151-01654
    HELLERMAN(海尔曼太通)
    CBLCLAMPP-TYPEBLACKFASTENER
151-01654 数据手册
151-01654 Article Number: 151-01654 Description: Ratchet P-Clamp, ±Bundle Dia, 180° Med, .26" Hole Dia, PA66HIRHSUV/ST/ZN, Black, 140/ctn Base Data Local Order Number 151-01654 Type RCC180MM6 Color Black (BK) Features and benefits ‡One-piece ratchet closure design allows for easy installation during pre- or final assembly. ‡Four sizes and multiple configurations handle a wide range of diameters and applications, reducing part inventory. ‡Clamp interior is designed to guide and center bundle to reduce pinching. ‡Easy release feature allows for quick adjustments and maintenance. ‡Impact modified, heat and UV stabilized PA66 provides long-term durability, indoors and out. ‡Steel mounting plate tolerates high torque mounting and is treated to resist chemicals and salt spray. Quantity Per carton Product Description The Ratchet P-Clamp family offers versatility when managing wires, cables and hoses. The robust design and durable materials make it ideal for heavy duty applications, both indoors and out. The one-piece adjustable clamp can be closed by hand to the desired diameter. The release feature provides easy and nondestructive removal of cables simply by using a flat-head screwdriver. This nondestructive release allows the clamp to be reused without removing or replacing any bolts or screws. The Ratchet P-Clamp is offered in four sizes and multiple mounting configurations. Short Description Ratchet P-Clamp, ±Bundle Dia, 180° Med, .26" Hole Dia, PA66HIRHSUV/ST/ZN, Black, 140/ctn Minimum Tensile Strength (Imperial) 100.0lbs Minimum Tensile Strength (Metric) 445.0N Length L (Imperial) 7.01" Length L (Metric) 178.1mm Length L2 (Imperial) 4.92" Fixation Method Screw Mounting Length L2 (Metric) 125.0mm Variant 180° Medium Width W (Imperial) 1.37" Product Dimensions generated on: 5/9/2017 151-01654 Product Dimensions Width W (Metric) 34.9mm Cable Tie Width Max. (Imperial) 0.52" Cable Tie Width Max. (Metric) 13.2mm Width W2 (Imperial) 1.181" Width W2 (Metric) 30.0mm Bundle Diameter Min. (Imperial) 0.76" Bundle Diameter Min. (Metric) 19.4mm Bundle Diameter Max. (Imperial) 1.42" Bundle Diameter Max. (Metric) 36.0mm Mounting Hole Diameter D (Imperial) 0.256" Mounting Hole Diameter D (Metric) M6 Mounting Hole Centers (Imperial) 3.32" Stud Size (Metric) M6 Material Steel (ST) Material Shortcut ST Flammability UL 94 HB Operating Temperature -40°F to +257°F (-40°C to +125°C) REACH Compliant (Article 33) Yes ROHS Compliant Yes Stamping Material Steel (ST) Package Quantity (Imperial) 140 Package Quantity (Metric) 140 Customs Number(Schedule B) 3926909987 Content Unit (BMEcat) pieces Material and Specifications Logistic and Packaging generated on: 5/9/2017
151-01654 价格&库存
很抱歉,暂时无法提供与“151-01654”相匹配的价格&库存,您可以联系我们找货
