12002500
12002500
    BOPLA
    CABLE GLAND MBF 32 15-21MM
12002500 数据手册
Enclosures . . . . . . for Industry ® A Phoenix Mecano Company We are Dedicated to Achieving Customer Satisfaction Through Continuous Improvement. Rose+Bopla, the enclosure companies of Phoenix Mecano AG, an international corporation based in Switzerland, has developed a broad range of products for industrial applications. The North American operation is located in Frederick, Maryland. The Rose division manufactures an extensive line of off-the-shelf and custom enclosures, machine control enclosures and suspension arm systems suited for industrial applications and harsh environments in a variety of materials including: cast and extruded aluminum; stainless steel; compression molded fiberglass and polyamide; and injection molded polycarbonate and ABS plastic. Bopla produces a diverse line of modular tabletop, instrumentation, hand-held and wallmountable plastic enclosures designed to meet today's demands for aesthetic electronic packaging. Rose+Bopla adheres to DIN Standards in the manufacture of high quality components, and we offer a wide variety of added value services for customizing our products. At our Maryland facility in the US we operate a machine shop for modifying and building product, complete with CNC Machining Centers, powder coat and wet painting operations, as well as silk screening, engraving, and assembly services. In addition, our engineering personnel are available to assist in the design or customization of your product. We employ advanced manufacturing techniques and strict quality control methods. Meticulous internal controls built into our Quality system ensure that every Rose+Bopla enclosure meets critical quality standards. Our workmanship is unsurpassed in the industry. Let Rose+Bopla be your partner for standard or customized enclosures. We have attempted to present the information about our enclosures in this catalog in a straight-forward manner. We offer this information as accurate at the time of publication. Specifications are subject to change without notice. Rose+Bopla is not responsible for inadvertent errors. ©2007 Phoenix Mecano Inc., Frederick, MD 21704 Phoenix Mecano Inc. is ISO 9001:2000 Certified. Choosing an Enclosure Enclosure Comparison Chart Secondary Services Terms and Conditions Drawings and Design Information Industrial Enclosures Page 2 Page 3 Pages 4–5 Pages 6–7 Page 8 Pages 9–35 Terminal and Equipment Enclosures Aluminum, Fiberglass, Polycarbonate, ABS, Polystyrene Build-A-Box Electronic Enclosures Pages 36–61 Aluminum extrusion enclosures Instrumentation Pages 62–79 Polycarbonate, ABS, Polyamide Stainless Steel Enclosures Standard enclosures, Ex enclosures, Cabinets Handheld Enclosures For data acquisition, instrumentaion and automation applications Ex Enclosures Pages 80–83 Pages 84–101 Pages 102–108 Explosion-protected empty and explosion-protected terminal enclosures Fiberglass, Aluminum, Stainless steel Beluga Ex handheld enclosures, empty Operating and Display Enclosures/Suspension Systems Pages 109–121 Aluminum enclosures for control and display fittings Suspension systems and mobile moterms Cable Glands Pages 122–133 PG and metric versions Standard, EMC Brass, plastic Technical Information Specifications Tolerances Protection Classifications Credit Application For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 Pages 134–159 Pages 135–150 Pages 151–155 Pages 156–159 Page 160 1 Choosing an Enclosure GENERAL CONSIDERATIONS Generally, enclosures are intended to protect their contents from outside risks. These risks can be varied in nature and are of extreme importance when choosing an enclosure. In judging whether a particular housing meets the protection requirements of your application, a clear analysis of the environment where the enclosure is to be used should be made. The following conditions need to be taken into account: 1. Protection against contact with and penetration by foreign bodies; 2. Protection against water ingress; 3. Protection against external or internal radiated noise (RFI Shielding); 4. Chemical resistance; 5. Temperature resistance; 6. Impact resistance; 7. Corrosion resistance. In electronics/electrical engineering, the functions of enclosures are two-fold: 1. To protect the contents from mechanical risks and radiated noise from the outside. 2. To protect the environment from mechanical and electrical risks, as well as from radiated noise caused by installed components. With the ever-increasing development of electronic components, the increased packing densities on printed circuit boards, and the increased "contamination" of the environment by electromagnetic interference, electromagnetic compatibility is becoming an issue of growing importance in the choice of an enclosure. MATERIAL CONSIDERATIONS In most applications, material is a major factor in your choice of an enclosure. In general, aluminum is ideal for EMI/RFI applications; fiberglass is ideal for caustic environments and salt-water applications; polycarbonate is good for all indoor and light outdoor applications; and ABS is well suited for indoor instrumentation designs. PROTECTION CLASSIFICATIONS Rose+Bopla enclosures are classified under the generally applicable European protection guidelines of EN 60529 and IEC 144. These protection classifications are indicated by a designation consisting of two unchanging letters, IP, plus two digits for the protection grade. Many of the enclosures in this catalog bear the IP 66 or IP 65 protection classification. IP 65: Protection against ingress by dust and water jets IP 66: Protection against ingress by dust and powerful water jets Specific product lines are classified according to UL 50 and UL 508. These include aluminum, fiberglass, and plastic. Also noted in this catalog are recommended classification types like NEMA and UL, which are commonly used in the USA. Please contact the appropriate association or agency for complete infor-mation regarding test requirements and qualifications. Refer to the Technical Information Chapter in this catalog for more information on Protection Classifications. TEMPERATURE RESISTANCE The temperature resistance of enclosures is defined as the maximum permanent temperature at which the stability of the shape and the protection classification are maintained. Permissible short-term peak temperatures are often considerably higher. CORROSION RESISTANCE OF ALUMINUM ENCLOSURES Aluminum enclosures are resistant to corrosion even without a special surface treatment. The use of aluminum alloys with a low copper content increases corrosion resistance. Additional treatments such as irriditing, painting, powder-coating, or a combination of irriditing and painting provide increased corrosion resistance. IMPACT RESISTANCE Impact resistance is a measurement of the maximum impact that will not affect the protection classification. The breaking strength is often far greater. Impact resistance for Rose+Bopla enclosures is determined in an impact test to EN 50014. 2 www.Rose-Bopla.com Me ta l Pl as ti W c at er In tigh do t o Ou r td o In or du Ha stria za l r Op dou er s A a W tor reas all Int M e Di ou rfac sp nt e l Co ay nt r Me ol P m an b e Te ran l rm e Ca inal bi n Ha et nd h De eld sk Co top ns ol e Enclosure Comparison Chart Aluminum Watertight 01 Aluform Stainless Steel Watertight 37 Fiberglass Watertight 02 Polymas Watertight PK Polycarbonate 03 Polycarbonate 33 Polycarbonate EM ABS Watertight 09 ABS Watertight ET Aluminum Ex Polyglas® Ex Okta-Box Ex Stainless Steel Ex Fiberglass Modular Flange Polycarbonate Modular Flange Element Executive ECO/PCI Compact Build-A-Box ANG Panel Meter Housings Alubos TG Handheld Series BG Handheld Series Tastomat Pilot 250 Mobile Control Units Arteb Databoss Limanda CombiCard CombiSet Intercard RCP Housings CombiBac Ultramas 1300 Machine Control Enclosures 5400 Machine Control Enclosures Slim Line 2000 Rose Suspension Arm System 4925 Support System 8850 Support System NGS Panel Meter Housings Fiberglass Watertight Cabinets ABS Watertight Mini Cabinets Mini Console Housings BP 810 & BP 900 F Housings Futura Sloped Housings Profitronic 19 Profitronic 19 Universal • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • 3 Secondary Services IRRIDITING/ CHROMATING/ ANODIZING For greater chemical resistance to corrosion in aluminum housings, consider using a chemical treatment process like irriditing, chromating, or anodizing. Subsequent priming and painting give lasting protection from corrosive attacks. Anodizing is available in black, or clear as standard. RFI/EMC SHIELDING RFI spray on plastic and fiberglass housings offers protection for your design against adverse interference or radiation. We can also install RFI gaskets, on request. PAINTING POWDER/COATING We routinely paint to customer requirements in smooth or textured finishes, using Federal Standard 595A colors, RAL colors, or other special colors. SCREEN PRINTING Using the screen print process, we are able to print your data on all housings and front plates. Silk-screen inks are available in several colors and are resistant to most solvents. Rose+Bopla creates screens in-house and can provide artwork services, if required. ENGRAVING Rose+Bopla offers engraving services using any alphabet or outline. Engraving is performed in-house by computer controlled machines. 4 www.Rose-Bopla.com Secondary Services DRILLING We can drill holes through all housings in tolerances to 0.002 of an inch. TAPPING Using NPT, Metric, or PG taps, we can thread holes in your housings to your specifications, on request. MILLING Our CNC processing center enables us to carry out difficult machining work to tight tolerances. The program for your job will be stored ensuring that future orders can be repeated with the same accuracy and quality. ASSEMBLY On request, we install accessories such as cable grips, conduit hubs, terminal blocks, DIN Rail assemblies, wiring, hinges, optional gaskets, and customer components into your housings. PANEL WORK Rose+Bopla fabricates panels using various thicknesses of plate aluminum and plastic material, as well as screen printing information on panels..all to your specifications. For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 5 Terms and Conditions This is an overview of our Terms and Conditions. A full written version is available on request. Terms and Conditions are subject to change without notice CATALOG LISTINGS Most products listed in this catalog are available, at our stocking location in Frederick, Maryland. On occasion slow moving items may have to be brought in from our sister company in Germany. All specifications and descriptions are current, as of the time of publication. Product listings, specifications, availability, and pricing are subject to change without notice. Detailed drawings are available on the internet and directly from the company on request. PRODUCT WARRANTY Phoenix Mecano Inc. warrants all its products to be free from defects in materials and workmanship. Phoenix Mecano’s liability under this warranty shall be limited to ninety days after delivery of the product to the original purchaser. Disputed product must be returned to Phoenix Mecano with prepaid transportation charges. After examination by Phoenix Mecano, should the product be found to be defective we will repair or replace it from our factory. Any defect is to be determined by accepted testing methods at Phoenix Mecano Inc. Any returned product found to be defective would become the property of Phoenix Mecano, Inc. Phoenix Mecano Inc. shall not be liable to the purchaser for the cost of repairs, alterations, replacement, or any other expenses (including loss of profits, additional labor costs, or injury to persons or property caused by defective material or parts) incurred by the purchaser, their employees, or agents. One exception would be where Phoenix Mecano had previously authorized such repairs, alterations, or consequential damages. This warranty shall not apply to products, which have been altered or repaired, except by Phoenix Mecano, Inc., or which have been subjected to misuse, negligence, or accident, including the use or operation of the products while parts are loose, broken, out of order, or damaged by the elements. This warranty supersedes all other warranties, expressed or implied, including any implied warranty of merchantability, and of all other obligations or liability on the part of Phoenix Mecano, Inc. PRICING Rose+Bopla offers standard OEM pricing based on quantity price breaks. For pricing information please contact the Rose+Bopla sales staff or your local distributor. Prices are subject to change without notice. RETURNS Submit your drawings for pricing information on our secondary services, such as, CNC machining, painting, EMC/RFI spray shielding, silk-screening, chemical coating, and engraving...just to mention a few of the customizing services we offer. 1. All returns must be accompanied by an RMA (return merchandise authorization). Please call your inside salesperson for an RMA number. Invoice or Packing Slip number must accompany return. 2. All returns due to customer error must be made within 30 days from the date of the invoice. 3. Warranty returns must be made within 90 days from the date of the invoice. 4. All returned product must be in resalable condition and in the original carton. 5. Off-the-shelf parts, returned due to customer error, are subject to a minimum 15% restocking charge. 6. Defective merchandise returns are evaluated on an individual basis. 7. Parts that have been modified and special order items are not returnable. METHODS OF PAYMENT Rose+Bopla has four methods of payment; Net 30 day credit, C.O.D, credit card and pre-payment. 6 www.Rose-Bopla.com Terms and Conditions NET 30 ACCOUNTS Net 30-account status is generally granted to qualified customers with appropriate credit and banking references. C.O.D. ACCOUNTS C.O.D. orders for product that has value added operations performed by Rose+Bopla require 50% down payment at time of order. The balance will be collected at time of shipment. CREDIT CARD ACCOUNTS Rose+Bopla accepts American Express, Discover, Master Card, Visa, or electronic funds transfers. PREPAYMENTS Payments can be made electronically directly to our bank account. Please contact an Accounts Receivable representative for our banking information. TO OPEN A NEW ACCOUNT To open a new account, please complete the credit application form in the back of this catalog. Fill out all references for credit contact. Names, addresses and telephone numbers will speed processing of your application. Rose+Bopla must have the credit application filled out in writing and signed BY CUSTOMER ONLY. Applications may be mailed or faxed (301-696-9493) to our Accounting Department in order to process a credit request. Please allow sufficient processing time. SALES TAX We are required by law to charge and collect Maryland sales tax. If you wish to avoid being charged state sales tax, you must submit a state sales tax exemption certificate annually to Rose+Bopla. Sales tax will always be charged unless otherwise indicated. MINIMUM ORDER All orders are subject to a minimum order value of $100.00 SHIPMENT DAMAGE Our products are inspected and carefully packed for shipment. In the event an item is damaged in shipment, you must submit a claim to the carrier within 15 days of delivery. We advise that you unpack and inspect all merchandise immediately upon receiving it. If damage does not become apparent until the shipment is unpacked, keep the shipping carton and make a request within 72 hours for inspection by the carrier’s agent and file a claim with the carrier. Any external evidence of loss or damage must be noted on the freight bill. Failure to do this will result in the carrier refusing to honor the claim. Rose+Bopla will not be responsible for shipment damage or lost parts due to such damage. DELIVERY Items are shipped F.O.B. Frederick, Maryland. All orders are shipped UPS unless the weight prohibits shipment by this method. On heavier shipments we will attempt to ship by the carrier of your choice. SAME DAY SHIPMENT All orders to be shipped Air and received by 4 p.m. EST are shipped the same day. All UPS shipments are prepaid and charges added to the invoice, unless otherwise requested. LARGE ITEMS AND SPECIAL HANDLING For heavy shipments, common carrier truck is the most economical. Charges are F.O.B. shipping point and the product is shipped freight prepaid and charges are added to your invoice, unless otherwise requested. BLANKET ORDERS 1. A “Blanket Purchase Order” is an agreement between two parties, “Seller/Buyer” to purchase a specific quantity of products over a specified period of time “Not to Exceed 12 Months”. 2. Blanket Orders cannot be changed or canceled without 90-day advance written notice. Customer will be responsible for all parts manufactured for shipment within this 90-day period. 3. Blanket Orders canceled for standard enclosures will result in customer being billed back for the difference between the price break of quantity received, versus total quantity ordered. 4. Blanket Orders for modified or special order products must state Non-cancelable/Non-returnable on the Purchase Order. 5. All Blanket Orders must have firm ship dates stated on the Purchase Order for every release. Terms of payment are net 30 days. Past due accounts are subject to late payment charge of 1½% per month. For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 7 Drawings & Design Information DESIGNING WITH Rose+Bopla offers the engineer faced with packaging requirements an enormous advantage in finding a ROSE+BOPLA solution. Electronic products need enclosures. Our ability to deliver off-the-shelf enclosures makes Rose+Bopla one of the most important partners an engineer could ask for when bringing a product to market. We offer both electrical and electronic enclosures and have one of the widest ranges of standard off-the-shelf enclosures in the industry. Rose+Bopla also offers years of expertise in machining and other value added services, as well as technical support from an experienced technical sales force. Rose+Bopla also guarantees all secondary services and machining 100%, thereby eliminating scrap and additional costs. The benefits of designing with Rose+Bopla enclosures are: cost savings, elimination of custom tool/ molding expense, a large off-the-shelf inventory, no scrap, machining expertise and over 30 years experience in enclosure manufacturing. Take advantage of our experience and reduce your frustrations from dealing with multiple vendors. Rose+Bopla can offer you a turnkey solution that is 100% guaranteed. DRAWINGS Rose+Bopla recognizes that dimensional information is very important to our customers. Therefore, we have taken advantage of other media channels to provide more comprehensive drawing information. For more detailed dimensional information, or for CAD drawings: 1. Contact our inside Rose+Bopla sales staff by telephone at 301-696-9800. 2. Download drawing(s) from our website at www.rose-bopla.com. All product drawings are not available on the website. Our internal sales staff has access to a larger library of drawings. Please feel free to call us if you do not find the product drawing you need. 3. Request that the drawing(s) be sent to you via e-mail, by contacting us by phone, 301-696-9800, or fax us at 301-696-9494. CUSTOM DESIGNS Rose+Bopla not only supplies empty standard enclosures, but can also provide and deliver custom designs. We have skilled technical support personnel in-house that will work with your engineering staff on a custom enclosure design for your next product. By means of direct communications with you, the customer, we can create an individual solution to fit your precise requirements. SPECIAL MATERIALS Rose+Bopla can injection-mold most plastic enclosures in special colors and/or special materials. Minimum quantities for special injection runs range from 500 to 1,000 units depending on the enclosure. For special colors, please send us a sample of the color you would like to match. Rose+Bopla cannot guarantee an exact color match. If you need a special material for improved flame retardancy, impact resistance, chemical resistance, etc., let us know specifically what specifications you need to meet. We will suggest a material suitable for use in our molds that meets your requirements. 8 www.Rose-Bopla.com Industrial Enclosures The universal design of ROSE industrial enclosures made from Aluminum, Fiberglass, Stainless Steel, Polycarbonate, ABS, and Polystyrene is the basis of their versatility. They are designed to accommodate mechanical parts as well as electrical and electronic components. Apart from standard versions, flange enclosures are also available in Aluminum, Fiberglass, and Polycarbonate. Aluform Aluminum Enclosure • 14 enclosure sizes from 80 x 80 x 80 mm to 200 x 280 x 70mm • Application area: its elegant design makes it ideal for use in areas where the visual impression is important. Standard Aluminum Enclosures / Aluminum Flange Enclosures • 48 enclosure sizes from 45 x 50 x 30 mm to 600 x 600 x 200 mm • Application area: standard industrial enclosures Standard Fiberglass Enclosures • 26 enclosure sizes from 55 x 55 x 37 mm to 405 x 400 x 120 mm • Application area: standard industrial enclosures Fiberglass Flange Enclosures • 6 enclosure sizes from 170 x 270 x 135 mm to 270 x 540 x 150 mm with two flange openings • Application area: fieldbus and installation enclosures Standard Polycarbonate/ABS Enclosures • 25 enclosure sizes from 50 x 52 x 35 mm to 360 x 400 x 150 mm • Application area: standard installation enclosures Polycarbonate Flange Enclosures • 6 enclosure sizes from 134 x 170 x 130 mm to 369 x 440 x 130 mm with 2 to 6 flange openings • Application area: standard installation enclosures ECO/PCI Compact Enclosures • 47 enclosure sizes from 65 x 65 x 57 mm to 254 x 355 x 165 mm GRP 3040/4060 Fiberglass Cabinets • 5 enclosure sizes from 300 x 400 x 200 mm to 400 x 600 x 250 mm • Application area: robust universal cabinet with hinged lid GFK Fiberglass/ABS Mini Cabinets • 4 enclosure sizes from 199 x 248.5 x 149 mm to 250 x 300 x 170 mm • Application area: universal cabinet with hinged lid for measurement/ control technology GRP Fiberglass Mini Cabinets • 6 enclosure sizes from 120 x 200 x 100 mm to 200 x 300 x 170 mm • Application area: robust mini-cabinets with hinged lid for measurement/ control technology For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 9 Aluform, Painted • Aluminum enclosure system for automation engineering • Lid designed for membrane keypads and overlays • Rectangular dome sequence in cover and base Included in delivery Aluminum enclosure consisting of lid, base, captive stainless steel lid screws, and removable polyurethane gasket UL 50 Technical Data Material Ingress Protection Impact Resistance Temperature Resistance Painting Color Part Number 04080808 00 04081208 00 04101006 00 04101606 00 04102006 00 04121208 00 04121608 00 04141407 00 04141807 00 04142207 00 04161608 00 04162408 00 04202007 00 04202807 00 Al Si 12, DIN 1725 IP 66 to EN 60529 >7 Nm, EN 50014 Polyurethane seal: -40°F to +194°F Neoprene seal: -40°F to +212°F Silicone seal: -76°F to +266°F RFI gasket: -40°F to +392°F Powdercoating Agate gray, similar to RAL 7038, special colors on request Dimensions mm Dimensions Inches WxLxH WxLxH TS 15 TS 35 3.15 x 3.15 x 3.15 4.72 x 3.15 x 3.19 3.94 x 3.94 x 2.40 3.94 x 6.30 x 2.40 3.94 x 7.87 x 2.40 4.72 x 4.72 x 3.19 6.30 x 4.72 x 3.19 5.51 x 5.51 x 2.80 5.51 x 7.09 x 2.80 5.51 x 8.66 x 2.80 6.30 x 6.30 x 3.19 9.45 x 6.30 x 3.19 7.87 x 7.87 x 2.80 7.87 x 11.02 x 2.80 • • • • • • • • • • • • • • • • • • • • • • • • • • • • 80 x 80 x 80 80 x 120 x 80 100 x 100 x 60 100 x 160 x 60 100 x 200 x 60 120 x 120 x 80 120 x 160 x 80 140 x 140 x 70 140 x 180 x 70 140 x 220 x 70 160 x 160 x 80 160 x 240 x 80 200 x 200 x 70 200 x 280 x 70 TS DIN rails for terminals Mounting Plate1) External brackets pair External aluminum hinges, pair3) EMC screening Corrosion resistant Allen lid screws2) • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • 1) 2) 3) Phenolic Stainless steel Cast aluminum Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories External brackets, pair for 0408 External brackets, pair for 0410 External brackets, pair for 0412 External brackets, pair for 0414 External brackets, pair for 0416 External brackets, pair for 0420 Console holder for wall or table mounting 98 mm wide, for type 0410 Console holder for wall ot table mounting 138 mm wide, for type 0414 External hinges, pair, painted 10 04000080 00 04000001 00 04002001 00 04004001 00 04006001 00 04000002 00 04300009 00 04300014 00 04000010 00 www.Rose-Bopla.com Aluform, Unpainted • Aluminum enclosure system for automation engineering • Lid designed for membrane keypads and overlays • Rectangular dome sequence in cover and base Included in delivery Aluminum enclosure consisting of lid, base, captive stainless steel lid screws, and removable polyurethane gasket UL 50 Technical Data Material Ingress Protection Impact Resistance Temperature Resistance Painting Color Part Number Dimensions mm WxLxH 04080808 85 04081208 85 04101006 85 04101606 85 04102006 85 04121208 85 04121608 85 04141407 85 04141807 85 04142207 85 04161608 85 04162408 85 04202007 85 04202807 85 80 x 80 x 80 80 x 120 x 80 100 x 100 x 60 100 x 160 x 60 100 x 200 x 60 120 x 120 x 80 120 x 160 x 80 140 x 140 x 70 140 x 180 x 70 140 x 220 x 70 160 x 160 x 80 160 x 240 x 80 200 x 200 x 70 200 x 280 x 70 Al Si 12, DIN 1725 IP 66 to EN 60529 >7 Nm, EN 50014 Polyurethane seal: -40°F to +194°F Neoprene seal: -40°F to +212°F Silicone seal: -76°F to +266°F RFI gasket: -40°F to +392°F Powdercoating Agate gray, similar to RAL 7038, special colors on request Dimensions Inches TS DIN rails for terminals WxLxH TS 15 TS 35 3.15 x 3.15 x 3.15 4.72 x 3.15 x 3.19 3.94 x 3.94 x 2.40 3.94 x 6.30 x 2.40 3.94 x 7.87 x 2.40 4.72 x 4.72 x 3.19 6.30 x 4.72 x 3.19 5.51 x 5.51 x 2.80 5.51 x 7.09 x 2.80 5.51 x 8.66 x 2.80 6.30 x 6.30 x 3.19 9.45 x 6.30 x 3.19 7.87 x 7.87 x 2.80 7.87 x 11.02 x 2.80 • • • • • • • • • • • • • • • • • • • • • • • • • • • • Mounting Plate1) External brackets pair External aluminum hinges, pair3) EMC screening Corrosion resistant Allen lid screws2) • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • 1) 2) 3) Phenolic Stainless steel Cast aluminum Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories (Painted) External brackets, pair for 0408 External brackets, pair for 0410 External brackets, pair for 0412 External brackets, pair for 0414 External brackets, pair for 0416 External brackets, pair for 0420 Console holder for wall or table mounting 98 mm wide, for type 0410 Console holder for wall ot table mounting 138 mm wide, for type 0414 External hinges, pair, unpainted 04000080 00 04000001 00 04002001 00 04004001 00 04006001 00 04000002 00 04300009 00 04300014 00 04000010 85 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 11 Standard & Flange Aluminum Enclosures, Painted • Robust aluminum enclosure for mechanical and automation engineering • Standard enclosures prepared for acceptance of DIN rail and mounting plates • Flange enclosures with 4, 6, or 8 flange openings Included in delivery Aluminum diecast enclosure consisting of lid with seal and captive stainless steel screws; base with 2 or 4 ground screws; flange enclosures with flange openings (please order flange plates separately). UL 508 UL 50 Technical Data Material Ingress Protection Impact Resistance Temperature Resistance Painting Color Part Number Dimensions mm WxLxH Al Si 12, DIN 1725 IP 66 to EN 60529. Flange: IP 65 EN 60526 >7 Nm, EN 50014 Neoprene gasket: -40°F to +212°F Silicone gasket: -76°F to +266°F RFI gasket: -40°F to +392°F Polyurethane -40°F to +194°F Powdercoating Silver gray, similar to RAL 7001, special colors on request Dimensions Inches WxLxH Part Number Dimensions mm WxLxH Standard enclosures 01122208 00 120 x 220 x 80 01050503 00 45 x 50 x 30 1.77 x .97 x 45 01122209 00 120 x 220 x 90 01060603 00 64 x 58 x 34 2.52 x 2.28 x 1.34 01122212 00 120 x 220 x 120 01061003 00 64 x 98 x 34 3.86 x 2.52 x 1.34 01123608 00 120 x 360 x 80 01061503 00 64 x 150 x 34 2.52 x 5.91 x 1.34 01141409 00 140 x 140 x 90 01061903 00 64 x 185 x 34 2.52 x 7.28 x 1.34 01142009 00 140 x 200 x 90 01080806 00 80 x 75 x 57 3.15 x 2.95 x 2.24 01161609 00 160 x 160 x 90 01081306 00 80 x 125 x 57 3.15 x 4.92 x 2.24 01162609 00 160 x 260 x 90 01081806 00 80 x 175 x 57 3.15 x 6.89 x 2.24 01163609 00 160 x 360 x 90 01082505 00 80 x 250 x 52 3.15 x 9.84 x 2.05 01165609 00 160 x 560 x 90 01101008 00 100 x 100 x 80 3.94 x 3.94 x 3.19 01181810 00 180 x 180 x 100 01101608 00 100 x 160 x 80 3.94 x 6.30 x 3.19 01182810 00 180 x 280 x 100 01102008 00 100 x 200 x 80 3.94 x 7.87 x 3.19 01231011 00 100 x 230 x 110 01121208 00 120 x 122 x 80 4.72 x 4.80 x 3.19 01232011 00 230 x 200 x 110 01121209 00 120 x 122 x 90 4.72 x 4.80 x 3.58 Flange Enclosures Flange openings 4 11232011 00 230 x 200 x 110 9.05 x 7.78 x 4.33 4 11232811 00 230 x 280 x 110 9.05 x 11.02 x 4.33 6 11234011 00 230 x 400 x 110 9.05 x 15.75 x 4.33 8 11236011 00 230 x 600 x 110 9.05 x 23.62 x 4.33 Aluminum Watertight Enclosures With External Mounting Flange 01061200 00 64 x 115 x 34.5 2.52 x 4.53 x 1.36 01061900 00 64 x 186 x 34.5 2.52 x 7.32 x 1.36 Dimensions Inches WxLxH 4.72 x 8.66 x 3.19 4.72 x 8.66 x 3.58 4.72 x 14.17 x 3.19 5.51 x 5.51 x 3.58 5.51 x 7.87 x 3.58 5.51 x 7.87 x 3.58 6.30 x 6.30 x 3.58 6.30 x 10.24 x 3.58 6.30 x 14.17 x 3.58 6.30 x 22.05 x 3.58 7.09 x 7.09 x 3.98 11.02 x 7.09 x 3.98 3.94 x 9.06 x 4.33 9.13 x 7.95 x 4.37 Part Number Dimensions mm WxLxH Dimensions Inches WxLxH 01232018 00 01232811 00 01233311 00 01233318 00 01234011 00 01234023 00 01236011 00 01314011 00 01314014 00 01314018 00 01314023 00 01316011 00 01316018 00 01606020 00 230 x 200 x 180 230 x 280 x 110 230 x 330 x 110 230 x 330 x 180 230 x 400 x 110 230 x 400 x 224 230 x 600 x 110 310 x 400 x 110 310 x 400 x 140 310 x 400 x 180 310 x 400 x 226 310 x 600 x 110 310 x 600 x 180 600 x 600 x 200 9.13 x 7.95 x 7.09 9.06 x 11.02 x 4.37 9.06 x 12.99 x 4.37 9.06 x 12.99 x 7.13 9.06 x 15.75 x 4.37 9.06 x 15.75 x 8.86 9.06 x 23.62 x 4.37 12.32 x 15.91 x 4.37 12.32 x 15.91 x 5.55 12.32 x 15.91 x 7.13 12.32 x 15.91 x 8.94 12.20 x 23.62 x 4.37 12.20 x 23.62 x 7.13 23.62 x 23.62 x 7.95 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. 12 www.Rose-Bopla.com Accessories Part Number TS DIN rails for terminals TS 15 Mounting plate thickness in mm External brackets pair set1) External aluminum hinges, pair3) Hinges inside pair 2) Corrosion resistant Allen lid screws2) Silicon lid seal up to +266° F Lead-sealable steel lid screws • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • TS 355) Standard Enclosures 01050503 00 01060603 00 01061003 00 01061503 00 01061903 00 01080806 00 01081306 00 01081806 00 01082505 00 01101008 00 01101608 00 01102008 00 01121208 00 01121209 00 01122208 00 01122209 00 0112221200 01123608 00 01141409 00 01142009 00 01161609 00 01162609 00 01163609 00 01165609 00 01181810 00 01182810 00 01231011 00 01232011 00 01232018 00 01232811 00 01233311 00 01233318 00 01234011 00 01234023 00 01236011 00 01314011 00 01314014 00 01314018 00 01314023 00 01316011 00 01316018 00 01606020 00 • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 2.0 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.5 • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • Flange Enclosures 11232011 00 11232811 00 11234011 00 11236011 00 • • • • • • • • Aluminum Watertight Enclosures With External Mounting Flange 01061200 00 01061900 00 2) 3) 5) Stainless Steel Die Cast Aluminum TS 32 on Request Galvanized Steel Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. 1) Accessories for Flange Enclosures Blank flange 10006001 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 13 Standard & Flange Aluminum Enclosures, Unpainted • Robust aluminum enclosure for mechanical and automation engineering • Standard enclosures prepared for acceptance of DIN rail and mounting plates • Flange enclosures with 4, 6 or 8 flange openings Included in delivery Aluminum diecast enclosure consisting of lid with seal and captive stainless steel screws; base with 2 or 4 ground screws; flange enclosures with flange openings (please order flange plates separately). UL 508 UL 50 Technical Data Material Ingress Protection Impact Resistance Temperature Resistance Painting Color Part Number Dimensions mm WxLxH Al Si 12, DIN 1725 IP 66 to EN 60529. Flange: IP 65 EN 60526 >7 Nm, EN 50014 Neoprene gasket: -40°F to +212°F Silicone gasket: -76°F to +266°F RFI gasket: -40°F to +392°F Polyurethane -40°F to +194°F Powdercoating Silver gray, similar to RAL 7001, special colors on request Dimensions Inches WxLxH Part Number Dimensions mm WxLxH Standard enclosures 01122208 85 120 x 220 x 80 01050503 85 45 x 50 x 30 1.77 x .97 x 45 01122209 85 120 x 220 x 90 01060603 85 64 x 58 x 34 2.52 x 2.28 x 1.34 01122212 85 120 x 220 x 120 01061003 85 64 x 98 x 34 3.86 x 2.52 x 1.34 01123608 85 120 x 360 x 80 01061503 85 64 x 150 x 34 2.52 x 5.91 x 1.34 01141409 85 140 x 140 x 90 01061903 85 64 x 185 x 34 2.52 x 7.28 x 1.34 01142009 85 140 x 200 x 90 01080806 85 80 x 75 x 57 3.15 x 2.95 x 2.24 01161609 85 160 x 160 x 90 01081306 85 80 x 125 x 57 3.15 x 4.92 x 2.24 01162609 85 160 x 260 x 90 01081806 85 80 x 175 x 57 3.15 x 6.89 x 2.24 01163609 85 160 x 360 x 90 01082505 85 80 x 250 x 52 3.15 x 9.84 x 2.05 01165609 85 160 x 560 x 90 01101008 85 100 x 100 x 80 3.94 x 3.94 x 3.19 01181810 85 180 x 180 x 100 01101608 85 100 x 160 x 80 3.94 x 6.30 x 3.19 01182810 85 180 x 280 x 100 01102008 85 100 x 200 x 80 3.94 x 7.87 x 3.19 01231011 85 100 x 230 x 110 01121208 85 120 x 122 x 80 4.72 x 4.80 x 3.19 01232011 85 230 x 200 x 110 01121209 85 120 x 122 x 90 4.72 x 4.80 x 3.58 Flange openings Flange Enclosures 4 11232011 85 230 x 200 x 110 9.05 x 7.78 x 4.33 4 11232811 85 230 x 280 x 110 9.05 x 11.02 x 4.33 6 11234011 85 230 x 400 x 110 9.05 x 15.75 x 4.33 8 11236011 85 230 x 600 x 110 9.05 x 23.62 x 4.33 Aluminum Watertight Enclosures with External Mounting Flange 01061200 85 64 x 115 x 34.5 2.52 x 4.53 x 1.36 01061900 85 64 x 186 x 34.5 2.52 x 7.32 x 1.36 Dimensions Inches WxLxH 4.72 x 8.66 x 3.19 4.72 x 8.66 x 3.58 4.72 x 14.17 x 3.19 5.51 x 5.51 x 3.58 5.51 x 7.87 x 3.58 5.51 x 7.87 x 3.58 6.30 x 6.30 x 3.58 6.30 x 10.24 x 3.58 6.30 x 14.17 x 3.58 6.30 x 22.05 x 3.58 7.09 x 7.09 x 3.98 11.02 x 7.09 x 3.98 3.94 x 9.06 x 4.33 9.13 x 7.95 x 4.37 Part Number Dimensions mm WxLxH Dimensions Inches WxLxH 01232018 85 01232811 85 01233311 85 01233318 85 01234011 85 01234023 85 01236011 85 01314011 85 01314014 85 01314018 85 01314023 85 01316011 85 01316018 85 01606020 85 230 x 200 x 180 230 x 280 x 110 230 x 330 x 110 230 x 330 x 180 230 x 400 x 110 230 x 400 x 224 230 x 600 x 110 310 x 400 x 110 310 x 400 x 140 310 x 400 x 180 310 x 400 x 226 310 x 600 x 110 310 x 600 x 180 600 x 600 x 200 9.13 x 7.95 x 7.09 9.06 x 11.02 x 4.37 9.06 x 12.99 x 4.37 9.06 x 12.99 x 7.13 9.06 x 15.75 x 4.37 9.06 x 15.75 x 8.86 9.06 x 23.62 x 4.37 12.32 x 15.91 x 4.37 12.32 x 15.91 x 5.55 12.32 x 15.91 x 7.13 12.32 x 15.91 x 8.94 12.20 x 23.62 x 4.37 12.20 x 23.62 x 7.13 23.62 x 23.62 x 7.95 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. 14 www.Rose-Bopla.com Accessories Part Number TS DIN rails for terminals TS 15 Mounting plate thickness in mm External brackets pair set1) External aluminum hinges, pair3) Hinges inside pair 2) Corrosion resistant Allen lid screws2) Silicon lid seal up to +266° F Lead-sealable steel lid screws • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • TS 353) Standard Enclosures 01050503 85 01060603 85 01061003 85 01061503 85 01061903 85 01080806 85 01081306 85 01081806 85 01082505 85 01101008 85 01101608 85 01102008 85 01121208 85 01121209 85 01122208 85 01122209 85 01122212 85 01123608 85 01141409 85 01142009 85 01161609 85 01162609 85 01163609 85 01165609 85 01181810 85 01182810 85 01231011 85 01232011 85 01232018 85 01232811 85 01233311 85 01233318 85 01234011 85 01234023 85 01236011 85 01314011 85 01314014 85 01314018 85 01314023 85 01316011 85 01316018 85 01606020 85 • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 2.0 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.5 • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • Flange Enclosures 11232011 85 11232811 85 11234011 85 11236011 85 • • • • • • • • Aluminum Watertight Enclosures With External Mounting Flange 01061200 85 01061900 85 1) 2) 3) 5) Galvanized Steel Stainless Steel Die Cast Aluminum TS 32 on Request Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories for Flange Enclosures Blank flange 10006001 85 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 15 Fiberglass Watertight 02 • Robust enclosure for automation engineering • Universal construction Included in delivery Fiberglass enclosure consisting of lid, base, seal, and captive stainless steel lid screws. Technical Data UL 508 Material Ingress Protection Impact Resistance Flammability Insulation Temperature Resistance Glassfiber-reinforced, duroplastic Polyester IP 66 to EN 60529 >7 Nm, EN 50014 UL 94 V0 Fully insulated to VDE 100 Neoprene gasket: -40°F to +212°F Silicone gasket: -76°F to +266°F Polyurethane gasket: -40°F to +194°F 18 KV/mm Halogen-free >1012 Ohm VDE 0303 DIN 53482 Gray, similar to RAL 7000, special colors on request Disruptive Strength Toxicity Surface Resistance Color Part Number 02060603 00 02060606 00 02080806 00 02080808 00 02081106 00 02081108 00 02081606 00 02081608 00 02081906 00 02081908 00 02082306 00 02082308 00 02103208 00 02121209 00 02122209 00 02161609 00 02162609 00 02163609 00 02165609 00 02252612 00 02252616 00 02254012 00 02254016 00 02256012 00 02363609 00 02414012 00 1) Dimensions mm Dimensions Inches TS DIN rails for terminals WxLxH WxLxH TS 15 TS 35 6) 55 x 55 x 37 55 x 55 x 59 75 x 80 x 55 75 x 80 x 75 75 x 110 x 55 75 x 110 x 75 75 x 160 x 55 75 x 160 x 75 75 x 190 x 55 75 x 190 x 75 75 x 230 x 55 75 x 230 x 75 100 x 320 x 80 120 x 122 x 90 120 x 220 x 90 160 x 160 x 90 160 x 260 x 90 160 x 360 x 90 160 x 560 x 90 250 x 255 x 120 250 x 255 x 160 250 x 400 x 120 250 x 400 x 160 250 x 600 x 120 360 x 360 x 90 405 x 400 x 120 2.17 x 2.17 x 1.46 2.17 x 2.17 x 2.32 2.95 x 3.15 x 2.20 2.95 x 3.15 x 2.95 2.95 x 4.33 x 2.20 2.95 x 4.33 x 2.95 2.95 x 6.30 x 2.20 2.95 x 6.30 x 2.95 2.95 x 7.48 x 2.20 2.95 x 7.48 x 2.95 2.95 x 9.06 x 2.20 2.95 x 9.06 x 2.95 2.95 x 12.60 x 3.19 4.72 x 4.80 x 3.58 4.72 x 8.66 x 3.58 6.30 x 6.30 x 3.58 6.30 x 10.24 x 3.58 6.30 x 14.17 x 3.58 6.30 x 22.05 x 3.58 9.84 x 10.04 x 4.76 9.84 x 10.04 x 6.34 9.84 x 15.75 x 4.76 9.84 x 15.75 x 6.34 9.84 x 23.62 x 4.76 14.17 x 14.17 x 3.58 15.94 x 15.94 x 4.76 Mounting Plate Thickness in mm 25) • • • • • • • • • • • 25) 25) 25) • • • • • • • • • • • • • 1.51) 1.51) 1.51) 2.51) 2.51) 2.51) 2.51) 2.01) 2.01) 2.01) 2.01) 2.01) 2.01) 2.01) External brackets pair2) • • • • • • • • • • • • • • • • • • • • • • • • External aluminum hinges, pair3) Allen lid screws2) Silicone lid seal up to 257°F • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • 2) 5) 3) Plastic cover insulated Laminated paper Stainless steel Galvanized steel Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. 16 UL 50 6) TS 32 on request www.Rose-Bopla.com Polyester Flange Enclosures • Enclosures with flange openings for automation engineering • Multiple configurations possible by combining with other Fiberglass Flange enclosures. Included in delivery Enclosure in Fiberglass consisting of lid with seal, and plastic quick-release lock screws; base with flange openings, threaded insert set (4 pcs.). Please order flange plates separately. Technical Data Standard Version Material Ingress Protection Impact Resistance Flammability Insulation Temperature Resistance Water Absorption Disruptive Strength Toxicity Surface Resistance Color Part Number Dimensions mm Dimensions Inches WxLxH WxLxH 14010000 00 170 x 270 x 135 6.69 x 10.63 x 5.31 14020000 00 270 x 270 x 135 10.63 x 10.63 x 5.91 14030000 00 270 x 540 x 135 10.63 x 21.26 x 5.31 Version with Polycarbonate Transparent Lid 6.69 x 10.63 x 5.91 270 x 270 x 150 14010001 00 10.63 x 10.63 x 5.91 270 x 270 x 150 14020001 00 10.63 x 21.26 x 5.91 270 x 540 x 150 14030001 00 *TS 32 on request With Polycarbonate Transparent Lid Glassfiber-reinforced, duroplastic Polyester IP 65 to EN 60529 >7 Nm, EN 50014 UL 94 V0 Fully insulated to VDE 010 Neoprene gasket: -40°F to +212°F Silicone gasket: -76°F to +266°F Polyurethane gasket: -40°F to +194°F RFI gasket: -40°F to + 392°F max. 0.7% downstream of ASTM D 570 18 KV/mm Halogen-free >1012 Ohm VDE 0303 DIN 53482 Gray, similar to RAL 7032, special colors on request IP 65 to EN 60529 V2 / UL 94 Fully insulated to VDE 0100 Polyurethane gasket: -40°F to +194°F max 0.2% DIN 53405 ISO/R62 >30 Kv/mm VDE 0303 DIN 53481 Halogen-free >1015 Ohm VDE 0303 DIN 53482 Gray, similar to RAL 7000, special colors on request Flange Openings Mounting Plate Front Plate * DIN Rail TS 35 Silicone Seal for Lid 2 4 6 14000011 00 14000012 00 14000013 00 14000027 00 14000028 00 14000029 00 10061721 00 10061722 00 10061723 00 10051501 00 10051502 00 10051503 00 2 4 6 14000011 00 14000012 00 14000013 00 14000027 00 14000028 00 14000029 00 10061721 00 10061722 00 10061723 00 10051501 00 10051502 00 10051503 00 Note: Standard delivery is without flanges, please order flange plates separately. Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Flanges and Accessories Blind Flange Threaded flange (17 x PG 11) Threaded flange (14 x PG 13.5) Threaded flange (11 x PG 16) Threaded flange (4 x PG 16, 2 x PG 21.1 x PG 29 Connecting flange (11 x PG 16) Lid hinges (2 pcs.) for all types External brackets (4 pcs.) Threaded insert, additional (10 pcs.) Silicone seal for flanges Silicone seal for connecting flange 14000020 00 14000030 00 14000022 00 14000021 00 14000023 00 14000025 00 14000026 00 10031102 00 10035002 00 10051402 00 10051403 00 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 17 Standard Polycarbonate / ABS Enclosures • Light-weight plastic enclosures for industrial applications • Polycarbonate enclosure with standard or transparent lid • Optional RFI version with coating Included in delivery Plastic enclosure consisting of lid with seal and captive stainless steel lid screws; base with 2 self-tapping screws for fastening internal components. UL 508 Technical Data ABS Polycarbonate Polycarbonate IP 66 EN 60529 >1012 OHm, DIN 53481 > 18 KV/mm, DIN 53481 Fully insulated, VDE 0100 UL 94 V0 >7Nm to EN 50014 -40°F to + 212°F (neoprene gasket) Light gray, similar to RAL 7035. Special colors on request. Halogen-free Material Ingress Protection Surface Resistance Disruptive Strength Insulation Flammability Impact Resistance Temperature Range Color Toxicity Polycarbonate Enclosure Part Number Polycarbonate Enclosure with Transparent Lid Part Number ABS Enclosure Part Number Dimensions mm Dimensions Inches WxLxH WxLxH 03050504 00 03050704 00 03080806 00 03080809 00 03081206 00 03081209 00 03081606 00 03081609 00 03082309 00 03121206 00 03121209 00 03121211 00 03121609 00 03121614 00 03122008 00 03122009 00 03122410 00 03152008 00 03162409 00 03162412 00 03163610 00 03203615 00 03233009 00 03233011 00 - 33050504 00 33050704 00 33080806 00 33080809 00 33081206 00 33081209 00 33081606 00 33081609 00 33121206 00 33121209 00 33121211 00 33121609 00 33121614 00 33122008 00 33122008 00 33122410 00 33152008 00 33162409 00 33162412 00 33203615 00 33233009 00 33233011 00 - 09050504 00 09050704 00 09080806 00 09080809 00 09081206 00 09081209 00 09081606 00 09081609 00 09082309 00 09121206 00 09121209 00 09121211 00 09121609 00 09121614 00 09122008 00 09122009 00 09122410 00 09152008 00 09162409 00 09162412 00 09163610 00 09203615 00 09233009 00 09233011 00 09403615 00 50 x 52 x 35 50 x 65 x 35 80 x 82 x 55 80 x 82 x 85 80 x 120 x 55 80 x 120 x 85 80 x 160 x 55 80 x 160 x 85 80 x 230 x 85 120 x 122 x 55 120 x 122 x 90 120 x 122 x 105 120 x 160 x 90 120 x 160 x 140 120 x 200 x 75 120 x 200 x 90 120 x 240 x 100 150 x 200 x 75 160 x 240 x 90 160 x 240 x 120 160 x 360 x 100 200 x 360 x 150 230 x 300 x 85 230 x 300 x 110 360 x 400 x 150 1.97 x 2.05 x 1.38 1.97 x 2.56 x 1.38 3.18 x 3.23 x 2.17 3.15 x 3.23 x 3.35 3.15 x 4.72 x 2.17 3.15 x 4.72 x 3.35 3.15 x 6.30 x 2.17 3.15 x 6.30 x 3.35 3.15 x 9.06 x 3.35 4.72 x 4.80 x 2.17 4.72 x 4.80 x 3.35 4.72 x 4.80 x 3.35 4.72 x 4.80 x 4.13 4.72 x 6.30 x 3.54 4.72 x 6.30 x 5.51 4.72 x 7.87 x 2.95 4.72 x 7.87 x 3.54 4.72 x 9.45 x 3.94 5.91 x 7.87 x 2.95 6.30 x 9.45 x 3.54 6.30 x 9.45 x 4.72 6.30 x 14.17 x 3.98 7.87 x 14.17 x 5.87 9.06 x 11.81 x 3.35 9.06 x 11.81 x 4.33 UL 50 IP 66 to EN 60529 4x1014 Ohm, VDE 0303 DIN 53486 24 Kv/mm VDE 03032 DIN 53481 Fully insulated VDE 0100 UL 94 HB -40°F to +212°F (neoprene gasket) Light gray, similar to RAL 7035. Special colors on request. Halogen-free External Brackets Mounting Plate Silicone Lid Seal 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 2 2 2 2 2 2 2 2 2.5 2.53) 2.5 2.5 2.5 2 2 23) • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • Rubber Feet • • • • • • • • • • • • • • • • • • • • • PC External Hinge approx. 150° • • • • • • • • • • • • • • • • • • • • 3) Galvanized sheet steel Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. 