1100.20.150
1100.20.150
    AMERICANELECTRICAL(美国电气)
    CBLGRP11.0-15.0MMCDM20X1.5
1100.20.150 数据手册
Cable Grips Cable Grips secure cables to control cabinets or junction boxes – providing strain relief and protection from the elements. They are made of metal (nickel plated brass) or plastic (nylon). Advantages exist for both types of cable grip with the nylon versions becoming more popular since they can provide the same level of protection against dust, debris and water as the metallic versions – for less cost and weight. Cable Grips are specified first by the cable diameter and second by thread type. Cable Grips are available in three different thread types, PG (Panzer Gewinde, a German specified thread widely used in Europe), Metric and NPT (National Pipe Thread – used in USA). This is useful since most specifiers thread the cabinet holes so that the cable grip can be screwed into it for a more secure fit. Others simply knockout a hole and place the cable grip inside it. Our Cable Grips are approved by UL and Lloyds of London and are rated IP 68, the highest Ingress Protection available. Ingress Protection consists of two numbers – the first between 0 and 6, indicating the resistance to particles and the second between 0 and 8, indicating resistance to water. Please see our charts on pages 164 and 165 explaining the IP system. 161 Table of Contents - Cable Grips 162 Nickel-Plated Brass Metric . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 166-170; 202 Pg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 171-174; 203 NPT . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 175 Gas Threads . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 175 High Temperature Applications . . . . . . . . . . . . . . . . 177-180 Multiple Cables . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 181-184 No Drilled Holes . . . . . . . . . . . . . . . . . . . . . . . . . . . . 185-186 Flat Cables . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 187-189 Special Entry Thread . . . . . . . . . . . . . . . . . . . . . . . . . 190-191 Anti-Kink/Nozzle/Spring/Clamps . . . . . . . . . . . . . . . . 190-197 Trumpet . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 198-201 Stainless Steel . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 202-205 Stainless Steel Acid Resistant . . . . . . . . . . . . . . . . 206-207 Elbows . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 208-211 45 Degree . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 212-213 DIN 46320-C4-MS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 214 Anti-Kink Nozzle and Clamps . . . . . . . . . . . . . . . . . . . . . . . 215 Electro-Magnetic Compatibility (EMC) Shield Grounding . . . . . . . . . . . . . . . . . . . . . . . . . . . . 216-229 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Table of Contents - Cable Grips Nylon Nylon Neoprene Seal -30-100°C . . . . . . . . . . . . . . . . 230-235 Anti-Kink . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 236-239 Elbows . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 240-241 Locknuts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 242-247 Reducers / enlargers / adapters Nickle-plated Brass . . . . . . . . . . . . . . . . . . . . . . . . . . 248-257 Nylon . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 258-261 Locking Plugs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 262-266 O Rings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 268-271 Cross Reference Heyco and Olflex . . . . . . . . . . . . . 272-273 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 163 Cable Grips 9 7 3 1 2 5 6 8 10 4 main features: Cable Grips 1 Wider domed nut which can not be over-tightened. The wide dome design allows space for the neoprene seal to form a tight grip on the cable, forming an IP68 barrier. (please refer to Ingress Protection [IP] ratings on the back page.) 2 7 8 Spacer Neoprene rubber seal Webs are staggered for better grip Webs are designed in an alternating geometry which enhances gripping capability. Retention springs for domed nut The ‘Tight Seal’ design allows the domed nut to lock with the collett before any threads are engaged. This guards against misthreads as well as aids in the installation process. 9 This seal grips around the cable to form the IP68 barrier when properly tightened. 5 Sprung webs The webs are designed so that they will spring back to their original open position making installation easy while maintaining the seal quality. A small spacer exists between the domed nut and the locking collett, providing an additional seal when fully tightened. 4 Staggered webs The web design is staggered to allow for seal conformity around the cable to maximize the pull out resistance and protection against the elements. Generous deep flats The deep flats allow enough room for the proper wrench to tighten or loosen the cable grip without the wrench coming off. 3 6 Sealing lip The collett design incorporates a sealing lip which provides for a positive seal against the enclosure. 10 Anti-Twist cable locking collett The entire design of the ‘Tight Seal’ product line insures that cables will not twist or turn once locked down. technical data Material: Polyamide PA 6, self-extinguishing, halogen-free Seal: Neoprene, oil and petroleum resistant Operating temperature: Static: –40°C to 100°C, short-term 120°C Dynamic: –30°C to 80°C, short-term 100°C Safety Class: IP68, waterproof (5 bar) Patents: Europe, USA, Japan VDE Test Report: 12 796-9000-4001/A 2 J. UL test (Underwriters Laboratories Inc.) Weather resistance good Lloyd’s Register of Shipping certificate Strain relief: Germanische Lloyd certificate Smooth action 164 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Grips Knockout Hole Reference Chart Ingress Protection (IP) Ratings PG 7 9 11 13.5 16 21 29 36 42 48 mm 12.5 15.2 18.6 20.4 22.5 28.3 37 47 54 59.3 inches 0.492 0.598 0.732 0.803 0.886 1.114 1.457 1.85 2.126 2.338 metric 12 16 20 25 32 40 50 63 mm 12 16 20 25 32 40 50 63 inches 0.472 0.63 0.787 0.984 1.26 1.575 1.969 2.48 List of Protection Classes IP Protection Classes to DIN 40 050 Sheet 1 Up to 1000 VAC and 1500 VDC (UTE standard C 200 10) IP ratings consist of a two digit number explained below: The two digits correspond to the description by DIN 40 050 sheet 1, IEC 144 and 525 as well as UTE C 200 10. 1st Digit Degree of Protection Against Touching and Foreign Matter 2nd Digit Degree of Protection Against Water IP Specifications 0 No protection. 1 Protection against penetration by solid foreign matters larger than 50 mm (accidental touching by hand). 2 Protection against penetration by solid foreign matters larger than 12 mm (touching with fingers). 3 Protection against penetration by solid foreign matters larger than 2.5 mm (touching with tools, wires larger than 2.5 mm). 4 Protection against solid foreign matters larger than 1 mm (touching with tools, wires larger than 1 mm). 5 Complete protection from being touched. Protection from harmful dust deposits dust penetration is not completely prevented. 6 Complete protection from being touched. Protection against penetration by dust. IP Specifications 0 No protection. 1 Protection against vertically dripping water. 2 Protection against drip water falling at an angle of up to 15 degrees. 3 Protection against spray water falling at an angle of up to 60 degrees. 4 Protection against spray water from all directions. 5 Protection against water jets from all directions 6 Protection against temporary flooding, e.g., by rough sea. 7 Protection when submersed in water at specified pressure and unspecified duration. 8 Protection when submersed in water at elevated pressure and unspecified time. 9K Protection against the penetration of water during high pressure (80-100 bars), high temperature wash-down applications (80°C). Use and Application of Nylon Cable Grips 1. The use of synthetic - Cable Grips is almost unlimited within the electrical and electronics industry. Installations where cables must be led safely through a wall of an enclosure will be specified with cable grips. Synthetic Cable grips are specified to: • Secure the cable • Seal and protect • Reduce material cost due to use of lighter, less to the enclosure’s wall to provide excellent pull-out resistance. the inside of the enclosure from the unwanted affects of the environment. These contaminants may be water, gas, chemicals vapors, or fumes. expensive materials, as well as, eliminating the need for running conduit. 2. Some of the typical applications using cable grips are: • • • • • • • • • • • • • • • Machinery Process equipment engineering Apparatus and appliance construction Aircraft and automotive engineering Locomotive engineering Elevator engineering Plant engineering Chemical and pharmaceutical industries Refineries Nuclear research institutions Process automation and process engineering Indoor and outdoor electrical installations Switchgear and distribution construction equipment for military purposes municipal and utility type applications, such as power, electricity and gas works American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 165 Cable Glands Nickel-Plated Brass short entry thread metric Material: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: Nickel-plated brass TPE NBR According to EN 50262 version A -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS One-piece sealing insert / overall length insulated​ ​ M6x1.0 M6x1.0 M8x1.25 M8x1.25 M10x1.5 M10x1.5 M12x1.5 M12x1.5 M12x1.5 M16x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 M40x1.5 M40x1.5 M50x1.5 M50x1.5 M63x1.5 M63x1.5 M75x1.5 M75x1.5 min ​ 2.0 2.5 2.5 3.0 3.0 4.0 3.5 5.0 6.5 4.5 6.0 8.0 6.0 8.0 11.0 9.5 12.5 16.0 17.0 21.0 24.0 28.5 33.0 37.0 40.0 46.0 50.0 56.0 max ​ 2.5 3.0 3.0 4.0 4.0 6.0 5.0 6.5 7.5 6.0 8.0 10.5 8.0 11.0 14.5 12.5 16.0 19.0 21.0 25.5 28.5 33.0 37.0 42.0 46.0 52.0 56.0 63.0 ​ 8 8 11 11 13 13 15 15 15 18 18 18 24 24 24 30 30 30 36 36 46 46 55 55 70 70 80 80 ​ 12 12 14 14 15 15 17 17 17 20 20 22 21 21 23 25 25 28 28 28 31 31 34 34 37 37 38 38 ​ 5 5 5 5 5 5 5 5 5 5 5 5 6 6 6 7 7 7 8 8 8 8 9 9 10 10 11 11 ​ 1 1 1 1 1 1                                             - Part. no. 1060.06.025 1060.06.030 1060.08.030 1060.08.040 1060.10.040 1060.10.060 1060.12.050 1060.12.065 1060.12.075 1060.17.060 1060.17.080 1060.17.105 1060.20.080 1060.20.110 1060.20.145 1060.25.125 1060.25.160 1060.25.190 1060.32.210 1060.32.255 1060.40.285 1060.40.330 1060.50.370 1060.50.420 1060.63.460 1060.63.520 1060.75.560 1060.75.630 ​​ 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 25 25 25 25 25 10 10 10 10 5 5 1 1 1 = Metric coarse-pitch thread ​ Progress MS Two-piece sealing insert / overall length insulated​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 M75x1.5 166 min 6.0 8.0 12.5 17.0 24.0 33.0 40.0 50.0 ​ max 10.5 14.5 19.0 25.5 33.0 42.0 52.0 63.0 ​ ​ 18 24 30 36 46 55 70 80 ​ 22 23 28 28 31 34 37 38 ​ 5 6 7 8 8 9 10 11 Part. no. 1060.17 1060.20 1060.25 1060.32 1060.40 1060.50 1060.63 1060.75 ​​ 50 50 25 25 10 10 5 1 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass short entry thread metric Material: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: Nickel-plated brass TPE / NBR NBR According to EN 50262 version A -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS One-piece sealing insert / not overall length insulated​ ​ M6x1.0 M6x1.0 M6x1.0 M8x1.25 M8x1.25 M10x1.5 M10x1.5 M12x1.5 M12x1.5 M12x1.5 M16x1.5 M16x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 M32x1.5 M40x1.5 M40x1.5 M40x1.5 M50x1.5 M50x1.5 M50x1.5 M63x1.5 M63x1.5 M63x1.5 M75x1.5 M75x1.5 M75x1.5 M85x2.0 M95x2.0 M95x2.0 M100x3.0 M105x3.0 M115x3.0 min 2.0 2.5 3.0 2.5 3.5 3.0 4.0 3.5 5.0 6.5 3.5 4.5 6.0 8.0 6.0 8.0 11.0 9.5 12.5 16.0 14.0 17.0 21.0 20.0 24.0 28.5 29.0 33.0 37.0 35.0 40.0 46.0 45.0 50.0 56.0 63.0 68.0 73.0 78.0 83.0 88.0 ​ max 2.5 3.0 3.5 3.5 5.0 4.0 6.0 5.0 6.5 8.0 4.5 6.0 8.0 10.5 8.0 11.0 15.0 12.5 16.0 20.5 17.0 21.0 25.5 24.0 28.5 33.0 33.0 37.0 42.0 40.0 46.0 52.0 50.0 56.0 63.0 70.0 75.0 80.0 85.0 90.0 95.0 ​ ​ 8 8 8 11 11 13 13 15 15 15 18 18 18 18 24 24 24 30 30 30 36 36 36 46 46 46 55 55 55 70 70 70 80 80 80 95 110 110 115 120 125 ​ 12 12 12 14 14 15 15 17 17 17 20 20 20 22 21 21 23 25 27 28 28 28 28 31 31 31 34 34 34 37 37 37 38 38 38 41 51 51 51 52 52 ​ 5 5 5 5 5 5 5 5 5 5 5 5 5 5 6 6 6 7 7 7 8 8 8 8 8 8 9 9 9 10 10 10 11 11 11 18 20 20 22 22 22 ​ 1 1 1 1 1 1 1        - Part. no. 1000.06.025 1000.06.030 1000.06.035 1000.08.035 1000.08.050 1000.10.040 1000.10.060 1000.12.050 1000.12.065 1000.12.080 1000.17.045 1000.17.060 1000.17.080 1000.17.105 1000.20.080 1000.20.110 1000.20.150 1000.25.125 1000.25.160 1000.25.205 1000.32.170 1000.32.210 1000.32.255 1000.40.240 1000.40.285 1000.40.330 1000.50.330 1000.50.370 1000.50.420 1000.63.400 1000.63.460 1000.63.520 1000.75.500 1000.75.560 1000.75.630 1000.85.700 1000.95.750 1000.95.800 1000.100.850 1000.105.900 1000.115.950 ​​ 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 25 25 25 25 25 25 10 10 10 10 10 10 5 5 5 1 1 1 1 1 1 1 1 1 1 = Metric coarse-pitch thread American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 167 Cable Glands Nickel-Plated Brass short entry thread metric Material: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: Nickel-plated brass TPE NBR According to EN 50262 version A -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS Two-piece sealing insert / not overall length insulated ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 M75x1.5 min ​ 6.0 8.0 12.5 17.0 24.0 33.0 40.0 50.0 max ​ 10.5 15.0 20.5 25.5 33.0 42.0 52.0 63.0 ​ 18 24 30 36 46 55 70 80 ​ 22 23 28 28 31 34 37 38 Part. no. ​ 5 6 7 8 8 9 10 11 1000.17 1000.20 1000.25 1000.32 1000.40 1000.50 1000.63 1000.75 ​​ 50 50 25 25 10 10 5 1 long entry thread metric ​ Progress MS One-piece sealing insert / overall length insulated​ ​ M6x1.0 M6x1.0 M8x1.25 M8x1.25 M10x1.5 M10x1.5 M12x1.5 M12x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 M75x1.5 min ​ 2.0 2.5 2.5 3.0 3.0 4.0 3.5 5.0 6.5 8.0 11.0 16.0 21.0 28.5 37.0 46.0 56.0 max ​ 2.5 3.0 3.0 4.0 4.0 6.0 5.0 6.5 7.5 10.5 14.5 19.0 25.5 33.0 42.0 52.0 63.0 ​ 8 8 11 11 13 13 15 15 15 18 24 30 36 46 55 70 80 ​ 12 12 14 14 15 15 17 17 17 22 23 28 28 34 34 37 38 ​ 8 8 10 10 10 10 10 10 10 10 10 11 13 13 14 14 15 ​ 1 1 1 1 1 1                       - Part. no. 1160.06.025 1160.06.030 1160.08.030 1160.08.040 1160.10.040 1160.10.060 1160.12.050 1160.12.065 1160.12.075 1160.17.105 1160.20.145 1160.25.190 1160.32.255 1160.40.330 1160.50.420 1160.63.520 1160.75.630 ​​ 50 50 50 50 50 50 50 50 50 50 50 25 25 10 10 5 1 1 = Metric coarse-pitch thread ​ Progress MS Two-piece sealing insert / overall length insulated​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 M75x1.5 168 min 6.0 8.0 12.5 17.0 24.0 33.0 40.0 50.0 ​ max 10.5 14.5 19.0 25.5 33.0 42.0 52.0 63.0 ​ ​ 18 24 30 36 46 55 70 80 ​ 22 23 28 28 31 34 37 38 ​ 10 10 11 13 13 14 14 15 Part. no. 1160.17 1160.20 1160.25 1160.32 1160.40 1160.50 1160.63 1160.75 ​​ 50 50 25 25 10 10 5 1 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass long entry thread metric Material: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: Nickel-plated brass TPE NBR According to EN 50262 version A -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS One-piece sealing insert / not overall length insulated​ ​ M6x1.0 M6x1.0 M6x1.0 M8x1.25 M8x1.25 M10x1.5 M10x1.5 M12x1.5 M12x1.5 M12x1.5 M16x1.5 M16x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 M32x1.5 M40x1.5 M40x1.5 M40x1.5 M50x1.5 M50x1.5 M50x1.5 M63x1.5 M63x1.5 M63x1.5 M75x1.5 M75x1.5 M75x1.5 min 2.0 2.5 3.0 2.5 3.5 3.0 4.0 3.5 5.0 6.5 3.5 4.5 6.0 8.0 6.0 8.0 11.0 9.5 12.5 16.0 14.0 17.0 21.0 20.0 24.0 28.5 29.0 33.0 37.0 35.0 40.0 46.0 45.0 50.0 56.0 ​ max 2.5 3.0 3.5 3.5 5.0 4.0 6.0 5.0 6.5 8.0 4.5 6.0 8.0 10.5 8.0 11.0 15.0 12.5 16.0 20.5 17.0 21.0 25.5 24.0 28.5 33.0 33.0 37.0 42.0 40.0 46.0 52.0 50.0 56.0 63.0 ​ ​ 8 8 8 11 11 13 13 15 15 15 18 18 18 18 24 24 24 30 30 30 36 36 36 46 46 46 55 55 55 70 70 70 80 80 80 ​ 12 12 12 14 14 15 15 17 17 17 20 20 20 22 21 21 23 25 27 28 28 28 28 31 31 31 34 34 34 37 37 37 38 38 38 ​ 8 8 8 10 10 10 10 10 10 10 10 10 10 10 10 10 10 11 11 11 13 13 13 13 13 13 14 14 14 14 14 14 15 15 15 ​ 1 1 1 1 1 1 1                                                         - Part. no. 1100.06.025 1100.06.030 1100.06.035 1100.08.035 1100.08.050 1100.10.040 1100.10.060 1100.12.050 1100.12.065 1100.12.080 1100.17.045 1100.17.060 1100.17.080 1100.17.105 1100.20.080 1100.20.110 1100.20.150 1100.25.125 1100.25.160 1100.25.205 1100.32.170 1100.32.210 1100.32.255 1100.40.240 1100.40.285 1100.40.330 1100.50.330 1100.50.370 1100.50.420 1100.63.400 1100.63.460 1100.63.520 1100.75.500 1100.75.560 1100.75.630 ​​ 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 25 25 25 25 25 25 10 10 10 10 10 10 5 5 5 1 1 1 1 = Metric coarse-pitch thread American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 169 Cable Glands Nickel-Plated Brass long entry thread metric Material: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: Nickel-plated brass TPE NBR According to EN 50262 version A -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS Two-piece sealing insert / not overall length insulated​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 M75x1.5 170 min 6.0 8.0 12.5 17.0 24.0 33.0 40.0 50.0 ​ max 10.5 15.0 20.5 25.5 33.0 42.0 52.0 63.0 ​ ​ 18 24 30 36 46 55 70 80 ​ 22 23 28 28 31 34 37 38 ​ 10 10 11 13 13 14 14 15 Part. no. 1100.17 1100.20 1100.25 1100.32 1100.40 1100.50 1100.63 1100.75 ​​ 50 50 25 25 10 10 5 1 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass short entry thread pg Material: Seal: O-ring: Temperature range: Protection class: Protection type addition: Nickel-plated brass TPE NBR -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS One-piece sealing insert / overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 7 7 7 9 9 9 11 11 11 13 13 13 16 16 16 21 21 21 29 29 36 36 42 42 48 48 ​ 3.5 5.0 6.5 4.5 6.0 8.0 4.0 5.5 8.5 6.0 8.0 11.0 6.0 8.0 11.0 9.5 12.5 16.0 19.0 23.0 26.0 30.5 33.0 37.0 37.0 43.0 max ​ 5.0 6.5 7.5 6.0 8.0 10.5 5.5 8.5 12.0 8.0 11.0 14.5 8.0 11.0 14.5 12.5 16.0 19.0 23.0 27.5 30.5 35.0 37.0 42.0 43.0 49.0 ​ 15 15 15 18 18 18 21 21 21 24 24 24 24 24 24 30 30 30 38 38 50 50 55 55 65 65 ​ 17 17 17 20 20 22 21 21 21 21 21 23 23 23 23 28 28 28 28 28 32 32 34 34 37 37 ​ 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 7.5 7.5 7.5 8.0 8.0 8.0 8.0 10.0 10.0 11.0 11.0 Part. no. 1060.07.050 1060.07.065 1060.07.075 1060.09.060 1060.09.080 1060.09.105 1060.11.055 1060.11.085 1060.11.120 1060.13.080 1060.13.110 1060.13.145 1060.16.080 1060.16.110 1060.16.145 1060.21.125 1060.21.160 1060.21.190 1060.29.230 1060.29.275 1060.36.305 1060.36.350 1060.42.370 1060.42.420 1060.48.430 1060.48.490 ​​ 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 25 25 25 25 25 10 10 10 10 10 10 ​ Progress MS Two-piece sealing insert / overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg min 9 11 13 16 21 29 36 42 48 6.0 5.5 8.0 8.0 12.5 19.0 26.0 33.0 37.0 ​ max 10.5 12.0 14.5 14.5 19.0 27.5 35.0 42.0 49.0 ​ ​ 18 21 24 24 30 38 50 55 65 ​ 22 21 23 23 28 28 32 34 37 ​ 6.0 6.0 6.0 6.0 7.5 8.0 8.0 10.0 11.0 Part. no. 1060.09 1060.11 1060.13 1060.16 1060.21 1060.29 1060.36 1060.42 1060.48 ​​ 50 50 50 50 25 25 10 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 171 Cable Glands Nickel-Plated Brass short entry thread pg Material: Seal: O-ring: Temperature range: Protection class: Protection type addition: Nickel-plated brass TPE NBR -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS One-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 7 7 7 9 9 9 9 11 11 11 13 13 13 16 16 16 21 21 21 29 29 29 36 36 36 42 42 42 48 48 48 ​ 3.5 5.0 6.5 3.5 4.5 6.0 8.0 4.0 5.5 8.5 6.0 8.0 11.0 6.0 8.0 11.0 9.5 12.5 16.0 16.0 19.0 23.0 21.5 26.0 30.5 29.0 33.0 37.0 32.0 37.0 43.0 max ​ 5.0 6.5 8.0 4.5 6.0 8.0 10.5 5.5 8.5 12.0 8.0 