151-01643
    HELLERMAN(海尔曼太通)
    CBLCLAMPP-TYPEBLACKFASTENER
151-01643 数据手册
151-01643 Article Number: 151-01643 Description: Ratchet P-Clamp, ±Bundle Dia, 90° Short, .26" Hole Dia, PA66HIRHSUV/ST/ZN, Black, 300/ctn Base Data Local Order Number 151-01643 Type RCA90SM6 Color Black (BK) Features and benefits ‡One-piece ratchet closure design allows for easy installation during pre- or final assembly. ‡Four sizes and multiple configurations handle a wide range of diameters and applications, reducing part inventory. ‡Clamp interior is designed to guide and center bundle to reduce pinching. ‡Easy release feature allows for quick adjustments and maintenance. ‡Impact modified, heat and UV stabilized PA66 provides long-term durability, indoors and out. ‡Steel mounting plate tolerates high torque mounting and is treated to resist chemicals and salt spray. Quantity Per carton Product Description The Ratchet P-Clamp family offers versatility when managing wires, cables and hoses. The robust design and durable materials make it ideal for heavy duty applications, both indoors and out. The one-piece adjustable clamp can be closed by hand to the desired diameter. The release feature provides easy and nondestructive removal of cables simply by using a flat-head screwdriver. This nondestructive release allows the clamp to be reused without removing or replacing any bolts or screws. The Ratchet P-Clamp is offered in four sizes and multiple mounting configurations. Short Description Ratchet P-Clamp, ±Bundle Dia, 90° Short, .26" Hole Dia, PA66HIRHSUV/ST/ZN, Black, 300/ctn Minimum Tensile Strength (Imperial) 100.0lbs Minimum Tensile Strength (Metric) 445.0N Length L (Imperial) 4.01" Length L (Metric) 101.9mm Length L2 (Imperial) 2.71" Fixation Method Screw Mounting Length L2 (Metric) 68.8mm Variant 90° Short Width W (Imperial) 1.37" Product Dimensions generated on: 5/9/2017 151-01643 Product Dimensions Width W (Metric) 34.9mm Cable Tie Width Max. (Imperial) 0.52" Cable Tie Width Max. (Metric) 13.2mm Width W2 (Imperial) 1.181" Width W2 (Metric) 30.0mm Bundle Diameter Min. (Imperial) 0.24" Bundle Diameter Min. (Metric) 6.2mm Bundle Diameter Max. (Imperial) 0.54" Bundle Diameter Max. (Metric) 13.7mm Mounting Hole Diameter D (Imperial) 0.256" Mounting Hole Diameter D (Metric) M6 Mounting Hole Centers (Imperial) 0.98" Stud Size (Metric) M6 Material Zinc plated (ZN) Material Shortcut PA66HIRHSUV Flammability UL 94 HB Operating Temperature -40°F to +257°F (-40°C to +125°C) REACH Compliant (Article 33) Yes ROHS Compliant Yes Stamping Material Steel (ST) Package Quantity (Imperial) 300 Package Quantity (Metric) 300 Customs Number(Schedule B) 3926909987 Content Unit (BMEcat) pieces Material and Specifications Logistic and Packaging generated on: 5/9/2017
151-01643
1. 物料型号:151-01643 2. 器件简介:HellermannTyton生产的棘轮P型夹,具有90°短型设计,适用于直径范围在0.24"至0.54"的束线,孔径为0.26",材质为PA66HIRHSUV/ST/ZN,黑色,每箱300个。 3. 引脚分配:未提供具体引脚分配信息,但提供了安装孔直径为M6,安装方式为螺丝固定。 4. 参数特性: - 最小拉伸强度:100.0磅(Imperial)/ 445.0牛顿(Metric) - 长度L:4.01"(Imperial)/ 101.9mm(Metric) - 长度L2:2.71"(Imperial)/ 68.8mm(Metric) - 宽度W:1.37"(Imperial)/ 34.9mm(Metric) - 宽度W2:1.181"(Imperial)/ 30.0mm(Metric) - 束线直径最小值:0.24"(Imperial)/ 6.2mm(Metric) - 束线直径最大值:0.54"(Imperial)/ 13.7mm(Metric) - 材质:锌镀层(ZN) - 工作温度:-40°F至+257°F(-40°C至+125°C) - 符合REACH和RoHS标准 5. 功能详解:该夹具采用一体式棘轮闭合设计,便于预装或最终组装时的安装。内部设计有助于引导和居中束线,减少夹伤。易于释放功能允许快速调整和维护。改良的耐冲击、耐热和UV稳定的PA66材质提供长期耐久性,适用于室内外环境。钢制安装板可承受高扭矩安装,并经过化学和盐雾处理。 6. 应用信息:适用于多种直径和应用场景,减少零件库存。 7. 封装信息:每箱300个,海关编号3926909987,内容单位为件。
151-01643 价格&库存
很抱歉,暂时无法提供与“151-01643”相匹配的价格&库存,您可以联系我们找货
