PA66 Natural (NA) 126-01401 T50SD6 160 5.0 31 18.0 180 111-85350 T50SD6 160 5.1 31 18.0 225 6.3-7.5 0.6 1.2 PA66HS Black (BK) 126-00015 T50SDOP* 160 5.0 30 22.0 225 6.2x12.2 0.7 2.0 PA66HS Black (BK) 126-01601 T50SDOR* 160 5.0 30 22.0 225 6.2x12.2 0.5 1.5 PA66HS Black (BK) 126-02300 T50SST5 170 4.6 31 16.2 225 6.1-6.5 0.7 1.5 PA66 Natural (NA) 150-15395 T50SST5 170 4.6 31 16.2 225 6.1-6.5 0.7 1.5 PA66HS Black (BK) 126-00017 T50SST5 170 4.6 31 16.2 225 6.1-6.5 0.7 1.5 PA66HS Black (BK) 150-35395 T50SST5 170 4.6 31 16.2 225 6.1-6.5 0.7 1.5 PA46 Grey (GY) 111-85850 T50MD7 225 5.0 59 16.0 225 6.8-7.2 0.8 2.0 PA66HS Black (BK) 126-00800 T50MD7 225 5.0 59 16.0 225 6.8-7.2 0.8 2.0 PA66HS Black (BK) 126-03100 T50SOSSFT6.5E-MD 160 4.6 35 16.0 225 6.3-6.7 0.6 1.8 PA66HS Green (GN) 156-00264 T50SOSSFT6.5E-MD 160 4.6 35 16.0 225 6.3-6.7 0.6 1.8 PA66HS Black (BK) 126-03102 T50SOSSFT6.5E 160 4.6 35 16.0 225 6.3-6.7 1.9 2.5 PA66HS Black (BK) 160 5.0 31 18.0 180 6.3-7.5 0.6 1.8 PA66HS Black (BK) Releasable 111-85480 RT50SD6 All dimensions in mm. Subject to technical changes. * for oval hole 86 085_113_chapter 1.3_prod 07_uk.qxp 31.07.2007 11:51 Seite 87 Cable Ties and Fixings F i x i n g Ti e s 1.3 One Piece Fixing Tie with Arrowhead Features and Benefits The arrowhead is simply pushed through the panel and locks into place, the design of the arrowhead (without 'legs') ensures that the minimum amount of space is used, and yet offers a firm, secure fixing. Application The arrowhead design allows these ties to be used in areas with limited space. The arrowhead design allows these ties to be used in areas with limited space. Application Tool Material Data Registration Numbers MK3SP 1 MK3PNSP2MK7P Material Polyamide 6.6 Heat Stabilised (PA66HS) 2 Operating Temperature -40 °C to +105 °C Continuous, (+145 °C for 500 h) MK7 3 Flammability UL94 V2 MK7HT 4 MK20 5 MK6 6 MK9P, MK6PN 7 MK9 8 MK9HT 9 MK21 10 For more information, please turn to page 388. T30RSF T50RSF T50RSF(U) Technical Table Material Colour Application Tool 2.36 PA66 Natural (NA) 1–3, 5 2.3 PA66HS Black (BK) 1–3, 5 1.0 3.56 PA66 Natural (NA) 1–3, 5 6.2-6.4 2.9 3.1 PA66 Natural (NA) 1–3, 5 6.2-6.4 2.9 3.1 PA66 Black (BK) 1–3, 5 Width (W) 111-85603 T30RSF(U) 161 3.6 31 135 4.8-5.6 0.9 111-85610 T30RSF(U) 161 3.6 31 135 4.8-5.6 0.9 111-85789 T50RSF(U) 210 4.7 44 225 6.4-7.1 111-85799 T50RSF(E) 210 4.6 50 225 126-01001 T50RSF(E) 210 4.6 50 225 Article-No. Type Bundle Min. Tensile Ø max. Strength (N) Panel Panel Thickness Thickness max. min. Length (L) Hole Ø All dimensions in mm. Subject to technical changes. Please Note for Product Specific Approvals please refer to the Appendix 87 085_113_chapter 1.3_prod 07_uk.qxp 1.3 31.07.2007 11:51 Seite 88 Cable Ties and Fixings F i x i n g Ti e s One Piece Fixing Ties with Arrowhead Features and Benefits The arrowhead design, in conjunction with the supporting 'legs', ensures a firm and secure fixing. The 'legs' take up any variation in panel thickness enabling one part to suit many applications. Both the RT and FBS versions are releasable and reusable, with the FBS type having the added feature of a ladder type strap as opposed to the conventional serrated strap this ladder type strap has the benefit of being very flexible. Application For the bundling and fixing of cable harnesses, pipes & hoses in the automotive, aerospace, white goods industries and panel building. Application Tool Registration Numbers MK3SP 1 MK3PNSP2, MK7P A wide range of arrowhead fixing ties which are suitable for panel thicknesses of 0.5mm to 4.5mm and hole diameters of 4.4mm to 8.0mm. Material Data Material Polyamide 6.6 (PA66) 2 Operating Temperature -40 °C to +85 °C Continuous, (+105 °C for 500 h) MK7 3 Flammability UL94 V2 MK7HT 4 MK20 5 MK6 6 MK9P, MK6PN 7 MK9 8 MK9HT MK21 Material Data Material 9 10 For more information, please turn to page 388. Polyamide 6.6 Heat Stabilised (PA66HS) Operating Temperature -40 °C to +105 °C Continuous, (+145 °C for 500 h) Flammability UL94 V2 Material Data Material Polyamide 6.6 UV Resistant (PA66W) Operating Temperature -40 °C to +85 °C Continuous, (+105 °C for 500 h) Flammability UL94 V2 Material Data Material 88 Polyamide 4.6 (PA46) Operating Temperature -40 °C to +150 °C for 5000 h, (+195 °C for 500 h) Flammability UL94 V2, Limited Fire Hazard, Halogen free, Low smoke generation, Low generation of toxic gases and corrosive acid 085_113_chapter 1.3_prod 07_uk.qxp 31.07.2007 11:51 Seite 89 Cable Ties and Fixings F i x i n g Ti e s 1.3 One Piece Fixing Ties with Arrowhead Technical Table Article-No. Type Length Width Bundle Min. Tensile (L) (W) Ø max. Strength (N) Hole Ø Panel Panel Thickness Thickness max. min. Material Colour Application Tool 111-85519 T18RSF 100 2.5 16 80 4.65-4.85 1.0 3.0 PA66 Natural (NA) 1–3, 5 111-85560 T18RSF 100 2.5 16 80 4.65-4.85 1.0 3.0 PA66W Black (BK) 1–3, 5 111-85719 T50SSFM 160 4.7 25 225 6.0-6.4 1.0 3.0 PA66 Natural (NA) 1–3, 5 126-01104 T50SSFM 160 4.7 25 225 6.0-6.4 1.0 3.0 PA66HS Natural (NA) 1–3, 5 126-00032 T50SSFM 160 4.7 25 225 6.0-6.4 1.0 3.0 PA66HS Black (BK) 1–3, 5 111-85729 T50RSFM 200 4.7 45 225 6.0-6.4 1.0 3.0 PA66 Natural (NA) 1–3, 5 111-85329 T50VSL5 100 4.6 16 225 6.1-6.3 1.0 2.6 PA66 Natural (NA) 1–3, 5 111-85349 T50SSL5 135 4.6 27 225 6.1-6.5 0.8 2.7 PA66 Natural (NA) 1–3, 5 111-85340 T50SSL5 135 4.6 27 225 6.1-6.5 0.8 2.7 PA66HS Black (BK) 1–3, 5 111-85395 T50SSL5 135 4.6 27 225 6.1-6.5 0.8 2.7 PA46 Grey (GY) 1–3, 5 126-00005 T50SL5 165 4.6 34 225 6.1-6.3 0.8 2.7 PA66HIRHS Black (BK) 1–3, 5 111-85369 T50SL5 165 4.6 34 225 6.1-6.3 0.8 2.7 PA66 Natural (NA) 1–3, 5 126-00001 T50SL5 165 4.6 34 225 6.1-6.3 0.8 2.7 PA66HS Black (BK) 1–3, 5 111-85469 T50SL6 165 4.6 34 225 6.3-7.5 0.5 2.5 PA66 Natural (NA) 1–3, 5 111-85460 T50SL6 165 4.6 34 225 6.3-7.5 0.5 2.5 PA66 Black (BK) 1–3, 5 111-85479 T50SL7 165 4.6 34 225 6.9-7.1 0.8 2.5 PA66 Natural (NA) 1–3, 5 126-00027 T50SL7 165 4.6 34 225 6.9-7.1 0.8 2.5 PA66 Black (BK) 1–3, 5 111-85781 YQR10050 165 4.6 34 225 6.9-7.1 1.6 4.0 PA66 Brown (BN) 1–3, 5 150-48396 T80RFT6X12* 228 4.6 45 225 6.3x12.3* 0.6 3.0 PA66 Black (BK) 1–3, 5 150-48397 T80RFT6X12* 228 4.6 45 225 6.3x12.3* 