11.0 15.0 8.0 11.0 15.0 12.5 16.0 20.5 19.0 23.0 27.5 26.0 30.5 35.0 33.0 37.0 42.0 37.0 43.0 49.0 ​ 15 15 15 18 18 18 18 21 21 21 24 24 24 24 24 24 30 30 30 38 38 38 50 50 50 55 55 55 65 65 65 ​ 17 17 17 20 20 20 22 21 21 21 21 21 23 23 23 23 28 28 28 28 28 28 32 32 32 34 34 34 37 37 37 ​ 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 7.5 7.5 7.5 8.0 8.0 8.0 8.0 8.0 8.0 10.0 10.0 10.0 11.0 11.0 11.0 Part. no. 1000.07.050 1000.07.065 1000.07.080 1000.09.045 1000.09.060 1000.09.080 1000.09.105 1000.11.055 1000.11.085 1000.11.120 1000.13.080 1000.13.110 1000.13.150 1000.16.080 1000.16.110 1000.16.150 1000.21.125 1000.21.160 1000.21.205 1000.29.190 1000.29.230 1000.29.275 1000.36.260 1000.36.305 1000.36.350 1000.42.330 1000.42.370 1000.42.420 1000.48.370 1000.48.430 1000.48.490 ​​ 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 25 25 25 25 25 25 10 10 10 10 10 10 10 10 10 ​ Progress MS Two-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg 172 min 9 11 13 16 21 29 36 42 48 6.0 5.5 8.0 8.0 12.5 19.0 26.0 33.0 37.0 ​ max 10.5 12.0 15.0 15.0 20.5 27.5 35.0 42.0 49.0 ​ ​ 18 21 24 24 30 38 50 55 65 ​ 22 21 23 23 28 28 32 34 37 ​ 6.0 6.0 6.0 6.0 7.5 8.0 8.0 10.0 11.0 Part. no. 1000.09 1000.11 1000.13 1000.16 1000.21 1000.29 1000.36 1000.42 1000.48 ​​ 50 50 50 50 25 25 10 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass long entry thread pg Material: Seal: O-ring: Temperature range: Protection class: Protection type addition: Nickel-plated brass TPE NBR -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS One-piece sealing insert / overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 7 7 9 11 13 16 21 29 36 42 48 ​ 5.0 6.5 8.0 8.5 11.0 11.0 16.0 23.0 30.5 37.0 43.0 max ​ 6.5 7.5 10.5 12.0 14.5 14.5 19.0 27.5 35.0 42.0 49.0 ​ 15 15 18 21 24 24 30 38 50 55 65 ​ 17 17 22 21 23 23 28 28 32 32 37 ​ 10 10 10 10 10 10 12 12 15 15 15 Part. no. 1160.07.065 1160.07.075 1160.09.105 1160.11.120 1160.13.145 1160.16.145 1160.21.190 1160.29.275 1160.36.350 1160.42.420 1160.48.490 ​​ 50 50 50 50 50 50 25 25 10 10 10 ​ Progress MS Two-piece sealing insert / overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg min 9 11 13 16 21 29 36 42 48 6.0 5.5 8.0 8.0 12.5 19.0 26.0 33.0 37.0 ​ max 10.5 12.0 14.5 14.5 19.0 27.5 35.0 42.0 49.0 ​ ​ 18 21 24 24 30 38 50 55 65 ​ 22 21 23 23 28 28 32 34 37 ​ 10 10 10 10 12 12 15 15 15 Part. no. 1160.09 1160.11 1160.13 1160.16 1160.21 1160.29 1160.36 1160.42 1160.48 ​​ 50 50 50 50 25 25 10 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 173 Cable Glands Nickel-Plated Brass long entry thread pg Material: Seal: O-ring: Temperature range: Protection class: Protection type addition: Nickel-plated brass TPE NBR -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS One-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 7 7 7 9 9 9 9 11 11 11 13 13 13 16 16 16 21 21 21 29 29 29 36 36 36 42 42 42 48 48 48 ​ 3.5 5.0 6.5 3.5 4.5 6.0 8.0 4.0 5.5 8.5 6.0 8.0 11.0 6.0 8.0 11.0 9.5 12.5 16.0 16.0 19.0 23.0 21.5 26.0 30.5 29.0 33.0 37.0 32.0 37.0 43.0 max ​ 5.0 6.5 8.0 4.5 6.0 8.0 10.5 5.5 8.5 12.0 8.0 11.0 15.0 8.0 11.0 15.0 12.5 16.0 20.5 19.0 23.0 27.5 26.0 30.5 35.0 33.0 37.0 42.0 37.0 43.0 49.0 ​ 15 15 15 18 18 18 18 21 21 21 24 24 24 24 24 24 30 30 30 38 38 38 50 50 50 55 55 55 65 65 65 ​ 17 17 17 20 20 20 22 21 21 21 21 21 23 23 23 23 28 28 28 28 28 28 32 32 32 34 34 34 37 37 37 ​ 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 12 12 12 12 12 12 15 15 15 15 15 15 15 15 15 Part. no. 1100.07.050 1100.07.065 1100.07.080 1100.09.045 1100.09.060 1100.09.080 1100.09.105 1100.11.055 1100.11.085 1100.11.120 1100.13.080 1100.13.110 1100.13.150 1100.16.080 1100.16.110 1100.16.150 1100.21.125 1100.21.160 1100.21.205 1100.29.190 1100.29.230 1100.29.275 1100.36.260 1100.36.305 1100.36.350 1100.42.330 1100.42.370 1100.42.420 1100.48.370 1100.48.430 1100.48.490 ​​ 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 25 25 25 25 25 25 10 10 10 10 10 10 10 10 10 ​ Progress MS Two-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg 174 min 9 11 13 16 21 29 36 42 48 6.0 5.5 8.0 8.0 12.5 19.0 26.0 33.0 37.0 ​ max 10.5 12.0 15.0 15.0 20.5 27.5 35.0 42.0 49.0 ​ ​ 18 21 24 24 30 38 50 55 65 ​ 22 21 23 23 28 28 32 34 37 ​ 10 10 10 10 12 12 15 15 15 Part. no. 1100.09 1100.11 1100.13 1100.16 1100.21 1100.29 1100.36 1100.42 1100.48 ​​ 50 50 50 50 25 25 10 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass entry thread npt Material: Seal: Temperature range: Protection class: Protection type addition: Entry thread: Nickel-plated brass TPE -40°C / +100°C IP 68 (up to 10 bar) IP 69K IP 68, if the entry thread is sealed ​ Progress NPT One-piece sealing insert / not overall length insulated​ ​ NPT NPT NPT NPT NPT NPT NPT NPT NPT NPT NPT NPT NPT NPT NPT NPT NPT NPT NPT NPT NPT NPT NPT NPT NPT NPT NPT min 1/8" 1/8" 1/4" 1/4" 1/4" 3/8" 3/8" 3/8" 3/8" 1/2" 1/2" 1/2" 3/4" 3/4" 3/4" 1" 1" 1" 1 1/4" 1 1/4" 1 1/4" 1 1/2" 1 1/2" 1 1/2" 2" 2" 2" ​ 3.0 4.0 3.5 5.0 6.5 3.5 4.5 6.0 8.0 6.0 8.0 11.0 9.5 12.5 16.0 14.0 17.0 21.0 20.0 24.0 28.5 29.0 33.0 37.0 35.0 40.0 46.0 max ​ 4.0 6.0 5.0 6.5 8.0 4.5 6.0 8.0 10.5 8.0 11.0 15.0 12.5 16.0 20.5 17.0 21.0 25.5 24.0 28.5 33.0 33.0 37.0 41.0 40.0 46.0 52.0 ​ 13 13 15 15 15 18 18 18 18 24 24 24 30 30 30 36 36 36 46 46 46 55 55 55 70 70 70 ​ 15 15 17 17 17 20 20 20 22 21 21 23 28 28 28 28 28 28 31 31 31 34 34 34 37 37 37 ​ 8 8 12 12 12 12 12 12 12 15 15 15 15 15 15 20 20 20 20 20 20 22 22 22 22 22 22 Part. no. 1000.1/8NPT.040 1000.1/8NPT.060 1000.1/4NPT.050 1000.1/4NPT.065 1000.1/4NPT.080 1000.3/8NPT.045 1000.3/8NPT.060 1000.3/8NPT.080 1000.3/8NPT.105 1000.1/2NPT.080 1000.1/2NPT.110 1000.1/2NPT.150 1000.3/4NPT.125 1000.3/4NPT.160 1000.3/4NPT.205 1000.1NPT.170 1000.1NPT.210 1000.1NPT.255 1000.11/4NPT.240 1000.11/4NPT.285 1000.11/4NPT.330 1000.11/2NPT.330 1000.11/2NPT.370 1000.11/2NPT.410 1000.2NPT.400 1000.2NPT.460 1000.2NPT.520 ​​ 50 50 50 50 50 50 50 50 50 50 50 50 25 25 25 25 25 25 10 10 10 10 10 10 5 5 5 ​ Progress NPT Two-piece sealing insert / not overall length insulated​ ​ NPT NPT NPT NPT NPT NPT NPT min 3/8" 1/2" 3/4" 1" 1 1/4" 1 1/2" 2" 6.0 8.0 12.5 17.0 24.0 33.0 40.0 ​ max 10.5 15.0 20.5 25.5 33.0 41.0 52.0 ​ ​ 18 24 30 36 46 55 70 ​ 22 23 28 28 31 34 37 ​ 12 15 15 20 20 22 22 Part. no. 1000.3/8NPT 1000.1/2NPT 1000.3/4NPT 1000.1NPT 1000.11/4NPT 1000.11/2NPT 1000.2NPT ​​ 50 50 25 25 10 10 5 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 175 Cable Glands Nickel-Plated Brass gas-pipe entry thread Material: Seal: O-ring: Temperature range: Protection class: Nickel-plated brass TPE NBR -40°C / +100°C IP 68 ​ Two-piece sealing insert / not overall length insulated​ ​ G 3/8" G 1/2" G 3/4" G 1" G 11/2" G 2" G 2 1/2" G 2 1/2" G 3" G 3" min 5.5 8.0 12.5 17.0 25.0 37.0 45.0 50.0 56.0 63.0 ​ max 12.0 15.0 20.5 25.5 35.0 49.0 50.0 56.0 63.0 70.0 ​ ​ 21 24 30 36 55/50 65 80 80 80 95 ​ 21 23 28 28 32 37 38 38 38 40 ​ 6 8 10 11 12 12 18 18 18 18 ​             1 1 1 1 ​ Part. no. 1000.3/8G 1000.1/2G 1000.3/4G 1000.1G 1000.11/2G 1000.2G 1000.21/2G.500 1000.21/2G.560 1000.3G.630 1000.3G.700 ​​ 50 50 25 25 10 10 1 1 1 1 1 = One-piece sealing insert 176 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass for High Temperature Applications short entry thread metric Material: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: Nickel-plated brass FPM FPM According to EN 50262 version A -40°C / +200°C IP 68 (up to 10 bar) IP 69K ​ Progress MS HT One-piece sealing insert / not overall length insulated​ ​ M6x1.0 M6x1.0 M6x1.0 M8x1.25 M8x1.25 M10x1.5 M10x1.5 M12x1.5 M12x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 min ​ 2.0 2.5 3.0 2.5 3.5 3.0 4.0 3.5 5.0 6.5 8.0 11.0 16.0 21.0 28.5 37.0 46.0 max ​ 2.5 3.0 3.5 3.5 5.0 4.0 6.0 5.0 6.5 8.0 10.5 15.0 20.5 25.5 33.0 42.0 52.0 ​ 8 8 8 11 11 13 13 15 15 15 18 24 30 36 46 55 70 ​ 12 12 12 14 14 15 15 17 17 17 22 23 28 28 31 34 37 ​ 5 5 5 5 5 5 5 5 5 5 5 6 7 8 8 9 10 ​ 1 1 1 1 1 1 1                     - Part. no. 1000.06.91.025 1000.06.91.030 1000.06.91.035 1000.08.91.035 1000.08.91.050 1000.10.91.040 1000.10.91.060 1000.12.91.050 1000.12.91.065 1000.12.91.080 1000.17.91.105 1000.20.91.150 1000.25.91.205 1000.32.91.255 1000.40.91.330 1000.50.91.420 1000.63.91.520 ​​ 50 50 50 50 50 50 50 50 50 50 50 50 25 25 10 10 5 1 = Metric coarse-pitch thread ​ Progress MS HT Two-piece sealing insert / not overall length insulated​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 min 6.0 8.0 12.5 17.0 24.0 33.0 40.0 ​ max 10.5 15.0 20.5 25.5 33.0 42.0 52.0 ​ ​ 18 24 30 36 46 55 70 ​ 22 23 28 28 31 34 37 ​ 5 6 7 8 8 9 10 Part. no. 1000.17.92 1000.20.92 1000.25.92 1000.32.92 1000.40.92 1000.50.92 1000.63.92 ​​ 50 50 25 25 10 10 5 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 177 Cable Glands Nickel-Plated Brass for High Temperature Applications long entry thread metric Material: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: Nickel-plated brass FPM FPM According to EN 50262 version A -40°C / +200°C IP 68 (up to 10 bar) IP 69K ​ Progress MS HT One-piece sealing insert / not overall length insulated​ ​ M6x1.0 M6x1.0 M6x1.0 M8x1.25 M8x1.25 M10x1.5 M10x1.5 M12x1.5 M12x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 min ​ 2.0 2.5 3.0 2.5 3.5 3.0 4.0 3.5 5.0 6.5 8.0 11.0 16.0 21.0 28.5 37.0 46.0 max ​ 2.5 3.0 3.5 3.5 5.0 4.0 6.0 5.0 6.5 8.0 10.5 15.0 20.5 25.5 33.0 42.0 52.0 ​ 8 8 8 11 11 13 13 15 15 15 18 24 30 36 46 55 70 ​ 12 12 12 14 14 15 15 17 17 17 22 23 28 28 31 34 37 ​ 8 8 8 10 10 10 10 10 10 10 10 10 11 13 13 14 14 ​ 1 1 1 1 1 1 1                     - Part. no. 1100.06.91.025 1100.06.91.030 1100.06.91.035 1100.08.91.035 1100.08.91.050 1100.10.91.040 1100.10.91.060 1100.12.91.050 1100.12.91.065 1100.12.91.080 1100.17.91.105 1100.20.91.150 1100.25.91.205 1100.32.91.255 1100.40.91.330 1100.50.91.420 1100.63.91.520 ​​ 50 50 50 50 50 50 50 50 50 50 50 50 25 25 10 10 5 1 = Metric coarse-pitch thread ​ Progress MS HT Two-piece sealing insert / not overall length insulated​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 178 min 6.0 8.0 12.5 17.0 24.0 33.0 40.0 ​ max 10.5 15.0 20.5 25.5 33.0 42.0 52.0 ​ ​ 18 24 30 36 46 55 70 ​ 22 23 28 28 31 34 37 ​ 10 10 11 13 13 14 14 Part. no. 1100.17.92 1100.20.92 1100.25.92 1100.32.92 1100.40.92 1100.50.92 1100.63.92 ​​ 50 50 25 25 10 10 5 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass for High Temperature Applications short entry thread pg Material: Seal: O-ring: Temperature range: Protection class: Protection type addition: Nickel-plated brass FPM FPM -40°C / +200°C IP 68 (up to 10 bar) IP 69K ​ Progress MS HT One-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 7 7 7 9 11 13 16 21 29 36 42 48 ​ 3.5 5.0 6.5 8.0 8.5 11.0 11.0 16.0 23.0 30.5 37.0 43.0 max ​ 5.0 6.5 8.0 10.5 12.0 15.0 15.0 20.5 27.5 35.0 42.0 49.0 ​ 15 15 15 18 21 24 24 30 38 50 55 65 ​ 17 17 17 22 21 23 23 28 28 32 34 37 ​ 6 6 6 6 6 6 6 7 8 8 10 11 Part. no. 1000.07.91.050 1000.07.91.065 1000.07.91.080 1000.09.91.105 1000.11.91.120 1000.13.91.150 1000.16.91.150 1000.21.91.205 1000.29.91.275 1000.36.91.350 1000.42.91.420 1000.48.91.490 ​​ 50 50 50 50 50 50 50 25 25 10 10 10 ​ Progress MS HT Two-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg min 9 11 13 16 21 29 36 42 48 6.0 5.5 8.0 8.0 12.5 19.0 26.0 33.0 37.0 ​ max 10.5 12.0 15.0 15.0 20.5 27.5 35.0 42.0 49.0 ​ ​ 18 21 24 24 30 38 50 55 65 ​ 22 21 23 23 28 28 32 34 37 ​ 6 6 6 6 7 8 8 10 11 Part. no. 1000.09.92 1000.11.92 1000.13.92 1000.16.92 1000.21.92 1000.29.92 1000.36.92 1000.42.92 1000.48.92 ​​ 50 50 50 50 25 25 10 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 179 Cable Glands Nickel-Plated Brass for High Temperature Applications long entry thread pg Material: Seal: O-ring: Temperature range: Protection class: Protection type addition: Nickel-plated brass FPM FPM -40°C / +200°C IP 68 (up to 10 bar) IP 69K ​ Progress MS HT One-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 7 7 7 9 11 13 16 21 29 36 42 48 ​ 3.5 5.0 6.5 8.0 8.5 11.0 11.0 16.0 23.0 30.5 37.0 43.0 max ​ 5.0 6.5 8.0 10.5 12.0 15.0 15.0 20.5 27.5 35.0 42.0 49.0 ​ 15 15 15 18 21 24 24 30 38 50 55 65 ​ 17 17 17 22 21 23 23 28 28 32 34 37 ​ 10 10 10 10 10 10 10 12 12 15 15 15 Part. no. 1100.07.91.050 1100.07.91.065 1100.07.91.080 1100.09.91.105 1100.11.91.120 1100.13.91.150 1100.16.91.150 1100.21.91.205 1100.29.91.275 1100.36.91.350 1100.42.91.420 1100.48.91.490 ​​ 50 50 50 50 50 50 50 25 25 10 10 10 ​ Progress MS HT Two-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg 180 min 9 11 13 16 21 29 36 42 48 6.0 5.5 8.0 8.0 12.5 19.0 26.0 33.0 37.0 ​ max 10.5 12.0 15.0 15.0 20.5 27.5 35.0 42.0 49.0 ​ ​ 18 21 24 24 30 38 50 55 65 ​ 22 21 23 23 28 28 32 34 37 ​ 10 10 10 10 12 12 15 15 15 Part. no. 1100.09.92 1100.11.92 1100.13.92 1100.16.92 1100.21.92 1100.29.92 1100.36.92 1100.42.92 1100.48.92 ​​ 50 50 50 50 25 25 10 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass for Installation of Multiple Cables short entry thread metric Material: Seal: O-ring: Strain relief: Temperature range: Protection class: Nickel-plated brass TPE NBR According to EN 50262 version A -40°C / +100°C IP 68 ​ Progress MS Multi One-piece sealing insert / not overall length insulated​ ​ M16x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M20x1.5 M20x1.5 M20x1.5 M20x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M25x1.5 M25x1.5 M25x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 M32x1.5 M32x1.5 M32x1.5 min 2.0 2.5 3.5 3.5 4.5 5.5 3.5 4.5 5.2 3.5 4.5 5.0 6.7 7.7 5.5 6.8 5.5 4.8 9.0 7.0 8.5 7.0 5.8 ​ max 3.0 4.0 5.0 5.0 6.0 7.5 5.0 6.0 6.5 5.0 6.0 7.0 9.0 10.0 7.0 9.0 7.0 6.0 11.5 9.0 10.5 9.0 7.0 ​ 2 2 2 2 2 2 3 3 3 4 4 2 2 2 3 3 4 6 2 3 3 4 6 ​ ​ ​ 18 22 18 22 18 22 24 23 24 23 24 23 24 23 24 23 24 23 24 23 24 23 30 28 30 28 30 28 30 28 30 28 30 28 30 28 36 28 36 28 36 28 36 28 36 28 ​ 5 5 5 6 6 6 6 6 6 6 6 7 7 7 7 7 7 7 8 8 8 8 8 Part. no. 1310.17.2.030 1310.17.2.040 1310.17.2.050 1310.20.2.050 1310.20.2.060 1310.20.2.075 1310.20.3.050 1310.20.3.060 1310.20.3.065 1310.20.4.050 1310.20.4.060 1310.25.2.070 1310.25.2.090 1310.25.2.100 1310.25.3.070 1310.25.3.090 1310.25.4.070 1310.25.6.060 1310.32.2.115 1310.32.3.090 1310.32.3.105 1310.32.4.090 1310.32.6.070 ​​ 50 50 50 50 50 50 50 50 50 50 50 25 25 25 25 25 25 25 25 25 25 25 25 Further versions and larger entry threads are available upon request. American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 181 Cable Glands Nickel-Plated Brass for Installation of Multiple Cables long entry thread metric Material: Seal: O-ring: Strain relief: Temperature range: Protection class: Nickel-plated brass TPE NBR According to EN 50262 version A -40°C / +100°C IP 68 ​ Progress MS Multi One-piece sealing insert / not overall length insulated​ ​ M16x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M20x1.5 M20x1.5 M20x1.5 M20x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M25x1.5 M25x1.5 M25x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 M32x1.5 M32x1.5 M32x1.5 min 2.0 2.5 3.5 3.5 4.5 5.5 3.5 4.5 5.2 3.5 4.5 5.0 6.7 7.7 5.5 6.8 5.5 4.8 9.0 7.0 8.5 7.0 5.8 ​ max 3.0 4.0 5.0 5.0 6.0 7.5 5.0 6.0 6.5 5.0 6.0 7.0 9.0 10.0 7.0 9.0 7.0 6.0 11.5 9.0 10.5 9.0 7.0 ​ 2 2 2 2 2 2 3 3 3 4 4 2 2 2 3 3 4 6 2 3 3 4 6 ​ ​ ​ 18 22 18 22 18 22 24 23 24 23 24 23 24 23 24 23 24 23 24 23 24 23 30 28 30 28 30 28 30 28 30 28 30 28 30 28 36 28 36 28 36 28 36 28 36 28 ​ 10 10 10 10 10 10 10 10 10 10 10 11 11 11 11 11 11 11 13 13 13 13 13 Part. no. 1311.17.2.030 1311.17.2.040 1311.17.2.050 1311.20.2.050 1311.20.2.060 1311.20.2.075 1311.20.3.050 1311.20.3.060 1311.20.3.065 1311.20.4.050 1311.20.4.060 1311.25.2.070 1311.25.2.090 1311.25.2.100 1311.25.3.070 1311.25.3.090 1311.25.4.070 1311.25.6.060 1311.32.2.115 1311.32.3.090 1311.32.3.105 1311.32.4.090 1311.32.6.070 ​​ 50 50 50 50 50 50 50 50 50 50 50 25 25 25 25 25 25 25 25 25 25 25 25 Further versions and larger entry threads are available upon request. 182 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass for Installation of Multiple Cables short entry thread pg Material: Seal: O-ring: Temperature range: Protection class: Nickel-plated brass TPE NBR -40°C / +100°C IP 68 ​ Progress MS Multi One-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 9 9 9 11 11 11 11 13 13 13 13 13 13 13 13 16 16 16 16 16 16 16 16 16 16 21 21 21 21 21 21 21 21 21 21 21 29 2.0 2.5 3.5 3.5 4.5 5.5 3.5 3.5 4.5 5.5 3.5 4.5 5.2 3.5 4.5 3.5 4.5 5.5 6.7 3.5 4.5 5.0 3.5 4.5 5.5 5.0 6.7 7.7 9.0 5.5 6.8 8.5 5.5 7.0 4.8 5.8 7.5 ​ max 3.0 4.0 5.0 5.0 6.0 7.5 5.0 5.0 6.0 7.5 5.0 6.0 6.5 5.0 6.0 5.0 6.0 7.5 9.0 5.0 6.0 7.0 5.0 6.0 7.0 7.0 9.0 10.0 11.5 7.0 9.0 10.5 7.0 9.0 6.0 7.0 9.0 ​ 2 2 2 2 2 2 3 2 2 2 3 3 3 4 4 2 2 2 2 3 3 3 4 4 4 2 2 2 2 3 3 3 4 4 6 6 3 ​ ​ ​ 18 22 18 22 18 22 21 21 21 21 24 23 21 21 24 23 24 23 24 23 24 23 24 23 24 23 24 23 24 23 24 23 24 23 24 23 30 28 24 23 24 23 30 28 24 23 24 23 30 28 30 28 30 28 30 28 36 28 30 28 30 28 36 28 30 28 36 28 30 28 36 28 38 28 ​ 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 8.0 Part. no. 1310.09.2.030 1310.09.2.040 1310.09.2.050 1310.11.2.050 1310.11.2.060 1310.11.2.075 1310.11.3.050 1310.13.2.050 1310.13.2.060 1310.13.2.075 1310.13.3.050 1310.13.3.060 1310.13.3.065 1310.13.4.050 1310.13.4.060 1310.16.2.050 1310.16.2.060 1310.16.2.075 1310.16.2.090 1310.16.3.050 1310.16.3.060 1310.16.3.070 1310.16.4.050 1310.16.4.060 1310.16.4.070 1310.21.2.070 1310.21.2.090 1310.21.2.100 1310.21.2.115 1310.21.3.070 1310.21.3.090 1310.21.3.105 1310.21.4.070 1310.21.4.090 1310.21.6.060 1310.21.6.070 1310.29.3.090 ​​ 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 25 50 50 25 50 50 25 25 25 25 25 25 25 25 25 25 25 25 25 Further versions and larger entry threads are available upon request. American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 183 Cable Glands Nickel-Plated Brass for Installation of Multiple Cables long entry thread pg Material: Seal: O-ring: Temperature range: Protection class: Nickel-plated brass TPE NBR -40°C / +100°C IP 68 ​ Progress MS Multi One-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 9 9 9 11 11 11 11 13 13 13 13 13 13 13 13 16 16 16 16 16 16 16 16 16 16 21 21 21 21 21 21 21 21 21 21 21 29 2.0 2.5 3.5 3.5 4.5 5.5 3.5 3.5 4.5 5.5 3.5 4.5 5.2 3.5 4.5 3.5 4.5 5.5 6.7 3.5 4.5 5.0 3.5 4.5 5.5 5.0 6.7 7.7 9.0 5.5 6.8 8.5 5.5 7.0 4.8 5.8 7.5 ​ max 3.0 4.0 5.0 5.0 6.0 7.5 5.0 5.0 6.0 7.5 5.0 6.0 6.5 5.0 6.0 5.0 6.0 7.5 9.0 5.0 6.0 7.0 5.0 6.0 7.0 7.0 9.0 10.0 11.5 7.0 9.0 10.5 7.0 9.0 6.0 7.0 9.0 ​ 2 2 2 2 2 2 3 2 2 2 3 3 3 4 4 2 2 2 2 3 3 3 4 4 4 2 2 2 2 3 3 3 4 4 6 6 3 ​ ​ ​ 18 22 18 22 18 22 21 21 21 21 24 23 21 21 24 23 24 23 24 23 24 23 24 23 24 23 24 23 24 23 24 23 24 23 24 23 30 28 24 23 24 23 30 28 24 23 24 23 30 28 30 28 30 28 30 28 36 28 30 28 30 28 36 28 30 28 36 28 30 28 36 28 38 28 ​ 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 12 12 12 12 12 12 12 12 12 12 12 12 Part. no. 1311.09.2.030 1311.09.2.040 1311.09.2.050 1311.11.2.050 1311.11.2.060 1311.11.2.075 1311.11.3.050 1311.13.2.050 1311.13.2.060 1311.13.2.075 1311.13.3.050 1311.13.3.060 1311.13.3.065 1311.13.4.050 1311.13.4.060 1311.16.2.050 1311.16.2.060 1311.16.2.075 1311.16.2.090 1311.16.3.050 1311.16.3.060 1311.16.3.070 1311.16.4.050 1311.16.4.060 1311.16.4.070 1311.21.2.070 1311.21.2.090 1311.21.2.100 1311.21.2.115 1311.21.3.070 1311.21.3.090 1311.21.3.105 1311.21.4.070 1311.21.4.090 1311.21.6.060 1311.21.6.070 1311.29.3.090 ​​ 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 25 50 50 25 50 50 25 25 25 25 25 25 25 25 25 25 25 25 25 Further versions and larger entry threads are available upon request. 