ADVANCED ENGINEERING
GENERAL PURPOSE
Technical Data Sheet
Put-Ups
H
igh Coverage, Self-Wrapping
Design
E
asy, Cost Effective
Installation
M
ore Flexible than Split
Convoluted or Spiral Wrap
I deal For Protecting
Components Without
Disconnecting Them
M
elt Temp. 482°F
Standard Put-Ups
Nominal
Size
Part
Wall
Thickness
Bulk
A
B
1/8”
3/16”
1/4”
5/16”
3/8”
1/2”
5/8”
3/4”
1”
1 1/2”
1 3/4”
2”
F6W0.13
F6W0.19
F6W0.25
F6W0.31
F6W0.38
F6W0.50
F6W0.63
F6W0.75
F6W1.00
F6W1.50
F6W1.75
F6W2.00
.027”
.027”
.027”
.027”
.027”
.027”
.027”
.027”
.027”
.027”
.027”
.027”
1,800’
1,200’
925’
650’
450’
300’
250’
150’
100’
50’
50’
40’
900’
600’
450’
325’
225’
150’
125’
100’
75’
25’
10’
10’
300’
200’
200’
125’
100’
75’
75’
50’
50’
Available
Colors
BK,
BK,
BK,
BK,
BK,
BK,
BK,
BK,
BK,
BK,
BK,
BK,
Woven, Split Tubular Harness Wrap
WH,
WH,
WH,
WH,
WH,
WH,
WH,
WH,
WH,
WH,
WH,
WH,
Overlap
*A
Lbs/
100’
40%
51%
44%
40%
41%
35%
30%
28%
26%
23%
23%
23%
0.57
0.98
1.10
1.30
1.50
1.80
2.10
2.40
3.20
4.50
5.00
6.00
CB
CB
CB
CB
CB
CB
CB
CB
CB
CB
CB
CB
Colors Available:
Woven Wrap has been engineered from the ground up
to meet the demanding specifications of today’s modern
wiring harness industry.
Black (BK), White
(WH), & Carbon (CB).
F6W utilizes many of the same characteristics
as our original F6 split braided sleeving including
the easy wrap around design and the extra
overlap to insure complete protection of
important electronic communication and
power systems.
Cut Cleanly
Hot Knife
Material
PET Polyethylene Terephthalate
Grade
F6W
The new woven construction provides superior elastic
flexibility with unbeatable coverage over any harness
assembly. Through a unique process, the blend of
monofilament and multifilament polyester fibers are
formed into a sleeving with memory that causes the
sleeve to self-close, and also snap back when opened.
Wire harness professionals will also appreciate the
increased abrasion resistance F6W will provide to their
cable assemblies.
Colors Available:
Filament Diameter
Overlap
Width
.009” Monofilament Polyester
1200 Denier Multifilament
Drawing Number
TF001F6W-WD
Black (BK), White (WH), & Carbon (CB).
Nominal Diameter
The Right Overlap
For Your Harness
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
*A
The engineered overlap allows ideal
flexibility without exposing wires and cables.
GENERAL
PURPOSE
ADVANCED
ENGINEERING
Melt Point
ABRASION
Low
Rating______________________UL94VO
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
72°F
Humidity
78%
Moderate Scuffing Visible
125 Test Cycles
Significant Scuffing;
Braid Separated
Approx. 20%
225 Test Cycles
Braid Begins to Break;
Material Destroyed
300 Test Cycles
Pre-Test Weight
9,736.4 mg
Post-Test Weight
9,328.6 mg
Test End Loss Of Mass
Point Of Destruction
407.8 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 2
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 3
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808_________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 3
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC_________________________ None
Maximum Continuous
Mil-I-23053
257°F (125°C)
Minimum Continuous
-94°F (-70°C)
www.techflex.com
Abrasion Resistance
FLAMMABILITY
ASTM D-2117
482°F (250°C)
PHYSICAL
PROPERTIES
Filament Diameter:_________________
Monofilament Polyester_______ .009”
MultiFilament__________ 1200 Denier
Recommended Cutting______Hot Knife
Colors__________________________ 3
Wall Thickness_________________ .027”
Tensile Strength________________6-10
Specific Gravity_________________ 1.38
Moisture Absorption%___________ .1-.2
Hard Vacuum Data _________________
ASTM E-595 at 10-5 torr
TML (%)________________________ .19
CVCM (%)______________________ .00
WVR (%)_______________________ .16
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of
sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-28
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
很抱歉,暂时无法提供与“F6W0.63BK75”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+844.546251+109.60669
- 2+776.718562+100.80390
- 3+739.575853+95.98345
- 5+695.348765+90.24358
- 7+667.679377+86.65260
- 10+639.5367510+83.00020
