151-00667
151-00667
    HELLERMAN(海尔曼太通)
151-00667 数据手册
151-00667 Article Number: 151-00667 WAC Adhesive Cable Clamp, .75” Max. Bundle Dia., PVC, Gray, 500/pkg Download drawing Download spec sheet Base Data Local Order Number 151-00667 Type WAC075 Color Gray (GY) Features and Benefits • Lead in angle design allows for quick and easy installation of wires and cables. • Rubber based adhesive allows for a permanent bond to most surfaces. Product Description The WAC Adhesive cable clamps are designed with lead in angles allowing for easy insertion of wires and cables. The rubber based adhesive allows for a permanent bond to most surfaces. Available in two sizes. Short Description WAC Adhesive Cable Clamp, .75” Max. Bundle Dia., PVC, Gray, 500/pkg Product Dimensions Length L (Imperial) 1.13 " Length L (Metric) 28.7 mm Width W (Imperial) 1.0 " Width W (Metric) 25.4 mm Height H (Imperial) 0.62 " Height H (Metric) 15.8 mm Height H2 (Imperial) 1.05 " Height H2 (Metric) 26.7 mm Bundle Diameter Min. (Imperial) 0.5 " Bundle Diameter Min. (Metric) 12.7 mm Bundle Diameter Max. (Imperial) 0.75 " Bundle Diameter Max. (Metric) 19.1 mm Thickness of Adhesive TA (Imperial) 0.036 " Thickness of Adhesive TA (Metric) 0.91 mm Logistics and Packaging Quantity Per bag Package Quantity (Metric) 500 Material and Specifications Material Polyvinylchloride (PVC) Material Shortcut PVC Adhesive Self adhesive Flammability UL94 V0 (excluding adhesive) Operating Temperature +122°F (+50°C) © HellermannTyton 2015
151-00667 价格&库存
很抱歉,暂时无法提供与“151-00667”相匹配的价格&库存,您可以联系我们找货
  • 40000+4.4491940000+0.57838