184 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass with Sealing Insert without Drilled Hole short entry thread metric Material: Seal: O-ring: Temperature range: Protection class: Protection type addition: Nickel-plated brass NBR, without drilled hole NBR -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS NBR One-piece solid sealing insert / not overall length insulated​ ​ M6x1.0 M8x1.25 M10x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 ​ max 3.5 5.0 6.0 8.0 10.5 15.0 20.5 25.5 33.0 42.0 52.0 ​ 8 11 13 15 18 24 30 36 46 55 70 ​ 12 14 15 17 22 23 28 28 31 34 37 ​ 5 5 5 5 5 6 7 8 8 9 10 ​ 1 1 1                 - Part. no. 1000.06.30 1000.08.30 1000.10.30 1000.12.30 1000.17.30 1000.20.30 1000.25.30 1000.32.30 1000.40.30 1000.50.30 1000.63.30 ​​ 50 50 50 50 50 50 25 25 10 10 5 1 = Metric coarse-pitch thread Technical note When frozen to at least -25°C, the solid sealing inserts are easy to drill. short entry thread pg ​ Progress MS NBR One-piece solid sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg max 7 9 11 11 13 16 16 21 21 29 29 36 36 42 48 8.0 10.5 12.0 15.0 15.0 15.0 18.5 20.5 23.0 27.5 33.0 35.0 42.0 42.0 49.0 ​ ​ 15 18 21 24 24 24 30 30 36 38 46 50 55 55 65 ​ 17 22 21 23 23 23 28 28 28 28 31 32 34 34 37 ​ 6.0 6.0 6.0 6.0 6.0 6.0 6.0 7.5 7.5 8.0 8.0 8.0 8.0 10.0 11.0 Part. no. 1000.07.30 1000.09.30 1000.11.30 1000.11.20.30 1000.13.30 1000.16.30 1000.16.25.30 1000.21.30 1000.21.32.30 1000.29.30 1000.29.40.30 1000.36.30 1000.36.50.30 1000.42.30 1000.48.30 ​​ 50 50 50 50 50 50 25 25 25 25 25 10 10 10 10 Technical note When frozen to at least -25°C, the solid sealing inserts are easy to drill. American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 185 Cable Glands Nickel-Plated Brass with Sealing Insert without Drilled Hole short entry thread metric Material: Seal: O-ring: Temperature range: Protection class: Protection type addition: Nickel-plated brass FPM, without drilled hole FPM -40°C / +200°C IP 68 (up to 10 bar) IP 69K ​ Progress MS FPM For high temperature applications / One-piece solid sealing insert / not overall length insulated ​ M6x1.0 M8x1.25 M10x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 ​ max 3.5 5.0 6.0 8.0 10.5 15.0 20.5 25.5 33.0 42.0 52.0 ​ 8 11 13 15 18 24 30 36 46 55 70 ​ 12 14 15 17 22 23 28 28 31 34 37 ​ 5 5 5 5 5 6 7 8 8 9 10 ​ 1 1 1                 - Part. no. 1000.06.30.91 1000.08.30.91 1000.10.30.91 1000.12.30.91 1000.17.30.91 1000.20.30.91 1000.25.30.91 1000.32.30.91 1000.40.30.91 1000.50.30.91 1000.63.30.91 ​​ 50 50 50 50 50 50 25 25 10 10 5 1 = Metric coarse-pitch thread Technical note When frozen to at least -25°C, the solid sealing inserts are easy to drill. short entry thread pg Progress MS FPM ​ For high temperature applications / One-piece solid sealing insert / not overall length insulated ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg max 7 9 11 11 13 16 16 21 21 29 29 36 36 42 48 8.0 10.5 12.0 15.0 15.0 15.0 18.5 20.5 23.0 27.5 33.0 35.0 42.0 42.0 49.0 ​ ​ 15 18 21 24 24 24 30 30 36 38 46 50 55 55 65 ​ 17 22 21 23 23 23 28 28 28 28 31 32 34 34 37 ​ 6.0 6.0 6.0 6.0 6.0 6.0 6.0 7.5 7.5 8.0 8.0 8.0 8.0 10.0 11.0 Part. no. 1000.07.30.91 1000.09.30.91 1000.11.30.91 1000.11.20.30.91 1000.13.30.91 1000.16.30.91 1000.16.25.30.91 1000.21.30.91 1000.21.32.30.91 1000.29.30.91 1000.29.40.30.91 1000.36.30.91 1000.36.50.30.91 1000.42.30.91 1000.48.30.91 ​​ 50 50 50 50 50 50 25 25 25 25 25 10 10 10 10 Technical note When frozen to at least -25°C, the solid sealing inserts are easy to drill. 186 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass for Flat Cables short entry thread metric Material: Seal: O-ring: Strain relief: Temperature range: Protection class: Nickel-plated brass TPE NBR According to EN 50262 version A -40°C / +100°C IP 68 ​ Progress MS FK One-piece sealing insert / not overall length insulated​ ​ M16x1.5 M20x1.5 M20x1.5 M25x1.5 M32x1.5 M32x1.5 M40x1.5 M40x1.5 M40x1.5 M40x1.5 M40x1.5 M40x1.5 M50x1.5 M50x1.5 M50x1.5 M50x1.5 M50x1.5 M63x1.5 M63x1.5 ​ 7.3x2.5 10.5x2.5 12.5x2.5 16.0x4.0 19.0x3.0 19.0x5.0 23.0x4.0 23.5x6.0 25.0x3.0 27.0x7.0 29.0x6.0 30.0x3.5 31.0x8.5 34.0x4.0 36.5x2.5 36.5x10.0 38.5x10.5 42.0x10.0 42.5x2.0 ​ 9.0x4.2 13.0x5.0 15.0x5.0 19.0x7.0 22.0x6.0 22.0x8.0 26.0x7.0 26.5x9.0 28.0x6.0 30.0x10.0 32.0x9.0 33.0x6.5 34.0x11.5 37.0x7.0 40.0x6.0 40.0x13.5 42.0x14.0 46.0x14.0 46.5x6.0 ​ 18 24 24 30 36 36 46 46 46 46 46 46 55 55 55 55 55 70 70 ​ 22 23 23 28 28 28 31 31 31 31 31 31 34 34 34 34 34 37 37 ​ 5 6 6 7 8 8 8 8 8 8 8 8 9 9 9 9 9 10 10 Part. no. 1300.17.090.042 1300.20.130.050 1300.20.150.050 1300.25.190.070 1300.32.220.060 1300.32.220.080 1300.40.260.070 1300.40.265.090 1300.40.280.060 1300.40.300.100 1300.40.320.090 1300.40.330.065 1300.50.340.115 1300.50.370.070 1300.50.400.060 1300.50.400.135 1300.50.420.140 1300.63.460.140 1300.63.465.060 ​​ 50 50 50 25 25 25 10 10 10 10 10 10 10 10 10 10 10 5 5 long entry thread pg ​ Progress MS FK One-piece sealing insert / not overall length insulated​ ​ M16x1.5 M20x1.5 M20x1.5 M25x1.5 M32x1.5 M32x1.5 M40x1.5 M40x1.5 M40x1.5 M40x1.5 M40x1.5 M40x1.5 M50x1.5 M50x1.5 M50x1.5 M50x1.5 M50x1.5 M63x1.5 M63x1.5 ​ 7.3x2.5 10.5x2.5 12.5x2.5 16.0x4.0 19.0x3.0 19.0x5.0 23.0x4.0 23.5x6.0 25.0x3.0 27.0x7.0 29.0x6.0 30.0x3.5 31.0x8.5 34.0x4.0 36.5x2.5 36.5x10.0 38.5x10.5 42.0x10.0 42.5x2.0 ​ 9.0x4.2 13.0x5.0 15.0x5.0 19.0x7.0 22.0x6.0 22.0x8.0 26.0x7.0 26.5x9.0 28.0x6.0 30.0x10.0 32.0x9.0 33.0x6.5 34.0x11.5 37.0x7.0 40.0x6.0 40.0x13.5 42.0x14.0 46.0x14.0 46.5x6.0 ​ 18 24 24 30 36 36 46 46 46 46 46 46 55 55 55 55 55 70 70 ​ 22 23 23 28 28 28 31 31 31 31 31 31 34 34 34 34 34 37 37 ​ 10 10 10 11 13 13 13 13 13 13 13 13 14 14 14 14 14 14 14 Part. no. 1301.17.090.042 1301.20.130.050 1301.20.150.050 1301.25.190.070 1301.32.220.060 1301.32.220.080 1301.40.260.070 1301.40.265.090 1301.40.280.060 1301.40.300.100 1301.40.320.090 1301.40.330.065 1301.50.340.115 1301.50.370.070 1301.50.400.060 1301.50.400.135 1301.50.420.140 1301.63.460.140 1301.63.465.060 ​​ 50 50 50 25 25 25 10 10 10 10 10 10 10 10 10 10 10 5 5 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 187 Cable Glands Nickel-Plated Brass for Flat Cables short entry thread pg Material: Seal: O-ring: Temperature range: Protection class: Nickel-plated brass TPE NBR -40°C / +100°C IP 68 ​ Progress MS FK One-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg 188 9 13 13 16 16 21 21 21 29 29 29 29 29 29 42 42 42 42 42 48 48 ​ 7.3x2.5 10.5x2.5 12.5x2.5 10.5x2.5 12.5x2.5 16.0x4.0 19.0x3.0 19.0x5.0 23.0x4.0 23.5x6.0 25.0x3.0 27.0x7.0 29.0x6.0 30.0x3.5 31.0x8.5 34.0x4.0 36.5x2.5 36.5x10.0 38.5x10.5 42.0x10.0 42.5x2.0 ​ 9.0x4.2 13.0x5.0 15.0x5.0 13.0x5.0 15.0x5.0 19.0x7.0 22.0x6.0 22.0x8.0 26.0x7.0 26.5x9.0 28.0x6.0 30.0x10.0 32.0x9.0 33.0x6.5 34.0x11.5 37.0x7.0 40.0x6.0 40.0x13.5 42.0x14.0 46.0x14.0 46.5x6.0 ​ 18 24 24 24 24 30 36 36 46 46 46 46 46 46 55 55 55 55 55 65 65 ​ 22 23 23 23 23 28 28 28 31 31 31 31 31 31 34 34 34 34 34 37 37 ​ 6.0 6.0 6.0 6.0 6.0 7.5 7.5 7.5 8.0 8.0 8.0 8.0 8.0 8.0 10.0 10.0 10.0 10.0 10.0 11.0 11.0 Part. no. 1300.09.090.042 1300.13.130.050 1300.13.150.050 1300.16.130.050 1300.16.150.050 1300.21.190.070 1300.21.220.060 1300.21.220.080 1300.29.260.070 1300.29.265.090 1300.29.280.060 1300.29.300.100 1300.29.320.090 1300.29.330.065 1300.42.340.115 1300.42.370.070 1300.42.400.060 1300.42.400.135 1300.42.420.140 1300.48.460.140 1300.48.465.060 ​​ 50 50 50 50 50 25 25 25 25 25 25 25 25 25 10 10 10 10 10 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass for Flat Cables long entry thread pg Material: Seal: O-ring: Temperature range: Protection class: Nickel-plated brass TPE NBR -40°C / +100°C IP 68 ​ Progress MS FK One-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg 9 13 13 16 16 21 21 21 29 29 29 29 29 29 42 42 42 42 42 48 48 ​ 7.3x2.5 10.5x2.5 12.5x2.5 10.5x2.5 12.5x2.5 16.0x4.0 19.0x3.0 19.0x5.0 23.0x4.0 23.5x6.0 25.0x3.0 27.0x7.0 29.0x6.0 30.0x3.5 31.0x8.5 34.0x4.0 36.5x2.5 36.5x10.0 38.5x10.5 42.0x10.0 42.5x2.0 ​ 9.0x4.2 13.0x5.0 15.0x5.0 13.0x5.0 15.0x5.0 19.0x7.0 22.0x6.0 22.0x8.0 26.0x7.0 26.5x9.0 28.0x6.0 30.0x10.0 32.0x9.0 33.0x6.5 34.0x11.5 37.0x7.0 40.0x6.0 40.0x13.5 42.0x14.0 46.0x14.0 46.5x6.0 ​ 18 24 24 24 24 30 36 36 46 46 46 46 46 46 55 55 55 55 55 65 65 ​ 22 23 23 23 23 28 28 28 31 31 31 31 31 31 34 34 34 34 34 37 37 ​ 10 10 10 10 10 12 12 12 12 12 12 12 12 12 15 15 15 15 15 15 15 Part. no. 1301.09.090.042 1301.13.130.050 1301.13.150.050 1301.16.130.050 1301.16.150.050 1301.21.190.070 1301.21.220.060 1301.21.220.080 1301.29.260.070 1301.29.265.090 1301.29.280.060 1301.29.300.100 1301.29.320.090 1301.29.330.065 1301.42.340.115 1301.42.370.070 1301.42.400.060 1301.42.400.135 1301.42.420.140 1301.48.460.140 1301.48.465.060 ​​ 50 50 50 50 50 25 25 25 25 25 25 25 25 25 10 10 10 10 10 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 189 Cable Glands Nickel-Plated Brass with Special Entry Thread extra-long entry thread metric Material: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: Nickel-plated brass TPE NBR According to EN 50262 version A -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS L Entry thread metric, 50 mm long / Two-piece sealing insert / not overall length insulated ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 ​ min 6.0 8.0 12.5 17.0 24.0 ​ max 10.5 15.0 20.5 25.5 33.0 ​ 24/18 30/24 36/30 46/36 55/46 ​ 22 23 28 28 31 ​ 50 50 50 50 50 Part. no. 1100.17.50 1100.20.50 1100.25.50 1100.32.50 1100.40.50 ​​ 10 10 10 10 10 L1 = L - 10mm Further dimensions upon request specially long entry thread pg Material: Seal: O-ring: Temperature range: Protection class: Protection type addition: Nickel-plated brass TPE NBR -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS L Entry thread Pg, 50 mm long / Two-piece sealing insert / not overall length insulated ​ Pg Pg Pg Pg Pg min 11 13 16 21 29 5.5 8.0 8.0 12.5 19.0 ​ max 12.0 15.0 15.0 20.5 27.5 ​ ​ 27/21 30/24 30/24 38/30 46/38 ​ 21 23 23 28 28 ​ 50 50 50 50 50 Part. no. 1100.11.50 1100.13.50 1100.16.50 1100.21.50 1100.29.50 ​​ 10 10 10 10 10 L1 = L - 10mm Further dimensions upon request 190 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass with Special Entry Thread inner thread metric Material: Seal: Strain relief: Temperature range: Protection class: Protection type addition: Nickel-plated brass TPE According to EN 50262 version A -40°C / +100°C IP 68, if the entry thread is sealed IP 69K ​ Progress MS IG Internal thread metric / Two-piece sealing insert / not overall length insulated ​ M16x1.5 M20x1.5 M25x1.5 ​ min 6.0 8.0 12.5 ​ max 10.5 15.0 20.5 ​ 18 24 30 ​ 28 31 40 ​ 6 6 10 Part. no. 1400.17 1400.20 1400.25 ​​ 25 25 25 inner thread pg Material: Seal: Temperature range: Protection class: Protection type addition: Nickel-plated brass TPE -40°C / +100°C IP 68, if the entry thread is sealed IP 69K ​ Progress MS IG Internal thread Pg / Two-piece sealing insert / not overall length insulated ​ Pg 11 Pg 16 Pg 21 min 5.5 8.0 12.5 ​ max 12.0 15.0 20.5 ​ ​ 21 24 30 ​ 28 31 40 ​ 6 6 10 Part. no. 1400.11 1400.16 1400.21 ​​ 25 25 25 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 191 Cable Glands Nickel-Plated Brass with antikink nozzle in EPDM short entry thread metric Material: Seal: O-ring: antikink nozzle: Strain relief: Temperature range: Protection class: Protection type addition: Nickel-plated brass NBR NBR EPDM According to EN 50262 version A -40°C / +100°C IP 68 IP 69K ​ ​ Short entry thread metric / One-piece sealing insert / not overall length insulated ​ M8x1.25 M10x1.5 M12x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 ​ min 3.8 4.0 4.0 6.0 9.0 10.5 13.0 ​ max 4.8 6.0 6.0 8.8 11.0 13.0 16.5 ​ 11 16 16 20 24 24 32 ​ 12 20 20 24 28 28 33 ​ 25 35 35 45 65 75 92 ​ 6 6 6 6 6 6 7 ​ 1 1           - Part. no. 1008.52 1010.52 1012.52 1017.52 1020.51 1020.52 1025.52 ​​ 50 50 50 50 25 25 10 1 = Metric coarse-pitch thread short entry thread pg Material: Seal: O-ring: antikink nozzle: Temperature range: Protection class: Protection type addition: Nickel-plated brass NBR NBR EPDM -40°C / +100°C IP 68 IP 69K ​ ​ Short entry thread Pg / One-piece sealing insert / not overall length insulated ​ Pg Pg Pg Pg Pg Pg Pg Pg 192 min 7 9 11 13 13 16 16 21 4.0 6.0 6.0 9.0 10.5 9.0 10.5 13.0 ​ max 6.0 8.8 8.8 11.0 13.0 11.0 13.0 16.5 ​ ​ 16 20 20 24 24 24 24 32 ​ 20 24 24 28 28 28 28 33 ​ 35 45 45 65 75 65 75 92 ​ 6 6 6 6 6 6 6 7.5 Part. no. 1007.52 1009.52 1011.52 1013.51 1013.52 1016.51 1016.52 1021.51 ​​ 50 50 50 25 25 25 25 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass with Antikink Spring short entry thread metric Material: Antikink spring: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: Nickel-plated brass Stainless steel A2 TPE NBR According to EN 50262 version A -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS FKN One-piece sealing insert / overall length insulated​ ​ M8x1.25 M8x1.25 M10x1.5 M10x1.5 M12x1.5 M12x1.5 M12x1.5 M16x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 min ​ 2.5 3.5 3.0 4.0 3.5 5.0 6.5 4.5 6.0 8.0 6.0 8.0 11.0 9.5 12.5 16.0 17.0 21.0 max ​ 3.0 4.0 4.0 6.0 5.0 6.5 7.5 6.0 8.0 10.5 8.0 11.0 14.5 12.5 16.0 19.0 21.0 24.5 ​ 11 11 13 13 15 15 15 18 18 18 24 24 24 30 30 30 36 36 ​ 49 49 52 52 57 57 57 66 66 66 86 86 86 99 99 99 109 109 ​ 5 5 5 5 5 5 5 5 5 5 6 6 6 7 7 7 8 8 ​ 1 1 1 1                             - Part. no. 1060.08.52.030 1060.08.52.040 1060.10.52.040 1060.10.52.060 1060.12.52.050 1060.12.52.065 1060.12.52.075 1060.17.52.060 1060.17.52.080 1060.17.52.105 1060.20.52.080 1060.20.52.110 1060.20.52.145 1060.25.52.125 1060.25.52.160 1060.25.52.190 1060.32.52.210 1060.32.52.245 ​​ 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 1 = Metric coarse-pitch thread The following cable glands with anti-kink spring are available upon request: - Short entry thread with short one-piece or two-piece sealing insert. - Long entry thread with short or full-length insulating one-piece or two-piece sealing insert. ​ Progress MS FKN Two-piece sealing insert / overall length insulated​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 min 6.0 8.0 12.5 17.0 ​ max 10.5 14.5 19.0 24.5 ​ ​ 18 24 30 36 ​ 66 86 99 109 ​ 5 6 7 8 Part. no. 1060.17.52 1060.20.52 1060.25.52 1060.32.52 ​​ 10 10 10 5 The following cable glands with anti-kink spring are available upon request: - Short entry thread with short one-piece or two-piece sealing insert. - Long entry thread with short or full-length insulating one-piece or two-piece sealing insert. American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 193 Cable Glands Nickel-Plated Brass with Antikink Spring short entry thread pg Material: Antikink spring: Seal: O-ring: Temperature range: Protection class: Protection type addition: Nickel-plated brass Stainless steel A2 TPE NBR -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS FKN One-piece sealing insert / overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 7 7 7 9 9 9 11 11 11 13 13 13 16 16 16 21 21 21 ​ 3.5 5.0 6.5 4.5 6.0 8.0 4.5 6.0 8.0 6.0 8.0 11.0 6.0 8.0 11.0 9.5 12.5 16.0 max ​ 5.0 6.5 7.5 6.0 8.0 10.5 6.0 8.0 10.5 8.0 11.0 14.5 8.0 11.0 14.5 12.5 16.0 19.0 ​ 15 15 15 18 18 18 18/21 18/21 18/21 24 24 24 24 24 24 30 30 30 ​ 57 57 57 66 66 66 66 66 66 86 86 86 86 86 86 99 99 99 ​ 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 7.5 7.5 7.5 Part. no. 1060.07.52.050 1060.07.52.065 1060.07.52.075 1060.09.52.060 1060.09.52.080 1060.09.52.105 1060.11.52.060 1060.11.52.080 1060.11.52.105 1060.13.52.080 1060.13.52.110 1060.13.52.145 1060.16.52.080 1060.16.52.110 1060.16.52.145 1060.21.52.125 1060.21.52.160 1060.21.52.190 ​​ 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 The following cable glands with anti-kink spring are available upon request: - Short entry thread with short one-piece or two-piece sealing insert. - Long entry thread with short or full-length insulating one-piece or two-piece sealing insert. ​ Progress MS FKN Two-piece sealing insert / overall length insulated​ ​ Pg Pg Pg Pg Pg min 9 11 13 16 21 6.0 6.0 8.0 8.0 12.5 ​ max 10.5 10.5 14.5 14.5 19.0 ​ ​ 18 18/21 24 24 30 ​ 66 66 86 86 99 ​ 6 6 6 6 7.5 Part. no. 1060.09.52 1060.11.52 1060.13.52 1060.16.52 1060.21.52 ​​ 10 10 10 10 5 The following cable glands with anti-kink spring are available upon request: - Short entry thread with short one-piece or two-piece sealing insert. - Long entry thread with short or full-length insulating one-piece or two-piece sealing insert. 194 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass with Clamps short entry thread metric Material: Screws: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: Nickel-plated brass Stainless steel A2 TPE NBR According to EN 50262 version B -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS KB One-piece sealing insert / not overall length insulated​ ​ M10x1.5 M10x1.5 M12x1.5 M12x1.5 min 3.0 4.0 5.0 6.5 ​ max ​ ​ 4.0 13/16 6.0 13/16 6.5 15/16 8.0 15/16 ​ 24 24 26 26 ​ 5 5 5 5 Part. no. ​ 1800.10.03.040 1800.10.03.060 1800.12.03.065 1800.12.03.080 1 1     - ​​ 50 50 50 50 1 = Metric coarse-pitch thread ​ Progress MS KB Two-piece sealing insert / not overall length insulated​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 M75x1.5 ​ min 6.0 8.0 12.5 17.0 24.0 33.0 40.0 50.0 max ​ 10.5 15.0 20.5 25.5 33.0 42.0 52.0 63.0 ​ 18/19 24 30 36 46 55 70 80 ​ 30 31 35 40 44 49 55 56 Part. no. ​ 1800.17.03.105 1800.20.03.150 1800.25.03.205 1800.32.03.255 1800.40.03.330 1800.50.03.410 1800.63.03.520 1800.75.03.630 5 6 7 8 8 9 10 11 ​​ 50 50 25 25 10 10 5 1 long entry thread metric ​ Progress MS KB One-piece sealing insert / not overall length insulated​ ​ M10x1.5 M10x1.5 M12x1.5 M12x1.5 min 3.0 4.0 5.0 6.5 ​ max ​ ​ 4.0 13/16 6.0 13/16 6.5 15/16 8.0 15/16 ​ 24 24 26 26 ​ 10 10 10 10 ​ 1 1     - Part. no. 1800.10.13.040 1800.10.13.060 1800.12.13.065 1800.12.13.080 ​​ 50 50 50 50 1 = Metric coarse-pitch thread ​ Progress MS KB Two-piece sealing insert / not overall length insulated​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 M75x1.5 min 6.0 8.0 12.5 17.0 24.0 33.0 40.0 50.0 ​ max 10.5 15.0 20.5 25.5 33.0 42.0 52.0 63.0 ​ ​ 18/19 24 30 36 46 55 70 80 ​ 30 31 35 40 44 49 55 56 ​ 10 10 11 13 13 14 14 15 Part. no. 1800.17.13.105 1800.20.13.150 1800.25.13.205 1800.32.13.255 1800.40.13.330 1800.50.13.410 1800.63.13.520 1800.75.13.630 ​​ 50 50 25 25 10 10 5 1 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 195 Cable Glands Nickel-Plated Brass with Clamps short entry thread pg Material: Screws: Seal: O-ring: Temperature range: Protection class: Protection type addition: Nickel-plated brass Stainless steel A2 TPE NBR -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS KB One-piece sealing insert / not overall length insulated​ ​ Pg 7 Pg 7 ​ max ​ ​ 5.0 6.5 15/16 6.5 8.0 15/16 min ​ 26 26 Part. no. ​ 1800.07.03.065 1800.07.03.080 6 6 ​​ 50 50 ​ Progress MS KB Two-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg min 9 11 13 16 21 29 36 42 48 ​ 6.0 5.5 8.0 8.0 12.5 19.0 26.0 33.0 37.0 max ​ 10.5 12.0 15.0 15.0 20.5 27.5 35.0 42.0 49.0 ​ 18/19 21 24 24 30 38 50 55 65 ​ 30 31 31 31 35 40 47 49 51 ​ 6 6 6 6 7 8 8 10 11 Part. no. 1800.09.03.105 1800.11.03.120 1800.13.03.150 1800.16.03.150 1800.21.03.205 1800.29.03.275 1800.36.03.350 1800.42.03.410 1800.48.03.490 ​​ 50 50 50 50 25 25 10 10 5 long entry thread pg ​ Progress MS KB One-piece sealing insert / not overall length insulated​ ​ Pg 7 Pg 7 ​ max ​ ​ 5.0 6.5 15/16 6.5 8.0 15/16 min ​ 26 26 Part. no. ​ 10 10 1800.07.13.065 1800.07.13.080 ​​ 50 50 ​ Progress MS KB Two-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg 196 min 9 11 13 16 21 29 36 42 48 6.0 5.5 8.0 8.0 12.5 19.0 26.0 33.0 37.0 ​ max 10.5 12.0 15.0 15.0 20.5 27.5 35.0 42.0 49.0 ​ ​ 18/19 21 24 24 30 38 50 55 65 ​ 30 31 31 31 35 40 47 49 51 ​ 10 10 10 10 12 12 15 15 15 Part. no. 1800.09.13.105 1800.11.13.120 1800.13.13.150 1800.16.13.150 1800.21.13.205 1800.29.13.275 1800.36.13.350 1800.42.13.410 1800.48.13.490 ​​ 50 50 50 50 25 25 10 10 5 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass with Clamps entry thread metric Material: Screws: Strain relief: Temperature range: Protection class: Nickel-plated brass Stainless steel A2 According to EN 50262 version B -50°C / +300°C IP 20 ​ Progress MS KBST Mechanical strain relief B​​ ​ M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 ​ min 5.0 6.0 8.0 12.5 17.0 24.0 ​ max 8.0 10.5 15.0 20.5 25.5 33.0 ​ 16 19 24 30 36 46 ​ 10 11 12 13 15 17 ​ 10 