18 www.Rose-Bopla.com Polycarbonate Flange Enclosures • Light plastic enclosure for industrial applications with flange pre-embossing • Multiple configurations possible by combining with other Polycarbonate Flange Enclosures • Snap lock technology and flange quick-fixing system Included in delivery Completely closed enclosure body with flange break-out points; lid with plastic quick-release lock; 4 threaded inserts for internal mounting. Technical Data Impact Resistance Flammability Disruptive Strength Surface Resistance Temperature Range Ingress Protection Sealing Toxicity Weather Resistance Insulation Color Enclosure base, flanges, opaque enclosure lids Transparent Lids > 7 Nm, EN 50014 UL 94 V0/ self-extinguising > 18 kV / mm, DIN 53482 >1015 Ohm, DIN 53482 -40°F up to +212°F IP 65 to #N 60529 Neoprene Low-halogen UV stabilized Fully insulated VDE 0100 Gray, similar to RAL 7032 >7 Nm, EN 50014 UL 94 V2 > 30 KV / mm, DIN 53481 >1015 ohm, DIN 53482 -40°F to + 212°F IP 65 to EN 60529 Neoprene Low-halogen Fully insulated VDE 0100 Transparent Enclosure with Lid Part Number Enclosure with Transparent Lid Part Number Dimensions mm 17011000 00 17021000 00 17031000 00 17041000 00 17051000 00 17061000 00 17011010 00 17021010 00 17031010 00 17041010 00 17051100 00 - 134 x 170 x 130 170 x 170 x 130 170 x 269 x 130 269 x 269 x 130 269 x 540 x 130 369 x 440 x 130 WxLxH Dimensions Inches Flange Opening TS 35* DIN Rail 2 4 4 4 6 4 • • • • • • • • • • • • Mounting Plate WxLxH 5.12 x 6.69 x 5.12 6.69 x 6.69 x 5.12 6.69 x 10.59 x 5.12 10.59 x 10.59 x 5.12 10.59 x 21.26 x 5.12 10.59 x 17.32 x 5.12 • • • • • • *TS 32 on request Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Flanges and Accessories Blind flange I Blind flange II Flange 11 PG, 19 x PG9/PG 13.5 Flange 11 PG, 16 x PG11/PG 16 Flange 11 PG , 10 x PG9/PG 13.5; 4 x PG 11/PG16; 2 x PG21/PG29 Connecting flange I Connecting flange II Internal Mounting Bracket (set of 4), for type 1705 2 sets required Additional threaded insterts (set of 10) External brackets (set of 4) Spare fixing wedges (set of 10) Internal hinges (set of 2) For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 Part Number 17003100 00 17003200 00 17003400 00 17003500 00 17003300 00 17003600 00 17003700 00 17004200 00 10035003 00 10031104 00 17004100 00 17005500 00 19 ECO/PCI Compact Enclosures • Light-weight thermoplastic enclosure for industrial applications • ECO version: base with smooth side walls, lid version standard or transparent • PCI version: base with knock-outs for cable connections Included in delivery Enclosure consisting of lid, base, seal, captive lid screws, and screws for fastening including spacer inserts. Technical Data Material Ingress Protection Impact Resistance Insulation Temperature Range Flammability Toxicity Weather Resistance Chemical Resistance Color 20 Flame-resistant Polystyrene IP 65 to EN 60529 2 Nm, EN 60068-2-75 Fully insulated to VDE 0100 +14°F to + 158°F UL 94 HB Low-halogen Do not expose to direct sunlight Not resistant to benzine, diesel, oils, and fats as well as strong acids. Gray, similar to RAL 7035. Special colors on request www.Rose-Bopla.com ECO Series Enclosure Type Part Number Dimensions mm WxLxH TS 15 60070711 00 60070721 00 60070911 00 60070921 00 60090911 00 60090921 00 60090912 00 60090922 00 60091311 00 60091321 00 60091312 00 60091322 00 60111111 00 60111121 00 60111112 00 60111122 00 60131311 00 60131321 00 60131312 00 60131322 00 60091811 00 60091821 00 60091812 00 60091822 00 60111811 00 60111821 00 60111812 00 60111822 00 60181811 00 60181821 00 60181831 00 60181812 00 60181822 00 60181832 00 60182509 00 60182510 00 60182511 00 60182521 00 60182531 00 60182512 00 60182522 00 60182532 00 60253611 00 60253621 00 60253612 00 60253622 00 65 x 65 x 57 65 x 65 x 81 65 x 94 x 57 65 x 94 x 81 94 x 94 x 57 94 x 94 x 81 94 x 94 x 57 94 x 94 x 81 94 x 130 x 57 94 x 130 x 81 94 x 130 x 57 94 x 130 x 81 110 x 110 x 66 110 x 110 x 90 110 x 110 x 66 110 x 110 x 90 130 x 130 x 75 130 x 130 x 99 130 x 130 x 75 130 x 130 x 99 94 x 180 x 57 94 x 180 x 81 94 x 180 x 57 94 x 180 x 81 110 x 180 x 90 110 x 180 x 111 110 x 180 x 90 110 x 180 x 111 180 x 182 x 90 180 x 182 x 111 180 x 182 x 165 180 x 182 x 90 180 x 182 x 111 180 x 182 x 165 180 x 254 x 63 180 x 254 x 63 180 x 254 x 90 180 x 254 x 111 180 x 254 x 165 180 x 254 x 90 180 x 254 x 111 180 x 254 x 165 254 x 355 x 111 254 x 355 x 165 254 x 355 x 111 254 x 355 x 165 2.56 x 2.56 x 2.24 2.56 x 2.56 x 3.49 2.56 x 3.70 x 2.24 2.56 x 3.70 x 3.19 3.70 x 3.70 x 2.24 3.70 x 3.70 x 3.19 3.70 x 3.70 x 2.24 3.70 x 3.70 x 3.19 3.58 x 5.12 x 2.24 3.70 x 5.12 x 3.19 3.58 x 5.12 x 2.24 3.70 x 5.12 x 3.19 4.33 x 4.33 x 2.60 4.33 x 4.33 x 3.54 4.33 x 4.33 x 2.60 4.33 x 4.33 x 3.54 4.33 x 4.33 x 2.95 4.33 x 4.33 x 3.90 4.33 x 4.33 x 2.95 4.33 x 4.33 x 3.90 3.70 x 7.09 x 2.24 3.70 x 7.09 x 3.19 3.70 x 7.09 x 2.24 3.70 x 7.09 x 3.19 4.33 x 7.09 x 3.54 4.33 x 7.09 x 4.37 4.33 x 7.09 x 3.54 7.33 x 7.09 x 4.37 7.09 x 7.16 x 3.54 7.09 x 7.16 x 4.37 7.09 x 7.19 x 6.50 7.09 x 7.16 x 3.54 7.09 x 7.16 x 4.37 7.09 x 7.16 x 6.50 7.09 x 10.00 x 2.48 7.09 x 10.00 x 2.48 7.09 x 10.00 x 3.54 7.09 x 10.00 x 4.37 7.09 x 10.00 x 6.50 7.09 x 10.00 x 3.15 7.09 x 10.00 x 4.37 7.09 x 10.00 x 6.50 10.00 x 13.98 x 4.37 10.00 x 13.98 x 6.50 10.00 x 13.98 x 4.37 10.00 x 13.98 x 6.50 • • • • • • • • • • • • • • • • • • • • • • • • 60070715 00 60070915 00 60090915 00 60091315 00 60111115 00 60131315 00 60091815 00 60111815 00 60111825 00 60181815 00 60181825 00 60182505 00 60182515 00 60182525 00 60253615 00 65 x 65 x 57 65 x 95 x 57 94 x 94 x 57 94 x 130 x 57 110 x 110 x 90 130 x 130 x 75 94 x 180 x 57 110 x 180 x 90 110 x 180 x 111 180 x 182 x 90 180 x 182 x 111 180 x 254 x 63 180 x 254 x 90 180 x 254 x 111 254 x 355 x 111 2.56 x 2.56 x 2.24 2.56 x 3.74 x 2.24 3.70 x 3.70 x 2.24 3.70 x 5.12 x 2.24 4.33 x 4.33 x 3.54 5.12 x 5.12 x 2.95 3.70 x 7.09 x 2.24 4.33 x 7.09 x 3.54 4.33 x 7.09 x 4.37 7.09 x 7.16 x 3.54 7.09 x 7.16 x 4.37 7.09 x 10.00 x 2.48 7.09 x 10.00 x 3.54 7.09 x 10.00 x 4.37 10.00 x 13.98 x 4.37 • • • • • • • WxLxH ECO 01-6 ECO 01-8 ECO 02-6 ECO 02-8 ECO 03-6 ECO 03-8 ECO 03-6t ECO 03-8t ECO 04-6 ECO 04-8 ECO 04-6t ECO 04-8t ECO 05-7 ECO 05-9 ECO 05-7t ECO 05-9t ECO 06-7 ECO 06-10 ECO 06-7t ECO 06-10t ECO 07-6 ECO 07-8 ECO 07-6t ECO 07-8t ECO 08-9 ECO 08-11 ECO 08-9t ECO 08-11t ECO 09-9 ECO 09-11 ECO 09-16 ECO 09-9t ECO 09-11t ECO 09-16t ECO 10-6t ECO 10-6 ECO 10-9 ECO 10-11 ECO 10-16 ECO 10-9t ECO 10-11t ECO 10-16t ECO 11-11 ECO 11-16 ECO 11-11t ECO 11-16t Dimensions Inches TS Din Rails for Terminals Mounting Plate External Bracket External Hinges Knurled Screw • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • TS 35* PCI Series PCI 06-1M PCI 02-6M PCI 03-6M PCI 04-6M PCI 05-9M PCI 06-7M PCI 07-6M PCI 08-9M PCI 08-11M PCI 09-9M PCI 09-11M PCI 10-6M PCI 10-9M PCI 10-11M PCI 11-11M t = Transparent lid * TS 32 available on request Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 21 Polymas Watertight Enclosures • Especially suitable for fitting small electronic components and terminal blocks • Available with or without molded-on cable glands and with or without quick-release lid screws • Mounting bosses for self-tapping screws provided for the assembly of terminal blocks, DIN rails or PCBs Included in delivery Enclosure consisting of lid and base; lid screws, or quickrelease lid screws; depending on design with molded-on cable glands PG 11 including clamping cage, pressure screw, and closed sealing ring. Technical Data Material Ingress Protection Color Lid Seal Enclosure Type PK 101* PK 101-111* PK 101-211* PK 101 SV PK 101 SV-111 PK 101 SV-211 PK 102* PK 102-211* PK 102-411* PK 102 SV PK 102 SV-211 PK 102 SV-411 PK 105* PK 105 SV PK 110* PK 110 SV PK 115* PK 115 SV Polyamide 6, 30% glassbead-reinforced. UV stabilized IP 65 DIN EN 60529. Increased protection up to IP x7 on request. Gray, similar to RAL 7001 Neoprene Part Number Dimensions mm WxLxH Dimensions Inches WxLxH 38101000 00 38101100 00 38101200 00 38101500 00 38101600 00 38101700 00 38102000 00 38102200 00 38102400 00 38102500 00 38102700 00 38102900 00 38105000 00 38105500 00 38110000 00 38110500 00 38115000 00 38115500 00 58 x 64 x 34 58 x 64 x 34 58 x 64 x 34 58 x 64 x 34 58 x 64 x 34 58 x 64 x 34 98 x 64 x 34 98 x 64 x 34 98 x 64 x 34 98 x 64 x 34 98 x 64 x 34 98 x 64 x 34 75 x 80 x 57 75 x 80 x 57 125 x 80 x 57 125 x 80 x 57 175 x 80 x 57 175 x 80 x 57 2.28 x 2.52 x 1.34 2.28 x 2.52 x 1.34 2.28 x 2.52 x 1.34 2.28 x 2.25 x 1.34 2.28 x 2.25 x 1.34 2.28 x 2.25 x 1.34 3.86 x 2.52 x 1.34 3.86 x 2.52 x 1.34 3.86 x 2.52 x 1.34 3.86 x 2.52 x 1.34 3.86 x 2.52 x 1.34 3.86 x 2.52 x 1.34 2.95 x 2.52 x 2.24 2.95 x 2.52 x 2.24 4.91 x 2.52 x 2.24 4.91 x 2.52 x 2.24 6.89 x 2.52 x 2.24 6.89 x 2.52 x 2.24 *Available with transparent polycarbonate lid for quantities exceeding 500 pieces. Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. 22 www.Rose-Bopla.com E30 Fire Protection Enclosures • Fire protection enclosures from special halogen-free fiberglass material • Individually fitted with ceramic terminals and cable glands to customer specifications Included in delivery Enclosure system with DIN rail and external brackets. Optional, approved terminals and cable glands Technical Data Material Ingress Protection Seal/Temperature Stability Test Certificate EMC Part Number E30121209 00 E30122209 00 E30161609 00 E30162609 00 E30252612 00 Glassfiber-reinforced polyester IP 66, EN 60529 CR round seal -40° to +90°F DIN 4102 Part 12. General building test certification. Optional EMC version Ceramic Terminal Blocks Dimensions mm WxLxH Dimensions Inches WxLxH SAKK4 SAKK10 120 x 120 x 90 120 x 220 x 90 160 x 160 x 90 160 x 260 x 90 250 x 260 x 120 4.72 x 4.72 x 3.54 4.72 x 8.66 x 3.54 6.30 x 6.30 x 3.54 6.30 x 10.24 x 3.54 9.84 x 10.24 x 4.72 7 pieces 18 pieces 11 pieces 23 pieces 2 x 23 pieces 4 pieces 12 pieces 8 pieces 16 pieces 2 x 16 pieces Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Terminals E30000104 00 SAKK4 ceramic terminal block E30000116 00 SAKK 10 ceramic terminal block E30000191 00 E30000192 00 E30000193 00 E30000194 00 E30000196 00 E30000197 00 E30000198 00 E30000201 00 AP/SAKK4/10 QL2/SAKK4 QL3/SAKK4 QL 4/SAKK4 QL 2/SAKK10 QL 3/SAKK10 QL 4/SAKK10 EW 1 lid bridge, 2 pole to SAKK 4 bridge, 3 pole to SAKK 4 bridge, 4 pole to SAKK 4 bridge, 2 pole to SAKK 10 bridge, 3 pole to SAKK 10 bridge, 4 pole to SAKK 10 end clamp TS 32 Cable Glands 08080512 00 08080516 00 08080520 00 08080525 00 08080532 00 08080540 00 M 12 x 1.5 M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 range 3 - 7 mm range 5 - 10 mm range 8 - 13 mm range 11 - 17 mm range 15 - 21 mm range 19 - 28 mm For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 0.5 to 6 mm2 (single strip) 0.5 to 4 mm2 (multi strip) 2.5 to 16mm2 (single strip) 2.5 to 10mm2 (multi strip) 23 Polycarbonate Watertight EM/ABS Watertight ET • Four new flat versions round off this innovative and successful IP 65 enclosure line. • Made from either high-quality polycarbonate or cost-effective ABS, this enclosure line offers a wide range of benefits due to its easy-to-use screw-mounting system and additional mounting bosses in the base. • Versions with a recessed membrane keypad area (F) and/or PCB plug-in-slots (LP/FLP) are ideal for use as electronic enclosures. • This enclosure is especially easy to recycle because there are no molded-in metal parts, and in each case only one type of plastic is used. Included in delivery Enclosure base with lid; self-tapping coarse thread lid screws made of V2A; max. screwing force 45 Ncm. Technical Data Material Ingress Protection Color Flammability Temperature Range Surface Resistance Disruptive Strength 24 Polycarbonate IP 65 DIN EN 60529 Light gray, similar to RAL 7035. Special colors on request UL V2/1.14 Neoprene Gasket -40°F to +212°F Silicone Gasket -76°F to +266°F RFI Gasket -40°F to +392°F >1015 Ohm to DIN 53482 28 KV/mm DIN 53481 ABS IP 65 DIN EN 60529 Light gray, similar to RAL 7035. Special colors on request UL 94 HB/1.6 Neoprene Gasket -40°F to +212°F Silicone Gasket -76°F to +266°F RFI Gasket -40°F to +392°F >1014 Ohm DIN 53482 - www.Rose-Bopla.com Polycarbonate Model Part Number ABS Dimensions mm LxWxH Dimensions Inches LxWxH Model Part Number 52 x 50 x 37 EM 205 2.05 x 1.97 x 1.46 62205000 00 ET 205 63205000 00 52 x 50 x 37 EM 250 F 2.05 x 1.97 x 1.46 62205200 00 ET 205 F 63205200 00 65 x 50 x 37 EM 206 2.56 x 1.97 x 1.46 62206000 00 ET 206 63206000 00 65 x 50 x 37 EM 206 F 2.56 x 1.97 x 1.46 62206200 00 ET 206 F 63206200 00 82 x 60 x 57 EM 207 LP 3.23 x 2.36 x 2.24 62207300 00 ET 207 LP 63207300 00 82 x 60 x 57 EM 207 F-LP 3.23 x 2.36 x 2.24 62207400 00 ET 207 F-LP 63207400 00 98 x 64 x 38 EM 208 3.86 x 2.52 x 1.50 62208000 00 ET 208 63208000 00 98 x 64 x 38 EM 208 F 3.86 x 2.52 x 1.50 62208200 00 ET 208 F 63208200 00 82 x 80 x 57 EM 210 3.23 x 3.15 x 2.24 62210000 00 ET 210 63210000 00 82 x 80 x 57 EM 210 F 3.23 x 3.15 x 2.24 62210200 00 ET 210 F 63210200 00 100 x 100 x 57 EM 212 3.94 x 3.94 x 2.24 62212000 00 ET 212 63212000 00 100 x 100 x 57 EM 212 F 3.94 x 3.94 x 2.24 62212200 00 ET 212 F 63212200 00 122 x 120 x 37 EM 213* 4.80 x 4.72 x 1.46 62213000 00 ET 213 63213000 00 122 x 120 x 37 EM 213 F* 4.80 x 4.72 x 1.46 62213200 00 ET 213 F 63213200 00 200 x 120 x 57 EM 214 LP 7.87 x 4.72 x 2.24 62214300 00 ET 214 LP 63214300 00 200 x 120 x 57 EM 214 F-LP 7.87 x 4.72 x 2.24 62214400 00 ET 214 F-LP 63214400 00 120 x 80 x 57 EM 215 4.72 x 3.15 x 2.24 62215000 00 ET 215 63215000 00 120 x 80 x 57 EM 215 F 4.72 x 3.15 x 2.24 62215200 00 ET 215 F 63215200 00 122 x 120 x 57 EM 217 4.80 x 4.72 x 2.24 62217000 00 ET 217 63217000 00 122 x 120 x 57 EM 217 F 4.80 x 4.72 x 2.24 62217200 00 ET 217 F 63217200 00 150 x 150 x 57 EM 218 LP 5.90 x 5.90 x 2.24 62218300 00 ET 218 LP 63218300 00 150 x 150 x 57 EM 218 F-LP 5.90 x 5.90 x 2.24 62218400 00 ET 218 F-LP 63218400 00 160 x 80 x 57 EM 220 6.30 x 3.15 x 2.24 62220000 00 ET 220 63220000 00 160 x 80 x 57 EM 220 F 6.30 x 3.15 x 2.24 62220200 00 ET 220 F 63220200 00 200 x 120 x 77 EM 221 7.87 x 4.72 x 3.03 62221000 00 ET 221 63221000 00 200 x 120 x 77 EM 221 F 7.87 x 4.72 x 3.03 62221200 00 ET 221 F 63221200 00 200 x 150 x 77 EM 223 7.87 x 5.90 x 3.03 62223000 00 ET 223 63223000 00 200 x 150 x 77 EM 223 F 7.87 x 5.90 x 3.03 62223200 00 ET 223 F 63223200 00 240 x 80 x 60 EM 224 LP 9.45 x 3.15 x 2.36 62224300 00 ET 224 LP 63224300 00 240 x 80 x 60 EM 224 F-LP 9.45 x 3.15 x 2.36 62224400 00 ET 224 F-LP 63224400 00 82 x 80 x 87 EM 225 3.23 x 3.15 x 3.42 62225000 00 ET 225 63225000 00 82 x 80 x 87 EM 225 F 3.23 x 3.15 x 3.42 62225200 00 ET 225 F 63225200 00 122 x 120 x 87 EM 227 4.80 x 4.72 x 3.42 62227000 00 ET 227 63227000 00 122 x 120 x 87 EM 227 F 4.80 x 4.72 x 3.42 62227200 00 ET 227 F 63227200 00 160 x 80 x 37 EM 229* 6.30 x 3.15 x 1.46 62229000 00 ET 229 63229000 00 160 x 80 x 37 EM 229 F* 6.30 x 3.15 x 1.46 62229200 00 ET 229 F 63229200 00 160 x 80 x 87 EM 231 6.30 x 3.15 x 3.42 62231000 00 ET 231 63231000 00 160 x 80 x 87 EM 231 F* 6.30 x 3.15 x 3.42 62231200 00 ET 231 F 63231200 00 200 x 150 x 37 EM 232* 7.87 x 5.90 x 1.46 62232000 00 ET 232 63232000 00 200 x 150 x 37 EM 232 F* 7.87 x 5.90 x 1.46 62232200 00 ET 232 F 63232200 00 250 x 160 x 37 EM 233* 9.84 x 6.30 x 1.46 62233000 00 ET 233* 63233000 00 250 x 160 x 37 EM 233 F* 9.84 x 6.30 x 1.46 62233200 00 ET 233 F 63233200 00 240 x 80 x 80 EM 236 LP 9.45 x 3.15 x 3.15 62236300 00 ET 236 LP 63236300 00 240 x 80 x 80 EM 236 F-LP 9.45 x 3.15 x 3.15 62236400 00 ET 236 F-LP 63236400 00 200 x 120 x 92 EM 237 7.87 x 4.72 x 3.62 62237000 00 ET 237 63237000 00 200 x 120 x 92 EM 237 F 7.87 x 4.72 x 3.62 62237200 00 ET 237 F 63237200 00 160 x 120 x 92 EM 238 6.30 x 4.72 x 3.62 62238000 00 ET 238 63238000 00 160 x 120 x 92 EM 238 F 6.30 x 4.72 x 3.62 62238200 00 ET 238 F 63238200 00 250 x 160 x 57 EM 239 9.84 x 6.30 x 2.24 62239000 00 ET 239 63239000 00 250 x 160 x 57 EM 239 F 9.84 x 6.30 x 2.24 62239200 00 ET 239 F 63239200 00 250 x 160 x 92 EM 240 9.84 x 6.30 x 3.62 62240000 00 ET 240 63240000 00 250 x 160 x 92 EM 240 F 9.84 x 6.30 x 3.62 62240200 00 ET 240 F 63240200 00 250 x 160 x 122 EM 241 9.84 x 6.30 x 4.80 62241000 00 ET 241 63241000 00 250 x 160 x 122 FM 241 F 9.84 x 6.30 x 4.80 62241200 00 ET 241 F 63241200 00 240 x 120 x 102 EM 242 9.45 x 4.72 x 4.01 62242000 00 ET 242 63242000 00 240 x 120 x 102 EM 242 F 9.45 x 4.72 x 4.01 62242200 00 ET 242 F 63242200 00 300 x 160 x 120 FM 247 LP 11.81 x 6.30 x 4.72 62247300 00 ET 247 LP 63247300 00 360 x 160 x 120 EM 247 F-LP 11.81 x 6.30 x 4.72 62247400 00 ET 247 F-LP 63247400 00 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. *An additional model with PCB slots EM/ET...LP is available on request. F = with recessed area in upper section for flush-fitting of membrane keypads LP/F=LP = with slots for PCBs For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 Dimensions mm LxWxH 52 x 50 x 37 52 x 50 x 37 65 x 50 x 37 65 x 50 x 37 82 x 60 x 57 82 x 60 x 57 98 x 64 x 38 98 x 64 x 38 82 x 80 x 57 82 x 80 x 57 100 x 100 x 57 100 x 100 x 57 122 x 120 x 37 122 x 120 x 37 200 x 120 x 57 200 x 120 x 57 120 x 80 x 57 120 x 80 x 57 122 x 120 x 57 122 x 120 x 57 150 x 150 x 57 150 x 150 x 57 160 x 80 x 57 160 x 80 x 57 200 x 120 x 77 200 x 120 x 77 200 x 150 x 77 200 x 150 x 77 240 x 80 x 60 240 x 80 x 60 82 x 80 x 87 82 x 80 x 87 122 x 120 x 87 122 x 120 x 87 160 x 80 x 37 160 x 80 x 37 160 x 80 x 87 160 x 80 x 87 200 x 150 x 37 200 x 150 x 37 250 x 160 x 37 250 x 160 x 37 240 x 80 x 80 240 x 80 x 80 200 x 120 x 92 200 x 120 x 92 160 x 120 x 92 160 x 120 x 92 250 x 160 x 57 250 x 160 x 57 250 x 160 x 92 250 x 160 x 92 250 x 160 x 122 250 x 160 x 122 240 x 120 x 102 240 x 120 x 102 300 x 160 x 120 300 x 160 x 120 Dimensions Inches LxWxH 2.05 x 1.97 x 1.46 2.05 x 1.97 x 1.46 2.56 x 1.97 x 1.46 2.56 x 1.97 x 1.46 3.23 x 2.36 x 2.24 3.23 x 2.36 x 2.24 3.86 x 2.52 x 1.50 3.86 x 2.52 x 1.50 3.23 x 3.15 x 2.24 3.23 x 3.15 x 2.24 3.94 x 3.94 x 2.24 3.94 x 3.94 x 2.24 4.80 x 4.72 x 1.46 4.80 x 4.72 x 1.46 7.87 x 4.72 x 2.24 7.87 x 4.72 x 2.24 4.72 x 3.15 x 2.24 4.72 x 3.15 x 2.24 4.80 x 4.72 x 2.24 4.80 x 4.72 x 2.24 5.90 x 5.90 x 2.24 5.90 x 5.90 x 2.24 6.30 x 3.15 x 2.24 6.30 x 3.15 x 2.24 7.87 x 4.72 x 3.03 7.87 x 4.72 x 3.03 7.87 x 5.90 x 3.03 7.87 x 5.90 x 3.03 9.45 x 3.15 x 2.36 9.45 x 3.15 x 2.36 3.23 x 3.15 x 3.42 3.23 x 3.15 x 3.42 4.80 x 4.72 x 3.42 4.80 x 4.72 x 3.42 6.30 x 3.15 x 1.46 6.30 x 3.15 x 1.46 6.30 x 3.15 x 3.42 6.30 x 3.15 x 3.42 7.87 x 5.90 x 1.46 7.87 x 5.90 x 1.46 9.84 x 6.30 x 1.46 9.84 x 6.30 x 1.46 9.45 x 3.15 x 3.15 9.45 x 3.15 x 3.15 7.87 x 4.72 x 3.62 7.87 x 4.72 x 3.62 6.30 x 4.72 x 3.62 6.30 x 4.72 x 3.62 9.84 x 6.30 x 2.24 9.84 x 6.30 x 2.24 9.84 x 6.30 x 3.62 9.84 x 6.30 x 3.62 9.84 x 6.30 x 4.80 9.84 x 6.30 x 4.80 9.45 x 4.72 x 4.01 9.45 x 4.72 x 4.01 11.81 x 6.30 x 4.72 11.81 x 6.30 x 4.72 25 Accessories Model EM/ET 205 EM/ ET 250 F EM / ET 206 EM/ET 206 F EM/ET 207 LP EM/ET 207 F-LP EM/ET 208 EM/ET 208 F EM/ET 210 EM/ET 210 F EM/ET 212 EM/ET 212 F EM/ET 213 EM/ET 213 F EM/ET 214 LP EM/ET 214 F-LP EM/ET 215 EM/ET 215 F EM/ET 217 EM/ET 217 F EM/ET 218 LP EM/ET 218 F-LP EM/ET 220 EM/ET 220 F EM/ET 221 EM/ET 221 F EM/ET 223 EM/ET 223 F EM/ET 224 LP EM/ET 224 F-LP EM/ET 225 EM/ET 225 F EM/ET 227 EM/ET 227 F EM/ET 229 EM/ET 229 F EM/ET 231 EM/ET 231 F EM/ET 232 EM/ET 232 F EM/ET 233 EM/ET 233 F EM/ET 236 LP EM/ET 236 F-LP EM/ET 237 EM/ET 237 F EM/ET 238 EM/ET 238 F EM/ET 239 EM/ET 239 F EM/ET 240 EM/ET 240 F EM/ET 241 EM/ET 241 F EM/ET 242 EM/ET 242 F EM/ET 247 LP EM/ET 247 F-LP *Can also be fitted in lids 26 Mounting Plate Part Number Terminal Rail TS 15 Part Number Terminal Rail TS 32 Part Number Terminal Rail TS 35 Part Number Screw Covers EM-SA Part Number Rubber Feet EM-GF Part Number Wall Bracket EM-WL Part Number 22000100 00 22000100 00 22000200 00 22000200 00 22207001 00* 22207001 00* 22000300 00 22000300 00 22212000 00* 22212000 00* 22214001 00* 22214001 00* 22000400 00 22000400 00 22000500 00 22000500 00 22218001 00* 22218001 00* 22000600 00 22000600 00 22000700 00 22000700 00 22000800 00 22000800 00 22224001 00* 22224001 00* 22000300 00 22000300 00 22000500 00 22000500 00 22000600 00 22000600 00 22224001 00 22224001 00 22000700 00 22000700 00 22001100 00 22001100 00 22000900 00 22000900 00 22000900 00 22000900 00 22000900 00 22000900 00 22001200 00 22001200 00 22247001 00* 22247001 00* 22150501 00 22150501 00 22150701 00 22150701 00 22150701 00 22150701 00 22150701 00 22150701 00 22150901 00 22150901 00 22151101 00 22151101 00 22151901 00 22151901 00 22151101 00 22151101 00 22151101 00 22151101 00 22151401 00 22151401 00 22151501 00 22151501 00 22151901 00 22151901 00 22151901 00 22151901 00 22152301 00 22152301 00 22150701 00 22150701 00 22151101 00 22151101 00 22151501 00 22151501 00 22151501 00 22151501 00 22151901 00 22151901 00 22152301 00 22152301 00 22152301 00 22152301 00 22151901 00 22151901 00 22151501 00 22151501 00 22152301 00 22152301 00 22152301 00 22152301 00 22152301 00 22152301 00 22152301 00 22152301 00 22152901 00 22152901 00 22320701 00 22320701 00 22320701 00 22320701 00 22320901 00 22320901 00 22321101 00 22321101 00 22321901 00 22321901 00 22321101 00 22321101 00 22321101 00 22321101 00 22321401 00 22321401 00 22321501 00 22321501 00 22321901 00 22321901 00 22321901 00 22321901 00 22322301 00 22322301 00 22320701 00 22320701 00 22321101 00 22321101 00 22321501 00 22321501 00 22321501 00 22321501 00 22321901 00 22321901 00 22322301 00 22322301 00 22322301 00 22322301 00 22321901 00 22321901 00 22321501 00 22321501 00 22322301 00 22322301 00 22322301 00 22322301 00 22322301 00 22322301 00 22322301 00 22322301 00 22322901 00 22322901 00 22350701 00 22350701 00 22350701 00 22350701 00 22350901 00 22350901 00 22351101 00 22351101 00 22351901 00 22351901 00 22351101 00 22351101 00 22351101 00 22351101 00 22351401 00 22351401 00 22351501 00 22351501 00 22351901 00 22351901 00 22351901 00 22351901 00 22352301 00 22352301 00 22350701 00 22350701 00 22351101 00 22351101 00 22351501 00 22351501 00 22351501 00 22351501 00 22351901 00 22351901 00 22352301 00 22352301 00 22352301 00 22352301 00 22351901 00 22351901 00 22351501 00 22351501 00 22352301 00 22352301 00 22352301 00 22352301 00 22352301 00 22352301 00 22352301 00 22352301 00 22352901 00 22352901 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22080000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22009000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 22010000 00 www.Rose-Bopla.com Fiberglass 3040/4060 Cabinets • Enclosure system with hidden external hinge • Standard version or with window • Version with handle Included in delivery Enclosure consisting of lower section and door; please order door lock separately, press-in inserts in base for internal and external fitting. Technical Data Material Ingress Protection Door Opening Angle Temperature Range Glassfiber-reinforced, duroplastic Polyester IP 66 to EN 60529 135° -40°F to +212°F window version -40°F to +176°F >7 Nm, EN 50014 >1012 Ohm, DIN 53482 18 kV/mm, VDE 0303 / DIN 53481 fully insulated, VDE 0100 UL 94 V0, self-extinguishing max. 0.6% halogen free Agate gray, similar to RAL 7038. Special colors on request. Impact Resistance Surface Resistance Disruptive Strength Insulation Flammability Water Absorption Toxicity Color Polyglass/Polycase Dimensions mm Size 1 Size 2 300 x 400 x 200 400 x 600 x 250 WxLxH Dimensions Inches Part Number Polyglas Part Number Polyglas with Window Part Number with Carrying Handle Part Number with Window and Carring Handle 21304000 00 21406000 00 22304000 00 22406000 00 23304000 00 23406000 00 24304000 00 24406000 00 WxLxH 11.81 x 15.75 x 7.87 15.75 x 23.62 x 9.84 Note: Standard delivery enclosure without lock, please order separately. Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Optional lock types (loose) Square lock 8 mm (2 pieces) Square lock 7 mm (2 pieces) Double ward lock 3 mm (2 pieces) Knob (2 pieces) Knob, to lock with keys (2 pieces) Part Number 21610004 00 21610014 00 21610007 00 21610001 00 21610002 00 Accessories Mounting plate for size 1 (galvanized sheet steel) Mounting plate for size 2 (glavanized sheet steel) External brackets (4 pieces) Hole covers for mounting through the cabinet base (4 pieces) Key, triangular 8 mm Key, square 8mm Key, square 7mm Key double ward 3 mm Part Number 10011203 00 10011204 00 10031009 00 10039001 00 10047003 00 10047004 00 10047014 00 10047007 00 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 27 GFK Fiberglass/ABS Mini Cabinets • Enclosure system with hinged lid • Standard version or with window panel or transparent door (ABS) Included in delivery Enclosure consisting of base and door; please order door lock and keys separately, press-in inserts in base for internal and external fitting. Door locks and keys sold separately. Technical Data Material Ingress Protection Door Opening Angle Temperature Range Glassfiber-reinforced, duroplastic Polyester IP 65 to EN 60529 135° -67°F to +194°F window version -67°F to +176°F >7 Nm, EN 50014 >1012 Ohm, DIN 53482 18 kV/mm, VDE 0303 / DIN 53481 fully insulated, VDE 0100 UL 94 V0, self-extinguishing max. 0.2% DIN 53495 / ISO R 62 halogen free Agate gray, similar to RAL 7038. Special colors on request. Impact Resistance Surface Resistance Disruptive Strength Insulation Flammability Water Absorption Toxicity Color Polyglass/Polycase Size 1 Size 2 Size 1 Size 2 Dimensions mm WxLxH 200 x 250 x 150 250 x 300 x 170 199 x 248.5 x 149 248.5 x 298.0 x 166 Dimensions Inches WxLxH 7.87 x 9.84 x 5.90 9.84 x 11.81 x 6.69 7.83 x 9.78 x 5.87 9.78 x 11.73 x 6.53 ABS IP 65 to EN 60529 135° -40°F to +158°F >7 Nm, EN 50014 >1012 Ohm VDE 0303 / DIN 53482 18 kV/mm, VDE 0303 / DIN 53481 fully insulated, VDE 0100 UL 94 HB max. 0.2% DIN 53495 / ISO R62 halogen free Light gray, similar to RAL 7035. Special colors on request. Part Number ABS Part Number ABS with Transparent Door Part Number GFK Part Number GFK with Window 21202590 00 21253090 00 - 22202590 00 22253090 00 - 21202500 00 21253000 00 22202500 00 22253000 00 Note: Standard delivery enclosure without lock, please order separately. Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Locking screws optional (loose) Triangular lock 8 mm (1 piece) Square lock 8 mm (1 piece) Door handle Locking door handle with key Part Number 21620003 00 21620004 00 21620001 00 21620002 00 Accessories Mounting plate for size 1 (2025) galvanized steel Mounting plate for size 2 (2035) galvanized steel Internal aluminum front panel with stud bolts for size 1 (2025) Internal aluminum front panel with stud bolts for size 2 (2035) Wall mount brackets (4 pieces) Triangular metal key Square metal key Mounting plate screws with washers (set of 4) Part Number 10089040 00 10089041 00 10095320 00 10095321 00 10052010 00 10094325 00 10094326 00 10051059 00 28 www.Rose-Bopla.com Fiberglass Mini Cabinets • Mini enclosure system with hidden external hinge for MCR technology • Standard version or with window panel Included in delivery Enclosure consisting of base and door; please order door locks and keys separately, press-in inserts in the base for internal fitting. UL 508 Technical Data Material Ingress Protection Door Opening Angle Temperature Range Impact Resistance Surface Resistance Disruptive Strength Insulation Flammability Water Absorption Toxicity Color Polyglass/Polycase Size 1 Size 2 Size 3 Size 4 Size 5 Size 6 Glassfiber-reinforced, duroplastic Polyester IP 66 to EN 60529 120° -40°F to +212°F window version -40°F to +176°F >7 Nm, EN 50014 >1012 Ohm, DIN 53482 18 kV/mm, VDE 0303 / DIN 53481 fully insulated, VDE 0100 UL 94 V0, self-extinguishing max. 0.6% halogen free Agate gray, similar to RAL 7038. Special colors on request. Dimensions Inches WxLxH Dimensions mm WxLxH 120 x 200 x 100 160 x 260 x 100 160 x 340 x 100 200 x 150 x 100 200 x 200 x 170 200 x 300 x 170 4.72 x 7.87 x 3.94 6.30 x 10.24 x 3.94 6.30 x 13.38 x 3.94 7.87 x 5.90 x 3.94 7.87 x 7.87 x 6.69 7.87 x 11.81 x 6.69 Part Number Mini-Polyglas Part Number Mini-Polyglas with window Part Number Mounting Plate 21122000 00 21162600 00 21163400 00 21201500 00 21202000 00 21203000 00 22122000 00 22162600 00 22163400 00 22201500 00 22202000 00 22203000 00 10011207 00 10011208 00 10011209 00 10011210 00 10011201 00 10011202 00 Note: Standard delivery enclosure without locking screws, please order separately. Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Philips lock (set of 2 with key) Triangular lock (set of 2). Key must be order separately Square lock (set of 2). Key must be order separately Extra Philips lock key Triangular metal key Square metal key Internal galvanized steel mounting plate for 2020 Internal galvanized steel mounting plate for 1220 Internal galvanized steel mounting plate for 1626 Internal galvanized steel mounting plate for 1634 Internal galvanized steel mounting plate for 2015 Internal galvanized steel mounting plate for 2030 Wall mount brackets for 2020 & 2030 (set of 4) Wall mount brackets for 1220, 1626, 1634 and 2015 (set of 4) Mounting plate screws and washers (set of 4) Part Number 10093312 00 10093313 00 10093314 00 10094320 00 10094325 00 10094326 00 10089202 00 10011207 00 10011208 00 10011209 00 10011210 00 10089204 00 10052008 00 10031008 00 10051051 00 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 29 Element • Components can be mounted quickly and easily through side-opening of the base. • Easy access to electronic components for servicing • Enclosure with air vents E...L available to ensure optimal heat dissipation Included in delivery Lid and base, 4 mounting screws, (E 434 S without screws-with molded-on snap lock). E 430 A: includes aluminum panel in lid. Technical Data Color Material Ingress Protection Flammability Surface Resistance Model Number E 406 E 406 F E 406 VL E 408 E 410 E 410 F E 410 FVL E 420 E 420 F E 420 FVL E 430 E 430 A E 430 F E 430 FVL Upper section, light gray, similar to RAL 7035. Lower section, graphite gray, similar to RAL 7024 Polystyrene IP 40, DIN EN 60529 Dustight. With air vents: IP 30 DIN EN 60529 UL 94 HB/1.47 >1013 Ohm to DIN 53482 Part Number Dimensions mm LxWxH Dimensions Inches LxWxH 05406000 00 05406700 00 05406900 00 05408000 00 05410002 00 05410700 00 05410800 00 05420002 00 05420700 00 05420800 00 05430002 00 05430500 00 05430700 00 05430800 00 65 x 50 x 30 65 x 50 x 31 65 x 50 x 30 65 x 50 x 45 100 x 50 x 25 100 x 50 x 26 100 x 50 x 26 100 x 50 x 40 100 x 50 x 41 100 x 50 x 41 120 x 65 x 40 120 x 65 x 40 120 x 65 x 41 120 x 65 x 41 2.56 x 1.97 x 1.18 2.56 x 1.97 x 1.22 2.56 x 1.97 x 1.18 2.56 x 1.97 x 1.77 3.94 x 1.97 x 0.98 3.94 x 1.97 x 1.02 3.94 x 1.97 x1.02 3.94 x 1.97 x 1.57 3.94 x 1.97 x 1.61 3.94 x 1.97 x 1.61 4.72 x 2.56 x 1.57 4.72 x 2.56 x 1.57 4.72 x 2.56 x 1.61 4.72 x 2.56 x 1.61 Model Number E 434 S E 435 E 440 E 440 F E 440 FVL E 440 VL E 445 E 450 E 450 F E 450 FVL E 450 VL E 460 E 470 Part Number Dimensions mm LxWxH Dimensions Inches LxWxH 05434000 00 05435000 00 05440002 00 05440700 00 05440800 00 05440200 00 05445000 00 05450002 00 05450700 00 05450800 00 05450200 00 05460000 00 05470000 00 188 x 110 x 40 120 x 65 x 65 150 x 80 x 55 150 x 80 x 56 150 x 80 x 56 150 x 80 x 55 150 x 80 x 80 188 x 110 x 70 188 x 110 x 71 188 x 110 x 71 188 x 110 x 70 188 x 110 x 100 188 x 100 x 120 7.40 x 4.33 x 1.57 4.72 x 2.56 x 2.56 5.90 x 3.15 x 2.16 5.90 x 3.15 x 2.20 5.90 x 3.15 x 2.20 5.90 x 3.15 x 2.16 7.40 x 4.33 x 3.15 7.40 x 4.33 x 2.75 7.40 x 4.33 x 2.79 7.40 x 4.33 x 2.75 7.40 x 4.33 x 2.75 7.40 x 4.33 x 3.94 7.40 x 4.33 x 4.72 F = Recessed for membrane keypad VL = Ventilation slots FVL = With membrane area for membrane keypads or front membranes and with vertically molded-in air vents A = Recessed aluminum top plate S = Snap fitting lid Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Part Number SMP 1230 G TF 1230 MP430E DO430E DO435E HS440E MP440E DO440E DO445E HS450E MP450E DO450E DO460E DO470E 30 Description Mounting boss screws. Self-tapping Rubber table feet (set of 4) Mounting plate for E430, E435 Lid access screws for E430 (set of 4) Lid access screws for E435 (set of 4) Carry handle for E440 Mounting plate for E440, E445 Lid access screws for E440 (set of 4) Lid access screws for E445E Carry handle for E450 Mounting plate for E450, 460, 470 Lid access screws for E450 (set of 4) Lid access screws for E460 (set of 4) Lid access screws for E470 (set of 4) www.Rose-Bopla.com Executive Enclosures • Provides optimal protection for your electronic products • Versions available with or without ventilation • Design covers and front panels made of aluminum or plastic also available Included in delivery Lid and base, screws and cover or front panel depending on model. Technical Data Color Material Ingress Protection Flammability Surface Resistance Model Number EG 1030 EG 1030 L EG 1040 EG 1040 L EG 1230 EG-AL 1230 EG 1230 L EG 1230 B* EG 1230 L-BL* EG 1230 F EG 1230 FL* EG 1240 EG-AL 1240 EG 1240 L EG 1240 B* EG 1240 L-BL* EG 1240 FK EG 1240 F-BL-FK* EG 1240 B-FK* EG 1240 F EG 1240 F-L* EG 1250 EG-AL 1250 EG 1250 L EG 1250 B* EG 1250 L-BL* EG 1250 FK EG 1250 L-BL-FK* EG 1250 B-FK* EG 1250 F EG 1250 FL* Upper section, light gray, similar to RAL 7035. Lower section, agate gray, similar to RAL 7038. Impact resistant polystyrene IP 40 DIN EN 60529, dusttight UL 94 HB/1.47 >1013 Ohm to DIN 53482 Part Number Dimensions mm Dimensions Inches LxWxH LxWxH 32103000 00 32103010 00 32104000 00 32104010 00 32123002 00 32123090 00 32123012 00 32123032 00 32123022 00 32123062 00 32123067 00 32124002 00 32124090 00 32124012 00 32124032 00 32124022 00 32124042 00 32124057 00 32124052 00 32124062 00 32124067 00 32125002 00 32125090 00 32125012 00 32125032 00 32125022 00 32125042 00 32125057 00 32125052 00 32125062 00 32125067 00 100 x 54 x 30 100 x 54 x 30 100 x 54 x 40 100 x 54 x 40 125 x 67 x 30 129 x 71 x 30 125 x 67 x 30 125 x 67 x 30 125 x 67 x 30 125 x 67 x 31 125 x 67 x 31 125 x 67 x 40 129 x 71 x 40 125 x 67 x 40 125 x 67 x 40 125 x 67 x 40 125 x 67 x 40 125 x 67 x 40 125 x 67 x 40 125 x 67 x 40 125 x 67 x 41 125 x 67 x 50 129 x 71 x 50 125 x 67 x 50 125 x 67 x 50 125 x 67 x 50 125 x 67 x 50 125 x 67 x 50 125 x 67 x 50 125 x 67 x 51 125 x 67 x 51 3.94 x 2.12 x 1.18 3.94 x 2.12 x 1.18 3.94 x 2.12 x 1.54 3.94 x 2.12 x 1.54 4.92 x 2.64 x 1.18 5.08 x 2.79 x 1.18 4.92 x 2.67 x 1.18 4.92 x 2.64 x 1.18 4.92 x 2.64 x 1.18 4.92 x 2.64 x 1.22 4.92 x 2.64 x 1.22 4.92 x 2.64 x 1.57 5.08 x 2.79 x 1.57 4.92 x 2.64 x 1.57 4.92 x 2.64 x 1.57 4.92 x 2.64 x 1.57 4.92 x 2.64 x 1.57 4.92 x 2.64 x 1.57 4.92 x 2.64 x 1.57 4.92 x 2.64 x 1.61 4.92 x 2.64 x 1.61 4.92 x 2.64 x 1.97 5.08 x 2.79 x 1.97 4.92 x 2.64 x 1.97 4.92 x 2.64 x 1.97 4.92 x 2.64 x 1.97 4.92 x 2.64 x 1.97 4.92 x 2.64 x 1.97 4.92 x 2.64 x 1.97 4.92 x 2.64 x 2.01 4.92 x 2.64 x 2.01 Model Number Part Number Dimensions mm LxWxH Dimensions Inches LxWxH EG 1530 EG 1530 L EG 1530 B* EG 1530 L-BL* EG 1530 F EG 1530 FL* EG 1545 EG 1545 L EG 1545 B* EG 1545 L-BL* EG 1545 FK EG 1545 L-BL-FK* EG 1545 B-FK* EG 1545 F EG 1545 FL* EG 1560 EG 1560 L EG 1560 B* EG 1560 L-BL* EG 1560 FK EG 1560 L-BL-FK* EG 1560 B-FK* EG 1560 F EG 1560 FL* 32153002 00 32153012 00 32153032 00 32153022 00 32153062 00 32153067 00 32154502 00 32154512 00 32154532 00 32154522 00 32154542 00 32154557 00 32154552 00 32154563 00 32154567 00 32156002 00 32156012 00 32156032 00 32156022 00 32156042 00 32156057 00 32156052 00 32156062 00 32156067 00 150 x 82 x 30 150 x 82 x 30 150 x 82 x 30 150 x 82 x 30 150 x 82 x 31 150 x 82 x 31 150 x 82 x 45 150 x 82 x 45 150 x 82 x 45 150 x 82 x 45 150 x 82 x 45 150 x 82 x 45 150 x 82 x 45 150 x 82 x 46 150 x 82 x 46 150 x 82 x 60 150 x 82 x 60 150 x 82 x 60 150 x 82 x 60 150 x 82 x 60 150 x 82 x 60 150 x 82 x 60 150 x 82 x 61 150 x 82 x 61 5.90 x 3.23 x 1.18 5.90 x 3.23 x 1.18 5.90 x 3.13 x 1.18 5.90 x 3.13 x 1.18 5.90 x 3.23 x 1.22 5.90 x 3.23 x 1.22 5.90 x 3.23 x 1.77 5.90 x 3.23 x 1.77 5.90 x 3.23 x 1.77 5.90 x 3.23 x 1.77 5.90 x 3.23 x 1.77 5.90 x 3.23 x 1.77 5.90 x 3.23 x 1.77 5.90 x 3.23 x 1.81 5.90 x 3.23 x 1.81 5.90 x 3.23 x 2.36 5.90 x 3.23 x 2.36 5.90 x 3.23 x 2.36 5.90 x 3.23 x 2.36 5.90 x 3.23 x 2.36 5.90 x 3.23 x 2.36 5.90 x 3.23 x 2.36 5.90 x 3.23 x 2.40 5.90 x 3.23 x 2.40 Model Number EG 2030 EG 2030 L EG 2030 B* EG 2030 L-BL* EG 2030 F EG 2030 FL* EG 2050 EG 2050 L EG 2050 B* EG 2050 L-BL* EG 2050 FK EG 2050 L-BL-FK* EG 2050 B-FK* EG 2050 F EG 2050 FL* EG 2070 EG 2070 L EG 2070 B* EG 2070 L-BL* EG 2070 FK EG 2070 L-BL-FK* EG 2070 B-FK* EG 2070 F EG 2070 FL* Part Number Dimensions mm LxWxH Dimensions Inches LxWxH 32203002 00 32203012 00 32203032 00 32203022 00 32203062 00 32203067 00 32205002 00 32205012 00 32205032 00 32205022 00 32205042 00 32205055 00 32205052 00 32205062 00 32205067 00 32207002 00 32207012 00 32207032 00 32207022 00 32207042 00 32207057 00 32207052 00 32207062 00 32207067 00 200 x 112 x 30 200 x 112 x 30 200 x 112 x 30 200 x 112 x 30 200 x 112 x 31 200 x 112 x 31 200 x 112 x 50 200 x 112 x 50 200 x 112 x 50 200 x 112 x 50 200 x 112 x 50 200 x 112 x 50 200 x 112 x 50 200 x 112 x 51 200 x 112 x 51 200 x 112 x 70 200 x 112 x 70 200 x 112 x 70 200 x 112 x 70 200 x 112 x 70 200 x 112 x 70 200 x 112 x 70 200 x 112 x 71 200 x 112 x 71 7.87 x 4.41 x 1.18 7.87 x 4.41 x 1.18 7.87 x 4.41 x 1.18 7.87 x 4.41 x 1.18 7.87 x 4.41 x 1.22 7.87 x 4.41 x 1.22 7.87 x 4.41 x 1.97 7.87 x 4.41 x 1.97 7.87 x 4.41 x 1.97 7.87 x 4.41 x 1.97 7.87 x 4.41 x 1.97 7.87 x 4.41 x 1.97 7.87 x 4.41 x 1.97 7.87 x 4.41 x 2.01 7.87 x 4.41 x 2.01 7.87 x 4.41 x 2.75 7.87 x 4.41 x 2.75 7.87 x 4.41 x 2.75 7.87 x 4.41 x 2.75 7.87 x 4.41 x 2.75 7.87 x 4.41 x 2.75 7.87 x 4.41 x 2.75 7.87 x 4.41 x 2.79 7.87 x 4.41 x 2.79 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. *Available on request FK = Plastic front panel L = Enclosure with air vents FKL = Plastic front panel with integrated ventilation B = Cover panel closed DOB = Front access lid screws (factory installaiton recommended) BL = Cover panel with air vents F = Membrane keypad ared Accessories Model Number WL 1230 EG SA 1230 EG AK 1230 EG MP 10 EG MP 12 EG S 1230 EG MP 15 EG MP 20 EG Description Wall mounting brackets (set of 4) Base screw covers (set of 4) Keyhole knockout covers (set of 4) Mounting plate for EG 1030-1040 Mounting plate for EG 1230-1250 4 assembly screws Mounting plate for EG 1530-1560 Mounting plate for EG 2030-2070 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 31 Futura Sloped Housings • Enclosures designed for keypads with a ergonomic sloped front • Designs in which half-shells are assembled either as a console type or with the top shell inverted as a parallel design. Included in delivery Lid, base, assembly screws, and 4 rubber feet RO Version with aluminum front panel Technical Data Color Material Ingress Protection Surface Resistance Flammability Light gray, similar to RAL 7035. T 900, black, similar to RAL 9005. Special colors or request. 500 piece minimum order required. ABS plastic IP 40 DIN EN 60529 >1014 Ohm to DIN 53482 UL 94 HB/1.6 Part Number External Dimensions mm LxW External Dimensions Inches LxW External Dimensions Inches Height Console External Dimensions mm Height Parallel External Dimensions Inches Height Parallel T 888 F 47888200 00 195 x 275 7.68 x 10.83 24.5 / 48.0 0.96 / 1.90 36.3 1.43 T 889 F 47889200 00 170 x 132 6.69 x 5.20 24.5 / 44.9 0.96 / 1.77 36.3 1.43 T 898 47898000 00 195 x 151 7.68 x 5.94 24.5 / 44.9 0.86 / 1.77 36.3 1.43 T 898 F 47898200 00 195 x 151 7.68 x 5.94 24.5 / 44.9 0.96 / 1.77 36.3 1.43 T 898 RO 47898100 00 195 x 151 7.68 x 5.94 24.5 / 44.9 0.96 / 1.77 T 898 F-RO 47898300 00 195 x 151 7.68 x 5.94 24.5 / 44.9 0.96 / 1.44 T 899 47899001 00 125 x 150 7.68 x 5.94 15.0 / 30.7 0.59 / 1.21 22.8 0.90 T 890 47890001 00 300 x 225 4.92 x 5.91 17.0 / 48.7 0.67 / 1.92 T 893 47893001 00 500 x 225 19.68 x 8.86 17.0 / 48.7 0.67 / 1.92 T 895 P 47895101 00 480 x 330 19.00 x 8.86 89.3 3.51 T 900 4790000 00 280 x 240 11.02 x 9.45 33.0 1.30 Model Number External Dimensions mm Height Console Design Console Design Parallel Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. F = Console with continuous area RO = Console with rear wall open, split key area F-RO = Console with rear wall open, continous key area P = Console with molded-on section for digital display 32 www.Rose-Bopla.com BP 810 & BP 900 F Housings BP 810 • Can be used as a console or handheld unit. • Elegant ergonomic design, large membrane keypad area, single PC board technology, clamp between lid and base, large front panel area, recessed installation area for cable glands. • Front panels can be processed separately without any problems and provides adequate space for a wide range of connector designs. Included in delivery Lid, base, assembly screws, front panel, and rubber feet. Technical Data Color Material Ingress Protection Surface Resistance Flammability Light gray, similar to RAL 7035. Special colors on request. Minimum order quantities apply. ABS plastic IP 40/DIN EN 60529 >1014 Ohm to DIN 53482 UL 94 HB/1.6 Model Number Part Number Dimensions mm LxDxH Dimensions Inches LxDxH BP 810 45810000 00 176 x 106 x 54/24 6.93 x 4.17 x 2.13/0.94 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. BP 900-F • Ideal for use as a charging operation terminal • Base can be attached parallel to STD 900 • Enclosure ideally suited for use under extreme environmental conditions • Have three different uses: flat position on a table, angled position on a table, or wall mounted. Included in delivery Lid, base, assembly screws, lid seal in groove (in horizontal position), and 2 cover panels Left - BP 900 F Technical Data Color Material Ingress Protection Surface Resistance Flammability Model Number Agate gray, similar to RAL 7038. Special colors on request. Minimum order quantities apply. ABS plastic IP 65/DIN EN 60529 >1014 Ohm to DIN 53482 UL 94 HB/1.6 Part Number Dimensions mm Dimensions Inches LxDxH LxDxH BP 900 F 45900600 00 211 x 100 x 118 8.31 x 3.94 x 1.65 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 33 Mini Console Housings • Two basic sizes, each with opened or closed console surface and open rear section that will accept a 2mm thick slide-in panel • Console can be easily adapted to meet your requirements by using aluminum front panels. • Internal mounting bosses in base for self-tapping screws Included in delivery Lid, base, 4 screw covers, 4 rubber feet, and 4 assembly screws (front panels not included) Technical Data Color Material Ingress Protection Surface Resistance Flammability Model Number Light gray, similar to RAL 7035. Screws, covers and wall brackets, agate gray, similar to RAL 7038. Special colors on request. Minimum order quantities apply. ABS plastic IP 40/DIN EN 60529 >1014 Ohm to DIN 53482 UL 94 HB/1.6 Part Number Dimensions mm W x D x H rear Dimensions Inches W x D x H rear UM 32014 45320140 00 157 x 199 x 100 6.18 x 7.83 x 3.94 UMP 32014 FP 45320145 00 157 x 199 x 100 6.18 x 7.83 x 3.94 UMP 32018 45320180 00 157 x 199 x 120 6.18 x 7.83 x 4.72 UMP 32018 FP 45320185 00 157 x 199 x 120 6.18 x 7.83 x 4.72 UMP 62014 45620140 00 291 x 199 x 100 11.46 x 7.83 x 3.94 UMP 62014 FP 45620145 00 291 x 199 x 100 11.46 x 7.83 x 3.94 UMP 62018 45620180 00 291 x 199 x 120 11.46 x 7.83 x 4.72 UMP 62018 FP 45620185 00 291 x 199 x 120 11.46 x 7.83 x 4.72 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Model Number Part Number Description FP 30014 FPK 30014 FPP 32000 UM 1230 WLN FP 60014 FPK 60014 FPP 62000 FP 30018 FPK 30018 UM 1230 WLH FP 60018 FPK 60018 56031400 00 56031410 00 29320180 00 56002100 00 56061400 00 56061410 00 29620180 00 56031800 00 56031810 00 56002000 00 56061800 00 56061810 00 Rear panel, aluminum for UMP 32014 / UMP 32014 FP Real panel, plastic for UMP 32014 / UMP 32014 FP Aluminum front panel for console areas Wall brackets for UMP 32014 and UMP 32016 Rear panel aluminum for UMP 62014 / UMP 62014 FP Real panel plastic for UMP 62014 / UMP 62014 FP Aluminum front panel for UMP 62014 / UMP 62014FP, UMP 32018 / UMP 32018 FP Rear panel aluminum for UMP 32018 / UMP 32018 FP Rear panel plastic for UMP 32018 / UMP 32018 FP Wall brackets for UMP 32018 and UMP 62018 Rear panel, aluminum for UMP 32018 / UMP 32018 FP Rear panel, plastic for UMP 32018 / 32018 FP 34 www.Rose-Bopla.com Executive Sloped Front Housings • Console type housing suited for use as a desktop or wall-mount enclosure • PD version features recessed display window for LCD displays and recessed membrane keypads • Wall mountable • PC boards or mounting plates can be attached on mounting bosses in lid and base • P version features a console-type lid with recessed continuous membrane keypad area Included in delivery Lid, base, 4 screws, and rear panel. PD version includes display screen. Technical Data Color Material Ingress Protection Surface Resistance Flammability Model Number Lid, light gray, similar to RAL 7035. Base, covers and rear panels, agate gray, similar to RAL 7038. Special colors on request. Minimum order quantity 500+ pieces. Impact-resistant polystyrene Closed version: IP 40/DIN EN 60529 >1013 Ohm to DIN 53482 UL 94 HB/1.47 Part Number Dimensions mm LxWxH Dimensions Inches LxWxH EG 1240 P 32124070 00 125 x 67.0 x 40 4.92 x 2.64 x 1.57 EG 1240 PD 32124080 00 125 x 67.0 x 40 4.92 x 1.64 x 1.57 EG 1545 P 32154570 00 150 x 82 .0 x 45 5.91 x 3.23 x 1.77 EG 1545 PD 32154580 00 150 x 82.0 x 45 5.91 x 3.23 x 1.77 EG 2060 P 32206010 00 200 x 112 x 64 7.87 x 4.41 x 2.52 EG 2060 PD 32206000 00 200 x 112 x 64 7.87 x 4.41 x 2.52 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. P = Version with console-type lid PD = Version with console-type lid and display opening Accessories Model Number EG-SA EG-AK EG-GF EG-M-12 EG-M 15 EG-M 20 Part Number 33000300 00 33000100 00 25002100 00 33012000 00 33015000 00 33020000 00 Description Set of screw covers for assembly screws, 4 piece pack Covers for keyhole suspension, 2 piece pack Rubber feet, pack of 4 Mounting plate for EG 1240 Mounting plate for EG 1545 Mounting plate for EG 2060 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 35 Build-A-Box® Electronic Enclosures Build-A-Box® extrusions are sold in meter lengths and cut to custom lengths to meet your exact design requirements. Developments in electronics are progressing faster and faster. Whereas complete modules could be housed in large standard enclosures just a few years ago, for added space, today’s enclosures must adapt themselves permanently to new requirements. In addition to conventional protection requirements such as the ingress protection classification (IP), the toughness against electromagnet interfering radiation is now an important selectrion criteria. Rose electronic enclosures comply with all current requirements for quality electronic enclosures: - EMC or standard protection version - for external, switchgear cabinet and internal use - implementation as table, wall or regulator enclosure - ingress protection up to IP 65 - design and functionality Alubos • 20 profiles are available with profiles that are closed, split horizontally, and/or open on one side • High mechanical loading capacity of the profile and EMC screening ensure high level of protective functions Multitronic Build-A-Box® • 8 enclosure profile configurations from 105W x 36H mm to 208W x 54H mm • Application area: EMC mounting enclosure in measurement and control engineering Multitronic TS Build-A-Box® • 8 enclosure profile configurations from 46/72W x 61H mm to 105W x 84H mm • Application area: EMC enclosure for measurement/control engineering and DIN rail mounting Custom Build-A-Box® • 8 enclosure profile configurations from 105W x 85H mm to 196W x 167H mm • Application area: PCB slot-in enclosure in measurement and control engineering Profitronic • 39 enclosures in sizes from 148 x 235 x 149 mm to 265 x 276 x 241 mm • Application area: mechanical engineering, MCR-technology, Bus-technology Profitronic Universal • 12 enclosures in sizes from 148 x 258 x 149 mm to 265 x 285 x 241 mm • Application area: mechanical engineering, measurement and control 36 www.Rose-Bopla.com ALUBOS • Ergonomic, individual hand-held enclosure in your design • Available with profiles which are closed, divided horizontally, and open on one side • High mechanical loading capacity of the profile and EMC screening ensure high level of protective functions Included in delivery ABP: Closed extrusion only. Black powder-coated