0.6 3.0 PA46 Grey (GY) 1–3, 5 All dimensions in mm. Subject to technical changes. * for slotted hole drilling 89 085_113_chapter 1.3_prod 07_uk.qxp 1.3 31.07.2007 11:51 Seite 90 Cable Ties and Fixings F i x i n g Ti e s One Piece Fixing Ties with Arrowhead Technical Table Hole Ø Panel Thickness min. Panel Thickness max. Material Colour 225 6.9-7.1 1.6 4.0 PA66 Black (BK) 225 6.9-7.1 1.6 4.0 PA66 Grey (GY) 50 225 7.8-8.2 0.6 2.5 PA66 Black (BK) 4.6 34 225 7.0 – 2.5 PA66 Black (BK) 132 3.0 27.0 80 3.8-4.2 – 2.4 PA66 Natural (NA) 225 5.0 50 225 6.4-7.0 0.8 3.0 PA66 Black (BK) 225 5.0 50 225 6.4-7.0 0.8 3.0 PA66HS Black (BK) 150-26100 FBS100 115 10 27 – 6.3-6.7 0.7 3.9 PA66 Black (BK) 150-26140 FBS140 160 10 42 – 6.3-6.7 0.7 3.9 PA66 Black (BK) 150-26180 FBS185 200 10 53 – 6.3-6.7 0.7 3.9 PA66 Black (BK) Length (L) Width (W) 126-03001 YQR10016 165 4.6 34 126-03000 YQR10016 165 4.6 34 115-07010 RT50RSF 215 4.6 126-00011 RT50SL7 165 115-01900 RT18RSF 115-06960 RT50SFK 115-00024 RT50SFK Article-No. Type Bundle Min. Tensile Ø max. Strength (N) Releasable Releasable Releasable All dimensions in mm. Subject to technical changes. 90 085_113_chapter 1.3_prod 07_uk.qxp 31.07.2007 11:51 Seite 91 Cable Ties and Fixings F i x i n g Ti e s 1.3 One Piece Fixing Ties with Arrowhead in the Strap Features and Benefits The arrowhead fixing is located in the mid-section of the strap of the cable tie which ensures that the cable bundle sits directly above the fixing point, minimising the space taken. The head of the T80RSF tie is moulded in a raised position to ease assembly when the fixing is already in place in the panel. The T50SSF type has specially moulded retainers to hold battery cables parallel and firmly in place Designed to secure battery cables the T50SSF6.5 offers a simple and secure fixing. Application This range of fixing ties are ideal for use in many different industries, for example: automotive, aerospace, rail and panel building. Material Data Material Polyamide 6.6 Heat Stabilised (PA66HS) Operating Temperature -40 °C to +105 °C Continuous, (+145 °C for 500 h) Flammability UL94 V2 T80RSFT6.5FW T80SSF6.5F Material Data Material Polyamide 4.6 (PA46) Operating Temperature -40 °C to +150 °C for 5000 h, (+195 °C for 500 h) Flammability UL94 V2 T50SSF6.5 Technical Table Article-No. Type Length Width Bundle Min. Tensile (L) (W) Ø max. Strength (N) Hole Ø Panel Panel Thickness Thickness max. min. Material Colour Application Tool 150-39396 T80RSF6.5F 209 4.6 45 300 6.3-6.5 0.6 3.0 PA66 Black (BK) 1–3, 5 150-39393 T80SSF6.5F 179 4.6 43 300 6.3-6.5 0.6 3.0 PA66HS Black (BK) 1–3, 5 126-02600 T80RSF6.5F 209 4.6 45 300 6.3-6.5 0.6 3.0 PA66HS Black (BK) 1–3, 5 150-39385 T80RSF6.5FW 209 4.6 45 300 6.3-6.5 0.6 3.0 PA66HS Black (BK) 1–3, 5 150-39392 T80SSF6.5F 179 4.6 43 225 6.3-6.5 0.6 3.0 PA46 Grey (GY) 1–3, 5 150-39395 T80RSF6.5F 209 4.6 45 300 6.3-6.5 0.6 3.0 PA46 Grey (GY) 1–3, 5 All dimensions in mm. Subject to technical changes. 91 085_113_chapter 1.3_prod 07_uk.qxp 1.3 31.07.2007 11:51 Seite 92 Cable Ties and Fixings F i x i n g Ti e s One Piece Fixing Ties with Arrowhead and Disc in the strap Features and Benefits The arrowhead fixing is located in the mid-section of the strap of the cable tie which ensures that the cable bundle sits directly above the fixing point, minimising the space taken. The 'disc' on types T50SSP and T50RSP completely covers the hole in the panel minimising the ingress of dust, dirt and water. The 'discs' on all three types flex to suit variations in panel thickness, ensuring a firm but secure fixing. A particular design feature of these ties is the 'tab' on the end of the head - this is to facilitate easy location and orientation of the head for assembly. Application With a diverse range of fixing possibilities (from 5.7mm to 6.5mm hole diameters and 0.7mm to 3.5mm panel thickness) this range of fixing ties are ideal for use in many different industries, for example: automotive, aerospace, rail, and panel building. The 'tab' on the head of the tie makes it easy to locate and lift the head for assembly. Material Data Material Polyamide 6.6 Heat Stabilised (PA66HS) Operating Temperature -40 °C to +105 °C Continuous, (+145 °C for 500 h) Flammability UL94 V2 T50SSP/T50RSP Material Data Material Polyamide 4.6 (PA46) Operating Temperature -40 °C to +150 °C for 5000 h, (+195 °C for 500 h) Flammability UL94 V2, Limited Fire Hazard, Halogen free, Low smoke generation, Low generation of toxic gases and corrosive acid T80RSFT Technical Table Article-No. Type Length Width Bundle Disc (L) (W) Ø max. Ø Hole Ø Panel Panel Thickness Thickness max. min. Material Colour Application Tool 150-35932 T50SSP 120 4.6 24 18.0 225 6.0-6.5 0.7 1.3 PA66 Black (BK) 1–3, 5 150-35930 T50RSP 190 4.6 45 18.0 225 6.0-6.5 0.75 1.3 PA66 Black (BK) 1–3, 5 150-15493 T80RSFT 190 4.6 45 24.4 355 5.7-6.3 1.0 3.5 PA66 Black (BK) 1–3, 5 150-15492 T80RSFT 190 4.6 45 24.4 355 5.7-6.3 1.0 3.5 PA66HS Natural (NA) 1–3, 5 126-02500 T80RSFT 190 4.6 45 24.4 355 5.7-6.3 1.0 3.5 PA66HS Black (BK) 1–3, 5 150-15498 T80RSFT 190 4.6 45 24.4 355 5.7-6.3 1.0 3.5 PA46 Grey (GY) 1–3, 5 All dimensions in mm. Subject to technical changes. 92 Min. Tensile Strength (N) 085_113_chapter 1.3_prod 07_uk.qxp 31.07.2007 11:51 Seite 93 Cable Ties and Fixings F i x i n g Ti e s 1.3 Cable Tie and Arrowhead Mount Assemblies Features and Benefits These two piece fixing ties are supplied ready assembled and offer a simple and versatile method of bundling and fixing cables, pipes and hoses. The arrowhead base will easily push into pre-punched holes in panels and offers a very secure fixing. The two piece design enables the head of the tie to be orientated to the required position to ease assembly, whilst the 'disc' on the top of the arrowhead takes up variation in panel thickness ensuring a stable fixing at all times. Available as either inside serrated or outside serrated 'standard' cable ties or 'double headed' ties. Application Primarily designed for fixing cable harnesses in the automotive industry, their simplicity and ease of use has resulted in these parts being used in other industries, for example: aviation, switch-gear