10 10 11 13 13 Part. no. 1812.02 1817.02 1820.02 1825.02 1832.02 1840.02 ​​ 50 50 50 25 25 10 entry thread pg Material: Screws: Temperature range: Protection class: Nickel-plated brass Stainless steel A2 -50°C / +300°C IP 20 ​ Progress MS KBST Mechanical strain relief B​​ ​ Pg Pg Pg Pg Pg Pg Pg Pg min 7 9 11 13 16 21 29 36 4.0 6.0 6.0 7.0 9.0 12.0 18.0 24.0 ​ max 8.0 10.0 12.0 15.0 17.0 22.0 30.0 36.0 ​ ​ 17 20 22 24 27 35 42 55 ​ 10 11 11 11 12 14 15 18 ​ 5 6 6 7 7 8 8 10 Part. no. 1807.02 1809.02 1811.02 1813.02 1816.02 1821.02 1829.02 1836.02 ​​ 50 50 50 50 50 25 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 197 Cable Glands Nickel-Plated Brass with Trumpet short entry thread metric Material: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: Nickel-plated brass TPE NBR According to EN 50262 version A -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS T Two-piece sealing insert / not overall length insulated​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 min ​ 6.0 8.0 12.5 17.0 24.0 max ​ 10.5 15.0 20.5 25.5 33.0 ​ 18 24 30 36 46 ​ 28 34 44 50 57 ​ 31 32 38 44 46 ​ 5 6 7 8 8 Part. no. 1800.10.17 1800.10.20 1800.10.25 1800.10.32 1800.10.40 ​​ 50 50 25 25 10 long entry thread metric ​ Progress MS T Two-piece sealing insert / not overall length insulated​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 198 min 6.0 8.0 12.5 17.0 24.0 ​ max 10.5 15.0 20.5 25.5 33.0 ​ ​ 18 24 30 36 46 ​ 28 34 44 50 57 ​ 31 32 38 44 46 ​ 10 10 11 13 13 Part. no. 1800.11.17 1800.11.20 1800.11.25 1800.11.32 1800.11.40 ​​ 50 50 25 25 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass with Trumpet short entry thread pg Material: Seal: O-ring: Temperature range: Protection class: Protection type addition: Nickel-plated brass TPE NBR -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS T Two-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg min 9 11 13 16 21 29 ​ 6.0 5.5 8.0 8.0 12.5 19.0 max ​ 10.5 12.0 15.0 15.0 20.5 27.5 ​ 18 21 24 24 30 38 ​ 28 30 34 34 44 50 ​ 31 31 32 32 38 44 ​ 6 6 6 6 7.5 8 Part. no. 1800.10.09 1800.10.11 1800.10.13 1800.10.16 1800.10.21 1800.10.29 ​​ 50 50 50 50 25 10 long entry thread pg ​ Progress MS T Two-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg min 9 11 13 16 21 29 6.0 5.5 8.0 8.0 12.5 19.0 ​ max 10.5 12.0 15.0 15.0 20.5 27.5 ​ ​ 18 21 24 24 30 38 ​ 28 30 34 34 44 50 ​ 31 31 32 32 38 44 ​ 10 10 10 10 12 12 Part. no. 1800.11.09 1800.11.11 1800.11.13 1800.11.16 1800.11.21 1800.11.29 ​​ 50 50 50 50 25 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 199 Cable Glands Nickel-Plated Brass with Trumpet / Clamps short entry thread metric Material: Screws: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: Nickel-plated brass Stainless steel A2 TPE NBR According to EN 50262 version B -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS T+KB Two-piece sealing insert / not overall length insulated​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 min ​ 6.0 8.0 12.5 17.0 24.0 max ​ 10.5 15.0 20.5 25.5 33.0 ​ 18 24 30 36 46 ​ 28 34 44 50 57 ​ 43 46 52 59 59 ​ 5 6 7 8 8 Part. no. 1801.10.17 1801.10.20 1801.10.25 1801.10.32 1801.10.40 ​​ 50 50 25 10 5 long entry thread metric ​ Progress MS T+KB Two-piece sealing insert / not overall length insulated​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 200 min 6.0 8.0 12.5 17.0 24.0 ​ max 10.5 15.0 20.5 25.5 33.0 ​ ​ 18 24 30 36 46 ​ 28 34 44 50 57 ​ 43 46 52 59 59 ​ 10 10 11 13 13 Part. no. 1801.11.17 1801.11.20 1801.11.25 1801.11.32 1801.11.40 ​​ 50 50 25 10 5 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass with Trumpet / Clamps short entry thread pg Material: Screws: Seal: O-ring: Temperature range: Protection class: Protection type addition: Nickel-plated brass Stainless steel A2 TPE NBR -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress MS T+KB Two-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg min 9 11 13 16 21 29 ​ 6.0 5.5 8.0 8.0 12.5 19.0 max ​ 10.5 12.0 15.0 15.0 20.5 27.5 ​ 18 21 24 24 30 38 ​ 28 30 34 34 44 50 ​ 43 43 46 46 52 59 ​ 6 6 6 6 7.5 8 Part. no. 1801.10.09 1801.10.11 1801.10.13 1801.10.16 1801.10.21 1801.10.29 ​​ 50 50 50 50 25 10 long entry thread pg ​ Progress MS T+KB Two-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg min 9 11 13 16 21 29 6.0 5.5 8.0 8.0 12.5 19.0 ​ max 10.5 12.0 15.0 15.0 20.5 27.5 ​ ​ 18 21 24 24 30 38 ​ 28 30 34 34 44 50 ​ 43 43 46 46 52 59 ​ 10 10 10 10 12 12 Part. no. 1801.11.09 1801.11.11 1801.11.13 1801.11.16 1801.11.21 1801.11.29 ​​ 50 50 50 50 25 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 201 Cable Glands Stainless Steel A2 long entry thread metric Material: Identification: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: CrNi stainless steel A2 (DIN EN 1.4305 / AISI 303) 1 groove TPE NBR According to EN 50262 version A -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress S2 One-piece sealing insert / not overall length insulated​ ​ M8x1.25 M8x1.25 M10x1.5 M10x1.5 M12x1.5 M12x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 min ​ 2.5 3.5 3.0 4.0 3.5 5.0 6.5 8.0 11.0 16.0 21.0 28.5 37.0 46.0 max ​ 3.5 5.0 4.0 6.0 5.0 6.5 8.0 10.5 15.0 20.5 25.5 33.0 42.0 52.0 ​ 11 11 13 13 17 17 17 19 24 30 36 46 55 70 ​ 14 14 15 15 17 17 17 20 21 25 28 31 34 37 ​ 10 10 10 10 10 10 10 10 10 11 13 13 14 14 ​ 1 1 1 1                     - Part. no. 1100.08.94.035 1100.08.94.050 1100.10.94.040 1100.10.94.060 1100.12.94.050 1100.12.94.065 1100.12.94.080 1100.17.94.105 1100.20.94.150 1100.25.94.205 1100.32.94.255 1100.40.94.330 1100.50.94.420 1100.63.94.520 ​​ 50 50 50 50 50 50 50 50 50 25 25 10 10 5 1 = Metric coarse-pitch thread ​ Progress S2 two-piece sealing insert / not overall length insulated​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 202 min 6.0 8.0 12.5 17.0 24.0 33.0 40.0 ​ max 10.5 15.0 20.5 25.5 33.0 42.0 52.0 ​ ​ 19 24 30 36 46 55 70 ​ 20 21 25 28 31 34 37 ​ 10 10 11 13 13 14 14 Part. no. 1100.17.94 1100.20.94 1100.25.94 1100.32.94 1100.40.94 1100.50.94 1100.63.94 ​​ 50 50 25 25 10 10 5 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Stainless Steel A2 long entry thread pg Material: Identification: Seal: O-ring: Temperature range: Protection class: Protection type addition: CrNi stainless steel A2 (DIN EN 1.4305 / AISI 303) 1 groove TPE NBR -40°C / +100°C IP 68 (up to 10 bar) IP 69K ​ Progress S2 One-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 7 7 7 9 11 13 16 21 29 36 42 48 ​ 3.5 5.0 6.5 8.0 8.5 11.0 11.0 16.0 23.0 30.5 37.0 43.0 max ​ 5.0 6.5 8.0 10.5 12.0 15.0 15.0 20.5 27.5 35.0 42.0 49.0 ​ 17 17 17 19 22 24 24 30 41 50 55 65 ​ 17 17 17 20 21 21 21 25 28 32 34 37 ​ 10 10 10 10 10 10 10 12 12 15 15 15 Part. no. 1100.07.94.050 1100.07.94.065 1100.07.94.080 1100.09.94.105 1100.11.94.120 1100.13.94.150 1100.16.94.150 1100.21.94.205 1100.29.94.275 1100.36.94.350 1100.42.94.420 1100.48.94.490 ​​ 50 50 50 50 50 50 50 25 25 10 10 10 ​ Progress S2 two-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg min 9 11 13 16 21 29 36 42 48 6.0 5.5 8.0 8.0 12.5 19.0 26.0 33.0 37.0 ​ max 10.5 12.0 15.0 15.0 20.5 27.5 35.0 42.0 49.0 ​ ​ 19 21 24 24 30 41 50 55 65 ​ 20 21 21 21 25 28 32 34 37 ​ 10 10 10 10 12 12 15 15 15 Part. no. 1100.09.94 1100.11.94 1100.13.94 1100.16.94 1100.21.94 1100.29.94 1100.36.94 1100.42.94 1100.48.94 ​​ 50 50 50 50 25 25 10 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 203 Cable Glands Stainless Steel A2 for High Temperature Applications long entry thread metric Material: Identification: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: CrNi stainless steel A2 (DIN EN 1.4305 / AISI 303) 1 groove FPM FPM According to EN 50262 version A -40°C / +200°C IP 68 (up to 10 bar) IP 69K ​ Progress S2 HT One-piece sealing insert / not overall length insulated​ ​ M8x1.25 M8x1.25 M10x1.5 M10x1.5 M12x1.5 M12x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 min ​ 2.5 3.5 3.0 4.0 3.5 5.0 6.5 8.0 11.0 16.0 21.0 28.5 37.0 46.0 max ​ 3.5 5.0 4.0 6.0 5.0 6.5 8.0 10.5 15.0 20.5 25.5 33.0 42.0 52.0 ​ 11 11 13 13 17 17 17 19 24 30 36 46 55 70 ​ 14 14 15 15 17 17 17 20 21 25 28 31 34 37 ​ 10 10 10 10 10 10 10 10 10 11 13 13 14 14 ​ 1 1 1 1                     - Part. no. 1100.08.96.035 1100.08.96.050 1100.10.96.040 1100.10.96.060 1100.12.96.050 1100.12.96.065 1100.12.96.080 1100.17.96.105 1100.20.96.150 1100.25.96.205 1100.32.96.255 1100.40.96.330 1100.50.96.420 1100.63.96.520 ​​ 50 50 50 50 50 50 50 50 50 25 25 10 10 5 1 = Metric coarse-pitch thread ​ Progress S2 HT two-piece sealing insert / not overall length insulated​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 204 min 6.0 8.0 12.5 17.0 24.0 33.0 40.0 ​ max 10.5 15.0 20.5 25.5 33.0 42.0 52.0 ​ ​ 19 24 30 36 46 55 70 ​ 20 21 25 28 31 34 37 ​ 10 10 11 13 13 14 14 Part. no. 1100.17.96 1100.20.96 1100.25.96 1100.32.96 1100.40.96 1100.50.96 1100.63.96 ​​ 50 50 25 25 10 10 5 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Stainless Steel A2 for High Temperature Applications long entry thread pg Material: Identification: Seal: O-ring: Temperature range: Protection class: Protection type addition: CrNi stainless steel A2 (DIN EN 1.4305 / AISI 303) 1 groove FPM FPM -40°C / +200°C IP 68 (up to 10 bar) IP 69K ​ Progress S2 HT One-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 7 7 7 9 11 13 16 21 29 36 42 48 ​ 3.5 5.0 6.5 8.0 8.5 11.0 11.0 16.0 23.0 30.5 37.0 43.0 max ​ 5.0 6.5 8.0 10.5 12.0 15.0 15.0 20.5 27.5 35.0 42.0 49.0 ​ 17 17 17 19 22 24 24 30 41 50 55 65 ​ 17 17 17 20 21 21 21 25 28 32 34 37 ​ 10 10 10 10 10 10 10 12 12 15 15 15 Part. no. 1100.07.96.050 1100.07.96.065 1100.07.96.080 1100.09.96.105 1100.11.96.120 1100.13.96.150 1100.16.96.150 1100.21.96.205 1100.29.96.275 1100.36.96.350 1100.42.96.420 1100.48.96.490 ​​ 50 50 50 50 50 50 50 25 25 10 10 10 ​ Progress S2 HT two-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg min 9 11 13 16 21 29 36 42 48 6.0 5.5 8.0 8.0 12.5 19.0 26.0 33.0 37.0 ​ max 10.5 12.0 15.0 15.0 20.5 27.5 35.0 42.0 49.0 ​ ​ 19 22 24 24 30 41 50 55 65 ​ 20 21 21 21 25 28 32 34 37 ​ 10 10 10 10 12 12 15 15 15 Part. no. 1100.09.96 1100.11.96 1100.13.96 1100.16.96 1100.21.96 1100.29.96 1100.36.96 1100.42.96 1100.48.96 ​​ 50 50 50 50 25 25 10 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 205 Cable Glands Stainless & Acid-Resistant Steel A4 for High Temperature Applications long entry thread metric Material: Stainless and acid resistant steel A4 CrNiMo (DIN EN 1.4435 / AISI 316L) 2 grooves FPM FPM According to EN 50262 version A -40°C / +200°C IP 68 (up to 10 bar) IP 69K Identification: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: ​ Progress S4 HT One-piece sealing insert / not overall length insulated​ ​ M8x1.25 M8x1.25 M10x1.5 M10x1.5 M12x1.5 M12x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 min ​ 2.5 3.5 3.0 4.0 3.5 5.0 6.5 8.0 11.0 16.0 21.0 28.5 37.0 46.0 max ​ 3.5 5.0 4.0 6.0 5.0 6.5 8.0 10.5 15.0 20.5 25.5 33.0 42.0 52.0 ​ 11 11 13 13 17 17 17 19 24 30 36 46 55 70 ​ 14 14 15 15 17 17 17 20 21 25 28 31 34 37 ​ 10 10 10 10 10 10 10 10 10 11 13 13 14 14 ​ 1 1 1 1                     - Part. no. 1100.08.98.035 1100.08.98.050 1100.10.98.040 1100.10.98.060 1100.12.98.050 1100.12.98.065 1100.12.98.080 1100.17.98.105 1100.20.98.150 1100.25.98.205 1100.32.98.255 1100.40.98.330 1100.50.98.420 1100.63.98.520 ​​ 50 50 50 50 50 50 50 50 50 25 25 10 10 5 1 = Metric coarse-pitch thread ​ Progress S4 HT two-piece sealing insert / not overall length insulated​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 206 min 6.0 8.0 12.5 17.0 24.0 33.0 40.0 ​ max 10.5 15.0 20.5 25.5 33.0 42.0 52.0 ​ ​ 19 24 30 36 46 55 70 ​ 20 21 25 28 31 34 37 ​ 10 10 11 13 13 14 14 Part. no. 1100.17.98 1100.20.98 1100.25.98 1100.32.98 1100.40.98 1100.50.98 1100.63.98 ​​ 50 50 25 25 10 10 5 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Stainless & Acid-Resistant Steel A4 for High Temperature Applications long entry thread pg Material: Identification: Seal: O-ring: Temperature range: Protection class: Protection type addition: Stainless and acid resistant steel A4 CrNiMo (DIN EN 1.4435 / AISI 316L) 2 grooves FPM FPM -40°C / +200°C IP 68 (up to 10 bar) IP 69K ​ Progress S4 HT One-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 7 7 7 9 11 13 16 21 29 36 42 48 ​ 3.5 5.0 6.5 8.0 8.5 11.0 11.0 16.0 23.0 30.5 37.0 43.0 max ​ 5.0 6.5 8.0 10.5 12.0 15.0 15.0 20.5 27.5 35.0 42.0 49.0 ​ 17 17 17 19 22 24 24 30 41 50 55 65 ​ 17 17 17 20 21 21 21 25 28 32 34 37 ​ 10 10 10 10 10 10 10 12 12 15 15 15 Part. no. 1100.07.98.050 1100.07.98.065 1100.07.98.080 1100.09.98.105 1100.11.98.120 1100.13.98.150 1100.16.98.150 1100.21.98.205 1100.29.98.275 1100.36.98.350 1100.42.98.420 1100.48.98.490 ​​ 50 50 50 50 50 50 50 25 25 10 10 10 ​ Progress S4 HT two-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg min 9 11 13 16 21 29 36 42 48 6.0 5.5 8.0 8.0 12.5 19.0 26.0 33.0 37.0 ​ max 10.5 12.0 15.0 15.0 20.5 27.5 35.0 42.0 49.0 ​ ​ 19 22 24 24 30 41 50 55 65 ​ 20 21 21 21 25 28 32 34 37 ​ 10 10 10 10 12 12 15 15 15 Part. no. 1100.09.98 1100.11.98 1100.13.98 1100.16.98 1100.21.98 1100.29.98 1100.36.98 1100.42.98 1100.48.98 ​​ 50 50 50 50 25 25 10 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 207 Cable Glands Nickel-Plated Brass Elbow 90° short entry thread metric Material: Seal: Strain relief: Temperature range: Protection class: Entry thread: Nickel-plated brass TPE According to EN 50262 version A -40°C / +100°C IP 68 IP 68, if the entry thread is sealed ​ Progress MS W90 One-piece sealing insert / not overall length insulated​ ​ M12x1.5 ​ max ​ ​ ​ 5.0 6.5 15 27 ​ min 8 ​ 11 Part. no. ​ 32 5200.12 ​​ 50 ​ Progress MS W90 Two-piece sealing insert / not overall length insulated​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 min ​ 6.0 8.0 12.5 17.0 24.0 max ​ 10.5 15.0 20.5 25.5 33.0 ​ 18 24 30 36 46 ​ 30 35 44 50 60 ​ 8 8 10 10 10 ​ 13 16 20 23 28 ​ 36 44 52 60 72 Part. no. 5200.17 5200.20 5200.25 5200.32 5200.40 ​​ 50 50 25 25 10 long entry thread metric ​ Progress MS W90 One-piece sealing insert / not overall length insulated​ ​ M12x1.5 ​ max ​ ​ ​ 5.0 6.5 15 30 min ​ 12 ​ 11 ​ 32 Part. no. 5210.12 ​​ 50 ​ Progress MS W90 Two-piece sealing insert / not overall length insulated​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 208 min 6.0 8.0 12.5 17.0 24.0 ​ max 10.5 15.0 20.5 25.5 33.0 ​ ​ 18 24 30 36 46 ​ 34 39 48 56 66 ​ 12 12 14 16 16 ​ 13 16 20 23 28 ​ 36 44 52 60 72 Part. no. 5210.17 5210.20 5210.25 5210.32 5210.40 ​​ 50 50 25 25 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass Elbow 90° short entry thread pg Material: Seal: Temperature range: Protection class: Entry thread: Nickel-plated brass TPE -40°C / +100°C IP 68 IP 68, if the entry thread is sealed ​ Progress MS W90 One-piece sealing insert / not overall length insulated​ ​ Pg 7 ​ max ​ ​ ​ 5.0 6.5 15 27 ​ min ​ 8 11 Part. no. ​ 32 5200.07 ​​ 50 ​ Progress MS W90 Two-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg min 9 11 13 16 21 29 ​ 6.0 5.5 8.0 8.0 12.5 19.0 max ​ 10.5 12.0 15.0 15.0 20.5 27.5 ​ 18 21 24 24 30 38 ​ 30 35 41 41 44 56 ​ 8 8 10 10 10 10 ​ 13 14 16 16 20 24 ​ 36 40 44 44 52 65 Part. no. 5200.09 5200.11 5200.13 5200.16 5200.21 5200.29 ​​ 50 50 50 50 25 10 long entry thread pg ​ Progress MS W90 One-piece sealing insert / not overall length insulated​ ​ Pg 7 ​ max ​ ​ ​ 5.0 6.5 15 30 min ​ 11 ​ 11 Part. no. ​ 32 5210.07 ​​ 50 ​ Progress MS W90 Two-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg min 9 11 13 16 21 29 6.0 5.5 8.0 8.0 12.5 19.0 ​ max 10.5 12.0 15.0 15.0 20.5 27.5 ​ ​ 18 21 24 24 30 38 ​ 34 38 44 44 48 60 ​ 11 11 13 13 14 14 ​ 13 14 16 16 20 65 ​ 36 40 44 44 52 24 Part. no. 5210.09 5210.11 5210.13 5210.16 5210.21 5210.29 ​​ 50 50 50 50 25 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 209 Cable Glands Nickel-Plated Brass Elbow 90° long entry thread metric with lock nut Material: Seal: O-ring: Strain relief: Temperature range: Protection class: Nickel-plated brass TPE NBR According to EN 50262 version A -40°C / +100°C IP 68 ​ Progress MS W90 One-piece sealing insert / not overall length insulated​ ​ M12x1.5 ​ max ​ ​ ​ 5.0 6.5 15 30 ​ 12 min ​ ​ 32 11 Part. no. 5215.12 ​​ 50 ​ Progress MS W90 Two-piece sealing insert / not overall length insulated​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 ​ min 6.0 8.0 12.5 17.0 24.0 ​ max 10.5 15.0 20.5 25.5 33.0 ​ ​ 34 39 48 56 66 18 24 30 36 46 ​ 12 12 14 16 16 ​ 13 16 20 23 28 ​ 36 44 52 60 72 Part. no. 5215.17 5215.20 5215.25 5215.32 5215.40 ​​ 50 50 25 25 10 long entry thread pg with lock nut Material: Seal: O-ring: Temperature range: Protection class: Nickel-plated brass TPE NBR -40°C / +100°C IP 68 ​ Progress MS W90 One-piece sealing insert / not overall length insulated​ ​ Pg 7 ​ max ​ ​ ​ 5.0 6.5 15 30 min ​ 11 ​ 11 Part. no. ​ 32 5215.07 ​​ 50 ​ Progress MS W90 Two-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg 210 min 9 11 13 16 21 29 6.0 5.5 8.0 8.0 12.5 19.0 ​ max 10.5 12.0 15.0 15.0 20.5 27.5 ​ ​ 18 21 24 24 30 38 ​ 34 38 44 44 48 60 ​ 11 11 13 13 14 14 ​ 13 14 16 16 20 24 ​ 36 40 44 44 52 65 Part. no. 5215.09 5215.11 5215.13 5215.16 5215.21 5215.29 ​​ 50 50 50 50 25 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Elbow 90° Nickel-Plated Brass with Internal & External Thread entry thread metric Material: O-ring: Temperature range: Protection class: Protection type addition: Nickel-plated brass NBR -40°C / +100°C IP 54 IP 68, if the entry thread is sealed With O-ring​ ​ M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 ​ M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 ​ 15 19 24 29 36 46 56 ​ 5.0 6.5 6.0 7.5 8.5 9.5 9.0 ​ 7 7 10 10 11 17 17 ​ 13 16 19 23 26 34 41 ​ 25 29 37 42 50 67 77 ​ 20 26 31 37 44 57 69 Part. no. 5612 5617 5620 5625 5632 5640 5650 ​​ 50 50 50 25 25 10 10 entry thread pg ​ With O-ring​ ​ Pg Pg Pg Pg Pg Pg Pg Pg 7 9 11 13 16 21 29 36 ​ Pg 7 Pg 9 Pg 11 Pg 13 Pg 16 Pg 21 Pg 29 Pg 36 ​ ​ 16 18 22 24 26 34 41 52 ​ ​ 7 7 8 10 10 11 11 12 7 7 8 10 10 11 11 17 ​ 13 15 18 19 20 24 28 38 ​ 23 26 31 34 36 46 52 82 ​ 21 24 29 31 33 41 49 64 Part. no. 5607 5609 5611 5613 5616 5621 5629 5636 ​​ 50 50 50 50 50 25 20 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 211 Elbows 45° nickel-Plated Brass with Internal & External Thread entry thread metric Material: O-ring: Temperature range: Protection class: Protection type addition: Nickel-plated brass NBR -40°C / +100°C IP 54 IP 68, if the entry thread is sealed ​ With O-Ring​​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 ​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 ​ 19 24 29 36 ​ 6.5 7.5 7.0 8.5 ​ 7 10 10 11 ​ 13 17 18 21 ​ 18 23 25 28 ​ 26 33 36 41 Part. no. 5717 5720 5725 5732 ​​ 50 50 25 25 entry thread pg ​ With O-Ring​​ ​ Pg Pg Pg Pg 212 11 16 21 29 Pg Pg Pg Pg ​ 11 16 21 29 ​ ​ 22 26 34 41 ​ 8 10 11 8 ​ 11 12 12 16 ​ 16 18 21 27 ​ 20 23 26 32 ​ 30 34 39 - Part. no. 5711 5716 5721 5729 ​​ 50 50 25 25 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Flanges & Elbows entry thread metric Flanged elbow 90° aluminum Material: Seal: Temperature range: Protection class: Properties: Aluminium NBR -40°C / +100°C IP 65 For splash water-proof mounting on casing walls with entry thread for cable glands or conduit glands ​ With 1 entry thread​​ ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 ​ 45 x 48 53 x 56 63 x 65 71 x 75 71 x 75 89 x 93 96 x 114 ​ ​ 37 44 54 60 60 72 84 ​ 4.3 5.5 5.5 5.5 5.5 6.5 4.3 ​ ​ 15.5 18.0 22.5 27.0 27.0 33.5 37.0 8 8 8 10 10 11 10 ​ 30 35 42 52 52 69 74 ​ 28 34 43 53 53 65 86 ​ 10.5 10.5 11.0 11.0 11.0 18.0 14.0 ​ 24 24 35 38 38 50 67 Part. no. 5517 5520 5525 5532 5540 5550 5563 ​​ 10 10 5 5 5 2 2 entry thread pg ​ With 1 entry thread​​ ​ Pg Pg Pg Pg Pg Pg 9 13 16 21 29 36 ​ 45 x 48 53 x 56 53 x 56 63 x 65 71 x 75 89 x 94 ​ ​ 37 44 44 54 60 72 ​ 4.3 5.5 5.5 5.5 5.5 6.5 ​ 8 8 8 8 10 11 ​ 15.5 19.0 19.0 23.0 27.0 34.0 ​ 30 35 35 42 52 69 ​ 28 34 34 43 53 65 ​ 10.5 10.5 10.5 11.0 11.0 18.0 ​ 24 24 24 35 38 50 Part. no. 5509 5513 5516 5521 5529 5536 ​​ 10 10 10 10 10 10 