Aluminum sold by the meter ABPH: Split extrusion only. Black powder-coated Aluminum sold by the meter ABPU: Extrusion open on one side. Black powder-coated Aluminum sold by the meter Technical Data Material Color Ingress Protection Model Number ABP 600-1000 ABP 800-1000 ABP 820-1000 ABP 1000-1000 ABP 1040-1000 ABP 1300-1000 ABP 1600-1000 ABP 1680-1000 ABP 2070-1000 ABPH 600-1000 ABPH 800-1000 ABPH 820-1000 ABPH 1000-1000 ABPH 1040-1000 ABPH 1300-1000 ABPH 1680-1000 ABPU 820-1000 ABPU 1040-1000 ABPU 1300-1000 ABPU 1680-1000 Aluminum extrusion, Al Mg Si 0.5, powder-coated aluminum diecast lid GD-Al Si 12 Powdercoated Satin Black, similar to RAL 9005, fine texture finish. Special colors on request. Minimum order quantities apply IP 65, EN 60529 IP 40 when using parallel adapters (AB-AP) with 600, 800 and 1000 extrusions Part Number 84060000 00 84080000 00 84820000 00 84100000 00 84040000 00 84130000 00 84160001 00 84680000 00 84207000 00 84066001 00 84086001 00 84826000 00 84106001 00 84046000 00 84136000 00 84686000 00 84827000 00 84047000 00 84137000 00 84687000 00 Dimensions mm Dimensions Inches LxWxH LxWxH 1000 x 57 x 32 1000 x 82 x 32 1000 x 82 x 22 1000 x 106 x 32 1000 x 108 x 32 1000 x 138 x 34 1000 x 169 x 52 1000 x 169 x 82 1000 x 210 x 74 1000 x 57 x 32 1000 x 82 x 32 1000 x 82 x 22 1000 x 106 x 32 1000 x 108 x 42 1000 x 138 x 34 1000 x 169 x 82 1000 x 82 x 22 1000 x 108 x 42 1000 x 138 x 34 1000 x 169 x 82 39.37 x 2.24 x 1.26 39.37 x 3.23 x 1.26 39.37 x 3.23 x 0.87 39.37 x 4.17 x 1.26 39.37 x 4.25 x 1.26 39.37 x 5.43 x 1.34 39.37 x 6.65 x 2.05 39.37 x 6.65 x 3.23 39.37 x 8.27 x 2.91 39.37 x 2.24 x 1.26 39.37 x 3.23 x 1.26 39.37 x 3.23 x 0.87 39.37 x 4.17 x 1.26 39.37 x 4.25 x 1.65 39.37 x 5.43 x 1.34 39.37 x 6.65 x 3.23 39.37 x 3.23 x 0.87 39.37 x 4.25 x 1.65 39.37 x 5.43 x 1.34 39.37 x 6.65 x 3.23 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 37 Accessories Model Number Part Number ABM 600 AL AMB 600 IR ABM 600 SAL ABM 600 AL-BE ABM 600 IR-BE 84602000 00 84063000 00 84064000 00 84062100 00 84063100 00 ABM 600 SAL-BE ABD 600 DI 600-EMV DI 600-5002 DI 600-3000 DI 600-1021 DI 600-6000 ABM 800 AL ABM 800 IR ABM 800 SAL ABM 800 AL-BE ABM 800 IR-BE 84064100 00 84061000 00 84200615 00 84200614 00 84200611 00 84200612 00 84200613 00 84082000 00 84083000 00 84084000 00 84082100 00 84083100 00 ABM 800 SAL-BE ABD 800 ABA 800-1000 DI 800-EMV DI 800-5002 DI 800-3000 DI 800-1021 DI 800-6000 ABD 820 DI 820-EMV DI 820-5002 DI 820-3000 DI 820-1021 DI 820-6000 ABPU 820-1000 FP2 ABM 1000 AL ABM 1000 IR ABM 1000 SAL AMB 1000 AL-BE ABM 1000 IR-BE 84084100 00 84081000 00 84002000 00 84200815 00 84200814 00 84200811 00 84200812 00 84200813 00 84821000 00 84208215 00 84208214 00 84208211 00 84208212 00 84208213 00 84828000 00 84102000 00 84103000 00 84104000 00 84202100 00 84103100 00 ABM 1000 SAL-BE ABD 1000 DI 1000-EMV DI 1000-5002 DI 1000-3000 DI 1000-1021 DI 1000-6000 ABM 1040 AL ABM 1040 SAL ABM 1040 DI 1040-EMV DI 1040-5002 84104100 00 84101000 00 84201015 00 84201014 00 84201011 00 84201012 00 84201013 00 84042000 00 84044000 00 84041000 00 84200415 00 84200414 00 Description Mounting lid, aluminum profile cap Mounting lid, infrared-permissive plastic cap Mounting lid, aluminum hinged flap Mounting lid, aluminum profile cap, battery compartment 9V Mounting lid, infrared-permissive plastic cap, battery compartment 9V Mounting lid, aluminum hinged flap, battery compartment 9V End lid EMC seal, black (10 pieces) Seal, ultramarine (10 pieces) Seal, flame red (10 pieces) Seal, yellow (10 pieces) Seal, patina green (10 pieces) Mounting lid, aluminum profile cap Mounting lid, infrared-permissive plastic cap Mounting lid, aluminum hinged flap Mounting lid, aluminum profile cap, battery compartment 9V Mounting lid, infrared-permissive plastic cap, battery compartment 9V Mounting lid, aluminum hinged flap, battery compartment 9V End lid, powder-coated aluminum Axial adapter for ALUBOS 800/100 EMC seal, black (10 pieces) Seal, ultramarine (10 pieces) Seal, flame red (10 pieces) Seal, yellow (10 pieces) Seal, patina green (10 pieces) End lid, black seal, screws, screw cover EMC seal, black (10 pieces) Seal, ultramarine (10 pieces) Seal, flame red (10 pieces) Seal, yellow (10 pieces) Seal, patina green (10 pieces) Front panel for ABPU 820-1000 Mounting lid, aluminum profile cap Mounting lid, infrared-permissive plastic cap Mounting lid, aluminum hinged flap Mounting lid, aluminum profile cap, battery compartment 9V Mounting lid, infrared-permissive plastic cap, battery compartment 9V Mounting lid, aluminum hinged flap, battery compartment 9V End lid EMC seal, black (10 pieces) Seal, ultramarine (10 pieces) Seal, flame red (10 pieces) Seal, yellow (10 pieces) Seal, patina green (10 pieces) Mounting lid, aluminum profile cap Mounting lid, aluminum hinged flap End lid EMC seal, black (10 pieces) Seal, ultramarine (10 pieces) Model Number Part Number Description DI 1040-3000 DI 1040-1021 DI 1040-6000 ABPU 1040-1000 FP2 ABM 1300 AL ABD 1300 SAL ABM 1300 DI 1300-EMV DI 1300-5002 DI 1300-3000 DI 1300-1021 DI 1300-6000 ABPU 1300-1000 FP2 ABD 1600 84200411 00 84200413 00 84200412 00 84048000 00 84132000 00 84134000 00 84131000 00 84201315 00 84201314 00 84201311 00 84201312 00 84201313 00 84138000 00 84161000 00 DI 1600-EMV DI 1600-5002 DI 1600-3000 DI 1600-1021 DI 1600-6000 ABD 1680 84201615 00 84201614 00 84201616 00 84201612 00 84201613 00 84168100 00 DI 1680-EMV DI 1680-5002 DI 1680-3000 DI 1680-1021 DI 1680-6000 ABPU 1680-1000 FP3 ABD 2070 84206815 00 84206814 00 84206811 00 84206812 00 84206813 00 84689000 00 84271000 00 DI 2070-EMV DI 2070-5002 DI 2070-3000 DI 2070-1021 DI 2070-6000 AB-1000 WLV AB-WL AB-WL 1 AB-WL 2 AB-WL 3 AB 600 MKL AB 800 MKL AB 1000 MKL AB-MKL AB 1600 HS AB 2000 HS AB-AP 60 AB-AP 100 AB-AP 150 ABA 800-1000 AB-GF 84202715 00 84202714 00 84202711 00 84202712 00 84202713 00 84105000 00 84005000 00 84006001 00 84007000 00 84008000 00 84006600 00 84006400 00 84006500 00 84006300 00 84162000 00 84200000 00 84006000 00 84010000 00 84015000 00 84002000 00 84006700 00 Seal, flame red (10 pieces) Seal, yellow (10 pieces) Seal, patina green (10 pieces) Front panel for ABPU 1040-1000 Mounting lid, aluminum profile cap Mounting lid, aluminum hinged flap End lid EMC seal, black (10 pieces) Seal, ultramarine (10 pieces) Seal, flame red (10 pieces) Seal, yellow (10 pieces) Seal, patina green (10 pieces) Front panel for ABPU 1300-1000 End lid, black seals, screws, screw cover for ABD 1600-1000 EMC seal, black (10 pieces) Seal, ultramarine (10 pieces) Seal, flame red (10 pieces) Seal, yellow (10 pieces) Seal, patina green (10 pieces) End lid, black seals, screws, screw cover for ABD 1680-1000 EMC seal, black (10 pieces) Seal, ultramarine (10 pieces) Seal, flame red (10 pieces) Seal, yellow (10 pieces) Seal, patina green (10 pieces) Front panels for ABPU 1680-1000 End lid, black seals, screws, screw covers for ABP 2070-1000 EMC seal, black (10 pieces) Seal, ultramarine (10 pieces) Seal, flame red (10 pieces) Seal, yellow (10 pieces) Seal, patina green (10 pieces) ALUBOS adjustable wall bracket Wall brackets for use with 600/800/1000/1300 Wall brackets for use with 820 Wall brackets for use with 1040 Wall brackets for use with 1600/1680/2070 Mounting clamp for ALUBOS 600 Mounting clamp for ALUBOS 800 Mounting clamp for ALUBOS 1000 Mounting clamp for ALUBOS 600/800/1000 Handle for use with ALUBOS 1600/1680 Handle for use ALUBOS 2070 Parallel adapter for ALUBOS 600/800/1000, 60 mm length Parallel adapter for ALUBOS 600/800/1000, 100 mm length Parallel adapter for ALUBOS 600/800/1000, 150 mm length Axial adapter, adapts ABP 800 to an ABP 1000 Rubber feet Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. 38 www.Rose-Bopla.com Alu-Topline • Desktop enclosure whose innovative technology and ergonomic lines for use in the field of data recording and processing. • Split profile of the enclosure guarantees easier and faster assembly of electronics and other components. • Lid can be rotated in order to cover different ranges of application with the same contents. • Profiles have a range of PCB slots and screw channels so that PCBs can be fitted in the required positions. Included in delivery Enclosure profile, split horizontally Technical Data Color Material Protection Classifications Profiles: clear anodized aluminum. End lids: quartz gray, similar to RAL 7039 and graphite gray, similar to RAL 7024. Special colors on request. Minimum order quantities apply. Profile: Alunminum Al Mg Si 0.5. End lids: ABS plastic IP 40, DIN EN 60529. IP 54, when using seal (AT...DI) with sponge cord factory-installed Model Number External Dimensions mm LxWxH External Dimensions Inches LxWxH 92850150 00 92850200 00 92850250 00 92850300 00 92865150 00 92865200 00 92865250 00 92865300 00 150 x 183.8 x 53.2 200 x 183.8 x 53.2 250 x 183.8 x 53.2 300 x 183.8 x 53.2 150 x 183.8 x 68.2 200 x 183.8 x 68.2 250 x 183.8 x 68.2 300 x 183.8 x 68.2 5.90 x 7.24 x 2.09 7.87 x 7.24 x 2.09 9.84 x 7.24 x 2.09 11.84 x 7.24 x 2.09 5.90 x 7.24 x 2.68 7.87 x 7.24 x 2.68 9.84 x 7.24 x 2.67 11.81 x 7.24 x 2.68 Model Number ATPH 1850-0150 ATPH 1850-0200 ATPH 1850-0250 ATPH 1850-0300 ATPH 1865-0150 ATPH 1865-0200 ATPH 1865-0250 ATPH 1865-0300 Meter lengths available upon request. Minimum order may apply. Accessories Model Number ATD 1850-7024 ATD 1850-7039 AT 1850 DI* ATD 1865-7024 ATD 1865-7039 AT 1865 DI* AT 1800-0150 WB AT 1800-0200 WB AT 1800-0250 WB AT 1800-0300 WB AT-IS 00020 AB-GF Part Number 92050024 00 92050039 00 92050000 00 92065024 00 92065039 00 92065000 00 92800150 00 92800200 00 92800250 00 92800300 00 92000100 00 94006700 00 Description Lid, graphite gray, similar to RAL 7024, (includes: 2 lids, right/left, 8 screws, 8 screw covers) Lid, quartz gray, similar to RAL 7039, (includes: 2 lids, right/left, 8 screws, 8 screw covers) Seal for ingress protection IP 54, (includes: 5 sets of sponge rubber seals, right/left) Lid, graphite gray, similar to RAL 7024 (includes: 2 lids, right/left, 8 screws, 8 screw covers) Lid, quartz gray, similar to RAL 7039, (includes 2 lids, right/left, 8 screws, 8 screw covers) Seal for ingress protection IP 54, (includes: 5 sets of sponge rubber seals, right/left) Wall bracket 150 (includes: 1 wall profile, 2 tapped pins) Wall bracket for profile 200 (includes: 1 wall profile, 2 tapped pins) Wall bracket for profile 250 (includes: 1 wall profile, 2 tapped pins) Wall bracket for profile 300 (includes: 1 wall profile, 2 tapped pins) Insulating strip (includes: 5 insulating strips) Rubbet feet (includes: 4 rubber feet) *Note: to attain IP 54, in addition to seal AT... DI, a sponge cord must be factory installed in the enclosure profile. ATPH 1850 Split Profile ATPH 1865 Split Profile For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 ATD 18... Lid made of ABS plastic 39 BOS-Ecoline • Clear anodized aluminum profile enclosure system in 3 different versions in 4 profile widths • Equipped with integral guide grooves for PC boards • Ecoline features recessed areas for front membranes or membrane keypads • Can be used with Euro cards Included in delivery Extrusion sold in meter lengths Technical Data Color Material Protection Classifications Profiles: clear anodized aluminum. End lids: dust gray, similar to RAL 7037. Special colors on request. Minimum order quantities apply. Profile: Alunminum Al Mg Si 0.5. End lids: ABS plastic IP 40, EN 60529. IP 54, when using seal (EL-DI) with 620, 8540, 1050 and 1240. ELP type extrusions only. Model Number ELP 620-1000 ELPH 620-1000 ELPU 620-1000 ELP 840-1000 ELPH 840-1000 ELPU 840-1000 ELP 1050-1000 ELPH 1050-1000 ELPU 1050-1000 ELPH-EU 1050-1000 ELP 1240-1000 ELPH 1240-1000 ELPU 1240-1000 Accessories Model Number ELD 620 ELDW 620 ELD 840 ELDW 840 ELD 1050 ELDW 1050 ELD 1240 ELDW 1240 EL 620 DI EL 840 DI EL 1050 DI EL 1240 DI External Dimensions mm LxWxH External Dimensions Inches LxWxH 83062000 00 83626000 00 83627000 00 83084000 00 83846000 00 83847000 00 83105000 00 83056000 00 83057000 00 83055100 00 83124000 00 83246000 00 83247000 00 1000 x 57.5 x 22 1000 x 57.5 x 22 1000 x 57.5 x 22 1000 x 80.0 x 42 1000 x 80.0 x 42 1000 x 80.0 x 42 1000 x 106 x 52 1000 x 106 x 52 1000 x 106 x 52 1000 x 106 x 52 1000 x 120 x 42 1000 x 120 x 42 1000 x 120 x 42 39.37 x 2.26 x 0.86 39.37 x 2.26 x 0.86 39.37 x 2.26 x 0.86 39.37 x 3.14 x 1.65 39.37 x 3.14 x 1.65 39.37 x 3.14 x 1.65 39.37 x 4.14 x 2.05 39.37 x 4.14 x 2.05 39.37 x 4.14 x 2.05 39.37 x 4.17 x 2.04 39.37 x 4.72 x 1.65 39.37 x 4.72 x 1.65 39.37 x 4.72 x 1.65 Part Number 83621000 00 83621100 00 83841000 00 83841100 00 83051000 00 83051100 00 83241000 00 83241100 00 83206210 00 83208410 00 83210510 00 83212410 00 ELP - Closed Profile 40 Part Number Description Ecoline 620 plastic end caps, ABS, set of 2 Ecoline 620 wall mount plastic end caps, ABS, set of 2 Ecoline 840 plastic end caps, ABS, set of 2 Ecoline 840 wall mount plastic end caps, ABS, set of 2 Ecoline 1050 plastic end caps, ABS, set of 2 Ecoline 1050 wall mount plastic end caps, ABS, set of 2 Ecoline 1240 plastic end caps, ABS, set of 2 Ecoline 1240 wall mount plastic end caps, ABS, set of 2 Ecoline 620 gasket set of 10 Ecoline 840 gasket set of 10 Ecoline 1050 gasket set of 10 Ecoline 1240 gasket set of 10 ELPH - Horizontally Split Profile ELPU - Open on one side Profile www.Rose-Bopla.com NoVoTronic • Aluminum profile enclosure system in 5 diameters for data acquisition, PC, and measurement and control technology • External screw channels guarantee complete use of internal area • Integrated guide grooves for PC boards • External groove system • Variable profile lengths Included in delivery Enclosure with 2 aluminum diecast lids and 2 multi-function profiles, not screwed. Technical Data Color Material Protection Classifications Temperature Resistance Model Number Profile and lid, jet black, similar to RAL 9005. Multi-function side profile: ruby red, similar to RAL 3003. Profile: AlMgSi 0.5; DIN 1725. End lids: GD-AlSi 12 up to IP 65, EN 60529 -40°F to +90°F Part Number External Dimensions mm WxHxD External Dimensions Inches WxHxD Internal Dimensions mm HxWxD Internal Dimensions Inches HxWxD NoVoTronic 80 80/100 80/160 80/200 80/SL* 07501010 00 07501011 00 07501012 00 07501099 00 98 x 44 x 100 98 x 44 x 160 98 x 44 x 200 98 x 44 x SL* 3.76 x 1.73 x 3.94 3.86 x 1.73 x 6.30 3.86 x 1.76 x 7.87 3.86 x 1.76 x SL* 80 x 36 x 100 80 x 36 x 160 80 x 36 x 200 80 x 30 x SL* 3.15 x 1.42 x 3.94 3.15 x 1.42 x 6.30 3.15 x 1.42 x 7.87 3.15 x 1.42 x SL* 07502010 00 07502011 00 07502012 00 07502099 00 118 x 44 x 100 118 x 44 x 160 118 x 44 x 200 118 x 44 x SL* 4.64 x 1.73 x 3.94 4.64 x 1.73 x 6.30 4.64 x 1.73 x 7.87 4.64 x 1.73 x SL* 100 x 36 x 100 100 x 36 x 160 100 x 36 x 200 100 x 36 x SL* 3.94 x 1.41 x 3.94 3.94 x 1.41 x 6.30 3.94 x 1.41 x 7.87 3.94 x 1.41 x SL* 07503010 00 07503011 00 07503012 00 07503099 00 182 x 85 x 160 182 x 85 x 200 182 x 85 x 300 182 x 85 x SL* 7.16 x 3.35 x 6.30 7.16 x 3.35 x 6.30 7.16 x 3.35 x 11.81 7.16 x 3.35 x SL* 160 x 75 x 160 160 x 75 x 200 160 x 75 x 300 160 x 75 x SL* 6.30 x 2.96 x 6.30 6.30 x 2.96 x 7.87 6.30 x 2.96 x 11.81 6.30 x 2.96 x SL* 07502510 00 07502511 00 07502513 00 07502599 00 157 x 69 x 150 157 x 69 x 160 157 x 69 x 220 157 x 69 x SL* 6.18 x 2.72 x 5.90 6.18 x 2.72 x 7.09 6.18x 2.72 x 8.66 6.18 x 2.72 x SL* 130 x 57 x 130 130 x 57 x 160 130 x 57 x 200 130 x 57 x SL* 5.12 x 2.24 x 5.12 5.12 x 2.24x 6.30 5.12 x 2.24 x 7.87 5.12 x 2.24 x SL* 200 x 105 x 220 200 x 105 x 280 200 x 105 x 330 200 x 105 x SL* 7.87 x 4.13 x 8.66 7.87 x 4.13 x 11.02 7.87 x 4.13 x 12.99 7.87 x 4.13 x SL* NoVoTronic 100 100/100 100/160 100/200 100/SL* NoVoTronic 160 160/160 160/200 160/300 160/SL* NoVoTronic 130 130/130 130/160 130/200 130/SL* NoVoTronic 200 07504010 00 233 x 121 x 240 9.17 x 4.76 x 9.45 200/220 07504011 00 233 x 121 x 300 9.17 x 4.76 x 11.81 200/280 07504012 00 233 x 121 x 350 9.17 x 4.76 x 13.78 200/330 07504099 00 233 x 121 x SL* 9.17 x 4.76 x SL* 200/SL* *SL = Special Length Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Part Number 07509011 00 07509012 00 07509013 00 07509099 00 07509111 00 07509112 00 07509113 00 07509114 00 07509199 00 07509002 00 07509003 00 07509004 00 07509015 00 *SL = Special Length Description Wall profile 80/100-100 Walll profile 80/100-160 Wall profile 80/100-200 Wall profile 80/SL* Wall profile 130/160-130 Wall profile 130/160-160 Wall profile 130/160-200 Wall profile 130/160-300 Wall profile 130/160-SL* Lid wall holder 80/100 NoVo wall holder P80 NoVo wall holder P100 NoVo wall holder P130 Part Number 07509005 00 07509006 00 07509007 00 07509014 00 07509008 00 83900003 00 83900006 00 07509211 00 07509212 00 07509213 00 07529299 00 07509214 00 07509010 00 Description NoVo wall holder P160 Foot/connection element 80 Foot/connection element 100 Foot connection element 130 Foot connection element 160 Battery insert 9V block Battery insert 4 AA NoVoTronic PCB profile 200-220 NoVoTronic PCB profile 200-280 NoVoTronic PCB profile 200-330 NoVoTronic PCB profile 200-SL* NoVoTronic PCB profile 80-100 Transparent cover 160 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 41 Multitronic Build-A-Box® • Aluminum profile that can be cut to any length required and capped with plate aluminum lids • All profiles slotted internally for PCB or chassis mounting • T-slot on bottom of profile for DIN rail mounting Included in delivery Extrusion only. Sold by the meter. Technical Data Material Temperature Range Protection Classification Bare aluminum, Al Mg Si 0.5 -40°F to +212°F IP 40 to EN 60529 Part Number Length Inches/mm Width Inches/mm Height Inches/mm PC Card Slot Size 10011109/10011109 10011109/10011110 10011110/10011110 10011109/10011111 10011111/10011110 10955170 / 10011113 10011108 00 10011112 00 39.37 / 1000 39.37 / 1000 39.37 / 1000 39.37 / 1000 39.37 / 1000 39.37 / 1000 39.37 / 1000 39.37 / 1000 4.13 / 105 4.13 / 105 4.13 / 105 4.13 / 105 4.13 / 105 8.19 / 208 4.13 / 105 6.50 / 165 1.97 / 50 3.15 / 80 4.33 / 110 2.20 / 56 3.39 / 86 2.13 / 54 1.42 / 36 2.56 / 65 2 x 100 mm 3 x 100 mm 4 x 100 mm 1 x 100 mm 2 x 100 mm 2 x 57 mm,1 x 85 mm, 1 x 204 mm 1 x 100 mm 2 x 160 mm These profiles feature external “T” slots for bracket wall-mounting Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. All extrusions sold in 1 meter lengths. Accessories Unpainted plate lid with screws for 10011109/10011109 Unpainted plate lid with screws for 10011109/10011110 Unpainted plate lid with screws for 10011110/10011110 Unpainted plate lid with screws for 10011111/10011109 Unpainted plate lid with screws for 10011111/10011110 Unpainted plate lid with screws for 10955170/10011113 Unpainted plate lid with wall mount flange and screws for 10955170/10011113 Unpainted plate lid with screws for 10011108 Unpainted plate lid with screws for 10011112 External wall mount brackets (set of 4) Rubber Table Feet Black Lid Screw (M3 x 8) 42 Part Number 10095151 08 10095153 08 10095154 08 10095150 08 10095152 08 10095517 08 10095518 07 10095150 08 10095155 08 77000100 00 10094110 00 10093205 00 www.Rose-Bopla.com Multitronic Build-A-Box® 10011109/10011109 Description Part # Type 10011109 00 Extrusion Top Extrusion only, bare Aluminum (sold by the meter) 10011109 00 Extrusion Bottom Extrusion only, bare Aluminum (sold by the meter) Accessories 10095151 08 End Lid Unpainted Aluminum plate lid with screws 77000100 00 Brackets Set of 4 External Wall Mount Brackets with spring nuts and screws 10094110 00 Rubber Feet 10093205 00 Screw Rubber Table Feet Black Lid Screw (M3 x 8) Two half-shell extrusions with integrated guide rails for two 100 mm PC boards, and 4 external “T” slots for bracket wall-mounting. External wall-mount bracket set, optional. Enclosure Profiles Multitronic Build-A-Box® 10011109/10011110 Part # Type Description 10011109 00 Extrusion Top Extrusion only, bare Aluminum (sold by the meter) 10011110 00 Extrusion Bottom Extrusion only, bare Aluminum (sold by the meter) Accessories 10095153 08 End Lid Unpainted Aluminum plate lid with screws 77000100 00 Brackets Set of 4 External Wall Mount Brackets with spring nuts and screws 10094110 00 Rubber Feet 10093205 00 Screw Rubber Table Feet Black Lid Screw (M3 x 8) Two half-shell extrusions with integrated guide rails for three 100 mm PC boards, and 4 externa; “T” slots for bracket wall-mounting. External wall-mount bracket set, optional. Enclosure Profiles For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 43 Multitronic Build-A-Box® 10011110/10011110 10011110 00 Type Extrusion Top 10011110 00 Extrusion Bottom Part # Description Extrusion only, bare Aluminum (sold by the meter) Extrusion only, bare Aluminum (sold by the meter) Accessories 10095154 08 End Lid Unpainted Aluminum plate lid with screws 77000100 00 Brackets Set of 4 External Wall Mount Brackets with spring nuts and screws 10094110 00 Rubber Feet 10093205 00 Screw Rubber Table Feet Black Lid Screw (M3 x 8) Two-shell extrusion design with integrated guide rails for four 100 mm PC boards, and 4 external “T” slots for bracket wall-mounting. External wall-mount bracket set, optional. Enclosure Profiles Multitronic Build-A-Box® 10011111/10011109 Part # Type 10011111 00 Extrusion Top Extrusion only, bare Aluminum (sold by the meter) 10011109 00 Extrusion Bottom Extrusion only, bare Aluminum (sold by the meter) Description Accessories 10095150 08 End Lid Unpainted Aluminum plate lid with screws 77000100 00 Brackets Set of 4 External Wall Mount Brackets with spring nuts and screws 10094110 00 Rubber Feet 10093205 00 Screw Rubber Table Feet Black Lid Screw (M3 x 8) Two-shell extrusion design with integrated heat sink, integrated guide rail for one 100 mm PC boards, and 2 external “T” slots for bracket wall-mounting. External wall-mount bracket set, optional. Enclosure Profiles 44 www.Rose-Bopla.com Multitronic Build-A-Box® 10011111/10011110 Part # 10011111 00 Type Extrusion Top Description Extrusion only, bare Aluminum (sold by the meter) 10011110 00 Extrusion Bottom Extrusion only, bare Aluminum (sold by the meter) Accessories 10095152 08 End Lid Unpainted Aluminum plate lid with screws 77000100 00 Brackets Set of 4 External Wall Mount Brackets w/spring nuts and screws 10094110 00 Rubber Feet 10093205 00 Screw Rubber Table Feet Black Lid Screw (M3 x 8) Two-shell extrusion design with integrated heat sink on top extrusion, integrated guide rails for two 100 mm PC boards, and 2 external “T” slots for bracket wall-mounting. External wall-mount bracket set, optional. Enclosure Profiles Multitronic Build-A-Box® 10955170/10011113 Part # Type Description 10955170 00 Plate Lid, Top Unpainted Aluminum Plate Lid (sold by the meter) 10011113 00 Extrusion Bottom Extrusion only, bare Aluminum (sold by the meter) Accessories 10095517 08 End Lid Unpainted Aluminum plate lid with screws 10095518 08 End Lid Unpainted Plate Lid w/Wall Mount Flange and lid screws 10094110 00 Rubber Feet 10093205 00 Screw Rubber Table Feet Black Lid Screw (M3 x 8) One-shell open extrusion with integrated guide rails for one 204 mm, one 87 mm, two 57 mm PC boards, and top aluminum plate lid. Wall-mount flange plate lids are available as an option. Enclosure Profile For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 45 Multitronic Build-A-Box® 10011108 Part # 10011108 00 Type Extrusion Description Extrusion, bare Aluminum (sold by the meter) Accessories 10095150 08 Lid 77000100 00 Brackets 10094110 00 Rubber Feet 10093205 00 Screw Unpainted Aluminum plate lid with screws Set of 4 External Wall Mount Brackets with spring nuts and screws Rubber Table Feet Black Lid Screw (M3 x 8) One-shell closed extrusion design with integrated guide rail for one 100 mm PC board and 2 external “T” slots for bracket wall-mounting. External wall-mount bracket set, optional. Enclosure Profile Multitronic Build-A-Box® 10011112 Part # 10011112 00 Type Extrusion Description Extrusion, bare Aluminum (sold by the meter) Accessories 10095155 08 Lid 77000100 00 Brackets 10094110 00 Rubber Feet 10093205 00 Screw Unpainted Aluminum plate lid with screws Set of 4 External Wall Mount Brackets with spring nuts and screws Rubber Table Feet Black Lid Screw (M3 x 8) One-shell closed extrusion design with integrated heat sink, integrated guide rails for two 160 mm PC boards, and 2 external “T” slots for bracket wall-mounting. External wall-mount bracket set, optional. Enclosure Profile 46 www.Rose-Bopla.com Multitronic TS Build-A-Box® • Aluminum profile that can be cut to any length required and capped with plate aluminum lids • All profiles slotted internally for PCB or chassis mounting • Optional “L-shaped” aluminum plate lids are offered for wall-mount applications Included in delivery Extrusion only. Sold by the meter. Technical Data Color Material Temperature Range Protection Classification Part Number 10011129 /10011129 10011129/10011131 10011131/10011131 10011130/10011131 10011130/10011130 10011132/10011132 10011133/10011132 10011133/10011133 Any color is available. Aluminum, Al Mg Si 0.5 -40°F to +212°F IP 40 to EN 60529 Length Inches/mm 39.37 / 1000 39.37 / 1000 39.37 / 1000 39.37 / 1000 39.37 / 1000 39.37 / 1000 39.37 / 1000 39.37 / 1000 Width Inches/mm Height Inches/mm PC Card Slot Size 2.83 / 72 2.99 / 76 2.99 / 76 2.99 / 76 2.99 / 76 4.13 / 105 4.13 / 1.05 4.13 / 1.05 1.81 / 46 2.40 / 61 2.01 / 51 2.54 / 64 3.07 / 78 1.77 / 45 2.60 / 66 3.42 / 87 42 mm 42, 72 mm 72 mm 72 mm 72 mm 100 mm 100 mm 100 mm Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. All extrusions sold in 1 meter lengths Accessories Part Number Unpainted plate lid with screws for 11129/11129 Unpainted plate lid with screws & wall flange for 11129/11129 Unpainted plate lid with screws for 11129/11131 Unpainted plate lid with screws & wall flange for 11129/11131 Unpainted plate lid with screws for 11131/11131 Unpainted plate lid with screws & wall flange for 11131/11131 Unpainted plate lid with screws for 11130/11131 Unpainted plate lid with screws & wall flange for 11130/11131 Unpainted plate lid with screws for 11130/11130 Unpainted plate lid with screws & wall flange for 11130/11130 Unpainted plate lid with screws for 11132/11132 Unpainted plate lid with screws & wall flange for 11132/11132 Unpainted plate lid with screws for 11133/11132 Unpainted plate lid with screws & wall flange for 11133/11132 Unpainted plate lid with screws & wall flange for 11133/11133 Black lid screws M3 x 8 10095525 08 10095531 08 10095530 08 10095538 08 10095526 08 10095532 08 10095527 08 10095538 08 10095528 08 10095534 08 10095529 08 10095535 08 10095152 08 10095536 08 10095537 08 10093205 00 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 47 Multitronic TS Build-A-Box® 10011129/10011129 Part # Type 10011129 00 Extrusion Top Extrusion only, bare Aluminum (sold by the meter) 10011129 00 Extrusion Bottom Extrusion only, bare Aluminum (sold by the meter) Accessories 10095525 08 Description End Lid End Lid Unpainted Plate Lid w/screws for 11129/11129 10095531 08 10093205 00 Screws Black Lid Screw M3x8 77003500 00 Bracket DIN Rail Bracket Unpainted Plate Lid w/ screws & Wall Flange for 11129/11129 Two half-shell extrusions with integrated guide rails for 42 mm PC boards and exterior slots designed for optional 35 mm DIN Rail mounting bracket. Enclosure Profiles Multitronic TS Build-A-Box® 10011129/10011131 Part # Type 10011129 00 Extrusion Top Extrusion only, bare Aluminum (sold by the meter) 10011131 00 Extrusion Bottom Extrusion only, bare Aluminum (sold by the meter) Description Accessories 10095530 08 End Lid Unpainted Plate Lid w/screws for 11129/11131 10095538 08 End Lid Unpainted Plate Lid w/ screws & Wall Flange for 11129/11131 10093205 00 Screws Black Lid Screw M3x8 77003500 00 Bracket DIN Rail Bracket Two half-shell extrusions with integrated guide rails for 42 and 72 mm PC boards and exterior slots designed for optional 35 mm DIN Rail mounting bracket. Enclosure Profiles 48 www.Rose-Bopla.com Multitronic TS Build-A-Box® 10011131/10011131 Part # Description Type 10011131 00 Extrusion Top Extrusion only, bare Aluminum (sold by the meter) 10011131 00 Extrusion Bottom Extrusion only, bare Aluminum (sold by the meter) Accessories 10095526 08 10095532 08 10093205 00 77003500 00 Unpainted Plate Lid w/screws for 11131/11131 Unpainted Plate Lid w/ screws & Wall Flange for 11131/11131 Black Lid Screw M3x8 DIN Rail Bracket End Lid End Lid Screws Bracket Two half-shell extrusions with integrated guide rails for 72 mm PC boards and exterior slots designed for optional 35 mm DIN Rail mounting bracket. Enclosure Profiles Multitronic TS Build-A-Box® 10011130/10011131 Part # Type Description 10011130 00 Extrusion Top Extrusion only, bare Aluminum (sold by the meter) 10011131 00 Extrusion Bottom Extrusion only, bare Aluminum (sold by the meter) Accessories 10095527 08 10095533 08 End Lid Unpainted Plate Lid w/screws for 11130/11131 End Lid Unpainted Plate Lid w/ screws & Wall Flange for 11130/11131 10093205 00 77003500 00 Screws Black Lid Screw M3x8 Bracket DIN Rail Bracket Two half-shell extrusions with integrated guide rails for 72 mm PC boards and exterior slots designed for optional 35 mm DIN Rail mounting bracket. Enclosure Profiles For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 49 Multitronic TS Build-A-Box® 10011130/10011130 Part # Type 10011130 00 Extrusion Top Extrusion only, bare Aluminum (sold by the meter) 10011130 00 Extrusion Bottom Extrusion only, bare Aluminum (sold by the meter) Description Accessories 10095528 08 End Lid Unpainted Plate Lid w/screws for 11130/11130 10095534 08 End Lid Screws Bracket Unpainted Plate Lid w/ screws & Wall Flange for 11130/11130 Black Lid Screw M3x8 DIN Rail Bracket 10093205 00 77003500 00 Two half-shell extrusions with integrated guide rails for 72 mm PC boards and exterior slots designed for optional 35 mm DIN Rail mounting bracket. Enclosure Profiles Multitronic TS Build-A-Box® 10011132/10011132 Part # Type 10011132 00 10011132 00 Extrusion Top Extrusion Bottom Accessories 10095529 08 Lid End Lid Description Extrusion only, bare Aluminum (sold by the meter) Extrusion only, bare Aluminum (sold by the meter) Unpainted Plate Lid w/screws for 11132/11132 Unpainted Plate Lid w/ screws & Wall Flange for 11132/11132 10093205 00 End Lid Screws 77003500 00 Bracket DIN Rail Bracket 10095535 08 Black Lid Screw M3x8 Two half-shell extrusions with integrated guide rails for 100 mm PC boards and exterior slots designed for optional 35 mm DIN Rail mounting bracket. Enclosure Profiles 50 www.Rose-Bopla.com Multitronic TS Build-A-Box® 10011133/10011132 Part # Type Description 10011133 00 Extrusion Top Extrusion only, bare Aluminum (sold by the meter) 10011132 00 Extrusion Bottom Extrusion only, bare Aluminum (sold by the meter) Accessories 10095152 08 10095536 08 10093205 00 77003500 00 Lid End Lid Screws Bracket Unpainted Plate Lid w/screws for 11133/11132 Unpainted Plate Lid w/ screws & Wall Flange for 11133/11132 Black Lid Screw M3x8 DIN Rail Bracket Two half-shell extrusions with integrated guide rails for 100 mm PC boards and exterior slots designed for optional 35 mm DIN Rail mounting bracket. Enclosure Profiles Multitronic TS Build-A-Box® 10011133/10011133 Part # Type Description 10011133 00 Extrusion Top Extrusion only, bare Aluminum (sold by the meter) 10011133 00 Extrusion Bottom Extrusion only, bare Aluminum (sold by the meter) Accessories 10095537 08 End Lid Unpainted Plate Lid with screws and Wall Flange for 11133/11133 10093205 00 Screws Black Lid Screw M3x8 Two half-shell extrusions with integrated guide rails for 100 mm PC boards and exterior slots designed for optional 35 mm DIN Rail mounting bracket. Enclosure Profiles For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 51 Custom Build-A-Box® • Aluminum electronic enclosures for telecommunications and measurement control technology • Sold by the meter and cut to custom lengths to meet design needs • Versions with flange mounting rails integrated into sides • Different lid versions depending on enclosure type • Integrated guide slots for PCBs Included in delivery Extrusion only. Sold by the meter. Technical Data Material Ingress Protection Temperature Resistance Bare aluminum extrusion Al Mg Si 0.5 IP 40 to EN 60529 (dustight) with aluminum plate lid IP 65 to EN 60529 (watertight) with die-cast aluminum lid -40°F to +212°F with aluminum plate lids -22°F to +176°F with die-cast aluminum lids Part Length Width Height P.C. Card Number Inches/mm Inches/mm Inches/mm Slot Sizes 07011100 00 39.37 / 1000 5.12 / 130 1.77 / 45 100 mm 07021100 00 39.37 / 1000 5.12 / 130 2.72 / 69 100 mm 07031100 00 39.37 / 1000 7.72 / 196 4.17 / 106 100 mm / 160 07051100 00 39.37 / 1000 4.09 / 104 3.31 / 84 100 mm / 80.5 07061100 00 39.37 / 1000 6.50 / 165 4.13 / 105 100 mm / 160 07071100 00 39.37 / 1000 7.68 / 195 6.55 / 166 160 mm / 189.5 07101102 00 39.34 / 1000 5.67 / 144 2.66 / 67 100 mm 07111102 00 39.37 / 1000 5.67 / 144 1.69 / 43 100 mm Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. All extrusions sold in 1 meter lengths. Accessories Description Dustight lid painted black with lid screws for 0701 Dustight lid unpainted with lid screws for 0701 Dustight lid painted with lid screws for 0702 Dustight lid unpainted with lid screws for 0702 Watertight lid painted with lid screws and gasket for 0711 Watertight lid unpainted with lid screws and gasket for 0711 Watertight lid painted with lid screws and gasket for 0710 Watertight lid unpainted with lid screws and gasket for 0710 Dustight wall mount lid painted with lid screws for 0703 Dustight wall mount lid unpainted with lids screws for 0703 Watertight die-cast lid painted with lid screws and gasket for 0703 Watertight die-cast lid unpainted with lid screws and gasket for 0703 Dustight lid painted with lid screws for 0705 Dustight lid unpainted with lid screws for 0705 Dustight wall mount lid painted with lid screws for 0705 Dustight wall mount lid unpainted with lid screws for 0705 Watertight die-cast lid painted with lid screws and gasket for 0705 Watertight die-cast lid unpainted with lid screws and gasket for 0705 Watertight wall mount die cast lid painted with lid screws and gasket for 0705 Watertight wall mount die cast lid painted with lid screws and gasket for 0705 Watertight die cast bezel lid with screws and gasket for 0705 Watertight die cast bezel lid with screws and gasket for 0705 Dustight lid painted with lid screws for 0706 Dustight lid unpainted with lid screws for 0706 Dustight wall mount lid painted with lid screws for 0706 Dustight wall mount lid unpainted with lid screws for 0706 Watertight die-cast lid painted with lid screws and gasket for 0706 Watertight die-cast lid unpainted with lid screws and gasket for 0706 Watertight wall mount die-cast lid painted with lid screws and gasket for 0706 Watertight wall mount die-cast lid unpainted with lid screws and gasket for 0706 Watertight die cast bezel lid painted with lid screws and gasket for 0706 52 Part Number 07019509 00 07019509 08 07029507 50 07029507 58 07110618 20 07110618 28 07100618 20 07100618 28 07038916 00 07038916 08 07031200 10 07031200 18 07059521 00 07059521 08 07059520 00 07059520 08 07051200 70 07051200 78 07051200 50 07051200 58 07051200 60 07051200 68 07069521 10 07069521 18 07069520 10 07069520 18 07061200 70 07061200 78 07061200 80 07061200 88 07061200 90 Description Part Number Watertight die-cast bezel lid unpainted with screws and gasket for 0706 Watertight die-cast membrane bezel lid painted with lid screws and gasket for 0706 Watertight die-cast membrane bezel lid unpainted with lid screws and gasket for 0706 Watertight die cast lid w/clear door & snap lock painted with lid screws and gasket for 0706 Watertight die cast lid w/clear door & key lock painted with lid screws, gasket and key for 0706 Watertight die cast membrane bezel lid w/clear pc door & side latch painted with screws and gasket for 0706 Dustight lid painted with lid screws for 0707 Dustight lid unpainted with lid screws for 0707 Dustight wall mount lid painted with lid screws for 0707 Dustight wall mount lid unpainted with lid screws for 0707 Watertight die cast lid unpainted with lid screws for 0707 Watertight die cast lid unpainted with lid screws and gasket for 0707 Wall mount die cast lid painted with lid screws and gasket for 0707 Watertight wall mount die-cast lid unpainted with lid screws and gasket for 0707 Watertight die-cast bezel lid painted with lid screws and gasket for 0707 Watertight die-cast bezel lid unpainted with lid screws and gasket for 0707 Watertight die-cast membrane bezel lid painted with lid screws and gasket for 0707 Watertight die-cast membrane bezel lid unpainted with lid screws and gasket for 0707 Watertight die-cast lid w/clear door & side latch painted with lid screws and gasket for 0707 Stainless steel lid screw M3 x 6 mm for 0701 and 0702 Phillips head screw for watertight lid, M4x18 mm for 0711, 0710, 0703, 0705, 0706, 0707 Slotted countersink screw for dustight lid, M4x6mm for 0703, 0705, 0706, 0707 Table feet (sold as each) 07061200 98 07061200 00 07061200 08 07061200 91 07061200 92 07808003 50 07079521 20 07079521 28 07079520 20 07079520 28 07071201 30 07071201 38 07071201 10 07071201 18 07071201 20 07071201 28 07071201 40 07071201 48 07808004 50 10093032 00 10093270 00 10093212 00 10094102 00 www.Rose-Bopla.com Custom Build-A-Box® 0701 Description Part # Type 07011100 10 Extrusion Extrusion only, bare Aluminum (sold by the meter) Accessories 07019509 00 07019509 08 10093032 00 10094102 00 End Lid End Lid Screws Table Feet Dustight Lid–plate Aluminum, painted black, with lid screws Dustight Lid–plate Aluminum, unpainted, with lid screws Stainless Steel Lid Screw M3x6 mm Table Feet (sold as each) 105 101 96 45 1.5 10 130 Enclosure Profile Custom Build-A-Box® 0702 Part # Type Description 07021100 20 Extrusion Extrusion only, bare Aluminum (sold by the meter) Accessories 07029507 50 End Lid Dustight Lid–plate Aluminum, painted black, with lid screws 07029507 58 End Lid Dustight Lid–plate Aluminum, unpainted, with lid screws 10093032 00 Screws Stainless Steel Lid Screw M3x6 mm 10094102 00 Table Feet Table Feet (sold as each) 105 101 96 130 Enclosure Profile For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 53 Custom Build-A-Box® 0711 Part # 07111102 40 Description Type Extrusion only, bare Aluminum, (sold by the meter) Extrusion Accessories 07110618 20 End Lid Watertight Die-cast Lid–Aluminum, painted black, with lid screws and gasket 07110618 28 End Lid Watertight Die-cast Lid–Aluminum, unpainted, with lid screws and gasket 10093270 00 Screws Phillips Head Screw for Watertight Lid M4x18 mm 10094102 00 Table Feet Table Feet (sold as each) 2.3 5.08 9.4 3 9 12 Die-cast Lid Enclosure Profile Custom Build-A-Box® 0710 Part # 07101102 30 Type Description Extrusion Extrusion only, bare Aluminum (sold by the meter) Accessories 07100618 20 End Lid Watertight Die-cast Lid–Aluminum, painted black, with lid screws and gasket 07100618 28 End Lid Watertight Die-cast Lid–Aluminum, unpainted, with lid screws and gasket 10093270 00 Screws Phillips Head Screw for Watertight Lid M4x18 mm 10094102 00 Table Feet Table Feet (sold as each) 2.3 5.08 11.5 3 9 12 Die-cast Lid Enclosure Profile 54 www.Rose-Bopla.com Custom Build-A-Box® 0703 Part # 07031100 30 Type Extrusion Description Extrusion only w/side flanges top and bottom–bare Aluminum (sold by the meter) Accessories 07038916 00 End Lid Dustight Wall Mount Lid–plate Aluminum, painted black, with lid screws 07038916 08 End Lid Dustight Wall Mount Lid–plate Aluminum, unpainted, with lid screws 07031200 10 07031200 18 End Lid End Lid Watertight Die-cast Lid–Aluminum, painted black, with lid screws and gasket Watertight Die-cast Lid–Aluminum, unpainted , with lid screws and gasket 10093212 00 10093270 00 Screws Slotted Countersink Screw for Dustight Lid M4x6mm Screws Phillips Head Screw for Watertight Lid M4x18mm 10094102 00 Table Feet Table Feet (sold as each) Enclosure Profile For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 55 Custom Build-A-Box® 0705 Part # Type 07051100 50 Extrusion Description Extrusion only–bare Aluminum, (sold by the meter) Accessories 07059521 00 Lid Dustight Lid–plate Aluminum, painted jet black similar to RAL 9005, with lid screws 07059521 08 Lid Dustight Lid–plate Aluminum, unpainted, with lid screws 07059520 00 Lid Dustight Wall Mount Lid–plate Aluminum, painted jet black similar to RAL 9005, with lid screws 07059520 08 Lid Lid Dustight Wall Mount Lid–plate Aluminum, unpainted, with lid screws Watertight Die-cast Lid–Aluminum, unpainted, with lid screws and gasket 07051200 50 Lid Lid 07051200 58 Lid 07051200 60 Lid Watertight Wall Mount Die-cast Lid–unpainted, with lid screws and gasket Watertight Die-cast Bezel Lid–Aluminum, painted jet black similar to RAL 9005, with lid screws and gasket 07051200 68 Lid Watertight Die-cast Bezel Lid–Aluminum, unpainted, with lid screws and gasket 10093212 00 Screw Slotted Countersink Screw for Dustight Lid M4x6mm 10093270 00 Screw Screw for Watertight Lid M4x18mm 07051200 70 07051200 78 Watertight Die-cast Lid–Aluminum, painted jet black similar to RAL 9005, with lid screws and gasket Watertight Wall Mount Die-cast Lid–Aluminum, painted jet black similar to RAL 9005, with lid screws and gasket 10094102 00 Table Feet Table Feet (sold as each) Enclosure Profile 56 Corner Detail www.Rose-Bopla.com Custom Build-A-Box® 0706 Part # Type 07061100 60 Extrusion Description Extrusion only–bare Aluminum (sold by the meter) Accessories 07069521 10 Lid Dustight Lid-plate Aluminum, painted jet black similar to RAL 9005, with lid screws 07069521 18 Lid Dustight Lid-plate Aluminum, unpainted, with lid screws 07069520 10 Lid 07069520 18 Lid 07061200 70 Lid Dustight Wall Mount Lid-plate Aluminum, painted jet black similar to RAL 9005, with lid screws Dustight Wall Mount Lid-plate Aluminum, unpainted with screws Watertight Die-cast Lid-Aluminum painted jet black similar to RAL 9005, with lid screws and gasket 07061200 78 Lid 07061200 80 Lid 07061200 88 Lid 07061200 90 Lid Watertight Die-cast Lid-Aluminum, painted jet black similar to RAL 9005, with lid screws and gasket 07061200 98 Lid Watertight Die-cast Bezel Lid-Aluminum, unpainted, with lid screws and gasket 07061200 00 Lid Watertight Die-cast Membrane Bezel Lid-Aluminum, painted jet black similar to RAL 9005, with lid screws and gasket 07061200 08 Lid Watertight Die-cast Membran Bezel Lid-Aluminum, unpainted, with lid screws and gasket 07061200 91 Lid Watertight Die-cast Lid/w Clear Door & Snap Lock-Aluminum, painted jet black similar to RAL 9005, with lid screws and gasket 07061200 92 Lid Watertight Die-cast Lid w/Clear Door & Key Lock-Aluminum, painted jet black similar to RAL 9005, with lid screws, gasket and key 07808003 50 Lid Watertight Die-cast Membrane Bezel Lid with Clear PC Door & Side Latch-Aluminum Lid painted jet black similar to RAL 9005, with lid screws and gasket 10093212 00 Screw Slotted Countersink Screw for Dustight Lid M4x6mm Screw Lid Screw for Watertight Lid M4x18mm 10093270 00 10094102 00 Watertight Die-cast Lid-Aluminum, unpainted with lid screws and gasket Watertight Wall Mount Die-cast Lid-Aluminum, painted jet black similar to RAL 9005, with lid screws and gasket Watertight Wall Mount Die-cast-Aluminum, unpainted, with lid screws and gasket Table Feet Table Feet (Sold as each) Enclosure Profile Corner Detail For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 57 Custom Build-A-Box® 0707 Part # Type 07071100 70 Extrusion Description Extrusion only–bare Aluminum (sold by the meter) Accessories 07079521 20 07079521 28 07079520 20 07079520 28 Lid Lid Lid Lid Dustight Lid-plate Aluminum, painted jet black similar to RAL 9005, with lid screws Dustight Lid-plate Aluminum, unpainted, with lid screws Dustight Wall Mount Lid-plate Aluminum, painted jet black similar to RAL 9005, with lid screws Dustight Wall Mount Lid-plate Aluminum, unpainted, with lid screws 07071201 30 Lid Watertight Die-cast Lid-Aluminum, painted jet black similar to RAL 9005, with lid screws and gasket 07071201 38 Lid Watertight Die-cast Lid-Aluminum, unpainted with lid screws and gasket 07071201 10 Lid Watertight Wall Mount Die-cast Lid-Aluminum, painted jet black similar to RAL 9005, with lid screws and gasket 07071201 18 Lid Watertight Wall Mount Die-cast Lid-Aluminum, unpainted, with lid screws and gasket 07071201 20 Lid Watertight Die-cast Bezel Lid-Aluminum, painted jet black similar to RAL 9005, with lid screws and gasket 07071201 28 Lid Watertight Die-cast Bezel Lid-Aluminum, unpainted, with lid screws and gasket 07071201 40 Lid Watertight Die-cast Membrane Bezel Lid-Aluminum, painted jet black similar to RAL 9005, with lid screws and gasket 07071201 48 Lid Watertight Die-cast Membrane Bezel Lid-Aluminum, unpainted, with lid screws and gasket 07808004 50 Lid Watertight Die-cast Lid w/Clear Door & Side Latch-Aluminum, painted jet black, similar to RAL 9005, with lid screws and gasket 10093212 00 Screw Slotted Countersink Screw for Dustight Lid M4x6mm 10093270 00 Screw Lid Screw for Watertight Lid M4x18mm 10094102 00 Table Feet Table Feet (Sold as each) Enclosure Profile 58 Corner Detail www.Rose-Bopla.com Profitronic • Aluminum electronic enclosures, chassis fittings in three sizes • Variable length options using profile technology • Standard construction or version with connection compartment • Optional Polycarbonate transparent cover Included in delivery Enclosure system - depending on version, either with cast aluminum lids, connection compartment, or transparent cover; please order mounting elements separately. Technical Data Material Ingress Protection Opening Angle Temperature Resistance Al Mg Si 0.5; connection compartment AlSi12 IP 65 EN 60529 For connection compartments and transparent covers 110° Lid seals -40°F to + 212°F Transparent cover -40° to +158°F; only suitable for external applications Plastic resin stove-enamel finish Light gray, similar to RAL 7035 - enclosure body and connection compartment Stone gray, similar to RAL 7030 - enclosure lid and external fittings Special colors on request Surface Resistance Color Type 19TE 28TE 42TE Part Number Part Number Front Panel 19" Mounting Frame Lid with Transparent Cover Enclosure with connection compartment Standard (63.5 mm) Part Number 19" Mounting Frame 07191100 00 07281100 00 07421100 00 07192100 00 07282100 00 07422100 00 07193100 00 07283100 00 07423100 00 Part Number Front Panel Lid and Transparent Cover Dimensions* mm Dimensions* Inches WxLxH WxLxH 07193300 00** 07283300 00** 07423300 00** 07192300 00 07282300 00 07422300 00 148 x 236 x 241 191 x 236 x 241 265 x 236 x 241 5.83 x 9.29 x 9.49 7.52 x 9.29 x 9.49 10.43 x 9.29 x 9.49 07193301 00** 07283301 00** 07423301 00** 07192301 00 07282301 00 07422301 00 148 x 276 x 241 191 x 276 x 241 265 x 276 x 241 8.53 x 10.87 x 9.49 7.52 x 10.87 x 9.49 10.43 x 10.87 x 9.49 - - 148 x 235 x 149 191 x 235 x 149 265 x 235 x 149 5.83 