manufacturers, white goods manufacturers. Being a two piece assembly allows the tie head to be located in the most convenient position. Other dimensions available, please contact us for further information. Two piece fixing tie with moveable arrowhead. Material Data Material Data Material Colour Polyamide 6.6 High Impact Modified, Heat Stabilised (PA66HIRHS) Material Colour Black (BK) Operating Temperature -40 °C to +105 °C Flammability UL94 HB Polyamide 6.6 Heat Stabilised (PA66HS) Black (BK) Operating Temperature -40 °C to +105 °C Continuous, (+145 °C for 500 h) Flammability UL94 V2 Technical Table Panel Panel Thickness Thickness max. min. Material Length (L) Width (W) Bundle Ø max. Disc Ø Min. Tensile Strength (N) Hole Ø Cable Tie Foot Part 150-13593 T50SSFT6.5 150 4.6 31 22.4 225 6.3-6.7 0.7 2.0 PA66HS PA66HS 150-13591 T50RSFT6.5 200 4.6 45 22.4 225 6.3-6.7 0.9 2.0 PA66HS PA66HS 150-37691 T50RSFT6.5D18 200 4.6 45 18.0 225 6.5-6.8 0.4 1.6 PA66HS PA66HIRHS 117-05160 T50RDHSFT6.5 210 4.7 45 22.4 225 6.3-6.7 0.7 2.0 PA66HS PA66HS 150-13596 T80ISFT6.5 300 4.6 81 22.4 355 6.3-6.7 0.7 2.0 PA66HS PA66HS Article-No. Type All dimensions in mm. Subject to technical changes. 93 085_113_chapter 1.3_prod 07_uk.qxp 1.3 31.07.2007 11:51 Seite 94 Cable Ties and Fixings F i x i n g Ti e s Rivet Fixing Ties Features and Benefits These ties are simply installed by pushing the rivet part of the tie into a hole and firmly tapping the rivet pin until flush to the surface. The pin expands the wings of the rivet and the tie is firmly locked in place. All three versions listed are releasable and reusable allowing for the removal or addition of cables after installation. The RELF and RI ranges are conventional 'serrated' cable ties, whilst the FBR range have a 'ladder-type' design which is locked by stretching the strap over the head of the tie. The design of the FBR gives a very flexible strap. FBR cable ties have a flexible 'ladder' design of strap - Ideal for secure fixing into thin panels (up to 2.5mm thick). Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °C to +85 °C Continuous, (+105 °C for 500 h) Flammability UL94 V2 Material Data Material Polyamide 12 (PA12) Operating Temperature -40 °C to +85 °C Continuous, (+105 °C for 500 h) Flammability UL94 HB Fixing ties type FBR Fixing ties type RELF Material Data Material Polyamide 6.6 High Impact Modified (PA66HIR) Operating Temperature -40 °C to +80 °C Continuous, (+105 °C for 500 h) Flammability UL94 HB Fixing ties type RI Technical Table Article-No. Type Length Width Bundle Min. Tensile (L) (W) Ø max. Strength (N) Panel Thickness Panel Thickness min. max. Material Colour 150-27100 FBR6/100 115 10.0 27 – 6.2-6.5 0.8 2.4 PA66 Black (BK) 150-27140 FBR6/140 160 10.0 42 – 6.2-6.5 0.8 2.4 PA66 Black (BK) 150-27180 FBR6/185 200 10.0 53 – 6.2-6.5 0.8 2.4 PA66 Black (BK) 150-27110 FBR7/100 115 10.0 27 – 7.2-7.5 0.8 2.4 PA66 Black (BK) 150-27150 FBR7/140 160 10.0 42 – 7.2-7.5 0.8 2.4 PA66 Black (BK) 150-27190 FBR7/185 200 10.0 53 – 7.2-7.5 0.8 2.4 PA66 Black (BK) 131-31710 RELF170 180 8.0 44 180 6.5 2.5 2.5 PA66 Black (BK) 115-40902 RELF170 180 8.0 44.0 180 6.3 2.5 2.5 PA66HIR Black (BK) 131-14080 RI 80 80 7.0 16 265 6.9-7.1 0.8 2.2 PA12 Black (BK) 131-14120 RI 120 120 9.0 28 265 6.9-7.1 0.8 2.2 PA12 Black (BK) 131-14160 RI 160 160 9.0 41 265 6.9-7.1 0.8 2.2 PA12 Black (BK) All dimensions in mm. Subject to technical changes. 94 Hole Ø 085_113_chapter 1.3_prod 07_uk.qxp 31.07.2007 11:51 Seite 95 Cable Ties and Fixings F i x i n g Ti e s 1.3 One Piece Fixing Ties with Fir Tree Mount Features and Benefits This one piece cable tie with fir tree fixing offers a simple and easy to use method of bundling and fixing cables, pipes and hoses. The design of the fir tree ensures a positive and secure fixing into panels from 0.8mm to 7.0mm deep or threaded blind holes. The 'disc' on the top of the fir tree covers the hole and minimises the ingress of dust, dirt and water. Type REL are releasable and reusable and are ideal for the removal or addition of cables after the initial installation is completed. Application Primarily designed for fixing cable harnesses in the automotive industry their simplicity and ease of use has resulted in these parts being used in many other industries, for example: aviation, switch-gear manufacture and white goods. Ideal for use in deep panels and threaded, blind holes. Material Data Material Operating Temperature Polyamide 6.6 (PA66) -40 °C to +85 °C Continuous, (+105 °C for 500 h) Flammability UL94 V2 Common head/fixing design. Material Data Material One piece fixing tie with fir tree mount Polyamide 6.6 Heat Stabilised (PA66HS) Operating Temperature -40 °C to +105 °C Continuous, (+145 °C for 500 h) Flammability UL94 V2 Special design without a gap between head and bundle; FT220DP7. Technical Table Panel Panel Thickness Thickness max. min. Length (L) Width (W) Bundle Ø max. Disc Ø Min. Tensile Strength (N) Hole Ø Material Colour 150-55610 T18RDP5 110 2.5 20 13.0 80 4.9-5.1 3.0 4.0 PA66 Black (BK) Article-No. Type 155-05800 T50SOSFT6E 160 4.6 35 – 150 6.5-7.0 0.75 3.0 PA66HIRHS Black (BK) 157-01104 T50SDP6 170 5.0 31 22.0 180 6.3-7.1 0.8 7.0 PA66 Natural (NA) 150-55550 T50SDP6 170 5.0 31 22.0 180 6.3-7.1 0.8 7.0 PA66HS Black (BK) 150-01700 FT220DP7 230 4.7 40 16.0 225 6.8-7.2 0.8 5.0 PA66 Black (BK) 170 5.0 31 22.0 135 6.3-7.0 3.0 7.0 PA66 Black (BK) Releasable 150-55500 REL30SDP6 All dimensions in mm. Subject to technical changes. 