151-01658
Article Number:
151-01658
Description:
Ratchet P-Clamp, ±Bundle Dia, 30° Long, .26"
Hole Dia, PA66HIRHSUV/ST/ZN, Black, 140/ctn
Base Data
Local Order Number
151-01658
Type
RCC30LM6
Color
Black (BK)
Features and benefits
One-piece ratchet closure design allows for easy installation during pre- or final
assembly.
Four sizes and multiple configurations handle a wide range of diameters and
applications, reducing part inventory.
Clamp interior is designed to guide and center bundle to reduce pinching.
Easy release feature allows for quick adjustments and maintenance.
Impact modified, heat and UV stabilized PA66 provides long-term durability,
indoors and out.
Steel mounting plate tolerates high torque mounting and is treated to resist
chemicals and salt spray.
Quantity Per
carton
Product Description
The Ratchet P-Clamp family offers versatility when managing wires, cables and
hoses. The robust design and durable materials make it ideal for heavy duty
applications, both indoors and out. The one-piece adjustable clamp can be closed
by hand to the desired diameter. The release feature provides easy and
nondestructive removal of cables simply by using a flat-head screwdriver. This
nondestructive release allows the clamp to be reused without removing or replacing
any bolts or screws. The Ratchet P-Clamp is offered in four sizes and multiple
mounting configurations.
Short Description
Ratchet P-Clamp, ±Bundle Dia, 30° Long, .26" Hole Dia,
Minimum Tensile Strength (Imperial)
100.0lbs
Minimum Tensile Strength (Metric)
445.0N
Length L (Imperial)
7.49"
Length L (Metric)
190.4mm
Length L2 (Imperial)
4.52"
Fixation Method
Screw Mounting
Length L2 (Metric)
114.9mm
Variant
30° Long
Width W (Imperial)
1.37"
Product
Dimensions
generated on:
5/9/2017
151-01658
Product
Dimensions
Width W (Metric)
34.9mm
Cable Tie Width Max. (Imperial)
0.52"
Cable Tie Width Max. (Metric)
13.2mm
Width W2 (Imperial)
1.181"
Width W2 (Metric)
30.0mm
Bundle Diameter Min. (Imperial)
0.76"
Bundle Diameter Min. (Metric)
19.4mm
Bundle Diameter Max. (Imperial)
1.42"
Bundle Diameter Max. (Metric)
36.0mm
Mounting Hole Diameter D (Imperial)
0.256"
Mounting Hole Diameter D (Metric)
M6
Mounting Hole Centers (Imperial)
2.96"
Stud Size (Metric)
M6
Material
Steel (ST)
Material Shortcut
ZN
Flammability
UL 94 HB
Operating Temperature
-40°F to +257°F (-40°C to +125°C)
ROHS Compliant
Yes
Stamping Material
Steel (ST)
Package Quantity (Imperial)
140
Package Quantity (Metric)
140
Customs Number(Schedule B)
3926909987
Material and
Specifications
Logistic and
Packaging
generated on:
5/9/2017
很抱歉,暂时无法提供与“151-01658”相匹配的价格&库存,您可以联系我们找货
