1000 Eaton Boulevard
Cleveland, OH 44122
United States
Easy Pull Type-A Connectors - (M/F set of VGA
with Audio and Faceplate)
MODEL NUMBER: EZA-VGAAX-2
Highlights
SVGA / 3.5mm Stereo
Connector Kit, Male to Female
Versatile trunk cable allows for a
variety of connection options
High quality RGB style VGA
cable supports resolutions up to
1600 x 1200
Package Includes
Description
Easy Pull Connector Kit includes: HD15 Male w/stereo 3.5mm plug - 1 ft. pigtail, HD15 Female w/stereo
3.5mm socket - 1 ft. pigtail, and mounting wall plate. Completes your Easy Pull trunk run with a finished
appearance. Video support up to 1600 x 1200. Use with either PVC or Plenum trunk cables.
Features
Eliminates the need to field terminate VGA connectors
Wall Plate with HD15 and 3.5mm stereo cut-outs cleanly finish off the cable run
Allows cable to be run according to code - inside conduit, drop ceilings, etc.
Makes pulling long cables fast and easy
Trunk cables available in 35 ft., 50 ft. and 100 ft. PVC lengths, and 35 ft. and 50 ft. Plenum jackets
High quality RGB style VGA cable supports resolutions up to 1600 x 1200
Specifications
OVERVIEW
UPC Code
037332141965
Technology
VGA/SVGA; Stereo Audio
PHYSICAL
Color
Black; Green
Cable Length (ft.)
1
Cable Length (m)
0.30
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
1/2
plug, 1 ft. pigtail
HD15 Female w/stereo 3.5mm
socket, 1 ft. pigtail
Wall plate w/HD15 and 3.5mm
cutouts
Cleveland, OH 44122
United States
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.60
Shipping Weight (kg)
0.27
CONNECTIONS
Side A - Connector 1
HD15 (MALE)
Side A - Connector 2
3.5MM (MALE)
Side A - Connector 3
DIN 14 PIN (MALE)
Side B - Connector 1
HD15 (FEMALE)
Side B - Connector 2
3.5MM (FEMALE)
Side B - Connector 3
DIN 14 PIN (MALE)
Latching or Gripping Connector
No
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“EZA-VGAAX-2”相匹配的价格&库存,您可以联系我们找货