95 085_113_chapter 1.3_prod 07_uk.qxp 1.3 31.07.2007 11:51 Seite 96 Cable Ties and Fixings F i x i n g Ti e s Cable Tie and Fir Tree Mount Assemblies Features and Benefits These two piece fixings are supplied ready assembled and offer a simple and versatile method of bundling and fixing cables. The fir tree base will easily push into prepunched holes in panels or threaded, blind holes, and offers a very secure fixing. The two piece design enables the head of the tie to be orientated to the required position to ease assembly, whilst the 'disc' on the top of the fir tree covers the hole and minimises the ingress of dust, dirt and water. Application These Fir Tree fixings can also be used in threaded, blind holes. Primarily designed for fixing cable harnesses in the automotive industry their simplicity and ease of use, has resulted in these parts being used in many industries, for example: aviation, switch gear manufacture and Other dimensions available on request. Please contact us. white goods. One piece fixing tie with fir tree mount Technical Table Article-No. Type Min. Tensile Length Width Bundle Disc Strength (N) (L) (W) Ø max. Ø Hole Ø Colour Cable Tie Foot Part Black (BK), Grey (GY) PA66HS PA66 150-55940 T30RFT5 150 3.6 31 16.0 135 4.5-5.0 0.7 3.0 150-55850 T30RFT5 148 3.6 35 16.0 135 4.5-5.0 0.7 3.0 Black (BK) PA66HS PA66HIRHS PA46 PA46 150-55948 T30RFT5 150 3.6 31 16.0 135 4.5-5.0 0.7 3.0 Natural (NA), Grey (GY) 150-55942 T30LRFT5 260 3.3 61 16.0 180 4.5-5.0 0.7 3.0 Black (BK), Grey (GY) PA66HS PA66 150-55941 T50RFT5 200 4.6 45 16.0 225 4.5-5.0 0.7 3.0 Black (BK), Grey (GY) PA66HS PA66 156-00025 T50RFT5 200 4.6 45 16.0 225 4.5-5.0 0.7 3.0 Black (BK) PA66HS PA66HIRHS PA66HS PA66 150-55943 T50SFT5 150 4.6 31 16.0 225 4.5-5.0 0.7 3.0 Black (BK), Grey (GY) 150-09110 T18RFT6 100 2.5 20 16.0 80 6.4-7.1 0.75 3.0 Black (BK) PA66 PA66 150-77935 T18RFT6 100 2.5 20 16.0 80 6.4-7.1 0.75 3.0 Black (BK) PA66W PA66 150-31097 T30LFT6LG 190 3.6 45 16.0 135 6.4-7.1 0.75 6.0 Black (BK) PA66 PA66HIRHS 150-77932 T30LRFT6 260 3.3 65 16.0 180 6.4-7.1 0.75 3.0 Black (BK) PA66HS PA66HIRHS 150-77950 T30RFT6 150 3.6 31 16.0 135 6.4-7.1 0.75 3.0 Black (BK) PA66HS PA66HIRHS 150-31090 T30RFT6LG 148 3.6 35 16.0 135 6.4-7.1 0.75 6.0 Black (BK) PA66HS PA66HIRHS 150-77936 T50RDHFT6 210 4.7 19 16.0 225 6.4-7.1 0.75 3.0 Black (BK) PA66HS PA66HIRHS 156-05308 T50RFT6 200 4.6 45 16.0 225 6.4-7.1 0.75 3.0 Black (BK) PA66 PA66 150-77938 T50RFT6 200 4.6 45 16.0 225 6.4-7.1 0.75 3.0 Grey (GY) PA46 PA46 150-77941 T50RFT6 200 4.6 45 16.0 225 6.4-7.1 0.75 3.0 Black (BK) PA66HS PA66 156-05300 T50RFT6 200 4.6 45 16.0 225 6.4-7.1 0.75 3.0 Black (BK) PA66HS PA66HS 150-31091 T50RFT6LG 200 4.6 44 16.0 225 6.4-7.1 0.75 6.0 Black (BK) PA66HS PA66HIRHS 156-00076 T50ROSFT6 200 4.6 45 16.0 225 6.4-7.1 0.75 3.0 Black (BK) PA66HS PA66HIRHS 156-01500 T50SFT6 150 4.6 31 16.0 225 6.4-7.1 0.75 3.0 Black (BK) PA66 PA66 All dimensions in mm. Subject to technical changes. 96 Material Panel Panel Thickness Thickness max. min. 085_113_chapter 1.3_prod 07_uk.qxp 31.07.2007 11:51 Seite 97 Cable Ties and Fixings F i x i n g Ti e s 1.3 Cable Tie and Fir Tree Mount Assemblies Material Data Material Polyamide 6.6 High Impact Modified, Heat Stabilised (PA66HIRHS) Operating Temperature -40 °C to +105 °C Flammability UL94 HB One piece fixing tie with fir tree mount Material Data Material Polyamide 6.6 Heat Stabilised (PA66HS) Operating Temperature -40 °C to +105 °C Continuous, (+145 °C for 500 h) Flammability UL94 V2 Other dimensions available on request. Please contact us for further information. Technical Table Article-No. Type Min. Tensile Length Width Bundle Disc Strength (N) (L) (W) Ø max. Ø Material Hole Ø Panel Panel Thickness Thickness max. min. Colour Cable Tie 150-77933 T50SFT6 150 4.6 31 16.0 225 6.4-7.1 0.75 3.0 Black (BK) PA66HS Foot Part PA66 150-31093 T50SFT6LG 160 4.6 35 16.0 225 6.4-7.1 0.75 6.0 Black (BK) PA66HS PA66HIRHS 156-05902 T50ROS-FT6-SD 200 4.6 46 16.0 225 6.4-7.1 0.75 3.0 Black (BK) PA66HS PA66HIR 150-77934 T80LFT6 390 4.6 108 16.0 355 6.4-7.0 0.75 3.0 Black (BK) PA66HS PA66HIRHS 150-77937 T80IFT6 300 4.6 81 16.0 355 6.4-7.1 0.75 3.0 Black (BK) PA66HS PA66HIRHS 150-31096 T80IFT6LG 300 4.6 81 16.0 355 6.4-7.1 0.75 6.0 Black (BK) PA66HS PA66HIRHS 156-01503 T50SFT7 160 4.6 31 16 225 6.5-7.0 0.8 7.0 Black (BK) PA66 PA66 111-85870 T50RFT7 200 4.6 45 16.0 225 6.5-7.0 0.8 7.0 Black (BK) PA66 PA66 156-05312 T50RFT7 200 4.6 45 16.0 225 6.5-7.0 0.8 7.0 Black (BK) PA66 PA66 156-05311 T50RFT7 200 4.6 45 16.0 225 6.5-7.0 0.8 7.0 Black (BK) PA66HS PA66HS 111-05350 T50IFT7 300 4.6 85 16 225 6.5-7.0 0.8 7.0 Black (BK) PA66 PA66 156-00903 T50IFT7 300 4.6 81 16.0 225 6.5-7.0 0.8 7.0 Black (BK) PA66 PA66 150-00700 T50IFT7 300 4.6 81 16.0 225 6.5-7.0 0.8 7.0 Black (BK) PA66HS PA66HS 156-05320 T50RFT8 200 4.6 45 16.0 225 7.7-8.0 0.8 6.0 Black (BK) PA66 PA66 111-85880 T50RFT8 200 4.6 45 16.0 225 7.7-8.0 0.8 6.0 Black (BK) PA66HS PA66HS 156-00044 T50RFT8 200 4.6 45 16.0 225 7.7-8.0 0.8 6.0 Black (BK) PA66HS 156-00200 T120IFT9 300 7.6 75 20.0 535 8.8-9.4 4.0 8.0 Black (BK) PA66HIR(S) 156-05301 T50RFT10 200 4.6 45 18.0 225 9.7-10.0 0.8 5.0 Black (BK) PA66 PA66 111-85810 T50RFT10 200 4.6 45 18.0 225 9.7-10.0 0.8 5.0 Black (BK) PA66HS PA66HS PA66HS PA66HIR(S) All dimensions in mm. Subject to technical changes. 97 085_113_chapter 1.3_prod 07_uk.qxp 1.3 31.07.2007 11:52 Seite 98 Cable Ties and Fixings F i x i n g Ti e s T50SOSSBH5E This cable tie offers three distinct benefits to the user. Firstly it offers the opportunity to retain insulation material. Secondly, it allows cables, pipes or hoses to be bundled. Thirdly it has a simple “soft push“ mechanism which allows it to be installed onto a weld stud without the use of any tools. The unique head design allows the cable tie to firmly hold bundles as small as 1.6 mm diameter. T50SOSSBH5E The new head design offers additional fixing of soft materials. Technical Table Article-No. Type 155-05701 T50SOSSBH5E Length (L) Width (W) 165 4.6 Bundle Min. Tensile Strength Ø max. (N) 35 225 Stud Ø Material Colour 5 PA66HS Black (BK) All dimensions in mm. Subject to technical changes. T50SSBS50TE Using the “soft push“ technology, this inside serrated tie is mounted on the top of the stud. The additional height gained by this design gives a clear “stand off“ from the panel. Ideal applications include mass transit industries, panel builders, and white goods manufacturers. The T50SSBS50TE allows very precise routing of cable bundles. T50SSBS50TE Technical Table Article-No. Type 155-30602 T50SSBS50TE* Length (L) Width (W) 160 4.6 Bundle Min. Tensile Strength Ø max. (N) 35 200 Stud Ø Material Colour 5 PA66HS Black (BK) All dimensions in mm. Subject to technical changes. * Since the bundled cables lie directly above or on the weld stud, care must be taken to ensure