x 9.25 x 5.87 7.52 x 9.25 x 5.87 10.43 x 9.25 x 5.87 Part Number Front Panel Lid Enclosure with connection compartment Standard (63.5 mm) 19TE 28TE 42TE 07192101 00 07282101 00 07422101 00 07191101 00 07281101 00 07421101 00 07193101 00 07283101 00 07423101 00 Enclosure with connection compartment Standard (63.5 mm) 19TE 28TE 42TE 07191200 00 07281200 00 07421200 00 *Length without lid 07192200 00 07282200 00 07422200 00 07193200 00 07283200 00 07423200 00 ** Enclosure length is equal to connection compartment depth Accessories External mounting for enclosure with connection compartment (set of 2) External mounting for enclosures without connection compartment (set of 2) Special lock with socket wrench for connection compartment (mounted) Turning handle for transparent cover (mounted) Cylinder lock, for transparent cover (mounted) Board guides for PCB’s, fixed (set of 10) Board guides for PCB’s; variable (set of 10) Insulating strip to fix bus boards (set of 2) Aluminum profile (Z rails) to fix connector bars (set of 2) Mounting plate for connection compartment Type 0719 0728 0742 Type 0719 0729 0742 Type 0719 0728 0742 Self-adhesive table feet (set of 4) Mounting feet (2 pieces) For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 Part Number 07000100 00 07000200 00 07000017 00 07000018 00 07000019 00 07000010 00 07000011 00 07190020 00 07280020 00 07420020 00 07190010 00 07280010 00 07420010 00 07190030 00 07280030 00 07420030 00 10070018 00 07700081 00 59 Profitronic Universal • Aluminum electronic enclosures, chassis fittings in three sizes • Variable length options using profile technology • Standard construction or version with connection compartment • Optional Polycarbonate transparent cover Included in delivery Enclosure system - depending on version either with cast aluminum lids, connection compartment or transparent cover; please order mounting elements separately. Technical Data Material Ingress Protection Opening Angle Temperature Resistance Surface Resistance Color Type Al Mg Si 0.5; connection compartment AlSi12 IP 65 EN 60529 For connection compartments and transparent covers 110° Lid seals -40°F to + 212°F Transparent cover -40° to +158°F; only suitable for external applications Plastic resin stove-enamel finish Light gray, similar to RAL 7035 - enclosure body and connection compartment Stone gray, similar to RAL 7030 - enclosure lid and external fittings Special colors on request Part Number 19" Mounting Frame with Transparent Cover Dimensions mm WxLxH Dimensions Inches WxLxH Part Number Front Panel Lid Dimensions mm WxLxH Dimensions Inches WxLxH 148 x 285 x 241 191 x 285 x 241 265 x 185 x 241 5.83 x 11.22 x 9.49 7.52 x 11.22 x 9.49 10.43 x 11.22 x 9.49 07193111 00 07283111 00 07423111 00 148 x 280 x 241 191 x 280 x 241 265 x 200 x 241 5.83 x 11.02 x 9.49 7.52 x 11.02 x 9.49 10.43 x 11.02 x 9.49 148 x 263.5 x 149 191 x 263.5 x 149 265 x 263.5 x 148 5.83 x 10.15 x 5.87 7.52 x 10.18 x 5.87 10.43 x 10.18 x 5.87 17193211 00 07283211 00 07423211 00 148 x 258.5 x 149 191 x 258.5 x 149 265 x 258.5 x 149 5.83 x 10.18 x 5.87 7.52 x 10.18 x 5.87 10.43 x 10.18 x 5.87 Enclosure with connection compartment (63.5 mm) 19TE 28TE 42TE 07192111 00 07282111 00 07422111 00 Enclosure without connection compartment 19TE 28TE 42TE 07192211 00 07282211 00 07422211 00 Accessories External mounting for enclosure with connection compartment (set of 2) External mounting for enclosures without connection compartment (set of 2) Special lock with socket wrench for connection compartment (mounted) Turning handle for transparent cover (mounted) Cylinder lock, for transparent cover (mounted) Board guides for PCB’s, fixed (set of 10) Board guides for PCB’s; variable (set of 10) Mounting plate for connection compartment Self-adhesive table feet (set of 4) Mounting feet (2 pieces) 60 Type 0719 0728 0742 Part Number 07000100 00 07000200 00 07000017 00 07000018 00 07000019 00 07000010 00 07000011 00 07190030 00 07280030 00 07420030 00 10070018 00 07700081 00 www.Rose-Bopla.com ANG Panel Meter Housing • First DIN panel meter housing on the market with NEMA 4x protection • Constructed from hollow extrusion of heavy duty aluminum with internal slotting to accomodate printed circuit boards or chassis. Included in delivery Enclosure body, mounting profiles, bezel, front frame, rear lid, 1.5 allen key, adhesive plate, screws and washers. Technical Data Color Material Protection Classifications Black powdercoat Extruded aluminum NEMA 4X IP 66, DIN 40050 Part Number Dimensions mm ANG 9610 ANG 9616 ANG 9601 109.5 x 96 x 96 165.5 x 96 x 96 Sold in one meter lengths LxWxH Dimensions Inches LxWxH 4.31 x 3.77 x 3.77 6.51 x 3.77 x 3.77 Sold in one meter lengths Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Part Number ANG 96 MPI ANG 96 BZ ANG 96 FF ANG 96 RL SST 1230 NG Description Aluminum mounting rail Front bezel Front open frame Rear cover Replacement screws (set of 8) For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 61 Instrumentation Electronic systems are not made for the enclosures that house them; rather the enclosures are made to hold the electronics. For this reason, Bopla offers designers modular enclosures. These enclosure systems are offered in many diverse sizes with a wide range of possibilities for variation. This allows the individual design to come to life. Electronic device manufacturers look for “packaging” that meets their requirements with regard to design and technology so that the ultimate product can effectively answer the demands of the market. The “package”, in this case, an enclosure made of plastic or metal, is of tremendous importance to the marketability of the device. Technical characteristics, price/performance comparisons, and the appearance of the product can prove central to its success. The extremely broad spectrum of different modular enclosure systems from Bopla represents a remarkable selection of “standards” that can be individualized. CombiCard 5000-7000 - 3 versions with dimensions from 175.7 mm to 323 mm for the front length Intercard - 1 version with dimensions from 212 x 198 x 162.5 mm CombiSet - 4 versions with dimensions from 224.5 to 252 mm CombiNorm Classic -2 versions with dimensions from 100 x 109.5 x 75 mm to 22.5 x 109.5 x 75 mm CombiNorm Compact - 3 versions with dimensions from 19 x 110 x 75 mm to 26 x 110 x 75 mm CombiCard 1000-3000 - 3 versions with dimensions from 134 mm to 288 mm for the front length Executive Plug Housings - 7 versions with dimensions from 125 x 37 mm with height from 15 to 35 mm SE 4 & SE 5 Plug Housings -2 versions with dimensions from 65 x 50 x 30 to 120 x 65 x 66 mm 62 www.Rose-Bopla.com Alurail • Modular DIN rail enclosure for use in measurement, control, and automation control technology • Individual design of the enclosure construction is made possible by attaching different module types in various lengths onto the basic profile • Basic profiles and modules equipped with integrated guide grooves for PCBs Included in delivery Profiles sold in meter lengths. Other components sold individually. See below for details. Technical Data Material Ingress Protection Flammability Surface Resistance (caps) Ingress Protection Color Profiles: Extruded aluminum profile, Al Mg Si 0.5; Profile caps: Polyamide 6.6 FR Up to IP 40/DIN EN 60529, depending on enclosure construction UL 94 V0/1 >1015 Ohm to DIN 53482 Up to IP 40/DIN EN 60529 depending on the enclosure construction Aluminum profile: anodized Profile caps: light gray, similar to RAL 7035 Special colors on request. Minimum quantities apply. Model Number Basic Profiles Part Number Basic Profiles Dimensions mm LxW Dimensions mm LxW Model Number Module Profiles Part Number Module Profiles Dimensions mm LxWxH ARP 75/31-1000 ARP 105/31-1000 87010000 00 87020000 00 990.0 x 75.0 990.0 x 105 39.00 x 2.95 39.00 x 4.13 ARPM 45/27-1000 ARPM 75-42-1000 87110000 00 87110000 00 990 x 45 x 27.5 990 x 75 x 42.5 Part Number Split Module Profiles 87120000 00 Dimensions mm LxH 990 x 27.5 Model Number Split Basic Profiles ARPG 75/31-1000 Part Number Split Basic Profiles 87030000 00 Dimensions mm LxW 990 x 75 Dimensions Inches LxW 39.00 x 2.95 Model Number Split Module Profiles ARPMG 00/27-1000 Dimensions mm LxWxH 39.00 x 2.95 x 1.08 39.00 x 2.95 x 1.67 Dimensions Inches LxH 39.00 x 1.08 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Model Number Accessories AR...KS Profile caps (Includes 2 side panels, 4 assembly screws, 1 snap-on element, 1 positioning screw for snap-on element) ARM...FP Module front panels (Includes 1 anodized front panel) AR...-KS-AL Side panels, aluminum (Includes 2 side panels, 4 assembly screws, 1 snap-on element, 1 positioning screw for snap-on element) ARPM... Module profiles for attaching to the basic profile (Includes 1 enclosure profile) ARPMG 00/... Split module profiles for attaching to the basic profile (Includes 2 aluminum profiles) ARM... Module caps (Includes 2 module profile caps, 4 assembly screws, 2 mounting screws) ARM...FP Module front panels (Includes 1 anodized front panel) Module bridges for attaching the module profiles onto the basic profiles (required if basic profile and module profile are of different lengths. Includes 5 modules bridges, 10 assembly screws) AR...MB AR...WB Wall mounting set (Includes 2 wall-mount elements) AR-E Grounding set (Includes ground claws 5 pieces) AR-R Snap-on element (Includes snap-on elements, positioning screws, 5 pieces) For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 63 CombiCard 5000-7000 • Modular construction ensures that the demands made of a future-oriented enclosure system are satisfied in the best possible way • Hinge system design and the possibility of installing prefabricated mounting racks minimize assembly times • User-defined access protection • Double clamp area permits easy, clean wiring with a large number of cable entries Included in delivery Modular product sold by individual components. See below for details. Technical Data Color Fronts and bases light gray, similar to RAL 7035. Clear front lid, G-version; side covers light gray, similar to RAL 7035. Rear parts agate gray, similar to RAL 7038 Special colors on request. Minimum quantities apply. ABS, except FD...G (clear polycarbonate) Neoprene IP 66 (IP 30 with ventilation) / DIN EN 60529, NEMA 4, 4X ABS, >1014 Ohm to DIN 53482 Polycarbonate, >1015 Ohm to DIN 53482 Polycarbonate 28KV/mm to DIN 53481 Polycarbonate: UL 94 V2/1.14. ABS: UL 94 HB/1.6 up to +167°F Material Gasket Material Ingress Protection Surface Resistance Disruptive Strength Flammability Temperature Range Model Number Front Length mm Front Length Inches Front Height mm Front Height Inches TE (x 5.08) HE (x 44.45) 5000 6000 7000 175.7 226.5 323.0 6.92 8.92 12.72 146.7 146.7 146.7 5.77 5.77 5.77 20 30 49 3 3 3 Dimensions without lid Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. For complete information and part numbers please see website. www.rose-bopla.com Model Front lids, clear Quick-release fastenings Lock cover Lock Front frames, open Front frame, closed Rear sections with/without terminal compartment FD FR FO BC RD • • • • • • • • • • Components Part Number FD...(G) FR... FO... BC...(L) - 0.5 BC...(L) - 1 BC...(L) - 1.5 BC...NG(L) RD/RDK Accessories FP...I/AI M... / K / BK WL... / K / BK SR 5670 - 0.5/-1/-1.5 VA 5670 SV 5670 2 BS 5670 64 Version Front lids, clear (Includes: front lid with seal, 2 mounting locks, 1 blind plug, 1 catch) Front frames, closed (Includes: front frame with seal, 2 snap-on covers, 4 assembly screws) Front frames, open (Includes: front frame with seal, 2 snap-on covers, 4 assembly screws, 10 front panel assembly screws) Bases - 0.5 (51.51 mm) construction depth (Includes: BC_000.0.5, base with seal, 2 mounted lockes. BC_000 L-0.5, base with air vents without seal, 2 mounted locks Bases - 1 (88.25mm) construction depth (Includes: BC_000-1, base with seal, 2 mounted locks. BC_000 L-1, base with air vents without seal, 2 mounted locks Bases - 1.5 (139.76 mm) construction depth (ncludes, BC_0001.5, base with seal, 2 mounted locks. BC_000 L-1.5, base with air vents without seal, 2 mounted locks) Base NG (control panel mounting) (Includes: base including mounted set of elements for control panel mounting) Rear sections with/without terminal compartments (Includes: RD - rear section, RDK - rear section, terminal compartment bar, terminal compartment cover including seal and assembly screws. Depth Depth mm Inches 1.34 34 1.34 34 1.34 34 51.1 88.25 139.76 68 50 2.01 3.47 5.50 2.68 1.97 Front panels Mounting plates for RD...,BC...(L)-...RD...K, RD...BK Wall bracket Set of catches Quick release fastening hinge (2 pieces) Lock cover / hinged quick-release fastening (Includes: 1 catch, 1 blind plug) Assembly kit www.Rose-Bopla.com CombiCard 1000-3000 • Gives the user almost infinite possibilities for the optimal integration of individual electronic components • Can be used as a desktop, wall or control panel mounted enclosure • Mountable hinges mean that separate parts can be swiveled as required Included in delivery Modular product sold by individual components. See below for details. Technical Data Base parts, light gray, similar to RAL 7035; front lid in G-version, crystal clear, front and rear parts, graphite gray, similar to RAL 7024. Special colors on request. Minimum order quantities apply. ABS, polycarbonate front lids (FD...G), for standard product Neoprene IP 65 DIN VDE 0470, NEMA 12 ABS, >1014 Ohm to DIN 53482, Polycarbonate, >1015 Ohm to DIN 53482 Polycarbonate 28KV/mm to DIN 53481 ABS, UL 94 HB/1.6, Polycarbonate, UL 94 V2/1.14 up to +167°F Color Material Gasket Material Ingress Protection Surface Resistance Disruptive Strength Flammability Temperature Range Model Front Length mm Front Length Inches Front Height Inches Front Height Inches 1000 2000 3000 134 184 281 5.27 7.24 11.06 144 144 144 5.67 5.67 5.67 Dimensions without lid Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. For detailed information and part numbers see website. www.rose-bopla.com Part Number Prefix Model FD Front lids Front frames, closed Front frames, open Front frames, open, with protective door Front panels Bases for control and mounting Rear lids, low/tall FR FO FCT • FA BC RD • • • • • • • • Depth mm Depth Inches Front lids with screws Front frames, closed with screws Front frames, open, screws Front frames, open, with protective door and screws 34 33.6 33.6 50 1.34 1.32 1.32 1.97 BC... -base, without air vents includes seal. BC...(L) with air vents, no seal. Bases, low with seal including integrated fixing kit for control panel mounting Bases for control panel mounting, (Includes base part with seal and integrated mounting kit for control panel mounting 87.5 51 87.5 3.44 2.00 3.44 Model Number Version Front Sections FD... FR... FO... FCT...F(P) Bases BC...(L) BC...N BC...NG Rear Lids RD... RD...H(SC) RD...K(SC) RD...G-K(SC) 1.16 29.6 Rear lids, low with seal, screws 1.89 48 RD...H-rear lid, tall with seal screws. RD...H(SC)-rear lid, tall with seal, hinges, and assembly material RD...K-rear lid, terminal compartments cover, seals, screws. RD...K(SC)-rear lid, terminal compartment 48-60 1.89-2.36 cover,seals, screws, hinge elements and assembly material Rear lids with large terminal compartment 48-60 1.89-2.36 G=Transparent cover P=Open L=With air vents K=Terminal compartment SC=With hinges Accessories Model Number WR... WR...H FP..AI FP..AA FA... FA...I MR... MR...K HS... Version Wall frame Wall frames for low/high rear parts Internal aluminum front panels (assembly material included with FO... and FCT...FP) External aluminum front panels (including assembly material) Aluminum front panels for base parts (including assembly material) Internal mounting plate for base parts in combination with front element (including assembly material) Mounting plate for rear wall (includind assembly material) Mounting plate for rear wall lid with terminal compartment (including assembly material) Handle For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 65 InterCard • Horizontal and vertical insertion slots for PCBs • Door hinge system can be mounted on the right or left side • Wall mounting (three-or four-point) is outside the sealed lip, so it does not affect the ingress protection IP 65 • Terminal compartment covers locks in the open position Included in delivery Base, hinged clear lid, mounted with snap lock; terminal compartment cover; screws; threaded inserts for mounting plates. Technical Data Color Light gray, similar to RAL 7035. Special colors available on request. Minimum order applies. ABS, clear Polycarbonate lid. Neoprene up to 167°F IP 65 / DIN EN 60529 ABS, >1014 Ohm to DIN 53482. Polycarbonate, >1015 Ohm to DIN 53482 Polycarbonate, 28 KV/mm to DIN 53481 ABS, UL 94 HB/1.6. Polycarbonate, UL 94 V2/1.14 Material Gasket Temperature Range Ingress Protection Surface Resistance Disruptive Strength Flammability Model Part Number Length mm Length Inches Height mm Height Inches Depth mm Depth Inches IC 5000 07500000 00 198 7.79 212 8.35 162.5 6.40 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Type SHLO-302 MP 5000 FA 5000 66 Version Cylinder catch Mounting plate, screws Front panel, screws Part Number 21008310 00 27450000 00 27350000 00 www.Rose-Bopla.com CombiSet • Ideal for mounting individual PCBs or cassettes in installation widths up to 12 TE • NG version with the wraparound molded covering frame can be installed in control panels • With lockable clear lid, this enclosure provides ingress protection IP 65 Included in delivery All models: Base and rear section, upper and lower guide grids, tapped strips and screws. CC...TK includes hinged clear door with knob. CC...NG includes molded-on installation frame on the base and retaining clasps. CC... NGTK additionally includes hinged clear door with knob. Technical Data Color Base, light gray, similar to RAL 7035; rear part, graphite gray, similar to RAL 7024; front door clear. Special colors available on request. Minimum order quantities apply. ABS, clear Polycarbonate front door Neoprene For version CC 500 TK/NGTK: IP 65 / DIN EN 60529, NEMA 12 ABS, >1014 Ohm to DIN 53482, Polycarbonate >1015 Ohm to DIN 53482 Polycarbonate, 28KV/mm to DIN 53481 ABS, UL 94 HB/1.6. Polycarbonate, UL 94 V2/1.14 up to 167°F Material Gasket Ingress Protection Surface Resistance Disruptive Strength Flammability Temperature Resistance Model Number CC 500 CC 500 TK CC 500 NG CC 500 NGTK Part Number 19050000 00 19050101 00 19050200 00 19050301 00 Version Desktop / wall / rail enclosure Desktop / wall / rail enclosure with door / ingress protection IP 65 Control panel mounting enclosure Control panel mounting enclosure with door Dimension mm WxHxD Dimensions Inches WxHxD 68 x 136 x 224.5 68 x 136 x 252.5 72 x 144 x 224.5 72 x 144 x 252.5 2.68 x 5.35 x 8.83 2.68 x 5.35 x 9.94 2.83 x 5.67 x 8.34 2.83 x 5.67 x 9.94 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Model Number CC 500 WR CC 500 MS CC 500 TS SHLO - 302 KF 1230 KS 1230 Part Number 39001000 00 39004000 00 39005000 00 21009310 00 39302000 00 39301000 00 Version Wall frame Mounting kit for DIN EN 60603-2 plug-in connector (previously DIN 41612) Rail snap foot for top hat rail DIN EN 60715 TH 35 Cylinder lock catch Card guides (10 pieces) Card securing devices (10 pieces) For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 67 CombiNorm Compact • Optimal PCB utilization because the unit PCB is inserted from the side • The right angled shape of the soldering pins makes it possible to mount terminals with components in one soldering process • Latching of the shell and lid can take place on automated machines because of the special snap trim Included in delivery Shell only. Lid and accessories must be ordered separately Technical Data Color Material Flammability Surface Resistance Ingress Protection Light gray, similar to RAL 7035. Special colors or request. Minimum order quantities apply. Polyamide 6,6 FR, front flap crystal clear polycarbonate UL 94 V0/1 >1015 Ohm to DIN 53482 IP 40 to DIN EN 60529 for complete enclosure without ventilation. IP 30 to DIN EN 60529 for complete enclosure with ventilation IP 20 to DIN EN 60529 for terminals Model Part Number Version Dimension mm WxLxH CN 19 GU CN 22 GU CN 26 GU CN-DU CN 19 GU-L CN 22 GU-L CN 26 GU-L CN 19 GK CN 22 GK CN 26 GK CN 19 GK-L CN 22 GK-L CN 26 GK-L CN-DK 65019000 00 65022000 00 65026000 00 65000100 00 65019010 00 65022010 00 65026010 00 65019100 00 65022100 00 65026100 00 65019110 00 65022110 00 65026110 00 65000200 00 Enclosure shell, universal Enclosure shell, universal Enclosure shell, universal Enclosure lid, universal Enclosure shell, universal, with air vents (on request) Enclosure shell, universal, with air vents (on request) Enclosure shell, universal, with air vents (on request) Enclosure shell, contoured Enclosure shell, contoured Enclosure shell, contoured Enclosure shell, contoured, with air vents Enclosure shell, contoured, with air vents Enclosure shell, contoured, with air vents Enclosure lid, contoured 19 x 110.8 x 75 22 x 110.8 x 75 26 x 110.8 x 75 19/22/26 x 110.8 x 75 19 x 110.8 x 75 22 x 110.8 x 75 26 x 110.8 x 75 19 x 110.8 x 75 22 x 110.8 x 75 26 x 110.8 x 75 19 x 110.8 x 75 22 x 110.8 x 75 26 x 110.8 x 75 19/22/26 x 110.8 x 75 Dimensions Inches WxLxH 0.75 x 4.36 x 2.95 0.87 x 4.36 x 2.95 1.03 x 4.36 x 2.95 0.75/0.87/1.03 x 4.36 x 2.95 0.75 x 4.36 x 2.95 0.87 x 4.36 x 2.95 1.03 x 4.36 x 2.95 0.75 x 4.36 x 2.95 0.87 x 4.36 x 2.95 1.03 x 4.36 x 2.95 0.75 x 4.36 x 2.95 0.87 x 4.36 x 2.95 1.03 x 3.97 x 2.95 0.75/0.87/1.03 x 4.36 x 2.95 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Model CN 19 FP CN 22 FP CN 26 FP CN 19 FK CN 22 FK CN 26 FK CN 19 FKG CN 22 FKG CN 26 FKG AK 8191/2DL AK 8191/2DR AK 8191/3DL AK 8191/3DR CN-BL1 CN-BL2 CN-WA CN-BZ Part Number 65019500 00 65022500 00 65026500 00 65019600 00 65022600 00 65026600 00 65019700 00 65022700 00 65026700 00 66000052 00 66000062 00 66000072 00 66000082 00 66000032 00 66000042 00 66000012 00 66000022 00 Version Front panel, plug-in Front panel, plug-in Front panel, plug-in Front flap, snap-on Front flap, snap-on Front flap, snap-on Front flap, clear, snap-on Front flap, clear, snap-on Front flap, clear, snap-on Connection terminals, 2-pole, on left of component side (seen from front), PCB vertical Connection terminals, 2-pole, on right of component side (seen from front), PCB vertical Connection terminals, 3-pole, on left of component side (seen from front), PCB vertical Connection terminals, 3-pole, on right of component side (seen from front), PCB vertical Blind piece, 1-pole, for unused terminal locations Blind piece, 2-pole, for unused terminal locations Wall adapter for mounting single enclosures to wall Marking plate for clipping onto upper and lower section of enclosure front Dimensions Width mm 19 22 26 19 22 26 19 22 26 19 - 26 19 - 26 22 - 26 22 - 26 19 - 26 19 - 26 19 - 26 19 - 26 Dimensions Width Inches 0.75 0.87 1.02 0.75 0.87 1.02 0.75 0.87 1.02 0.75 - 1.02 0.75 - 1.02 0.87 - 1.02 0.87 - 1.02 0.75 - 1.02 0.75 - 1.02 0.75 - 1.02 0.75 - 1.02 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. 68 www.Rose-Bopla.com CombiNorm Classic • 5-width enclosure program for 35 mm rail unit can be adapted to suit specific requirements by means of 4 different terminal types (PCB = variations) which, in some cases, can be combined outside a unit • Lower part can be supplied with an adjusting flap on the upper side (type CNS...) that permits subsequent access to the electronic parts, e.g. for adjustment purposes • Clear hood covers provide optimal protection for the operating fronts against dirt, unauthorized access (lead seal) and unintentional terminal operation • Front lids are membrane-keypad ready Included in delivery CN: Base, lid, mounted latch for rail fitting CNS: Base, lid adjusting flap, mounted latch for rail fitting Technical Data Color Material Flammability Surface Resistance Ingress Protection Model CN 22 AK CN 45 AK CN 55 AK CN 70 AK CN 100 AK CNS 22 AK CNS 45 AK CNS 55 AK CNS 70 AK CNS 100 AK Light gray, similar to RAL 7035. Special colors or request. Minimum order quantities apply. ABS UL 94 HB/1.6 >1014 Ohm to DIN 53482 IP 40 to DIN EN 60529 Part Number 65002210 00 65004510 00 65005510 00 65007010 00 65010010 00 65002230 00 65004530 00 65005530 00 65007030 00 65010030 00 Dimensions mm WxLxH Version Small control enclosure for max. 8 terminals Small control enclosure for max. 16 terminals Small control enclosure for max. 20 terminals Small control enclosure for max. 26 terminals Small control enclosure for max. 138 terminals Small control enclosure for max. 8 terminals with adjustable flap, included Small control enclosure for max. 16 terminals with adjustable flap, included Small control enclosure for max. 20 terminals with adjustable flap, included Small control enclosure for max. 26 terminals with adjustable flap, included Small control enclosure for max. 138 terminals with adjustable flap, included 22.5 x 109.5 x 75 45.0 x 109.5 x 75 55.0 x 109.5 x 75 70.0 x 109.5 x 75 100.0 x 109.5 x 75 255.0 x 109.5 x 75 45.0 x 109.5 x 75 55.0 x 109.5 x 75 70.0 x 109.5 x 75 100.0 x 109.5 x 75 Dimensions Inches WxLxH 0.88 x 4.31 x 2.95 1.77 x 4.31 x 2.95 2.16 x 4.31 x 2.95 2.75 x 4.31 x 2.95 3.94 x 4.31 x 2.95 10.03 x 4.31 x 2.95 1.77 x 4.31 x 2.95 2.16 x 4.31 x 2.95 2.75 x 4.31 x 2.95 3.94 x 4.31 x 2.95 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Model CNH 22 N CNH 22 H CNH 45 N CNH 45 H CNH 55 N CNH 55 H CNH 70 N CNH 70 H CNH 100 N CNH 100 H CNB 100 CNA 100 AK 700 V AK 700 H AK 950 STL 950 AK-BS Part Number 65002260 00 65002250 00 65004560 00 65004550 00 65005560 00 65005550 00 65007060 00 65007050 00 65010060 00 65010050 00 65010070 00 65010100 00 66000100 00 Version Hinged hood cover, crystal-clear, low, for enclosure CN(S) 22 AK Hinged hood cover, crystal-clear, tall, for enclosure CN(S) 22 AK Hinged hood cover, crystal-clear, low, for enclosure CN(S) 45 AK Hinged hood cover, crystal-clear, tall, for enclosure CN(S) 45 AK Hinged hood cover, crystal-clear, low, for enclosure CN(S) 55 AK Higned hood cover, crystal-clear, tall, for enclosure CN(S) 55 AK Hinged hood cover, crystal-clear, low, for enclosure CN(S) 70 AK Hinged hood cover, crystal-clear, tall, for enclosure CN(S) 70 AK Hinged hood cover, crystal-clear, low, for enclosure CN(S) 100 AK Hinged hood cover, crystal-clear, tall, for enclosure CN(S) 100 AK Blind bar CNB 100 STL adapter CNA 100 Connection terminals Connection terminals Connection terminals Pin bars Terminal indentification strip For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 69 RCP/RCPM • Wall enclosure system for use in measurement and control applications available in 8 basic sizes, each with 6 different designs • To permit insertion of mounting plates and PCBs, all designs feature vertical and horizontal grooves which ensure optimal unit assembly • Terminal compartment can be separated from the actual electronics area by means of integrated grooves with separating plates Included in delivery Enclosures with hinged lid and latch: Base, clear lid, hinged, clear lid, mounted with latch, terminal compartment covers, screws, blind plug, catch. Enclosures with covering frame: Base, covering frame, terminal compartment cover, screws Enclosures with membrane front: Base, recessed front lid, terminal compartment cover, screws, screw cover. Technical Data Color Material Ingress Protection Surface Resistance Disruptive Strength Flammability Model Number With Hinged Lid and Latch RCP 1300 RCPM 1300 RCP 1600 RCPM 1600 RCP 1700 RCPM 1700 RCP 2000 RCPM 2000 RCP 2500 RCPM 2500 RCP 3100 RCPM 3100 RCP 3500 RCPM 3500 RCP 4000 RCPM 4000 Light gray, similar to RAL 7035 ABS housing, crystal clear polycarbonate lid (Lexan 241A) VO version: Lexan 500 R housing. Lexan 940 A lid. Special materials and colors can be supplied on request. Minimum order quantities apply. Up to IP 65, DIN EN 60529. NEMA 12 ABS, >1014 Ohm to DIN 53482. Polycarbonate, >1015 Ohm to DIN 53482 Polycarbonate 28 KV/mm to DIN 53481 UL 94 HB/1.6 - ABS enclosure material, clear polycarbonate lid. (Lexan 241 R) UL 94 V0 Lexan 500 R enclosure material, Lexan 940 A lid. Part Number With Hinged Lid and Latch 41130109 00 41131109 00 41160109 00 41161109 00 41170109 00 41171109 00 41200309 00 41201309 00 41250109 00 41251109 00 41310109 00 41311109 00 41350109 00 41351109 00 41400109 00 41401109 00 Model Number With Covering Frame RCP 130 RCPM 130 RCP 160 RCPM 160 RCP 170 RCPM 170 RCP 200 RCPM 200 RCP 250 RCPM 250 RCP 310 RCPM 310 RCP 350 RCPM 350 RCP 400 RCPM 400 Part Number With Covering Frame Model Number With Membrane Front Part Number With Membrane Front 41130009 00 41131009 00 41160009 00 41161009 00 41170009 00 41171009 00 41200009 00 41201009 00 41250009 00 41251009 00 41310009 00 41311009 00 41350009 00 41351009 00 41400009 00 41401009 00 RCP 130 F RCPM 130 F RCP 160 F RCPM 160 F RCP 170 F RCPM 170 F RCP 200 F RCPM 200 F RCP 250 F RCMP 250 F RCP 310 F RCPM 310 F RCP 350 F RCPM 350 F RCP 400 F RCPM 400 F 41130609 00 41131609 00 41160609 00 41161609 00 41170609 00 41171609 00 41200609 00 41201609 00 41250609 00 41251609 00 41310609 00 41311609 00 41350609 00 41351609 00 41400609 00 41401609 00 Dimensions mm HxWxD Dimensions Inches HxWxD 186 x 131 x 81-103 186 x 131 x 81-103 161 x 166 x 71-93 161 x 166 x 71-93 161 x 166 x 99-121 161 x 166 x 99-121 185 x 213 x 82.5-104.5 185 x 213 x 82.5-104.5 217 x 257 x 110.5-132.5 217 x 257 x 110.5-132.5 261 x 296 x 110.5-132.5 261 x 296 x 110.5-132.5 281 x 296 x 136-158 281 x 296 x 136-158 318.6 x 363.4 x 128.5-150 318.6 x 363.4 x 128.2-150 7.32 x 5.16 x 3.19-4.05 7.32 x 5.16 x 3.19-4.05 6.34 x 6.53 x 2.79-3.66 6.34 x 6.53 x 2.79-3.66 6.34 x 6.53 x 3.90-4.76 6.34 x 6.53 x 3.90-4.76 7.28 x 8.38 x 3.25-4.11 7.28 x 8.38 x 3.25-4.11 8.54 x 10.12 x 4.35-5.22 8.54 x 10.12 x 4.35-5.22 10.27 x 11.65 x 4.35-5.22 10.27 x 11.65 x 4.35-5.22 11.06 x 11.65 x 5.35-6.22 11.06 x 11.65 x 5.35-6.22 12.54 x 14.31 x 5.06-5.90 12.54 x 14.31 x 5.06-5.90 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. RCPM Version = Metric size knock outs Accessories Model Number SHLO-302 RCP/RCPM-HK RCP/RCPM-WL RCP/RCPM 130 M RCP/RCPM 160/170 M RCP/RCPM 200 M RCP/RCPM 250 M RCP/RCPM 310 M/350M RCP/RCPM 400 M FAE 130 FAE 160/170 FAE 200 FAE 250 FAE 310/350 FAE 400 70 Part Number 21008310 00 41002501 00 41000300 00 41000350 00 41000400 00 41000500 00 41000600 00 41000700 00 41000800 00 27000100 00 27000300 00 27000500 00 27000700 00 27000900 00 27120000 00 Version Cylinder catch Hand knob Wall brackets (PU = 2 pieces) Mounting plate Mounting plate Mounting plate Mounting plate Mounting plate Mounting plate Front panel, for enclosure 130/1300 Front panel, for enclosure 160/170 Front panel, for enclosure 200 Front panel, for enclosure 250 Front panel, for enclosure 310/350 Front panel, for enclosure 400 www.Rose-Bopla.com Bovista • Individually adaptable enclosure for use in building automation systems and many other fields of electronics • Enclosure bases can be supplied with or without ventilation in 3 basic sizes • Eight different lid types, with different sizes and shapes, can be mounted on the base • Choose between lids with a membrane keypad area, design front or a hinged lid Included in delivery Modular product sold by individual components. Technical Data Color Material Ingress Protection Surface Resistance Flammability Base and wall mount fittings: agate gray, similar to RAL 7038 or white, similar to RAL 9010. Lid: light gray (standard color) similar to RAL 7035 or white (special order) similar to RAL 9010 Module bridges: light gray, similar to RAL 7035. Special colors on request. ABS - BVT-MB. Polyamide (PA 6, 15% GF) BVL-MB. Up to IP 40, according to DIN EN 60529, depending on construction. Up to IP 30 if used with ventilated bases. Up to IP 20 if used with lids with secondary flap. >1012 Ohm to DIN 53482 (Polyamide), >1014 Ohm to DIN 53482 (ABS) ABS and Polyamide: UL 94 HB/1.6 Model Number Part Number Agate Gray Part Number White Dimensions mm LxWxH BVT-UT BVT-UT-L BVT-UT2 BVT-UT2-L BVT-OT1 BVT-OT1-F BVT-OT1-D BVT-OT2 BCT-OT2-F BVT-OT3 BVT-OT3-F BVT-OT3-SK BVL-UT BVL-UT-L BVL-OT1 BVL-OT1-F BVL-OT1-D BVL-OT2 BVL-OT2-F BVL-OT3 BVL-OT3-F BVL-OT3-SK 40001000 00 40001100 00 40001200 00 40001300 00 40002100 00 40002110 00 40002120 00 40002130 00 40002140 00 40002150 00 40002160 00 40002170 00 40011000 00 40011100 00 40012100 00 40012110 00 40012120 00 40012130 00 40012140 00 40012150 00 40012160 00 40012170 00 40101000 00 40101100 00 40101200 00 40101300 00 40102100 00 40102110 00 40102120 00 40102130 00 40102140 00 40102150 00 40102160 00 40102170 00 40111000 00 40111100 00 40112100 00 40112110 00 40112120 00 40112130 00 40112140 00 40112150 00 40112160 00 40112170 00 200 x 120 x 18 200 x 120 x 18 120 x 80 x 18 120 x 80 x 18 120 x 40 x 18 120 x 40 x 18 120 x 40 x 18 120 x 80 x 18 120 x 80 x 18 120 x 120 x 18 120 x 120 x 18 120 x 120 x 18 270 x 162 x 28 270 x 162 x 28 162 x 54 x 22 162 x 54 x 22 162 x 54 x 22 162 x 108 x 22 162 x 108 x 22 162 x 162 x 22 162 x 162 x 22 162 x 162 x 22 Dimensions Inches LxWxH 7.87 x 4.72 x 0.71 7.87 x 4.72 x 0.71 4.72 x 3.16 x 0.71 4.72 x 3.15 x 0.71 4.72 x 1.57 x 0.71 4.72 x 1.57 x 0.71 4.72 x 1.57 x 0.71 4.72 x 3.15 x 0.71 4.72 x 3.15 x 0.71 4.72 x 4.72 x 0.71 4.72 x 4.72 x 0.71 4.72 x 4.72 x 0.71 10.63 x 6.38 x 1.10 10.63 x 6.38 x 1.10 6.38 x 2.12 x 0.87 6..38 x 2.12 x 0.87 6.38 x 2.12 x 0.87 6.38 x 4.25 x 0.87 6.38 x 4.25 x 0.87 6.38 x 6.38 x 0.87 6.38 x 6.38 x 0.87 6.38 x 6.38 x 0.87 Description Compact base Compact base with ventilation Compact base 2 Compact base 2 with ventilation Compact lid 1 Compact lid 1 with membrane keypad area Compact lid 1 with design front Compact lid 2 Compact lid 2 with membrane keypad area Compact lid 3 Compact lid 3 with membrane keypad area Compact lid 3 with secondary flap Control base Control base with ventilation Control lid 1 Control lid 1 with membrane keypad area Control lid 1 with design front Control lid 2 Control lid 2 with membrane keypad area Control lid 3 Control lid 3 with membrane keypad area Control lid 3 with secondary flap Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Model Number BVT-MB BVT-WB BVT-WB 2 BVT-UP BVT-FO-9010 BVT-FO-7035* BVT-UP2 BVT-FO2-9010 BVT-FO2-7035* BVL-MB DIBLZ AK 30 x 5/IM3/10 BVL-WB BVL-UP BVL-FO-9010 BVL-FO-7035* *Available on request Part Number Agate Gray 40040000 00 40042000 00 40014000 00 Part Number White 40003000 00 40104000 00 40104200 00 40200000 00 40200300 00 40200200 00 40200010 00 40200310 00 40013000 00 59006986 00 40114000 00 40300000 00 40300300 00 40200200 00 Version Compact module bridges Compact wall mount plate Compact wall mount plate 2 Compact flush mount enclosure Compact front frame, white, similar to RAL 9010 Compact front frame, light gray, similar to RAL 7035 Compact 2 flush-mount enclosure Compact 2 front frame, white, similar to RAL 9010 Compact 2 front frame with 2 mounting screws, light gray, similar to RAL 7035 Control module bridges Distance bolts, boss internal Ø 2.4-2.6 Control wall mount plate Control flush-mount enclosure Control front frame, white, similar to RAL 9010 Control front frame, light gray, similar to RAL 7035 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 71 BOTEGO • Enclosure system consisting of two-half shells. Designed for either horizontal or vertical use. • Extension sets permit optimal adaptation of relevant space. • Snap-lock technology reduces assembly time. • Cap sets available in 6 colors to individualize the enclosure. Included in delivery 2 half shells. Other components sold individually or in sets. See website for details, www.rose-bopla.com Technical Data Color Material Ingress Protection Surface Resistance Flammability Model Number BO 32006 BO 32006 L BO 32009 BO 32009 L BO 32012 BO 32012 L BO 51406 BO 51406 L BO 51409 BO 51409 L BO 51412 BO 51412 L BO 52006 BO 52006 L BO 52009 BO 52009 L BO 52012 BO 52012 L BO 62606 BO 62606 L BO 62609 BO 62609 L BO 62612 BO 62612 L Light gray, similar to RAL 7035. Special colors on request. Minimum order quantities apply. ABS Closed: IP 40 to EN 60529. With air vents: IP 30 to EN 60529 >1014 Ohm to DIN 53482 UL 94 HB/1.6 Part Number 68320060 00 68320061 00 68320090 00 68320091 00 68320120 00 68320121 00 68514060 00 68514061 00 68514090 00 68514091 00 68514120 00 68514121 00 68520060 00 68520061 00 68520090 00 68520091 00 68520120 00 68520121 00 68626060 00 68626061 00 68626090 00 68626091 00 68626120 00 68626121 00 Dimensions mm WxHxD 174 x 49.96 x 196.9 174 x 49.96 x 196.9 174 x 65.20 x 196.9 174 x 65.20 x 196.9 174 x 80.44 x 196.9 174 x 80.44 x 196.9 240.67 x 49.96 x 136.9 240.67 x 49.96 x 136.9 240.67 x 65.20 x 136.9 240.67 x 65.20 x 136.9 240.67 x 80.44 x 136.9 240.67 x 80.44 x 136.9 240.67 x 49.96 x 196.9 240.67 x 49.96 x 196.9 240.67 x 65.20 x 196.9 240.67 x 65.20 x 196.9 240.67 x 80.44 x 196.9 240.67 x 80.44 x 196.9 307.35 x 49.96 x 256.9 307.35 x 49.96 x 256.9 307.35 x 65.20 x 256.9 307.35 x 65.20 x 256.9 307.35 x 80.44 x 256.9 307.35 x 80.44 x 256.9 Dimensions Inches WxHxD Front Panel to be Used 6.85 x 1.97 x 7.75 6.85 x 1.97 x 7.75 6.85 x 2.57 x 7.75 6.85 x 2.57 x 7.75 6.85 x 3.17 x 7.75 6.85 x 3.17 x 7.75 9.47 x 1.97 x 5.39 9.47 x 1.97 x 5.39 9.47 x 2.57 x 5.39 9.47 x 2.57 x 5.39 9.47 x 3.17 x 5.39 9.47 x 3.17 x 5.39 9.47 x 1.97 x 7.75 9.47 x 1.97 x 7.75 9.47 x 2.57 x 7.75 9.47 x 2.57 x 7.75 9.47 x 3.17 x 7.75 9.47 x 3.17 x 7.75 12.10 x 1.97 x 10.11 12.10 x 1.97 x 10.11 12.10 x 2.57 x 10.11 12.10 x 2.57 x 10.11 12.10 x 3.17 x 10.11 12.10 x 3.17 x 10.11 BO FP 30006 BO FP 30006 BO FP 30009 BO FP 30009 BO FP 30012 BO FP 30012 BO FP 50006 BO FP 50006 BO FP 50009 BO FP 50009 BO FP 50012 BO FP 50012 BO FP 50006 BO FP 50006 BO FP 50009 BO FP 50009 BO FP 50012 BO FP 50012 BO FP 60006 BO FP 60006 BO FP 60009 BO FP 60009 BO FP 60012 BO FP 60012 L = With injection molded air vents in both half-shells. Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Model Number BO FP ... BO AB... BO-KS BO-SF... BO-PB ... BO-PT... BO HS... BO FF... BO D... BO WB... 72 Version Front panel, aluminum Al Mg 3, anodized 2 mm. Front panel available in plastic on request Extension set. ABS light gray, similar to RAL 7035; additional colors for minimum orders of 500 extension sets Cap sets Angled operating front Filling profile set for mounting rack installation. Profile set Handle Design foil Design element set Wall mounting set www.Rose-Bopla.com Ultramas • Ideal for small test equipment and computer peripherals, this enclosure can be adapted superbly to your individual space requirements • Features smooth design lines, flawless satin finish and offered with or without ventilation slots • Works in either the horizontal or vertical position, making it perfect as a desk or wall-mount Included in delivery Lid and base, 8 screw covers, 4 rubber feet, 4 screws M3 Accessories sold separately. Technical Data Color Material Protection Classification Surface Resistance Flammability Enclosure, light gray, similar to RAL 7035. Screw covers, brackets and feet in agate gray, similar to RAL 7038. ABS Closed: IP 40 DIN EN 60529. IP 30 DIN EN 60529 with air vents >1014 Ohm to DIN 53482 UL 94 HB/1.6 Model Number Part Number UM 32009 UM 32009 L UM 32609 UM 32609 L UM 52011 UM 52011 L UM 62009 UM 62009 L UM 62609 UM 62609 L 55320000 00 55320010 00 55326000 00 55326010 00 55520000 00 55520020 00 55620000 00 55620010 00 55626000 00 55626010 00 Dimensions mm WxDxH Dimensions Inches WxDxH 157.5 x 198.9 x 62.2 157.5 x 198.9 x 62.2 157.5 x 258.9 x 62.2 157.5 x 258.9 x 62.2 224.2 x 198.9 x 72.4 224.2 x 198.9 x 72.4 290.9 x 198.9 x 62.2 290.9 x 198.9 x 62.2 290.9 x 258.9 x 62.2 290.9 x 258.9 x 62.2 6.20 x 7.83 x 2.45 6.20 x 7.83 x 2.45 6.20 x 10.19 x 2.45 6.20 x 10.19 x 2.45 8.83 x 7.83 x 2.85 8.83 x 7.83x 2.85 11.45 x 7.83 x 2.45 11.45 x 7.83 x 2.45 11.45 x 10.19 x 2.45 11.45 x 10.19 x 2.45 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Model Number FP FPK AB UM-AS UM-ASK UM-WLH UM-VHH Version Front panel, aluminum Al Mg3, anodized, 2 mm Front panel, plastic ABS, light gray, similar to RAL 7035, 2 mm, embossed on one side Extension set left and right, ABS light gray, similar to RAL 7035 (set = 2 pieces) Fixed set-up foot set (set = 4 pieces) Hinged set-up foot set (set = 2 fixed and 2 hinged feet) Wall brackets (set = 4 pieces) Connecting straps (set = 4 pieces) For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 73 BOCARD • Available in 5 basic sizes, each with 2 bases in different heights. Can be combined with 5 different lid types. • Range of combinations ensures that the enclosure is suitable for an extremely wide range of applications. • Terminal compartment can be kept separate from the electronics compartment by means of partitions. Included in delivery Modular product sold individually. For details call factory. Technical Data Color Material Ingress Protection Surface Resistance Flammability Model Number Base parts, light gray, similar to RAL 7035. Lids, light gray, similar to RAL 7035 or graphite gray, similar to RAL 7024. DIN Rail holder, black similar to RAL 9005. Special colors on request ABS. Front lids, polycarbonate. DIN Rail holder, polyamide IP 65/DIN VDE 06529, NEMA 12, depending on combined systems parts. ABS: >1014 Ohm to DIN 53482 ABS: UL 94 HB/1.6. Polyamide: UL 94 VO/1 Part Number Light Gray Model Number Part Number Graphite Gray Dimensions mm HxWxD Dimensions Inches HxWxD High enclosure, with clear hinged lid, without terminal compartment BCD 160 Set 01-7035 BCD 200 Set 01-7035 BCD 250 Set 01-7035 BCD 310 Set 01-7035 BCS 400 Set 01-7035 20163501 00 20203501 00 20253501 00 20313501 00 20403501 00 BCD 160 Set 01-7024 BCD 200 Set 01-7024 BCD 250 Set 01-7024 BCD 310 Set 01-7024 BCD 400 Set 01-7024 20162401 00 20202401 00 20252401 00 20312401 00 20402401 00 179 x 199 x 106.5 204 x 229 x 116.0 234 x 264 x 141.0 289 x 324 x 145.2 344 x 404 x 160.5 7.05 x 7.83 x 4.19 8.03 x 9.01 x 4.57 9.21 x 10.39 x 5.55 11.38 x 12.75 x 5.72 13.54 x 15.90 x 6.32 20162402 00 20202402 00 20252402 00 20312402 00 20402402 00 179 x 199 x 71.5 204 x 229 x 76.0 234 x 264 x 86.0 289 x 324 x 111.2 344 x 404 x 112.0 7.05 x 7.83 x 2.81 8.03 x 9.01 x 2.99 9.21 x 10.39 x 3.38 11.38 x 12.75 x 4.38 13.54 x 15.90 x 4.41 20162403 00 20202403 00 20252403 00 20312403 00 20402403 00 179 x 199 x 106.5 204 x 229 x 116.0 234 x 264 x 141.0 289 x 324 x 145.2 344 x 404 x 160.5 7.05 x 7.83 x 4.19 8.03 x 9.01 x 4.57 9.21 x 10.39 x 5.55 11.38 x 12.75 x 5.72 13.54 x 15.90 x 6.32 20162404 00 20202404 00 20252404 00 20312404 00 20402404 00 179 x 199 x 71.5 204 x 229 x 76.0 234 x 264 x 86.0 289 x 324 x 111.2 344 x 404 x 112.0 7.05 x 7.83 x 2.81 8.03 x 9.01 x 2.99 9.21 x 10.39 x 3.38 11.38 x 12.75 x 4.38 13.54 x 15.90 x 4.41 20162405 00 20202405 00 20252405 00 20312405 00 20432405 00 179 x 199 x 106.5 204 x 229 x 116.0 234 x 264 x 141.0 289 x 324 x 145.2 344 x 404 x 160.5 7.05 x 7.83 x 4.19 8.03 x 9.01 x 4.57 9.21 x 10.39 x 5.55 11.38 x 12.75 x 5.72 13.54 x 15.90 x 6.32 20162406 00 20202406 00 20252406 00 20312406 00 20402406 00 179 x 199 x 71.5 204 x 229 x 76.0 234 x 264 x 86.0 289 x 324 x 111.2 344 x 404 x 112.0 7.05 x 7.83 x 2.81 8.03 x 9.01 x 2.99 9.21 x 10.39 x 3.38 11.38 x 12.75 x 4.38 13.54 x 15.90 x 4.41 Flat enclosure, with clear hinged lid, without terminal compartment BCD 160 Set 02-7035 BCD 200 Set 02-7035 BCD 250 Set 02-7035 BCD 310 Set 02-7035 BCD 400 Set 02-7035 20163502 00 20203502 00 20253502 00 20313502 00 20403502 00 BCD 160 Set 02-7024 BCD 200 Set 02-7024 BCD 250 Set 02-7024 BCD 310 Set 02-7024 BCD 400 Set 02-7024 High enclosure, with clear hinged lid, for 1 terminal compartment BCD 160 Set 03-7035 BCD 200 Set 03-7035 BCD 250 Set 03-7035 BCD 310 Set 03-7035 BCD 400 Set 03-7035 20163503 00 20203503 00 20253503 00 20313503 00 20403503 00 BCD 160 Set 03-7024 BCD 200 Set 03-7024 BCD 250 Set 03-7024 BCD 310 Set 04-7024 BCD 400 Set 04-7024 Flat enclosure, with clear hinged lid, for 1 terminal compartment BCD 160 Set 04-7035 BCD 200 Set 04-7035 BCD 250 Set 04-7035 BCD 310 Set 04-7035 BCD 400 Set 04-7035 20163504 00 20203504 00 20253504 00 20313504 00 20403504 00 BCD 160 Set 04-7024 BCD 200 Set 04-7024 BCD 250 Set 04-7024 BCD 310 Set 04-7024 BCD 400 Set 04-7024 High enclosure, with clear hinged lid, for 2 terminal compartments BCD 160 Set 05-7035 BCD 200 Set 05-7035 BCD 250 Set 05-7035 BCD 310 Set 05-7035 BCD 400 Set 05-7035 20163505 00 20203505 00 20253505 00 20313505 00 20403505 00 BCD 160 Set 05-7024 BCD 200 Set 05-7024 BCD 250 Set 05-7024 BCD 310 Set 05-7024 BCD 400 Set 05-7024 Flat enclosure, with clear hinged lid, for 2 terminal compartments BCD 160 Set 06-7035 BCD 200 Set 06-7035 BCD 250 Set 06-7035 BCD 310 Set 06-7035 BCD 400 Set 06-7035 20163506 00 20203506 00 20253506 00 20313506 00 20403506 00 BCD 160 Set 06-7024 BCD 200 Set 06-7024 BCD 250 Set 06-7024 BCD 310 Set 06-7024 BCD 400 Set 06-7024 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. 