150-35930
150-35930
    HELLERMAN(海尔曼太通)
    CNTRMNT DOMED 50LB 7.48"
150-35930 数据手册
1-Piece Fixing Ties with Arrowhead, with Disc in the strap T50RSP | HellermannTy... Page 1 of 2 www.hellermanntyton.co.uk | Products | Cable Ties and Fixings | Fixing Ties 1-Piece Fixing Ties with Arrowhead, with Disc in the strap T50RSP Article number: 150-35930 • • • • Arrowhead located on strap for minimal space Disc covering hole for reduced ingress of water and dirt Flexible discs for firm but secure fixing of any panel thickness Tab on end to facilitate easy location and orientation of head for assembly With a diverse range of fixing possibilities (from 5.7mm to 6.5mm hole diameters and 0.7mm to 3.5mm panel thickness) this range of fixing ties is ideal for use in many different industries, including automotive, aerospace and panel building. Catalogue page (April 2011) All catalogue pages Print Base Data Application Tool MK20, MK3PNSP2, MK3SP, MK7P, MK7 Colour Black (BK) Fixation Method (FF) Arrowhead Identification Plate Position none Product Group 1-Piece Fixing Ties with Arrowhead, with Disc in the strap Releasable Closure (Yes/No) No Tie Closure plastic pawl Type T50RSP.NB7P Variant Inside Serrated Product Dimensions Bundle ∅ max. 45.0 mm Bundle ∅ min. 7.0 mm Disc ∅ 18.0 mm Disc ∅ (imperial) 0.71 " Fixing Hole Diameter D max (Imperial) 0.26 " Fixing Hole Diameter D min (Imperial) 0.24 " Hole ∅ 6.4 mm Hole ∅ (FH) 6.0 - 6.5 mm Hole ∅ (FH) min. 6 mm Length (L) 190 mm Length (L) (imperial) 7.48 " Min. Tensile Strength (lbs) 50 lbs Min.Tensile Strength (N) 225 N Panel Thickness max. 1.3 mm Panel Thickness max. (imperial) 0.05 " Panel Thickness min. 0.75 mm Panel Thickness min. (imperial) 0.03 " Thickness (T) 1.2 mm Width (W) 4.6 mm Width (W) (imperial) 0.18 " Logisitic and Packaging Carton Quantity 8000 pcs. EAN code 4031026120522 Pack Cont. 1000 http://www.hellermanntyton.co.uk/site/products/fixing-ties/t50rsp/150-35930 11/18/2013 1-Piece Fixing Ties with Arrowhead, with Disc in the strap T50RSP | HellermannTy... Page 2 of 2 Quantity of Europallet 96000 pcs. Quantity per Bag UPC 089306207375 Weight 1.5 kg Material and Specifications Flammability UL94 V2 Material PA66 Material Polyamide 6.6 (PA66) Operating Temperature -40 °C to +85 °C More Information UNSPSC Key 39121717 © HellermannTyton 2013 http://www.hellermanntyton.co.uk/site/products/fixing-ties/t50rsp/150-35930 11/18/2013
150-35930 价格&库存
很抱歉,暂时无法提供与“150-35930”相匹配的价格&库存,您可以联系我们找货
