EZA-VGAAM-2
EZA-VGAAM-2
    TRIPPLITE
    EASY PULL TYPE-A RGB CONN KIT
EZA-VGAAM-2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Easy Pull Type-A Connectors - (M/M set of VGA with Audio) MODEL NUMBER: EZA-VGAAM-2 Highlights ● SVGA / 3.5mm Stereo Connector Kit, Male to Male ● Versatile trunk cable allows for a variety of connection options ● High quality RGB style VGA cable supports resolutions up to 1600 x 1200 Package Includes ● Description Easy Pull Connector Kit includes: 2 x HD15 Male w/stereo 3.5mm plug, 1 ft. pigtails. Video support up to 1600 x 1200. Use with either PVC or Plenum trunk cables. Features ● Easy Pull, 2 x HD15 Male & 2 x 3.5mm Stereo, 1 ft. pigtails ● Eliminates the need to field terminate VGA connectors ● Allows cable to be run according to code - inside conduit, drop ceilings, etc. ● Makes pulling long cables fast and easy ● Trunk cables available in 35 ft., 50 ft. and 100 ft. PVC lengths, and 35 ft. and 50 ft. Plenum jackets ● Support resolutions up to 1600 x 1200 Specifications OVERVIEW UPC Code 037332141958 Technology VGA/SVGA; Stereo Audio Cable Type Passive PHYSICAL Color Black; Green Cable Length (ft.) 1 Cable Length (m) 0.30 Shipping Dimensions (hwd / in.) 0.50 x 5.90 x 8.40 1/2 2 x HD15 Male/3.5mm Stereo Male, 1 ft. pigtails 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / cm) 1.27 x 14.99 x 21.34 Shipping Weight (lbs.) 0.30 Shipping Weight (kg) 0.14 CONNECTIONS Side A - Connector 1 HD15 (MALE) Side A - Connector 2 3.5MM (MALE) Side A - Connector 3 DIN 14 PIN (MALE) Side B - Connector 1 HD15 (MALE) Side B - Connector 2 3.5MM (MALE) Side B - Connector 3 DIN 14 PIN (MALE) Latching or Gripping Connector No FEATURES & SPECIFICATIONS IP68 Rated No WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
EZA-VGAAM-2
1. 物料型号: - 型号编号:EZA-VGAAM-2
2. 器件简介: - Easy Pull Connector Kit包含2个HD15公头和2个3.5mm立体声公头,1英尺长的猪尾线。视频支持分辨率高达1600 x 1200。适用于PVC或Plenum主干电缆。
3. 引脚分配: - Side A - Connector 1: HD15(公头) - Side A - Connector 2: 3.5MM(公头) - Side A - Connector 3: DIN 14 PIN(公头) - Side B - Connector 1: HD15(公头) - Side B - Connector 2: 3.5MM(公头) - Side B - Connector 3: DIN 14 PIN(公头)
4. 参数特性: - 技术:VGA/SVGA; 立体声音频 - 电缆类型:被动 - 物理特性:颜色为黑色和绿色,电缆长度1英尺(0.30米)。 - 运输尺寸:高0.50x宽5.90x长8.40英寸;高1.27x宽14.99x长21.34厘米。 - 运输重量:0.30磅(0.14千克)。 - 无锁扣或抓握连接器。 - 不符合IP68等级。
5. 功能详解: - 易拉式设计,无需现场端接VGA连接器。 - 允许电缆根据规范运行,如在管道、吊顶内等。 - 主干电缆有35英尺、50英尺和100英尺PVC长度,以及35英尺和50英尺Plenum套管。 - 支持高达1600 x 1200的分辨率。
6. 应用信息: - 适用于需要高分辨率视频和立体声音频传输的应用场合。
7. 封装信息: - UPC代码:037332141958 - 产品保修期(全球):有限终身保修。
EZA-VGAAM-2 价格&库存
很抱歉,暂时无法提供与“EZA-VGAAM-2”相匹配的价格&库存,您可以联系我们找货
