ADVANCED ENGINEERING
METAL & SHIELDING
Technical Data Sheet
Put-Ups
Expansion Range
E
conomical And Easy
To Install
Nominal
Size
Part
Min
Max
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
E
xpands Up To 150%
1/8”
1/4”
3/8”
1/2”
5/8”
3/4”
1”
1 1/4”
1 1/2”
CNN0.13BK
CNN0.25BK
CNN0.38BK
CNN0.50BK
CNN0.63BK
CNN0.75BK
CNN1.00BK
CNN1.25BK
CNN1.50BK
3/32”
1/8”
3/16”
1/4”
3/8”
1/2”
5/8”
3/4”
1”
1/4”
7/16”
5/8”
3/4”
1”
1 1/4”
1 5/8”
1 3/4”
2 1/2”
1,000’
1,000’
500’
500’
500’
250’
250’
250’
200’
225’
200’
125’
100’
100’
75’
65’
50’
40’
Black
Black
Black
Black
Black
Black
Black
Black
Black
0.35
0.40
0.60
0.82
0.96
1.24
1.37
1.65
2.20
R
esists Gasoline And
Engine Chemicals
E
MI, RFI Protection
S
uperior Static
Dissipation
C
ut And Abrasion
Resistant
C
ustom Lengths
Available
Conductive Carbon Infused Nylon
For Static Protection And Shielding
CN is braided from 11 mil carbonized
nylon monofilament yarn. CN is designed
to protect sensitive wiring from abrasion
while shielding it from high frequency
noise. Many successful applications have
utilized CN for maintaining clean video
signals, interference filtering in pro sound
environments, and RF filtering on power
cables and outputs. CN is also useful in static
sensitive environments.
Cut Cleanly
Hot Knife
Material
Carbonized Nylon
Grade
CNN
CN utilizes a patented carbonization process
which infuses our braided sleeving with
a microscopic carbon compound that is virtually
indistinguishable from the base material.
The result is a strong, long lasting jacket that
is ready for the most sensitive applications.
Monofilament Diameter
.011”
Drawing Number
TF001CNN-WD
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
Clean signals are achieved without excessive noise
with properly isolated cables and wires.
Colors Available:
Black (BK)
METAL & SHIELDING
ADVANCED
ENGINEERING
Melt Point
ASTM D-2117
ABRASION
482ºF (250ºC)
Maximum Continuous
302ºF (150ºC)
Medium
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
73°F
Humidity
51%
Material Destroyed
800 Test Cycles
Pre-Test Weight
8,822.3 mg
Post-Test Weight
8,662.5 mg
Test End Loss Of Mass
Point Of Destruction
159.8 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 4
Strong Oxidants___________________ 4
Esters/Ketones____________________ 1
UV Light_________________________ 2
Petroleum________________________ 3
Fungus ASTM G-21_________________ 2
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC_________________________ None
Minimum Continuous
-49ºF (-45ºC)
PHYSICAL
PROPERTIES
Monofilament Diameter________ .011”
ASTM D-204
Recommended Cutting______Hot Knife
Colors__________________________ 1
Wall Thickness_________________ .028”
Tensile Strength (Yarn)______________
ASTM D-2256 Lbs
Abrasion_____________________ Med
Specific Gravity ASTM D-792______ 1.13
Moisture Absorption_____________ 2.5
% ASTM D-570
Hard Vacuum Data_________________
ASTM E-595 at 10-5 torr
TML___________________________ .19
CVCM_________________________ .04
WVR___________________________ .06
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-28
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Mil-I-23053
Abrasion Resistance
很抱歉,暂时无法提供与“CNN0.25BK100”相匹配的价格&库存,您可以联系我们找货