that the length of the weld stud does not exceed the height of the sheath. To avoid damage, we recommend a maximum weld stud length of 16.5 mm. 98 085_113_chapter 1.3_prod 07_uk.qxp 31.07.2007 11:52 Seite 99 Cable Ties and Fixings F i x i n g Ti e s 1.3 T50SOSSB5HEC T50SOSSB6 High E The special oval shape of the fixing on this stud mounted fixing tie provides a 5-6mm lateral adjustment to cater for any misalignment of the stud or incorrect positioning of the tie on the cables. The simple “soft push“ mechanism allows for easier installation onto a weld stud without the use of any tools. This outside serrated cable tie with weld stud mounting keeps the cables close to the fixing stud. T50SOSSB5HEC T50SOSSB6HE T50SOSSBS5E Providing an especially strong fixing method, the design of this fixing tie offers the “soft push“ mounting technology with the ability to mount the cables very close to the fixing stud. The outside serrations present a smooth surface to the cables preventing chafe and damage to the insulation, especially in mass transit applications. T50SOSSBS5E Technical Table Length (L) Width (W) Material Colour 155-05400 T50SOSSB5HEC 160 4.6 35 170 5 PA66HS Black (BK) 155-46302 T50SOSSB6HE 160 4.6 35 170 6 PA66HS Black (BK) 155-12300 T50SOSSBS5E 160 4.6 35 225 5 PA66HS Black (BK) 155-23601 T50SOSWSP5E 163 4.6 35 200 5 PA66HS Black (BK) Article-No. Type Bundle Min. Tensile Strength Stud Ø max. (N) Ø All dimensions in mm. Subject to technical changes. T50SOSWSP5E The unique shape of the head on this fixing tie provides a 5-6mm lateral adjustment to cater for any misalignment of the stud or incorrect positioning of the tie on the cables. The low profile of the fixing allows for several ties to be installed one on top of the other on the same stud, to accommodate different cable routings. This is both space saving and versatile. T50SOSWSP5E, parallel installation using two fixing ties. T50SOSWSP5E 99 085_113_chapter 1.3_prod 07_uk.qxp 1.3 31.07.2007 11:52 Seite 100 Cable Ties and Fixings F i x i n g Ti e s Wide Strap Heavy Duty Stud Mount Cable Ties Features and Benefits The wide strap stud mount cable tie minimizes pinching on soft bundles and features a low profile head to provide compact bundling. A thinner strap provides increased flexibility for improved ergonomics. Available with a 6mm and 9mm stud mount, the wide strap tie utilizes a strong hinge between the stud mount and head to provide superior holding ability on a threaded stud. • Wide strap to minimize pinching of soft hoses and convoluted tubing • Clamping rails to increase grip on round bundles • Wide variation of bundle diameters: 9.5mm - 104.7mm • Flexible strap • Flexible hinge • Mount provides low insertion and high extraction forces The wide strap stud mount cable tie minimizes pinching on soft bundles. Application Primarily designed for use in the automotive- or truck industry, these parts can be used in a wide variety of industries and applications where 6mm/9mm weld studs or 6mm/9mm ISO bolts are used and cables need to be bundled and secured. Wide Strap Heavy Duty Stud Mount Cable Ties Material Data Material Material Data Material Polyamide 6.6 High Impact Modified, Heat Stabilised (PA66HIRHS) Polyamide 6.6 High Impact Modified, Heat and UV Stabilised (PA66HIRHSW) Operating Temperature -40 °C to +110 °C Operating Temperature -40 °C to +110 °C Flammability UL94 HB Flammability UL94 HB Material Colour Black (BK) Technical Table Length Article-No. Type (L) Wide Strap Ties with 6mm Stud Mount Width (W) 157-00400 WSS250 246 12.7 157-00401 WSI250 322 157-00402 WSR250 398 Bundle Min. Tensile Strength Ø max. (N) 57 534 PA66HIRHSW 12.7 82 534 PA66HIRHSW Black (BK) 12.7 104 534 PA66HIRHS Black (BK) Wide Strap Ties with 9mm Stud Mount 157-00406 WSS380 246 12.7 57 534 PA66HIRHS Black (BK) 157-00403 WSS380 246 12.7 57 534 PA66HIRHS Black (BK) 157-00407 WSI380 322 12.7 82 534 PA66HIRHS Black (BK) 157-00404 WSI380 322 12.7 82 534 PA66HIRHS Black (BK) 157-00408 WSR380 398 12.7 104 534 PA66HIRHS Black (BK) 157-00405 WSR380 398 12.7 104 534 PA66HIRHS Black (BK) All dimensions in mm. Subject to technical changes. 100 085_113_chapter 1.3_prod 07_uk.qxp 31.07.2007 11:52 Seite 101 Cable Ties and Fixings F i x i n g Ti e s 1.3 Cable Ties for Weld Studs Features and Benefits This one piece cable tie and fixing offers a simple and easy to use method of bundling and fixing cables, pipes and hoses. The design of the stud fixing ensures simple mounting while giving a positive and secure fixing. A variety of designs gives the choice of a soft 'push fit' or 'hammer fit'. Both designs give excellent 'pull off' forces in relation to the application forces. FBB one piece fixing ties for weld studs, can be easily removed by unscrewing in an anti-clockwise direction. Material Data Material Data Material Material Polyamide 4.6 (PA46) Operating Temperature -40 °C to +150 °C for 5000 h, (+195 °C for 500 h) Flammability UL94 V2, Limited Fire Hazard, Halogen free, Low smoke generation, Low generation of toxic gases and corrosive acid Polyamide 6.6 Heat Stabilised (PA66HS) Operating Temperature -40 °C to +105 °C Continuous, (+145 °C for 500 h) Flammability UL94 V2 Technical Table Article-No. Type Length (L) Width (W) Bundle Ø max. Min. Tensile Strength (N) Material Colour 150-28100 FBB100 110 10 23 – PA66 Black (BK) 150-28140 FBB140 142 10 38 – PA66 Black (BK) 150-28180 FBB185 200 10 50 – PA66 Black (BK) 150-29100 FBB100M 110 10.0 23 – PA66 Black (BK) 150-29140 FBB140M 145 10.0 38 – PA66 Black (BK) 150-29180 FBB185M 200 10.0 50 – PA66 Black (BK) 151-01000 SBR5 220 6.0 40 300 PA66 Black (BK) 131-60060 SBR5 220 6.0 40 300 PA66HS Black (BK) 131-60058 SBR8S 215 6.0 40 300 PA46 Grey (GY) All dimensions in mm. Subject to technical changes. 