74 www.Rose-Bopla.com Part Number Light Gray Model Number Dimensions mm WxLxH Dimensions Inches WxLxH Model Number Part Number Graphite Gray BCD 160 Set 07-7024 BCD 200 Set 07-7024 BCD 250 Set 07-7024 20162407 00 20202407 00 20252407 00 178 x 199 x 89.0 203 x 229 x 99.0 233 x 264 x 124 7.01 x 7.83 x 3.50 7.99 x 9.01 x 3.90 9.17 x 10.39 x 4.88 20162408 00 20202408 00 20252408 00 178 x 199 x 54.0 203 x 229 x 59.0 233 x 264 x 69.0 7.01 x 7.83 x 2.12 7.99 x 9.01 x 2.32 9.17 x 10.39 x 2.72 20162409 00 20202409 00 20252409 00 178 x 199 x 89.0 203 x 229 x 99.0 233 x 264 x 124 7.01 x 7.83 x 3.50 7.99 x 9.01 x 3.90 9.17 x 10.39 x 4.88 High enclosure with front frame open, without terminal compartment BCD 160 Set 07-7035 BCD 200 Set 07-7035 BCD 250 Set 07-7035 20163507 00 20203507 00 20253507 00 Flat enclosure, with front frame open, without terminal compartment BCD 160 Set 08-7035 BCD 200 Set 08-7035 BCD 250 Set 08-7035 20163508 00 20203508 00 20253508 00 BCD 160 Set 08-7024 BCD 200 Set 08-7024 BCD 250 Set 08-7024 High enclosure, with front frame open, including terminal compartment cover BCD 160 Set 09-7035 BCD 200 Set 09-7035 BCD 250 Set 09-7035 20163509 00 20203509 00 20253509 00 BCD 160 Set 09-7024 BCD 200 Set 09-7024 BCD 250 Set 09-7024 Flat enclosure, with front frame open, including terminal compartment cover BCD 160 Set 10-7035 BCD 200 Set 10-7035 BCD 250 Set 10-7035 20163510 00 20203510 00 20253510 00 BCD 160 Set 10-7024 BCD 200 Set 10-7024 BCD 250 Set 10-7024 20162410 00 20202410 00 20252410 00 178 x 199 x 54.0 203 x 229 x 59.0 233 x 264 x 69.0 7.01 x 7.83 x 2.12 7.99 x 9.01 x 2.32 9.17 x 10.39 x 2.72 20163511 00 20203511 00 20253511 00 BCD 160 Set 11-7024 BCD 200 Set 11-7024 BCD 250 Set 11-7024 20162411 00 20202411 00 20252411 00 178 x 199 x 89.0 203 x 229 x 99.0 233 x 264 x 124 7.01 x 7.83 x 3.50 7.99 x 9.01 x 3.90 9.17 x 10.39 x 4.88 20163512 00 20203512 00 20253512 00 BCD 160 Set 12-7024 BCD 200 Set 12-7024 BCD 250 Set 12-7024 20162412 00 20202412 00 20252412 00 178 x 199 x 54.0 203 x 229 x 59.0 233 x 264 x 69.0 7.01 x 7.83 x 2.12 7.99 x 9.01 x 2.32 9.17 x 10.39 x 2.72 BCD 160 Set 13-7024 BCD 200 Set 13-7024 BCD 250 Set 13-7024 BCD 310 Set 13-7024 BCD 400 Set 13-7024 20162413 00 20202413 00 20252413 00 20312413 00 20402413 00 179 x 199 x 106.5 204 x 229 x 116.0 234 x 264 x 141.0 289 x 324 x 145.2 344 x 404 x 160.5 7.05 x 7.83 x 4.19 8.03 x 9.01 x 4.57 9.21 x 10.39 x 5.55 11.38 x 12.75 x 5.72 13.54 x 15.90 x 6.32 BCD 160 Set 14-7024 BCD 200 Set 14-7024 BCD 250 Set 14-7024 BCD 310 Set 14-7024 BCD 400 Set 14-7024 20162414 00 20202414 00 20252414 00 20312414 00 20402414 00 179 x 199 x 71.5 204 x 229 x 76.0 234 x 264 x 86.0 289 x 324 x 111.2 344 x 404 x 112.0 7.05 x 7.83 x 2.81 8.03 x 9.01 x 2.99 9.21 x 10.39 x 3.38 11.38 x 12.75 x 4.38 13.54 x 15.90 x 4.41 High enclosure, with membrane lid BCD 160 Set 11-7035 BCD 200 Set 11-7035 BCD 250 Set 11-7035 Flat enclosure, with membrane lid BCD 160 Set 12-7035 BCD 200 Set 12-7035 BCD 250 Set 12-7035 High enclosure, with hinged membrane lid BCD 160 Set 13-7035 BCD 200 Set 13-7035 BCD 250 Set 13-7035 BCD 310 Set 13-7035 BCD 400 Set 13-7035 20163513 00 20203513 00 20253513 00 20313513 00 20403513 00 Flat enclosure, with hinged membrane lid BCD 160 Set 14-7035 BCD 200 Set 14-7035 BCD 250 Set 14-7035 BCD 310 Set 14-7035 BCD 400 Set 14-7035 20163514 00 20203514 00 20253514 00 20313514 00 20403514 00 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Model Number BCD FP... BCD FPK... BCD TP... BCD M... BCD WL-7035 TSH 35-2 Description Front panel, 1.5 mm aluminum Front panel, 2 mm plastic Partition, 1.5 mm hard paper Mounting panel, 2 mm hard paper 4 Wall brackets and assembly screws DIN rail holders (2 pieces) and assembly screws Model Number SHLO 402 BCD...WB BCD HS 2-9005 BCD...GE-7024 BCD...GE-B For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 Description Cylinder lock (1 lock, 2 keys) Wall mounting fastening angle and assembly screws Handle (2 side section, 2 anti-slip elements, profile and assembly material) Handle element Set-up bow for handle element 75 Executive Plug Housing • This generation of plug enclosures is available in different styles for use in specific countries. • From 3 lids with sockets, 5 lids without sockets, 2 console type lids, as well as 3 bases with plug, and one base without plug, it is possible to create 40 different plug enclosures. Included in delivery Lid and base, assembly screws, including connector pins/socket inserts depending on type. Technical Data Color Lid, light gray, similar to RAL 7035; base, agate gray, similar to RAL 7038. Special colors on request. Minimum order quantities apply. Polycarbonate/ABS blend plastic IP 40/DIN EN 60529 UL 94 VO/1.6 Tested to VDE 0624/IEC 884 Material Ingress Protection Flammability Testing Subject to minimum order quantities Model Number Part Number Version Length Inches/mm Width Inches/mm Height Inches/mm ESO 1250 E ESO 1250 CEE ESO 1250 SEV ESO 1250 E-K* ESO 1250 CEE-K* ESO 1250 ESO 1240 ESO 1230 ESO 1240 P ESO 1240 PD ESU 1200 E/CEE ESU 1200 SEV ESU 1200 E-US ESU 1200 41010004 00 44020004 00 44030004 00 44011004 00 44021004 00 44040004 00 44050004 00 44060004 00 44070004 00 44080004 00 44093004 00 44091004 00 44092004 00 44090004 00 Lid with socket DIN 49440/CEE 7 III Lid with socket CEE 7 V Lid with socket SEV 1011 Type 13 Lid with socket DIN 49440/CEE 7 III Lid with socket CEE 7 V Lid without socket Lid without socket Lid without socket Console lid without socket, keypad area 46 x 90 x 1mm deep Console lid without socket, keypad area 46 x 70 x 1mm deep. Display opening 46 x 11mm Base with plug DIN 49441 R2 Base with plug SEV 1011 Type 12 Base with plug UL 498 ANSI ST. A5-15 Base with plug 4.92 / 125 4.92 / 125 4.92 / 125 4.92 / 125 4.92 / 125 4.92 / 125 4.92 / 125 4.92 / 125 4.92 / 125 4.92 / 125 4.92 / 125 4.92 / 125 4.92 / 125 4.92 / 125 2.64 / 67 2.64 / 67 2.64 / 67 2.64 / 67 2.64 / 67 2.64 / 67 2.64 / 67 2.64 / 67 2.64 / 67 2.64 / 67 2.64 / 67 2.64 / 67 2.64 / 67 2.64 / 67 1.38 / 35 1.38 / 35 1.38 / 35 1.38 / 35 1.38 / 35 1.38 / 35 0.98 / 25 0.98 / 25 0.98 / 25 0.98 / 25 0.59 / 15 0.59 / 15 0.59 / 15 0.59 / 15 E = German version with ground E-US = US version with ground CEE = French version with ground K = With child safety lock SEV = Swiss version with ground E/CEE = Swiss version with ground Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. 76 www.Rose-Bopla.com SE 4 and SE 5 Plug Housings • Eight basic sizes are available. This enclosure program comprises six country-specific plugs and four different sockets. • Because of their compactness and integrated cable inlets, the enclosures in the SE 510/520 series are especially suitable for use as transformer mains power units. Included in delivery Lid and base, mounting screws, including connector pins/socket inserts depending on type. Technical Data Color Material Ingress Protection Flammability Testing Subject to minimum order quantities Model Number SE 4 Series - lid, light gray, similar to RAL 7035; base, graphite gray, similar to RAL 7024. SE 5 series, black, similar to RAL 9005. Special colors on request SE 4 Series-flame-resistance Polycarbonate/ABS blend. SE 5 Series-flame-resistant Polyamide, PA 6.6 FR. IP 40/DIN VDE 60529, IP 30 (enclosures with ventilation) SE 4 Series, UL 94 VO/1.6. SE 5 Series, UL 94 VO/1 SE 5 Series tested to VDE 0624/IEC 884. Part Number Plug Enclosures with Euro Plug SE 420 EU 43420204 00 Plug Enclosures with German/French Plug 43406204 00 SE 406 E/CEE* 43408504 00 SE 408 E/CEE* 43410104 00 SE 410 E/CEE* 43420104 00 SE 420 E/CEE 43430004 00 SE 430 E/CEE 43435004 00 SE 435 E/CEE Plug Enclosures with Swiss Plug SE 430 SEV* 43430604 00 SE 435 SEV* 43435604 00 Plug Enclosures with American Plug SE 410 E/US* 43410404 00 SE 420 E/US* 43420224 00 SE 430E/US* 43430104 00 SE 435 E/US 43435204 00 Plug Enclosures with Appropriate Socket 43432504 00 SE 432 DE 43432704 00 SE 432 DE CEE* 43432604 00 SE 432 DE SEV* 43435504 00 SE 435 DE 43435704 00 SE 435 DE CEE* Dimensions mm Dimensions Inches Version LxWxH LxWxH 100 x 50 x 40 3.94 x 1.97 x 1.57 65 x 50 x 30 65 x 50 x 45 100 x 50 x 40 100 x 50 x 25 120 x 65 x 40 120 x 65 x 66 2.56 x 1.97 x 1.18 2.56 x 1.97 x 1.77 3.94 x 1.97 x 0.98 E/CEE = plug with ground, DIN 49441 R2. 3.94 x 1.97 x 1.57 * = Available on request. Minimum order applies 4.72 x 2.56 x 1.57 4.72 x 2.56 x 2.60 120 x 65 x 40 120 x 65 x 66 4.72 x 2.56 x 1.57 4.72 x 2.56 x 2.56 SEV = Swiss version, with ground. SEV-1011 type 12, minimum order 500+. *Available on request. 100 x 50 x 25 100 x 50 x 40 120 x 65 x 40 120 x 65 x 66 3.94 x 1.97 x 0.98 3.94 x 1.97 x 1.57 4.72 x 2.56 x 1.57 4.72 x 2.56 x 2.60 E-US = US version, with ground. UL 498 or ANSI St. A 5-15, minimum order 500+. *Available on request. Minimum order applies 120 x 65 x 50 120 x 65 x 50 120 x 65 x 50 120 x 65 x 66 120 x 65 x 66 4.72 x 2.56 x 1.97 4.72 x 2.56 x 1.97 4.72 x 2.56 x 1.97 4.72 x 2.56 x 2.60 4.72 x 2.56 x 2.60 DE = German version (DIN 49440/CEE 7 111) DE-CEE = French version (CEE 7V) DE-SEV = Swiss version (SEV 1011 Type 13) * = Available on request. Minimum order applies. Euro plug, DIN VDE 0620 part 101 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Model Number Part Number Description Plugs SE 510... SE 510 EU SE 510 E/CEE SE 510 AS SE 510 US SE 510 GB* SE 510 EU-L SE 510 E/CEE-L SE 510 AS-L SE 510 US-L SE 510 GB-L* Plugs SE 520... 43510200 00 43510000 00 43510500 00 43510600 00 43510300 00 43510210 00 43510010 00 43510510 00 43510610 00 43510310 00 Euro plug DIN VDE 0620 part 101 German/French plug DIN 49441 R2 Australian plug AS 3112 without ground 7.5 A American plug US 498 ANSI ST. A 1-15 without ground 15 A British plug GB-BS 1363 with ground 13 A fuse Euro plug DIN VDE 0620 part 101, with ventilation German/French plug DIN 49441 R2, with ventilation Australian plug AS 3112 without ground 7.5 A, with ventilation American plug US 498 ANSI ST. A 1-15 without ground 15 A, with ventilaiton British plug GB-BS 1363 with ground, 13 A fuse, with ventilation SE 520 EU SE 520 E/CEE SE 520 AS SE 520 US SE 520 GB* SE 520 EU-L SE 520 E/CEE-L SE 520 AS-L SE 520 US-L SE 520 GB-L* 43520200 00 43520000 00 43520500 00 43520600 00 43520300 00 43520210 00 43520010 00 43520510 00 43520610 00 43520313 00 Euro plug DIN VDE 0620 part 101 German/French plug DIN 49441 R2 Australian plug AS 3112 without ground 7.5 A American plug US 498 ANSI ST. A 1-15 without ground 15 A British plug GB-BS 1363 with ground 5 A fuse Euro plug DIN VDE 0620 part 101, with ventilation German/French plug DIN 49441 R2, with ventilation Australian plug AS 3112 without ground 7.5 A, with ventilation American plug US 498 ANSI ST. A 1-15 without ground 15 A, with ventilation British plug GB-BS 1363 with ground, 5 A fuse, with ventilation For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 77 NGS Panel Meter Housing • Specifically designed to conform to the dimensional standard DIN 43700 • Housings slotted internally to accept PC boards comes in 36 different sizes • Clear PVC front covers (available as an accessory) protect the front elements up to IP65 Included in delivery Enclosure body, standard front frame, rear cover, and assembly screws. Technical Data Color Material Ingress Protection Flammability Gasket Impact Resistance Disruptive Strength Model Number NGS 4806 NGS 4808 NGS 4810 NGS 4811 NGS 4813 NGS 7406 NGS 7408 NGS 7410 NGS 7411 NGS 7413 NGS 7416 NGS 7706 NGS 7708 NGS 7710 NGS 7711 NGS 7713 NGS 7716 NGS 9406 Black, similar to RAL 9005 Flame resistant Noryl SE 1 GFN 1 IP 40, IP 65 possible with rubber hoods, part types NGS...GHN UL 94 V1/1.47 Neoprene 200 JM at 23°C 26 KV/mm to DIN 53481 Part Number 17480601 00 17480801 00 17481001 00 17481101 00 17481301 00 17740601 00 17740801 00 17741001 00 17741101 00 17741301 00 17741601 00 17770601 00 17770801 00 17771001 00 17771101 00 17771301 00 17771601 00 17940601 00 Width Inches/mm Height Inches/mm Depth Inches/mm Model Number Part Number Width Inches/mm Height Inches/mm Depth Inches/mm 1.89 / 48.0 1.89 / 48.0 1.89 / 48.0 1.89 / 48.0 1.89 / 48.0 5.67 / 144.0 5.67 / 144.0 5.67 / 144.0 5.67 / 144.0 5.67 / 144.0 5.67 / 144.0 2.83 / 72.0 2.83 / 72.0 2.83 / 72.0 2.83 / 72.0 2.83 / 72.0 2.83 / 72.0 3.78 / 96.0 1.89 / 48.0 1.89 / 48.0 1.89 / 48.0 1.89 / 48.0 1.89 / 48.0 2.83 / 72.0 2.83 / 72.0 2.83 / 72.0 2.83 / 72.0 2.83 / 72.0 2.83 / 72.0 2.83 / 72.0 2.83 / 72.0 2.83 / 72.0 2.83 / 72.0 2.83 / 72.0 2.83 / 72.0 1.89 / 48.0 2.48 / 63.0 3.36 / 85.0 4.31 / 109.5 4.68 / 119.0 5.55 / 141.0 2.52 / 64.0 3.38 / 86.0 4.35 / 110.5 4.72 / 120.0 5.59 / 142.0 6.55 / 166.5 2.48 / 63.0 3.35 / 85.0 4.31 / 109.5 4.68 / 119.0 5.55 / 141.0 6.51 / 165.5 2.48 / 63.0 NGS 9408 NGS 9410 NGS 9411 NGS 9413 NGS 9416 NGS 9606 NGS 9608 NGS 9610 NGS 9611 NGS 9613 NGS 9616 NGS 9806 NGS 9806 GR NGS 9808 NGS 9810 NGS 9811 NGS 9813 NGS 9816 17940801 00 17941001 00 17941101 00 17941301 00 17941601 00 17960601 00 17960801 00 17961001 00 17961101 00 17961301 00 17961601 00 17980601 00 17980605 00 17980801 00 17981001 00 17981101 00 17981301 00 17981601 00 3.78 / 96.0 3.78 / 96.0 3.78 / 96.0 3.78 / 96.0 3.78 / 96.0 3.78 / 96.0 3.78 / 96.0 3.78 / 96.0 3.78 / 96.0 3.78 / 96.0 3.78 / 96.0 5.67 / 144.0 5.67 / 144.0 5.67 / 144.0 5.67 / 144.0 5.67 / 144.0 5.67 / 144.0 5.67 / 144.0 1.89 / 48.0 1.89 / 48.0 1.89 / 48.0 1.89 / 48.0 1.89 / 48.0 3.78 / 96.0 3.78 / 96.0 3.78 / 96.0 3.78 / 96.0 3.78 / 96.0 3.78 / 96.0 5.67 / 144.0 5.67 / 144.0 5.67 / 144.0 5.67 / 144.0 5.67 / 144.0 5.67 / 144.0 5.67 / 144.0 3.35 / 85.0 4.31 / 109.5 4.68 / 119.0 5.55 / 141.0 6.51 / 165.5 2.48 / 63.0 3.35 / 85.0 4.31 / 109.5 4.68 / 119.0 5.55 / 141.0 6.51 / 165.5 2.52 / 64.0 2.68 / 68.0 3.38 / 86.0 4.35 / 110.5 4.72 / 120.0 5.59 / 142.0 6.55 / 166.5 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Model Number NGS...NF NGS...NK NGS...ZE NGS...NH NGS...FKT NGS...FAE NGS...F NGS...TK NGS...SA NGS...AH NGS...DA NGS...DI NGS...GHN NGS...RKS SHLO-302 78 Description Spring clamp (pk of 2) Screw clamp (pk of 2) Connecting piece for DIN retaining clasp (pk of 2) DIN retaining clasp (pk of 2) Plastic front panel, red translucent, 3mm thick Aluminum front panel, anodized aluminum, 1.5mm thick Membrane front, firmly latching NGS front door lockable by means of knob for models 74..., 96..., and 98 Firmly latching front frame Clear hood cover Seal enclosure / control panel (pk of 5) Seal front panel / enclosure (pk of 5) Flexible tansparent PVC hoods for IP 65 front seal Rear lid Cylinder catch for front door NGS 9806-GR with stepped rear panel. www.Rose-Bopla.com NGS 48 NGS 74 NGS Front Panels NGS 77 NGS 94 NGS Front Frames NGS 96 NGS 98 NGS Hood Covers NGS Front Doors NGS Cylinder Catch for Front Door For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 NGS Transparent Rubber Hood 79 Stainless Steel Enclosure System Stainless steel enclosure systems can offer considerable advantages in some application areas in comparison with plastic enclosure solutions: • Food industries • Packaging industries • Hazardous environments • EMC areas • Field bus areas Rose stainless steel-enclosure systems are manufactured in materials 1.4404 and 1.4301 as standard. This stainless steel quality offers permanent resistance in both rough environments, in the chemical industry, and is ideal for the cleaning demands of the food industry. Rose stainless steel products offer consistent high surface finish qualitiy as standard (longitudinal finish 240 grain), finishing (precise edging and welding) and ingress protection (IP 65 and IP 66 as standard or higher upon request). Stainless Steel Industrial Enclosures • 18 enclosure sizes with lid or hinged door in sizes from 100 x 100 x 61 mm up to 600 x 200 x 121 mm • Application area: food and packaging industries, as well as hazardous environments Stainless Steel Cabinets • 16 enclosure sizes with door and mounting plates in dimensions from 200 x 250 x 90 mm up to 600 x 760 x 210 mm • Application area: food and packaging industries Ex Stainless Steel Cabinets and Enclosures • 27 enclosure sizes from 100 x 100 x 61 mm up to 600 x 380 x 217 mm • Application area: EExe, EExia in Zones 1 and 2 • Approvals: PTB 00 ATEX 1101U; PTB 00 ATEX 1052 80 www.Rose-Bopla.com Standard Stainless Steel Enclosures • Universal standard enclosures for hygienic areas • High surface quality 1.4301 • No gaps in cover/lower section - ingress protection up to IP 66 • Special versions and sizes available as an option for 25 pieces and above Included in delivery Enclosure base with internal mounting support bars for DIN rail mounting, 4 floor break-outs with or without mounting holes, gasket and mounting nuts, cover with internal threaded bolts and captive lid screws. UL 50 Technical Data Material Ingress Protection Surface Temperature Range Stainless steel 1.25 mm or 1.5mm; 1.4301/304. Other materials on request IP 66, EN 60529. High pressure cleaning-resistant on request Polished 240 grain. Other surface on request -76°F to +266°F Part Number Part Number Enclosure with floor breakouts and mounting holes Enclosure without mounting holes 37101006 00 37151006 00 37151508 00 37201006 00 37202008 00 37202012 00 37301508 00 37302008 00 37302012 00 37303012 00 37303016 00 37383816 00 37401508 00 37402012 00 37403016 00 37503016 00 37504016 00 37602012 00 37999999 00 37101096 00 37151096 00 37151598 00 37202098 00 37202092 00 37302092 00 Dimensions mm LxWxH 100 x 100 x 61 150 x 100 x 61 150 x 150 x 81 200 x 100 x 61 200 x 200 x 81 200 x 200 x 121 300 x 150 x 81 300 x 200 x 81 300 x 200 x 121 300 x 300 x 121 300 x 300 x 161 380 x 380 x 161 400 x 150 x 81 400 x 200 x 121 400 x 300 x 161 500 x 300 x 161 500 x 400 x 161 600 x 200 x 121 Special dimension Dimensions Inches L xW x H 3.94 x 3.94 x 2.40 5.90 x 3.94 x 2.40 5.90 x 5.90 x 3.19 7.87 x 3.94 x 2.40 7.87 x 7.87 x 3.19 7.87 x 7.87 x 4.76 11.81 x 5.90 x 3.19 11.81 x 7.87 x 3.19 11.81 x 7.87 x 4.76 11.81 x 11.81 x 4.76 11.81 x 11.81 x 6.34 14.96 x 14.96 x 6.34 15.75 x 5.90 x 3.19 15.75 x 7.87 x 4.76 15.75 x 11.81 x 6.34 19.68 x 11.81 x 6.34 19.68 x 15.75 x 6.34 23.62 x 7.87 x 4.76 Special dimension Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories External bracket set (4 pcs.) Mounting plate screws Allen head lid screws Part Number 37105000 00 10093041 00 10091001 00 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 81 IGS Stainless Steel Cabinets with Hinges • Universal enclosure with hinge and lock • High quality polished surface 1.4301 • Custom sizes and versions with flange openings or window available (25 piece minimum) Included in delivery Enclosure base with bracket clips and threaded bores for attachment of mounting rail, hinged cover, double ward lock, 4 floor break-outs with attachment holes and sealing plugs. Technical Data Material Stainless steel 1.25 mm or 1.5 mm 1.4301 / 304 other matierial on request IP 65 to EN 60529 -40°F to +176°F VMQ-(silicone) seal or PUR-(polyurethane) seal EMC on request Polished, 240 grain, other surfaces on request Ingress Protection Temperature Range Seals Surface Part Number 37002209 00 37002215 00 37003209 00 37003316 00 37004416 00 37004421 00 37005316 00 37006316 00 37006421 00 37009900 00 Dimensions mm LxWxH 200 x 250 x 90 200 x 250 x 150 300 x 300 x 165 350 x 250 x 90 380 x 380 x 165 380 x 380 x 215 500 x 300 x 165 600 x 300 x 165 600 x 380 x 215 Special sizes (please state requested dimensions) Dimensions Inches LxWxH 7.87 x 9.84 x 3.54 7.87 x 9.84 x 5.90 11.81 x 11.84 x 6.50 13.78 x 9.84 x 3.54 14.96 x 14.96 x 6.50 14.96 x 14.96 x 8.46 19.68 x 11.81 x 6.50 23.62 x 11.81 x 6.50 23.62 x 14.96 x 8.46 Number of Locks 1 1 1 1 1 1 1 1 1 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Part Number Mounting plate for 37002209 and 37002215 Mounting plate for 37003209 Mounting plate for 37004416 Mounting plate for 37006316 Mounting plate for 37006421 External bracket set (4 pieces) 10011066 00 10111067 00 10011045 00 10011068 00 10011069 00 37105000 00 82 www.Rose-Bopla.com KSS Stainless Steel Switch Gear Cabinets • Switch gear cabinets with hinged door • Mounting plate attachment above stud bolts / threaded weld nuts • Surface polished all sides (240 grain) • Custom sizes and versions available (25 piece minimum). Included in delivery Enclosure system with door, double ward lock, 4 x M6 threaded stud bolts in lid and 4 x M6 threaded weld nuts in base. Technical Data Material Ingress Protection Temperature Range Gasket Stainless steel 1.25 mm or 1.5 mm 1.4301 / 304 IP 65 to EN 60529 -40°F to + 176°F VMQ gasket (silicone) seal or PUR (polyurethane) EMC on request polished, 240 grain Surface Part Number Dimensions mm LxWxH Dimensions Inches LxWxH 37012315 00 37013421 00 37014315 00 37014621 00 37015521 00 37016415 00 37016821 00 37019900 00 200 x 300 x 155 300 x 380 x 210 400 x 300 x 155 380 x 600 x 210 500 x 500 x 210 600 x 400 x 155 600 x 760 x 210 Special dimensions 7.87 x 11.81 x 6.10 11.81 x 14.96 x 8.27 15.75 x 11.81 x 6.10 14.96 x 23.62 x 8.27 19.68 x 19.68 x 8.27 23.62 x 15.75 x 6.10 23.62 x 29.92 x 8.27 - Number of Locks 1 1 1 2 2 1 4 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Mounting plate for 37012305 Mounting plate for 37013421 Mounting plate for 37014315 Mounting plate for 37014621 Mounting plate for 37015521 Mounting plate for 37016415 Mounting plate for 37016821 Part Number 37019901 00 37019902 00 37019903 00 37019904 00 37019905 00 37019906 00 37019907 00 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 83 Handheld Enclosures The increasing mobility prevalent in all areas of industry requires portable hand enclosures. Materials, sizes and versions vary depending on the application area. Cableconnected systems made of robust Polyamide or Polyester with high ingress protection are in use, especially in automation engineering. In contrast, the data adquisition and instrumentation industries prefer to use light enclosures with integrated power supplies. The range of hand held enclosure products covers all areas of mobile applications. Taguan 130 / 180 / 230 • 8 enclosures in four sizes from 125 x 80 x 37 mm to 229 x 97 x 52 mm • Application area: data acquisition, instrumentation Beluga 180 / 220 / 380 • 5 enclosures in three sizes from 106 x 187 x 50 mm to 380 x 117 x 68 mm • Application area: instrumentation and automation engineering, analytical control Limanda • Enclosure system for controller components, sizes 270 x 248 x 64 mm and 311 x 281 x 72 mm • Application area: analytical control and automation engineering Pilot 250 • 2 enclosures in size 280 x 140 x 86 mm • Application area: instrumentation and automation engineering, analytical control Mobile Control Units 2911, 2912, 2913 • 3 enclosures in sizes 280 x 191 x 76 mm to 440 x 191 x 76 mm • Application area: instrumentation and automation engineering, analytical control Mobile Control Units • 3 enclosures with integrated handles in sizes 190 x 70 x 93 mm to 295 x 164 x 116 mm • Application area: pushbutton and switch enclosures Mobile Control Units 2921 • 5 enclosures with integrated handle in sizes 206 x 85 x 85 mm to 281 x 160 x 105 mm • Application area: pushbutton and switch enclosures Alubos • 20 profiles are available with profiles that are closed, split horizontally, and/or open on one side, for ergonomic hand-held enclosure designs. • High mechanical loading capacity of the profile and EMC screening ensure high level of protective functions Tastomat • 2 enclosures in sizes 251 x 91 x 46 mm to 251 x 91 x 80 mm • Application area: ideal for pushbutton or membrane keypad application ARTEB • 6 basic enclosures in sizes from 78 x 45 x 18 mm to 236 x 125 x 41mm • Application area: ideal for applications requiring a display screen or membrane keypad BOS • 9 enclosures in sizes from 100 x 65 x 24 mm to 224 x 106 x 40 mm • Application area: cost-effective handheld enclosure for mobile data collection and processing applications BOS-Streamline • 3 enclosures in sizes from 119.3 x 64.9 x 26.5 mm to 209.3 x 98.0 x 34.8 mm • Application area: ideal for applications requiring a display screen or membrane keypad 84 www.Rose-Bopla.com Taguan 130 / 180 / 230 • ABS hand held enclosure for data acquisition and instrumentation • With integrated battery/accumulator compartment • Versions with or without display opening • Prepared for acceptance of keypads/silicone switch mats Included in delivery Taguan 130: 5 piece enclosure with top and base, battery compartment, battery compartment cover, head and shaft surround, mounting and enclosure screws. Taguan 180/230: enclosure with top and base, keyboard surround, head and shaft surround, mounting and enclosure screws. Please order battery compartment separately. Taguan 130 Technical Data Color Material Ingress Protection Surface Resistance Impact Resistance Flammability Temperature Range Model Number Taguan 130 FO Taguan 130 FG Taguan 130 TO Taguan 130 TG Taguan 180 O Taguan 180 G Taguan 230 G Taguan 230 O Enclosure body - green blue, similar to RAL 5020. Models 180/230-keypad plate, battery compartment/pack, black-gray, similar to RAL 7021 ABS IP 40 to EN60529 4 x 1014 Ohm to DIN 53482 24 KV/mm to DIN 53481 UL 94 HB -40°F to +176°F Part Number Versions Dimensions mm WxLxH 27010200 00 27010201 00 27010210 00 27010211 00 27010400 00 27010401 00 27010600 00 27010601 00 Flat, open Flat, closed Deep, open Deep, closed Open Closed Open Closed 80/70 x 125 x 36.7 80/70 x 125 x 36.7 80/70 x 125 x 46 80/70 x 125 x 46 84/70 x 180 x 52.5/37.5 84/70 x 180 x 52.5/37.5 97/70 x 229 x 52.5/37.5 97/70 x 229 x 52.5/37.5 Dimensions Inches WxLxH Taguan 180/230 Weight 3.15/2.75 x 4.92 x 1.44 3.15/2.75 x 4.92 x 1.44 3.15/2.75 x 4.92 x 1.81 3.15/2.75 x 4.92 x 1.81 3.31/2.75 x 7.07 x 2.07/1.48 3.31/2.75 x 7.07 x 2.07/1.48 3.82/2.75 x 9.01 x 2.07/1.48 3.82/2.75 x 9.01 x 2.07/1.48 kg lbs 0.085 0.085 0.085 0.09 0.17 0.12 0.15 0.16 0.187 0.187 0.187 0.198 0.374 0.264 0.330 0.352 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Description Battery holder 4 round cells (T130) Battery holder 9 volt (T130) Battery holder for 9 volt (T180 / 230) Clip (T130) Keypad FT 130b, 12 printed keys (T130) Kaypad FT 130b, 12 keys with plug-in unit (T130) End plate in enclosure color End plate, transparent End plate, infra-red Battery compartment empty (T180 / 230) 0.03 kg Battery pack 1000 mAh Battery charging station 115 V Battery charging station 230 V Battery charging station without connector charger Docking station (T180 / 230) without connector charger Docking station (T180 / 230) with connector charger Angle brackets for PCBs for docking station Spring contact, 2-pole (T180 / 230) Part Number 27010280 00 27010281 00 27010094 00 27010282 00 82100001 00 82100002 00 27010285 00 27010286 00 27010287 00 27010080 00 27010081 00 27010084 00 27010086 00 27010088 00 27010096 00 27010097 00 27010098 00 27010082 00 Description Wrist strap (T 180 / 230) Display assembly set (T 180) Display assembly set (T 230) Switch mat set (T 180 / 230) Switch mat set (T 230) Switch mat set (T 180 / 230) Hand strap (T 180) Hand strap (T 230) Spare display screen set (T 130) Spare display screen set (T180) Spare display screen set (T 230) Spare screws Head cover, stepped, in enclosure color (T 180/230) Head cover, stepped for infra-red (T 180 / 230) Head cover, stepped, transparent (T 180 / 230) Head cover, straight, in enclosure color (T180 / 230) Head cover, straight, in enclosure color (T 180 / 230) Head cover, straight, in enclosure color (T 180 / 230) For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 Part Number 27010083 00 27010480 00 27010680 00 27010481 00 27010681 00 27010095 00 27010484 00 27010684 00 27010288 00 27010488 00 27010688 00 27010090 00 27010085 00 27010087 00 27010089 00 27010091 00 27010092 00 27010093 00 85 Beluga 180 / 220 / 380 • Polyamide hand held enclosure for measurement control automation engineering • Ergonomic enclosure shape • Versions with or without display opening • Prepared for acceptance of keypads/silicone switch mats Included in delivery Beluga 180/220: enclosure with top and base unit, each with mounting bosses, fastening and enclosure screws. Beluga 380: enclosure with top and base unit, each with mounting bosses, mounting hook/set, fastening and enclosure screws. Beluga 180/220 Technical Data Color Material Ingress Protection Surface Resistance Impact Resistance Flammability Temperature Range Black-gray, similar to RAL 7021 Polyamide IP 65 to EN 60529 1012 Ohm to DIN 53482 >7 Nm to DIN 50014 UL 94 V2 -40°F to +140°F Beluga 380 Model Number Part Number Versions Beluga 180 O Beluga 180 G Beluga 220 O Beluga 220 G Beluga 380 27020200 00 27020201 00 27020400 00 27020401 00 27020501 00 open closed open closed closed Dimensions mm WxLxH 106/75 x 187 x 50 106/75 x 187 x 50 116/85 x 220 x 51 116/85 x 220 x 51 380 x 117 x 68 Dimensions Inches WxLxH 4.17/2.95 x 7.36 x 1.97 4.17/2.95 x 7.36 x 1.97 4.57/3.35 x 8.66 x 2.01 4.57/3.35 x 8.66 x 2.01 14.96 x 4.61 x 2.68 Weight kg lbs 0.16 0.17 0.20 0.21 0.52 0.35 0.37 0.44 0.46 1.15 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Description Hook set without magnet (B180 / 220) Hook set with magnet (B180 / 220) Keypad FT 180e, 15 keys, printed (B180) Keypad FT 180e, 15 keys, with plug-in unit (B180) Keypad FT 220e, 18 keys, printed (B220) Keypad FT 220b, 18 keys, with plug-in unit (B220) Display assembly set (B180) Display assembly set, (B220) Cable gland with bending protection M 16 x 1.5 Cable gland with bending protection M 20 x 1.5 Hand strap (B180/220) Carrying strap (B380) 86 Part Number 27020080 00 27020081 00 82100003 00 82100004 00 82100005 00 82100006 00 27010680 00 27020482 00 08100116 00 08100120 00 27020083 00 28020580 00 Description Hand strap (B 380) Wall holder (B 380) Spare screws (B 180 / 220) Spare screws (B 380) Spare display screen set (B 180) Spare display screen set (B 220) 2-stage enable button, blue Battery compartment (B 180 / 220) Battery holder for 4 round cells for battery compartment Battery holder for 9 V battery for battery compartment Hook set for wall-mounting (B 180/220) Part Number 27020581 00 27020582 00 27020082 00 27020583 00 27010688 00 27020483 00 83500001 00 27020085 00 27020086 00 27020087 00 27020084 00 www.Rose-Bopla.com Limanda • Polyamide hand held enclosure for automation engineering measurement control and data acquisition • Large component space • Interface ports for acceptance of interfaces • Variable enclosure depth (optional) • Handle set for acceptance of enable button and batteries Included in delivery Enclosure with upper and lower mold, each with mounting bosses including seal and border profile, 3 cover panels for interface compartments, screws and material for front panel mounting. Front panels must be ordered separately. Technical Data Color Material Ingress Protection Surface Resistance Disruptive Strength Flammability Temperature Range Enclosure Type Limanda I Limanda I EMC Limanda I for OP17 Limanda II Black-gray, similar to RAL 7021 Polyamide enclosure, anodized aluminum front panel IP 65 to EN 60529, NEMA 12 1012 Ohm to DIN 53482 >7Nm to DIN 50014 UL 94 V2 -40°F to +140°F Part Number 27030300 00 27030301 00 27030317 00 27030200 00 Dimensions mm WxLxH 311 x 281 x 72 311 x 281 x 72 311 x 281 x 97 270 x 248 x 64 Dimensions Inches Weight WxLxH kg lbs 12.24 x 11.06 x 2.83 12.24 x 11.06 x 2.83 12.24 x 11.06 x 3.82 10.63 x 9.76 x 2.52 0.9 1.0 1.4 0.7 1.98 2.20 3.09 1.54 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Description Limanda I front plate aluminum, natural anodized finish Limanda I EMC front plate Limanda II front plate, aluminum, natural anodized finish Limanda I intermediate frame Limanda I EMC intermediate frame Limanda I handle set without push button Limanda holder Limanda I carrying strap Limanda I quiver Limanda II table stand ( set = 2 pieces) Limanda II quiver Limanda I handle set with 3-stage enable button (right-hand version) Limanda I handle set with 3-stage enable button (left-hand version) Enable button (2-stage/1 make contact) Emergency off switch (2 break contacts) Cable connection with bending protection M 16 Cable connection with bending protection M 20 Cable connection with bending protection M 25 Inclination adapter for mounting directly on wall or machine Inclination adapter for mounting directly onto 4949 Suspension System Inclination adapter for mounting directly onto 4945 Suspension System Inclination adapter for mounting directly on 4945 Suspension System Inclination adapter for Limanda bracket on 4949 Suspension System Inclination adapter for Limanda bracket on 4945 Suspension System Inclination adapter for Limanda bracket on wall or machine For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 Part Number 27030380 00 27030390 00 27030280 00 27030381 00 27030088 00 27030083 00 27030084 00 27030085 00 27030086 00 27030087 00 27030089 00 85701001 00 85701002 00 83500001 00 83500002 00 08100116 00 08100120 00 08100125 00 50020001 00 50020002 00 50020003 00 50020004 00 50020005 00 50020006 00 50020007 00 87 Pilot 250 • Polyamide hand held enclosure for automation engineering and data acquisition • Large component space • Version 3 with closed or front frame • Rear battery compartment Included in delivery Enclosure with top and base unit, each with mounting bosses, battery compartment cover, fastening and enclosure screws. Technical Data Color Base and lid: black gray, similar to RAL 7021 Rear cover: sapphire blue, similar to RAL 5003 Polyamide IP 65 to EN 60529 Continuous foamed-in Neoprene >7 Nm, EN 50014 -40°F to +140 ° F Material Ingress Protection Gasket Impact Resistance Temperature Range Enclosure Type Pilot 250/1 Pilot 250/2 Part Number 29250001 00 29250002 00 Dimensions mm Dimensions Inches WxLxH WxLxH 140/120 x 280 x 86 140/120 x 280 x 86 5.51/4.72 x 11.02 x 3.38 5.51/4.72 x 11.02 x 3.38 Version Upper liner Closed as frame for front panel mounting Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Description Part Number Front panel, aluminum for Pilot 250/2 Magnet holder, round Battery holder for mounting 4 rounds cells in the enclosure base Battery holder for mounting a 9V battery in the enclosure base Mounting set (2 hooks, 2 bolts with screws) Cable gland with bending protection M 16 x 1.5 Cable gland with bending protection M 20 x 1.5 Enable button (3-stage) 29250101 00 29250102 00 29250103 00 29250104 00 29250105 00 08100116 00 08100120 00 on request 88 www.Rose-Bopla.com Mobile Controls Units 2911, 2912, 2913 • Polyamide hand held enclosure for automation engineering and data acquisition • Large component space • Variable length using profile technology • Optional EMC suitable version with internal enclosure in aluminum Included in delivery Enclosure system consisting of Polyamide internal enclosure with end caps, two PVC side cover profiles, aluminum front panel, rear panel, 2 external end caps, with M 25 x 1.5 threaded hole for cable gland. Technical Data Color End caps: yellow, similar to RAL 1021 Body and rear panel : black, similar to RAL 9005 Inner enclosure body: Polyamide Side cover: Black PVC extrusion Rear panel: Black laminated board, 3mm, plastic-coated End caps: Yellow polyamide IP 65 to EN 60529, NEMA 12 Neoprene >7 Nm, EN 50014 -4°F to +158°F Material Ingress Protection Gasket Impact Resistance Temperature Range External Dimensions mm WxLxH 191 x 280 x 76 191 x 330 x 76 191 x 440 x 76 Special length Dimensions Inches WxLxH Part Number Standard Complete Part Number EMC Complete Part Number Standard Enclosure Body with Front Panel Part Number Standard Rear Panel Separate Part Number Standard Front Panel Separate 7.52 x 11.02 x 2.99 7.52 x 12.99 x 2.99 7.52 x 17.32 x 2.99 Special length 29111000 00 29121000 00 29131000 00 29191000 00 29141000 00 29151000 00 29161000 00 29171000 00 29110000 00 29120000 00 29130000 00 29190000 00 29110001 00 29120001 00 29130001 00 29190001 00 29110002 00 29120002 00 29190002 00 29190002 00 Part Number Standard Rear Panel Recessed 29130003 00 - Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Description Part Number Wall mount element including enclosure modification Modification for crane cable gland Cable gland with bending protection M 25 x 1.5 Cable gland reduction M 25 / M 12 Cable gland reduction M 25 / M 16 Cable gland reduction M 25 / M 20 Crane cable gland for cable diameter 10-22 mm M4 spring nuts for internal mounting, set of 4 pieces PCB mounting set (4 pieces including spring nuts) Wall mount bracket (set single) Magnetic wall mount, 1 piece EMC cable gland with bending protection M 25 x 1.5 29001000 00 29000030 00 08100125 00 08102512 00 08102516 00 08102520 00 29000800 00 29000050 00 29000060 00 29000070 00 29000080 00 08100125 00 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 89 Mobile Controls Units 2930, 2940, 2950 • Hand held enclosure for measurement control and automation engineering • Robust design (Polyamide or Polyester) • Versions with handle and integrated cable entry (2940, 2930 standard) Included in delivery 2930/2940: enclosure with handle, including cable gland M 20 x 1.5, front panel with assembly screw and wall-mount bracket. 2950: two-part Polyester enclosure with self-adhesive aluminum front panel, enclosure screws and wall-mount bracket Technical Data Material Temperature Range Ingress Protection Gasket 2930, 2940 2950 2930, 2940 2950 2930, 2940 2950 2930, 2940 2950 Color Polyamide Polyester -40°F to +140°F -13°F to +194°F IP 65 to EN 60529 IP 66 to EN 60529 Stamped foam rubber gasket Round Neoprene gasket Yellow, similar to RAL 1021 Dimensions Including Handle Inches Dimensions Front Panel mm Dimensions Front Panel Inches Enclosure Type Part Number Dimensions Including Handle mm WxLxH WxLxH WxH WxH 2940 2930 2950 29400200 00 29300100 00 29500100 00 70 x 93 x 190 115 x 93 x 200 164 x 116 x 295 2.75 x 3.66 x 7.48 4.53 x 3.66 x 7.87 6.46 x 4.57 x 11.61 61 x 59 106 x 69 70 x 280 2.40 x 2.32 4.17 x 2.72 2.75 x 11.02 Mounting Depth mm Mounting Depth Inches 67 67 71 2.64 2.64 2.79 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Description Mounting plate 2930 Wall-mount bracket (2 pieces with screws) Cable gland M 25 x 1.5 (2950) 90 Part Number 29310000 00 29600100 00 08100125 00 www.Rose-Bopla.com Mobile Controls Units 2921 • Polyamide hand held enclosure for automation and control technology • Version with handle and integrated cable exit • Large component space Included in delivery Enclosure with handle, including cable gland M 20 x 1.5, front panel, enclosure and front panel screws, and wall-mount bracket. Technical Data Material Body Cable Gland Material Front Panel Material Body color Ingress Protection Impact Resistance Gasket Material Temperature Resistance Enclosure Type Part Number Pilot 110 Pilot 120 Pilot 130 Pilot 140 Pilot 150 29211000 00 29212000 00 29213000 00 29214000 00 29215000 00 Polyamide Polyamide Black Polyester Yellow, similar to RAL 1021 IP 65 to EN 60529, NEMA 12 >7 Nm, EN 50014 Stamped foam rubber -40° to +140°F Dimensions Including Handle mm Dimensions Including Handle Inches Dimensions Front Panel mm Dimensions Front Panel Inches WxLxH WxLxH WxH WxH 85 x 85 x 206 115 x 85 x 206 85 x 85 x 236 160 x 85 x 226 105 x 85 x 281 3.35 x 3.35 x 8.11 4.53 x 3.35 x 8.11 3.35 x 3.35 x 9.29 6.30 x 3.35 x 8.90 4.13 x 3.35 x 11.06 77 x 77 107 x 77 77 x 107 152 x 97 97 x 152 3.03 x 3.03 4.21 x 3.03 3.03 x 4.21 5.98 x 3.82 3.82 x 5.98 Mounting Depth mm Mounting Depth Inches 63.5 63.5 63.5 63.5 63.5 2.5 2.5 2.5 2.5 2.5 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Description Part Number External wall mounting bracket Extra power cable PG 11 Extra power cable PG 16 Magnetic holder, self-adhesive External wall mounting bracket for 29214000 and 29215000 10094657 00 10087222 00 10087224 00 29000080 00 10094657 00 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 91 Tastomat • Developed for use as a factory floor control unit in tough operating conditions • Gasketed to provide an ingress protection of IP 65 and made of glassbead-reinforced polyamide. • Designed for easier handling with molded-in ribs in the bottom half of the enclosure Included in delivery Lid with seal, base, 6 enclosure screws M 4 x 28 and 4 self-tapping screws for mounting plate Technical Data Material Color Ingress Protection Flammability Polyamide, 30% glassbead-reinforced Light gray, similar to RAL 7035. Special colors on request. Minimum order quanitites apply IP 65 to DIN EN 60529 UL 94 HB/1.6 Model Number Part Number TAS 100 TAS 200 08100000 00 08200000 00 Dimensions mm Dimensions Inches LxWxH LxWxH 251 x 91 x 46 251 x 91 x 80 9.88 x 3.58 x 1.81 9.88 x 3.58 x 3.15 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. 92 www.Rose-Bopla.com ARTEB 115 / 225 / 335 / 555 / 655 / 865 • Ergonomic handheld enclosure made of durable ABS plastic • Design concept spanning 6 sizes in numerous combinations with end caps in black and 6 colors • All sizes are membrane keypad ready • Battery compartments with integrated front panels to prevent contact with other built-in components Included in delivery ART 115: Lid and base, screw, screw cover ART 225, 335: Lid and base ART 555, 655, 865: Lids and bases including tool operated snap locks for caps Please order end caps separately. Technical Data Material Color Ingress Protection Flammability Temperature Resistance Model Number ART 115 F ART 225 F ART 335 DIS ART 335 F ART 555 DIS ART 555 F ART 555 DIS with BE 30 ART 555 F with BE 30 ART 555 DIS with BE 60 ART 555 F with BE 60 ART 655 DIS ART 655 F ART 655 DIS with BE 30 ART 655 F with BE 30 ART 655 DIS with BE 60 ART 655 F with BE 60 ART 865 DIS ART 865 F ART 865 DIS with BE 30 ART 865 F with BE 30 ART 865 DIS with BE 60 ART 865 F with BE 60 ABS Agate gray, similar to RAL 7038. Special colors available. Minimum order quantities apply. ART 115: IP 40/DIN EN 60529; ART 225 up to 865, IP 40/DIN EN 60529, can be increased to IP 65/DIN EN 60529 with set of seals ART..DI UL 94 HB/1.6 -58°F to +158°F Part Number 34111511 00 34122511 00 34133512 00 34133511 00 34155512 00 34155511 00 34155582 00 34155581 00 34155592 00 34155591 00 34165512 00 34165511 00 34165582 00 34165581 00 34165592 00 34165591 00 34186512 00 34186511 00 34186582 00 34186581 00 34186592 00 34186591 00 Dimensions mm LxWxH 78 x 45 x 18 98 x 55 x 20 130 x 75 x 26 130 x 75 x 26 165 x 92 x 30 165 x 92 x 30 165 x 92 x 30 165 x 92 x 30 165 x 92 x 30 165 x 92 x 30 204 x 110 x 41 204 x 110 x 41 204 x 110 x 41 204 x 110 x 41 204 x 110 x 41 204 x 110 x 41 236 x 125 x 41 236 x 125 x 41 236 x 125 x 41 236 x 125 x 41 236 x 125 x 41 236 x 125 x 41 Dimensions Inches LxWxH 3.07 x 1.77 x 0.71 3.86 x 2.16 x 0.79 5.12 x 2.95 x 1.02 5.12 x 2.95 x 1.02 6.50 x 3.62 x 1.18 6.50 x 3.62 x 1.18 6.50 x 3.62 x 1.18 6.50 x 3.62 x 1.18 6.50 x 3.62 x 1.18 6.50 x 3.62 x 1.18 8.03 x 4.33 x 1.61 8.03 x 4.33 x 1.61 8.03 x 4.33 x 1.61 8.03 x 4.33 x 1.61 8.03 x 4.33 x 1.61 8.03 x 4.33 x 1.61 9.29 x 4.92 x 1.61 9.29 x 4.92 x 1.61 9.29 x 4.92 x 1.61 9.29 x 4.92 x 1.61 9.29 x 4.92 x 1.61 9.29 x 4.92 x 1.61 F= continuous membrane area DIS = display opening BE=battery compartment Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 93 Accessories Model Number ART 115 KO-1016 ART 115 KO-3000 ART 115 KO-5015 ART 115 KO-6027 ART 115 KO-7037 ART 115 KO-7038 ART 115 KO-IR ART 225 KO-1016 ART 225 KO-3000 ART 225 KO-5015 ART 225 KO-6027 ART 225 KO-7037 ART 225 KO-7038 ART 225 KO-IR ART 225 KU-1016 ART 225 KU-3000 ART 225 KU-5015 ART 225 KU-6027 ART 225 KU-7037 ART 225 KU-7038 ART 225 KO-IR ART 225 DI ART 335 KO-1016 ART 335 KO-3000 ART 335 KO-5015 ART 335 KO-6027 ART 335 KO-7037 ART 335 KO-7038 ART 335 KO-IR ART 335 KU-1016 ART 335 KU-3000 ART 335 KU-5015 ART 335 KU-6027 ART 335 KU-7037 ART 335 KU-7038 ART 335 KO-IR ART 335 BTU 1 ART 335 BTU 2 ART 335-DI ART 335 DIS ART 555 KO-1016 ART 555 KO-3000 ART 555 KO-5015 ART 555 KO-6027 ART 555 KO-7037 ART 555 KO-7038 ART 555 KO-IR ART 555 KU-1016 ART 555 KU-3000 ART 555 KU-5015 ART 555 KU-6027 ART 555 KU-7037 ART 555 KU-7038 Part Number 34111523 00 34111525 00 34111527 00 34111522 00 34111524 00 34111521 00 34111526 00 34122523 00 34122525 00 34122527 00 34122522 00 34122524 00 34122521 00 34122526 00 34122533 00 34122535 00 34122537 00 34122532 00 34122534 00 34122531 00 34122526 00 34122551 00 34133523 00 34133525 00 34133527 00 34133522 00 34133524 00 34133521 00 34133526 00 34133533 00 34133535 00 34133537 00 34133532 00 34133534 00 34133531 00 34133526 00 34133541 00 34133542 00 34133551 00 34130041 00 34155523 00 34155525 00 34155527 00 34155522 00 34155524 00 34155521 00 34155526 00 34155533 00 34155535 00 34155537 00 34155532 00 34155534 00 34155531 00 Description Top end caps, sulphur yellow, similar to RAL 1016 (5 pcs.) Top end caps, flame red, similar to RAL 3000 (5 pcs.) Top end caps, sky blue, similar to RAL 5015 (5 pcs.) Top end caps, light green, similar to RAL 6027 (5 pcs.) Top end caps, dust gray, similar to RAL 7037 (5 pcs.) Top end caps, agate gray, similar to RAL 7038 (5 pcs.) Top end caps, black, infrared-permissive (5 pcs.) Top end caps, sulphur yellow, similar to RAL 1016 (5 pcs.) Top end caps, flame red, similar to RAL 3000 (5 pcs.) Top end caps, sky blue, similar to RAL 5015 (5 pcs.) Top end caps, light green, similar to RAL 6027 (5 pcs.) Top end caps, dust gray, similar to RAL 7037 (5 pcs.) Top end caps, agate gray, similar to RAL 7038 (5 pcs.) Top end caps, black, infrared-permissive (5 pcs.) Bottom end caps, sulphur yellow, similar to RAL 1016 (5 pcs.) Bottom end caps, flame red, similar to RAL 3000 (5 pcs.) Bottom end caps, sky blue, similar to RAL 5015 (5 pcs.) Bottom end caps, light green, similar to RAL 6027 (5 pcs.) Bottom end caps, dust gray, similar to RAL 7037 (5 pcs.) Bottom end caps, agate gray, similar to RAL 7038 (5 pcs.) Bottom end caps, black, infrared-permissive (5 pcs.) Seal set for ARTEB 225 to achieve IP 65 (5 pcs.) Top end caps, sulphur yellow, similar to RAL 1016 (5 pcs.) Top end caps, flame red, similar to RAL 3000 (5 pcs.) Top end caps, sky blue, similar to RAL 5015 (5 pcs.) Top end caps, light green, similar to RAL 6027 (5 pcs.) Top end caps, dust gray, similar to RAL 7037 (5 pcs.) Top end caps, agate gray, similar to RAL 7038 (5 pcs.) Top end caps, black, infrared-permissive (5 pcs.) Bottom end caps, sulphur yellow, similar to RAL 1016 (5 pcs.) Bottom end caps, flame red, similar to RAL 3000 (5 pcs.) Bottom end caps, sky blue, similar to RAL 5015 (5 pcs.) Bottom end caps, light green, similar to RAL 6027 (5 pcs.) Bottom end caps, dust gray, similar to RAL 7037 (5 pcs.) Bottom end caps, agate gray, similar to RAL 7038 (5 pcs.) Bottom end caps, black, infrared-permissive (5 pcs.) Partitiions for battery compartment (5 pcs.) Partitions for battery compartment (5 pcs.) Seal set for ARTEB 335 to achieve IP 65 (5 pcs.) Display screen for ARTEB 335 DIS (5 pcs.) Top end caps, sulphur yellow, similar to RAL 1016 (5 pcs.) Top end caps, flame red, similar to RAL 3000 (5 pcs.) Top end caps, sky blue, similar to RAL 5015 (5 pcs.) Top end caps, light green, similar to RAL 6027 (5 pcs.) Top end caps, dust gray, similar to RAL 7037 (5 pcs.) Top end caps, agate gray, similar to RAL 7038 (5 pcs.) Top end caps, black, infrared-permissive (5 pcs.) Bottom end caps, sulphur yellow, similar to RAL 1016 (5 pcs.) Bottom end caps, flame red, similar to RAL 3000 (5 pcs.) Bottom end caps, sky blue, similar to RAL 5015 (5 pcs.) Bottom end caps, light green, similar to RAL 6027 (5 pcs.) Bottom end caps, dust gray, similar to RAL 7037 (5 pcs.) Bottom end caps, agate gray, similar to RAL 7038 (5 pcs.) KO = Cap at Top KU = Cap at Bottom 1 Connection with soldering tags Model Number ART 555 BEU-2MN ART 500 DIS ART 555-DI ART 555 BTU 1 ART 655 BEU-2MN ART 655 KO-1016 ART 655 KO-3000 ART 655 KO-5015 ART 655 KO-6027 ART 655 KO-7037 ART 655 KO-7038 ART 655 KO-IR ART 655 KU-1016 ART 655 KU-3000 ART 655 KU-1015 ART 655 KU-6027 ART 655 KU-7037 ART 655 KU-7038 ART 655 BTU 1 ART 655 BTU 2 ART 600 DIS ART 655-DI ART 865 BEU -2MN ART 865 KO-1016 ART 865 KO-3000 ART 865 KO-5015 ART 865 KO-6027 ART 865 KO-7037 ART 865 KO-7038 ART 865 KO-IR ART 865 KU-1016 ART 865 KU-3000 ART 865 KU-5015 ART 865 KU-6027 ART 865 KU-7037 ART 865 KU-7038 ART 865 BTU 1 ART 865 BTU 2 ART 865 BTU 3 ART 800 DIS ART 865-DI ART SV-HB-7038 ART SV-SR-7038 BH 2MC1 BH 4MC1 BH 2MN3 BH 3MN3 BH 4MN-BL3 BH 6MN-BL3 BH 9V CLIP ASC 1 Part Number 34155561 00 34150041 00 34155551 00 34155541 00 34165561 00 34165523 00 34165525 00 34165527 00 34165522 00 34165524 00 34165521 00 34165526 00 34165533 00 34165535 00 34165537 00 34165532 00 34165534 00 34165531 00 34165541 00 34165542 00 34160041 00 34165551 00 34165561 00 34186561 00 34186525 00 34165527 00 34186527 00 34186524 00 34186521 00 34186526 00 34186533 00 34186535 00 34186537 00 34186532 00 34186534 00 34186531 00 34186541 00 34186542 00 34186543 00 34180041 00 34186551 00 34155573 00 34155572 00 34165572 00 34165573 00 34165574 00 34165575 00 34165576 00 34165577 00 34165578 00 Description Battery shaft for ARTEB 555 (5 pcs.) Display screen for ARTEB 555 DIS (5 pcs.) Seal set for ARTEB 555 DIS to achieve IP 65 (5 pcs.) Partitions for battery compartment (5 pcs.) Battery shaft for ARTEB 655 (5 pcs.) Top end caps, sulphur yellow, similar to RAL 1016 (5 pcs.) Top end caps, flame red, similar to RAL 3000 (5 pcs.) Top end caps, sky blue, similar to RAL 5015 (5 pcs.) Top end caps, light green, similar to RAL 6027 (5 pcs.) Top end caps, dust gray, similar to RAL 7037 (5 pcs.) Top end caps, agate gray, similar to RAL 7038 (5 pcs.) Top end caps, infrared-permissive (5 pcs.) Bottom end caps, sulphur yellow, similar to RAL 1016 (5 pcs.) Bottom end caps, flame red, similar to RAL 3000 (5 pcs.) Bottom end caps, sky blue, similar to RAL 5015 (5 pcs.) Bottom end caps, light green, similar to RAL 6027 (5 pcs.) Bottom end caps, dust gray, similar to RAL 7037 (5 pcs.) Bottom end caps, agate gray, similar to RAL 7038 Partitions for battery compartment (5 pcs.) Partitions for battery compartment (5 pcs.) Display screen for ARTEB 655 DIS (5 pcs.) Seal set for ARTEB 655 to achieve IP 65 (5 pcs.) Battery shaft for ARTEB 865 (5 pcs.) Top end caps, sulfur yellow, similar to RAL 7035 (5 pcs.) Top end caps, flame red, similar to RAL 3000 (5 pcs.) Top end caps, sky blue, similar to RAL 5015 (5 pcs.) Top end caps, light green, similar to RAL 6027 (5 pcs.) Top end caps, dust gray, similar to RAL 7037 (5 pcs.) Top end caps, agate gray, similar to RAL 7038 Top end caps, infrared-permissive (5 pcs.) Bottom end caps, sulfur yellow, similar to RAL 7035 (5 pcs.) Bottom end caps, flame red, similar to RAL 3000 (5 pcs.) Bottom end caps, sky blue, similar to RAL 5015 (5 pcs.) Bottom end caps, light green, similar to RAL 6027 (5 pcs.) Bottom end caps, dust gray, similar to RAL 7037 (5 pcs.) Bottom end caps, agate gray, similar to RAL 7038 Partitions for battery compartment (5 pcs.) Partitions for battery compartment (5 pcs.) Partitions for battery compartment (5 pcs.) Display screen for ARTEB 865 DIS (5 pcs.) Seal set for ARTEB 865 to achieve IP 65 (5 pcs.) Hand operated snap lock (10 pcs.) Snap lock, blocking (10 pcs.) Battery holder L 52.6 x W 26.9 x H 12.0 (5 pcs.) Battery holder L 50.6 x W 17.8 x H 12.8 (5 pcs.) Battery holder L 58.04 x W31.9 x H 17.2 (5 pcs.) Battery holder L 58.24 x W 49.7 x H 17.5 (5 pcs.) Battery holder L 58.64 x W 33.0 x H31.6 (5 pcs.) Battery holder L 59.14 x W48.4 H 31.5 (5 pcs.) Cable: approximately 100mm long 34090010 00 Set-up clip, agate gray, similar to RAL 7038 34333574 00 Dismantling tool IR = Infrared Permissive 2 For battery shaft 3 Connection clip included 4 Length including clip: additional 8 mm Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. 