NHN1.50BK25
NHN1.50BK25
    TECHFLEX
    SLEEVING1.5"X25'BLACK
NHN1.50BK25 数据手册
ADVANCED ENGINEERING HEAVY DUTY Technical Data Sheet Technical Data Sheet Put-Ups I nnovative Braided Flat Filament Technology R  esists Damage From UV, Gasoline, Engine Chemicals And Salt Water H  eavy Plastic Protection S  mooth Inner Wall Reduces Internal Abrasion E  xtreme Cut And Abrasion Resistant H  alogen Free Nominal Size Part # 3/8” 1/2” 3/4” 1” 1 1/4” 1 1/2” 1 3/4” 2” 3” NHN0.38 NHN0.50 NHN0.75 NHN1.00 NHN1.25 NHN1.50 NHN1.75 NHN2.00 NHN3.00 Expansion Range Min Max Bulk Spool Shop Spool Available Colors Lbs/ 100’ 1/4” 3/8” 5/8” 7/8” 1” 1 1/4” 1 1/2” 1 3/4” 2 1/4” 1/2” 5/8” 1” 1 1/4” 1 1/2” 1 3/4” 2” 2 1/2” 3 1/2” 500’ 500’ 250’ 250’ 250’ 100’ 100’ 100’ 100’ 100’ 100’ 50’ 50’ 50’ 25’ 25’ 25’ 25’ BK,SVB,NO,HY BK,SVB,NO,HY BK,SVB,NO,HY BK,SVB,NO,HY BK,SVB,NO,HY BK,SVB,NO,HY BK,SVB,NO,HY BK,SVB,NO,HY BK,SVB,NO,HY 1.00 1.40 2.10 2.20 2.50 3.40 4.00 4.40 6.50 Innovative Flat Filament Braided For High Abrasion Resistance The latest innovation in Techflex® material design is the concept of using different shaped filaments to create strength, stiffness or a variety of other effects. Cut Cleanly Hot Knife Material Polyamide Monofilament Gorilla Sleeve is engineered from flat filaments of tough and strong 6-6 nylon to achieve a thick abrasion guard for use on hoses. This type of sleeve has been tested against competitor’s abrasion guards that mix materials in an effort to gain slight abrasion advantages. Gorilla Sleeve achieves better results without sacrificing great looks or flexibility. Constant abuse from road hazards, abrasion and vibration make Gorilla Sleeving the choice to protect hoses in over road vehicles. Grade NHN Flat Filament Thickness .020” Colors Available: Drawing Number TF001NH-WD Black (BK), Silver Back (SVB), Neon Orange (NO), & Highlighter Yellow (HY). www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Colors Available: Black (BK), Neon Orange (NO), & Highlighter Yellow (HY) HEAVY DUTY ENGINEERING ADVANCED Technical Data Sheet Technical Data Sheet Melt Point ABRASION ASTM D-2117 509°F (265°C) Maximum Continuous Abrasion Resistance Mil-I-23053 302°F (150°C) Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 80°F Humidity 72% Minor Scuffing 100 Test Cycles One Broken Strand 900 Test Cycles Second Broken Strand 1,200 Test Cycles One Strand Pulled Out Of Material 3,500 Test Cycles Material Destroyed 4,400 Test Cycles Pre-Test Weight 7,191.6 mg Post-Test Weight 6,761.4 mg Test End Loss Of Mass Point Of Destruction Minimum Continuous -76°F (-60°C) CHEMICAL RESISTANCE 1=No Effect 4=More Affected 2=Little Effect 5=Severely Affected 3=Affected Aromatic Solvents_________________ 1 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 1 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases_______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 5 Strong Oxidants___________________ 5 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 2 Fungus ASTM G-21_________________ 2 Halogen Free____________________ Yes RoHS___________________________ Yes PHYSICAL PROPERTIES Flat Filament__________________ .020” Flammability Rating________________ Recommended Cutting______Hot Knife Colors__________________________ 4 Wall Thickness__________________ .05” Tensile Strength (Yarn)____________ 19 ASTM D-2256 Lbs Specific Gravity ASTM D-792______ 1.12 Moisture Absorption_____________ 2.5 % ASTM D-570 Hard Vacuum Data_________________ ASTM E-595 TML__________________________ 1.10 CVCM_________________________ .01 WVR___________________________ .69 Smoke D-Max___________________ 56 ASTM E-662 Outgassing___________________ High Oxygen Index___________________ 22 ASTM D-2863 430.2 mg © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-28 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Extreme
NHN1.50BK25 价格&库存
很抱歉,暂时无法提供与“NHN1.50BK25”相匹配的价格&库存,您可以联系我们找货