101 085_113_chapter 1.3_prod 07_uk.qxp 1.3 31.07.2007 11:52 Seite 102 Cable Ties and Fixings F i x i n g Ti e s Dual Clamp Ties Features and Benefits Dual clamp ties are designed to provide parallel separation between hoses, wires, cables and tubing, protecting them from abrasion. These ties have an optional mounting hole for securing bundles along the chassis of trucks, trailers, and heavy duty equipment. The unique, one-piece design features the dual head centered on the strap. Available in two lengths, the dual clamp ties accommodate bundles ranging from 6 mm to 58 mm. The flexible wide straps minimize pinching of hoses and convoluted tubing. The straps are also releasable. Application Primarily designed for use in the automotive/truck industry, these parts can be used in a wide variety of industries and applications where 6mm/9mm weld studs or 6mm/9mm ISO bolts are used and cables need to be bundled and secured. Dual clamp ties are designed to provide parallel separation between hoses, wires, cables and tubing, protecting them from abrasion. Material Data Material Polyamide 6.6 High Impact Modified (PA66HIR) Operating Temperature -40 °C to +80 °C Continuous, (+105 °C for 500 h) Flammability UL94 HB Dual Clamp Ties Technical Table Length (L) Width (W) Bundle Ø max. Min. Tensile Strength (N) Stud Ø Material Colour 115-00034 DCT9 330 12.7 33 670 6.35 PA66HIR Black (BK) 115-00033 DCT11 489 12.7 58 670 6.35 PA66HIR Black (BK) Article-No. Type All dimensions in mm. Subject to technical changes. 102 085_113_chapter 1.3_prod 07_uk.qxp 31.07.2007 11:52 Seite 103 Cable Ties and Fixings F i x i n g Ti e s 1.3 Standoff Mounting Dual Clamp Ties Features and Benefits HellermannTyton’s standoff dual clamp tie offers the same features as the standard dual clamp tie with a standoff mount that secures the bundle away from the side of the frame rail, protecting the bundles from bolts and other protrusions. • Wide strap minimizes pinching of soft hoses & convoluted tubing • Clamping rails increase circumferential grip on varying bundle diameters • Locking stud mount pawls allow for easy hand insertion • Nut or weld nesting counter bore provides flush mounting at the base • Socket counter bore for fastening a nut provides added retention Application Primarily designed for use in the automotive/ truck industry, these parts can be used in a wide variety of industries and applications where bundles need a standoff mounting position. Standoff Mounting Dual Clamp Ties. Material Data Material Polyamide 6.6 High Impact Modified, Heat and UV Stabilised (PA66HIRHSW) Operating Temperature -40 °C to +110 °C Flammability UL94 HB Standoff Mounting Dual Clamp Ties Technical Table Article-No. Type 117-00012 SDCTR312 Length (L) Width (W) Bundle Ø max. Min. Tensile Strength (N) Stud Ø Material Colour 511 12.7 58 445 8 PA66HIRHSW Black (BK) All dimensions in mm. Subject to technical changes. 103 085_113_chapter 1.3_prod 07_uk.qxp 1.3 31.07.2007 11:52 Seite 104 Cable Ties and Fixings F i x i n g Ti e s Cable Ties for Weld Studs Features and Benefits These weld stud fixing ties are designed to be fitted onto 5mm studs or 5mm ISO threaded studs. The types T50RS5, RT50RS5 and SBS9/230 are designed to be applied by hand (Soft Push). Types SB14 and SB9 are designed to be hammered onto the stud (Hard Push). Both types give excellent 'pull-off' forces in relation to the application forces. With the RT50RS5 and the SB14/172 you can mount pipes or cables to a weld stud. Material Data Material Colour Polyamide 6.6 (PA66) Black (BK) Operating Temperature -40 °C to +85 °C Continuous, (+105 °C for 500 h) Flammability UL94 V2 Simple fixing to a weld stud or 5mm ISO bolt. Technical Table Article-No. Type Length (L) Width (W) Height Bundle Min. Tensile (H2) Ø max. Strength (N) Material 111-07110 T50RS5 190 4.6 14.5 40 225 PA66 Black (BK) 115-07110 RT50RS5 190 4.6 14.5 40 225 PA66 Black (BK) 150-10901 SBS9/230 230 5.0 10.0 60 245 PA66 Black (BK) 131-80050 SB9/172 172 5.0 10.0 40 245 PA66 Black (BK) 150-10900 SB9/230 230 5.0 10.0 60 245 PA66 Black (BK) 150-10690 SB14/172 172 5.0 15.5 40 245 PA66 Black (BK) 150-11400 SB14/230 230 5.0 15.5 60 245 PA66 Black (BK) All dimensions in mm. Subject to technical changes. 104 Colour 085_113_chapter 1.3_prod 07_uk.qxp 31.07.2007 11:52 Seite 105 Cable Ties and Fixings F i x i n g Ti e s 1.3 Cable Tie and Weld Stud Fixing Assemblies Features and Benefits These two piece fixing ties consist of the cable tie from the 'inside' or 'outside serrated' series with the foot part for fixing to weld studs already mounted on the strap. They are easy to press onto a 5mm type weld stud (also suitable for M5 screws) without the need for separate application tools. Because the foot part slides along the cable tie, the head can be rotated into the best position both during fitting and also for installation. Series SBH5 and SBH5SD features a flat plate on the foot part which can simultaneously fix an insulation mat. Series SB5 and SBS5 have a cable guide on the weld stud. Series SB5 has an oval weld stud for equalisation of the cable loom if out of line with the main loom. Cable ties illustrating the variety of application methods for weld stud fixing. Application Series SBH5 and SBH5SD are used mainly in the automotive industry. The SD variant is for the smallest bundle diameters, from 1.0 mm. Suitable for bundling and fastening cables, pipes and hoses in a multitude of industries, for example: switch gear manufacture, automotive and machine manufacture. Technical Table Length (L) Width (W) Bundle Ø max. Disc Ø Min. Tensile Strength (N) 150-16941 T30RSBH5 150 3.5 31 30.0 135 PA66HS 150-16942 T40RSBH5 175 PA66HS 1–3, 5 4.0 40 30.0 180 PA66HS PA66HS 150-16943 T50RSBH5 1–3, 5 200 4.6 45 30.0 225 PA66HS PA66HS 1–5 156-05905 T50ROSSBH5SD 200 4.6 45 30.0 225 PA66HS PA66HS 1–5 150-16945 T80ISBH5 300 4.6 81 30.0 355 PA66HS PA66HS 1–5 Article-No. Type SBH5 Material Cable Tie Foot Part Application Tool SBH5SD Other dimensions available on request. Please contact us for further information. 150-21290 T30RSBS5 150 3.5 31 – 135 PA66HS PA66HS 150-21299 T50ROSSBS5 200 4.6 45 – 225 PA66HS PA66HS 1–5 150-21291 T50RSBS5 200 4.6 45 – 225 PA66HS PA66HS 1–5 1–3, 5 150-21293 T50SSBS5 150 4.6 31 – 225 PA66HS PA66HS 1–5 150-21297 T80ISBS5 300 4.6 81 – 355 PA66HS PA66HS 1–5 150-10140 T30RSB5 150 3.5 31 – 135 PA66HS POM 1–3, 5 150-10142 T40RSB5 175 4.0 38 – 180 PA66HS POM 1–3, 5 150-10144 T50SSB5 150 4.6 31 – 225 PA66HS POM 1–5 150-10141 T50RSB5 200 4.6 45 – 225 PA66HS POM 1–5 150-10149 T50ROSSB5 200 4.6 45 – 225 PA66HS POM 1–5 All dimensions in mm. Subject to technical changes. 