94 www.Rose-Bopla.com ALUBOS • Ergonomic enclosure ideally suited to handheld or small instrument designs • Available with profiles that are closed, divided horizontally, or open on one side • High mechanical loading capacity of the profile and EMC screening ensure a high level of protective function. Included in delivery ABP: Closed extrusion only. Black powder-coated aluminum sold by the meter ABPH: Split extrusion only. Black powder-coated aluminum sold by the meter ABPU: Extrusion open on one side. Black powder-coated aluminum sold by the meter. Please order end caps and accessories separately. Technical Data Material Color Ingress Protection Aluminum extrusion, Al Mg Si 0.5, powdercoated; aluminum diecast lid GD-Al Si 12, powdercoated Powdercoated Satin Black, similar to RAL 9005, fine texture finish. Special colors on request. Minimum order quantities apply IP 65, DIN EN 60529 IP 40 when using parallel adapters (AP-AP) with 600, 800 and 1000 extrusions Model Number Part Number ABP 600-1000 ABP 800-1000 ABP 820-1000 ABP 1000-1000 ABP 1040-1000 ABP 1300-1000 ABP 1600-1000 ABP 1680-1000 ABP 2070-1000 ABPH 600-1000 ABPH 800-1000 ABPH 820-1000 ABPH 1000-1000 ABPH 1040-1000 ABPH 1300-1000 ABPH 1680-1000 ABPU 820-1000 ABPU 1040-1000 ABPU 1300-1000 ABPU 1680-1000 84060000 00 84080000 00 84820000 00 84100000 00 84040000 00 84130000 00 84160001 00 84680000 00 84207000 00 84066001 00 84086001 00 84826000 00 84106001 00 84046000 00 84136000 00 84686000 00 84827000 00 84047000 00 84137000 00 84687000 00 Dimensions mm Dimensions Inches LxWxH LxWxH 1000 x 57 x 32 1000 x 82 x 32 1000 x 82 x 22 1000 x 106 x 32 1000 x 108 x 32 1000 x 138 x 34 1000 x 169 x 52 1000 x 169 x 82 1000 x 210 x 74 1000 x 57 x 32 1000 x 82 x 32 1000 x 82 x 22 1000 x 106 x 32 1000 x 108 x 42 1000 x 138 x 34 1000 x 169 x 82 1000 x 82 x 22 1000 x 108 x 42 1000 x 138 x 34 1000 x 169 x 82 39.37 x 2.24 x 1.26 39.37 x 3.23 x 1.26 39.37 x 3.23 x 0.87 39.37 x 4.17 x 1.26 39.37 x 4.25 x 1.26 39.37 x 5.43 x 1.34 39.37 x 6.65 x 2.05 39.37 x 6.65 x 3.23 39.37 x 8.27 x 2.91 39.37 x 2.24 x 1.26 39.37 x 3.23 x 1.26 39.37 x 3.23 x 0.87 39.37 x 4.17 x 1.26 39.37 x 4.25 x 1.65 39.37 x 5.43 x 1.34 39.37 x 6.65 x 3.23 39.37 x 3.23 x 0.87 39.37 x 4.25 x 1.65 39.37 x 5.43 x 1.34 39.37 x 6.65 x 3.23 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Pictures top to bottom: Group shot showing application using parallel adapter (AB-AP) and axial adapter (ABA), as well as closed profiles with endcaps; Wall mount application using wall brackets (AB-WL); Application featuring handles (AB...HS); and Application using parallel adapter (AB-AP). For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 95 The Anatomy of ALUBOS SEALS Colored seals DI...provide ingress protection up to IP65 between the profile and the lid. Seals are available in 4 colors plus a black EMC seal DI...EMV. The EMC and standard seals are suitable for a temperature range of -15°C to +50°. VO seals for temperature ranges from -30°C to +85°C are available on request. ABP Profile closed version ABM...SAL Mounting lid with recessed surface for plugs, inserts, etc. Can be sealed watertight. ABD End lid with recessed surface for front membranes or membrane keypads. Depending on requirements, various lid designs are available to complete the Alubos. These designs include simple end lids, lids with battery compartments, and mounting lids with aluminum caps or infrared-permissive plastic caps. 96 Diecast aluminum lids, diecast aluminum mounting lid with aluminum hinged flap, and diecast aluminum mounting lid with aluminum profile cap. All lids can be sealed with colored gaskets up to IP 65. ABPH Profile Version with horizontal split for mounting components that protrude through the key surface. All profiles feature integral grooves for inserting PCBs. ABM...IR / ABM...AL Mounting lid with a recessed assembly surface for example, plugs, inserts, etc. These lids can be sealed watertight with a push-on cap. ABM...IR Infrared-permissive plastic cap. ABM...AL Aluminum cap All mounting lids are available with battery comparment ABM...BE for 9V block batteries. ABPU Profile—open on one side Diecast aluminum lids with recessed surface for mounting front membranes or membrane keypads. Colored seals provide ingress protection up to IP 65. www.Rose-Bopla.com Accessories Model Number Part Number ABM 600 AL AMB 600 IR ABM 600 SAL ABM 600 AL-BE ABM 600 IR-BE 84602000 00 84063000 00 84064000 00 84062100 00 84063100 00 ABM 600 SAL-BE ABD 600 DI 600-EMV DI 600-5002 DI 600-3000 DI 600-1021 DI 600-6000 ABM 800 AL ABM 800 IR ABM 800 SAL ABM 800 AL-BE ABM 800 IR-BE 84064100 00 84061000 00 84200615 00 84200614 00 84200611 00 84200612 00 84200613 00 84082000 00 84083000 00 84084000 00 84082100 00 84083100 00 ABM 800 SAL-BE ABD 800 ABA 800-1000 DI 800-EMV DI 800-5002 DI 800-3000 DI 800-1021 DI 800-6000 ABD 820 DI 820-EMV DI 820-5002 DI 820-3000 DI 820-1021 DI 820-6000 ABPU 820-1000 FP2 ABM 1000 AL ABM 1000 IR ABM 1000 SAL AMB 1000 AL-BE ABM 1000 IR-BE 84084100 00 84081000 00 84002000 00 84200815 00 84200814 00 84200811 00 84200812 00 84200813 00 84821000 00 84208215 00 84208214 00 84208211 00 84208212 00 84208213 00 84828000 00 84102000 00 84103000 00 84104000 00 84202100 00 84103100 00 ABM 1000 SAL-BE ABD 1000 ABA 800-1000 DI 1000-EMV DI 1000-5002 DI 1000-3000 DI 1000-1021 DI 1000-6000 ABM 1040 AL ABM 1040 SAL ABM 1040 DI 1040-EMV 84104100 00 84101000 00 84002000 00 84201015 00 84201014 00 84201011 00 84201012 00 84201013 00 84042000 00 84044000 00 84041000 00 84200415 00 Model Number Description Mounting lid, aluminum profile cap Mounting lid, infrared-permissive plastic cap Mounting lid, aluminum hinged flap Mounting lid, aluminum profile cap, battery compartment 9V Mounting lid, infrared-permissive plastic cap, battery compartment 9V Mounting lid, aluminum hinged flap, battery compartment 9V End lid EMC seal, black (10 pieces) Seal, ultramarine (10 pieces) Seal, flame red (10 pieces) Seal, yellow (10 pieces) Seal, patina green (10 pieces) Mounting lid, aluminum profile cap Mounting lid, infrared-permissive plastic cap Mounting lid, aluminum hinged flap Mounting lid, aluminum profile cap, battery compartment 9V Mounting lid, infrared-permissive plastic cap, battery compartment 9V Mounting lid, aluminum hinged flap, battery compartment 9V End lid, powder-coated aluminum Axial adapter for ALUBOS 800/100 EMC seal, black (10 pieces) Seal, ultramarine (10 pieces) Seal, flame red (10 pieces) Seal, yellow (10 pieces) Seal, patina green (10 pieces) End lid, black seal, screws, screw cover EMC seal, black (10 pieces) Seal, ultramarine (10 pieces) Seal, flame red (10 pieces) Seal, yellow (10 pieces) Seal, patina green (10 pieces) Front panel for ABPU 820-1000 Mounting lid, aluminum profile cap Mounting lid, infrared-permissive plastic cap Mounting lid, aluminum hinged flap Mounting lid, aluminum profile cap, battery compartment 9V Mounting lid, infrared-permissive plastic cap, battery compartment 9V Mounting lid, aluminum hinged flap, battery compartment 9V End lid Axial adapter for ALUBOS 800/1000 EMC seal, black (10 pieces) Seal, ultramarine (10 pieces) Seal, flame red (10 pieces) Seal, yellow (10 pieces) Seal, patina green (10 pieces) Mounting lid, aluminum profile cap Mounting lid, aluminum hinged flap End lid EMC seal, black (10 pieces) Part Number Description DI 1040-5002 DI 1040-3000 DI 1040-1021 DI 1040-6000 ABPU 1040-1000 FP2 ABM 1300 AL ABD 1300 SAL ABM 1300 DI 1300-EMV DI 1300-5002 DI 1300-3000 DI 1300-1021 DI 1300-6000 ABPU 1300-1000 FP2 ABD 1600 84200414 00 84200411 00 84200412 00 84200413 00 84048000 00 84132000 00 84134000 00 84131000 00 84201315 00 84201314 00 84201311 00 84201312 00 84201313 00 84138000 00 84161000 00 DI 1600-EMV DI 1600-5002 DI 1600-3000 DI 1600-1021 DI 1600-6000 ABD 1680 84201615 00 84201614 00 84201616 00 84201612 00 84201613 00 84168100 00 DI 1680-EMV DI 1680-5002 DI 1680-3000 DI 1680-1021 DI 1680-6000 ABPU 1680-1000 FP3 ABD 2070 84206815 00 84206814 00 84206811 00 84206812 00 84206813 00 84689000 00 84271000 00 DI 2070-EMV DI 2070-5002 DI 2070-3000 DI 2070-1021 DI 2070-6000 AB-1000 WLV AB-WL AB-WL 1 AB-WL 2 AB-WL 3 AB 600 MKL AB 800 MKL AB 1000 MKL AB-MKL AB 1600 HS AB 2000 HS AB-AP 60 AB-AP 100 AB-AP 150 ABA 800-1000 AB-GF 84202715 00 84202714 00 84202711 00 84202712 00 84202713 00 84105000 00 84005000 00 84006001 00 84007000 00 84008000 00 84006600 00 84006400 00 84006500 00 84006300 00 84162000 00 84200000 00 84006000 00 84010000 00 84015000 00 84002000 00 84006700 00 Seal, ultramarine (10 pieces) Seal, flame red (10 pieces) Seal, yellow (10 pieces) Seal, patina green (10 pieces) Front panel for ABPU 1040-1000 Mounting lid, aluminum profile cap Mounting lid, aluminum hinged flap End lid EMC seal, black (10 pieces) Seal, ultramarine (10 pieces) Seal, flame red (10 Ppieces) Seal, yellow (10 pieces) Seal, patina green (10 pieces) Front panel for ABPU 1300-1000 End lid, black seals, screws, screw cover for ABD 1600-1000 EMC seal, black (10 pieces) Seal, ultramarine (10 pieces) Seal, flame red (10 pieces) Seal, yellow (10 pieces) Seal, patina green (10 pieces) End lid, black seals, screws, screw cover for ABD 1680-1000 EMC seal, black (10 pieces) Seal, ultramarine (10 pieces) Seal, flame red (10 pieces) Seal, yellow (10 pieces) Seal, patina green (10 pieces) Front panels for ABPU 1680-1000 End lid, black seals, screws, screw covers for ABP 2070-1000 EMC seal, black (10 pieces) Seal, ultramarine (10 pieces) Seal, flame red (10 pieces) Seal, yellow (10 pieces) Seal, patina green (10 pieces) ALUBOS adjustable wall bracket Wall brackets for use with 600/800/1000/1300 Wall brackets for use with 820 Wall brackets for use with 1040 Wall brackets for use with 1600/1680/2070 Mounting clamp for ALUBOS 600 Mounting clamp for ALUBOS 800 Mounting clamp for ALUBOS 1000 Mounting clamp for ALUBOS 600/800/1000 Handle for use with ALUBOS 1600/1680 Handle for use ALUBOS 2070 Parallel adapter for ALUBOS 600/800/1000, 60 mm length Parallel adapter for ALUBOS 600/800/1000, 100 mm length Parallel adapter for ALUBOS 600/800/1000, 150 mm length Axial adapter, adapts ABP 800 to an ABP 1000 Rubber feet Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Application showing battery compartment with a closed profile, diecast lid, and seal. Besides stationary wall brackets, as shown on page 95, an adjustable wall bracket is offered, which allows angles from 0° to 90°. For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 This Alubos mounting lid, ABM...SAL, can be sealed watertight, even with hinged flap. 97 Closed Profiles 98 Split Profiles U-Shaped Profiles www.Rose-Bopla.com BOS • Versatile ABS handheld enclosure available in either black or gray and over 50 configurations • Each enclosure provides different equipment features and accessories • Ideal enclosure for use with a wide range of mobile data collection and processing applications Included in delivery Lid, base, and enclosure screws as required. See website for more detailed information on various configurations. Technical Data Material Color Ingress Protection Surface Resistance Flammability Model Number BOS 400 BOS 400 ASC BOS 401 BOS 401 ASC BOS 500 BOS 501 BOS 502 BOS 503 BOS 600 BOS 601 BOS 602 BOS 700 BOS 701 BOS 704 BOS 705 BOS 750 BOS 751 BOS 752 BOS 753 BOS 754 BOS 755 BOS 756 BOS 757 BOS 758 BOS 759 BOS 760 BOS 761 BOS 800 BOS 801 BOS 802 BOS 803 BOS 804 BOS 805 BOS 807 BOS 808 BOS 900 BOS 901 BOS 902 BOS 903 BOS 910 BOS 911 BOS 912 BOS 913 ABS; display screen, clear polycarbonate Black, similar to RAL 9005 and/or agate gray, similar to RAL 7038. Special colors on request. IP 40/DIN VDE 0470 >1014 Ohm to DIN 53482 UL 94 HB/1.6 Type With battery compartment Includes integrated set-up clip Without battery compartment Includes integrated set-up clip With panoramic display screen With display screen Without display opening With membrane keypad area With display screen With membrane keypad area With loudspeaker grill With display opening and battery compartment With display opening and battery compartment With slide for switch With slide for switch With panoramic display screen With display screen With membrane keypad area With panoramic display screen With display screen With membrane keypad area With panoramic display screen, with slide for switch With display screen, with slide for switch With membrane keypad area, with slide for switch With panoramic display screen, with slide for switch With display screen, with slide for switch With membrane keypad area, with slide for switch With panoramic display screen With display screen Without display opening With panoramic display screen With display screen Without display opening With membrane keypad area With membrane keypad area Without battery compartment and carrying strap Without battery compartment with carrying strap With carrying strap With carrying strap Without battery compartment Without battery compartment With battery compartment With battery compartment Part Number Black Part Number Agate Gray 34400000 00 34400500 00 34401000 00 34401500 00 34500000 00 34501000 00 34502000 00 34503000 00 34600000 00 34601000 00 34602000 00 34700000 00 34701000 00 34704000 00 34705000 00 34750000 00 34751000 00 34752000 00 34753000 00 34754000 00 34755000 00 34756000 00 34757000 00 34758000 00 34759000 00 34760000 00 34761000 00 34800000 00 34801000 00 34802000 00 34803000 00 34804000 00 34805000 00 34807000 00 34808000 00 34900009 00 34901009 00 34902009 00 34903009 00 34910009 00 34911009 00 34912009 00 34913009 00 34500003 00 34501002 00 34502002 00 34503001 00 34750001 00 34751001 00 34752001 00 34754001 00 34755001 00 34800001 00 34801001 00 34802001 00 34803001 00 34804001 00 34805001 00 34807001 00 34808001 00 34900000 00 34901000 00 34902000 00 34903000 00 34910002 00 34911000 00 34912000 00 34913000 00 Dimensions mm Dimensions Inches LxWxH 100 x 65 x 24 100 x 65 x 24 100 x 65 x 24 100 x 65 x 24 120 x 60 x 25 120 x 60 x 25 120 x 60 x 25 120 x 60 x 25 172 x 77 x 25 172 x 77 x 25 172 x 77 x 25 150 x 80 x 30 150 x 80 x 30 150 x 80 x 30 150 x 80 x 30 157 x 84 x 30 157 x 84 x 30 157 x 84 x 30 157 x 84 x 30 157 x 84 x 30 157 x 84 x 30 157 x 84 x 30 157 x 84 x 30 157 x 84 x 30 157 x 84 x 30 157 x 84 x 30 157 x 84 x 30 196 x 100 x 40 196 x 100 x 40 196 x 100 x 40 196 x 100 x 40 196 x 100 x 40 196 x 100 x 40 196 x 100 x 40 196 x 100 x 40 211 x 100 x 26 211 x 100 x 26 211 x 100 x 26 224 x 106 x 26 224 x 106 x 40 224 x 106 x 40 224 x 106 x 40 224 x 106 x 40 LxWxH 3.94 x 2.56 x 0.94 3.94 x 2.56 x 0.94 3.94 x 2.56 x 0.94 3.94 x 2.56 x 0.94 4.72 x 2.36 x 0.98 4.72 x 2.36 x 0.98 4.72 x 2.36 x 0.98 4.72 x 2.36 x 0.98 6.77 x 3.03 x 0.98 6.77 x 3.03 x 0.98 6.77 x 3.03 x 0.98 5.90 x 3.15 x 1.18 5.90 x 3.15 x 1.18 5.90 x 3.15 x 1.18 5.90 x 3.15 x 1.18 6.18 x 3.31 x 1.18 6.18 x 3.31 x 1.18 6.18 x 3.31 x 1.18 6.18 x 3.31 x 1.18 6.18 x 3.31 x 1.18 6.18 x 3.31 x 1.18 6.18 x 3.31 x 1.18 6.18 x 3.31 x 1.18 6.18 x 3.31 x 1.18 6.18 x 3.31 x 1.18 6.18 x 3.31 x 1.18 6.18 x 3.31 x 1.18 7.72 x 3.94 x 1.57 7.72 x 3.94 x 1.57 7.72 x 3.94 x 1.57 7.72 x 3.94 x 1.57 7.72 x 3.94 x 1.57 7.72 x 3.94 x 1.57 7.72 x 3.94 x 1.57 7.72 x 3.94 x 1.57 8.31 x 3.94 x 1.02 8.31 x 3.94 x 1.02 8.31 x 3.94 x 1.02 8.82 x 4.17 x 1.02 8.82 x 4.17 x 1.57 8.82 x 4.17 x 1.57 8.82 x 4.17 x 1.57 8.82 x 4.17 x 1.57 Display Opening Battery Compartment For Ingress Protection DIN EN 60529 x x x x x x x x x x x x x x x x x x x x x x x x x x 9 Volt 9 Volt 9 Volt 9 Volt 9 Volt 9 Volt 9 Volt 9 Volt 3 AA 9 Volt 9 Volt 9 Volt 9 Volt 9 Volt 9 Volt 9 Volt 9 Volt 9 Volt 4 AA 4 AA 4 AA 4 AA 4 AA 2 - 9 Volt 4 AA 2 - 9 Volt IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 65 IP 65 IP 65 IP 65 IP 65 IP 65 IP 65 ASC = including integrated set-up clip Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 99 BOS-Streamline • The construction design permits parallel or inclined arrangement of the half-shells, as well as lengthwise and crosswise use • Can be used for graphic-capable displays or as a membrane keypad model with continuous membrane keypad • Ingress protection up to IP 65 depending on design. • Can be adapted to customers individual requirements with membrane keypads and displays as well as mechanical processing and printing Included in delivery BS 400/402/600/602/800/802 F: Lid and base, 4 screws BS 401/403/404/601/603/604/801/803/804 F: Lid and base, 4 screws, battery compartment including screws, battery contacts BS 400/402/600/602/800/802 DIS: Lid and base, display window, adhesive film, 4 screws BS 401/403/404/601/603/604/801/803/804 DIS: Lid and base, display window, adhesive film, 4 screws, battery compartment lid including screws, battery contacts Technical Data Color Enclosure: graphite gray, similar to RAL 7024. Light gray, similar to RAL 7035. Silver coated (minimum order 100 pieces) Special colors on request Material ABS plastic Protection Classifications IP 40, without seal IP 65 DIN EN 60529, with seal Model Number BS 400 F-7024 BS 400 F-7035 BS 400 F-S** BS 400 DIS-7024 BS 400 DIS-7035 BS 400 DIS-S** BS 401 F-7024 BS 401 F-7035 BS 401-F-S** BS 401 DIS-7024 BS 401 DIS-7035 BS 401 DIS-S** BS 402 F-7024 BS 402 F-7035 BS 402 F-S** BS 402 DIS-7024 BS 402 DIS-7035 BS 402 DIS-S** BS 403 F-7024 BS 403 F-7035 BS 403 F-S* BS 403 DIS-7024 BS 403 DIS-7035 BS 403 DIS-S** BS 404 F-7024 BS 404 F-7035 BS 404 F-S** BS 404 DIS-7024 BS 404 DIS-7035 BS 404 DIS-S** Part Number Dimensions mm LxWxH Dimensions Inches LxWxH 82400124 00 82400135 00 82400100 00 82400224 00 82400235 00 82400200 00 82401124 00 82401135 00 82401100 00 82401224 00 82401235 00 82401200 00 82402124 00 82402135 00 82402100 00 82402224 00 82402235 00 82402200 00 82403124 00 82403135 00 82403100 00 82403224 00 82403235 00 82403200 00 82404124 00 82404135 00 82404100 00 82404224 00 82404235 00 82404200 00 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 119.3 x 64.9 x 26.5 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 4.70 x 2.55 x 1.04 Protection Classification IP 40/IP 65* IP 40/IP 65* IP 40/IP 65* IP 40/IP 65* IP 40/IP 65* IP 40/IP 65* IP 40 IP 40 IP 40 IP 40 IP 40 IP 40 IP 65 IP 65 IP 65 IP 65 IP 65 IP 65 IP 40/IP 65* IP 40/IP 65* IP 40/IP 65* IP 40/IP 65* IP 40/IP 65* IP 40/IP 65* IP 65 IP 65 IP 65 IP 65 IP 65 IP 65 Description Continuous membrane surface, graphite gray similar to RAL 7024 Continuous membrane surface, light gray, similar to RAL 7035 Continuous membrane surface, silver With display cut-out, graphite gray, similar to RAL 7024 With display cut-out, light gray, similar to RAL 7035 With display cut-out, silver Continuous membrane surface, battery compartment 3 AAA, graphite gray, similar to RAL 7024 Continuous membrane surface, battery compartment 3 AAA, light gray, similar to RAL 7035 Continuous membrane surface, battery compartment 3 AAA, silver With display cut-out, battery compartment 3 AAA, graphite gray, similar to RAL 7024 With display cut-out, battery compartment 3 AAA, light gray, similar to RAL 7035 With display cut-out, battery compartment 3 AAA, silver Continuous membrane surface, fitted round cord seal, graphite gray, similar to RAL 7024 Continuous membrane surface, fitted round cord seal, light gray, similar to RAL 7035 Continuous membrane surface, fitted round cord seal, silver With display cut-out, fitted round cord seal, graphite gray, similar to RAL 7024 With display cut-out, fitted round cord seal, light gray, similar to RAL 7035 With display cut-out, fitted round cord seal, silver Continuous membrane surface, battery compartment 3 AAA, graphite gray, similar to RAL 7024 Continuous membrane surface, battery compartment 3 AAA, light gray, similar to RAL 7035 Continuous membrane surface, battery compartment 3 AAA, silver With display cut-out, battery compartment 3 AAA, graphite gray, similar to RAL 7024 With display cut-out, battery compartment 3 AAA, light gray, similar to RAL 7035 With display cut-out, battery compartment 3 AAA, silver Continuous membrane surface, battery compartment 3 AAA, fitted round cord seal graphite gray similar to RAL 7024 Continuous membrane surface, battery compartment 3 AAA, fitted round cord seal, light gray, similar to RAL 7035 Continuous membrane surface, battery compartment 3 AAA, fitted round cord seal, silver With display cut-out, battery compartment 3 AAA, fitted round cord seal, graphite gray, similar to RAL 7024 With display cut-out, battery compartment 3 AAA, fitted round cord seal, light gray, similar to RAL 7035 With display cut-out, battery compartment 3 AAA, fitted round cord seal, silver * IP 65 and anti-knock protection when decorative seal BS 400 DI-D... is used **Available on request - minimum order quantity 100 pieces Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. 100 www.Rose-Bopla.com Model Number Part Number BS 600 F-7024 BS 600 F-7035 BS 600 F-S** BS 600 DIS-7024 BS 600 DIS-7035 BS 600 DIS-S** BS 601 F-7024 BS 601 F-7035 BS 601 F-S** BS 601 DIS-7024 BS 601 DIS-7035 BS 601 DIS-S** BS 602 F-7024 BS 602 F-7035 BS 602 F-S** BS 602 DIS-7024 BS 602 DIS-7035 BS 602 DIS-S** BS 603 F-7024 BS 603 F-7035 BS 603 F-S** BS 603 DIS-7024 BS 603 DIS-7035 BS 603 DIS-S** BS 604 F-7024 BS 604 F-7035 BS 604 F-S** BS 604 DIS-7024 BS 604 DIS-7035 BS 604 DIS-S** BS 800 F-7024 BS 800 F-7035 BS 800 F-S** BS 800 DIS-7024 BS 800 DIS-7035 BS 800 DIS-S** BS 801 F-7024 BS 801 F-7035 BS 801 F-S** BS 801 DIS-7024 BS 801 DIS-7035 BS 801 DIS-S** BS 802 F-7024 BS 802 F-7035 BS 802 F-S** BS 802 DIS-7024 BS 802 DIS-7035 BS 802 DIS-S** BS 803 F-7024 BS 803 F-7035 BS 803 F-S** BS 803 DIS-7024 BS 803 DIS-7035 BS 803 DIS-S** BS 804 F-7024 BS 804 F-7035 BS 804 F-S** BS 804 DIS-7024 BS 804 DIS-7035 BS 804 DIS-S** 82600124 00 82600135 00 82600100 00 82600224 00 82600235 00 82600200 00 82601124 00 82601135 00 82601100 00 82601224 00 82601235 00 82601200 00 82602124 00 82602135 00 82602100 00 82602224 00 82602235 00 82602200 00 82603124 00 82603135 00 82603100 00 82603224 00 82603235 00 82603200 00 82604124 00 82604135 00 82604100 00 82604224 00 82604235 00 82604200 00 82800124 00 82800135 00 82800100 00 82800224 00 82800235 00 82800200 00 82801124 00 82801135 00 82801100 00 82801224 00 82801235 00 82801200 00 82802124 00 82802135 00 82502100 00 82802224 00 82802235 00 82802200 00 82803124 00 82803135 00 82803100 00 82803224 00 82803235 00 82803200 00 82804124 00 82804135 00 82804100 00 82804224 00 82804235 00 82804200 00 Dimensions mm LxWxH 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 159.4 x 77.9 x 33.5 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 209.3 x 98.0 x 34.8 External Protection Dimensions Description Classification Inches LxWxH 6.27 x 3.07 x 1.32 IP 40/65* Continuous membrane surface, graphite gray, similar to RAL 7024 6.27 x 3.07 x 1.32 IP 40/65* Continuous membrane surface, light gray, similar to RAL 7035 6.27 x 3.07 x 1.32 IP 40/65* Continuous membrane surface, silver 6.27 x 3.07 x 1.32 IP 40/65* With display cut-out, graphite gray, similar to RAL 7024 6.27 x 3.07 x 1.32 IP 40/65* With display cut-out, light gray, similar to RAL 7035 6.27 x 3.07 x 1.32 IP 40/65* With display cut-out, silver Continuous membrane surface, battery compartment 3 AA, graphite gray, similar to RAL 7024 6.27 x 3.07 x 1.32 IP 40 Continuous membrane surface, battery compartment 3 AA, light gray, similar to RAL 7035 6.27 x 3.07 x 1.32 IP 40 Continuous membrane surface, battery cmompartment 3 AA, silver 6.27 x 3.07 x 1.32 IP 40 With display cut-out, battery compartment 3 AA, graphite gray, similar to RAL 7024 6.27 x 3.07 x 1.32 IP 40 With display cut-out, battery compartment 3 AA, light gray, similar to RAL 7035 6.27 x 3.07 x 1.32 IP 40 With display cut-out, battery compartment 3 AA, silver 6.27 x 3.07 x 1.32 IP 40 Continuous membrane surface, fitted round cord seal, graphite gray, similar to RAL 7024 6.27 x 3.07 x 1.32 IP 65 Continuous membrane surface, fitted round cord seal, light gray, similar to RAL 7035 6.27 x 3.07 x 1.32 IP 65 Continuous membrane surface, fitted round cord seal, silver 6.27 x 3.07 x 1.32 IP 65 With display cut-out, fitted round cord seal, graphite gray, similar to RAL 7024 6.27 x 3.07 x 1.32 IP 65 With display cut-out, fitted round cord seal, light gray, similar to RAL 7035 6.27 x 3.07 x 1.32 IP 65 With display cut-out, fitted round cord seal, silver 6.27 x 3.07 x 1.32 IP 65 6.27 x 3.07 x 1.32 IP 40/65* Continuous membrane surface, battery compartment 3 AA, graphite gray, similar to RAL 7024 6.27 x 3.07 x 1.32 IP 40/65* Continuous membrane surface, battery compartment 3 AA, light gray, similar to RAL 7035 6.27 x 3.07 x 1.32 IP 40/65* Continuous membrane surface, battery compartment 3 AA, silver 6.27 x 3.07 x 1.32 IP 40/65* With display cut-out, battery compartment 3 AA, graphite gray, similar to RAL 7024 6.27 x 3.07 x 1.32 IP 40/65* With display cut-out, battery compartment 3 AA, light gray, similar to RAL 7035 6.27 x 3.07 x 1.32 IP 40/65* With display cut-out, battery compartment 3 AA. silver Continuous membrane surface, battery compartment 3 AA, fitted round cord seal, graphite gray, similar to RAL 7024 6.27 x 3.07 x 1.32 IP 65 Continuous membrane surface, battery compartment 3 AA, fitted round cord seal, light gray, similar to RAL 7035 6.27 x 3.07 x 1.32 IP 65 Continuous membrane surface, battery compartment 3 AA, fitted round cord seal, silver 6.27 x 3.07 x 1.32 IP 65 With display cut-put, battery compartment 3 AA, fitted round cord seal, graphite gray, similar to RAL 7024 6.27 x 3.07 x 1.32 IP 65 With display cut-out, battery compartment 3 AA, fitted round cord seal, light gray, similar to RAL 7035 6.27 x 3.07 x 1.32 IP 65 With display cut-out, battery compartment 3 AA, fitted round cord seal, silver 6.27 x 3.07 x 1.32 IP 65 8.24 x 3.86 x 1.37 IP 40/65* Continuous membrane surface, graphite gray, similar to RAL 7024 8.24 x 3.86 x 1.37 IP 40/65* Continuous membrane surface, light gray, similar to RAL 7035 8.24 x 3.86 x 1.37 IP 40/65* Continuous membrane surface, silver 8.24 x 3.86 x 1.37 IP 40/65* With display cut-out, graphite gray, similar to RAL 7024 8.24 x 3.86 x 1.37 IP 40/65* With display cut-out, light gray, similar to RAL 7035 8.24 x 3.86 x 1.37 IP 40/65* With display cut-out, silver Continuous membrane surface, battery compartment 4 AA, graphite gray, similar to RAL 7024 8.24 x 3.86 x 1.37 IP 40 Continuous membrane surface, battery compartment 4 AA, light gray, similar to RAL 7035 8.24 x 3.86 x 1.37 IP 40 Continuous membrane surface, battery compartment 4 AA, silver 8.24 x 3.86 x 1.37 IP 40 With display cut-out, battery compartment 4 AA, graphite gray, similar to RAL 7024 8.24 x 3.86 x 1.37 IP 40 With display cut-out, battery compartment 4 AA, light gray, similar to RAL 7035 8.24 x 3.86 x 1.37 IP 40 With display cut-out, battery compartment 4 AA, silver 8.24 x 3.86 x 1.37 IP 40 Continuous membrane surface, fitted round cord seal, graphite gray, similar to RAL 7024 8.24 x 3.86 x 1.37 IP 65 Continuous membrane surface, fitted round cord seal, light gray, similar to RAL 7035 8.24 x 3.86 x 1.37 IP 65 Continuous membrane surface, fitted round cord seal, silver 8.24 x 3.86 x 1.37 IP 65 With display cut-out, fitted round cord seal, graphite gray, similar to RAL 7024 8.24 x 3.86 x 1.37 IP 65 With display cut-out, fitted round cord seal, light gray, similar to RAL 7035 8.24 x 3.86 x 1.37 IP 65 With display cut-out, fitted round cord seal, silver 8.24 x 3.86 x 1.37 IP 65 8.24 x 3.86 x 1.37 IP 40/65* Continuous membrane surface, battery compartment 4 AA, graphite gray, similar to RAL 7024 8.24 x 3.86 x 1.37 IP 40/65* Continuous membrane surface, battery compartment 4 AA, light gray, similar to RAL 7035 8.24 x 3.86 x 1.37 IP 40/65* Continuous membrane surface, battery compartment 4 AA, silver 8.24 x 3.86 x 1.37 IP 40/65* With display cut-out, battery compartment 4 AA, graphite gray, similar to RAL 7024 8.24 x 3.86 x 1.37 IP 40/65* With display cut-out, battery compartment 4 AA, light gray, similar to RAL 7035 8.24 x 3.86 x 1.37 IP 40/65* With display cut-out, battery compartment 4 AA, silver Continuous membrane surface, fitted round cord seal, graphite gray, similar to RAL 7024 8.24 x 3.86 x 1.37 IP 65 Continuous membrane surface, fitted round cord seal, light gray, similar to RAL 7035 8.24 x 3.86 x 1.37 IP 65 Continuous membrane surface, fitted round cord seal, silver 8.24 x 3.86 x 1.37 IP 65 With display cut-out, battery compartment 4 AA, fitted round cord seal, graphite gray, similar to RAL 7024 8.24 x 3.86 x 1.37 IP 65 With display cut-out, battery compartment 4 AA, fitted round cord seal, light gray, similar to RAL 7035 8.24 x 3.86 x 1.37 IP 65 With display cut-out, battery compartment 4 AA, fitted round cord seal, silver 8.24 x 3.86 x 1.37 IP 65 * IP 65 and anti-knock protection when decorative seal BS 400 DI-D... is used **Available on request - minimum order quantity 100 pieces Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories Model Number BS 400 DI-D-1003 BS 400 DI-D-3001 BS 400 DI-D-5005 BS 400 DI-D-6032 BS 400 DI-D-7024 BS 600 DI-D-1003 BS 600 DI-D-3001 BS 600 DI-D-5005 BS 600 DI-D-6032 BS 600 DI-D-7024 Part Number 82841003 00 82843001 00 82845005 00 82846032 00 82847024 00 82861003 00 82863001 00 82865005 00 82866032 00 82867024 00 Description Decorative seal, signal yellow, similar to RAL 1003 Decorative seal, signal red, similar to RAL 3001 Decorative seal, signal blue, similar to RAL 5005 Decorative seal, signal green, similar to RAL 6032 Decorative seal, graphite gray, similar to RAL 7024 Decorative seal, signal yellow, similar to RAL 1003 Decorative seal, signal red, similar to RAL 3001 Decorative seal, signal blue, similar to RAL 5005 Decorative seal, signal green, similar to RAL 6032 Decorative seal, graphite gray, similar to RAL 7024 Model Number Part Number BS 800 DI-D-1003 BS 800 DI-D-3001 BS 800 DI-D-5005 BS 800 DI-D-6032 BS 800 DI-D-7024 BS SA-7024 BS SA-7035 82881003 00 82883001 00 82885005 00 82886032 00 82887024 00 82800011 00 82800010 00 Description Decorative seal, signal yellow, similar to RAL 1003 Decorative seal, signal red, similar to RAL 3001 Decorative seal, signal blue, similar to RAL 5005 Decorative seal, signal green, similar to RA: 6032 Decorative seal, graphite gray, similar to RAL 7024 Screw covers, graphite gray, similar to RAL 7024 Screw covers, light gray, similar to RAL 7035 Note: Screw covers are not required if decorative seal DI-D is used. For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 101 Ex enclosures Rose Ex enclosures made of aluminum, polyester and stainless steel correspond to ATEX guidelines. They have the approval II 2G/2D and may be used in zones 1 and 2. The standard temperature range for applications corresponds to T6, -4°F to +104°F; optionally aluminum and stainless steel enclosures can be used from -67°F to +203°F (corresponds to temperature classes T6, T5, T4); and polyester enclosures from -67°F to +131°F (corresponds to temperature classes T6, T5). Aluminum Ex Enclosures • Fully assembled enclosure with terminal blocks, cable glands and accessories • Empty enclosures, component certified Polyester Ex Enclosures • More that 60 variations in more than 20 different sizes • Worldwide use in all climate environments Okta-Box Enclosures • Fully assembled enclosure with terminal blocks, cable glands, and accessories. • 9 variations in 3 sizes. • Empty enclosure, component certified Stainless Steel Ex Enclosures • A rugged enclosure to meet the highest standards • Robust material, safe system, terminal enclosure for increased and intrinsic safety protection Stainless Steel Enclosures with Hinged Lid, Ex-IGS • Enclosures with hinged lid and terminals for instrinsic and increased safety protection • Empty enclosure with EC - type examination certificate for individual fittings Beluga • Handheld empty enclosures for applications in hazardous environments • 3 enclosure sizes, 180, 220, 380 mm and an optional display opening 102 www.Rose-Bopla.com Aluminum terminal enclosures E Ex e II T6 • Empty enclosures with EC-type examination certificate for individual fittings • Terminal enclosure for increased safety and intrinsically safe protection • Robust aluminum diecast enclosure in standard or flange type Included in delivery Empty enclosure: Enclosure with silicone seal and external ground connection Terminal enclosure: Enclosure system - depending on version either with silicone seal, external ground connection, DIN rails, internal ground connection, terminals, manufacturing, cable glands. PTB Technical Data Explosion protection II 2 G / 2 D Certificates Material Painting Color Ingress protection Impact resistance Temperature range of application acc. EN EEx e II T6 (increased safety) EEx ia IIC T6 (intrinsic safety) EEx e(ia) IIC T6 (mixed fitting) Temperature class T5 and T4 on request Empty enclosure: PTB 98 ATEX 3101U Terminal enclosure: PTB 00 ATEX 1063 Aluminum diecast AlSi 12 Powdercoating Gray, similar to RAL 7001 IP 66, EN 60529 >7 Nm, EN 50014 -20°F to +104°F (corresponds T6 = 185°F max. surface temperature) -20°F to +131°F (corresponds T5 = 212°F max. surface temperature) -20°F to +195°F (corresponds T4 = 275°F max. surface temperature) Temperature to -67°F with special marking on request Part Number Part Number Part Number Ex-e version EN 50014/ EN 50019 Ex-ia version EN 50014/ EN 50020 Empty enclosure EN 50014/ EN 50019 05060603 00 05061003 00 05061503 00 05080806 00 05081306 00 05081806 00 05082505 00 05101008 00 05101608 00 05102008 00 05121208 00 05121209 00 05122208 00 05122209 00 05123608 00 05141409 00 04142009 00 05161609 00 05162609 00 05163609 00 15060603 00 15061003 00 15061503 00 15080806 00 15081306 00 15081806 00 15082505 00 15101008 00 15101608 00 15102008 00 15121208 00 15121209 00 15122208 00 15122209 00 15123608 00 15141409 00 15142009 00 15161609 00 15162609 00 15163609 00 25060603 00 25061003 00 25161503 00 25080806 00 25081306 00 25081806 00 25082505 00 25101008 00 25101608 00 25102008 00 25121208 00 25121209 00 25122208 00 25122209 00 25123608 00 25141409 00 25142009 00 25161609 00 25162609 00 25163609 00 Dimensions mm WxLxH 64 x 58 x 34 64 x 98 x 34 64 x 150 x 34 80 x 75 x 57 80 x 125 x 57 80 x 175 x 57 80 x 250 x 52 100 x 100 x 80 100 x 160 x 80 100 x 200 x 80 120 x 122 x 80 120 x 122 x 90 120 x 220 x 80 120 x 220 x 90 120 x 360 x 80 140 x 140 x 90 140 x 200 x 90 160 x 160 x 90 160 x 260 x 90 160 x 360 x 90 Dimensions Inches WxLxH 2.52 x 2.28 x 1.34 2.52 x 3.86 x 1.34 2.52 x 5.90 x 1.34 3.15 x 2.95 x 2.24 3.15 x 4.92 x 2.24 3.15 x 6.89 x 2.24 3.15 x 9.84 x 2.24 3.94 x 3.94 x 3.15 3.94 x 6.30 x 3.15 3.94 x 7.87 x 3.15 4.72 x 4.80 x 3.15 4.72 x 4.80 x 3.54 4.72 x 8.66 x 3.15 4.72 x 8.66 x 3.54 4.72 x 14.17 x 3.15 5.51 x 5.51 x 3.54 5.51 x 7.87 x 3.54 6.30 x 6.30 x 3.54 6.30 x 10.24 x 3.54 6.30 x 14.17 x 3.54 Part Number Part Number Part Number Ex-e version EN 50014/ EN 50019 Ex-ia version EN 50014/ EN 50020 Empty enclosure EN 50014/ EN 50019 05165609 00 05181810 00 05182810 00 05231011 00 05232011 00 05232018 00 05232811 00 05233311 00 05233318 00 05234011 00 05234023 00 05236011 00 05314011 00 05314014 00 05314018 00 05314023 00 05316011 00 05316018 00 05606020 00 15165609 00 15181810 00 15182810 00 15231011 00 15232011 00 15232018 00 15232811 00 15233311 00 15233318 00 15234011 00 15234023 00 15236011 00 15314011 00 15314014 00 15314018 00 15314023 00 15316011 00 15316018 00 15606020 00 25165609 00 25181810 00 25182810 00 25231011 00 25232011 00 25232018 00 25232811 00 25233311 00 25233318 00 25234011 00 25234023 00 25236011 00 25314011 00 25314014 00 25314018 00 25314023 00 25316011 00 25316018 00 25606020 00 Dimensions mm WxLxH Dimensions Inches WxLxH 160 x 560 x 90 180 x 180 x 100 180 x 280 x 100 100 x 230 x 110 230 x 200 x 110 230 x 200 x 180 230 x 280 x 110 230 x 330 x 110 230 x 330 x 180 230 x 400 x 110 230 x 400 x 224 230 x 600 x 110 310 x 400 x 110 310 x 400 x 140 310 x 400 x 180 310 x 400 x 230 310 x 600 x 110 310 x 600 x 180 600 x 600 x 200 6.30 x 22.04 x 3.54 7.09 x 7.09 x 3.94 7.09 x 11.02 x 3.94 3.94 x 9.05 x 4.33 9.05 x 7.87 x 4.33 9.05 x 7.87 x 7.09 9.05 x 11.02 x 4.33 9.05 x 12.99 x 4.33 9.05 x 12.99 x 7.09 9.05 x 15.75 x 4.33 9.05 x 15.75 x 8.82 9.05 x 23.62 x 4.33 12.20 x 15.75 x 4.33 12.20 x 15.75 x 5.51 12.20 x 15.75 x 7.09 12.20 x 15.75 x 9.05 12.20 x 23.62 x 4.33 12.20 x 23.62 x 7.09 23.62 x 23.62 x 7.87 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 103 Fiberglass Terminal Enclosures E Ex e II T6 • Fiberglass enclosure with graphite added to reduce surface static • Terminal enclosure for increased safety and intrinsically safe protection • Empty enclosure for individual fittings with EG increased safeguard Included in delivery Empty enclosure: Enclosure system with silicone seal Terminal enclosure: Enclosure system - depending on version either with silicone seal, DIN rails, internal grounding connection, terminals, continuity plate, manufacturing, cable glands. Technical Data PTB Explosion protection II 2 G / 2 D EEx e II T6 (increased safety) EEx ia IIC T6 (intrinsic safety) EEx e(ia) IIC T6 (mixed fitting) Temperature classes T5 and T4 on request Empty enclosure: PTB 01 ATEX 1061U Terminal enclosure: PTB 00 ATEX 1002 Glassfiber-reinforced duroplastic Polyester, graphite added Black, similar to RAL 9011 IP 66, EN 60529 >7 Nm, EN 50014 self-extinguishing, UL 94/V0 7 Nm, EN 50014 self-extinguishing UL 94 V0 >109 Ohm, EN 50014 max. 0.7%, ASTM D570 Halogen free UV stabilized -40°F to +104°F (corresponds T6 = 185°F max. surface temperature) -40°F to +131°F (corresponds T5 = 212°F max. surface temperature) Temperature to -67°F with special marking on request Part Number Ex-ia version EN 50020 16880100 00 16880200 00 16880300 00 Part Number Empty enclosure EN 50019 26880100 00 26880200 00 26880300 00 Dimensions mm WxLxH Dimensions Inches WxLxH 80 x 80 x 70 120 x 120 x 75 160 x 160 x 93 3.15 x 3.15 x 2.75 4.72 x 4.72 x 2.95 6.30 x 6.30 x 3.66 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Part Number A B C D E F HU HD Htot 06880100 00 16880100 00 26880100 00 06880200 00 16880200 00 26880200 00 06880300 00 16880300 00 26880200 00 81 81 81 121 121 121 161 161 161 68 68 68 100 100 100 140 140 140 73 73 73 118 118 118 175 175 175 92 92 92 132 132 132 59 59 59 92 92 92 99 99 99 99 99 99 6.0.5 60.5 60.5 60.5 60.5 60.5 73 73 73 15 15 15 15 15 15 20 20 20 75.5 75.5 75.5 75.5 75.5 75.5 93 93 93 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 105 Ex Stainless Steel Enclosures • Terminal enclosure for increased safety and intrinsically safe protection • Empty enclosure for individual fittings with EC-type examination certificate • High quality stainless steel (1.4404) Included in delivery Empty enclosure: Enclosure with silicone/PUR seal and external ground connection. Terminal enclosure: Enclosure system-depending on version either with silicone/PUR seal, continuity plate, DIN rails, internal ground connection, terminals, manufacturing, cable glands. PTB Technical Data Explosion protection II 2 G / 2 D Certificates Material Surface Ingress protection Impact resistance Temperature range of application acc. EN EEx e II T6 (increased safety) EEx ia IIC T6 (intrinsic safety) EEx e(ia) IIC T6 (mixed fitting) Temperature class T5 and T4 on request Empty enclosure: PTB 01 ATEX 1101U Terminal enclosure: PTB 00 ATEX 1052 Stainless steel 1.25 mm or 1.5 mm 1.4404 / 316L Polished grain 240 IP 66 EN 60529 >7 Nm, EN 50014 -40°F to +104°F (corresponds T6 = 185°F max. surface temperature) -40°F to +131°F (corresponds T5 = 212°F max. surface temperature) -40°F to +194°F (corresponds T4 = 275°F max. surface temperature) Temperature to -67°F with special marking on request Part Number Ex-e version Part Number Ex-ia version Part Number Empty enclosure Dimensions mm WxLxH 35101006 00 35151006 00 35151508 00 35201006 00 35202008 00 35202012 00 35301508 00 35302008 00 35302012 00 35303012 00 35303016 00 35383816 00 35401508 00 35402012 00 35403016 00 35503016 00 35504016 00 35602012 00 35999999 00 36101006 00 36151006 00 36151508 00 36201006 00 36202008 00 36202012 00 36301508 00 36302008 00 36302012 00 36303012 00 36303016 00 36383816 00 36401508 00 36402012 00 36403016 00 36503016 00 36504016 00 36602012 00 36999999 00 34101006 00 34151006 00 34151508 00 34201006 00 34202008 00 34202012 00 34301508 00 34302008 00 34302012 00 34303012 00 34303016 00 34383816 00 34401508 00 34402012 00 34403016 00 34503016 00 34504016 00 34602012 00 34999999 00 100 x 100 x 61 150 x 100 x 61 150 x 150 x 81 200 x 100 x 61 200 x 200 x 81 200 x 200 x 121 300 x 150 x 81 300 x 200 x 81 300 x 200 x 121 300 x 300 x 121 300 x 300 x 161 380 x 380 x 151 400 x 150 x 81 400 x 200 x 121 400 x 300 x 161 500 x 300 x 161 500 x 400 x 161 600 x 200 x 121 Special size Dimensions Inches WxLxH 3.94 x 3.94 x 2.40 5.90 x 3.94 x 2.40 5.90 x 5.90 x 3.19 7.87 x 3.94 x 2.40 7.87 x 7.87 x 3.19 7.87 x 7.87 x 4.76 11.81 x 5.90 x 3.19 11.81 x 7.87 x 3.19 11.81 x 7.87 x 4.76 11.81 x 11.81 x 4.76 11.81 x 11.81 x 6.34 14.96 x 14.96 x 5.94 15.75 x 5.90 x 3.19 15.75 x 7.87 x 4.76 15.75 x 11.81 x 6.34 19.68 x 11.81 x 6.34 19.68 x 15.75 x 6.34 23.62 x 7.87 x 4.76 Special size Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories External brackets (4 pieces) Mounting set (gaskets, nuts and screws) External hinge set (2 pieces) 106 31105000 00 37990001 00 37000002 00 www.Rose-Bopla.com Ex Stainless Steel Enclosures with Hinged Lid Ex-IGS • Enclosure with EC-type examination certificate for individual fittings • Stainless steel enclosure with terminals for increased safety and intrinsically protection • High-quality stainless steel version with covered hinges and double ward lock • Optional flange break outs Included in delivery Empty enclosure: Enclosure with hinged lid, double ward lock, silicone/PUR-seal and external ground connection. Terminal enclosure: Depending on design with hinged lid, double ward lock, silicone/PUR-seal, external ground, DIN rail, internal ground connection, terminals, manufacturing, cable glands. PTB Technical Data Explosion protection II 2 G / 2 D Certificates Material Surface Ingress protection Impact resistance Temperature range of application acc. EN EEx e II T6 (increased safety) EEx ia IIC T6 (intrinsic safety) EEx e(ia) IIC T6 (mixed fitting) Temperature class T5 and T4 on request Empty enclosure: PTB 01 ATEX 1101U Terminal enclosure: PTB 00 ATEX 1052 Stainless steel 1.25 mm or 1.5 mm 1.4301 / 304 Polished grain 240 IP 66 EN 60529 >7 Nm, EN 50014 -40°F to +104°F (corresponds T6 = 185°F max. surface temperature) -40°F to +131°F (corresponds T5 = 212°F max. surface temperature) -40°F to +194°F (corresponds T4 = 275°F max. surface temperature) Temperature to -67°F with special marking on request Part Number Ex-e version Part Number Ex-ia version Part Number Empty enclosure 35002209 00 35002215 00 35003316 00 35003209 00 35004416 00 35004421 00 35005316 00 35006316 00 35006421 00 35009999 00 36002209 00 36002215 00 36003316 00 36003209 00 36004416 00 36004421 00 36005316 00 36006316 00 36006421 00 36009999 00 34002209 00 34002215 00 34003316 00 34003209 00 34004416 00 34004421 00 34005316 00 34006316 00 34006421 00 34009999 00 Dimensions mm WxLxH 200 x 250 x 90 200 x 250 x 150 300 x 300x 167 350 x 250 x 90 380 x 380 x 167 380 x 380 x 215 500 x 300 x 167 600 x 300 x 167 300 x 380 x 215 Special size Dimensions Inches WxLxH 7.87 x 9.84 x 3.54 7.87 x 9.84 x 5.90 11.81 x 11.81 x 6.57 13.78 x 9.84 x 3.54 14.96 x 14.96 x 6.57 14.96 x 14.96 x 8.46 19.68 x 11.81 x 6.57 23.62 x 11.81 x 6.57 23.62 x 14.96 x 8.46 Special size Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Accessories External brackets (4 pieces) Mounting set (gaskets, nuts and screws) 37105000 00 37990001 00 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 107 Beluga • Hand enclosure for potentially explosive environments • 3 enclosure sizes 180, 220, 380 mm • Optionally with display opening Included in delivery Lid, base and enclosure screws. See options below. Technical Data Explosion protection Certificates Material Surface resistance Flammability Color Ingress protection Impact resistance Temperature range PTB II 2 G / EEx e II Empty enclosure: PTB 02 ATEX 1076U Polyamide 12 7 Nm, EN 50014 -4°F to +140°F Beluga 180 Consisting of top and bottom part, enclosure and board mounting screws, sealing ring, tongue-and-groove system with integrated seal. Open version comes complete with display screen and safety glass. Max. display board dimensions approximately 74 x 56.4 mm or 80 x 54 mm. Beluga 220 Consisting of top and bottom part, enclosure and board mounting screws, sealing rings, tongue-and-groove system with integral seal. Open version comes complete with display screen and safety glass. Max. display board dimensions approximately 84 x 74.5 mm or 86 x 70.5 mm. Enclosure Type Part Number Version Beluga 180 O Beluga 180 G Beluga 220 O Beluga 220 G Beluga 380 28020200 00 28020201 00 28020400 00 28020401 00 28020501 00 open closed open closed closed Dimensions mm WxLxH 106/75 x 187 x 50 106/75 x 187 x 50 116/85 x 220 x 51 116/85 x 220 x 51 380 x 117 x 68 Beluga 380 Consisting of top part with seal, bottom part with hang-up set-up, enclosure and board mounting screws, sealing rings, tongue-and-groove system with integrated seal. Dimensions Inches WxLxH Weight lbs. 4.17/2.95 x 7.36 x 1.97 4.72/2.95 x 7.36 x 1.97 4.57/3.35 x 8.66 x 2.00 4.57/3.35 x 8.66 x 200 14.96 x 4.61 x 2.68 0.35 0.37 0.44 0.46 1.15 Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. 