ADVANCED ENGINEERING
Technical Data Sheet
Put-Ups
C
omplies to HL2 According
to the Railway Standard
DIN EN 45545-2
Cuts Easily, Neatly And
Maintains a Fray Resistant
End
E
xpands For Ease of
Installation
C
ut And Abrasion Resistant
Mil-202 & VW-1 Approved
Expansion Range
Nominal
Size
Part
Min
Max
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1/8”
1/4”
3/8”
1/2”
3/4”
1”
1 1/4”
1 1/2”
1 3/4”
2”
CCF0.13
CCF0.25
CCF0.38
CCF0.50
CCF0.75
CCF1.00
CCF1.25
CCF1.50
CCF1.75TB
CCF2.00TB
1/8”
5/32”
3/16”
1/4”
5/8”
3/4”
1”
1 1/4”
1 1/2”
1 3/4”
1/4”
7/16”
5/8”
3/4”
1”
1 3/16”
1 1/2”
2”
2 1/8”
2 1/2”
1,000’
1,000’
500’
500’
250’
250’
250’
250’
200’
200’
100’
100’
100’
100’
75’
50’
50’
50’
50’
50’
2
2
2
2
2
2
2
2
TB
TB
0.40
0.46
0.74
0.82
1.11
1.24
1.56
1.85
2.30
2.80
Scissor Cut For Field Installation,
Will Not Support Combustion
CLEAN CUT FR has all of the same qualities that
make our standard CC so easy to cut and install,
with the added advantage of a flame
inhibitor to provide an extra level of safety
in certain applications.
Colors Available:
2 = TW & TB
Under normal conditions, Clean Cut FR will
quickly self-extinguish and minimize flame
spread and incidental damage
to surrounding components.
Cut Cleanly
Scissors
Material
Polyethylene Terephthalate
The combination of flame retardance, ease
of installation and nearly complete coverage
makes CC an ideal solution for many industrial and
engineering applications.
Grade
CCF
Monofilament Diameter
.008”
Cuts easily and neatly with regular scissors and
maintains a fray resistant end during installation.
When scissor cut, the end of CC will withstand
heavier handling without fraying than standard PT.
Colors Available:
Drawing Number
TF001CCF-WD
White w/Black Tracer (TW) and Black w/White Tracer (TB).
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 0787
FAR-25
VW-1
DIN EN
45545-2
ADVANCED
ENGINEERING
ADVANCED
ENGINEERING
Melt Point
ABRASION
Medium
Rating______________________UL VW-1
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
80°F
Humidity
70%
Very Minor Scuffing
100 Test Cycles
Strands Frayed
And Rough Surface
400 Test Cycles
Scuffing And Several
Broken Strands
500 Test Cycles
Material Destroyed
700 Test Cycles
Pre-Test Weight
3,602.0 mg
Post-Test Weight
3,373.9 mg
Test End Loss Of Mass
Point Of Destruction
228.1 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents__________________ 2
Aliphatic Solvents __________________ 1
Chlorinated Solvents_______________ 3
Weak Bases ________________________ 1
Salts _____________________________ 1
Strong Bases________________________ 2
Salt Water 0-S-1926__________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808_________________ 1
De-Icing Fluid MIL-A-8243____________ 1
Strong Acids _______________________ 3
Strong Oxidants___________________ 2
Esters/Ketones_____________________2
UV Light__________________________ 1
Petroleum_________________________ 1
Fungus ASTM G-211__________________
Halogen Free ____________________ Yes
RoHS____________________________Yes
SVHC_________________________ None
482°F (250°C)
Maximum Continuous
Mil-I-23053
257°F (125°C)
Minimum Continuous
-94°F (-70°C)
PHYSICAL
PROPERTIES
Monofilament Diameter_________.008”
ASTM D-204
Flammability Rating____________ VW-1
FMVSS-302 Approved
Recommended Cutting_____Scissor/HK
Colors__________________________ 2
Wall Thickness__________________.024”
Tensile Strength (Yarn)______________ 4
ASTM D-2256 Lb
Specific Gravity ASTM D-792______ 1.38
Moisture Absorption %__________ .1-.2
ASTM D-570
Hard Vacuum Data__________________
ASTM E-595
TML___________________________.19
CVCM_________________________ .04
WVR___________________________ .06
Smoke D-Max___________________275
ASTM E-66
Outgassing____________________Med
Oxygen Index___________________ 31
ASTM D-2863
© 2020 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
01-07
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
ASTM D-2117
很抱歉,暂时无法提供与“CCF0.13TB100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+393.366831+50.92474
- 2+361.743952+46.83089
- 3+344.486063+44.59670
- 5+323.862605+41.92682
- 7+310.975557+40.25848
- 10+297.8638210+38.56105