105 085_113_chapter 1.3_prod 07_uk.qxp 1.3 31.07.2007 11:52 Seite 106 Cable Ties and Fixings F i x i n g Ti e s Double Mounting Base For Weld Studs Features and Benefits These are three part fixing ties, with a stud fix mounting base and two cable ties. The mounting base can be fitted to the weld stud prior to installing the cables, the cables are simply laid alongside the base and the cable ties then pulled tight. Having two separate 'cradles' allows for the installation of the two cable runs at different times. The design of the stud retainer means excessive force is not required for installation - it is simply a 'soft push' action by hand. Having separate ties to the fixing means that the head of the tie can be easily rotated to ensure the easiest possible assembly. Parallel fixation of two cables. Application Many applications require cables to be run parallel to each other but separated to avoid abrasion, the double mounting base, when used with two cable ties allow this to be achieved simply and quickly. Widely used for securing cables, pipes and hoses in the automotive and truck building industries, the mounting base is simply pushed onto a 5mm diameter weld stud or bolt. Application Tool MK3SP 1 MK3PNSP2, MK7P 2 MK7 3 MK7HT 4 MK20 5 MK6 6 MK9P, MK6PN 7 MK9 8 MK9HT Other dimensions available on request. Please contact us for further information. Registration Numbers 9 MK21 10 For more information, please turn to page 388. T50SDSBS5, T50ROSDSBS5 Technical Table Length (L) Width (W) Bundle Ø max. Min. Tensile Strength (N) Stud Ø 150-56193 T50SDSBS5 150 4.6 31 225 5.0 PA66HS 150-56199 T50ROSDSBS5 200 4.6 45 225 5.0 PA66HS Article-No. Type Material Cable Tie Foot Part Colour Application Tool PA66HIRHS Black (BK) 1–5 PA66HIRHS Black (BK) 1–5 All dimensions in mm. Subject to technical changes. Material Data Cable Tie 106 Material Data Polyamide 6.6 Heat Stabilised (PA66HS) Operating Temperature -40 °C to +105 °C Continuous, (+145 °C for 500 h) Flammability UL94 V2 Foot Part Polyamide 6.6 High Impact Modified, Heat Stabilised (PA66HIRHS) Operating Temperature -40 °C to +105 °C Flammability UL94 HB 085_113_chapter 1.3_prod 07_uk.qxp 31.07.2007 11:52 Seite 107 Cable Ties and Fixings F i x i n g Ti e s 1.3 T50SVC5 This simple to use inside serrated tie provides the opportunity to attach an additional 5mm diameter cable, pipe or hose to an existing bundle. Offering the facility of a full 360 degrees of rotation, the second bundle can be orientated in any direction in relation to the main harness. Ideally suited for any application where the cable, pipe or hose can move in relation to the fixing point. T50SVC5 T50SVC5 rotates in any direction. Material Data Cable Tie Polyamide 6.6 Heat Stabilised (PA66HS) Operating Temperature -40 °C to +105 °C Continuous, (+145 °C for 500 h) Flammability UL94 V2 Application in automotive industries. Technical Table Article-No. Type 155-31202 T50SVC5 Length (L) Width (W) Bundle Ø max. Min. Tensile Strength (N) Attach to Ø Material Colour 155 4.7 35 225 4.5 - 5.2 PA66HS Black (BK) All dimensions in mm. Subject to technical changes. 107 085_113_chapter 1.3_prod 07_uk.qxp 1.3 31.07.2007 11:52 Seite 108 Cable Ties and Fixings F i x i n g Ti e s Cable Ties and Edge Clips Features and Benefits Available with either 'inside' or 'outside' serrated ties these two piece assemblies simply push onto metal or plastic 'edges' with thicknesses from 1.0 to 3.0mm and from 3.0 to 6.0mm. The high 'pull off' forces are due to the integrated metal clamp. Different Edge Clip variations are available. One version allows for cables to run parallel to the metal/plastic edge, whilst another allows for installation at 90 degrees to the metal edge. The clip is simply pushed on by hand and held firmly in place by the integrated metal clamp. No fixing hole is necessary. Combined with the outside serrated (OS) ties, specially designed to protect cables from chafing (see section 1.1) and wear, the Edge Clip family provides an excellent fastening solution. T50ROSEC10 fitted onto a plastic panel to hold a Ø 6mm harness. Application These cable ties and Edge Clip assemblies are ideal for use where holes are not acceptable or where due to temperature problems adhesives will fail. These assemblies are widely used for fixing and bundling cables, pipes and hoses within the automotive industry, harness making, panel buidling and electrical industry. T50ROSEC5B - the cable runs 90 degrees to the edge. T50ROSEC4A - the cable bundle runs across the edge. Material Data For more Edge Clip products please see Chapter 1.4 page 127. Material Colour Polyamide 6.6 Heat Stabilised (PA66HS) Black (BK) Operating Temperature -40 °C to +105 °C Continuous, (+145 °C for 500 h) Flammability UL94 V2 Material Data Material Colour 108 Polyamide 6.6 High Impact Modified, Heat Stabilised (PA66HIRHS) Black (BK) Operating Temperature -40 °C to +105 °C Flammability UL94 V2 085_113_chapter 1.3_prod 07_uk.qxp 31.07.2007 11:52 Seite 109 Cable Ties and Fixings F i x i n g Ti e s 1.3 Cable Ties and Edge Clips for Panel Thickness 1.0 to 3.0mm With the Edge Clip family the bundled cables can be located either above or to the side of a fixing. In all two piece mounting ties, the edge clip moves freely along the tie. This allows the head of the tie to be rotated during mounting for installation in the ideal position. Technical Table Length Article-No. Type (L) Two piece, panel thickness 1.0 - 3.0 mm Width (W) Bundle Ø max. Min. Tensile Strength (N) Material Cable Tie Foot Part Application Tool 150-76090 T30REC4A 150 3.5 33 135 PA66HS PA66HIRHS 1–3, 5 150-76099 T50ROSEC4A 200 4.6 45 225 PA66HS PA66HIRHS 1–5 150-76080 T30REC4B 150 3.5 33 135 PA66HS PA66HIRHS 1–3, 5 150-76079 T50ROSEC4B 200 4.6 45 225 PA66HS PA66HIRHS 1–5 150-40591 T50ROSEC5A 200 4.6 45 225 PA66HS PA66HIRHS 1–5 150-40581 T50ROSEC5B 200 4.6 45 225 PA66HS PA66HIRHS 1–5 156-05903 T50ROSEC9SD 200 4.6 45 225 PA66HS PA66HIRHS 1–5 156-05904 T50ROSEC10SD 200 4.6 45 225 PA66HS PA66HIRHS 1–5 156-00010 T50ROSEC21 200 4.6 45 225 PA66HS PA66HIRHS 1–5 156-00011 T50ROSEC22 200 4.6 45 225 PA66HS PA66HIRHS 1–5 Drawing One piece, panel thickness 1.0 - 3.0 mm 148-00200 T50SOSEC12E 160 4.6 35 180 PA66HS PA66HS 1–5 126-00000 T50SOSEC13E 160 4.6 35 180 PA66HS PA66HS 1–5 All dimensions in mm. Subject to technical changes. 