Cable Ties and Fixings
Fixing Elements
1.8
Fixing Elements for Tubes and Harnesses with
Automatic Locking Feature, interconnectable
Offering a simple and secure method of attaching cables to panels.
Originally designed for the automotive industry, these products are used
in a wide range of applications with sheet metal panels across various
industries.
Features and Benefits
• Push and click closure
• Coupling elements of the IAHC variants allow parts to interconnect
• Clip is clicked into a specific hole
• IAHC( )T can only be connected with another IAHC element
IHAC( )AH in combination with an IAHC( )T.
IAHC-Series, Connectable
W
L
IAHC( )T
Width
(W)
Length
(L)
Bundle
Ø max.
Material
Colour
Article-No.
IAHC1T
10.0
23.0
13.0
PA66HIRHS
Black (BK)
151-00223
IAHC2T
10.0
30.0
20.0
PA66HIRHS
Black (BK)
151-00199
IAHC3T
10.0
40.0
28.0
PA66HIRHS
Black (BK)
151-00213
IAHC4T
13.5
47.0
36.0
PA66HIRHS
Black (BK)
151-00207
IAHC5T
13.5
57.0
45.0
PA66HIRHS
Black (BK)
151-00195
TYPE
Drawing
All dimensions in mm. Subject to technical changes.
Date of issue: October 2015
Material specification
please see page 24.
Further information at www.HellermannTyton.com/fixings
157
1.8
Fixing Elements
IAHC-Serie, Connectable, with Arrowhead
w
L
please see page 24.
AHC( )AH
Width
(W)
Length
(L)
Bundle
Ø max.
Hole Ø
(FH)
Panel
Thickness
Material
Colour
Article-No.
13.5
40.0
28.0
6.2 - 6.7
0.7 - 2.7
PA66HIRHS
Black (BK)
151-00378
13.5
53.0
36.0
6.2 - 6.7
0.5 - 2.5
PA6HIRHS
Black (BK)
151-00211
13.5
53.0
36.0
6.2 - 6.7
0.7 - 3.0
PA66HIRHS
Black (BK)
151-00382
IAHC5BH
13.5
57.0
45.0
6.2 x 12.2
0.7 - 3.0
PA66HIRHS
Black (BK)
151-00384
IAHC3CH
10.0
47.0
28.0
6.2 x 12.2
0.7 - 2.0
PA66HIRHS
Black (BK)
151-00381
IAHC4CH
13.5
53.0
36.0
6.2 x 12.2
0.7 - 2.0
PA6HIRHS
Black (BK)
151-00383
IAHC3EH
13.5
44.5
28.0
6.2 x 12.2
1.5 - 3.1
PA66HIRHS
Black (BK)
151-00489
IAHC5FH
13.5
61.5
45.0
6.2 x 12.2
1.5 - 3.0
PA66HIRHS
Black (BK)
151-00787
TYPE
IAHC3AH
IAHC4AH
Drawing
158
1.0
Material Information
Material Specification Overview
Material
Shortcut
Operating
Temperature
Aluminium-alloy
AL
-40 °C to +180 °C
Natural
(NA)
• Corrosion resistant
• Antimagnetic
Chloroprene
CR
-20 °C to +80 °C
Black (BK)
• Weather-resistant
• High yield strength
Ethylene
Tetrafluoroethylene
E/TFE
-80 °C to +170 °C
Blue (BU)
UL94 V0
Polyacetal
POM
-40 °C to +90 °C,
(+110 °C, 500 h)
Natural
(NA)
UL94 HB
Polyamide 11
PA11
-40 °C to +85 °C,
(+105 °C, 500 h)
Black (BK)
UL94 HB
Polyamide 12
PA12
-40 °C to +85 °C,
(+105 °C, 500 h)
Black (BK)
UL94 HB
• Good chemical resistance to:
acids, bases, oxidizing agents
• UV-resistant
Polyamide 4.6
PA46
-40 °C to +150 °C
(5000 h), +195 °C
(500 h)
Natural
(NA),
Grey (GY)
UL94 V2
• Resistance to high temperatures
• Very moisture sensitive
• Low smoke sensitive
Polyamide 6
PA6
-40 °C to +80 °C
Black (BK)
UL94 V2
PA6HIR
-40 °C to +80 °C
Black (BK)
UL94 HB
• Limited brittleness sensitivity
• Higher flexibility at low temperature
Polyamide 6.6
PA66
-40 °C to +85 °C,
(+105 °C, 500 h)
Black (BK),
Natural
(NA)
UL94 V2
Polyamide 6.6,
PA66GF13,
PA66GF15
-40 °C to +105 °C
Black (BK)
UL94 HB
• Good resistance to: lubricants, vehicle
fuel, salt water and many solvents
PA66HSW