108 www.Rose-Bopla.com Operating and Display Enclosures Machine control enclosures are used for machine operation. These complex modules, from a simple emergency stop switch up to complete industrial PCs or CNC controllers, must be adapted to the rough environmental conditions placed on the machines. ROSE operating and display enclosures ensure guaranteed protection for built-in electronic components and offer the very best in operator comfort. Machine Control For stationary application areas and fitting of controllers and industrial PCs, the ROSE range offers a variety of enclosure types with more that 140 individual solutions, depending on controller size and construction. If your individual solution is not available here, please contact us. Suspension Arm Systems Suspension systems link control enclosures with the respective machine. In addition to covering cable routing, they have the task of facilitating optimal positioning of the control enclosure for the user. For this reason we offer a variety of turning knuckles, inclination sets and coupling pieces. The selection of a suitable system depends on the weight and construction of the completely equipped control enclosure. For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 109 1300 Machine Control • Small machine control enclosure in aluminum with protective bumper bars • Membrane Lid Versions: small machine control enclosure in aluminum with front frame for front panel and keypads • Robust aluminum diecast enclosure body with front panel • Transparent cover and handle sets (optional) Included in delivery Unpainted diecast aluminum base and bezel. Membrane Lid Versions: Aluminum front plate - 1F membrane, unpainted base for 1F membrane style, bezel designed for membrane front panel. Please order front panel separately. Technical Data Material Ingress Protection Impact Resistance Seal Temperature Range Color Part Number 13050000 00 13070000 00 13080000 00 13090000 00 13100000 00 13110000 00 13120000 00 13130000 00 13140000 00 13150000 00 13160000 00 13170000 00 13200000 00 13210000 00 13220000 00 13230000 00 13240000 00 13250000 00 Enclosure body, die cast aluminum, Al Si 12. Bezel, die cast aluminum Al Si 12. Front panel, anodized sheet aluminum, 3mm thick IP 65 to EN 60529 >7Nm, EN 50014 Neoprene -40°F to +194°F Body, agate gray, similar to RAL 7038. Bezel, transport gray, similar to RAL 7043. Special colors on request. Dimensions mm Dimensions Inches WxLxH 230 x 100 x 128 260 x 160 x 108 360 x 160 x 108 560 x 160 x 108 230 x 200 x 128 230 x 200 x 198 230 x 330 x 128 230 x 330 x 198 230 x 400 x 128 230 x 400 x 242 230 x 600 x 128 230 x 280 x 130 310 x 400 x 128 310 x 400 x 198 310 x 600 x 128 310 x 600 x 198 310 x 400 x 244 310 x 400 x 158 WxLxH 9.05 x 3.94 x 5.04 10.23 x 6.30 x 4.25 14.17 x 6.30 x 4.25 22.05 x 6.30 x 4.25 9.05 x 7.87 x 5.04 9.05 x 7.87 x 7.79 9.05 x 12.99 x 5.04 9.05 x 12.99 x 7.79 9.05 x 15.75 x 5.04 9.05 x 15.75 x 9.53 9.05 x 23.62 x 5.04 9.05 x 11.02 x 5.12 12.20 x 15.75 x 5.04 12.20 x 15.75 x 7.79 12.20 x 23.62 x 5.04 12.20 x 23.62 x 7.79 12.20 x 15.75 x 9.61 12.20 x 15.75 x 6.22 Handle Mounting Options Front Panel 10013005 00 10013007 00 10013008 00 10013009 00 10013010 00 10013010 00 10013012 00 10013012 00 10013014 00 10013014 00 10013016 00 10013017 00 10013020 00 10013020 00 10013022 00 10013022 00 10013020 00 10013020 00 • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • Ext. hinges diecast aluminum swiveling range 150° Int. hinges stainless steel swiveling range 150° Mounting plates sheet steel, noncorrosive • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • DIN rails noncorrosive TS 35 • • • • • • • • • • • • • • • • • • Silicone Transparent Turn bolt lid seal, Covers lock resistant up to 130° • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • Note: Dimensions are external. Metric is the primary dimension. Inch conversions are for the user’s convenience and are for reference only. Membrane Lid Version available. Call your factory representative for more information. 110 www.Rose-Bopla.com Slim Line 2000 • Enclosure system for control and display fittings • Variable size available in width and depth • All-round adaptation capabilities for accessories • Front panel insertion from front and rear Included in delivery Profile 1: Extruded aluminum, 80 mm max. mounting depth Profile 2: Extruded aluminum, 100 mm max. mounting depth Profile 3: Extruded aluminum, 185 mm max. mounting depth Technical Data Material Ingress Protection Temperature Range Color Item Number Profile 1 Profile 2 Profile 3 Enclosure profile: extruded aluminum, Al Mg Si 0.5 DIN 1725 Corner elements: diecast aluminum, Al Si 12 DIN 1725 Rear panel door: sheet metal, Al Mg 3, DIN 1725 Cover profile: thermoplastic material IP 65 to EN 60529, NEMA 12 -22°F to +176°F Enclosure: light gray, similar to RAL 7035 Handles: ruby red, similar to RAL 3003 Description Extruded aluminum, 80mm maximum mounting depth Extruded aluminum, 110mm maximum mounting depth Extruded aluminum, 185mm maximum mounting depth Accessories Part Number 19590020 00 19601004 00 19601008 00 19601001 00 19601002 00 19601007 00 10036001 00 19590011 00 19590012 00 19590013 00 19601005 00 19602004 00 19602005 00 19602006 00 19602002 00 Description Standard linking bar, one meter length, for split panels Keyboard holder Set of 2 hinges with screws Panel mounting set with 12 screws, spring nuts, brackets Fastening set 30 spring nuts, brackets, screws Quick fastening kit for front plate Set of M5 mounting nuts (8 pieces) Console mounting kit, 15° fixed Console mounting kit, 30° fixed Console mounting kit. adjustable Floppy disk drive mounting bay Handle set (1 handle with brackets), 301 mm long for side attachment Handle set (1 handle with brackets), 345 mm long for side attachment Handle set (1 handle with brackets), 472 mm long for side attachment Corner handle set: one L-shaped handle with brackets; three 556/395mm asymetrical for side/bottom attachment Coupling Adapters for Suspension Arm System 4945, 4949, 4951, 4961, 1981 ItemNumber 19602003 00 19602011 00 19602012 00 Description Flange coupling adapter for 80 mm profile 1 Flange coulpling adapter for 100 mm profile 2 Flange coupling adapter for 185 mm profile 3 Coupling Adapters for Suspension Arm System 4945, 4949 Part Number 19602007 00 19602008 00 19602013 00 Description Flange coupling adapter for 110 mm profile 2 Flange coupling adapter for 185 mm profile 3 Flange coupling adapter for 185 mm profile 3 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 111 SL 2000 Ordering Guide Start at the top of this guide and work down, considering all options required. Circle required options and corresponding part numbers. You will build a 10 digit part number, eg., 19020002 01, plus assembly options. Then, call a Rose+Bopla sales person and they will give you pricing, internal dimensions and coupling hole options for the enclosure you designed. CONSOLE HOLE LOCATION GUIDE Horizontal Top Left Please Circle All Items Required DESCRIPTION COUPLING HOLES  YES  NO COUPLING HOLE LOCATION FLANGE COUPLING ADAPTER REQUIRED Left Right Right Bottom COUPLING PART NUMBER Bottom CONSOLE BOOT LOCATION ROSE P.N. 4945 & 4949 Suspension Systems 19602003 - 80mm Profile 19602011 - 110mm Profile 19602012 - 185mm Profile Top Left Bottom Right 19 4951 & 4961 Suspension Systems INSTALL ADAPTER  YES NOTE: One Inch equals 25.4 mm Vertical Top  NO 19602007 - 110mm Profile 19602008 - 185mm Profile Price of Adapter Not Included SELECT PROFILE Profile #1 - 80 mm Profile #2 - 110 mm Profile #3 - 185 mm ENCLOSURE CIRCUMFERENCE HEIGHT / WIDTH N/A 01 02 03 HEIGHT WIDTH Actual Panel Size + 95.6mm = External Height and Width Usable Panel Space Required 0 - 1200mm _________________ mm _________________ mm 0001 1201 - 1800mm _________________ mm _________________ mm 0002 1801 - 2300mm _________________ mm _________________ mm 0003 2301 - 2800mm _________________ mm _________________ mm 0004 2801 - 3300mm _________________ mm _________________ mm 0005 Height:____________ Width:____________ Actual Panel Size (Usable Panel Space + 34mm) Height:____________ Width:____________ Usable Depth:_________________________ Refer to SL 2000 Drawing DOORS Rear Panel Rear Door FRONT PANEL (Circle One) Install Panel Gasket Hinge Location, if required (facing the unit). Top Left Bottom Right Install Front Panel: YES or NO No Front Panel Clear Anodized   Mill Finish / Painted YES MACHINING  YES NO From Front W / Studs From Rear  NO Silk Screen to DWG #  NO HANDLES  YES From Front (Circle One) Machine to DWG # SILK SCREENING  YES 00 01  NO Type Dual Side Handles Corner Handles Console Mounting Kit Installed Yes No Yes No Yes No Handle Location Horizontal or Vertical Prices of Handles Not Included INSTALL Front Bezel Black T-Slot Gasket Optional: Keyboard Holder NOTES OR SPECIAL INSTRUCTIONS: CONSOLE REQUIRED  NO IF YES, PROCEED TO NEXT PAGE  YES 112 www.Rose-Bopla.com SL 2000 Console Ordering Guide CONSOLE HOLE LOCATION GUIDE Horizontal Top Left Start at the top of this guide and work down, considering all options required. Circle required options and corresponding part numbers. You will build a 10 digit Rose part number, eg., 19010001 00, plus assembly options. Then call a Rose+Bopla sales person and they will give you pricing, internal dimensions and coupling hole options for the enclosure you designed. Vertical Top Left Right Right Bottom Bottom Please Circle All Items Required DESCRIPTION CONSOLE MOUNTING KIT-HANDLES  YES  NO INSTALL MOUNTING KIT-HANDLES  YES  NO FIXED CONSOLE MOUNTING KIT CONSOLE MOUNTING KIT LOCATION 19590011 00 15 Degree Angle Top Left 19590012 00 30 Degree Angle Bottom Right 19590013 00 Variable / Adjustable ROSE P.N. 19 Price of Mounting Kit Not Included SELECT PROFILE Profile #1 - 80 mm Profile #2 - 110 mm Profile #3 - 185 mm ENCLOSURE CIRCUMFERENCE HEIGHT / WIDTH NOTE: One Inch equals 25.4 mm 01 02 03 HEIGHT WIDTH Actual Panel Size + 95.6mm = External Height and Width Usable Panel Space Required 0 - 1200mm _________________ mm _________________ mm 0001 1201 - 1800mm _________________ mm _________________ mm 0002 Height:____________ Width:_____________ 1801 - 2300mm _________________ mm _________________ mm 0003 Usable Depth:_________________________ Refer to SL 2000 Drawing 2301 - 2800mm _________________ mm _________________ mm 0004 2801 - 3300mm _________________ mm _________________ mm 0005 Height:____________ Width:_____________ Actual Panel Size (Usable Panel Space + 34mm) DOORS Rear Panel Rear Door FRONT PANEL (Circle One) Install Panel Gasket No Front Panel Clear Anodized   Mill Finish / Painted YES MACHINING  YES From Front (Circle One) NO From Front W / Studs From Rear Machine to DWG # Silk Screen to DWG #  NO HANDLES  YES 00 01  NO SILK SCREENING  YES Hinge Location, if required (facing the unit). Top Left Bottom Right Install Front Panel: YES or NO Type  NO INSTALL Dual Side Handles Corner Handles Front Bezel Installed Yes Yes - No No Black T-Slot Gasket Handle Location Horizontal or Vertical Optional: Keyboard Holder NOTES OR SPECIAL INSTRUCTIONS: For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 113 SL 2000 Ordering Guide Instruction Sheet 1. Begin to fill in your SL 2000 part number as 19__by going down through the SL 2000 Ordering Guide and filling in or circling the required items. You will build a 10-digit part number. 2. Coupling Hole–circle yes if you will be using a suspension coupling adapter. 3. Coupling Hole Location–select from...top, bottom, left, right. Also circle location guide in top left hand corner of ordering guide sheet. 4. Install Adapter–circle yes if you would like us to install the coupling adapter. 5. Write in the Rose +Bopla flange coupling part number being used if any. 6. Select Profile–your profile choice will depend on your required depth. See drawings and keep in mind that your front plate will affect this choice. 7. Usable Panel Space–fill in the usable panel space (in mm) you will need for your control or display panel. 8. Actual Panel Size–take your usable space and add 34mm to arrive at this figure. 9. Usable Depth–Check your supplied drawings to get this figure. Note: mounting your front plate from the front or rear will affect this dimension. 10. External Size–take your actual panel size and add 95.6mm to the height and width to arrive at these circumference dimensions. 11. Door/Rear Panel–you have a choice of a screwed-on rear panel or a hinged door. Please circle your choice and also the desired hinge locations. 12. Front Panel–Circle your choice of front panel/finish and installation method. 13. Machining–Please circle if you would like for us to machine/engrave your panels. if yes, please supply us with your drawing number and fax us a copy for review. 14. Silkscreen–Rose+Bopla can provide complete silkscreen services. If you would like this service we will need a drawing for placement and artwork to create the screen. 15. Handles–Please provide the part number and location for the handle style you have chosen. Keyboard Holder and Console Mounting Kit are available options. Note: A handle set consists of one handle and the required number of brackets. 16. Rose +Bopla will install front bezel material and outside protective rubber unless specified otherwise. 17. Notes–please fill in any special notes or instructions for building the unit. 18. After design review, a copy of the ordering guide will be faxed to you for final approval and signature. Note: For units with a console, please also fill out the “Console Ordering Guide” using these same guidelines. 114 SL 2000 Accessories SL Panel Mounting Set for integrating the SL 2000 into control panels. 19601000 00 Includes fittings, sealing ring, and screws. SL Handle Set consisting of tube and fittings 19602002 00 Asymmetrical 19602004 00 Side Attachment 19602005 00 Side Attachment 19602006 00 Side Attachment www.Rose-Bopla.com 5400 Machine Control • Heavy duty aluminum extrusion, self-reinforced with internal ribs and slots • Choose front and rear panels in either clear anodized aluminum, black anodized aluminum or mill finish aluminum • Internal gasket protects against dust, water, chips and cutting fluids Technical Data Color Material Gasket Material Protection Classifications Temperature Range Panel vs. Enclosure Size Panel Working Surface Height Working Surface Width Visible Surface Height Visible Surface Width Total Height Total Width Body, doors and rear panel, agate gray, similar to RAL 7038. Corner handles and lock, transport gray, similar to RAL 7043. Custom colors on request. Al SI 12, DIN 1725 Al Mg 3, DIN 1725 Al Mg Si 0.5, DIN 1725 Neoprene foam rubber IP 65 to EN 60529, NEMA 12 including see-through door -40°F to +176°F Transparent door: +14°F to +140°F Description Working Surface Height + 84mm Working Surface Width + 84mm Visible Surface Height + 75mm Visible Surface Width + 75mm Total Height + 48mm Total Width + 48mm 5400 Accessory Order Guide Part Number 10036001 00 10036002 00 10033101 00 Description M5 Captive Nuts for Internal Slots M6 Captive Nuts for Internal Slots Internal Mounting Brackets with nuts and bolts Internal Shelf Bracket for 160mm depth Internal Shelf Bracket for 240mm depth Internal Shelf Bracket for 320mm depth Gas Springs for Doors External Keyboard Tray For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 115 5400 Ordering Guide CONSOLE HOLE LOCATION GUIDE Horizontal Top Left Start at the top of this guide and work down, considering all options required. Circle required options and corresponding part numbers. You will build a 10 digit part number, eg., 54000102 02, plus assembly options. Then, call a Rose+Bopla sales person and they will give you pricing, internal dimensions and coupling hole options for the enclosure you designed. Vertical Top Left Right Right Bottom Bottom Please Circle All Items Required NOTE: One Inch equals 25.4 mm Description ROSE P.N. COUPLING HOLE  YES  NO Series Type Location 4949 4951, 54 4961, 4981 4990 OR OTHER TYPE ENCLOSURE HEIGHT / WIDTH 0 - 1800 mm 1801 - 2300 mm 2301 - 2800 mm 2801 - 3300 mm Inside Usable Height _________________mm Inside Usable Width _________________mm DOORS ENCLOSURE BODY DEPTH DOOR LOCK / LATCH 1/4 WRAP HANDLES External Size Height Circumference Width ____________________mm ____________________mm ____________________mm ____________________mm ____________________mm ____________________mm ____________________mm ____________________mm Type Hinge Location (facing door) Hinged Front Door Hinged Rear Door Hinged Front Clear Door Hinged Rear Clear Door Left Left Left Left Right Right Right Right Top Top Top Top 0001 0002 0003 0004 Configuration Bottom Bottom Bottom Bottom 0 - 1 Door 2 Doors 3 Doors 01 02 03 External Size 160 mm 240 mm 320 mm 160 mm 240 mm 160 mm 240 mm 240 mm 320 mm 160 mm 320 mm 320 mm Inside Usable Depth _____________________mm Flush Square Door Lock With Key Front Rear Clear Door Handle/Latch Front Rear Clear + + + + + + + + + + + 01 01 02 03 03 03 04 03 04 03 04 03 160 mm 240 mm 240 mm 320 mm 160 mm 240 mm 320 mm 320 mm 160 mm Locking Door Handle w/Key Front Rear Clear Type Location ¼ Handle Horizontal (set of two) Front Rear N/A ¼ Handle Vertical (set of two) Front Rear N/A FRONT / REAR PANELS Type Location Grained / Clear Anodized Grained / Black Anodized Mill Finish / Painted None Front Front Front Front 19" ADAPTER PLATES INTERNAL MOUNTING PLATES Grained / Clear Anodized Front Mill Finish / Painted H Rear Rear Rear Rear Engrave per Dwg #_______________________________ Machine per Dwg #_______________________________ Silkscreen per Dwg #_______________________________ Paint Instructions Rear mm / W N/A mm N/A Notes or Special Instructions: 116 www.Rose-Bopla.com 4949 Suspension Arm System • Industrial tube suspension arm system for supporting machine control enclosures • Modular construction using steel tubing and individual connection components • Protected internal cable routing Included in delivery Individual system components including assembly material. Technical Data Color Material Finish Protection Classifications Assembly Transport gray, similar to RAL 7043 Connection components - aluminum, steel Round Tubing - galvanized steel tube, 48 x 4 mm Powder-coat painted connection components IP 54, EN 60529. Foot 49496800, IP 40 Cut the tubing. Slide components together. Tighten to required torque, 22 lbs. force (30 Newton Meters). Complete assembly instructions are provided with components. Connection Components Bass bracket Foot Foot Wall bracket (Horizontal Exit) Wall bracket (Vertical Exit) Elbow Coupling Coupling Elbow coupling Elbow coupling Angled adapter 30° Adapter flange for external cable Tilting adapter Steel Tubing Round tubing 10 feet, 4 mm wall thickness, zinc plated Round tubing 10 feet, 4 mm wall thickness, zinc plated Part Number Weight (lbs) 49496600 00 49497200 00 49496800 00 49497000 00 49496200 00 49497100 00 49497300 00 49497700 00 49497500 00 49497800 00 49497600 00 49497900 00 49498000 00 4.18 1.65 1.54 3.75 3.31 1.76 1.10 1.10 1.54 1.54 0.88 8.82 1.32 Part Number Weight (lbs) 10094158 45 10094158 85 30.80 (10 feet) 30.80 (10 feet) For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 4949 Maximum Weight: 3.3 ft. 4.9 ft. 112 67 lbf. lbf.=Pounds Force 117 4951/61/81 Suspension Arm System • Robust industrial suspension arm system for supporting machine control enclosures • Modular construction using square steel tubing and cast steel and aluminum connection components • High loading capacity, long extension capabilities Included in delivery Individual system components including assembly material. Technical Data Color Material Protection Classifications Assembly Torque Requirements Dark gray, similar to RAL 7043. Tubing: zinc plated. Square connection tubing, 5mm thick, steel, to DIN 2395 IP 65, EN 60529, NEMA 12 Cut tubing to desired length. Slide components together. Tighten to required torque. Complete assembly instructions provided with components. 30 Nm, 22 lbs. force Connection Components 4951 Part Number Weight (lbs) 4961 Part Number Weight (lbs) 4981 Part Number Weight (lbs) Base unit bracket Foot Wall bracket Adapter angle coupling (for vertical wiring exit) Intermediate joint Elbow Elbow coupling Flange elbow coupling Flange coupling Adjustable angle coupling 30° fixed angle adapter for flange coupling 49516600 00 49517400 00 49517000 00 49517900 00 49516700 00 49518000 00 49517500 00 49517800 00 49517700 00 49516200 00 49517600 00 30.86 6.61 13.89 11.02 13.67 9.92 4.85 4.85 4.63 3.97 1.76 49616600 00 49617400 00 49617000 00 49617900 00 49616700 00 49618000 00 49617500 00 49617800 00 49617700 00 49616200 00 49617600 00 40.12 6.61 20.06 13.23 19.62 12.79 7.05 7.94 6.17 4.85 2.20 49816600 00 49817400 00 49817000 00 49817900 00 49816700 00 49818000 00 49817500 00 49817800 00 49817700 00 49816200 00 49817600 00 51.38 13.23 28.66 14.33 28.00 17.64 12.57 12.35 10.80 6.17 3.75 Steel Tubing Support tubing, zinc plated steel, 10 foot sections for 4951 Support tubing, zinc plated steel, 10 foot sections for 4961 Support tubing, zinc plated steel, 10 foot sections for 4981 Part Number Weight (lbs.) 10094156 45 (51) 10094157 45 (61) 10094159 45 (81) 44.00 47.00 71.00 Maximum Weight: 3.3 ft. 4.9 ft. 6.6 ft. 8.1 ft. 9.8 ft. lbf. System 51 225 146 112 System 61 281 180 140 112 lbf. System 81 337 213 163 135 lbf. 112 lbf. lbf.=Pounds Force Usable Space: System 51–40 x 40mm, Inside Dimension of Tubing. System 61–50 x 50mm, Inside Dimension of Tubing. System 81–70 x 70mm, Inside Dimension of Tubing. 118 www.Rose-Bopla.com 4990 Suspension Arm System • Robust industrial suspension arm system for supporting machine control enclosures, with open cable duct for heavy loads • Modular construction with freely accessible cable duct • Floor, top-mounting or wall exit options Included in delivery System individual components including cable duct covering and assembly material. Technical Data Color Material Cable Duct Torque Protection Classification Load Connection Components–transport gray, similar to RAL 7043. Aluminum profile–agate gray, similar to RAL 7038 Tubing–square tubing, 5mm or 8mm thick, steel, to ST 37 DIN 2395. Components–cast iron with copper graphite, or aluminum. Bearing–ball bearing. Textile bellows. Free cable passage in system components. Approximately 3.15" W x 2.81" H, 80 x 71.37mm 22 lbs. force (30 Newton Meters) IP 65 when special surface-mounted flange is used between enclosure coupling and control panel. When using square steel tube 80 x 80 x 5mm (ST 37 DIN 2395), maximum 500N at 3 meter extension. When using square steel tube 80 x 80 x 8mm (ST 37 DIN 2395), maximum 750N at 3 meter extension. Maximum Weight: Part Number Weight (kg) 49906601 00 49907401 00 49907001 00 49906701 00 49907111 00 49907120 00 49907501 00 49907301 00 49900030 00 49900020 00 44.53 13.23 38.58 38.86 20.06 9.48 9.26 8.60 2.43 2.43 Description Brass bracket Foot/wall flange Wall bracket Intermediate joint Elbow C Elbow A Elbow coupling Coupling Watertight top flange (used in conjunction with couplings) Watertight top flange (used in conjunction with couplings) 2.4 ft. 3.3 ft. 4.9 ft. 6.6 ft. 8.1 ft. 9.8 ft. lbf. Supporting Tubing 80 x 80 x 5mm 449 337 225 169 135 112 lbf. Supporting Tubing 80 x 80 x 8mm 449 449 337 253 198 169 lbf. lbf.=Pounds Force Note: Tubing can be cut to specific lengths. Maximum length for UPS 9 feet (108”) Description Cable duct Support tubing, steel Support tubing, steel Part Number Cable Duct (standard length to fit relevant suspension tube) Part Number Support Tube 80 x 80 x 5 mm Part Number Support Tube 80 x 80 x 8 mm 10094238 00 10094159 45 10094234 00 *The cable duct needs to be 175 mm shorter that the suspension tube length. For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 119 Moterm • Mobile stand system for system components • Optional fixed or manually adjusted version • 2 and 4 wheels available Included in delivery Moterm with mounting inclining adapter and adapter plate for Machine Control Systems. Please order adapter plate separately Technical Data Material Temperature Range Painting Color Maximum Load Foot: sheet steel Profile: AlMgSi 0.5 -40°F to +176°F Powder coating Profile: light gray similar to RAL 7035 Foot: black gray similar to RAL 7021 Dependent on system construction - on request Description Moterm 1, fixed version, height 1000 mm, 2 wheels Moterm 2, manual adjustable (750 - 1000 mm), 2 wheels Moterm 4, fixed version, height 980 mm, 4 wheels Moterm 5, manual adjustable (730 - 1000 mm), 4 wheels Part Number 50010101 00 50010102 00 50010104 00 50010105 00 Accessories Description Adapter plate SL 2000 profile 1 Adapter plate SL 2000 profile 2 Adapter plate SL 2000 profile 3 Adapter plate universal (without holes) Adapter plate Beckhoff CP 7032 120 Part Number 50010203 00 50010204 00 50010205 00 50010209 00 50010210 00 www.Rose-Bopla.com Inclining Adapter • Inclining adapter for individual connection between enclosure and suspension systems or for wall mounting • Simple handling Included in delivery Inclining adapter, flange plates, sealing and mounting material Technical Data Material Surface Temperature Range Sheet steel, 2.5 mm Bellow: PVC, RAL 9005 (black) Black, similar to RAL 9005, powdered -40°F to +140°F Description 1. Inclining adapter for mounting to wall or machinery 2. Inclining adapter for suspension system 4945 3. Inclining adapter for suspension system with flange 4945 Part Number Weight (lb) 50020001 00 50020002 00 50020004 00 2.87 2.20 1.98 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 121 Cable Glands Cable entries and cable glands must be tightly sealed in accordance with design requirements. Rose+Bopla offers a wide range of cable gland products for this purpose: –versions in plastic, aluminum, brass and stainless steel –for Standard, Ex and EMC applications –for ingress protection to IP 68 Note: Other cable glands on request Plastic Cable Glands • Product range in Polyamide (PG and metric thread) as standard or Ex cable gland • Accessories, blanking plugs, lock nuts, self-sealing grommets and PE seals Brass Cable Glands • Product range PG and metric thread as standard, Ex or EMC cable glands • Accessories, blanking plugs and lock nuts Stainless Steel Cable Glands • Product range in 2 versions (PG and metric thread) as standard or Ex cable glands 122 www.Rose-Bopla.com Polyamide Plastic Cable Glands Type Material Color Sealing Inset External Seal Ingress Protection Temperature Range Polyamide Cable Gland Polyamide RAL 7035 NBR IP 68 -40°F to +212°F Polyamide Cable Glands Cable Ø Type PG 7 3 - 6.5 9 4-8 11 5 - 10 13.5 6 - 12 10 14 16 13 - 18 21 18 - 25 29 22 - 32 36 30 - 38 42 48 34 - 44 Metric M 12 x 1.5 M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 M 50 x 1.5 M 63 x 1.5 Type Certification Material Color Ingress Protection Temperature Range Plastic Ex Blind Plugs DIN EN 5014/19/20 II 2 G/D acc. guideline 94/9/EG Polyamide 6 RAL 9005 (black) IP 68 with seal -40°F to +104°F 3-6 5 - 10 8 - 13 11 - 17 15 - 21 19 - 28 26 - 35 32 - 42 Cable Ø Type For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 100 100 100 100 50 50 25 10 5 5 08020207 08020209 08020211 08020213 08020216 08020221 08020229 08020236 08020242 08020248 00 00 00 00 00 00 00 00 00 00 100 100 100 100 50 10 5 5 08080512 08080516 08080520 08080525 08080532 08080540 08080550 08080563 00 00 00 00 00 00 00 00 Polyamide Ex Blind Plug Type PG 7 9 11 13.5 16 21 29 36 42 48 Pcs/Pack Metric M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 M 50 x 1.5 M 63 x 1.5 Polyamide Ex DIN EN 50014/19/20 II 2 G/D Certification acc. guideline 94/9/EG Material Polyamide 6 Color Black (RAL 9005) Blue (RAL 5012) Ingress Protection IP 68 with seal Temperature Range -40°F to +140°F Part Number Pcs/Pack Cable Ø Type PG 7 9 11 13.5 16 21 29 36 42 48 3.5 - 6 5-8 6 - 10 8 - 13 10 - 15 13 - 19 17 - 25 24 - 32 28 - 38 34 - 44 Metric M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 M 50 x 1.5 M 63 x 1.5 5-8 8 - 13 13 - 19 17 - 25 24 - 32 28 - 38 34 - 44 Part Number 100 100 100 100 100 100 50 20 20 20 08056707 08056709 08056711 08056713 08056716 08056721 08056729 08056736 08056742 08056748 00 00 00 00 00 00 00 00 00 00 100 100 100 100 20 20 20 08090616 08090620 08090625 08090632 08090640 08090650 08090663 00 00 00 00 00 00 00 Polyamide Ex Cable Glands Pcs/Pack Part Number 20 20 20 20 20 20 10 10 10 10 Black 08060007 08060009 08060011 08060013 08060016 08060021 08060029 08060036 08060042 08060048 00 00 00 00 00 00 00 00 00 00 Part Number Blue 08065007 00 08065009 00 08065011 00 08065013 00 08065016 00 08065021 00 08065029 00 08065036 00 08065042 00 08065048 00 20 20 20 10 10 10 10 08080616 08080620 08080625 08080632 08080640 08080650 08080663 00 00 00 00 00 00 00 08080716 08080720 08080725 08080732 08080740 08080750 08080763 00 00 00 00 00 00 00 123 Polyamide Cable Glands Type Material Color Sealing Inset External Seal Ingress Protection Temperature Range Polyamide lock nut Polyamide RAL 7035 -40°F to +212°F Type PG 7 9 11 13.5 16 21 29 36 42 48 Cable Ø Metric M 12 M 16 M 20 M 25 M 32 M 40 M 50 M 63 Type Ingress Protection Temperature Range Material Type Ingress Protection Temperature Range Material Color Type Material Color Sealing Inset External Seal Ingress Protection Temperature Range 124 MZI Cable Gland IP 65 -4°F to +212°F Polyamide PA with bending protection IP 54 IP 68 - 10 bar with seal -40°F to +212°F Polyamide Black, RAL 9005 Blind Plugs Polyamide RAL 7035 IP 54 -10°F to +176°F Model PG Cable Ø MZI 9 6-8 Type Cable Ø PG 7 9 11 13.5 16 21 Metric M 12 x 1.5 M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 Type PG 7 9 11 13.5 16 21 29 Metric M 12 x 1.5 M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 Cable Ø Pcs/Pack Part Number 100 100 100 100 50 50 25 25 25 25 08020907 00 08020909 00 08020911 00 08020913 00 08020916 00 08020921 00 08020929 00 08020936 00 08020942 00 08020948 00 100 100 100 100 50 50 5 5 08090712 00 08090716 00 08090720 00 08090725 00 08090732 00 08090740 00 08090750 00 08090763 00 MZI Cable Glands Connection Thread 13.5 Part Number 12060200 00 Pcs/Pack Part Number 50 50 50 50 25 20 08110107 00 08110109 00 08110111 00 08110113 00 08110116 00 08110121 00 50 50 50 20 08100112 00 08100116 00 08100120 00 08100125 00 Pcs/Pack Part Number 100 100 100 100 100 100 50 08020607 00 08020609 00 08020611 00 08020613 00 08020616 00 08020621 00 08020629 00 100 100 100 100 50 50 08090512 00 08090516 00 08090520 00 08090525 00 08090532 00 08090540 00 www.Rose-Bopla.com Polyamide Cable Glands Characteristics Ingress Protection Temperature Range Characteristics Ingress Protection Temperature Range Characteristics Ingress Protection Temperature Range Integrated strain relief, large sealing and terminal section, easy to assemble IP 68 -4°F to + 212°F Integrated strain relief, anti-kink protection, large sealing and terminal section, easy to assemble IP 68 -4°F to +212° F With clamping cage for strain relief IP 65 -22°F to +212°F For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 Model PG BF 7 BF 9 BF 11 BF 13 BF 16 BF 21 BF 29 BF 36 Metric MBF 12 MBF 16 MBF 20 MBF 25 MBF 32 MBF 40 Cable Ø BF/MBF Cable Glands Connection Thread Part Number 3 - 6.5 4-8 5 - 10 6 - 12 10 14 13 - 18 18 - 25 22 - 32 PG 7 PG 9 PG 11 PG 13.5 PG 16 PG 21 PG 29 PG 36 10000100 00 10000200 00 10000300 00 10000400 00 10000500 00 10000600 00 10000700 00 10000800 00 3-6 5 - 10 8 - 13 11 - 17 15 - 21 19 - 28 M 12 x 1.5 M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 12002100 00 12002200 00 12002300 00 12002400 00 12002500 00 12002600 00 BFK/MBFK Cable Glands Model Cable Ø PG, with anti-kink protection BFK 7 3 - 6.5 BFK 9 4-8 BFK 11 5 - 10 BFK 13 6 - 12 BFK 16 10 - 14 BFK 21 13 - 18 Metric, with anti-kink protection MBFK 12 3 - 6.5 MBFK 16 5 - 10 MBFK 20-1 6 - 12 MBFK 20-2 10 - 14 MBFK 25 13 - 18 Model PG POZ 7 POZ 9 POZ 11 POZ 13 POZ 16 POZ 21 POZ 29 Metric MPOZ 12-1 MPOZ 12-2 MPOZ 16 MPOZ 20-1 MPOZ 20-2 MPOZ 20-3 MPOZ 25-2 MPOZ 32 Connection Thread Part Number PG 7 PG 9 PG 11 PG 13.5 PG 16 PG 21 10001100 00 10001200 00 10001300 00 10001400 00 10001500 00 10001600 00 M 12 x 1.5 M 16 x 1.5 M 20 x 1.5 M 20 x 1.5 M 25 x 1.5 12002103 00 12002210 00 12002303 00 12002306 00 12002401 00 POZ/MPOZ Cable Glands Cable Ø Connection Thread 4-6 6-8 8 - 10 10 -12 12 - 14 14 - 18 18 - 24 4-6 6-8 6-8 8 - 10 10 -12 12 - 14 14 - 18 18 - 24 PG 7 PG 9 PG 11 PG 13 PG 16 PG 21 PG 29 M 12 x 1.5 M 12 x 1.5 M 16 x 1.5 M 20 x 1.5 M 20 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 Part Number 12051809 00 12051909 00 12052009 00 12052109 00 12052209 00 12052309 00 12052409 00 12151800 00 12151900 00 12152000 00 12152100 00 12152200 00 12152300 00 12152400 00 12152500 00 125 Polyamide Cable Glands Characteristics Material: Ingress Protection Temperature Range Characteristics Characteristics 126 With clamping cage for strain relief and anti-kink grommet Polyamide IP 65 -22°F to + 212°F Polyamide counter nut for all cable glands with PG or metric connection threads. Polyamide blind plugs for closing and sealing unused Pg/metric threaded drill holes. For increased protection, please use sealing ring for connection thread DR. POZB/MPOZB Cable Glands Connection Thread Part Number 4-6 6-8 8 - 10 10 - 12 12 - 14 14 - 18 18 - 24 PG 7 PG 9 PG 11 PG 13 PG 16 PG 21 PG 29 12052609 00 12052709 00 12052809 00 12052909 00 12053009 00 12053109 00 12053209 00 4-6 6-8 6-8 8 - 10 10 - 12 12 - 14 14 - 18 18 - 24 M 12 x 1.5 M 12 x 1.5 M 16 x 1.5 M 20 x 1.5 M 20 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 12152600 00 12152700 00 12152800 00 12152900 00 12153000 00 12153100 00 12153200 00 12153300 00 Cable Ø Model PG POZB 7 POZB 9 POZB 11 POZB 13 POZB 16 POZB 21 POZB 29 Metric MPOZB 12-1 MPOZB 12-2 MPOZB 16 MPOZB 20-1 MPOZB 20-2 MPOZB 20-3 MPOZB 25-2 MPOZB 32 GM/MGM Counter Nuts Model PG GM 7 GM 9 GM 11 GM 13 GM 16 GM 21 GM 29 GM 36 Metric MGM 12 MGM 16 MGM 20 MGM 25 MGM 32 MGM 40 Connection Thread Part Number Width Across Flats PG 7 PG 9 PG 11 PG 13.5 PG 16 PG 21 PG 29 PG 36 52080100 00 52080200 00 52080300 00 52080400 00 52080500 00 52080600 00 52080700 00 52080800 00 SW 19 SW 22 SW 24 SW 27 SW 30 SW 36 SW 46 SW 60 M 12 x 1.5 M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 52090100 00 52090200 00 52090300 00 52090400 00 52090500 00 52090600 00 SW 17 SW 22 SW 26 SW 32 SW 41 SW 50 BL/MBL Blind Plugs Model PG blind plugs BL 7 BL 9 BL 11 BL 13 BL 16 BL 21 BL 29 BL 36 Metric blind plugs MBL 12 MBL 16 MBL 20 MBL 25 MBL 32 MBL 40 Connection Thread Part Number PG 7 PG 9 PG 11 PG 13.5 PG 16 PG 21 PG 29 PG 36 52010000 00 52010100 00 52010200 00 52010300 00 52010400 00 52010500 00 52010600 00 52010700 00 M 12 x 1.5 M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 52011100 00 52011200 00 52011300 00 52011400 00 52011500 00 52011600 00 www.Rose-Bopla.com Brass Cable Glands Characteristics Ingress Protection Temperature Range Characteristics Ingress Protection Temperature Range Characteristics Ingress Protection Temperature Range Integrated strain relief, large sealing and terminal section, easy to assemble, anti-twist protection. IP 68 -4°F to +212°F With clamping cage for strain relief IP 65 -4°F to +212°F Industrial cable glands in the style of DIN 46320 IP 54 -22°F to +230°F For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 MSBF Cable Glands Connection Thread Metric M 12 x 1.5 M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 Cable Ø 3 - 6.0 5 - 9.0 9 - 13.0 11 - 16.0 14 - 21.0 19 - 27.0 Model Part Number MSBF 12 MSBF 16 MSBF 20 MSBF 25 MSBF 32 MSBF 40 13002100 00 13002200 00 13002300 00 13002400 00 13002500 00 13002600 00 MSK Cable Glands Connection Thread PG 7 9 11 13.5 16 21 29 Connection Thread PG 7 9 11 13.5 16 21 Cable Ø Model Part Number 4-6 6-8 8 - 10 10 - 12 12 - 14 14 - 18 18 - 24 MSK 7 MSK 9 MSK 11 MSK 13 MSK 16 MSK 21 MSK 29 13050100 00 13050200 00 13050300 00 13050400 00 13050500 00 13050600 00 13050700 00 MSS Cable Glands Cable Ø Model 4-6 6-8 8 - 10 10 - 12 12 - 14 15 - 17 MSS 7 MSS 9 MSS 11 MSS 13 MSS 16 MSS 21 Part Number 13020100 00 13020200 00 13020300 00 13020400 00 13020500 00 13020600 00 127 Brass Cable Glands Type Material Sealing Inset External Seal Ingress Protection Temperature Range Brass cable gland Nickel-faced brass NBR O-ring, NBR IP 68 -40° to +212°F briefly +248°F Brass Cable Glands Type PG 7 9 11 13.5 16 21 29 36 42 48 Metric M 12 x 1.5 M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 M 50 x 1.5 M 63 x 1.5 Characteristics Ingress Protection Temperature Range Characteristics 128 Large sealing section, easy to assemble. IP 68 -4°F to +212°F Brass counter nut for all cable glands with PG or metric connection Connection Thread PG 7 9 11 13.5 16 Cable Ø Pcs/Pack Part Number 3.5 - 6 4-8 5 - 10 6 - 12 10 - 14 13 - 18 18 - 25 22 - 32 30 - 38 34 - 44 50 50 50 50 25 25 20 1 1 1 08040307 00 08040309 00 08040311 00 08040313 00 08040316 00 08040321 00 08040329 00 08040336 00 08040342 00 08040348 00 3 - 6.5 4-8 6 - 12 10 - 14 13 - 18 18 - 25 22 - 32 34 - 44 50 50 50 25 20 1 1 1 08080412 00 08080416 00 08080420 00 08080425 00 08080432 00 08080440 00 08080450 00 08080463 00 MSD Cable Glands Cable Ø Model 4 - 6.5 5 - 10 7 - 11.5 8 - 15.0 8 - 15.0 Part Number 13040100 00 13040200 00 13040300 00 13040400 00 13040500 00 MSD 7 MSD 9 MSD 11 MSD 13 MSD 16 GMS/MGMS Counter Nuts Connection Thread PG 7 9 11 13.5 16 21 29 36 Metric M 12 x 1.5 M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 Width Across Flats Model Part Number SW 15 SW 18 SW 21 SW 23 SW 26 SW 32 SW 41 SW 51 GMS 7 GMS 9 GMS 11 GMS 13 GMS 16 GMS 21 GMS 29 GMS 36 13150100 00 13150200 00 13150300 00 13150400 00 13150500 00 13150600 00 13150700 00 13150800 00 SW 15 SW 19 SW 24 SW 30 SW 36 SW 46 MGMS 12 MGMS 16 MGMS 20 MGMS 25 MGMS 32 MGMS 40 13160100 00 13160200 00 13160300 00 13160400 00 13160500 00 13160600 00 www.Rose-Bopla.com Brass Cable Glands Ex Version Type Brass Ex Cable Gland with Seal Certification II 2 G/D acc. guideline 94/9/EG IP 68 -4°F to +221°F Ingress Protection Temperature Range Brass Ex Cable Gland with Seal Type PG 7 9 11 13.5 16 21 29 36 42 48 Metric M 12 x 1.5 M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 M 50 x 1.5 M 63 x 1.5 Cable Ø 3.5 - 6 4-8 5 - 10 6 - 12 10 - 14 13 - 18 18 - 25 22 - 32 32 - 38 37 - 44 3 - 6.5 4-8 6 - 12 13 - 18 18 - 25 22 - 30 32 - 38 37 - 44 Pcs/Pack Part Number 50 50 50 50 50 50 25 1 1 1 08040707 00 08040709 00 08040711 00 08040713 00 08040716 00 08040721 00 08040729 00 08040736 00 08040742 00 08040748 00 50 10 10 10 10 5 1 1 08080812 00 08080816 00 08080820 00 08080825 00 08080832 00 08080840 00 08080850 00 08080863 00 Brass Ex Blind Plug Type Certification Ingress Protection Temperature Range Brass Ex Blind Plug Type II 2 G/D acc. guideline 94/9/EG IP 68 -22°F to +194°F PG 7 9 11 13.5 16 21 29 36 42 48 Metric M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 M 50 x 1.5 M 63 x 1.5 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 Cable Ø Pcs/Pack Part Number 50 50 50 50 50 50 25 10 10 10 08080907 00 08080909 00 08080911 00 08080913 00 08080916 00 08080921 00 08080929 00 08080936 00 08080942 00 08080948 00 50 50 50 25 10 5 5 08090816 00 08090820 00 08090825 00 08090832 00 08090840 00 08090850 00 08090863 00 129 Brass Cable Glands EMC Versions Type Material Sealing Inset External Seal Ingress Protection Temperature Range MS cable gland EMC Nickel-faced brass NBR NBR IP 68 -40°F to +212°F briefly +248°F Brass Cable Glands EMC Versions Type PG 7 9 11 13.5 16 21 29 36 42 48 Cable Ø Metric M 12 x 1.5 M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 Type Material External seal Ingress protection Temperature range Type Material Sealing insert External insert Ingress protection Temperature range 130 MS Blind Plug Nickel-faced brass O-Ring, NBR IP 65 -40°F to +176°F Brass lock nut Nickel-faced brass - Type PG 7 9 11 13.5 16 21 29 36 42 Metric M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 M 50 x 1.5 M 63 x 1.5 Cable Ø Type PG 7 9 11 13.5 16 21 29 Metric M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 M 50 x 1.5 M 63 x 1.5 Cable Ø Pcs/Pack Part Number 50 50 50 50 50 50 25 1 1 1 08070007 00 08070009 00 08070011 00 08070013 00 08070016 00 08070021 00 08070029 00 08070036 00 08070042 00 08070048 00 50 50 50 25 25 25 08070112 00 08070116 00 08070120 00 08070125 00 08070132 00 08070140 00 Pcs/Pack Part Number 100 100 100 100 100 100 50 25 25 08040607 00 08040609 00 08040611 00 08040613 00 08040616 00 08040621 00 08040629 00 08040636 00 08040642 00 50 50 50 25 1 1 1 08090416 00 08090420 00 08090425 00 08090432 00 08090440 00 08090450 00 08090463 00 Pcs/Pack Part Number 100 100 100 100 100 100 100 08040907 00 08040909 00 08040911 00 08040913 00 08040916 00 08040921 00 08040929 00 50 50 50 25 1 1 1 08090916 00 08090920 00 08090925 00 08090932 00 08090940 00 08090950 00 08090963 00 www.Rose-Bopla.com Brass Cable Glands EMC Version Type Material Sealing Inset External Seal Ingress Protection Temperature Range Brass lock nut EMC Nickel-faced brass - Brass Lock Nut EMC Type PG 7 9 11 13.5 16 21 29 36 42 48 Metric M 12 x 1.5 M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 Cable Ø Model Part Number 100 100 100 100 100 100 100 100 100 100 08070907 00 08070909 00 08070911 00 08070913 00 08070916 00 08070921 00 08070929 00 08070936 00 08070942 00 08070948 00 50 50 50 50 25 25 08070812 00 08070816 00 08070820 00 08070825 00 08070832 00 08070840 00 Brass Cable Glands EMC Version Characteristics Ingress Protection Temperature Range For fast, easy EMC connection of cables and leads with the enclosure (via the contact spring and the intermediate connection of the screen mesh). Integrated strain relief, anti-twist protection. IP 68 -4°F to +212°F For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 MEMV EMC Cable Glands Type Metric MEMV 16 MEMV 20 MEMV 25 MEMV 32 MEMV 40 Connection Thread M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 Cable Diameter 5.0 - 9.0 9.0 - 13.0 11.0 - 16.0 14.0 - 21.0 19.0 - 27.0 Part Number 12102200 00 12102300 00 12102400 00 12102500 00 12102600 00 131 Polyethylene Cable Glands Type Material Color Sealing Inset External Seal Ingress Protection Temperature Range PE seal HP Polyethylene Transparent -22°F to +158°F PE Seal Type PG 7 9 11 13.5 16 21 29 36 Cable Ø Model Outer Ø Pcs/Pack Part Number 50 50 50 50 50 50 50 50 08000807 00 08000809 00 08000811 00 08000813 00 08000816 00 08000821 00 08000829 00 08000836 00 Polyethylene Cable Glands Characteristics Characteristics Blanking plug for BoplaFlex cable glands not fitted with cables to provide IP 65 ingress protection Material Polyethylene Characteristics Blind washer for all Bopla cable glands. Place the blind washer under the sealing ring if dust protection is required. Material 132 Polyethylene twisting nipple with Pg connection thread for feeding through cables, without IP protection or strain relief. Polyethylene WN Twisting Nipples WN 9 WN 11 WN 13 WN 16 WN 21 WN 29 Connection Thread Part Number PG 9 PG 11 PG 13.5 PG 16 PG 21 PG 29 52020100 00 52020200 00 52020300 00 52020400 00 52020500 00 52020600 00 15.2 18.6 20.4 22.5 28.3 37 VS BF Blanking Plugs for PoplaFlex Cable Glands Model VS BF 7 VS BF 9 VS BF 11 VS BF 13 VS BF 16 VS BF 21 VS BF 29 VS BF 32 VS BF 36 VS BF 40 For Use With Part Number BF 7 / MBF 12 BF 9 / MBF 16 BF 11 BF 13 / MBF 20 BF 16 BF 21 / MBF 25 BF 29 MBF 32 BF 36 MBF 40 10000110 00 10000210 00 10000310 00 10000410 00 10000510 00 10000610 00 10000710 00 10000715 00 10000810 00 10000815 00 BS Blind Washers for BoplaCon Cable Glands Model BS 7 BS 9 BS 11 BS 13 BS 16 BS 21 BS 29 Connection Thread Part Number POZ 7 / POZB 7 / MSS 7 / MSD 7 / MSK 7 POZ 9 / POZB 9 / MSS 9 / MSD 9 / MSK 9 POZ 11 / POZB 11 / MSS 11 / MSD 11 / MSK 11 POZ 13 / POZB 13 / MSS 13 / MSD 13 / MSK 13 POZ 16 / POZB 16 / MSS 16 / MSD 16 / MSK 16 POZ 21 / POZB 21 / MSS 21 / MSK 21 POZ 29 / POZB 29 / MSK 29 12911280 00 12911285 00 12911290 00 12911300 00 12911305 00 12911310 00 12911320 00 www.Rose-Bopla.com Nitrite-Rubber Cable Glands Characteristics Sealing rings for PG or metric type connection threads. DR Sealing Rings Model For Connection Thread Part Number PG 7 PG 9 PG 11 PG 13 PG 16 PG 21 PG 29 PG 36 52030000 00 52030100 00 52030200 00 52030300 00 52030400 00 52030500 00 52030600 00 52030700 00 PG Material Nitrite-rubber DR 7 DR 9 DR 11 DR 13 DR 16 DR 21 DR 29 DR 36 Metric MDR 12 MDR 16 MDR 20 MDR 25 MDR 32 MDR 40 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 M 12 x 1.5 M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 52050100 00 52050200 00 52050300 00 52050400 00 52050500 00 52050600 00 133 Technical Information Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 135 Aluminum. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 135 Fiberglass . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 137 Polystyrene . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 138 Polycarbonate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 139 ABS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 141 Polyamide . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 143 Material Properties of Plastics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 143 Material Chemical Resistance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 144 Military . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 145 EMI/RFI Coatings and Gasket . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 147 Gaskets . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 148 Standard Paint Color Guide . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 149 Cable Grip . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 150 Tolerances . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 151 Aluminum. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 151 Plastic . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 155 Protection Classifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 156 Comparison of NEMA, UL, CSA Standards . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 156 Comparison of NEMA and IEC Standards . