161-64006
161-64006
    HELLERMAN(海尔曼太通)
    CBLCLIPU-TYPEBLKPUSHIN50PK
161-64006 数据手册
Specification Sheet Part Number: 161-64006 An innovative coupling system allows for an unlimited number of bundling combinations. Clips can be easily released and reused. Clips swivel freely which reduces mechanical stress and eliminates pinch points. High Impact Polyamide 6.6 material provides firm fit even in rugged conditions. Consists of acrylate adhesive with base of polyurethane foam allowing it to adhere firmly and easily to nearly any surface. Helawrap, Accessory Clip, HWCLIP20, 3/4" Dia, PA66HIRHS, Black, 50/pkg Article Number 161-64006 Type HWCLIP20 Color Black (BK) Quantity Per bag Product Description The Helawrap cable management system is the flexible routing and protection solution for industrial, datacom and electrical applications. Clips can be joined to a base and another clip of any size. Different cable sizes can be bundled together, organized and protected flexibly and efficiently. Short Description Helawrap, Accessory Clip, HWCLIP20, 3/4" Dia, PA66HIRHS, Black, 50/pkg Global Part Name HWCLIP20-PA66HIRHS-BK Fixation Method Plug-in mounting Diameter D (Imperial) 0.79 Diameter D (Metric) 20 Nominal Diameter (Imperial) 0.75 Nominal Diameter (Metric) 20.0 Material Polyamide 6.6, high impact modified, heat stabilized (PA66HIRHS) Material Shortcut PA66HIRHS Flammability UL 94 HB Halogen Free Yes Operating Temperature -40°F to +221°F (-40°C to +105°C) Reach Compliant (Article 33) Yes ROHS Compliant Yes Package Quantity (Imperial) 50 Package Quantity (Metric) 50 Customs Number 3926909988 © 2021 HellermannTyton. All Rights Reserved. Contact Us RoHS/WEEE Compliance Disclaimer Terms and Conditions
161-64006 价格&库存
很抱歉,暂时无法提供与“161-64006”相匹配的价格&库存,您可以联系我们找货
