151-01667
151-01667
    HELLERMAN(海尔曼太通)
    CBLCLAMPP-TYPEBLACKFASTENER
151-01667 数据手册
Ratchet P Clamp Rugged Bundle Management for Heavy Duty Applications Engineered with both the application and Integrated cable tie saddle provides a second fixing point. the user in mind, Ratchet P Clamp offers: • Versatility – Secure hard lines, soft cable bundles ranging from ¼” to 2” wide Impact modified, heat and UV stabilized PA66 plastic ensures long-term durability. One-piece ratchet closure allows for easy installation, one-touch close. Screwdriver release enables easy adjustments and maintenance. • Ease of Use – Position, torque down, close by hand – that’s it! Tension Tabs slide through this slot to facilitate closure using an EVO Series hand tool. • Alignment – Center cables as the clamp closes • Durability – PA66 body and high grade steel mounting plate never wears out or corrodes Designed for heavy duty manufacturing, Ratchet P Clamp non-destructive, releasable clamp also solves wire bundling challenges in OEM, automotive and solar installations. Contoured clamp interior is designed to guide and center bundle to reduce pinching. Mounting plates are available with M6, M8, M10 and M12 diameter hole sizes. Interior rib design minimizes movement due to vibration. High grade steel mounting plate tolerates high torque mounting and is treated to resist chemicals and salt spray. Versatile, durable, efficient fastening and routing Offered in four sizes and with several mounting configurations and hole sizes, the reusable design minimizes part inventory, speeds fastening and simplifies maintenance. 180° straight 15° 30° 90° 800.537.1512 | WWW.HELLERMANN.TYTON.COM
151-01667 价格&库存
很抱歉,暂时无法提供与“151-01667”相匹配的价格&库存,您可以联系我们找货
  • 160+27.06641160+3.50300
  • 800+24.97095800+3.23180
  • 2400+21.827752400+2.82500
