ADVANCED ENGINEERING
GENERAL PURPOSE
Technical Data Sheet
Put-Ups
R
esists Fraying When
Cut With Scissors
I ncreased Braid Density
For Fuller Coverage
H
igh Abrasion
Resistance
C
ut And Abrasion
Resistant
H
alogen Free
Expansion Range
Nominal
Size
Part
Min
Max
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1/8”
1/4”
3/8”
1/2”
3/4”
1”
1 1/4”
1 1/2”
1 3/4”
2”
CCP0.13
CCP0.25
CCP0.38
CCP0.50
CCP0.75
CCP1.00
CCP1.25
CCP1.50
CCP1.75BK
CCP2.00BK
1/8”
5/32”
3/16”
1/4”
5/8”
3/4”
1”
1 1/4”
1 1/2”
1 3/4”
1/4”
7/16”
5/8”
3/4”
1”
1 3/16”
1 1/2”
2”
2 1/8”
2 1/2”
1,000’
1,000’
500’
500’
250’
250’
250’
250’
200’
200’
100’
100’
100’
100’
75’
50’
50’
50’
50’
50’
2
2
2
2
2
2
2
2
2
2
0.40
0.46
0.74
0.82
1.11
1.24
1.56
1.85
2.30
2.80
Scissor Cut For Easy, Fray Resistant
Installation In Shop Or Field
By adjusting the physical characteristics
of the polyethylene terephthalate filaments,
the engineers at Techflex® have produced
a product with the same specifications
of our PT with the unique advantage of being
able to cut the material with ordinary scissors
and still maintain an extraordinarily
fray-resistant end.
Cut Cleanly
Scissors
Material
Polyethylene Terephthalate
Flexo Clean Cut (CC) is ideal for field installers
and other situations where access to a hot knife
is impossible. CC’s fray-resistant properties
allows frequent expansion at the cut-end without
unraveling. When cut with a hot knife, CC produces
a virtually frayless end.
Cuts easily and neatly with regular scissors
and maintains a fray resistant end during
installation. When scissor cut, the end
of Clean Cut will withstand heavier handling
without fraying than standard PT.
Grade
CCP
Monofilament Diameter
.008”
Colors Available:
Drawing Number
TF001CCPT-WD
Black (BK) and Gray (GY).
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
Colors Available:
2 = BK and GY.
GENERAL
PURPOSE
ADVANCED
ENGINEERING
Melt Point
ABRASION
Medium
FLAMMABILITY
Rating______________________UL94VO
FMVSS 302 and SAE J369__________ Pass
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
77°F
Humidity
72%
A Few Strands Beginning
To Pull Out Of Sample
550 Test Cycles
Small Hole In Material
650 Test Cycles
Material Destroyed
800 Test Cycles
Pre-Test Weight
3,168.1 mg
Post-Test Weight
2,771.9 mg
Test End Loss Of Mass
Point Of Destruction
396.2 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 2
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 3
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 3
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC_________________________ None
482°F (250°C)
Maximum Continuous
Mil-I-23053
257°F (125°C)
Minimum Continuous
-94°F (-70°C)
PHYSICAL
PROPERTIES
Monofilament Diameter________ .008”
Avv 204
Flammability Rating____________ UL94
Recommended Cutting____ Scissor/HK
Colors__________________________ 2
Wall Thickness_________________ .024”
Tensile Strength (Yarn)_____________ 6
ASTM____________________________
D-2256 Lbs
Specific Gravity ASTM D-792______ 1.38
Moisture Absorption %__________ .1-.2
ASTM D-570
Hard Vacuum Data_________________
ASTM E-595 at 10-5 torr
TML___________________________ .19
CVCM_________________________ .00
WVR___________________________ .16
Smoke D-Max___________________ 56
ASTM E-662
Outgassing___________________ Med
Oxygen Index___________________ 21
ASTM D-2863
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of
sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-28
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
ASTM D-2117
很抱歉,暂时无法提供与“CCP0.13BK100”相匹配的价格&库存,您可以联系我们找货
