Ratchet P Clamp
Rugged Bundle Management
for Heavy Duty Applications
Engineered with both the application and
Integrated cable tie saddle
provides a second fixing point.
the user in mind, Ratchet P Clamp offers:
• Versatility – Secure hard lines, soft cable
bundles ranging from ¼” to 2” wide
Impact modified, heat and
UV stabilized PA66 plastic
ensures long-term durability.
One-piece ratchet closure
allows for easy installation,
one-touch close.
Screwdriver release
enables easy adjustments
and maintenance.
• Ease of Use – Position, torque down,
close by hand – that’s it!
Tension Tabs slide
through this slot to
facilitate closure using
an EVO Series hand tool.
• Alignment – Center cables as the clamp
closes
• Durability – PA66 body and high grade
steel mounting plate never wears out or
corrodes
Designed for heavy duty manufacturing,
Ratchet P Clamp non-destructive, releasable
clamp also solves wire bundling challenges
in OEM, automotive and solar installations.
Contoured clamp
interior is designed to
guide and center bundle
to reduce pinching.
Mounting plates are
available with M6,
M8, M10 and M12
diameter hole sizes.
Interior rib design minimizes
movement due to vibration.
High grade steel mounting plate tolerates
high torque mounting and is treated to
resist chemicals and salt spray.
Versatile, durable, efficient fastening and routing
Offered in four sizes and
with several mounting
configurations and hole sizes,
the reusable design minimizes
part inventory, speeds fastening
and simplifies maintenance.
180° straight
15°
30°
90°
800.537.1512 |
WWW.HELLERMANN.TYTON.COM
很抱歉,暂时无法提供与“151-01637”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+38.086841+4.92755
