EXTREME
TEMPERATURE
Technical Data Sheet
ADVANCED ENGINEERING
Put-Ups
UL Recognized: VW-1
Nominal
Size
Diameter
Part
Wall
Thickness
±0.005”
Expansion Range
Min.
Max.
Bulk
Spool
Shop
Spool
Available
Colors
24
0.022”
FGLG.24
0.005”
0.020”
0.027”
500’
250’
6
F
or High Temp - Low Voltage
Applications
22
0.027”
FGLG.22
0.005”
0.025”
0.032”
500’
250’
6
0.034”
FGLG.20
0.009”
0.032”
0.039”
500’
250’
6
18
0.042”
FGLG.18
0.011”
0.040”
0.049”
500’
250’
6
E
asy To Install-Cuts With
Scissors
16
0.053”
FGLG.16
0.011”
0.051”
0.061”
500’
250’
6
14
0.066”
FGLG.14
0.011”
0.064”
0.072”
500’
250’
6
12
0.085”
FGLG.12
0.011”
0.081”
0.089”
250’
100’
6
R
esists Most Organic Solvents
11
0.095”
FGLG.11
0.011”
0.091”
0.101”
250’
100’
6
10
0.106”
FGLG.10
0.011”
0.102”
0.112”
250’
100’
6
9
0.118”
FGLG.09
0.011”
0.114”
0.124”
250’
100’
6
8
0.133”
FGLG.08
0.011”
0.129”
0.141”
250’
100’
6
7
0.148”
FGLG.07
0.013”
0.144”
0.158”
250’
100’
6
6
0.166”
FGLG.06
0.013”
0.162”
0.178”
250’
100’
6
5
0.186”
FGLG.05
0.013”
0.182”
0.198”
250’
100’
6
4
0.208”
FGLG.04
0.016”
0.204”
0.224”
250’
100’
6
3
0.234”
FGLG.03
0.016”
0.229”
0.249”
250’
100’
6
2
0.263”
FGLG.02
0.016”
0.258”
0.278”
250’
100’
6
1
0.294”
FGLG.01
0.016”
0.289”
0.311”
100’
50’
6
0.330”
FGLG.00
0.016”
0.325”
0.347”
100’
50’
6
3/8”
0.375”
FGL0.38
0.016”
0.375”
0.399”
100’
50’
6
7/16”
0.438”
FGL0.44
0.018”
0.438”
0.462”
100’
50’
6
1/2”
0.500”
FGL0.50
0.018”
0.500”
0.524”
100’
50’
6
5/8”
0.625”
FGL0.63
0.018”
0.625”
0.655”
100’
50’
6
3/4”
0.750”
FGL0.75
0.018”
0.750”
0.786”
100’
50’
6
1”
1.000”
FGL1.00
0.018”
1.000”
1.040”
100’
50’
6
Cut And Abrasion Resistant
Heat Treated, Fray-Resistant
Fiberglass Sleeving
Cut Cleanly
Scissors
Material
Acrylic Coated Fiberglass
Grade
FGL
Wall Thickness
Refer to Chart
Drawing Number
TF001INS-WD
Techflex® INSULTHERM® TRU-FIT (FGL) is a braided fiberglass
sleeving which has been heat treated and
impregnated with an acrylic binder to reduce fraying
and dusting, and improve usability and performance.
FGL is engineered for applications where temperatures as
high as 1,200ºF may be encountered. FGL is used as primary
insulation on low voltage applications such as leads in
toasters, coffee makers, ranges and other appliances. FGL
may also be used as insulation and protection for small
heaters and resistors that operate at high temperatures, and
to insulate over soldered connections when exposure to solder melt temperatures is possible.
Colors
Available:
6 = WH, NT, YL
RD, BL, BK
Insultherm® Tru-Fit provides a sturdy, long lasting and inexpensive insulation solution. It is flexible and expandable,
and can easily be installed over applications with irregular
shapes and tight turns. Standard color are Black and
Natural, but other colors are available by special order.
Contact your Account representative for details.
Colors Available:
www.techflex.com
VW-1
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
White (WH), Natural (NT), Yellow (YL), Red (RD), Blue (BL), Black (BK).
EXTREME
TEMPERATURE
Melt Point
ASTM D-2117
ABRASION
Very High
Rating_____________________ UL VW-1
Maximum Continuous
Mil-I-23053
1,202°F (650°C)
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
75°F
Humidity
15%
Slight Fraying
200 Test Cycles
Slight Fraying
1,000 Test Cycles
Fraying
1,700 Test Cycles
Material Destroyed
2,300 Test Cycles
Pre-Test Weight
15.3 g
Post-Test Weight
13.6 g
Test End Loss Of Mass
Point Of Destruction
11%
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 1
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 2
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 2
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
Minimum Continuous
-94°F (-70°C)
PHYSICAL
PROPERTIES
Monofilament Diameter_________ NA
ASTM D-204
Flammability Rating___________ VW-1
Recommended Cutting________ Scissor
Colors___________________________6
Wall Thickness_____________ .005”-.018”
Specific Gravity ASTM D-792___ 1.0-1.8
Moisture Absorption_____________ .01
% ASTM D-570
TML___________________________.02
CVCM_________________________ .01
WVR___________________________ .00
Outgassing____________________ Low
SVHC_________________________ None
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
08-26
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
2,048°F (1,120°C)
很抱歉,暂时无法提供与“FGLG.12BK”相匹配的价格&库存,您可以联系我们找货