109 085_113_chapter 1.3_prod 07_uk.qxp 1.3 31.07.2007 11:52 Seite 110 Cable Ties and Fixings F i x i n g Ti e s Cable Ties and Edge Clips for Panel Thickness 3.0 to 6.0mm The Edge Clips are produced as two part mounting clips for metal or plastic edge mounting of 3.0 to 6.0mm. The 'loose' tie means the head can be rotated during fitting for installation in the best position with respect to the tie closure. Combined with our outside-serrated (OS) ties, they reduce the risk of chafe and cable damage by offering a smooth surface to the cable insulation and are suitable for minimum bundle diameters of 1.0mm. Technical Table Length Width Article-No. Type (L) (W) Two piece, panel thickness 3.0 - 6.0 mm Bundle Ø max. Min. Tensile Strength (N) Material Cable Tie Foot Part Application Tool 156-04602 T50ROSEC19 200 4.6 45 225 PA66HS PA66HIRHS 1–5 156-00020 T50ROSEC20 200 4.6 45 225 PA66HS PA66HIRHS 1–5 156-00006 T50ROSEC23 200 4.6 45 225 PA66HS PA66HIRHS 1–5 156-00007 T50ROSEC24 200 4.6 45 225 PA66HS PA66HIRHS 1–5 Drawing All dimensions in mm. Subject to technical changes. Combinations with other cable ties are possible. For further information please contact us. Application Tool MK3SP 1 MK3PNSP2, MK7P 2 MK7 3 MK7HT 4 MK20 5 MK6 6 MK9P, MK6PN 7 MK9 8 MK9HT For more Edge Clip products please see Chapter 1.4 page 127. 110 Registration Numbers MK21 9 10 For more information please turn to page 388. 085_113_chapter 1.3_prod 07_uk.qxp 31.07.2007 11:52 Seite 111 Cable Ties and Fixings F i x i n g Ti e s 1.3 New - Automation of fixing applications! It is now possible to fit fixings (sometimes known as foot parts) in conjunction with automatic cable tying. This is best suited to applications where either high volume manufacture or flexible production methods are needed. Fixing Clip ATS EC36 The footpart is placed, … Fixing Clip ATS EC35 Fir Tree ATS FT6 ... the strap is tied automatically through the head of the footpart, … Autotool System 3080. … and the harness is completely bundled including the footpart. 111 085_113_chapter 1.3_prod 07_uk.qxp 1.3 31.07.2007 11:52 Seite 112 Cable Ties and Fixings F i x i n g Ti e s MR range of Mounting Head Ties Features and Benefits A one piece bundling and fixing tie offering quick and easy installation. Application This range of one piece cable ties has a mounting hole fixing method. Once fastened around the cables the bundle can be simply secured to the panel with a screw or bolt. Ideal for fixing cables, pipes and hoses onto solid surfaces with pre-drilled holes or holes in metal plates. These ties are used in many industries, for example: building construction, panel builders and white goods manufacturers. The mounting head ties can be easily screwed onto a panel. Material Data Material Data Material Material Polyamide 6.6 UV Resistant (PA66W) Polyamide 6.6 Heat Stabilised (PA66HS) Operating Temperature -40 °C to +85 °C Continuous, (+105 °C for 500 h) Operating Temperature -40 °C to +105 °C Continuous, (+145 °C for 500 h) Flammability UL94 V2 Flammability UL94 V2 Technical Table Article-No. Type Length (L) Width (W) Bundle Ø max. Min. Tensile Strength (N) Hole Ø Material Colour Application Tool 1–3, 5 113-01819 T18MR 110 2.5 20 80 3.1 PA66 Natural (NA) 113-01810 T18MR 110 2.5 20 80 3.1 PA66 Black (BK) 1–3, 5 113-01801 T18MR 110 2.5 20 80 3.1 PA66HS Natural (NA) 1–3, 5 113-03019 T30MR 160 3.5 32 135 4.3 PA66 Natural (NA) 1–3, 5 113-03020 T30MR 160 3.5 32 135 4.3 PA66 Natural (NA) 1–3, 5 113-03010 T30MR 160 3.5 32 135 4.3 PA66 Black (BK) 1–3, 5 113-00004 T30MR 160 3.5 32 135 4.3 PA66 Black (BK) 1–3, 5 113-00006 T30MR 160 3.5 32 135 4.3 PA66W Black (BK) 1–3, 5 113-03160 T30MR 160 3.5 32 135 4.3 PA66W Black (BK) 1–3, 5 113-05019 T50MR 215 4.7 45 225 5.4 PA66 Natural (NA) 1–10 113-05010 T50MR 215 4.7 45 225 5.4 PA66 Black (BK) 1–10 113-05060 T50MR 215 4.7 45 225 5.4 PA66W Black (BK) 1–10 1–10 113-05819 T50MS 165 4.6 32 225 5.3 PA66 Natural (NA) 113-05820 T50MS 165 4.6 32 225 5.3 PA66 Black (BK) 1–10 113-05419 T50ML 390 4.7 100 225 5.5 PA66 Natural (NA) 1–10 113-05400 T50ML 390 4.7 100 225 5.5 PA66 Black (BK) 1–10 113-12017 T120MR(E) 395 7.6 102 535 6.5 PA66 Black (BK) 6–10 113-12018 T120MR(E) 395 7.6 102 535 6.5 PA66 Natural (NA) 6–10 113-00001 T120MR(E) 395 7.6 102 535 6.5 PA6W Black (BK) 6–10 All dimensions in mm. Subject to technical changes. Please Note for Product Specific Approvals please refer to the Appendix 112 085_113_chapter 1.3_prod 07_uk.qxp 31.07.2007 11:52 Seite 113 Cable Ties and Fixings F i x i n g Ti e s 1.3 WPT ties Features and Benefits One piece fixing and cable tie can be fixed to brick, cement or wood. This product is often used in the construction industry and is both time saving and versatile. Application Simply drill an 8mm hole and knock in the peg. Used to fasten cables, pipes or hoses in place. Wall plug tie in application. Material Data Material Polyamide 6.6 High Impact Modified (PA66HIR) Operating Temperature -40 °C to +80 °C Continuous, (+105 °C for 500 h) Flammability UL94 HB WPT230 Technical Table Article-No. Type 126-00020 WPT230 Length (L) Width (W) Bundle Ø max. Fixing Hole Ø (FH) Material Colour 230 8 59 8.0 PA66HIR Black (BK) All dimensions in mm. Subject to technical changes. T18RSA Self Adhesive Cable Tie Features and Benefits This cable tie and integral self adhesive base ensures a firm securement of wiring bundles to a variety of materials. The T18RSA is both quick and easy to install. Application Ideal for use in a variety of clean applications. Material Data Material Polyamide 6.6 (PA66) T18RSA Operating Temperature -40 °C to +85 °C Continuous, (+105 °C for 500 h) Flammability UL94 V2 Technical Table Article-No. Type 148-00001 T18RSA Length (L) Width (W) Bundle Ø max. Min. Tensile Strength (N) Material Colour 100 2.5 16 80 PA66 Natural (NA) All dimensions in mm. Subject to technical changes. 113
150-76080 价格&库存
很抱歉,暂时无法提供与“150-76080”相匹配的价格&库存,您可以联系我们找货