entry thread pg Flanged elbow 90° zinc diecasting Material: Color: Seal: Temperature range: Protection class: Properties: Zinc diecasting Hammergrey enamel NBR -20°C / +100°C IP 65 For splash water-proof mounting on casing walls with entry thread for cable glands or conduit glands ​ With 1-3 entry threads​​ ​ Pg Pg Pg Pg Pg Pg 16 21 29 36 16 16 1 1 1 1 2 3 ​ x x x x x x ​ 31 40 51.5 62 34 34 ​ 42 60 76 90 70 70 ​ ​ 42 60 66 85 91 124 ​ 36.0 52.5 54.0 73.0 79.0 111.0 ​ 36 30 58 56 ​ 11 12 12 12 10 10 ​ 2x4.5 2x5.2 4x5.5 4x5.5 4x5.5 4x5.5 Part. no. 5516.10 5521.10 5529.10 5536.10 5516.12 5516.13 ​​ 10 10 10 10 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 213 Cable Glands Nickel-Plated Brass According to DIN 46320-C4-MS short entry thread metric Material: Seal: Temperature range: Protection class: Nickel-plated brass NBR -20°C / +80°C IP 54 ​ One-piece sealing ring / not overall length insulated​ ​ M12x1.5 M16x1.5 M20x1.5 M20x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 min ​ 5.0 6.0 8.0 10.0 12.0 15.0 24.0 33.0 41.0 45.0 max ​ 7.0 8.0 10.0 12.0 14.0 17.0 26.0 35.0 43.0 47.0 ​ 14/13 18/15 22/18 22/20 22/20 30/28 40/37 50/47 57/54 66/60 ​ 15 15 19 19 19 23 26 30 34 35 ​ ​ Part. no. ​ 5 5 6 6 6 7 8 8 9 10 B 112 B 117 B 120.10 B 120.12 B 120.14 B 125 B 132 B 140 B 150 B 163 100 100 50 50 50 50 25 20 10 10 long entry thread metric ​ One-piece sealing ring / not overall length insulated​ ​ M12x1.5 M16x1.5 M20x1.5 M20x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 214 min 5.0 6.0 8.0 10.0 12.0 15.0 24.0 33.0 41.0 45.0 ​ max 7.0 8.0 10.0 12.0 14.0 17.0 26.0 35.0 43.0 47.0 ​ ​ 14/13 18/15 22/18 22/20 22/20 30/28 40/37 50/47 57/54 66/60 ​ 15 15 19 19 19 23 26 30 34 35 ​ 10 10 10 10 10 12 12 14 14 14 ​ Part. no. ​ B 212 B 217 B 220.10 B 220.12 B 220.14 B 225 B 232 B 240 B 250 B 263 100 100 50 50 50 50 25 20 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands Nickel-Plated Brass with Antikink Nozzle & Clamps short entry thread metric Material: Seal: antikink nozzle: Temperature range: Protection class: Nickel-plated brass NBR NBR -20°C / +80°C IP 65 if the entry thread is sealed ​ One-piece sealing ring / not overall length insulated​ ​ M12x1.5 M16x1.5 M20x1.5 M20x1.5 M20x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 M40x1.5 M40x1.5 M40x1.5 M40x1.5 ​ min 3.5 5.5 5.5 7.5 9.0 11.0 13.0 13.5 15.0 17.0 18.0 21.0 23.0 23.0 27.0 30.0 32.0 ​ max 5.0 7.0 7.0 9.0 11.0 13.0 15.0 15.0 17.0 19.0 20.0 23.0 25.0 26.0 30.0 33.0 35.0 ​ 14/15 17/18 20/22 20/22 22/22 22/22 24/24 30/30 30/30 30/30 30/30 40/40 40/40 50/50 50/50 50/50 50/50 ​ 28 28 32 32 33 33 35 42 42 42 42 42 42 51 51 51 51 ​ 5 6 6 6 6 6 6 7 7 7 7 8 8 9 9 9 9 ​ Part. no. 1852.12.05 1852.16.07 1852.20.07 1852.20.09 1852.20.11 1852.20.13 1852.20.15 1852.25.15 1852.25.17 1852.25.19 1852.25.20 1852.32.23 1852.32.25 1852.40.26 1852.40.30 1852.40.33 1852.40.35 ​​ 25 25 25 25 25 25 25 25 25 25 25 1 1 1 1 1 1 short entry thread pg ​ One-piece sealing ring / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 7 9 11 11 13 13 13 16 16 21 21 21 21 29 29 29 36 36 36 36 42 42 42 48 48 3.5 5.5 5.5 7.5 7.5 9.0 11.0 11.5 13.0 13.5 15.0 17.0 18.0 18.0 21.0 23.0 23.0 27.0 30.0 32.0 32.0 35.0 36.0 36.0 40.0 ​ max 5.0 7.0 7.0 9.0 9.0 11.0 13.0 13.0 15.0 15.0 17.0 19.0 20.0 20.0 23.0 25.0 26.0 30.0 33.0 35.0 35.0 38.0 40.0 40.0 44.0 ​ ​ 14/16 17/19 20/22 20/22 22/24 22/24 22/24 24/27 24/27 30/34 30/34 30/34 30/34 40/42 40/42 40/42 50/52 50/52 50/52 50/52 57/62 57/62 57/62 64/68 64/68 ​ 28 28 32 32 32 33 33 35 35 42 42 42 42 42 42 42 51 51 51 51 59 59 59 62 62 ​ 5 6 6 6 6 6 6 6 6 7 7 7 7 8 8 8 9 9 9 9 10 10 10 10 10 ​ Part. no. 1852.07.05 1852.09.07 1852.11.07 1852.11.09 1852.13.09 1852.13.11 1852.13.13 1852.16.13 1852.16.15 1852.21.15 1852.21.17 1852.21.19 1852.21.20 1852.29.20 1852.29.23 1852.29.25 1852.36.26 1852.36.30 1852.36.33 1852.36.35 1852.42.35 1852.42.38 1852.42.40 1852.48.48.40 1852.48.48.44 ​​ 50 50 50 50 25 25 25 25 25 25 25 25 25 1 1 1 1 1 1 1 1 1 1 1 1 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 215 Cable Glands EMC EasyCONNECT Nickel-Plated Brass with Contact Spring short entry thread metric Material: Contact spring: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: Properties: Nickel-plated brass Spring steel 1.4310 TPE NBR According to IEC 62444 version A -60°C / +100°C IP 68 (up to 10 bar) IP 69K Full control of the installation process thanks to fast and safe assembly for partially stripped shielding cables equally as well as the contact of completely cable shields ​ Progress MS EMC easyCONNECT Two-piece sealing insert / not overall length insulated​ ​ M12x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 min ​ 3.5 5.0 6.0 8.0 12.5 17.0 max ​ 5.0 6.5 10.5 15.0 20.5 25.5 ​ 15 15 18 24 30 36 ​ 22 22 25 27 33 33 ​ 5 5 5 6 7 8 Part. no. ​ 1083.12.050 1083.12.065 1083.17 1083.20 1083.25 1083.32 1 1 - ​​ 50 50 50 50 25 25 1 = One-piece sealing insert Approvals in preperation long entry thread metric ​ Progress MS EMC easyCONNECT Two-piece sealing insert / not overall length insulated​ ​ M12x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 min 3.5 5.0 6.0 8.0 12.5 17.0 ​ max 5.0 6.5 10.5 15.0 20.5 25.5 ​ ​ 15 15 18 24 30 36 ​ 22 22 25 27 33 33 ​ 10 10 10 10 11 13 ​ 1 1 - Part. no. 1183.12.050 1183.12.065 1183.17 1183.20 1183.25 1183.32 ​​ 50 50 50 50 25 25 1 = One-piece sealing insert Approvals in preperation 216 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands EMC Rapid Nickel-Plated Brass with Contact Disc short entry thread metric Material: Contact sleeve: Contact disc: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: Properties: Nickel-plated brass Nickel-plated brass Stainless steel A2 TPE NBR According to EN 50262 version A -40°C / +100°C IP 68 (up to 10 bar) IP 69K For a quick installation of partially dismantled cables as well as thoroughly shielded cables ​ Progress MS EMC Rapid One-piece sealing insert / not overall length insulated​ ​ M12x1.5 M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 min ​ 4.5 6.0 6.0 8.0 8.0 11.0 13.0 16.0 18.0 21.0 max ​ 6.0 7.5 8.0 10.0 11.0 14.0 16.0 19.0 21.0 25.0 ​ 15 15 18 18 24 24 30 30 36 36 ​ 20 20 23 25 25 27 30 33 32 32 ​ 5 5 5 5 6 6 7 7 8 8 Part. no. 1081.12.060 1081.12.075 1081.17.080 1081.17.100 1081.20.110 1081.20.140 1081.25.160 1081.25.190 1081.32.210 1081.32.250 ​​ 50 50 50 50 50 50 25 25 25 25 long entry thread metric ​ Progress MS EMC Rapid One-piece sealing insert / not overall length insulated​ ​ M12x1.5 M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 min 4.5 6.0 6.0 8.0 8.0 11.0 13.0 16.0 18.0 21.0 ​ max 6.0 7.5 8.0 10.0 11.0 14.0 16.0 19.0 21.0 25.0 ​ ​ 15 15 18 18 24 24 30 30 36 36 ​ 20 20 23 25 25 27 30 33 32 32 ​ 10 10 10 10 10 10 11 11 13 13 Part. no. 1181.12.060 1181.12.075 1181.17.080 1181.17.100 1181.20.110 1181.20.140 1181.25.160 1181.25.190 1181.32.210 1181.32.250 ​​ 50 50 50 50 50 50 25 25 25 25 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 217 Cable Glands EMC Rapid Nickel-Plated Brass with Contact Disc short entry thread pg Material: Contact sleeve: Contact disc: Seal: O-ring: Temperature range: Protection class: Protection type addition: Properties: Nickel-plated brass Nickel-plated brass Stainless steel A2 TPE NBR -40°C / +100°C IP 68 (up to 10 bar) IP 69K For a quick installation of partially dismantled cables as well as thoroughly shielded cables ​ Progress MS EMC Rapid One-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 7 7 9 9 11 11 13 13 16 16 21 21 29 29 ​ 4.5 6.0 6.0 8.0 5.5 8.5 8.0 11.0 8.0 11.0 13.0 16.0 19.0 23.0 max ​ 6.0 7.5 8.0 10.0 8.5 12.0 11.0 14.0 11.0 14.0 16.0 19.0 23.0 25.5 ​ 15 15 18 18 21 21 24 24 24 24 30 30 38 38 ​ 20 20 23 25 25 25 25 27 24 27 30 33 33 32 ​ 6 6 6 6 6 6 6 6 6 6 7 7 8 8 Part. no. 1081.07.060 1081.07.075 1081.09.080 1081.09.100 1081.11.085 1081.11.120 1081.13.110 1081.13.140 1081.16.110 1081.16.140 1081.21.160 1081.21.190 1081.29.230 1081.29.255 ​​ 50 50 50 50 50 50 50 50 50 50 25 25 25 25 long entry thread pg ​ Progress MS EMC Rapid One-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg 218 min 7 7 9 9 11 11 13 13 16 16 21 21 29 29 4.5 6.0 6.0 8.0 5.5 8.5 8.0 11.0 8.0 11.0 13.0 16.0 19.0 23.0 ​ max 6.0 7.5 8.0 10.0 8.5 12.0 11.0 14.0 11.0 14.0 16.0 19.0 23.0 25.5 ​ ​ 15 15 18 18 21 21 24 24 24 24 30 30 38 38 ​ 20 20 23 25 25 25 25 27 24 27 30 33 33 32 ​ 10 10 10 10 10 10 10 10 10 10 12 12 12 12 Part. no. 1181.07.060 1181.07.075 1181.09.080 1181.09.100 1181.11.085 1181.11.120 1181.13.110 1181.13.140 1181.16.110 1181.16.140 1181.21.160 1181.21.190 1181.29.230 1181.29.255 ​​ 50 50 50 50 50 50 50 50 50 50 25 25 25 25 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands EMC Nickel-Plated Brass with Contact Sleeve short entry thread metric Material: Contact sleeve: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: Properties: Nickel-plated brass Nickel-plated brass TPE NBR According to EN 50262 version A -40°C / +100°C IP 68 (up to 10 bar) IP 69K Excellent shield contact through the contact sleeve with the braided shield terminating in the screwed cable gland ​ Progress MS EMC One-piece sealing insert / not overall length insulated​ ​ M8x1.25 M8x1.25 M10x1.5 M10x1.5 M12x1.5 M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 M40x1.5 M40x1.5 M50x1.5 M50x1.5 M63x1.5 M63x1.5 M75x1.5 M80x2.0 M85x2.0 M95x2.0 min 2.5 3.0 3.0 4.0 4.5 6.0 6.0 8.0 8.0 11.0 13.0 16.0 18.0 21.0 24.0 28.5 33.0 37.0 40.0 46.0 50.0 56.0 63.0 68.0 ​ max 3.5 4.0 4.0 6.0 6.0 7.5 8.0 10.0 11.0 14.0 16.0 19.0 21.0 25.0 28.5 32.0 37.0 41.0 46.0 50.0 56.0 65.0 70.0 75.0 ​ ​ 11 11 13 13 15 15 18 18 24 24 30 30 36 36 46 46 55 55 70 70 80 95 95 110 ​ 15 15 16 16 20 20 23 25 25 27 30 33 32 32 34 34 36 36 39 39 40 45 45 52 ​ 5 5 5 5 5 5 5 5 6 6 7 7 8 8 8 8 9 9 10 10 11 18 18 20 ​ 1 1 1 1                                         - Part. no. 1080.08.035 1080.08.040 1080.10.040 1080.10.060 1080.12.060 1080.12.075 1080.17.080 1080.17.100 1080.20.110 1080.20.140 1080.25.160 1080.25.190 1080.32.210 1080.32.250 1080.40.285 1080.40.320 1080.50.370 1080.50.410 1080.63.460 1080.63.500 1080.75.560 1080.80.650 1080.85.700 1080.95.750 ​​ 50 50 50 50 50 50 50 50 50 50 25 25 25 25 10 10 10 10 5 5 1 1 1 1 1 = Metric coarse-pitch thread American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 219 Cable Glands EMC Nickel-Plated Brass with Contact Sleeve long entry thread metric Material: Contact sleeve: Seal: O-ring : Strain relief: Temperature range: Protection class: Protection type addition: Properties: Nickel-plated brass Nickel-plated brass TPE NBR According to EN 50262 version A -40°C / +100°C IP 68 (up to 10 bar) IP 69K Excellent shield contact through the contact sleeve with the braided shield terminating in the screwed cable gland ​ Progress MS EMC One-piece sealing insert / not overall length insulated​ ​ M8x1.25 M8x1.25 M10x1.5 M10x1.5 M12x1.5 M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 M40x1.5 M40x1.5 M50x1.5 M50x1.5 M63x1.5 M63x1.5 min 2.5 3.0 3.0 4.0 4.5 6.0 6.0 8.0 8.0 11.0 13.0 16.0 18.0 21.0 24.0 28.5 33.0 37.0 40.0 46.0 ​ max 3.5 4.0 4.0 6.0 6.0 7.5 8.0 10.0 11.0 14.0 16.0 19.0 21.0 25.0 28.5 32.0 37.0 41.0 46.0 50.0 ​ ​ 11 11 13 13 15 15 18 18 24 24 30 30 36 36 46 46 55 55 70 70 ​ 15 15 16 16 20 20 23 25 25 27 30 33 32 32 34 34 36 36 39 39 ​ 10 10 10 10 10 10 10 10 10 10 11 11 13 13 13 13 14 14 14 14 ​ 1 1 1 1                                 - Part. no. 1180.08.035 1180.08.040 1180.10.040 1180.10.060 1180.12.060 1180.12.075 1180.17.080 1180.17.100 1180.20.110 1180.20.140 1180.25.160 1180.25.190 1180.32.210 1180.32.250 1180.40.285 1180.40.320 1180.50.370 1180.50.410 1180.63.460 1180.63.500 ​​ 50 50 50 50 50 50 50 50 50 50 25 25 25 25 10 10 10 10 5 5 1 = Metric coarse-pitch thread 220 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands EMC Nickel-Plated Brass with Contact Sleeve short entry thread pg Material: Contact sleeve: Seal: O-ring: Temperature range: Protection class: Protection type addition: Properties: Nickel-plated brass Nickel-plated brass TPE NBR -40°C / +100°C IP 68 (up to 10 bar) IP 69K Excellent shield contact through the contact sleeve with the braided shield terminating in the screwed cable gland ​ Progress MS EMC One-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 7 7 9 9 11 11 13 13 16 16 21 21 29 29 36 36 42 42 48 48 ​ 4.5 6.0 6.0 8.0 5.5 8.5 8.0 11.0 8.0 11.0 13.0 16.0 19.0 23.0 25.0 30.5 33.0 37.0 39.0 43.0 max ​ 6.0 7.5 8.0 10.0 8.5 12.0 11.0 14.0 11.0 14.0 16.0 19.0 23.0 25.5 30.5 35.0 37.0 41.0 43.0 46.5 ​ 15 15 18 18 21 21 24 24 24 24 30 30 38 38 50 50 55 55 65 65 ​ 20 20 23 25 23 23 25 27 24 27 30 33 33 32 36 34 37 36 42 40 ​ 6 6 6 6 6 6 6 6 6 6 7.5 7.5 8 8 8 8 10 10 11 11 Part. no. 1080.07.060 1080.07.075 1080.09.080 1080.09.100 1080.11.085 1080.11.120 1080.13.110 1080.13.140 1080.16.110 1080.16.140 1080.21.160 1080.21.190 1080.29.230 1080.29.255 1080.36.305 1080.36.350 1080.42.370 1080.42.410 1080.48.430 1080.48.465 ​​ 50 50 50 50 50 50 50 50 50 50 25 25 25 25 10 10 10 10 10 10 long entry thread pg ​ Progress MS EMC One-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 7 7 9 9 11 11 13 13 16 16 21 21 29 29 36 36 42 42 48 48 4.5 6.0 6.0 8.0 5.5 8.5 8.0 11.0 8.0 11.0 13.0 16.0 19.0 23.0 25.0 30.5 33.0 37.0 39.0 43.0 ​ max 6.0 7.5 8.0 10.0 8.5 12.0 11.0 14.0 11.0 14.0 16.0 19.0 23.0 25.5 30.5 35.0 37.0 41.0 43.0 46.5 ​ ​ 15 15 18 18 21 21 24 24 24 24 30 30 38 38 50 50 55 55 65 65 ​ 20 20 23 25 23 23 25 27 24 27 30 33 33 32 36 34 37 36 42 40 ​ 10 10 10 10 10 10 10 10 10 10 12 12 12 12 15 15 15 15 15 15 Part. no. 1180.07.060 1180.07.075 1180.09.080 1180.09.100 1180.11.085 1180.11.120 1180.13.110 1180.13.140 1180.16.110 1180.16.140 1180.21.160 1180.21.190 1180.29.230 1180.29.255 1180.36.305 1180.36.350 1180.42.370 1180.42.410 1180.48.430 1180.48.465 ​​ 50 50 50 50 50 50 50 50 50 50 25 25 25 25 10 10 10 10 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 221 Cable Glands EMC Nickel-Plated Brass with Contact Sleeve for High Temperature Applications short entry thread metric Material: Contact sleeve: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: Properties: Nickel-plated brass Nickel-plated brass FPM FPM According to EN 50262 version A -40°C / +200°C IP 68 (up to 10 bar) IP 69K Excellent shield contact through the contact sleeve with the braided shield terminating in the screwed cable gland ​ ​ One-piece sealing insert / not overall length insulated​ ​ M10x1.5 M10x1.5 M12x1.5 M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 min ​ 3.0 4.0 4.5 6.0 6.0 8.0 8.0 11.0 13.0 16.0 18.0 21.0 max ​ 4.0 6.0 6.0 7.5 8.0 10.0 11.0 14.0 16.0 19.0 21.0 25.0 ​ 13 13 15 15 18 18 24 24 30 30 36 36 ​ 16 16 20 20 23 25 25 27 30 33 32 32 ​ 5 5 5 5 5 5 6 6 7 7 8 8 Part. no. ​ 1080.10.91.040 1080.10.91.060 1080.12.91.060 1080.12.91.075 1080.17.91.080 1080.17.91.100 1080.20.91.110 1080.20.91.140 1080.25.91.160 1080.25.91.190 1080.32.91.210 1080.32.91.250 1 1                     - ​​ 50 50 50 50 50 50 50 50 25 25 25 25 1 = Metric coarse-pitch thread long entry thread metric ​ One-piece sealing insert / not overall length insulated​ ​ M10x1.5 M10x1.5 M12x1.5 M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 min 3.0 4.0 4.5 6.0 6.0 8.0 8.0 11.0 13.0 16.0 18.0 21.0 ​ max 4.0 6.0 6.0 7.5 8.0 10.0 11.0 14.0 16.0 19.0 21.0 25.0 ​ ​ 13 13 15 15 18 18 24 24 30 30 36 36 ​ 16 16 20 20 23 25 25 27 30 33 32 32 ​ 10 10 10 10 10 10 10 10 11 11 13 13 ​ 1 1                     - ​ Part. no. 1180.10.91.040 1180.10.91.060 1180.12.91.060 1180.12.91.075 1180.17.91.080 1180.17.91.100 1180.20.91.110 1180.20.91.140 1180.25.91.160 1180.25.91.190 1180.32.91.210 1180.32.91.250 ​​ 50 50 50 50 50 50 50 50 25 25 25 25 1 = Metric coarse-pitch thread 222 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands EMC Nickel-Plated Brass with Contact Sleeve for High Temperature Applications short entry thread pg Material: Contact sleeve: Seal: O-ring: Temperature range: Protection class: Protection type addition: Properties: Nickel-plated brass Nickel-plated brass FPM FPM -40°C / +200°C IP 68 (up to 10 bar) IP 69K Excellent shield contact through the contact sleeve with the braided shield terminating in the screwed cable gland ​ One-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 9 9 11 11 13 13 16 16 21 21 29 29 ​ 6.0 8.0 5.5 8.5 8.0 11.0 8.0 11.0 13.0 16.0 19.0 23.0 max ​ 8.0 10.0 8.5 12.0 11.0 14.0 11.0 14.0 16.0 19.0 23.0 25.5 ​ 18 18 21 21 24 24 24 24 30 30 38 38 ​ 23 25 23 23 25 27 24 27 30 33 33 32 ​ 6 6 6 6 6 6 6 6 7.5 7.5 8 8 ​ Part. no. 1080.09.91.080 1080.09.91.100 1080.11.91.085 1080.11.91.120 1080.13.91.110 1080.13.91.140 1080.16.91.110 1080.16.91.140 1080.21.91.160 1080.21.91.190 1080.29.91.230 1080.29.91.255 ​​ 50 50 50 50 50 50 50 50 25 25 25 25 long entry thread pg ​ One-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 9 9 11 11 13 13 16 16 21 21 29 29 6.0 8.0 5.5 8.5 8.0 8.5 8.0 11.0 13.0 16.0 19.0 23.0 ​ max 8.0 10.0 8.5 12.0 11.0 12.0 11.0 14.0 16.0 19.0 23.0 25.5 ​ ​ 18 18 21 21 24 24 24 24 30 30 38 38 ​ 23 25 23 23 25 27 24 27 30 33 33 32 ​ 10 10 10 10 10 10 10 10 12 12 12 12 ​ Part. no. 1180.09.91.080 1180.09.91.100 1180.11.91.085 1180.11.91.120 1180.13.91.110 1180.13.91.140 1180.16.91.110 1180.16.91.140 1180.21.91.160 1180.21.91.190 1180.29.91.230 1180.29.91.255 ​​ 50 50 50 50 50 50 50 50 25 25 25 25 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 223 Cable Glands EMC Nickel-Plated Brass with Antikink Spring short entry thread metric Material: Antikink spring: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: Properties: Nickel-plated brass Stainless steel A2 TPE NBR According to EN 50262 version A -40°C / +100°C IP 68 IP 69K Excellent shield contact through the contact sleeve with the braided shield terminating in the screwed cable gland ​ Progress MS EMC FKN One-piece sealing insert / not overall length insulated​ ​ M8x1.25 M8x1.25 M10x1.5 M10x1.5 M12x1.5 M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 min 2.5 3.0 3.0 4.0 4.5 6.0 6.0 8.0 8.0 11.0 13.0 16.0 18.0 21.0 ​ max 3.5 4.0 4.0 6.0 6.0 7.5 8.0 10.0 11.0 14.0 16.0 19.0 21.0 24.5 ​ ​ 11 11 13 13 15 15 18 18 24 24 30 30 36 36 ​ 50 50 54 54 60 60 69 69 88 88 104 104 112 112 ​ 5 5 5 5 5 5 5 5 6 6 7 7 8 8 ​ 1 1 1 1                     - Part. no. 1080.08.52.035 1080.08.52.040 1080.10.52.040 1080.10.52.060 1080.12.52.060 1080.12.52.075 1080.17.52.080 1080.17.52.100 1080.20.52.110 1080.20.52.140 1080.25.52.160 1080.25.52.190 1080.32.52.210 1080.32.52.245 ​​ 10 10 10 10 10 10 10 10 10 10 10 10 5 5 1 = Metric coarse-pitch thread Long entry thread available on request 224 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands EMC Nickel-Plated Brass with Antikink Spring short entry thread pg Material: Antikink spring: Seal: O-ring: Temperature range: Protection class: Properties: Nickel-plated brass Stainless steel A2 TPE NBR -40°C / +100°C IP 68 Excellent shield contact through the contact sleeve with the braided shield terminating in the screwed cable gland ​ Progress MS EMC FKN One-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 7 7 9 9 11 11 13 13 16 16 21 21 4.5 6.0 6.0 8.0 6.0 8.0 8.0 11.0 8.0 11.0 13.0 16.0 ​ max 6.0 7.5 8.0 10.0 8.0 10.0 11.0 14.0 11.0 14.0 16.0 19.0 ​ ​ 15 15 18 18 18/21 18/21 24 24 24 24 30 30 ​ 60 60 69 69 69 69 88 88 88 88 104 104 ​ 6 6 6 6 6 6 6 6 6 6 7 7 Part. no. 1080.07.52.060 1080.07.52.075 1080.09.52.080 1080.09.52.100 1080.11.52.080 1080.11.52.100 1080.13.52.110 1080.13.52.140 1080.16.52.110 1080.16.52.140 1080.21.52.160 1080.21.52.190 ​​ 10 10 10 10 10 10 10 10 10 10 5 5 Long entry thread available on request American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 225 Cable Glands EMC Series 85 Nickel-Plated Brass with Collet Chuck entry thread metric Material: Seal: O-ring: Strain relief: Temperature range: Protection class: Protection type addition: Properties: Nickel-plated brass TPE NBR According to EN 50262 version A -40°C / +100°C IP 68 (up to 10 bar) IP 69K For high leakage currents, concentric shield contact with minimal transfer