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 157 I.P. Ingress Protection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 158 134 www.Rose-Bopla.com Specifications Aluminum ALUMINUM CASTING METHODS Rose+Bopla uses three methods to produce their die cast aluminum watertight enclosures: Die Casting, Chill Casting, and Sand Casting. LIMITATIONS Like all products, Rose+Bopla’s cast aluminum enclosures do have limitations. Rose+Bopla cannot change the size of any of these boxes dimensionally. Rose+Bopla’s die cast boxes have depth limitations. Most designs are somewhat shallow. Rose+Bopla cannot increase depth. If depth is a problem, use Rose+Bopla’s Build-A-Box® enclosures which are made from aluminum extrusion that can be cut to any depth required. If you cannot find the size you need, please call the factory. We can do a custom size for your application. Tooling costs and minimum order may apply. ROSE+BOPLA COPPER FREE ALUMINUM Rose+Bopla uses AL Si 12 alloy in its cast aluminum housings. The term “Copper Free” is used to describe aluminum alloys which contain less then 0.4% copper. Rose+Bopla’s copper content is .10% for Die Castings and .05% for Chill Castings and Sand Castings. It is the reduction in the copper content which increases the natural corrosion resistant properties of aluminum. Copper Free aluminum is particularly resistant to salt atmospheres, sulphur gases and ammonium nitrate. Above a level of 0.4% copper, the range of corrosion due to galvanic action within the structure of the metal increases rapidly. Rose+Bopla’s aluminum alloys are highly superior to most ferrous materials. For military applications we irridite these enclosures to Mil Spec C-5541, Class 1A or Class 3. Rose+Bopla’s “Copper Free” aluminum products provide optimum protection against galvanic corrosion. ALUMINUM Mechanical, Electrical, and Thermal Properties Pressure Die-Cast Chill Cast Sand Cast Extrusion Unit Of Measurement Yield 130 80 70 160 N/mm2 Tensile Strength 240 170 150 215 N/mm2 Ductile Yield 1 6 5 12 % Brinnel Hardness 60 55 45 70 HB 2.65 2.65 2.65 2.7 g/cm3 Castability Very Good Excellent Excellent - Polishability Good Adequate Adequate Excellent Machinability Good Good Good Excellent Weldability Limited Excellent Excellent Excellent Resistance 18-27 18-27 18-27 28-34 m/⍀mm2 130-160 140-170 140-170 190-210 W/mK Heat Resistance 200 200 200 200 °C Cold Resistance -100 -100 -100 -100 °C Density Thermal Conductivity For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 135 Specifications Aluminum GENERAL ALUMINUM Article Aluminum Castings Aluminum Extrusions Aluminum Plates ALUMINUM TOLERANCES 136 DIN Alloy AA Alloy Closest Equivalent AL Si 12 B4130 A413 AL Mg Si 0.5 6060 6063 AL Mg 3 5754 5052 Sufficient tolerances must be allowed for cast aluminum enclosures and extruded aluminum enclosures. To properly do this, refer to DIN 1688 for castings and DIN EN 12020 for extrusions. Refer to tolerance charts on page 151 through 154. www.Rose-Bopla.com Specifications Fiberglass COMPRESSION MOLDED FIBERGLASS • Fiberglass Watertight Enclosures • Fiberglass Compression Molded Enclosures • Fiberglass Mobile Control Enclosures Made of glass fiber (25mm long) reinforced polyester plastic. Heat pressed compression molded under heat and pressure. This guarantees excellent dimensional stability under heat, excellent mechanical strength and dynamic load capacity, very low friction, excellent abrasion resistance to chemicals and weather, excellent surface finish, excellent dimensional stability and little tendency to stress and cracking. Reinforced glass fiber fiberglass (polyester) mats come in rolls. The rolls are cut in the correct size, weighed and then placed into a heated mold. Under high pressure the material liquifies, and fills the mold completely. After a few minutes under heat and pressure, the completed housing can be removed for trimming and assembly. In general, the resistance of this material to acids, bleaches and organic solvents ranges from good to excellent. Physical Properties Approx Value Unit of Measurement Test Standard KA 3c Class DIN 53480 Surface Resistance 1.0 x 1013 Ohm DIN 53482 Absorption of Water .6 % DIN 53472 Leakage Current Combustibility self-extinguishing ASTD D-635 UL 94 VO Flame Resistance self-extinguishing Almost Non-Flammable fully insulated VDE 0100-7 -40° C +250° C DIN 53458 Insulation Continuous Heat Thermal Conductivity: .6 W/mk (watts per meter x coefficient of thermal expansion) NOTE: VALUES SHOWN ARE APPROXIMATE. Approx Value Unit of Measurement Test Standard Density 1.50 g/cm3 DIN 53479 Resistance to Pressure 150 N/mm2 DIN 53453 1 % DIN 53455 Modulus of Elasticity 7100 N/mm2 DIN 53457 Bending Strength 180 N/mm2 DIN 53452 120-150 N/mm DIN 53454 Impact Resistance 21-25 2 KJ/m DIN 53453 Shear Resistance 180 N/mm DIN 53452 Mechanical Properties Elongation Compression Strength 2 2 NOTE: VALUES SHOWN ARE APPROXIMATE. For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 137 Specifications Fiberglass GFK FIBERGLASS Physical Properties Surface Resistance Approx. Value Unit of Measurement 4 x 1015 Ohm Insulation Burning Process Toxic Fumes fully insulated self-extinguishing Free of Halogenated Gases Moisture Content 0.2% Max Polystyrene Test Standard KDS 0303 DIN 53482 VDE 0100 UL 94 VO DIN 53495 ISO/R 62 Approx. Value Unit of Measurement Tensile strength, yield 27 MPa Tensile strain, yield 1.4 % 2200 MPa Normal strain at break 25 % ISO 527 Charpy impact, unnotched + 23° C - 30° C 150 120 kJ/m2 ISO 179/1eU Charpy impact, notched 23° C 16 kJ/m2 ISO 179/1eA 78 82 °C ISO 75 Method b 84 °C ISO 306 Flame resistance test HB Relative Permittivity (100Hz) 2.5 - ISO 60250 Relative Permittivity (1 MHz) 2.5 - ISO 60250 Dissipation Factor (100 Hz) 1.5 E-4 ISO 60250 Dissipation Factor (1 MHz) 4 E-4 ISO 60250 Surface resistivity >1013 Ohms IEC 60093 Physical Strength Tensile modulus Test Standard ISO 527 ASTM D 638 ISO 527, ASTM D 638 ISO 527 ASTM D 638 Heat deflation, temperature Method A Method B Vicat Softening, Temperature 138 UL 94/ISO 1210 www.Rose-Bopla.com Specifications Polycarbonate POLYCARBONATE Features excellent strength, stiffness and impact resistance, very good thermal stability, tough yet flexible down to -150° F, excellent dimensional accuracy and stability, weather resistance, excellent light transmission (up to 89% with translucent grades), good electrical insulating properties. High gloss finish. Mechanical fastening is a good technique for attaching materials and components to polycarbonate. It is relatively quick and provides high assembly strength. In addition, mechanical fastening does not subject the plastic to chemical changes, accordingly, losses in the properties of the polycarbonate are minimized. Screws are one form of mechanical fastening used to minimize induced assembly stresses in polycarbonate use. Thread cutting, rather than thread forming screws are recommended. A thread forming screw merely displaces material, setting-up areas of high stress. THREAD CUTTING screws remove material and do not cause excessive stress when used properly. NOTE POLYCARBONATE IS NOT TOLERANT OF OIL IN GENERAL AND HIGH SULPHIDE OILS, IN PARTICULAR. IF OIL IS CONTINUOUSLY PRESENT, WE DO NOT RECOMMEND POLYCARBONATE. For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 139 Specifications Polycarbonate POLYCARBONATE Physical Properties Approx. Value Unit of Measurement Standard Tensile stress, break 70 69 110 130 63 62 6 7 MPa ISO 527 ASTM D 638 ISO 527 ASTM D 638 Tensile strain, break MPa ISO 527 ASTM D 638 % ISO 527 ASTM D 638 2350 90 97 2300 2340 MPa ISO 527 ISO 178 ASTM D 790 ISO 178 ASTM D 790 No failure No failure 3204 KJ/m2 KJ/m2 Jm ISO 180/1U ISO 180/1U ASTM D 4812 25 10 801 KJ/m2 Jm ISO 180/1A ISO 180/1A ASTM D 256 No failure No failure KJ/m2 KJ/m2 ISO 179/1eU ISO 179/1eU 35 KJ/m2 ISO 179/2C 10 Mg/1000cy ASTM 1044 -- IEC 60695-10-2 ISO 8302 ASTM C 177 Specific heat Passes 0.2 0.27 1.26 Vicat Softening Temperature Method b Method a Long term service temperature 141 153 115-135 Tensile stress, yield Tensile strain, yield Tensile modulus Flexural stress, yield Flexural modulus Izod impact, unnotched + 23° C - 30° C + 23° C Izod impact, notched + 23° C - 30° C + 23° C Charpy impact, unnotched + 23° C - 30° C Charpy impact, notched + 23° C Taber abrasion, CS-17, 1 kg Ball indentation, 125° C Thermal conductivity Heat deflection temperature Method A Method B Flame resistance test MPa MPa W/m-°C J/g-°C ASTM C 351 °C ISO 306/ASTM D 1525 °C 135 140 V-2 °C 0.5-0.7 % Shrinkage Dielectric strength, in air, 3.2mm 1.0 mm in oil, 0.8mm in oil, 1.6mm in oil, 3.2mm Surface resistivity 15 15 35 27 17 >10^15 Volume resistivity 10^15 Permittivity 50 Hz 1MHz Water absorption 23°C, 50% RH 23° C, storage in H2O 140 % KV/mm ASTM D 149 IEC 60243-1 IEC 60243-1 IEC 60243-1 IEC 60243-1 Ohms IEC 60093 Ohm-cm IEC 60093 2.7 2.7 0.15 0.35 ISO 75 ISO 75 UL 94 IEC 60250 IEC 60250 % ISO 62 ISO 62 www.Rose-Bopla.com Specifications ABS ABS ABS offers an excellent combination of mechanical and thermal properties, outstanding stiffness, impact strength, hardness, heat resistance, and dimensional stability. ABS can be chemically electroplated. Approx. Value Unit of Measurement Test Standard Tensile stress, yield 50 MPa ISO 527 Tensile strain, yield 2.3 % ISO 527 2300 MPa ISO 527 72 MPa ISO 178 2460 MPa ISO 178 16 KJ/m2 ISO 180/1A No failure 75 KJ/m2 ISO 179/1eU Charpy impact, notched +23°C - 30°C 18 8 KJ/m2 ISO 179/2C Ball indentation, hardness 108 MPa ISO 2039-1 Thermal conductivity 0.18 W/mK DIN 52612 °C ISO 306 °C ISO 75 Physical Properties Tensile modulus Flexural stress, yield Flexural modulus Izod impact, notched + 23°C Charpy impact, unnotched + 23°C -30° C Vicat Softening, temperature Method b Method a 97 Heat deflection, temperature Method A Method B 92 96 Flame resistance test HB Dielectric Strength 17 KV/mm IEC 60243-1 Surface resistivity >1014 Ohms IEC 60093 Volume resistivity 1015 Ohm-cm IEC 60093 Water absorption 23°C, storage H2O 0.4 % ISO 62 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 UL 94/ISO 1210 141 Specifications ABS WEATHERABILITY OF POLYCARBONATE & ABS Unlike the Rose+Bopla compression molded and GFK fiberglass enclosures, our polycarbonate and ABS enclosures are affected by weather, particularly, ultra-violet light. The quality of most materials deteriorate if they are exposed to the weather for long periods of time. For ABS moldings, exposure to direct sunlight is harmful. Yellowing of the material gradually leads to changes in most color shades. The surface of the moldings lose their gloss, become harder and rough. If objects damaged in this way are subjected to mechanical load (eg: impact), a marked reduction in their initial toughness is noticeable, particularly if the damaged side is situated in the tensile zone of deflection with prolonged exposure to ultra violet rays, fine micro cracks will appear. Fine micro cracks act as notches. The original micro-crack damage itself only extends to a slight depth, and polishing the weathered surface restores its original toughness. To decide whether ABS or polycarbonate can be used depends on the extent to which it is affected by the above mentioned changes, the design of the part, and its application. For example, a part which suffers surface damage by impact in the compressive zone has a much better performance than a part suffering impact in the tensile zone. Polycarbonate is affected by weathering, but due to its general technical properties being higher in performance than ABS, the polycarbonate parts will retain higher mechanical values after equal exposure to weather. 142 www.Rose-Bopla.com Specifications Polyamide Material Properties Unit of Measurement Approx.Value Test Standard DIN 53453 Impact Strength KJ/m 35 – – Heat Resistance* °C 120 80-100* – Cold Resistance* °C -40 -40 DIN 53453 Notched Impact Strength KJ/m2 20 17 DIN 53452 Maximum Bending Stress N/mm2 100 150 DIN 53455 Elastic Modulus N/mm2 2700 6000 – Elastic Stretch % 18 4 UL 94 Flammability Class 94HB 94HB DIN 53472 Water Absorption % .9 1 DIN 53480 Creep Resistance Class KB 350 KB 350 Thermal Conductivity w/m °C – .33 VDE 0304/1 *The temperature resistance of the enclosure is dependent upon the installed gasket. Temperature limits can also be influenced by mechanical stress. 2 POLYAMIDE SPECIFICATIONS Material Properties of Plastics Test Requirements Material Properties Unit Impact strength +20° C Impact strength -40° C Notched impact str. (Charpy) +20° C Notched impact str. (Charpy) -40° C ISO 179 DIN 53453 ISO 179 KJ/m2 DIN 53453 ISO 178 N/mm2 DIN 53452 ISO 335–1 °C DIN 0471/2–1 ISO 75 °C DIN 53461 DIN 53461 W/mK ASTM 648 °C ISO 695 with mm DIN 0471/2–1 Grade from mm UL 94 Max. bending stress Round body pressure test Retention of shape under heat 1) A Retention of shape under heat 1) B Thermal conductivity Glow hot wire test Combustibility Water absorption Surface resistivity Special Volume resistivity Dielectric strength 1) KJ/m2 ISO 62 DIN 53495 ASTM D 570 IEC 93 Ohm DIN 53482 ASTM 257 IEC 93 Ohm DIN 53482 x cm VDE 303 T3 ASTM 257 IEC 243 DIN 53481 KV / mm VDE 303 T2 ASTM 149 % PS ABS PC SE 1 GFN1 PC / ABS Blend PA6.6 FR PA6 FR (NV12) PA6 GF 15 UP–GF – – 7 4 60 40 10 4 without breaking 25 10 30 30 – – – – – – – – – – without breaking 3.5 – 36 – 55 — 49 – – – – 64 >70 110 – – – – 100 – 75 125 125 125 – 125 – – 75 – 80 85 125 135 120 130 120 130 90 215 70 190 150 210 150 – 0.17 0.18 0.2 0.23 – – – – 0.6 – 650/2 850/1 960/3.2 960/2 – 850/1 – – HB/1.47 HB/1.6 V2/1.14 V1/1.47 VO/1.6 VO/1 V2/1.6 HB/1.6 VO/4 1013 >1014 >1015 >1015 – >1015 >1012 – >1012 >1016 >1015 >1016 >1015 – >1015 >1015 >1012 >1013 – 17 28 26 – – – – 25 The ability of the enclosure to maintain their shape when subject to heat depends on a seal being inserted. The temperature resistance can still be affected by mechanical stress. The above data are for guidance only. It has been determined using standardized test pieces and can vary within normal tolerances. The combustibility classification refers to the material and deviations are possible in finished parts if these have a different material strength. For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 143 Specifications Material Chemical Resistance Type Acetic acid Acetone Ammonia Benzene Benzole Brake fluid Butane Butanol Calcium chloride Carbon disulphide Carbon tetrachloride Caustic potash solution Chlorine benzole Citric acid Diesel oil Detergents Engine oils Formaldehyde Formic acid Frigen Fruit Juice Glycerine Heating oil Hydraulic oil Hydrochloric acid Lactic acid Linseed oil Lubricating oil Methanol Methylene chloride Mineral oils Nitric oils Potassium chloride Potassium hydroxide Soap suds Soda lye Sodium carbonate Sodium chloride Sodium hydroxide Sulphuric acid Tartaric acid Toluol Trichloroethylene Turpentine oil Water(distilled, river, tap, sea water) Xylol Zinc sulphate + % C° • / 144 PS ABS PC PA Aluminum Stainless Steel Polyester 50% + / / + 50% + / • 40% 40% / / + / 10% 80% + / / / 10% + / / 50% + + / 50% + + + 25% 25% • + / + 50% + + / + 30% / + • / / 80% + / / / / / / 50% + + + 50% + / + + 10% • + / + / 10% • + + / + + • • + 20% + + + + 10% + / • + + / 50% + • + + 5% + 10% + + + + 10% + + 50% + / + / + • + + + + + • + + • • + 10% / / + 10% / 10% + + + + + / + + + + + / + / + + + / + + / / / + • / / + + / / + + + + + / + • / / • • + • / + + / / + • + + + + + / / / + + / + / / / + / + + / + + + / + + + + + + / + + + + + + • + + / / / / + / / 40% + + + / + + + + + + / + 30% 10% + + + + + + + + + + 10% + + 40% + + 70% + + + + + + Resistant to all concentrations Resistant to max % concentration Resistant up to max C° Conditionally resistant Not resistant No information available www.Rose-Bopla.com Specifications Military THE FOLLOWING STANDARDS WILL BE APPLIED ONLY WHEN SPECIFIED. FEDERAL SUPPLY CODES Rose Federal Supply Code Rose Foreign Country Supply Code Cage Code QUALITY PROCEDURES ISO 9001:2000 CALIBRATION SYSTEM REQUIREMENTS ISO 9001:2000 ASSEMBLY & PACKAGING Mil Spec #STD-130 Special request only. ALUMINUM Mil Spec ASTM For Europe: STAINLESS STEEL LID SCREWS Hardness Cross: 70 Torque: M4 = 18-26 inch lbs. #FSCM-4Y520 #FSCM-C024 1L9R7 ASTM-B85 #B-8560: S 12A DIN 230 Alloy M6 = 26-35 inch lbs. Torque specs are included for reference only. Rose+Bopla does not recommend using a torque wrench on enclosures (tighten until snug). MACHINED SURFACES When specified, Rose+Bopla can: (A) Machine Surfaces to 125 micro inches or better (B) Deburr / Break All Sharp Edges (C) Remove All Burrs Helicoils Mil Spec #NASM-21209 Helicoil Insert Method Masking Surfaces Prior To Painting Rose+Bopla will mask all threaded surfaces and connector mating surfaces prior to primer and paint application. Chemical Surface Treatments Gold Irridite: Mil Spec Clear Irridite: Mil Spec #C-5541-Class 1A #C-5541-Class 3 NOTE: Gold irriditing to Mil Spec C-5541-Class 1A offers superior protection, but creates a less conductive surface for grounding or shielding. Clear irriditing to Mil Spec C-5541-Class 3 offers less protection from corrosion, but leaves a conductive surface which is recommended for optimum EMI shielding. All machined surfaces are irridited after machining. Anodizing Mil Spec Federal Standard # A 8625: Black Anodize Class 2 Type 2, Nickel acetate sealcoat test. #595A: Color 37038 NOTE: All machined surfaces can be anodized after machining. For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 145 Specifications Military: Coatings Rose+Bopla normally does not paint any inside surfaces on Military boxes, but leaves them gold irridited bare aluminum (unpainted) in accordance with normal requirements. Rose+Bopla will evaluate coating requirements on a per contract basis. Our capabilities include both wet spray and powder coating. Silk Screen Ink Mil Spec Mil Spec #A-56032 #A-56032 Epoxy Ink White Epoxy Ink Black Engraving Per customer’s specifications. 146 www.Rose-Bopla.com Specifications EMI/RFI Coatings and Gaskets EMI/RFI SHIELDED COATINGS We offer the Isolex WP 120 nickel acrylic conductive coating as our standard EMI/RFI coating. Upon request we also have available Electro DAG 7050, copper acrylic conductive coating. Detailed spec sheet is available upon request. EMI/RFI SHIELDED STANDARD GASKETS All data supplied is from manufacturer’s engineering data sheets. We offer the Cho-Seal 1350 gasket as our standard EMI/RFI gasket. Cho-Seal is a silver-plated glass-filled material and will not remain sufficiently conductive during vibration or after EMP-induced currents. Test Standard Grade Cho-Seal 1350 Industrial Commercial Elastomer Binder Conductive Filler Silicone Ag/glass Volume Resistivity (ohm-cm, max) as supplied MIL-G-83528 Para. 4.6.11 0.01 Durometer (shore A±5) Specific Gravity (±0.2) Tensile Strength (psi, min) Elongation (percent, min/max) ASTM D2240 ASTM D792 ASTM D412 65 1.8 150 ASTM D412 75/300 Tear Strength (lb./in., min.) Compression Set, 70 hrs @ 100° C (percent, max) ASTM D624 25 ASTM D395 Method B 30 ASTM D1329 -55 Low Temperature Flex, TRIO (° C, minimum) Electrical Stability Heat Aging Vibration During Resistance After (db, min.) 200 kHz (H Field) 100 MHz (E Field) 500 MHz (E Field) 2 GHz (Plane Wave) 10 GHz (Plane Wave) 160 (ohm-cm, max.) Shielding Effectiveness Maximum Continuous Use Temperature (° C) MIL-G-83528 Para. 4.6.12 50 100 100 90 80 MIL-G-83528 Para. 4.6.15 MIL-G-83528 Para. 4.6.13 N/A Post Tensile Set MIL-G-83528 Para. 4.6.9 0.01 0.01 EMP Survivability (KA) MIL-G-83528 Para. 4.6.16 NS For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 N/A 147 Specifications Gaskets EMI/RFI SHIELDED OPTIONAL GASKETS (SPECIAL ORDER ONLY) For military requirements where greater shielding is required, such as EMP survivability, we can supply Cho-Seal 1285 gasket, which meets the Specs listed below. Rose+Bopla DOES NOT stock this gasket. Accordingly, we will have to advise lead-time, delivery, cost and minimum quantity (if applicable), if Rose+Bopla is to supply this higher grade gasket. Test Standard Cho-Seal 1285 Grade Mil Aerospace Silicone Ag/Al Elastomer Binder Conductive Filler Volume Resistivity (ohm-cm, max) as supplied Durometer (shore A±5) Specific Gravity (±0.2) Tensile Strength (psi, min) Elongation (percent, min/max) Tear Strength (lb./in., min.) Compression Set, 70 hrs @ 100° C (percent, max) Low Temperature Flex, TRIO (° C, minimum) Maximum Continuous Temperature (° C) 200 kHz (H Field) 100 MHz (E Field) 500 MHz (E Field) 2 GHz (Plane Wave) 10 GHz (Plane Wave) 0.008 Para. 4.6.11 ASTM D2240 ASTM D792 ASTM D412 65 1.9 200 ASTM D412 100/300 ASTM D624 ASTM D395 Method B 30 ASTM D1329 -65 32 200 MIL-G-83528 Para. 4.6.15 0.01 MIL-G-83528 Para. 4.6.13 0.012 0.008 Post Tensile Set MIL-G-83528 Para. 4.6.9 0.015 EMP Survivability (KA) MIL-G-83528 Para. 4.6.16 0.9 Vibration During Resistance After (ohm-cm, max.) Heat Aging (db, min.) MIL-G-83528 Para. 4.6.12 60 115 100 105 100 Shielding Effectiveness Electrical Stability MIL-G-83528 * Maximum continuous use is defined as 1000 hours at max. rated temperature (compressed between flanges 7-10%) without electrical degradation above the limits given under Electrical Stability-Heat Aging. CROSS REFERENCE CHART 148 Rose Part Number Gasket Size Metric Inches 10082020 00 2.0mm .078 10082021 00 2.5mm .098 10082022 00 3.0mm .118 10082023 00 3.5mm .137 10082024 00 4.0mm .157 10082025 00 5.0mm .197 10082026 00 5.5mm .216 www.Rose-Bopla.com Specifications Standard Paint Color Guide STANDARD METALLIC COLOR GUIDE Product Category Description Acrylic Enamel # P. P. G. Industrial Color 01 04 01 07 Painted Aluminum Aluform Corrosion-Proof Aluminum P.C. Board Extrusions 0701, 0702, 0703, 0710, 0711 Profitronic 19 Body Profitronic 19 Trim 8850 Support Arms 49, 51, 61, 81 Suspension Components RAL 7001 RAL 7038 DAR 2825H Gray Light Gray Bright Blue RAL 9005 Black RAL 7035 RAL 7030 RAL 7035 White Gray Stone Gray Light Gray RAL 7043 Dark Gray 07 07 88 49 STANDARD NON-METALLIC COLOR GUIDE 13 Small Machine Control Enclosures 1300 Base RAL 7038 Light Gray 13 Small Machine Control Enclosures 1300 Bezels RAL 7043 Dark Gray SL 2000 Thin Profile Machine Control Enclosures RAL 7035 White Gray 54 Large Machine Control Enclosures 5400 DAR 5400 SC Gold Smoke Gray Product Category 02 06 PK 03, 33, EM 09, ET 21 21 21 14 17 08 29 Description RAL Color Fiberglass Fiberglass Safety Polyamide Polycarbonate ABS ABS Cabinets GFK Cabinets Compression-Molded Fiberglass Cabinets Fiberglass Modular Flange Polycarbonate Modular Flange Polyamide Cable Grips Mobile Control Housings 7000 9011 7001 7035 7035 7035 7032 7038 7032 7032 7035 1021 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 149 Specifications Cable Grip CABLE GRIP INSTALLATION INFORMATION PG cable glands are in the process of being phased out. These will be replaced with metric type glands. Rose+Bopla’s PG cable grips employ a special thread not generally available in America, therefore we are standardizing with metric. Accordingly, Rose+Bopla has a limited stock of taps for sale to customers wishing to drill, tap and install Rose+Bopla’s PG type cable grips at their own facilities. We do not offer metric taps, however they can be purchased through your local hardware supplier. Listed below is the necessary information for drilling and tapping holes for Rose+Bopla’s PG or metric cable grips and the appropriate tap part number. Thick wall applications require that you tap holes for cable glands. Thin wall applications may be drilled through with a nut. CROSS REFERENCE CHART Metric Cable Grip Size M 12 M 16 M 20 M 25 M 32 M 40 Tap Size Metric Tapped Hole Size M 12 x 1.5 M 16 x 1.5 M 20 x 1.5 M 25 x 1.5 M 32 x 1.5 M 40 x 1.5 10.5 mm 14.5 mm 18.5 mm 23.5 mm 30.5 mm 38.5 mm Inch Tapped Hole Size 0.413 0.571 0.728 0.925 1.2 1.516 Closest American Drill Size Metric Through-Hole z (.413) 37/64" (.578) 47/64" (.734) 59/64" (.922) - 12.2 mm 16.2 mm 20.2 mm 25.2 mm 32.2 mm 40.2 mm Inch Through-Hole 0.480 0.638 0.795 0.992 1.268 1.583 If you are going to use a polyamide grip with a nut and are not going to tap the hole, you will need to drill a larger hole to push the grip through. Use the chart below for the correct size hole. DRILL HOLE AND TAP INFORMATION Cable Grip Size PG 7 PG 9 PG 11 PG 13.5 PG 16 PG 21 PG 29 PG 36 PG 42 PG 48 Rose PG Tap Part Number 08070000 08090000 08110000 08130000 08160000 08210000 08290000 08360000 08420000 08480000 Metric Tapped Hole Size 11.5 mm 14 mm 17.25 mm 19 mm 21.25 mm 27 mm 35.5 mm 45.5 mm 52.8 mm 58 mm Wire Size CABLE GRIP SELECTION GUIDE 150 mm 3-6.5 4-8 6-10 6-12 7-12 10-14 13-18 14-18 20-25 24.32 32-38 37-44 Inches .12-.26 .18-.32 .24-.39 .24-.47 .28-.47 .39-.55 .51-.71 .55-.71 .79-.98 .95-1.26 1.26-1.50 1.46-1.73 Inch Tapped Hole Size 0.453 0.551 0.679 0.748 0.837 1.063 1.398 1.791 2.079 2.283 Closest American Drill Size Metric Through-Hole Inch Through-Hole 12.3 mm 15.1 mm 19.6 mm 20.2 mm 22.3 mm 28.2 mm 36.9 mm 48.8 mm - 0.484 0.594 0.772 0.795 0.878 1.11 1.453 1.921 - 29/64" ( .453) 35/64" ( .547) 43/64" ( .672) 3/4" ( .750) 53/64" ( .828) 1 1/16" (1.063) 1 25/64" (1.391) 1 51/64" (1.797) 2 5/64" (2.078) 2 9/32" (2.281) Metric Size PG Size American Size M12 M16 M16 M20 M20 M25 M32 M40 M50 M63 PG 7 PG 9 PG 11 PG 13.5 PG 16 PG 21 PG 29 PG 36 PG 42 PG 48 3/8" NPT 1/2" NPT 3/4" NPT 1" NPT - www.Rose-Bopla.com Tolerances Aluminum TOLERANCES FOR PRESSURE DIECASTINGS (DIN 1688)* 1) Determining the spatial diagonal: The spatial diagonal R is that between the extreme points of the casting. It is calculated from the nominal dimensions of the prismatic body, which delimits the casting, whatever its shape R = l2 + b2 + h2 (spatial diagonal) Table 1. Tolerances of dimensions for lengths, widths, heights, central distances, diameters and roundings. Nominal Dimension Area Spatial diagonal area Degree of exactitude over 180 GTA 13 over 50 up to 500 GTA 13/5 over 180 GTA 14 over 500 up to 18 over 18 up to 30 over 30 up to 50 over 50 up to 80 over 80 up to 120 over 120 up to 180 Intrinsic ±0.14 ±0.17 ±0.20 ±0.23 ±0.27 ±0.32 Non-Intrinsic ±0.24 ±0.27 ±0.30 ±0.33 ±0.37 ±0.42 Intrinsic ±0.17 ±0.20 ±0.25 ±0.30 ±0.35 Non-Intrinsic ±0.32 ±0.35 ±0.40 ±0.45 Intrinsic ±0.22 ±0.26 ±0.31 Non-Intrinsic ±0.42 ±0.46 Intrinsic ±0.25 Non-Intrinsic ±0.55 Shape dependency over 500 up to 630 over 630 up to 800 over 800 up to 1000 over 1000 up to 1250 ±0.80 ±0.90 ±1.00 ±1.20 ±1.30 ±0.90 ±1.00 ±1.10 ±1.20 ±1.40 ±1.50 ±0.80 ±0.85 ±0.95 ±1.10 ±1.20 ±1.40 ±1.60 ±1.10 ±1.10 ±1.20 ±1.40 ±1.50 ±1.70 ±1.90 over 180 up to 250 over 250 up to 315 over 315 up to 400 over 400 up to 500 ±0.40 ±0.45 ±0.50 ±0.55 ±0.60 ±0.50 ±0.55 ±0.60 ±0.65 ±0.70 ±0.75 ±0.37 ±0.44 ±0.50 ±0.60 ±0.65 ±0.70 ±0.51 ±0.57 ±0.64 ±0.70 ±0.80 ±0.85 ±0.35 ±0.40 ±0.45 ±0.55 ±0.65 ±0.75 ±0.65 ±0.70 ±0.75 ±0.85 ±0.95 ±1.00 GTA 14/5 Intrinsic dimensions are those in the same parts of the tool. Non-intrinsic dimensions are those created by the interaction of movable tool components, e.g. wall thickness and base thickness or dimensions affected by additives or extenders. *Important: We assume no liability for quoted standards. For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 151 Tolerances Aluminum TOLERANCES FOR PRESSURE DIECASTINGS (DIN 1688)* CONTINUED Table 2. Tolerances of dimensions for wall thicknesses, ledges and ribs. Nominal dimensional area Spatial diagonal area Degree of exactitude up to 180 GTA 13 over 50 up to 500 over 180 over 500 up to 3 over 3 up to 6 over 6 up to 10 Intrinsic ±0.15 ±0.20 ±0.20 Non-Intrinsic ±0.25 ±0.30 ±0.30 Intrinsic ±0.20 ±0.25 ±0.30 Non-Intrinsic ±0.35 ±0.40 ±0.45 Intrinsic ±0.25 ±0.30 ±0.35 Non-Intrinsic ±0.45 ±0.50 ±0.55 Intrinsic ±0.30 ±0.40 ±0.45 Non-Intrinsic ±0.55 ±0.65 ±0.70 Shape dependency GTA 13/5 GTA 14 GTA 14/5 Intrinsic dimensions are those in the same parts of the tool. Non-intrinsic dimensions are those created by the interaction of movable tool components, e.g. wall thickness and base thickness or dimensions affected by additives or extenders. 152 www.Rose-Bopla.com Tolerances Aluminum TOLERANCES FOR CHILL CASTINGS (DIN 1688)* In the case of raw castings made of light metal alloys in the chill casting process, all deviations in dimensions are essentially dependent on : a). the dimensional accuracy of the mold, characterized by the degree of accuracy b). the position of the mold division, cores, extenders, characterized by the subdivision into intrinsic and non-intrinsic dimensions (see DIN 1680 part 1) c). the nominal dimensions. Table 1. Deviations in lengthwise dimensions (lengths, widths, heights, central distances, diameters, roundings). Nominal Dimension Area Degree of accuracy up to 18 over 18 up to 30 over 30 up to 50 over 50 up to 80 over 80 up to 120 over 120 up to 180 over 180 up to 250 over 250 up to 315 over 315 up to 400 over 400 up to 500 over 500 up to 630 over 630 up to 800 over 800 up to 1000 over 1000 up to 1250 Intrinsic ±0.45 ±0.50 ±0.60 ±0.75 ±0.85 ±1.00 ±1.20 ±1.30 ±1.40 ±1.60 ±1.70 ±2.00 ±2.30 ±2.60 Non-Intrinsic ±0.55 ±0.65 ±0.80 ±0.95 ±1.10 ±1.30 ±1.50 ±1.60 ±1.80 ±2.00 ±2.20 ±2.50 ±2.80 ±3.30 Shape dependency GTA 15/5 Table 2. Deviations in thickness (wall thicknesses, ledges, ribs). Nominal Dimension Area Degree of accuracy up to 6 over 6 up to 10 over 10 up to 18 Intrinsic ±0.60 ±1.20 ±1.80 Non-Intrinsic ±0.80 ±1.50 ±2.20 Shape dependency Intrinsic dimensions are those in the same parts of the tool. Non-intrinsic dimensions are those created by the interactions of movable tool components, e.g. wall thicknesses and base thicknesses or dimensions affected by additives or extenders. GTA 15/5 *Important: We assume no liability for quoted standards! For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 153 Tolerances Aluminum TOLERANCES FOR ALUMINUM PROFILES ACCORDING TO DIN EN 12020-2* The tolerances for the nominal dimensions (see table 1) depend on the following ratios: - diameter of the minimum circumscribing circle du divided by the minimum wall thickness smin. - maximum wall thickness smax divided by the minimum wall thickness smin. Table 1 Tolerances for linear measurements Tolerances for a ratio of du : smin Range of dimensions up to 40 : 1 over 40 : 1 and a ratio of smax : smin ABPH 800 (Full Profile) up to 6 : 1 up to 10 15 30 45 60 90 120 150 180 240 300 over 10 15 30 45 60 90 120 150 180 240 over 6 : 1 ±0.15 ±0.20 ±0.25 ±0.30 ±0.40 ±0.45 ±0.60 ±0.70 ±0.90 ±1.10 ±1.40 ±0.80 ±1.00 ±1.20 ±1.50 Table 2 Tolerances for the wall thickness of full profiles Range of dimensions ABP 800 (Hollow Profile) over up to 1.5 3 6 10 15 20 30 1.5 3 6 10 15 20 30 40 Tolerances for wall thickness ±0.15 ±0.20 ±0.25 ±0.30 ±0.40 ±0.50 ±0.60 ±0.70 Table 3 Tolerances for the wall thickness of hollow profiles Range of dimensions over up to 1.5 1.5 2 2 3 3 6 6 9 9 12 12 15 15 20 to 75 ±0.20 ±0.20 ±0.25 ±0.35 ±0.50 ±0.60 ±0.70 - Tolerances for the wall thicknesses with a circumscribing circle du over 75 over 130 over 250 to 130 to 250 to 300 ±0.25 ±0.25 ±0.30 ±0.30 ±0.35 ±0.45 ±0.40 ±0.50 ±0.60 ±0.55 ±0.70 ±0.80 ±0.70 ±0.85 ±0.95 ±0.80 ±1.00 ±1.10 ±1.00 ±1.20 ±1.30 *Important: We assume no liability for quoted standards! 154 www.Rose-Bopla.com Tolerances Plastic TOLERANCES OF PLASTICS ACCORDING TO DIN 16901 Deviations from the nominal dimensions are unavoidable in the manufacture of plastic shapes. There are various reasons for the deviations: a) Processing parameters. These are dependent on: • the evenness of the shape the setting of the machine the temperature of the tools the distortion of the tool under pressure b) The condition of the tool: manufacturing tolerances for tool dimensions (see DIN 16749) wear on tools deviations in the position of movable tool parts. The tolerances for this norm have been laid down taking into account these factors and numerous measurements in practice. The plastics in this norm are divided into tolerance rows. All the plastics used by Rose+Bopla for standard enclosures are in row 130, for which tolerances given below apply. The tolerances apply on the basis of the machining shrinkage working into the tool only for the appropriate enclosure with the standard material stated. Nominal dimension area over up to A B over up to A B 0 1 ±0.18 ±0.08 90 120 ±0.51 ±0.41 1 3 ±0.19 ±0.09 120 160 ±0.60 ±0.50 3 6 ±0.20 ±0.10 160 200 ±0.70 ±0.60 6 10 ±0.21 ±0.11 200 250 ±0.90 ±0.80 10 15 ±0.23 ±0.13 15 22 ±0.25 ±0.15 250 315 ±1.10 ±1.00 315 400 ±1.30 ±1.20 22 30 ±0.27 ±0.17 400 500 ±1.60 ±1.50 30 40 ±0.30 ±0.20 40 53 ±0.34 ±0.24 500 630 ±2.00 ±1.90 630 800 ±2.50 ±2.40 53 70 ±0.38 ±0.28 70 90 ±0.44 ±0.34 800 1000 ±3.00 ±2.90 A = Dimensions which are not tool specific are those formed by the interaction of movable tool parts, e.g. wall thicknesses and floor thicknesses or dimensions which are affected by additives or pushers. B = Tool-specific dimensions are those in the same part of the tool. *Important: We assume no liability for quoted standards! For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 155 Protection Classifications Standards Comparison: NEMA, UL, CSA Standard Enclosures Type Designation National Electrical Manufacturers’ Association (NEMA Standard 250) Underwriters’ Laboratories Inc. (UL 50 and UL 508) Canadian Standards Association (Standard C22.2, Nos. 14, 40 and 94) Enclosures are intended for use indoors, primarily to prevent accidental contact of personnel with the enclosed equipment in areas where unusual service conditions do not exist. Indoor use primarily to provide a degree of protection against contact with the enclosed equipment and against a limited amount of falling dirt. General purpose enclosure. Protects against accidental contact with live parts. Indoor use primarily to provide a degree of protection against contact with the enclosed equipment and against a limited amount of falling water and dirt. An enclosure for indoor use, constructed so as to provide a degree of protection against dripping and light splashing of non-corrosive liquids, and falling dirt. Indoor use to provide a degree of protection against limited amounts of falling water and dirt. Enclosures are intended for outdoor use primarily to provide a degree of protection against windblown dust, rain, sleet, and external ice formation. Outdoor use to provide a degree of protection against windblown dust, rain, and sleet; undamaged by the formation of ice on the enclosure. Enclosures are intended for outdoor use primarily to provide a degree or protection against windblown falling rain, sleet, and external ice formation. (May be ventilated). Outdoor use to provide a degree of protection against windblown dust, rain, and sleet; undamaged by the formation of ice on the enclosure. An enclosure for either indoor or outdoor use, constructed so as to provide a degree of protection against rain, snow, windblown dust, splashing and hose-directed water; undamaged by the external formation of ice on the enclosure. Enclosures are intended for use indoors or out doors, to protect the enclosed equipment against splashing water, seepage of water, falling or hose directed water, and severe external condensation. They are sleet resistant but not sleet (ice) proof. Indoor or outdoor use to provide a degree of protection against splashing water, windblown dust and rain, and hose-directed water; undamaged by the formation of ice on the enclosure. An enclosure for either indoor or outdoor use, constructed so as to provide a degree of protection against rain, snow, windblown dust, splashing and hose-directed water; undamaged by the external formation of ice on the enclosure. Type 4X enclosures have the same provisions as Type 4 enclosures and, in addition, are corrosion-resistant. Indoor or outdoor use to provide a degree of protection against splashing water, windblown dust and rain, and hose-directed water; undamaged bythe formation of ice on the enclosure; resists corrosion. An enclosure for either indoor or outdoor use, constructed so as to provide a degree of protection against rain, snow, windblown dust, splashing and hose-directed water; undamaged by the external formation of ice on the enclosure; resists corrosion. 12 Enclosures are intended for use indoors to protect the enclosed equipment against fibers, flyings, lint, dust, and dirt, and light splashing, seepage, dripping and external condensation of non-corrosive liquids. Indoor use to provide a degree of protection against dust, falling dirt, and dripping non-corrosive liquids. An enclosure for indoor use, constructed so as to provide a degree of protection against circulating dust, lint, fibers, and flyings; drippings and light splashing of non-corrosive liquids; not provided with knockouts. 13 Enclosures are intended for use indoors primarily to house pilot devices such as limit switches, foot switches, pilot lights, etc., and to protect these devices against lint and dust, seepage, external condensation, and spraying of water, oil, and coolant. Indoor use to provide a degree of protection against dust and spraying of water, oil, and non-corrosive coolants. An enclosure for indoor use, constructed so as to provide a degree of protection against circulating dust, lint, fibers, and flyings; seepage and spraying of non-corrosive liquids including oils and coolants. 1 2 3 3R 4 4X An enclosure for either indoor or outdoor use, constructed so as to provide a degree or protection against rain, snow, and windblown dust; undamaged by the external formation of ice on the enclosure. Please Note: The information presented here is for reference only and is not meant to be a definitive description of the test requirements and/or qualifications. The complete standards should be obtained from the appropriate association or agency. 156 www.Rose-Bopla.com Protection Classifications Comparison of NEMA and IEC Standards ENCLOSURE TYPES Europe IEC specifications 144 & 529 define the degree of protection provided electrical enclosures to safeguard personnel against electric shock and equipment within the enclosure from environmental contamination such as entry of water. This is expressed by the letters IP followed by two numerals. In the USA, NEMA and UL have established a rating system for enclosures which provided for different levels of protection. A direct comparison between IEC and NEMA is not possible but the following table gives an approximate guide. NEMA TO IEC Enclosure Rating Comparison NEMA TYPE IP 23 1 • 2 IP 30 IP 32 IP 64 IP 65 IP 66 IP 67 • • 3 3R • • • 4 4X • 6 12 13 • • Note: This comparison table is an approximation of NEMA and IEC classifications and is for reference only. Complete standards should be obtained from the appropriate association or agency. For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 157 Protection Classifications I.P. Ingress Protection Classifications to DIN VDE 0470/EN 60529* The protection classification offered by an enclosure is shown by the letters IP Ingress Protection, and two digits. The first digit indicates two factors (protection for persons and equipment). The second digit indicates only one factor, protection against water. Similarly, changes in temperature, as may occur, for example, in the open air, are not taken into account. Such changes in temperature may cause a loss of pressure in the enclosure, and dampness may be absorbed through the seal area. Rose+Bopla can supply pressure compensation elements for this purpose. First digit: Protection for persons and equipment Persons Digit Brief Description Definition Brief Description Definition 0 Not protected – Not protected – 1 Protection against the back of the hand touching dangerous parts A round body, 50mm in diameter, must be at a sufficient distance from dangerous parts Protection against a solid foreign body of 50mm or more in diameter A round body, 50mm in diameter, must not fully penetrate The test finger, jointed, 12mm in diameter and 80mm long, must be at a sufficient distance from dangerous parts Protection against a solid foreign body of 12.5mm or more in diameter A round body, 12.5mm in diameter, must not penetrate at all 3 Protection against a tool touching dangerous parts A body, 2.5mm in diameter, must not be able to penetrate Protection against a solid foreign body of 2.5mm or more in diameter A round body, 2.5mm in diameter, must not penetrate at all 4 Protection against a wire touching dangerous parts A body, 1.0mm in diameter, must not be able to penetrate Protection against a solid foreign body of 1.0mm or more in diameter A round body, 1.0mm in diameter, must not penetrate at all 5 Protection against a wire touching dangerous parts A body, 1.0mm in diameter, must not be able to penetrate Protection against dust No dust penetration 6 Protection against a wire touching dangerous parts A body, 1.0mm in diameter, must not be able to penetrate Sealed against dust No dust penetration 2 1) Equipment Protection against a finger touching dangerous parts Dust must not penetrate in sufficient quantities to prevent the equipment from operating satisfactorily, or to impair safety. Important note:The protection classifications given for the enclosures refer to unmachined enclosures as supplied. In the case of protection against water in particular (second digit), the test conditions will be met if during the given time for the experiment no water has penetrated, or not in harmful quantities. As the tests to show protection classifications take no account of ageing, the maintenance of the protection classification throughout the lifetime of the equipment in not guaranteed. *We assume no liability for quoted standards. 158 www.Rose-Bopla.com Protection Classifications Example: IP54 –first digit 5= protection against dust and wire contact with dangerous parts –second digit 4= protection against splashing water Second digit: Protection against water Digit Brief Description Definition 0 Not protected – 1 Protection against vertical water drops Drops of water falling vertically onto the enclosure must not have any harmful effects 2 Protection against vertical water drops when the enclosure is inclined at 15° 3 Protection against water spray Water sprayed onto the enclosure at up to 60° on both sides of the vertical must not have any harmful effects 4 Protection against water spray Water splashed onto the enclosure from any direction must not have any harmful effects 5 Protection against water jet Water splashed onto the enclosure from any direction must not have any harmful effects 6 Protection against powerful water jet A strong water jet directed at the enclosure from any direction must not have any harmful effects 7 Protection against the effects of temporary immersion in water Water must not enter in a quantity that could have harmful effects if the enclosure is temporarily immersed in water under standardized pressure and time conditions 8 Protection against the effects of constant submersion in water Water must not enter in a quantity that could have harmful effects if the enclosure is kept permanently under water under conditions agreed between the manufacturer and the user; however, these must be more severe than those under figure 7 For Secondary Services, Product Support, or To Order, Call 1-301-696-9800 Drops of water falling vertically onto the enclosure must not have any harmful effects if the enclosure is inclined by up to 15° on both sides of the vertical 159 ® ROSE+BOPLA A Phoenix Mecano Company Credit Application 30 day credit limit requested $ Company Name Phone Street Address City Fax Number Are you incorporated? Where BANK REFERENCES SUPPLIER REFERENCES Zip When Tax Exemption Number: PRINCIPAL OFFICERS State Please provide Tax Exemption Certificate with Application Name Title Name Title Bank Name Account No. Phone Bank Name Account No. Phone Bank Name Account No. Phone Name Address Phone City Name Address State Phone City Name Address Fax Fax State Phone City Zip Zip Fax State Zip TERMS AND APPLICATION FOR CREDIT: We hereby agree that Rose+Bopla terms are Net 30 days from the date of invoice, with interest charge at 1½ percent per month on all accounts past due. Signature*: Authorized By Title Date DO NOT WRITE BELOW THIS LINE *It is understood that by signing the Rose+Bopla Credit Application you, the customer, agree to Rose+Bopla’s Net 30 credit terms, including a 1½% late finance charge per month for any overdue balance. By signing this document, you also agree to give Rose+Bopla permission to investigate your credit worthiness through trade references and credit bureau research. ROSE+BOPLA ENCLOSURES • 7330 Executive Way • 160 Frederick, Maryland 21704-8377 • A PHOENIX MECANO COMPANY Telephone (301) 696-9800 • Fax (301) 696-9494 www.Rose-Bopla.com ® Who Is Phoenix Mecano? ROSE+BOPLA A PHOENIX MECANO COMPANY Phoenix Mecano is dedicated to achieving customer satisfaction through continuous improvement. Using best business practice, lean manufacturing and sustained supply chain operations Phoenix Mecano Inc. markets its products and services through three product divisions in Maryland. The Frederick, Maryland facility serves as headquarters for North American operations. PMI is part of Phoenix Mecano AG, an international corporation based in Switzerland comprised of independent manufacturing plants worldwide. Rose+Bopla, a division of PMI, manufactures an extensive line of off-the-shelf and customized enclosures, as well as suspension arm systems. The Rose line is suited for industrial applications and harsh environments in a variety of materials__cast and extruded aluminum; fiberglass; stainless steel; polycarbonate; polyamide; and ABS. By contrast, Bopla produces a diverse line of modular tabletop, handheld, and wall-mount plastic enclosures designed to meet today’s demands for aesthetic electronic packaging. Value-added secondary services at PMI offer our customers a broad range of specialized manufacturing processes. Secondary services include: irriditing, chromating, anodizing, wet painting, powder-coating, silk-screening, engraving, drilling, tapping, milling, etching, in-house prototyping and engineering services, as well as product print generation. ® ROSE+BOPLA A PHOENIX MECANO COMPANY Rose+Bopla sales representatives are available to assist you in choosing the right enclosure for your application. Orders and inquiries are processed during normal business hours, 8:30 am to 5:00 pm ET, Monday through Friday. Feel free to contact us at 301-696-9800, or learn more online at www.Rose-Bopla.com. 7330 Executive Way Frederick, Maryland 21704 301-696-9800 301-696-9494, Fax CustomerService@Rose-Bopla.com www.Rose-Bopla.com ISO 9001:2000 Certified ® 7330 Executive Way Frederick, MD 21704 USA 301-696-9800, Phone 301-696-9494, Fax E-Mail: CustomerService@Rose-Bopla.com Web: www.Rose-Bopla.com 5,000 12/07 A Phoenix Mecano Company
12002500 价格&库存
很抱歉,暂时无法提供与“12002500”相匹配的价格&库存,您可以联系我们找货
  • 1+64.21338
  • 5+59.38433
  • 10+54.54341
  • 20+51.62462
  • 50+48.69396
库存:66
