CCP1.50BK
CCP1.50BK
    TECHFLEX
    SLEEVING 1.5" X 250' BLACK
CCP1.50BK 数据手册
ADVANCED ENGINEERING GENERAL PURPOSE Technical Data Sheet Technical Data Sheet Put-Ups R  esists Fraying When Cut With Scissors I ncreased Braid Density For Fuller Coverage H  igh Abrasion Resistance C  ut And Abrasion Resistant H  alogen Free Expansion Range Nominal Size Part # Min Max Bulk Spool Shop Spool Available Colors Lbs/ 100’ 1/8” 1/4” 3/8” 1/2” 3/4” 1” 1 1/4” 1 1/2” 1 3/4” 2” CCP0.13 CCP0.25 CCP0.38 CCP0.50 CCP0.75 CCP1.00 CCP1.25 CCP1.50 CCP1.75BK CCP2.00BK 1/8” 5/32” 3/16” 1/4” 5/8” 3/4” 1” 1 1/4” 1 1/2” 1 3/4” 1/4” 7/16” 5/8” 3/4” 1” 1 3/16” 1 1/2” 2” 2 1/8” 2 1/2” 1,000’ 1,000’ 500’ 500’ 250’ 250’ 250’ 250’ 200’ 200’ 100’ 100’ 100’ 100’ 75’ 50’ 50’ 50’ 50’ 50’ 2 2 2 2 2 2 2 2 2 2 0.40 0.46 0.74 0.82 1.11 1.24 1.56 1.85 2.30 2.80 Scissor Cut For Easy, Fray Resistant Installation In Shop Or Field By adjusting the physical characteristics of the polyethylene terephthalate filaments, the engineers at Techflex® have produced a product with the same specifications of our PT with the unique advantage of being able to cut the material with ordinary scissors and still maintain an extraordinarily fray-resistant end. Cut Cleanly Scissors Material Polyethylene Terephthalate Flexo Clean Cut (CC) is ideal for field installers and other situations where access to a hot knife is impossible. CC’s fray-resistant properties allows frequent expansion at the cut-end without unraveling. When cut with a hot knife, CC produces a virtually frayless end. Cuts easily and neatly with regular scissors and maintains a fray resistant end during installation. When scissor cut, the end of Clean Cut will withstand heavier handling without fraying than standard PT. Grade CCP Monofilament Diameter .008” Colors Available: Drawing Number TF001CCPT-WD Black (BK) and Gray (GY). www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Colors Available: 2 = BK and GY. GENERAL PURPOSE ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ABRASION Medium FLAMMABILITY Rating______________________UL94VO FMVSS 302 and SAE J369__________ Pass Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 77°F Humidity 72% A Few Strands Beginning To Pull Out Of Sample 550 Test Cycles Small Hole In Material 650 Test Cycles Material Destroyed 800 Test Cycles Pre-Test Weight 3,168.1 mg Post-Test Weight 2,771.9 mg Test End Loss Of Mass Point Of Destruction 396.2 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 2 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 3 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC_________________________ None 482°F (250°C) Maximum Continuous Mil-I-23053 257°F (125°C) Minimum Continuous -94°F (-70°C) PHYSICAL PROPERTIES Monofilament Diameter________ .008” Avv 204 Flammability Rating____________ UL94 Recommended Cutting____ Scissor/HK Colors__________________________ 2 Wall Thickness_________________ .024” Tensile Strength (Yarn)_____________ 6 ASTM____________________________ D-2256 Lbs Specific Gravity ASTM D-792______ 1.38 Moisture Absorption %__________ .1-.2 ASTM D-570 Hard Vacuum Data_________________ ASTM E-595 at 10-5 torr TML___________________________ .19 CVCM_________________________ .00 WVR___________________________ .16 Smoke D-Max___________________ 56 ASTM E-662 Outgassing___________________ Med Oxygen Index___________________ 21 ASTM D-2863 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-28 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance ASTM D-2117
CCP1.50BK 价格&库存
很抱歉,暂时无法提供与“CCP1.50BK”相匹配的价格&库存,您可以联系我们找货
