155-16301
155-16301
    HELLERMAN(海尔曼太通)
155-16301 数据手册
Specification Sheet Part Number: S3STM500HIRHSC2 Fir Tree Saddle Mount, Hole Diameter 0.5", Panel Thickness 0.08 - 0.52", PA66HIRHSUV, Black, 100/pkg Article Number 151-29500 Type S3STM50 Color Black (BK) Features & Benefits • Heavy duty fir tree mount requires low insertion force and high extraction force. • Impact modified, heat stabilized, UV material makes it ideal for heavy-duty solutions. Quantity Per bag Product Description The saddle mount acts as a standoff, elevating bundles above bolt protrusions commonly found in frame rails and panels. A tension tab on the mount allows cable ties to be pre-assembled in a ready position prior to bundles being brought to the mount. The mount can secure up to four separate bundles, providing parallel spacing between the frame rail and adjacent bundles. Fir tree eliminates the need for mounting hardware. For use with HellermannTyton T50-T255 ties. Short Description Fir Tree Saddle Mount, Hole Diameter 0.5", Panel Thickness 0.08 - 0.52", PA66HIRHSUV, Black, 100/pkg Global Part Name S3STM50-PA66HIRHSUV-BK Length L (Imperial) 2.0 Length L (Metric) 50.0 Fixation Method with Fir Tree (Mounts) Width W (Imperial) 0.9 Width W (Metric) 22.0 Bundle Diameter Min (Imperial) 5.0 Bundle Diameter Min (Metric) 127.0 Bundle Diameter Max (Imperial) 5.0 Bundle Diameter Max (Metric) 127.0 Bundle Diameter 1st Loop Max (Imperial) 5.0 Bundle Diameter 1st Loop Max (Metric) 127.0 Bundle Diameter 2nd Loop Max (Imperial) 5.0 Bundle Diameter 2nd Loop Max (Metric) 127.0 Height H (Imperial) 1.40 Height H (Metric) 35.0 Panel Thickness Min(Imperial) 0.075 Panel Thickness Max(Imperial) 0.512 Panel Thickness Min (Metric) 1.9 Panel Thickness Max (Metric) 13.0 Mounting Hole Diameter D (Imperial) 0.5 Mounting Hole Diameter D (Metric) 12.7 - 13.7 mm Mounting Hole Diameter D Min (Imperial) 0.5 Mounting Hole Diameter D Max (Imperial) 0.54 Mounting Hole Diameter D Max (Metric) 13.7 Material Polyamide 6.6 high impact modified, heat and UV stabilized (PA66HIRHSUV) Material Shortcut PA66HIRHSUV Flammability UL 94 HB Operating Temperature (Metric) -40°F to +230°F (-40°C to +110°C) Minimum Extraction Force (Imperial) 200.0 Minimum Extraction Force (Metric) 890 Reach Complaint(Article 33) Yes ROHS Complaint Yes Package Quantity(Imperial) 100 Package Quantity (Metric) 100 Customs Number 3926909987 Content Unit(BMEcat) pcs. © 2018 HellermannTyton. All rights reserved. Contact Us RoHS/WEEE Compliance Disclaimer Terms and Conditions
155-16301 价格&库存
很抱歉,暂时无法提供与“155-16301”相匹配的价格&库存,您可以联系我们找货
