Specification Sheet
Part Number: 151-00927
Fir Tree C-Clip, .24"–.30" Bundle Dia, .03"–.25" Panel, .26" Mnt Hole, PA66HIRHSUV, Black, 100/pkg
Article Number
151-00927
Type
SC6.6
Color
Black (BK)
Features & Benefits
• Pre-drilled holes allows for Easy installation by hand. • Cable can be
removed and reinstalled without removing the clip, providing multiple use
options. • Made of PA66HIRHSUV material for withstanding extreme conditions
Quantity Per
bag
Product Description
The C Clip with fir tree mount is ideal for panels with pre-drilled holes. Easy
installation by hand eliminates the need for any tools. Once installed, the cable
simply snaps into the clip. The cable can be removed and reinstalled without
removing the clip. Made from PA66HIRHSUV material, the clip offers increased
flexibility along with heat resistance and UV stability.
Short Description
Global Part Name
SC6.6-PA66HIRHSUV-BK
Width W (Imperial)
0.72
Width W (Metric)
18.26
Bundle Diameter Min (Imperial)
0.24
Bundle Diameter Min (Metric)
6.0
Bundle Diameter Max (Imperial)
0.29
Bundle Diameter Max (Metric)
7.6
Height H (Imperial)
1.32
Height H (Metric)
33.43
Panel Thickness Min(Imperial)
0.03
Panel Thickness Max(Imperial)
0.25
Panel Thickness Min (Metric)
0.7
Panel Thickness Max (Metric)
6.35
Mounting Hole Diameter D (Imperial)
0.26
Mounting Hole Diameter D (Metric)
6.6 mm
Mounting Hole Diameter D Max (Metric)
6.6
Disc Diameter(Metric)
18.55
Disc Diameter (Imperial)
0.73
Material
Polyamide 6.6 high impact modified, heat and UV stabilized (PA66HIRHSUV)
Material Shortcut
PA66HIRHSUV
Flammability
UL 94 HB
Operating Temperature (Metric)
-65°F to +230°F (-54°C to +110°C)
Reach Complaint(Article 33)
Yes
ROHS Complaint
Yes
Package Quantity(Imperial)
100
Package Quantity (Metric)
100
Customs Number
3926909988
Content Unit(BMEcat)
pcs.
© 2019 HellermannTyton. All Rights Reserved.
Contact Us RoHS/WEEE Compliance Disclaimer Terms and Conditions
很抱歉,暂时无法提供与“151-00927”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 200+3.68733200+0.47706
- 500+3.45586500+0.44711
- 1000+2.481021000+0.32099
- 国内价格 香港价格
- 100+3.41754100+0.44215
