SDN1.00BK50
SDN1.00BK50
    TECHFLEX
    1" SUPER DUTY BLACK 50'
SDN1.00BK50 数据手册
ADVANCED ENGINEERING HEAVY DUTY Technical Data Sheet Technical Data Sheet Put-Ups F  ull Coverage E  xtreme Abrasion And Cut Resistance R  esists Gasoline, UV, Solvents, Salt Water And Chemicals B  raided From 20 mil Nylon Monofilament Expansion Range Nominal Size Part # Min Max Bulk Spool Shop Spool Available Colors Lbs/ 100’ 1/4” 1/2” 3/4” 1” 1 1/4” 1 3/4” 2 1/4” SDN0.25BK SDN0.50BK SDN0.75BK SDN1.00BK SDN1.25BK SDN1.75BK SDN2.25BK 1/4” 1/2” 3/4” 1” 1 1/4” 1 3/4” 2 1/1” 1/2” 1” 1 1/4” 1 1/2” 2” 2 3/4” 3” 500’ 250’ 250’ 250’ 250’ 100’ 100’ 100’ 100’ 50’ 50’ 50’ 25’ 25’ Black Black Black Black Black Black Black 1.05 1.85 2.30 2.75 3.00 4.00 5.30 C  ustom Lengths Available H  alogen Free Heavy Duty Construction For High Abrasion Protection, Light Weight & Flexible For Easy Installation SD is braided from .020” nylon 6-6 polyamide monofilament. Heavy duty and flexible, this sleeving is extremely versatile. Excellent durability makes SD ideal for a wide range of industrial applications, and other jobs where high abrasion protection is needed. Cut Cleanly Hot Knife Super Duty will outperform the competition’s dual monofilament sleeving. SD is also more economical and easy to use, cutting cleanly with a hot knife leaving a neat, sealed end. Material Nylon 6-6 Monofilament Grade SDN Monofilament Diameter .020” Drawing Number TF001SDN-WD www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 SD protects hydraulic hoses from abrasion, flying debris and UV damage without affecting flexibility or trapping moisture like other abrasion covers. Colors Available: Black (BK). HEAVY DUTY ENGINEERING ADVANCED Technical Data Sheet Technical Data Sheet Melt Point ASTM D-2117 ABRASION 493°F (256°C) Maximum Continuous 302°F (150°C) Very High Abrasion Test Machine Minimum Continuous -49°F (-45°C) Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 72°F Humidity 48% Material Destroyed 2,500 Test Cycles Pre-Test Weight 6,878.6 mg Post-Test Weight 6,527.2 mg Test End Loss Of Mass Point Of Destruction 351.4 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 1 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 1 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 5 Strong Oxidants___________________ 5 Esters/Ketones____________________ 1 UV Light_________________________ 2 Petroleum________________________ 3 Fungus ASTM G-21_________________ 2 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC______________________________ PHYSICAL PROPERTIES Monofilament Diameter________ .020” ASTM D-204 Recommended Cutting______Hot Knife Colors__________________________ 1 Wall Thickness__________________ .05” Tensile Strength (Yarn)_____________ 9 ASTM D-2256 Lbs Specific Gravity ASTM D-792______ 1.14 Moisture Absorption_____________ 2.5 % ASTM D-570 Hard Vacuum Data_________________ ASTM E-595 TML__________________________ 1.10 CVCM_________________________ .01 WVR___________________________ .69 Outgassing___________________ High Oxygen Index___________________ 22 ASTM D-2863 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-28 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Mil-I-23053 Abrasion Resistance
SDN1.00BK50 价格&库存
很抱歉,暂时无法提供与“SDN1.00BK50”相匹配的价格&库存,您可以联系我们找货