resistances and transfer impedances ​ Progress MS EMC Series 85 Two-piece sealing insert / not overall length insulated​ ​ M16x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 M63x1.5 min 4.5 6.0 8.0 8.0 12.5 12.5 17.0 17.0 24.0 24.0 33.0 33.0 40.0 ​ max 6.0 10.5 15.0 15.0 20.5 20.5 25.5 25.5 33.0 33.0 42.0 42.0 52.0 ​ ​ 3.0-4.5 4.5-8.0 7.5-10.0 7.5-12.0 10.0-14.0 10.0-16.0 14.0-19.0 14.0-22.0 21.0-25.0 21.0-30.0 29.0-38.0 29.0-38.0 35.0-44.0 ​ 18 18 24 24 30 30 36 36 46 46 55 70/55 70 ​ 40 42 47 47 59 59 66 66 68 68 77 77 78 ​ 6 8 8 8 8 8 8 10 10 12 13 15 15 ​ 14 16 20 20 21 21 24 24 24 24 25 25 26 Part. no. 1000.17.85.045 1000.17.85.080 1000.17.85.100 1000.20.85.120 1000.20.85.140 1000.25.85.160 1000.25.85.190 1000.32.85.220 1000.32.85.250 1000.40.85.300 1000.50.85.380 1000.63.85.380 1000.63.85.440 ​​ 25 25 25 25 20 20 25 25 5 5 5 5 1 Important! To provide the best possible protection for the cable shield and the cable, it is necessary to install a copper EMC tape. The copper tape must be fixed according to the illustration! (example: Tape Scotch 3M Typ 1181) 2x 226 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cable Glands EMC Series 85 Nickel-Plated Brass with Collet Chuck entry thread pg Material: Seal: O-ring: Temperature range: Protection class: Protection type addition: Properties: Nickel-plated brass TPE NBR -40°C / +100°C IP 68 (up to 10 bar) IP 69K For high leakage currents, concentric shield contact with minimal transfer resistances and transfer impedances ​ Two-piece sealing insert / not overall length insulated​ ​ Pg Pg Pg Pg Pg Pg Pg Pg min 11 11 16 16 21 21 29 29 6.0 8.0 8.0 12.5 12.5 17.0 17.0 24.0 ​ max 10.5 15.0 15.0 20.5 20.5 25.5 25.5 33.0 ​ ​ 4.5-8.0 7.5-12.0 7.5-12.0 10.0-15.0 10.0-16.0 14.0-19.0 14.0-22.0 21.0-25.0 ​ 21/18 24 24 30 30 36 38/36 46 ​ 42 47 47 59 59 66 66 68 ​ 8 8 8 8 8 8 10 10 ​ Part. no. ​ 16 20 20 21 21 24 24 24 1000.11.85.080 1000.11.85.120 1000.16.85.120 1000.16.85.150 1000.21.85.160 1000.21.85.190 1000.29.85.220 1000.29.85.250 ​​ 25 25 25 25 20 25 20 5 Important! To provide the best possible protection for the cable shield and the cable, it is necessary to install a copper EMC tape. Further dimensions upon request The copper tape must be fixed according to the illustration! (example: Tape Scotch 3M Typ 1181) 2x American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 227 EMC Cable Glands Accessories entry thread metric EMC lock nuts nickel-plated brass with cutter teeth Material: Execution: Nickel-plated brass EMC lock nut brass with cutting teeth for optimised shield contact -60°C / +200°C Temperature range: ​ ​​​ ​ ​​​ ​ M8x1.25 M10x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 ​ 11 13 15 19 24 30 36 46 55 70 ​ 3.3 3.3 3.5 3.5 4.0 4.0 5.0 5.3 6.3 7.0 Part. no. ​ 8008.85 8010.85 8012.85 8017.85 8020.85 8025.85 8032.85 8040.85 8050.85 8063.85 1 1                 - ​​ 25 25 25 25 25 10 10 10 10 10 1 = Metric coarse-pitch thread entry thread pg ​ ​​​ ​ ​​​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg 228 ​ 7 9 11 13 16 21 29 36 42 48 15 18 21 24 26 32 41 50 60 64 ​ 3.3 3.3 3.5 3.5 3.5 4.0 4.6 5.8 5.8 6.5 Part. no. 8007.85 8009.85 8011.85 8013.85 8016.85 8021.85 8029.85 8036.85 8042.85 8048.85 ​​ 25 25 25 25 25 10 10 10 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com EMC Cable Glands Accessories suitable for cable glands progress® Grounding straps suitable for cable glands Material: Temperature range: Application: Brass raw -60°C / +200°C Solderable or pluggable 6,3 x 1,0 mm ​ Grounding straps suitable for cable glands / Entry thread metric​ ​ M12 / Pg 7 M16 M20 M25 M32 M40 M50 M63 ​ 13.0 16.5 20.5 25.5 33.0 40.5 50.5 63.5 ​ 24 24 28 32 40 52 62 78 ​ ​ Part. no. 1007.80.10 1017.80.10 1020.80.10 1025.80.10 1032.80.10 1040.80.10 1050.80.10 1063.80.10 1 1 1 1 1 1 1 1 ​ 100 100 100 100 100 100 50 50 ​ Grounding straps suitable for cable glands / Entry thread Pg ​ M12 / Pg 7 Pg 9 Pg 11 Pg 13 Pg 16 Pg 21 Pg 29 Pg 36 ​ 13.0 16.0 19.0 21.0 23.0 29.0 38.0 48.0 ​ 24 24 28 28 32 37 52 62 ​ 1 1 1 1 1 1 1 1 ​ Part. no. 1007.80.10 1009.80.10 1011.80.10 1013.80.10 1016.80.10 1021.80.10 1029.80.10 1036.80.10 ​ 100 100 100 100 100 100 50 50 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 229 Synthetic Cable Glands Syntec® with Lamellar Technology short entry thread metric Material: Properties: Sealing ring: Tested acc. to: Temperature range: Protection class: Polyamide PA 6 halogen-free TPE or CR (Neoprene) EN 50262 -30°C / +100°C IP 68 ​ SYNTEC Light grey RAL 7035 / One-piece sealing ring​ ​ M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 min ​ 2.5 2.0 4.5 3.5 7.0 5.0 10.0 17.0 max ​ 6.5 6.0 10.0 8.0 13.0 11.0 17.0 25.0 ​ 15 19 19 24 24 29 29 42 ​ 21 25 25 29 29 38 38 36 ​ 6 8 8 9 9 10 10 10 Part. no. 1555.12.06 1555.17.06 1555.17.10 1555.20.08 1555.20.13 1555.25.11 1555.25.17 1555.32.25 ​ 100 50 50 50 50 25 25 20 ​ SYNTEC Dark grey RAL 7001 / One-piece sealing ring​ ​ M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 min ​ 2.5 2.0 4.5 3.5 7.0 5.0 10.0 17.0 max ​ 6.5 6.0 10.0 8.0 13.0 11.0 17.0 25.0 ​ 15 19 19 24 24 29 29 42 ​ 21 25 25 29 29 38 38 36 ​ 6 8 8 9 9 10 10 10 Part. no. 1556.12.06 1556.17.06 1556.17.10 1556.20.08 1556.20.13 1556.25.11 1556.25.17 1556.32.25 ​ 100 50 50 50 50 25 25 20 ​ SYNTEC Black RAL 9005 / One-piece sealing ring​ ​ M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 230 min 2.5 2.0 4.5 3.5 7.0 5.0 10.0 17.0 ​ max 6.5 6.0 10.0 8.0 13.0 11.0 17.0 25.0 ​ ​ 15 19 19 24 24 29 29 42 ​ 21 25 25 29 29 38 38 36 ​ 6 8 8 9 9 10 10 10 Part. no. 1545.12.06 1545.17.06 1545.17.10 1545.20.08 1545.20.13 1545.25.11 1545.25.17 1545.32.25 ​ 100 50 50 50 50 25 25 20 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Synthetic Cable Glands Syntec® with Lamellar Technology long entry thread metric Material: Properties: Sealing ring: Tested acc. to: Temperature range: Protection class: Polyamide PA 6 halogen-free TPE or CR (Neoprene) EN 50262 -30°C / +100°C IP 68 ​ SYNTEC Light grey RAL 7035 / One-piece sealing ring​ ​ M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 min ​ 2.5 2.0 4.5 3.5 7.0 5.0 10.0 17.0 22.0 28.0 32.0 max ​ 6.5 6.0 10.0 8.0 13.0 11.0 17.0 25.0 33.0 38.0 44.0 ​ 15 19 19 24 24 29 29 42 53 60 65 ​ 21 25 25 29 29 38 38 36 48 48 49 ​ 12 15 15 15 15 15 15 15 15 15 16 Part. no. 1555.12.1.06 1555.17.1.06 1555.17.1.10 1555.20.1.08 1555.20.1.13 1555.25.1.11 1555.25.1.17 1555.32.1.25 1555.40.1.33 1555.50.1.38 1555.63.1.44 ​ 100 50 50 50 50 25 25 20 10 5 5 ​ SYNTEC Dark grey RAL 7001 / One-piece sealing ring​ ​ M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 min 2.5 2.0 4.5 3.5 7.0 5.0 10.0 17.0 22.0 28.0 32.0 ​ max 6.5 6.0 10.0 8.0 13.0 11.0 17.0 25.0 33.0 38.0 44.0 ​ ​ 15 19 19 24 24 29 29 42 53 60 65 ​ 21 25 25 29 29 38 38 36 48 48 49 ​ 12 15 15 15 15 15 15 15 15 15 16 Part. no. 1556.12.1.06 1556.17.1.06 1556.17.1.10 1556.20.1.08 1556.20.1.13 1556.25.1.11 1556.25.1.17 1556.32.1.25 1556.40.1.33 1556.50.1.38 1556.63.1.44 ​ 100 50 50 50 50 25 25 20 10 5 5 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 231 Synthetic Cable Glands Syntec® with Lamellar Technology long entry thread metric Material: Properties: Sealing ring: Tested acc. to: Temperature range: Protection class: Polyamide PA 6 halogen-free TPE or CR (Neoprene) EN 50262 -30°C / +100°C IP 68 ​ SYNTEC Black RAL 9005 / One-piece sealing ring​ ​ M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 232 min 2.5 2.0 4.5 3.5 7.0 5.0 10.0 17.0 22.0 28.0 32.0 ​ max 6.5 6.0 10.0 8.0 13.0 11.0 17.0 25.0 33.0 38.0 44.0 ​ ​ 15 19 19 24 24 29 29 42 53 60 65 ​ 21 25 25 29 29 38 38 36 48 48 49 ​ 12 15 15 15 15 15 15 15 15 15 16 Part. no. 1545.12.1.06 1545.17.1.06 1545.17.1.10 1545.20.1.08 1545.20.1.13 1545.25.1.11 1545.25.1.17 1545.32.1.25 1545.40.1.33 1545.50.1.38 1545.63.1.44 ​ 100 50 50 50 50 25 25 20 10 5 5 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Synthetic Cable Glands Syntec® with Lamellar Technology entry thread pg Material: Properties: Sealing ring: Temperature range: Protection class: Polyamide PA 6 halogen-free CR (neoprene) -30°C / +100°C IP 68 ​ SYNTEC Light grey RAL 7035 / One-piece sealing ring​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 7 9 11 11 13 13 16 16 21 21 29 36 42 48 ​ 2.5 3.0 2.0 4.0 3.0 5.5 5.0 8.5 6.5 11.0 17.0 22.0 28.0 32.0 max ​ 6.5 8.0 7.0 10.0 7.0 12.0 11.0 14.0 14.0 18.0 25.0 33.0 38.0 44.0 ​ 15 19 22 22 24 24 27 27 33 33 42 53 60 65 ​ 21 23 25 25 26 26 30 30 35 35 36 48 48 48 ​ 8 8 8 8 9 9 10 10 11 11 11 15 15 15 Part. no. 1555.07.06 1555.09.08 1555.11.07 1555.11.10 1555.13.07 1555.13.12 1555.16.11 1555.16.14 1555.21.14 1555.21.18 1555.29.25 1555.36.33 1555.42.38 1555.48.44 ​ 100 50 50 50 50 50 50 50 25 25 20 10 5 5 ​ SYNTEC Dark grey RAL 7001 / One-piece sealing ring​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg min 7 9 11 11 13 13 16 16 21 21 29 36 42 48 2.5 3.0 2.0 4.0 3.0 5.5 5.0 8.5 6.5 11.0 17.0 22.0 28.0 32.0 ​ max 6.5 8.0 7.0 10.0 7.0 12.0 11.0 14.0 14.0 18.0 25.0 33.0 38.0 44.0 ​ ​ 15 19 22 22 24 24 27 27 33 33 42 53 60 65 ​ 21 23 25 25 26 26 30 30 35 35 36 48 48 48 ​ 8 8 8 8 9 9 10 10 11 11 11 15 15 15 Part. no. 1556.07.06 1556.09.08 1556.11.07 1556.11.10 1556.13.07 1556.13.12 1556.16.11 1556.16.14 1556.21.14 1556.21.18 1556.29.25 1556.36.33 1556.42.38 1556.48.44 ​ 100 50 50 50 50 50 50 50 25 25 20 10 5 5 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 233 Synthetic Cable Glands Syntec® with Lamellar Technology entry thread pg Material: Properties: Sealing ring: Temperature range: Protection class: Polyamide PA 6 halogen-free CR (neoprene) -30°C / +100°C IP 68 ​ SYNTEC Black RAL 9005 / One-piece sealing ring​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg 234 min 7 9 11 11 13 13 16 16 21 21 29 36 42 48 2.5 3.0 2.0 4.0 3.0 5.5 5.0 8.5 6.5 11.0 17.0 22.0 28.0 32.0 ​ max 6.5 8.0 7.0 10.0 7.0 12.0 11.0 14.0 14.0 18.0 25.0 33.0 38.0 44.0 ​ ​ 15 19 22 22 24 24 27 27 33 33 42 53 60 65 ​ 21 23 25 25 26 26 30 30 35 35 36 48 48 48 ​ 8 8 8 8 9 9 10 10 11 11 11 15 15 15 Part. no. 1545.07.06 1545.09.08 1545.11.07 1545.11.10 1545.13.07 1545.13.12 1545.16.11 1545.16.14 1545.21.14 1545.21.18 1545.29.25 1545.36.33 1545.42.38 1545.48.44 ​ 100 50 50 50 50 50 50 50 25 25 20 10 5 5 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Synthetic Cable Glands Syntec® with Lamellar Technology entry thread npt Material: Properties: Sealing ring: Temperature range: Protection class: Protection type addition: Polyamide PA 6 halogen-free CR (neoprene) -30°C / +100°C IP 54 IP 68, if the entry thread is sealed ​ SYNTEC Light grey RAL 7035 / One-piece sealing ring​ ​ NPT NPT NPT NPT NPT NPT min 3/8" 1/2" 1/2" 3/4" 3/4" 1" ​ 3.0 3.0 5.5 6.5 11.0 17.0 max ​ 8.0 7.0 12.0 14.0 18.0 22.0 ​ 19/22 24 24 33 33 42 ​ 23 26 26 35 35 36 ​ 15 15 15 15 15 15 Part. no. 1555.N0375.08 1555.N0500.07 1555.N0500.12 1555.N0750.14 1555.N0750.18 1555.N1000.22 ​​ 50 50 50 25 25 20 ​ SYNTEC Dark grey RAL 7001 / One-piece sealing ring​ ​ NPT NPT NPT NPT NPT NPT min 3/8" 1/2" 1/2" 3/4" 3/4" 1" ​ 3.0 3.0 5.5 6.5 11.0 17.0 max ​ 8.0 7.0 12.0 14.0 18.0 22.0 ​ 19/22 24 24 33 33 42 ​ 23 26 26 35 35 36 ​ 15 15 15 15 15 15 Part. no. 1556.N0375.08 1556.N0500.07 1556.N0500.12 1556.N0750.14 1556.N0750.18 1556.N1000.22 ​​ 50 50 50 25 25 20 ​ SYNTEC Black RAL 9005 / One-piece sealing ring​ ​ NPT NPT NPT NPT NPT NPT min 3/8" 1/2" 1/2" 3/4" 3/4" 1" 3.0 3.0 5.5 6.5 11.0 17.0 ​ max 8.0 7.0 12.0 14.0 18.0 22.0 ​ ​ 19/22 24 24 33 33 42 ​ 23 26 26 35 35 36 ​ 15 15 15 15 15 15 Part. no. 1545.N0375.08 1545.N0500.07 1545.N0500.12 1545.N0750.14 1545.N0750.18 1545.N1000.22 ​​ 50 50 50 25 25 20 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 235 Synthetic Cable Glands Syntec® with Lamellar Technology & Antikink Nozzle short entry thread metric Material: Properties: Sealing ring: Tested acc. to: Temperature range: Protection class: Polyamide PA 6 halogen-free CR (neoprene) EN 50262 -30°C / +100°C IP 68 ​ SYNTEC Light grey RAL 7035 / One-piece sealing ring​ ​ M12x1.5 M16x1.5 M20x1.5 M20x1.5 min ​ 2.5 4.0 3.0 5.5 max ​ 6.5 8.0 7.0 12.0 ​ 15 19 24 24 ​ 54 64 88 88 ​ Part. no. 1576.12.06 1576.17.08 1576.20.07 1576.20.12 6 6 8 8 ​​ 50 50 50 50 ​ SYNTEC Dark grey RAL 7001 / One-piece sealing ring​ ​ M12x1.5 M16x1.5 M20x1.5 M20x1.5 min ​ 2.5 4.0 3.0 5.5 max ​ 6.5 8.0 7.0 12.0 ​ 15 19 24 24 ​ 54 64 88 88 ​ Part. no. 1577.12.06 1577.17.08 1577.20.07 1577.20.12 6 6 8 8 ​​ 50 50 50 50 ​ SYNTEC Black RAL 9005 / One-piece sealing ring​ ​ M12x1.5 M16x1.5 M20x1.5 M20x1.5 236 min 2.5 4.0 3.0 5.5 ​ max 6.5 8.0 8.0 12.0 ​ ​ 15 19 24 24 ​ 54 64 88 88 ​ 6 6 8 8 Part. no. 1546.12.06 1546.17.08 1546.20.07 1546.20.12 ​​ 50 50 50 50 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Synthetic Cable Glands Syntec® with Lamellar Technology & Antikink Nozzle long entry thread metric Material: Properties: Sealing ring: Tested acc. to: Temperature range: Protection class: Polyamide PA 6 halogen-free CR (neoprene) EN 50262 -30°C / +100°C IP 68 ​ SYNTEC Light grey RAL 7035 / One-piece sealing ring​ ​ M12x1.5 M16x1.5 M20x1.5 M20x1.5 min ​ 2.5 4.0 3.0 5.5 max ​ 6.5 8.0 7.0 12.0 ​ 15 19 24 24 ​ 54 64 88 88 ​ 12 12 13 13 Part. no. 1576.12.1.06 1576.17.1.08 1576.20.1.07 1576.20.1.12 ​​ 50 50 50 50 ​ SYNTEC Dark grey RAL 7001 / One-piece sealing ring​ ​ M12x1.5 M16x1.5 M20x1.5 M20x1.5 min ​ 2.5 4.0 3.0 5.5 max ​ 6.5 8.0 7.0 12.0 ​ 15 19 24 24 ​ 54 64 88 88 ​ 12 12 13 13 Part. no. 1577.12.1.06 1577.17.1.08 1577.20.1.07 1577.20.1.12 ​​ 50 50 50 50 ​ SYNTEC Black RAL 9005 / One-piece sealing ring​ ​ M12x1.5 M16x1.5 M20x1.5 M20x1.5 min 2.5 4.0 3.0 5.5 ​ max 6.5 8.0 7.0 12.0 ​ ​ 15 19 24 24 ​ 54 64 88 88 ​ 12 12 13 13 Part. no. 1546.12.1.06 1546.17.1.08 1546.20.1.07 1546.20.1.12 ​​ 50 50 50 50 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 237 Synthetic Cable Glands Syntec® with Lamellar Technology & Antikink Nozzle entry thread pg Material: Properties: Sealing ring: Temperature range: Protection class: Polyamide PA 6 halogen-free CR (neoprene) -30°C / +100°C IP 68 ​ SYNTEC Light grey RAL 7035 / One-piece sealing ring​ ​ Pg Pg Pg Pg Pg Pg Pg Pg min 7 9 11 11 13 13 16 16 ​ 2.5 3.0 2.0 4.0 3.0 5.5 5.0 8.5 max ​ 6.5 8.0 7.0 10.0 7.0 12.0 11.0 14.0 ​ 15 19 22 22 24 24 27 27 ​ 54 64 77 77 88 88 102 102 ​ 8 8 8 8 9 9 10 10 Part. no. 1576.07.06 1576.09.08 1576.11.07 1576.11.10 1576.13.07 1576.13.12 1576.16.11 1576.16.14 ​​ 50 50 50 50 50 50 50 50 ​ SYNTEC Dark grey RAL 7001 / One-piece sealing ring​ ​ Pg Pg Pg Pg Pg Pg Pg Pg min 7 9 11 11 13 13 16 16 ​ 2.5 3.0 2.0 4.0 3.0 5.5 5.0 8.5 max ​ 6.5 8.0 7.0 10.0 7.0 12.0 11.0 14.0 ​ 15 19 22 22 24 24 27 27 ​ 54 64 77 77 88 88 102 102 ​ 8 8 8 8 9 9 10 10 Part. no. 1577.07.06 1577.09.08 1577.11.07 1577.11.10 1577.13.07 1577.13.12 1577.16.11 1577.16.14 ​​ 50 50 50 50 50 50 50 50 ​ SYNTEC Black RAL 9005 / One-piece sealing ring​ ​ Pg Pg Pg Pg Pg Pg Pg Pg 238 min 7 9 11 11 13 13 16 16 2.5 3.0 2.0 4.0 3.0 5.5 5.0 8.5 ​ max 6.5 8.0 7.0 10.0 7.0 12.0 11.0 14.0 ​ ​ 15 19 22 22 24 24 27 27 ​ 54 64 77 77 88 88 102 102 ​ 8 8 8 8 9 9 10 10 Part. no. 1546.07.06 1546.09.08 1546.11.07 1546.11.10 1546.13.07 1546.13.12 1546.16.11 1546.16.14 ​​ 50 50 50 50 50 50 50 50 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Synthetic Cable Glands Syntec® with Lamellar Technology & Antikink Nozzle entry thread npt Material: Properties: Sealing ring: Temperature range: Protection class: Protection type addition: Polyamide PA 6 halogen-free CR (neoprene) -30°C / +100°C IP 54 IP 68, if the entry thread is sealed ​ SYNTEC Light grey RAL 7035 / One-piece sealing ring​ ​ NPT 3/8" NPT 1/2" NPT 1/2" min ​ 3.0 3.0 5.5 max ​ 8.0 7.0 12.0 ​ 19/22 24 24 ​ 64 88 88 ​ 15 15 15 Part. no. 1576.N0375.08 1576.N0500.07 1576.N0500.12 ​​ 50 50 50 ​ SYNTEC Dark grey RAL 7001 / One-piece sealing ring​ ​ NPT 3/8" NPT 1/2" NPT 1/2" min ​ 3.0 3.0 5.5 max ​ 8.0 7.0 12.0 ​ 19/22 24 24 ​ 64 88 88 ​ 15 15 15 Part. no. 1577.N0375.08 1577.N0500.07 1577.N0500.12 ​​ 50 50 50 ​ SYNTEC Black RAL 9005 / One-piece sealing ring​ ​ NPT 3/8" NPT 1/2" NPT 1/2" min 3.0 3.0 5.5 ​ max 8.0 7.0 12.0 ​ ​ 19/22 24 24 ​ 64 88 88 ​ 15 15 15 Part. no. 1546.N0375.08 1546.N0500.07 1546.N0500.12 ​​ 50 50 50 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 239 Synthetic Cable Glands Elbow 90° entry thread metric Material: Seal: Temperature range: Protection class: Polyamide PA 6 PVC / TPE -20°C / +100°C IP 68 ​ Light grey RAL 7035 / One-piece sealing insert ​ M16x1.5 M20x1.5 M20x1.5 M25x1.5 ​ min 6.5 7.0 9.0 11.5 ​ max 9.5 10.5 13.0 15.5 ​ 19 24 24 27 ​ 22 28 28 32 ​ 38 46 46 52 ​ 8 9 9 10 ​ Part. no. 5215.17.95 5215.20.105 5215.20.13 5215.25.155 ​​ 25 25 25 25 ​ Black RAL 9005 / One-piece sealing insert ​ M16x1.5 M20x1.5 M20x1.5 M25x1.5 ​ min 6.5 7.0 9.0 11.5 ​ max 9.5 10.5 13.0 15.5 ​ 19 24 24 27 ​ 22 28 28 32 ​ 38 46 46 52 ​ 8 9 9 10 ​ Part. no. 5215.17.40.95 5215.20.40.105 5215.20.40.13 5215.25.40.155 ​​ 25 25 25 25 entry thread pg ​ Light grey RAL 7035 / One-piece sealing insert ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg 240 min 9 9 11 11 11 13 13 13 16 16 16 16 4.5 6.5 7.0 4.0 6.5 7.0 9.0 6.5 7.0 9.0 11.5 6.5 ​ max 6.5 9.5 10.5 6.5 9.5 10.5 13.0 9.5 10.5 13.0 15.5 9.5 ​ ​ 19 19 22 22 22 24 24 24 27 27 27 27 ​ 22 22 25 25 25 28 28 32 32 32 32 32 ​ 38 38 42 42 42 46 46 46 52 52 52 52 ​ 8 8 9 9 9 9 9 9 10 10 10 10 ​ Part. no. 5215.09.65 5215.09.95 5215.11.105 5215.11.65 5215.11.95 5215.13.105 5215.13.13 5215.13.95 5215.16.105 5215.16.13 5215.16.155 5215.16.95 ​​ 25 25 25 25 25 25 25 25 25 25 25 25 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Synthetic Flanged Elbow 90° entry thread metric Material: Seal: Temperature range: Protection class: Properties: Polyamide NBR -40°C / +110°C IP 65 The flanged elbow can be opened to insert the cables and therefore permits an effortless installation ​ Grey ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 ​ ​ 49 49 69 90 100 116 ​ 47 47 65 78 94 101 ​ 35 35 44 55 66 76 ​ 22 22 30 40 48 63 ​ 27 27 31 65 68 85 ​ 29 29 42 65 80 88 ​ 37 37 52 65 80 88 Part. no. 5500.20.17 5500.20.20 5500.20.25 5500.20.32 5500.20.40 5500.20.50 ​​ 10 10 10 10 5 5 ​ Black ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 ​ ​ 49 49 69 90 100 116 ​ 47 47 65 78 94 101 ​ 35 35 44 55 66 76 ​ 22 22 30 40 48 63 ​ 27 27 31 65 68 85 ​ 29 29 42 65 80 88 ​ 37 37 52 65 80 88 Part. no. 5500.40.17 5500.40.20 5500.40.25 5500.40.32 5500.40.40 5500.40.50 ​​ 10 10 10 10 5 5 entry thread pg ​ Grey ​ Pg Pg Pg Pg Pg Pg ​ ​ 11 16 21 29 36 48 49 49 69 90 100 116 ​ 47 47 65 78 94 101 ​ 35 35 44 55 66 76 ​ 22 22 30 40 48 63 ​ 27 27 31 65 68 85 ​ 29 29 42 65 80 88 ​ 37 37 52 65 80 88 Part. no. 5520.11 5520.16 5520.21 5520.29 5520.36 5520.48.48 ​​ 10 10 10 10 5 5 ​ Black ​ Pg Pg Pg Pg Pg Pg ​ ​ 11 16 21 29 36 48 49 49 69 90 100 116 ​ 47 47 65 78 94 101 ​ 35 35 44 55 66 76 ​ 22 22 30 40 48 63 ​ 27 27 31 65 68 85 ​ 29 29 42 65 80 88 ​ 37 37 52 65 80 88 Part. no. 5540.11 5540.16 5540.21 5540.29 5540.36 5540.48.48 ​​ 10 10 10 10 5 5 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 241 Lock Nut Nickel-Plated Brass entry thread metric Material: Execution: Temperature range: Nickel-plated brass Hexagonal design -40°C / +200°C ​ metric thread ​ M6x0.75 M6x1.0 M8x1.0 M8x1.25 M10x1.0 M10x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 M75x1.5 M80x2.0 M85x2.0 M95x2.0 M100x3.0 M105x3.0 M115x3.0 ​ ​ 9 9 11 11 13 13 15 19 24 30 36 46 55 70 80 95 95 110 115 120 125 ​ 2.8 2.8 2.8 2.8 2.8 2.8 3.0 3.0 3.5 4.0 4.0 5.0 5.5 6.0 6.0 8 8.0 9.0 9.0 9.0 10.0 ​   1   1   1                               - Part. no. 8000.06.1 8000.06 8000.08.1 8000.08 8000.10.1 8000.10 8000.12 8000.17 8000.20 8000.25 8000.32 8000.40 8000.50 8000.63 8000.75 8000.080 8000.085 8000.095 8000.100 8000.105 8000.115 ​ 50 50 50 50 50 50 100 100 100 50 25 25 10 10 10 5 5 5 1 1 1 1 = Metric coarse-pitch thread entry thread pg ​ pg thread ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg 242 ​ ​ 7 9 11 13 16 21 29 36 42 48 15 18 21 23 26 32 41 51 60 64 ​ 3.0 3.0 3.0 3.0 3.0 3.5 4.0 5.0 5.0 5.5 Part. no. 8007 8009 8011 8013 8016 