-40 °C to +105 °C
Black (BK)
UL94 V2
• Modified elevated max. temperature
• UV-resistant
Polyamide 6.6,
heat stabilised
PA66HS
-40 °C to +105 °C
Black (BK),
Natural
(NA)
UL94 V2
• Modified elevated
max. temperature
Polyamide 6.6,
high impact modified
PA66HIR
-40 °C to +80 °C,
(+105 °C, 500 h)
Black (BK)
UL94 HB
Polyamide 6.6,
high impact modified, heat
and UV stabilised
PA66HIRHSW
-40 °C to +110 °C
Black (BK)
UL94 HB
Polyamide 6.6,
stabilised
PA66HIRHS
-40 °C to +105 °C
Black (BK)
UL94 HB
Polyamide 6.6,
high impact modified, scan
black
PA66HIR(S)
-40 °C to +80 °C,
(+105 °C, 500 h)
Black (BK)
UL94 HB
PA66W
-40 °C to +85 °C,
(+105 °C, 500 h)
Black (BK)
UL94 V2
• UV-resistant
Polyamide 6,
glass-fibre reinforced
Polyamide 6.6,
heat and UV stabilised
Polyamide 6.6,
UV-resistant
Colour**
Material
Properties*
Flammability
Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers.
• Resistance to radioactivity
• UV-resistant, not moisture sensitive
• Flexible at low temperature
• Not moisture sensitive
• Robust on impacts
• Bio-plastic, derived from vegetable oil
• Strong impact resistance at low
temperature
• Very low moisture absorption
• Weather-resistant
temperature
• High yield strength, UV-resistant
**More colours on request.
*These details are only rough guide values. They should be regarded as a material specification and are no substitute for a
suitability test. Please see our datasheets for further details.
HF = Halogenfree
LFH = Limited Fire Hazard
RoHS = Restriction of Hazardous Substances
24
Material
Specifications
MATERIAL
Material
Shortcut
Operating
Temperature
Polyamide 6.6,
with metal particles
PA66MP
Polyamide 6.6 V0
MATERIAL
Material
Properties*
Colour**
Flammability
-40 °C to +85 °C,
(+105 °C, 500 h)
Blue (BU)
UL94 HB
• Metal and X-Ray detectable
PA66V0
-40 °C to +85 °C
White (WH)
UL94 V0
• Low smoke emission
PA66V0-HOI
-40 °C to +85 °C,
(+105 °C, 500 h)
White (WH)
UL94 V0
• Low smoke emissions
SP
-50 °C to +150 °C
Black (BK)
Halogen free
• UV-resistant
most acids, alkalis and oils
PEEK
-55 °C to +240 °C
Beige (BGE)
UL94 V0
Polyethylene
PE
-40 °C to +50 °C
Black (BK),
Grey (GY)
UL94 HB
• Low moisture absorption
• Good chemical resistance to: most
acids, alcohol and oils
Polyolefin
PO
-40 °C to +90 °C
Black (BK)
UL94 V0
Polypropylene
PP
-40 °C to +115 °C
Black (BK),
Natural
(NA)
UL94 HB
• Floats in water
• Moderate yield strength
organic acids
PP, EPDM
-20 °C to +95 °C
Black (BK)
UL94 HB
• Good resistance to high temperatures
• Good chemical and abrasion
resistance
Polyamide 6.6 V0,
High Oxygen Index
Polyester
Polyetheretherketone
Polypropylene, EthylenePropylene-DienTerpolymere-rubber
free of Nitrosamine
Polypropylene
PPMP
-40 °C to +115 °C
Blue (BU)
UL94 HB
• Floats in certain liquids
• Heat resistant
Polyvinylchloride
PVC
-10 °C to +70 °C
Black (BK),
Natural
(NA)
UL94 V0
acids, ethanol and oil
Stainless Steel,
Stainless Steel
SS304,
SS316
-80 °C to +538 °C
Natural
(NA)
Non burning
• Antimagnetic
• Weather resistant
• Outstanding chemical resistance
Thermoplastic
Polyurethane
TPU
-40 °C to +85 °C
Black (BK)
UL94 HB
• High elasticity
acids, bases and oxidizing agents
1.0
Material
Specifications
HF = Halogenfree
25
