166-90183
166-90183
    HELLERMAN(海尔曼太通)
    CBLCLIPCONDUITBLACKFASTENER
166-90183 数据手册
166-90183 Article Number: 166-90183 Description: HelaGuard PACC Conduit Clip,1.50" Dia, PA66, Black, 2/pkg Base Data Local Order Number 166-90183 Type PACC1500 Color Black (BK) Features and benefits ‡Assists with installation by easily cutting through HelaGuard non-mettalic conduit and tubing. Product Description Conduit Clips clamp onto corrugated conduits and tubing to secure. Nylon material resists corrosion and chemicals. Can also be used on C-shaped DIN rails. Short Description HelaGuard PACC Conduit Clip,1.50" Dia, PA66, Black, 2/pkg Length L (Imperial) 2.76" Length L (Metric) 70mm Fits Conduit Size (Imperial) 1-1/2 " Fits Conduit Size (Metric) 54mm Width W (Imperial) 0.59" Width W (Metric) 15mm Height H (Imperial) 2.83" Height H (Metric) 72mm Mounting Hole Diameter D (Imperial) 0.24" Mounting Hole Diameter D (Metric) 6.0 mm Nominal Diameter (Imperial) 1-1/2" Nominal Diameter (Metric) 54mm Material Polyamide 6.6 (PA66) Material Shortcut PA66 Flammability UL 94 V2 Product Dimensions Material and Specifications generated on: 5/10/2017 166-90183 Material and Specifications Halogenfree Yes Operating Temperature -58°F to +275°F (-50°C to +135°C) ROHS Compliant Yes Package Quantity (Imperial) 5 Package Quantity (Metric) 5Pieces Customs Number(Schedule B) 3926909987 Logistic and Packaging generated on: 5/10/2017
166-90183 价格&库存
很抱歉,暂时无法提供与“166-90183”相匹配的价格&库存,您可以联系我们找货
  • 50+490.4295950+63.45016