8021 8029 8036 8042 8048.48 ​​ 50 50 50 50 50 25 10 10 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Lock Nut Nickel-Plated Brass gas-pipe thread metric Material: Execution: Temperature range: Nickel-plated brass Hexagonal design -40°C / +200°C ​ Gas-pipe thread ​ G 3/8" G 1/2" G 3/8" G 3/4" G 1" G 1 1/2" G 1 1/4" G 2" G 2 1/2" G 3" ​ ​ ​ 3.0 3.0 3.0 3.5 4.5 5.0 5.0 5.5 12.0 12.0 19 24 26 30 38 51 46 64 Ø90 Ø105 ​ 1 1 Part. no. 803/8G 801/2G 805/8G 803/4G 801G 8011/2G 8011/4G 8048 8050 8051 ​​ 10 10 10 10 10 10 10 10 50 50 1 = Round form, zinc coated steel entry thread metric ​ Thick-walled version ​ M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 ​ 15 19 24 30 36 46 ​ 5.0 5.0 5.5 5.5 6.0 7.0 ​ Part. no. 8300.12 8300.17 8300.20 8300.25 8300.32 8300.40 ​​ 50 50 50 50 50 50 entry thread pg ​ Thick-walled version ​ Pg Pg Pg Pg Pg Pg Pg ​ 7 9 11 13 16 21 29 15 18 21 24 26 32 41 ​ 5.0 5.0 5.0 5.5 5.5 6.0 7.0 ​ Part. no. 8300.07 8300.09 8300.11 8300.13 8300.16 8300.21 8300.29 ​​ 50 50 50 50 50 50 50 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 243 Lock Nut Nickel-Plated Brass with Recess for O-Ring entry thread metric Material: Execution: O-ring: Temperature range: Nickel-plated brass Hexagonal design To be ordered separately -40°C / +200°C ​ Thick-walled version without O-Ring​ ​ M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 244 ​ 15 19 24 30 36 46 55 70 ​ 5.0 5.0 5.5 5.5 6.0 7.0 7.5 8.0 ​ 1007.00.08 1016.00.15.08 1016.00.08 1013.00.22.08 1021.00.30.08 1029.00.39.08 1036.00.49.08 1048.00.62.08 ​ Part. no. 8300.12.1 8300.17.1 8300.20.1 8300.25.1 8300.32.1 8300.40.1 8300.50.1 8300.63.1 ​​ 50 50 50 50 50 50 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Stainless Steel Lock Nuts stainless steel a2 Material: CrNi stainless steel A2 (DIN EN 1.4305 / AISI 303) Hexagonal design -40°C / +300°C Execution: Temperature range: ​ Metric thread ​ M8x1.25 M10x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 ​ 11 13 17 19 24 30 36 46 55 70 ​ ​ 2.8 2.8 3.0 3.0 3.5 3.5 4.5 4.5 5.5 6.0 Part. no. ​ 8008.96 8010.96 8012.96 8017.96 8020.96 8025.96 8032.96 8040.96 8050.96 8063.96 1 1                 - ​​ 50 50 50 50 50 25 25 10 10 5 1 = Metric coarse-pitch thread ​ Pg thread ​ Pg Pg Pg Pg Pg Pg Pg Pg ​ ​ 7 9 11 13 16 21 29 36 17 19 22 24 27 32 41 51 Part. no. ​ 3.5 3.5 3.5 4.0 4.0 4.5 5.5 6.0 8007.96 8009.96 8011.96 8013.96 8016.96 8021.96 8029.96 8036.96 ​​ 50 50 50 50 50 25 10 10 stainless steel and acid resistant a4 Material: Stainless and acid resistant steel A4 CrNiMo (DIN EN 1.4435 / AISI 316L) Hexagonal design -40°C / +300°C Execution: Temperature range: ​ metric thread ​ M8x1.25 M10x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 ​ 11 13 17 19 24 30 36 46 55 70 ​ ​ 2.8 2.8 3.0 3.0 3.5 3.5 4.5 4.5 5.5 6.0 ​ 1 1                 - Part. no. 8008.98 8010.98 8012.98 8017.98 8020.98 8025.98 8032.98 8040.98 8050.98 8063.98 ​​ 50 50 50 50 50 25 25 10 10 5 1 = Metric coarse-pitch thread American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 245 Synthetic Lock Nuts entry thread metric Material: Execution: Temperature range: Polyamide glass fiber reinforced Hexagonal design -40°C / +100°C light grey RAL 7035​​ ​ M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 ​ 17 22 26 32 41 50 60 ​ 5.5 5.5 6.5 7.0 7.0 7.0 8.5 Part. no. 8212 8217 8220 8225 8232 8240 8250 ​ 100 100 100 100 100 50 10 ​ black RAL 9005​​ ​ M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 ​ 17 22 26 32 41 50 60 ​ 5.5 5.5 6.5 7.0 7.0 7.0 8.5 ​ Part. no. 8212.40 8217.40 8220.40 8225.40 8232.40 8240.40 8250.40 ​ 100 100 100 100 100 50 10 entry thread pg ​ light grey RAL 7035​​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg ​ 7 9 11 13 16 21 29 36 42 48 19 22 24 27 30 36 46 60 65 70 ​ 5.0 6.0 6.0 6.0 6.0 7.0 7.0 8.0 8.0 8.0 ​ Part. no. 8207 8209 8211 8213 8216 8221 8229 8236 8242 8248.48 ​ 100 100 100 100 100 100 50 25 25 25 ​ black RAL 9005​​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg 246 ​ 7 9 11 13 16 21 29 36 42 48 19 22 24 27 30 36 46 60 65 70 ​ 5.0 6.0 6.0 6.0 6.0 7.0 7.0 8.0 8.0 8.0 ​ Part. no. 8207.40 8209.40 8211.40 8213.40 8216.40 8221.40 8229.40 8236.40 8242.40 8248.48.40 ​ 100 100 100 100 100 100 50 25 25 25 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Synthetic Lock Nuts with Flange entry thread metric Material: Execution: Temperature range: Polyamide PA 6 Hexagonal design with flange -30°C / +100°C Light grey RAL 7035​​ ​ M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 ​ 17 22 27 33 42 48 59 73 ​ 5.0 5.0 6.0 6.7 7.9 8.4 9.9 11.0 Part. no. ​ 5.0 5.0 6.0 6.7 7.9 8.4 9.9 11.0 Part. no. ​ Black RAL 9005​​ ​ M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 ​ 17 22 27 33 42 48 59 73 8255.12 8255.17 8255.20 8255.25 8255.32 8255.40 8255.50 8255.63 8245.12 8245.17 8245.20 8245.25 8245.32 8245.40 8245.50 8245.63 ​ 100 100 100 100 50 50 10 10 ​ ​ 100 100 100 100 50 50 10 10 entry thread pg ​ Light grey RAL 7035​​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg ​ 7 9 11 13 16 21 29 36 42 48 19 21 24 27 30 36 46 59 65 69 ​ 5.0 5.0 5.0 6.0 6.0 7.0 8.0 8.0 8.0 8.0 ​ Part. no. 8255.07 8255.09 8255.11 8255.13 8255.16 8255.21 8255.29 8255.36 8255.42 8255.48 ​ 100 100 100 100 100 50 50 25 10 10 ​ Black RAL 9005​​ ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg ​ 7 9 11 13 16 21 29 36 42 48 19 21 24 27 30 36 46 59 65 69 ​ 5.0 5.0 5.0 6.0 6.0 7.0 8.0 8.0 8.0 8.0 ​ Part. no. 8245.07 8245.09 8245.11 8245.13 8245.16 8245.21 8245.29 8245.36 8245.42 8245.48 ​ 100 100 100 100 100 50 50 25 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 247 Reduction & Enlarging Fittings Nickel-Plated Brass hexagonal reduction fittings Material: O-ring: Temperature range: Protection class: Nickel-plated brass NBR -40°C / +100°C IP 68 ​ Outer thread metric / Inner thread metric / with O-ring ​ M 8x1.25 M10x1.5 M10x1.5 M12x1.5 M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 M40x1.5 M40x1.5 M50x1.5 M50x1.5 M63x1.5 M63x1.5 M75x1.5 M75x1.5 ​ M 6x1.0 M 6x1.0 M 8x1.25 M 8x1.25 M10x1.5 M10x1.5 M12x1.5 M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 M40x1.5 M40x1.5 M50x1.5 M50x1.5 M63x1.5 ​ 11 13 13 15 15 18 18 24 24 30 30 36 36 46 46 55 55 70 70 80 80 ​ 8.0 3.0 8.0 3.0 8.0 3.0 3.0 3.0 3.0 3.5 3.5 4.0 4.0 4.5 4.5 5.0 5.0 5.5 5.5 6.0 6.0 ​ 5 5 5 5 5 5 5 6 6 7 7 8 8 8 8 9 9 10 10 11 11 ​ 1 1 1 1 1 1                               - ​ Part. no. 3500.08.06 3500.10.06 3500.10.08 3500.12.08 3500.12.10 3500.17.10 3500.17.12 3500.20.12 3500.20.17 3500.25.17 3500.25.20 3500.32.20 3500.32.25 3500.40.25 3500.40.32 3500.50.32 3500.50.40 3500.63.40 3500.63.50 3500.75.50 3500.75.63 ​​ 50 50 50 50 50 50 50 50 50 25 25 20 20 10 10 10 10 5 5 5 5 1 = Metric coarse-pitch thread 248 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Reduction & Enlarging Fittings Nickel-Plated Brass round, knurled reduction fittings Material: Temperature range: Protection class: Protection type addition: Nickel-plated brass -40°C / +200°C IP 54 IP 68, if the entry thread is sealed ​ Outer thread metric / Inner thread metric / without O-Ring ​ M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 M40x1.5 M40x1.5 M50x1.5 M50x1.5 M63x1.5 M63x1.5 ​ M12x1.5 M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 M40x1.5 M40x1.5 M50x1.5 ​ 18 22 22 27 27 34 34 42 42 52 52 65 65 ​ 3 3 3 3 3 4 4 4.5 4.5 4.5 4.5 5 5 ​ 7 8 8 8 8 9 9 9 9 10 10 11 11 ​ Part. no. 3545.17.12 3545.20.12 3545.20.17 3545.25.17 3545.25.20 3545.32.20 3545.32.25 3545.40.25 3545.40.32 3545.50.32 3545.50.40 3545.63.40 3545.63.50 ​ 100 100 100 50 50 50 50 50 25 25 10 10 10 hexagonal Reduction Fittings Material: O-ring: Temperature range: Protection class: Nickel-plated brass NBR -40°C / +100°C IP 68 Outer thread metric / Inner thread metric / with O-ring ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg 9 11 11 13 13 13 16 16 16 21 21 21 29 29 29 36 36 42 42 48 ​ Pg 7 Pg 7 Pg 9 Pg 7 Pg 9 Pg 11 Pg 9 Pg 11 Pg 13 Pg 11 Pg 13 Pg 16 Pg 13 Pg 16 Pg 21 Pg 21 Pg 29 Pg 29 Pg 36 Pg 36 ​ 18 20 22 24 24 24 24 24 27 32 32 32 38 38 38 50 50 60 60 65 ​ 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.5 3.5 3.5 4.0 4.0 4.0 4.5 4.5 4.0 4.0 4.0 ​ 6.5 6.5 7.0 7.0 7.0 7.0 7.0 7.0 7.0 7.5 7.5 7.5 8.0 8.0 8.0 8.5 8.5 11.0 11.0 11.0 Part. no. 3509.07 3511.07 3511.09 3513.07 3513.09 3513.11 3516.09 3516.11 3516.13 3521.11 3521.13 3521.16 3529.13 3529.16 3529.21 3536.21 3536.29 3542.29 3542.36 3548.48.36 ​​ 50 50 50 50 50 50 50 50 50 25 25 25 10 10 10 10 10 10 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 249 Reduction & Enlarging Fittings Nickel-Plated Brass hexagonal enlarging fittings Material: O-ring: Temperature range: Protection class: Nickel-plated brass NBR -40°C / +100°C IP 68 Outer thread metric / Inner thread metric / with O-ring ​ M 6x1.0 M 6x1.0 M 8x1.25 M 8x1.25 M10x1.5 M10x1.5 M12x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 ​ M 8x1.25 M10x1.5 M10x1.5 M12x1.5 M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 M75x1.5 ​ 11 13 13 15 15 18 18 24 24 30 36 46 55 70 80 ​ 8.5 8.5 9 9 9 9 9 10 10 11.5 14 14 16 17 18 ​ 5 5 5 5 5 5 5 5 5 6 7 8 8 9 10 ​ 1 1 1 1 1 1                   - Part. no. 3600.06.08 3600.06.10 3600.08.10 3600.08.12 3600.10.12 3600.10.17 3600.12.17 3600.12.20 3600.17.20 3600.20.25 3600.25.32 3600.32.40 3600.40.50 3600.50.63 3600.63.75 ​​ 50 50 50 50 50 50 50 50 50 25 25 25 10 10 10 1 = Metric coarse-pitch thread round execution enlarging fittings Material: Temperature range: Protection class: Protection type addition: Nickel-plated brass -40°C / +200°C IP 54 IP 68, if the entry thread is sealed ​ Outer thread metric / Inner thread metric / without O-ring ​ M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 250 ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 ​ 19 22 27 34 42 53 66 ​ 9.5 10.5 11 12 12 14 19 ​ 6.5 7 8 8 9 9 10 ​ Part. no. 3645.12.17 3645.17.20 3645.20.25 3645.25.32 3645.32.40 3645.40.50 3645.50.63 ​ 100 100 100 50 50 25 25 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Reduction & Enlarging Fittings Nickel-Plated Brass hexagonal enlarging fittings Material: O-ring: Temperature range: Protection class: Nickel-plated brass NBR -40°C / +100°C IP 68 ​ Outer thread metric / Inner thread metric / with O-ring ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg 7 9 9 11 11 11 13 16 16 21 29 36 36 ​ Pg 9 Pg 11 Pg 13 Pg 13 Pg 16 Pg 21 Pg 16 Pg 21 Pg 29 Pg 29 Pg 36 Pg 42 Pg 48 ​ 18 22 24 24 24 32 24 32 40 40 50 60 64 ​ 13 15 15 15 15 16 15 16 16 16 18 19 20 ​ 8 8 8 8 8 8 8 8 8 8 10 12 12 ​ Part. no. 3607.09.08 3609.11.08 3609.13.08 3611.13.08 3611.16.08 3611.21.08 3613.16.08 3616.21.08 3616.29.08 3621.29.08 3629.36.08 3636.42.08 3636.48.48.08 ​​ 50 50 50 50 50 50 50 25 25 25 20 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 251 Adapter Nickel-Plated Brass hexagonal Material: O-ring: Temperature range: Protection class: Nickel-plated brass NBR -40°C / +100°C IP 68 ​ Outer thread metric / Inner thread pg / with O-ring ​ M16x1.5 M20x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M25x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 ​ Pg 7 Pg 7 Pg 9 Pg 11 Pg 9 Pg 11 Pg 13 Pg 16 Pg 21 Pg 29 Pg 29 Pg 36 ​ 20 24 24 24 30 30 30 30 38 45 55 70 ​ 3.0 3.0 3.0 13.0 3.5 3.5 3.8 15.0 16.0 16.0 4.0 5.5 ​ Part. no. ​ 3500.17.07 3500.20.07 3500.20.09 3500.20.11 3500.25.09 3500.25.11 3500.25.13 3500.25.16 3500.32.21 3500.40.29 3500.50.29 3500.63.36 7 7 7 7 8 8 8 8 8 8 10 11 ​​ 50 50 50 50 50 50 50 25 25 10 10 10 ​ Outer thread metric / Inner thread pg / with O-ring ​ M10x1.5 M10x1.5 M12x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M50x1.5 ​ Pg 7 Pg 9 Pg 9 Pg 11 Pg 13 Pg 16 Pg 21 Pg 29 Pg 36 Pg 42 Pg 48 ​ 16 18 18 22 24 24 32 40 50 60 64 ​ 12 12 12 14 15 15 16 16 18 19 20 ​ 6 6 7 7 7 7 8 8 8 10 10 ​ 1 1                   - ​ Part. no. 3600.10.07 3600.10.09 3600.12.09 3600.17.11 3600.20.13 3600.20.16 3600.25.21 3600.32.29 3600.40.36 3600.50.42 3600.50.48 ​​ 50 50 50 50 50 50 25 25 20 10 10 1 = Metric coarse-pitch thread 252 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Adapter Nickel-Plated Brass hexagonal Material: O-ring: Temperature range: Protection class: Nickel-plated brass NBR -40°C / +100°C IP 68 ​ Outer thread pg / Inner thread metric / with O-ring ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg 7 7 7 9 9 9 9 11 11 11 11 11 13 13 16 16 16 21 21 21 29 29 36 36 42 42 42 48 48 ​ M 6x1.0 M 8x1.25 M10x1.5 M 6x1.0 M 8x1.25 M10x1.5 M12x1.5 M 6x1.0 M 8x1.25 M10x1.5 M12x1.5 M16x1.5 M12x1.5 M16x1.5 M12x1.5 M16x1.5 M20x1.5 M16x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 M40x1.5 M32x1.5 M40x1.5 M50x1.5 M40x1.5 M50x1.5 ​ 15 15 15 18 18 18 18 21 21 21 21 21 24 24 24 24 24 30 30 30 38 38 50 50 55 55 55 65 65 ​ 3.0 3.0 7.0 3.0 3.0 3.0 8.0 3.0 3.0 3.0 3.0 8.0 3.0 3.0 3.0 3.0 10.5 3.5 3.5 10.5 4.0 13.0 4.5 4.5 5.0 5.0 15.0 5.5 5.5 ​ 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 7.5 7.5 7.5 8 8 8 8 10 10 10 11 11 ​ 1 1 1 1 1 1   1 1 1                                       - ​ Part. no. 3500.07.06 3500.07.08 3500.07.10 3500.09.06 3500.09.08 3500.09.10 3500.09.12 3500.11.06 3500.11.08 3500.11.10 3500.11.12 3500.11.17 3500.13.12 3500.13.17 3500.16.12 3500.16.17 3500.16.20 3500.21.17 3500.21.20 3500.21.25 3500.29.25 3500.29.32 3500.36.32 3500.36.40 3500.42.32 3500.42.40 3500.42.50 3500.48.40 3500.48.50 ​​ 50 50 50 50 50 50 50 50 50 50 50 50 50 50 25 25 25 25 25 25 20 20 10 10 10 10 10 5 5 1 = Metric coarse-pitch thread American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 253 Adapter Nickel-Plated Brass hexagonal Material: O-ring: Temperature range: Protection class: Nickel-plated brass NBR -40°C / +100°C IP 68 ​ Outer thread Pg / Inner thread metric / with O-ring ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg 7 7 9 9 11 11 13 13 16 16 21 21 29 29 36 36 42 42 48 48 ​ M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 M40x1.5 M40x1.5 M50x1.5 M50x1.5 M63x1.5 M63x1.5 M75x1.5 M63x1.5 M75x1.5 ​ ​ 9.0 9.0 9.5 10.5 10.5 11.5 10.5 11.5 11.5 13.5 14.0 14.0 14.0 16.0 16.0 17.0 17.0 18.0 17.0 18.0 15 18 18 24 24 30 24 30 30 36 36 46 46 55 55 70 70 80 70 80 ​ 6 6 6 6 6 6 6 6 6 6 7.5 7.5 8 8 8 8 10 10 11 11 ​ Part. no. 3600.07.12 3600.07.17 3600.09.17 3600.09.20 3600.11.20 3600.11.25 3600.13.20 3600.13.25 3600.16.25 3600.16.32 3600.21.32 3600.21.40 3600.29.40 3600.29.50 3600.36.50 3600.36.63 3600.42.63 3600.42.75 3600.48.63 3600.48.75 ​​ 50 50 50 50 50 25 50 25 25 25 25 20 20 10 10 10 10 10 10 10 round, knurled Material: Temperature range: Protection class: Protection type addition: Nickel-plated brass -40°C / +200°C IP 54 IP 68, if the entry thread is sealed Outer thread Pg / Inner thread metric / without O-ring ​ Pg Pg Pg Pg Pg Pg Pg 254 11 16 21 21 29 29 36 ​ M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 M40x1.5 ​ 20 24 30 30 39 39 50 ​ 10 11 3.5 11 4 4 4.5 ​ 6 6 7.5 7.5 8 8 8 Part. no. 3545.11.17 3545.16.20 3545.21.20 3545.21.25 3545.29.25 3545.29.32 3545.36.40 ​​ 50 50 50 50 25 25 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Adapter Nickel-Plated Brass round execution Material: Temperature range: Protection class: Protection type addition: Nickel-plated brass -40°C / +200°C IP 54 IP 68, if the entry thread is sealed ​ outer thread Pg / Inner thread metric / without O-Ring ​ Pg Pg Pg Pg Pg Pg Pg 7 9 11 13 16 21 29 ​ M12x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 ​ 14 19 22 22 27 34 42 ​ ​ 9 9.5 11 11 11 12 12 6 6 6 6 6 7.5 8 ​ Part. no. 3645.07.12 3645.09.17 3645.11.20 3645.13.20 3645.16.25 3645.21.32 3645.29.40 ​ 100 50 50 50 50 50 10 hexagonal Material: O-ring: Temperature range: Protection class: Nickel-plated brass NBR -40°C / +100°C IP 68 ​ outer thread Pg / Inner thread metric / with O-Ring ​ Pg Pg Pg Pg Pg 13 16 21 36 42 ​ G3/8" G1/2" G3/4" G 2" G 2" ​ 24 24 32 64 64 ​ ​ 3 14 14 20 20 7 10 12 12 15 ​ Part. no. 35133/8G 36161/2G.08 36213/4G.08 3636.48.08 3642.48.08 ​​ 50 50 25 10 10 ​ outer thread gas-pipe / Inner thread Pg / with O-ring ​ G3/8" G1/2" G3/4" G3/4" G3/4" G1" G1 1/4" G2" G2" ​ Pg 7 Pg 9 Pg 9 Pg 11 Pg 16 Pg 21 Pg 29 Pg 36 Pg 42 ​ 20 24 30 30 32 38 50 64 64 ​ 3 3 3.5 3.5 3.5 3.5 5 5 5 ​ 10 9.5 11 11 11 11 11 11 11 ​ Part. no. 353/8G.07 351/2G.09 353/4G.09 353/4G.11 353/4G.16 351G.21 3511/4G.29 352G.36 3548.42 ​​ 50 50 50 50 50 25 25 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 255 Adapter Nickel-Plated Brass hexagonal Material: O-ring: Temperature range: Protection class: Nickel-plated brass NBR -40°C / +100°C IP 68 ​ Outer thread gas-pipe / Inner thread Pg / with O-ring ​ G3/8" G1/2" G1/2" G1/2" G5/8" G3/4" G7/8" G1" G1 1/2" ​ Pg 11 Pg 11 Pg 13 Pg 16 Pg 16 Pg 21 Pg 29 Pg 29 Pg 36 ​ 20 24 24 24 24 32 41 41 54 Material: Temperature range: Protection class: ​ 12 12 12 12 12 15 15 15 22 ​ 10 10 10 10 10 12 12 11 12 ​ Part. no. 363/8G.11.08 361/2G.11.08 361/2G.13.08 361/2G.16.08 365/8G.16.08 363/4G.21.08 367/8G.29.08 361G.29.08 3611/2G.36.08 ​​ 50 50 50 50 50 25 25 25 10 Nickel-plated brass -40°C / +100°C IP 68, if the entry thread is sealed ​ Outer thread NPT / Inner thread Pg / without O-Ring ​ NPT1/2" NPT3/4" NPT3/4" NPT 1" 256 ​ Pg 9 Pg 11 Pg 13 Pg 16 ​ 22 30 30 36 ​ 4.5 4 4 6 ​ 20 20 20 26 ​ Part. no. 351/2NPT.09 353/4NPT.11 353/4NPT.13 351NPT.16 ​​ 50 10 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Adapter Nickel-Plated Brass hexagonal Material: O-ring: Temperature range: Protection class: Nickel-plated brass NBR -40°C / +100°C IP 68, if the entry thread is sealed ​ outer thread NPT / Inner thread Pg / without O-Ring ​ NPT1/2" NPT1/2" NPT1/2" NPT3/4" ​ Pg 11 Pg 13 Pg 16 Pg 21 ​ 24 24 34 32 ​ 12 14 20 14 ​ 20 20 20 20 ​ Part. no. 361/2NPT.11 361/2NPT.13 361/2NPT.16 363/4NPT.21 ​​ 50 50 50 25 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 257 Synthetic Reduction & Enlarging Fittings hexagonal reduction fittings Material: Temperature range: Protection class: Protection type addition: Polyamide PA 6 -30°C / +100°C IP 54 IP 68, if the entry thread is sealed ​ Outer thread metric / inner thread metric / light grey RAL 7035 ​ M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M25x1.5 M32x1.5 M32x1.5 M32x1.5 M32x1.5 M40x1.5 M40x1.5 M40x1.5 M40x1.5 M50x1.5 M50x1.5 M50x1.5 M50x1.5 M63x1.5 M63x1.5 M63x1.5 M63x1.5 ​ M12x1.5 M12x1.5 M16x1.5 M12x1.5 M16x1.5 M20x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 ​ 22 24 24 29 29 29 36 36 36 36 46 46 46 46 55 55 55 55 68 68 68 68 Material: Temperature range: Protection class: Protection type addition: ​ 4 4 4 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 ​ 8 8 8 8 8 8 10 10 10 10 10 10 10 10 12 12 12 12 12 12 12 12 ​ Part. no. 3455.17.12 3455.20.12 3455.20.17 3455.25.12 3455.25.17 3455.25.20 3455.32.12 3455.32.17 3455.32.20 3455.32.25 3455.40.17 3455.40.20 3455.40.25 3455.40.32 3455.50.20 3455.50.25 3455.50.32 3455.50.40 3455.63.25 3455.63.32 3455.63.40 3455.63.50 ​ 100 100 100 100 100 100 50 50 50 50 50 50 25 25 5 5 5 5 5 5 5 5 Polyamide glass fiber reinforced -20°C / +100°C IP 54 IP 68, if the entry thread is sealed ​ Outer thread Pg / inner thread Pg / light grey ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg 258 9 11 11 13 13 16 16 16 21 21 29 36 ​ Pg 7 Pg 7 Pg 9 Pg 9 Pg 11 Pg 9 Pg 11 Pg 13 Pg 13 Pg 16 Pg 21 Pg 29 ​ 19 22 22 24 24 27 27 27 32 32 41 50 ​ 12 3 15 3 15 5 5 17 5 5 6 6 ​ 8 8 8 9 9 9 9 10 11 11 12 14 ​ Part. no. 3409.07 3411.07 3411.09 3413.09 3413.11 3416.09 3416.11 3416.13 3421.13 3421.16 3429.21 3436.29 ​​ 50 50 50 50 50 50 50 50 25 25 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Synthetic Reduction & Enlarging Fittings round with hexagon enlarging fittings Material: Temperature range: Protection class: Protection type addition: Polyamide PA 6 -30°C / +100°C IP 54 IP 68, if the entry thread is sealed ​ Outer thread metric / Inner thread metric / Light grey RAL 7035 ​ M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 ​ M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 ​ 20 24 29 36 46 55 68 Material: Temperature range: Protection class: ​ 13 13 13 15 15 15 15 ​ 8 8 8 8 10 10 10 ​ Part. no. 3755.12.17 3755.17.20 