ADVANCED ENGINEERING
GENERAL PURPOSE
Technical Data Sheet
Put-Ups
Nominal
Size
E
conomical And Easy
To Install
1/16”
PTN0.06
1/8”
PTN0.13
1/4”
PTN0.25
5/16”
PTN0.31
3/8”
PTN0.38
7/16”
PTN0.44
1/2”
PTN0.50
9/16”
PTN0.56
5/8”
PTN0.63
3/4”
PTN0.75
1”
PTN1.00
1 1/4”
PTN1.25
1 1/2”
PTN1.50
1 3/4”
PTN1.75
2”
PTN2.00
2 1/2”
PTN2.50
3”
PTN3.00
3 END CONSTRUCTION
1/4”
PT30.25
9 MIL CONSTRUCTION
4”
PT94.00BK
PET LEAN
3/4”
PTL0.75BK
1 1/4”
PTL1.25BK
R
esists Gasoline,
Engine Chemicals
And Cleaning Solvents
E
xpands Up To 150%
C
ut And Abrasion
Resistant
F
MVSS 302 Approval
Cut Cleanly
Hot Knife
Material
Polyethylene Terepthalate
Grade
PTN
Monofilament Diameter
.010”
Drawing Number
TF001PET-WD
Part
Expansion Range
Min
Max
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
3/64”
3/32”
1/8”
5/32”
3/16”
7/32”
1/4”
5/16”
3/8”
1/2”
5/8”
3/4”
1”
1 1/4”
1 1/2”
1 3/4”
2 1/2”
3/32”
1/4”
7/16”
15/32”
1/2”
5/8”
3/4”
7/8”
1”
1 1/4”
1 5/8”
1 3/4”
2 1/8”
2 3/4”
3 1/2”
3 5/8”
4 3/4”
1,000’
1,000’
1,000’
500’
500’
500’
500’
500’
500’
250’
250’
250’
200’
200’
200’
200’
100’
250’
225’
200’
150’
125’
125’
100’
100’
100’
75’
65’
50’
40’
30’
50’
50’
50’
more
than
40
BK,CL,NB,RE
0.22
0.20
0.30
0.50
0.57
0.68
0.77
0.81
0.95
1.20
1.34
1.60
1.96
2.45
2.60
3.80
4.00
1/8”
3/8”
1,000’
200’
4
0.39
4”
6 1/2”
100’
50’
BK
3.80
1/2”
3/4”
1 1/4”
1 3/4”
250’
250’
75’
50’
BK
BK
1.04
1.19
Colors
Available:
A Versatile Bundling
And Protection Solution
See color chart
The FLEXO® Original braided from 10 mil
polyethylene terepthalate (PET)
monofilament yarns. The material has a wide
operating temperature range, is resistant
to chemical degradation, UV radiation, and
abrasion. Used in electronics, automotive,
marine and industrial wire harnessing applications
where cost efficiency and durability are critical.
The unique braided construction and wide
expandability allows quick and easy installation
over large connectors and long runs.
High thermal and chemical resistance and wide
color/size selection make FLEXO® Original PET
ideal for customizing and protecting the wires,
hoses and cables in custom and classic colors.
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
FAR-25
GENERAL
PURPOSE
ADVANCED
ENGINEERING
Melt Point
ABRASION
High
Rating_______________ UL94VO, FAR25,
FMVSS-302
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
77°F
Humidity
72%
Two Broken Filament
300 Test Cycles
Approximately 6 Broken
Filaments
500 Test Cycles
Material Destroyed
- Very Visible Hole In
Material
1,150 Test Cycles
Pre-Test Weight
4,547.4 mg
Post-Test Weight
4,133.9 mg
Test End Loss Of Mass
Point Of Destruction
413.5 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 2
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 3
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 3
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC_________________________ None
Maximum Continuous
Mil-I-23053
257°F (125°C)
Minimum Continuous
-94°F (-70°C)
PHYSICAL
PROPERTIES
Monofilament Diameter_________ .010
ASTM D-204
Flammability Rating____________ UL94
FMVSS-302 Approved
Recommended Cutting______Hot Knife
Colors________________________ >40
Wall Thickness__________________ .025
Tensile Strength (Yarn)____________ 7.5
ASTM D-2256 Lbs
Specific Gravity ASTM D-792______ 1.38
Moisture Absorption____________ .1-.2
% ASTM D-570
Hard Vacuum Data_________________
ASTM E-595 at 10-5 torr
TML___________________________ .19
CVCM_________________________ .00
WVR___________________________ .16
Smoke D-Max___________________ 56
ASTM E-662
Outgassing___________________ Med
Oxygen Index___________________ 21
ASTM D-2863
© 2021 Techflex®, Inc. - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex®, Inc. is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, Inc., unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex®’s only obligations are those in standard
terms of sale for these products and Techfle® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-28
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.obroilandmarine.com
Abrasion Resistance
FLAMMABILITY
ASTM D-2117
482°F (250°C)
GENERAL PURPOSE
WH White
CF Checkered Flag
PG Platinum Gray
SK Snake
BR Brown
AQ Aqua
RD Red
OR Orange
YL Yellow
GN Green
BL Blue
PP Purple
CL Clear
BK Black
CB Carbon
BE Beige
GY Gray
DP Dark Purple
* NR Neon Red
* NP Neon Pink
* NY Neon Yellow
* NG Neon Green
* NB Neon Blue
*NO Neon Orange
PT Patriot
* NX Nitrox
* JS Jester
* OG Ogre
* SH Super Hero
SS Safety Stripe
GENERAL
PURPOSE
ADVANCED
ENGINEERING
C
ustom combination colors manufactured by Techflex
T
he possibilities are endless!
RE Reggae
FG Forest Green
BM Black Magic
CC Candy Cane
AL Alien
Alien
MO Monochrome
Monochrome
GW Gray White
DS Desert
Desert
RS Red Spiral
UG Uptown Green
Green
UY Uptown Yellow
Yellow
UR Uptown Red
Red
UP Uptown Purple
UB Uptown Blue
UX Uptown Gold
CO Coral
HH Hip Hop
SB Sherbert
TL Twilight
RW Rainbow
HO Holiday
BB Black Beige
GD Ground Wire
SM Shimmer
CK Corn Kernel
RC Rainbow Clear
RB Rainbow Black
很抱歉,暂时无法提供与“PTN0.13RD225”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+487.522741+63.27156
- 2+448.385792+58.19229
- 3+426.932433+55.40804
- 5+401.384085+52.09233
- 7+385.414877+50.01982
- 10+369.1693510+47.91145
