1000 Eaton Boulevard
Cleveland, OH 44122
United States
Easy Pull Type-A Connectors - (F/F set of VGA
with Audio and Faceplates)
MODEL NUMBER: EZA-VGAAF-2
Highlights
SVGA / 3.5mm Stereo
Connector Kit, Female to
Female
Versatile trunk cable allows for a
variety of connection options
High quality RGB style VGA
cable supports resolutions up to
1600 x 1200
Easily pull through conduit or
confined spaces with included
pull-caps
Package Includes
Features
Eliminates the need to field terminate VGA connectors
Wall plates with HD15 and 3.5mm stereo cut-outs cleanly finish off the cable run
Allows cable to be run according to code - inside conduit, drop ceilings, etc.
Makes pulling long cables fast and easy
Trunk cables available in 35 ft., 50 ft. and 100 ft. PVC lengths, and 35 ft. and 50 ft. Plenum jackets
High quality RGB style VGA cable supports resolutions up to 1600 x 1200
Specifications
OVERVIEW
UPC Code
037332142849
Technology
VGA/SVGA; Stereo Audio
PHYSICAL
Color
Black; Green
Cable Length (ft.)
1
Cable Length (m)
0.30
Shipping Dimensions (hwd / in.)
12.00 x 10.00 x 0.50
Shipping Dimensions (hwd / cm)
30.48 x 25.40 x 1.27
Shipping Weight (lbs.)
0.35
Shipping Weight (kg)
0.16
1/2
2 x HD15 Female w/stereo
3.5mm socket, 1-ft. (0.31 m)
pigtail
2 x Mounting plate w/HD15 and
3.5mm cutouts
Cleveland, OH 44122
United States
CONNECTIONS
Side A - Connector 1
HD15 (FEMALE)
Side A - Connector 2
3.5MM (FEMALE)
Side A - Connector 3
DIN 14 PIN (MALE)
Side B - Connector 1
HD15 (FEMALE)
Side B - Connector 2
3.5MM (FEMALE)
Side B - Connector 3
DIN 14 PIN (MALE)
Latching or Gripping Connector
No
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“EZA-VGAAF-2”相匹配的价格&库存,您可以联系我们找货