3755.20.25 3755.25.32 3755.32.40 3755.40.50 3755.50.63 ​ 100 100 100 50 25 10 10 Polyamide glass fiber reinforced -20°C / +100°C IP 54, IP 68 if the thread is sealed ​ Outer thread Pg / Inner thread Pg / Light grey ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg 7 9 11 13 16 21 29 36 42 ​ Pg 9 Pg 11 Pg 13 Pg 16 Pg 21 Pg 29 Pg 36 Pg 42 Pg 48 ​ 19 22 24 27 32 41 55 60 65 ​ 18 19 21 23 26 33 39 46 39 ​ 7 7 8 9 9 10 12 14 16 ​ Part. no. 3707.09 3709.11 3711.13 3713.16 3716.21 3721.29 3729.36 3736.42 3742.48 ​​ 50 50 50 50 25 25 10 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 259 Synthetic Adapter round with hexagon Material: Temperature range: Protection class: Protection type addition: Polyamide glass fiber reinforced -20°C / +100°C IP 54 IP 68, if the entry thread is sealed ​ Outer thread metric / Inner thread Pg / Light grey ​ M12x1.5 M20x1.5 M20x1.5 M25x1.5 M32x1.5 M50x1.5 ​ Pg 9 Pg 13 Pg 16 Pg 21 Pg 29 Pg 42 ​ 19 24 27 33 42 60 ​ 13 15 17 20 22 28 ​ 11 11 11 11 11 11 ​ Part. no. 3712.09 3720.13 3720.16 3725.21 3732.29 3750.42 ​​ 50 50 50 25 25 10 hexagonal ​ Outer thread metric / Inner thread Pg / Light grey ​ M16x1.5 M20x1.5 M25x1.5 M40x1.5 M50x1.5 M63x1.5 260 ​ Pg 9 Pg 11 Pg 16 Pg 29 Pg 36 Pg 48 ​ 19 22 27 42 53 65 ​ 14 16 18 23 26 29 ​ 11 11 11 11 11 11 ​ Part. no. 3417.09 3420.11 3425.16 3440.29 3450.36 3463.48 ​​ 50 50 50 25 10 5 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Synthetic Adapter round with hexagon Material: Temperature range: Protection class: Protection type addition: Polyamide PA 6 -30°C / +100°C IP 54 IP 68, if the entry thread is sealed ​ Outer thread Pg / Inner thread metric / Light grey RAL 7035 ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg 7 7 9 9 11 13 16 21 29 42 48 ​ M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 ​ 15 20 20 24 24 30 30 37 45 55 68 ​ 12 12 12 12 12 13 13 14 14 17 17 ​ 8 8 8 8 8 9 10 11 11 11 11 ​ Part. no. 3755.07.12 3755.07.17 3755.09.17 3755.09.20 3755.11.20 3755.13.25 3755.16.25 3755.21.32 3755.29.40 3755.42.50 3755.48.63 ​ 100 100 100 100 100 100 50 50 50 10 5 ​ Outer thread Pg / Inner thread metric / Light grey RAL 7035 ​ Pg Pg Pg Pg Pg Pg Pg Pg 9 11 13 13 16 21 29 36 ​ M12x1.5 M16x1.5 M16x1.5 M20x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 ​ 19 22 24 24 27 33 42 55 ​ 12 12 13 13 13 14 14 14 ​ 8 8 9 9 10 11 11 11 ​ Part. no. 3455.09.12 3455.11.17 3455.13.17 3455.13.20 3455.16.20 3455.21.25 3455.29.32 3455.36.40 ​ 100 100 100 100 50 50 50 25 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 261 Locking Plugs Nickel-Plated Brass short entry thread metric Material: O-ring: Temperature range: Protection class: Nickel-plated brass NBR -40°C / +100°C IP 68 ​ Round execution​/ with O-ring ​ M6x1.0 M8x1.25 M10x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 M75x1.5 ​ 9 10 12 14 19 24 28 35 45 55 70 80 ​ 3 3 3 3 3 3 4 4 6 6 6 6 ​ 5 5 5 5 5 6 7 8 8 9 10 11 ​ ​ Part. no. 8706.08 8708.08 8710.08 8712.08 8717.08 8720.08 8725.08 8732.08 8740.08 8750.08 8763.08 8775.08 1 1 1                   - ​​ 50 50 50 50 50 25 25 10 10 10 10 5 1 = Metric coarse-pitch thread long entry thread metric ​ Round execution​/ with O-ring ​ M6x1.0 M8x1.25 M10x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 M75x1.5 ​ 9 10 12 14 19 24 28 35 45 55 70 80 ​ 3 3 3 3 3 3 4 4 6 6 6 6 ​ 8 10 10 10 10 10 11 13 13 14 15 15 ​ 1 1 1                   - ​ Part. no. 8706.11.08 8708.11.08 8710.11.08 8712.11.08 8717.11.08 8720.11.08 8725.11.08 8732.11.08 8740.11.08 8750.11.08 8763.11.08 8775.11.08 ​​ 50 50 50 50 50 25 25 10 10 10 10 5 1 = Metric coarse-pitch thread 262 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Locking Plugs Nickel-Plated Brass short entry thread metric Material: Temperature range: Protection class: Protection type addition: Nickel-plated brass -40°C / +200°C IP 54 IP 68, if the entry thread is sealed ​ Hexagonal design​/ without O-Ring ​ M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 ​ 14 18 22 27 34 42 52 65 ​ 2.5 2.5 2.5 3.0 3.5 4.0 4.0 4.0 ​ Part. no. ​ 8745.12 8745.17 8745.20 8745.25 8745.32 8745.40 8745.50 8745.63 5 5 6 7 8 8 9 10 ​ 100 100 100 50 25 25 10 10 short entry thread pg Material: O-ring: Temperature range: Protection class: Nickel-plated brass NBR -40°C / +100°C IP 68 ​ Round execution / with O-Ring ​ Pg 7 Pg 9 Pg 11 Pg 13 Pg 16 Pg 21 Pg 29 Pg 36 Pg 42 Pg 48 G 2“ ​ 14 17 20 22 24 30 39 50 60 65 65 ​ 3 3 3 3 3 4 4 6 6 6 6 ​ 5 6 6 6.5 6.5 7 8 9 10 10 10 ​ Part. no. 8707.08 8709.08 8711.08 8713.08 8716.08 8721.08 8729.08 8736.08 8742.08 8748.48.08 8748.08 ​ 100 100 100 50 50 10 10 10 10 10 10 long entry thread pg ​ Round execution / with O-Ring ​ Pg 7 Pg 9 Pg 11 Pg 13 Pg 16 Pg 21 Pg 29 Pg 36 G 2“ ​ 14 17 20 22 24 30 39 50 65 ​ 3 3 3 3 3 4 4 6 6 ​ 10 10 10 10 10 12 12 15 15 ​ Part. no. 8707.11.08 8709.11.08 8711.11.08 8713.11.08 8716.11.08 8721.11.08 8729.11.08 8736.11.08 8748.11.08 ​ 100 100 100 50 50 10 10 10 10 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 263 Locking Plugs Stainless Steel A2 round execution Material: CrNi stainless steel A2 (DIN EN 1.4305 / AISI 303) NBR -40°C / +100°C IP 68 O-ring : Temperature range: Protection class: ​ Short entry thread metric​/ with O-ring ​ M10x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 M75x1.5 ​ 12 14 19 24 28 35 45 55 70 80 ​ 3 3 3 3 4 4 6 6 6 6 ​ 5 5 5 6 7 8 8 9 10 11 ​ ​ Part. no. 8710.96.08.70 8712.96.08.70 8717.96.08.70 8720.96.08.70 8725.96.08.70 8732.96.08.70 8740.96.08.70 8750.96.08.70 8763.96.08.70 8775.96.08.70 1                   - ​​ 50 50 50 25 25 10 10 10 10 5 1 = Metric coarse-pitch thread Available on request: Entry thread Pg ​ Long entry thread metric​/ with O-ring ​ M10x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 M75x1.5 ​ 12 14 19 24 28 35 45 55 70 80 ​ 3 3 3 3 4 4 6 6 6 6 ​ 10 10 10 10 11 13 13 14 15 15 ​ 1                   - ​ Part. no. 8710.96.11.08.70 8712.96.11.08.70 8717.96.11.08.70 8720.96.11.08.70 8725.96.11.08.70 8732.96.11.08.70 8740.96.11.08.70 8750.96.11.08.70 8763.96.11.08.70 8775.96.11.08.70 ​​ 50 50 50 25 25 10 10 10 10 5 1 = Metric coarse-pitch thread Available on request: Entry thread Pg 264 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Locking Plugs Stainless Steel A2 for High Temperature Applications round execution Material: CrNi stainless steel A2 (DIN EN 1.4305 / AISI 303) FPM -40°C / +200°C IP 68 O-ring: Temperature range: Protection class: ​ Short entry thread metric​/ with O-ring ​ M10x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 M75x1.5 ​ 12 14 19 24 28 35 45 55 70 80 ​ 3 3 3 3 4 4 6 6 6 6 ​ 5 5 5 6 7 8 8 9 10 11 ​ ​ Part. no. 8710.96.08 8712.96.08 8717.96.08 8720.96.08 8725.96.08 8732.96.08 8740.96.08 8750.96.08 8763.96.08 8775.96.08 1                   - ​​ 50 50 50 25 25 10 10 10 10 5 1 = Metric coarse-pitch thread Available on request: Entry thread Pg ​ Long entry thread metric​/ with O-ring ​ M10x1.5 M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 M75x1.5 ​ 12 14 19 24 28 35 45 55 70 80 ​ 3 3 3 3 4 4 6 6 6 6 ​ 10 10 10 10 11 13 13 14 15 15 ​ 1                   - ​ Part. no. 8710.96.11.08 8712.96.11.08 8717.96.11.08 8720.96.11.08 8725.96.11.08 8732.96.11.08 8740.96.11.08 8750.96.11.08 8763.96.11.08 8775.96.11.08 ​​ 50 50 50 25 25 10 10 10 10 5 1 = Metric coarse-pitch thread Available on request: Entry thread Pg American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 265 Synthetic Locking Plugs metric thread Material: Temperature range: Protection class: Protection type addition: Polyamide PA 6 -30°C / +100°C IP 54 IP 68, if the entry thread is sealed ​ Light grey RAL 7035​/ without O-Ring ​ M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 ​ 15 20 24 30 37 46 56 70 ​ 4.5 4.5 4.5 5.0 5.5 6.0 6.0 6.0 ​ Part. no. ​ 8855.12 8855.17 8855.20 8855.25 8855.32 8855.40 8855.50 8855.63 6 6 6 8 8 8 10 12 ​ 100 100 100 100 50 50 10 10 ​ Black RAL 9005 / without O-Ring ​ M12x1.5 M16x1.5 M20x1.5 M25x1.5 M32x1.5 M40x1.5 M50x1.5 M63x1.5 ​ 15 20 24 30 37 46 56 70 ​ 4.5 4.5 4.5 5.0 5.5 6.0 6.0 6.0 ​ Part. no. ​ 8845.12 8845.17 8845.20 8845.25 8845.32 8845.40 8845.50 8845.63 6 6 6 8 8 8 10 12 ​ 100 100 100 100 50 50 10 10 entry thread pg Material: Temperature range: Protection class: Shock-resistant polystyrene -20°C / +80°C IP 54, IP 68 if the thread is sealed ​ Light grey RAL 7035​/ without O-Ring ​ Pg Pg Pg Pg Pg Pg Pg Pg Pg Pg 266 7 9 11 13 16 21 29 36 42 48 ​ 15 19 22 25 27 33 44 55 62 69 ​ 2.0 3.0 3.5 3.5 3.5 4.0 4.0 4.0 4.0 4.0 ​ 6.0 6.5 6.5 6.5 6.5 8.0 8.0 10.0 10.0 12.0 ​ Part. no. 8807 8809 8811 8813 8816 8821 8829 8836 8842 8848.48 ​ 100 100 100 100 100 100 50 25 10 25 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Solid Rubber Sealing Inserts Suitable for Cable Glands Progress® Material: Temperature range: NBR -40°C / +100°C ​ Short sealing insert without drilled hole​​ ​ M6 M8 M10 Pg 11 M12 / Pg M16 / Pg M20 / Pg M25 / Pg Pg 29 M32 Pg 36 M40 Pg 48 M50 / Pg M63 M75 M85 M95 M100 M105 M115 ​ 42 Part. no. 1000.06.30.03 1000.08.30.03 1000.10.30.03 1000.11.30.03 1000.12.30.03 1000.17.30.03 1000.20.30.03 1000.25.30.03 1000.29.30.03 1000.32.30.03 1000.36.30.03 1000.40.30.03 1000.48.30.03 1000.50.30.03 1000.63.30.03 1000.75.30.03 1000.085.30.03 1000.095.30.03 1000.100.30.03 1000.105.30.03 1000.115.30.03 3.5 5.0 6.0 12.0 8.0 10.5 15.0 20.5 27.5 25.5 35.0 33.0 49.0 42.0 52.0 63.0 70.0 80.0 85.0 90.0 95.0 7 9 13 / Pg 16 21 ​ ​​ 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Technical note When frozen to at least -25°C, the solid sealing inserts are easy to drill. for high-temperature applications Material: Temperature range: FPM -40°C / +200°C ​ Short sealing insert without drilled hole​​ ​ M6 M8 M10 Pg 11 M12 / Pg M16 / Pg M20 / Pg M25 / Pg Pg 29 M32 Pg 36 M40 / Pg Pg 48 M50 / Pg M63 ​ 7 9 16 21 29 42 3.5 5.0 6.0 12.0 8.0 10.5 15.0 20.5 27.5 25.5 35.0 33.0 49.0 42.0 52.0 ​ Part. no. 1000.06.98.30.03 1000.08.98.30.03 1000.10.98.30.03 1000.11.98.30.03 1000.12.98.30.03 1000.17.98.30.03 1000.20.98.30.03 1000.25.98.30.03 1000.29.98.30.03 1000.32.98.30.03 1000.36.98.30.03 1000.40.98.30.03 1000.48.98.30.03 1000.50.98.30.03 1000.63.98.30.03 ​​ 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Technical note When frozen to at least -25°C, the solid sealing inserts are easy to drill. American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 267 O-Rings & Sealing Washers Suitable for Cable Glands Progress® o-rings Material: Temperature range: NBR -40°C / +100°C ​ Suitable for entry thread metric or Pg​​ ​ M6 M8 M10 M12 M16 M20 M25 M32 M40 M50 M63 M75 Pg 13 - 268 ​ Pg 7 Pg 9 Pg 11 Pg 16 Pg 21 Pg 29 Pg 36 Pg 42 Pg 48 ​ 5.0 6.0 8.1 10.0 13.1 17.0 22.0 30.0 36.0 46.0 60.0 72.0 15.0 19.0 25.0 33.0 42.5 48.0 55.0 ​ 1.0 1.5 1.6 1.5 1.6 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.2 2.6 3.0 2.0 ​ Part. no. 1005.00.08 1006.00.08 1006.06.08 1007.00.08 1000.09.00.08 2111.00.08 1013.00.22.08 1021.00.30.08 1000.40.00.08 1000.50.00.08 1000.63.00.08 1000.75.00.08 1011.00.08 1016.00.08 1016.00.25.08 1029.00.08 1036.00.08 1000.42.00.08 1000.48.00.08 ​​ 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com O-Rings & Sealing Washers Suitable for Cable Glands Progress® o-rings for high temperatures Material: Temperature range: FPM -40°C / +200°C ​ Suitable for entry thread metric or Pg​​ ​ M6 M8 M10 M12 M16 M20 M25 M32 M40 M50 M63 M75 Pg 16 - ​ Pg 7 Pg 9 Pg 11 Pg 13 Pg 21 Pg 29 Pg 36 Pg 42 Pg 48 ​ 5.0 6.0 8.1 10.0 13.1 17.0 22.0 30.0 36.0 46.0 60.0 72.0 15.0 18.0 25.0 33.0 42.5 48.0 55.0 ​ 1.0 1.5 1.6 1.5 1.6 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 1.8 2.6 3.0 2.0 ​ Part. no. 1105.98.08 1106.98.08 1106.06.98.08 1107.98.08 1100.09.98.08 2111.98.08 1113.98.22.08 1121.98.30.08 1100.40.98.08 1100.50.98.08 1100.63.98.08 1100.75.98.08 1111.98.08 1116.98.08 1116.98.25.08 1129.98.08 1136.98.08 1100.42.98.08 1100.48.98.08 ​​ 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 269 O-Rings & Sealing Washers Suitable for Cable Glands Progress® sealing washers Material: Temperature range: Color: KlingerSIL C-4300 -40°C / +300°C Green ​ Suitable for metric entry thread​​ ​ M6 M8 M10 M12 M16 M20 / Pg 13 M25 M32 M40 M50 M63 ​ 10.0 12.0 14.0 16.0 21.0 25.0 31.0 39.0 48.0 59.0 73.0 ​ 6.0 8.0 10.0 12.0 16.0 20.5 25.0 32.0 40.0 50.0 63.0 ​ 1.5 1.5 1.5 1.5 1.5 1.5 2.0 2.0 2.0 2.0 2.0 ​ Part. no. 1006.00.16 1008.00.16 1010.00.16 1012.00.16 1017.00.16 1013.00.16 1025.00.16 1032.00.16 1040.00.16 1050.00.16 1063.00.16 ​​ 1 1 1 1 1 1 1 1 1 1 1 ​ Suitable for entry thread Pg​​ ​ Pg 7 Pg 9 Pg 11 M20 / Pg 13 Pg 16 Pg 21 Pg 29 Pg 36 Pg 42 Pg 48 270 ​ 16.5 19.0 22.5 25.0 27.0 33.5 43.5 55.0 63.0 69.0 ​ 12.5 15.2 18.5 20.5 22.5 28.5 37.0 47.0 54.0 59.3 ​ 1.5 1.5 1.5 1.5 1.5 2.0 2.0 2.0 2.0 2.0 ​ Part. no. 1007.00.16 1009.00.16 1011.00.16 1013.00.16 1016.00.16 1021.00.16 1029.00.16 1036.00.16 1042.00.16 1048.00.16 ​​ 1 1 1 1 1 1 1 1 1 1 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com O-Rings & Sealing Washers, Blind Discs Suitable for Cable Glands Syntec® sealing washers Material: Temperature range: Perbunan -20°C / +100°C ​ Suitable for metric entry thread​​ ​ M12 M16 M20 M25 M32 M40 M50 M63 ​ 20 23 29 37 44 52 64 68 ​ 12 16 20 25 32 40 50 63 ​ Part. no. ​ 1.6 1.8 1.8 1.8 2.2 2.2 2.7 3.2 1012.45.16 1017.45.16 1020.45.16 1025.45.16 1032.45.16 1040.45.16 1050.45.16 1063.45.16 ​​ 50 50 50 50 25 25 25 10 ​ Suitable for entry thread Pg​​ ​ Pg Pg Pg Pg Pg Pg Pg Pg ​ 7 9 11 13 16 21 29 36 16.0 19.0 22.5 25.0 27.0 34.0 43.0 54.0 ​ 11.5 14.0 18.5 19.0 21.0 27.0 35.0 45.0 ​ Part. no. ​ 2.0 2.0 2.0 2.0 2.0 2.5 2.5 2.5 1007.45.16 1009.45.16 1011.45.16 1013.45.16 1016.45.16 1021.45.16 1029.45.16 1036.45.16 ​​ 50 50 50 50 50 25 25 25 blind discs suitable for cable glands Material: Temperature range: Application: Polyamide -20°C / +100°C Dust stopper for cable glands ​ Blind disc for dust protection​​ ​ M10 / M12 / Pg 7 M16 / Pg 9 M20 / Pg 11 Pg 13 / Pg 16 M25 / Pg 21 Pg 29 M32 Pg 36 M40 M50 / Pg 42 M63 / Pg 48 ​ 10.5 13.5 16.5 20.5 26.5 35.0 30.0 45.0 38.0 52.0 57.0 ​ 0.3 0.3 0.3 0.3 0.3 0.3 0.3 0.3 0.3 0.3 0.3 ​ Part. no. 1012.00.19 1017.00.19 1011.00.19 1020.00.19 1025.00.19 1029.00.19 1032.00.19 1036.00.19 1040.00.19 1050.00.19 1063.00.19 ​​ 50 50 50 50 50 50 50 50 50 50 50 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 271 Cross Reference Heyco - Agro Heyco - PG Thread Type Thread Type PG7 PG7 PG9 PG9 PG11 PG11 PG13 PG13 PG16 PG16 PG21 PG21 PG29 PG29 PG36 PG36 PG42 PG42 PG48 PG48 Heyco Black 3207 3444 3210 3446 3213 3448 3216 3450 3219 3452 3222 3454 3225 3456 3204 3206 3212 3218 3281 3283 Agro - PG Thread Type Heyco Grey 3208 3445 3211 3447 3214 3449 3217 3451 3220 3453 3223 3455 3226 3457 n/a n/a n/a n/a n/a n/a Diameter Range (mm) 2.3 - 6.4 2.0 - 4. 4.7 - 7.6 3.0 - 5.8 5.9 - 10.0 3.8 - 7.0 6.9 - 11.9 5.0 - 8.8 10.9 - 13.9 8.1 - 11.9 13.8 - 18.0 11.6 - 16.0 18.3 - 24.5 16.3 - 19.6 22.0 - 32.0 20.0 - 26.0 32.0 - 38.0 25.0 - 31.0 37.0 - 44.0 29.0 - 35.0 Heyco - NPT Thread Type Thread Type NPT 3/8 NPT 3/8 NPT 1/2 NPT 1/2 NPT 3/4 NPT 3/4 NPT 1 NPT 1 Heyco Black 3228 3458 3231 3224 3234 3460 8437 8439 272 Heyco Black 3237 3464 3240 3466 3243 3468 3246 3470 3249 3472 Agro Black 1545.07.06 1545.07.06 1545.09.08 1545.09.08 1545.11.10 1545.11.07 1545.13.12 1545.13.07 1545.16.14 1545.16.11 1545.21.18 1545.21.14 1545.29.25 1545.29.25 1545.36.33 1545.36.33 1545.42.38 1545.42.38 1545.48.44 1545.48.44 Agro Grey 1555.07.06 1555.07.06 1555.09.08 1555.09.08 1555.11.10 1555.11.07 1555.13.12 1555.13.07 1555.16.14 1555.16.11 1555.21.18 1555.21.14 1555.29.25 1555.29.25 1555.36.33 1555.36.33 1545.42.38 1545.42.38 1545.48.44 1545.48.44 Agro - NPT Thread Type Heyco Grey 3229 3459 3232 3236 3235 3461 8438 8440 Diameter Range (mm) 4.7 - 7.9 2.0 - 6.0 6.9 - 11.8 5.0 - 8.8 13.8 - 18.0 11.5 - 16.0 18.0 - 25.4 12.0 - 19.5 Heyco - Strain Relief Thread Type PG7 PG7 PG9 PG9 PG11 PG11 PG13 PG13 PG16 PG16 Diameter Range (mm) 2.5 - 6.5 2.5 - 6.5 3.0 - 8.0 3.0 - 8.0 4.0 - 10.0 2.0 - 7.0 5.5- 12.0 3.0 - 7.0 8.5 - 14.0 5.0 - 11.0 11.0 - 18.0 6.5 - 14.0 17.0 - 25.0 17.0 - 25.0 22.0 - 33.0 22.0 - 33.0 28.0 - 38.0 28.0 - 38.0 32.0 - 44.0 32.0 - 44.0 Diameter Range (mm) 3.0 - 8.0 3.0 - 8.0 5.5 - 12.0 3.0 - 7.0 11.0 - 18.0 6.5 - 14.0 17.0 - 22.0 17.0 - 22.0 Agro Black Agro Grey 1545.N0375.08 1555.N0375.08 1545.N0375.08 1555.N0375.08 1545.N0500.12 1555.N0500.12 1545.N0500.07 1555.N0500.07 1545.N0750.18 1555.N0750.18 1545.N0750.14 1555.N0750.14 1545.N1000.22 1555.N1000.22 1545.N1000.22 1555.N1000.22 Agro - Strain Relief Heyco Grey 3228 3464 3241 3467 3244 3469 3247 3471 3250 3473 Diameter Range (mm) 2.3 - 6.4 2.0 - 4.6 4.7 - 7.6 3.0 - 5.8 5.9 - 10.0 3.8 - 7.0 6.9 - 11.9 5.0 - 8.8 10.9 - 13.9 8.1 - 11.9 Diameter Range (mm) 2.5 - 6.5 2.5 - 6.5 3.0 - 8.0 3.0 - 8.0 4.0 - 10.0 2.0 - 7.0 5.5 - 12.0 3.0 - 7.0 8.5 - 14.0 5.0 - 11.0 Agro Grey 1576.07.06 1576.07.06 1576.09.08 1576.09.08 1576.11.10 1576.11.07 1576.13.12 1576.13.07 1576.16.14 1576.16.11 Agro Black 1546.07.06 1546.07.06 1546.09.08 1546.09.08 1546.11.10 1546.11.07 1546.13.12 1546.13.07 1546.16.14 1546.16.11 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Cross Reference Olflex - Agro Olflex - PG Thread Type Thread Type Olflex Black Olflex Grey Diameter Range (mm) PG7 S2207 S1207 2.0 - 5.0 PG7 S2107 S1107 3.0 - 6.5 PG9 S2209 S1209 2.0 - 6.0 PG9 S2109 S1109 4.0 - 8.0 PG11 S2211 S1211 4.0 - 7.0 PG11 S2111 S1111 5.1 - 10.0 PG13 S2213 S1213 8.7 - 9.0 PG13 S2113 S1113 6.0 - 12.0 PG16 S2216 S1216 10.7 - 12.2 PG16 S2116 S1116 10.0 - 14.0 PG21 S2221 S1221 12.2 - 15.7 PG21 S2121 S1121 13.8 - 18.0 PG29 S2229 S1229 13.0 - 20.0 PG29 S2129 S1129 18.0 - 25.0 PG36 S2236 S1236 20.0 - 26.0 PG36 S2136 S1136 22.0 - 32.0 PG42 S2242 S1242 25.0 - 31.0 PG42 S2142 S1142 32.0 - 38.0 PG48 S2248 S1248 29.0 - 35.0 PG48 S2148 S1148 37.0 - 44.0 Olflex - NPT Thread Type Thread Type NPT 3/8 NPT 3/8 NPT 1/2 NPT 1/2 NPT 3/4 NPT 3/4 NPT 1 NPT 1 Olflex Black Olflex Grey Diameter Range (mm) S2238 S1238 2.0 - 6.0 S2138 S1138 4.0 - 8.0 S2212 S1212 8.7 - 9.0 S2112 S1112 6.0 - 12.0 S2234 S1234 12.2 - 15.7 S2134 S1134 13.8 - 18.0 S2201 S1201 14.0 - 21.0 S2101 S1101 18.0 - 26.0 Olflex - Strain Relief Thread Type PG7 PG7 PG9 PG9 PG11 PG11 PG13 PG13 PG16 PG16 Olflex Black Olflex Grey Diameter Range (mm) S2407 S1407 2.0 - 5.0 S2307 S1307 3.0 - 6.5 S2409 S1409 2.0 - 6.0 S2309 S1309 4.0 - 8.0 S2411 S1411 4.0 - 7.0 S2311 S1311 5.1 - 10.0 S2413 S1413 8.7 - 9.0 S2313 S1313 6.0 - 12.0 S2416 S1416 10.7 - 12.2 S2316 S1316 10.0 - 14.0 Agro - PG Thread Type Diameter Range (mm) 2.5 - 6.5 2.5 - 6.5 3.0 - 8.0 3.0 - 8.0 2.0 - 7.0 4.0 - 10.0 3.0 - 7.0 5.5 - 12.0 5.0 - 11.0 8.5 - 14.0 6.5 - 14.0 11.0 - 18.0 17.0 - 25.0 17.0 - 25.0 22.0 - 33.0 22.0 - 33.0 28.0 - 38.0 28.0 - 38.0 32.0 - 44.0 32.0 - 44.0 Agro Black 1545.07.06 1545.07.06 1545.09.08 1545.09.08 1545.11.07 1545.11.10 1545.13.07 1545.13.12 1545.16.11 1545.16.14 1545.21.14 1545.21.18 1545.29.25 1545.29.25 1545.36.33 1545.36.33 1545.42.38 1545.42.38 1545.48.44 1545.48.44 Agro Grey 1555.07.06 1555.07.06 1555.09.08 1555.09.08 1555.11.07 1555.11.10 1555.13.07 1555.13.12 1555.16.11 1555.16.14 1555.21.14 1555.21.18 1555.29.25 1555.29.25 1555.36.33 1555.36.33 1555.42.38 1555.42.38 1555.48.44 1555.48.44 Agro - NPT Thread Type Diameter Range (mm) 3.0 - 8.0 3.0 - 8.0 3.0 - 7.0 5.5 - 12.0 6.5 - 14.0 11.0 - 18.0 17.0 - 22.0 17.0 - 22.0 Agro Black Agro Grey 1545.N0375.08 1555.N0375.08 1545.N0375.08 1555.N0375.08 1545.N0500.07 1555.N0500.07 1545.N0500.12 1555.N0500.12 1545.N0750.14 1555.N0750.14 1545.N0750.18 1555.N0750.18 1545.N1000.22 1555.N1000.22 1545.N1000.22 1555.N1000.22 Agro - Strain Relief Diameter Range (mm) 2.5 - 6.5 2.5 - 6.5 3.0 - 8.0 3.0 - 8.0 2.0 - 7.0 4.0 - 10.0 3.0 - 7.0 5.5 - 12.0 5.0 - 11.0 8.5 - 14.0 Agro Grey 1576.07.06 1576.07.06 1576.09.08 1576.09.08 1576.11.07 1576.11.10 1576.13.07 1576.13.12 1576.16.11 1576.16.14 Agro Black 1546.07.06 1546.07.06 1546.09.08 1546.09.08 1546.11.07 1546.11.10 1546.13.07 1546.13.12 1546.16.11 1546.16.14 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 273
1100.20.150 价格&库存
很抱歉,暂时无法提供与“1100.20.150”相匹配的价格&库存,您可以联系我们找货
