T6F0.25SV
T6F0.25SV
    TECHFLEX
T6F0.25SV 数据手册
EXTREME TEMPERATURE Technical Data Sheet ADVANCED ENGINEERING Technical Data Sheet 4’ Put-Ups Heat Reflective Aluminum Laminated Fiberglass  elf Wrap And Seal Overlap S With High Temperature Adhesive Strip R  eflects Radiant Heat R  esists Gasoline And Engine Chemicals C  ut And Abrasion Resistant Nominal Size Part # Wall Thickness ±0.007” Bulk Box Box 8x8 Box 6x6 Box 4x4 Available Colors Lbs/ 10Pcs. 1/4” 3/8” 1/2” 5/8” 3/4” 1” 1 1/4” 1 1/2” 2” T6F0.25SV T6F0.38SV T6F0.50SV T6F0.63SV T6F0.75SV T6F1.00SV T6F1.25SV T6F1.50SV T6F2.00SV 0.042” 0.042” 0.042” 0.042” 0.042” 0.042” 0.042” 0.042” 0.042” 250 250 250 150 125 70 63 40 24 140 90 70 60 50 30 20 15 8 100 50 40 35 30 20 10 8 4 50 30 25 20 15 9 6 4 2 Silver Silver Silver Silver Silver Silver Silver Silver Silver 1.0 1.5 2.0 2.5 3.0 3.5 4.5 5.0 6.0 Reflective Aluminized Surface Bonded To Insulating Self Wrapping Fiberglass The newest item in the ThermaShield® line of aluminized fiberglass products, T6 is designed for ease of installation when component disassembly isn’t practical. Just wrap the pre-formed, split flexible tube around any component and seal the sides with the high temperature adhesive strip to provide protection from hot pipes and engine components. The highly reflective aluminized exterior, combined with the insulating fiberglass interior, protects delicate wire bundles, cables and lines from damage caused by nearby exhaust pipes, headers or other heat generating components. Cut Cleanly Scissors Aluminum Laminated Fiberglass Grade T6F Temperature Material Colors Available: Steel Braided Hose Without T6 Protection Silver (SV) With T6 Protection Time Wall Thickness .042” Drawing Number TF001TW-WD www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 When applied, the aluminum laminate reflects heat away and the insulating fiberglass backing protects the fragile contents from thermal damage and failure. T6 can reduce the heat transmission from hot pipes or engine components into hoses or harnesses by up to 50% or more. HALOGEN FREE FAR-25 EXTREME ADVANCED ENGINEERING TEMPERATURE Technical Data Sheet Technical Data Sheet Melt Point ASTM D-2117 ABRASION Extreme Rating_______________ Non Flammable Abrasion Test Machine Calibrase H-18 Abrasion Test Load 500g Room Temperature 71°F Humidity 53% Most Foil Coating Worn Away In Tested Area Of Material 3,500 Test Cycles Braid Worn Through In Both Directions Material Destroyed 6,000 Test Cycles Pre-Test Weight 18,188.4 mg Post-Test Weight 16,555.5 mg Test End Loss Of Mass Point Of Destruction 1,632.9 mg Mil-I-23053 491°F (255°C) Minimum Continuous -76°F (-60°C) Taber 5150 Abrasion Test Wheel Maximum Continuous CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 1 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 1 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong __________________________ 1 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-78 08________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 2 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes PHYSICAL PROPERTIES Flammability Rating__Non Combustible Recommended Cutting________Scissor Colors__________________________ 1 Wall Thickness_________________ .042” © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 08-26 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance FLAMMABILITY 2,048°F (1,120°C)
T6F0.25SV 价格&库存
很抱歉,暂时无法提供与“T6F0.25SV”相匹配的价格&库存,您可以联系我们找货
