ADVANCED ENGINEERING
GENERAL PURPOSE
Technical Data Sheet
Put-Ups
E
conomical And Easy
To Install
R
esists Gasoline,
Engine Chemicals
And Cleaning Solvents
C
omplete Coverage
C
ut And Abrasion
Resistant
Expansion Range
Nominal
Size
Part
Min
Max
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1/8”
1/4”
5/16”
1/2”
PTT0.13
PTT0.25
PTT0.31
PTT0.50
1/16"
11/64”
1/4”
11/32”
1/4"
11/32”
3/8”
5/8”
1,000’
1,000’
1,000’
500’
225’
200’
200’
100’
5
5
5
5
0.29
0.36
0.58
0.84
3/4”
1”
1 1/4”
1 1/2”
1 3/4”
2”
2 1/2”
PTT0.75
PTT1.00
PTT1.25
PTT1.50
PTT1.75
PTT2.00
PTT2.50
1/2”
5/8”
1”
1 1/8”
1 1/2”
1 3/4”
2"
13/16”
1 1/8”
1 11/16”
2”
2 5/8”
3 1/8”
3 1/2"
250’
250’
250’
200’
200’
200’
100’
75’
65’
50’
40’
30’
50’
50’
5
5
5
5
5
5
5
1.10
1.23
1.30
1.95
2.60
3.43
3.60
Tight Weave for Extra Coverage
The FLEXO® Tight Weave original braided
from 10 mil polyethylene terepthalate (PET)
monofilament yarns. The material has a wide
operating temperature range, is resistant
to chemical degradation, UV radiation, and
abrasion. Tight Weave is designed for use in
applications where optimum coverage and
abrasion resistance is required. The tight braid
construction increases the coverage, wear factor
and improves harness security.
Cut Cleanly
Hot Knife
Material
Polyethylene Terepthalate
Used in electronics, automotive, marine and
industrial wire harnessing applications where cost
efficiency and durability are critical.
Grade
PTT
Monofilament Diameter
.010”
Drawing Number
TF001PET-WD
High thermal and chemical resistance and
extra coverage make FLEXO® TIGHT WEAVE
ideal for customizing and protecting the wires,
hoses and cables.
Black & Neon Blue(BNB), Black & Neon Red(BNR), Black and
Neon Orange(BNO), Black and Neon Yellow(BNY), and
Black (BK)
www.techflex.com
800.323.5140 • 973.300.9242 • fax: 973.300.9409
104 Demarest Road • Sparta, NJ 07871
FAR-25
Colors
Available:
BK, BNY, BNB, BNO,BNR
GENERAL
PURPOSE
ADVANCED
ENGINEERING
Melt Point
ABRASION
High
Rating_______________ UL94VO, FAR25,
FMVSS-302
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
77°F
Humidity
72%
Two Broken Filament
300 Test Cycles
Approximately 6 Broken
Filaments
500 Test Cycles
Material Destroyed
- Very Visible Hole In
Material
1,150 Test Cycles
Pre-Test Weight
4,547.4 mg
Post-Test Weight
4,133.9 mg
Test End Loss Of Mass
Point Of Destruction
413.5 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 2
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 3
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 3
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC_________________________ None
Maximum Continuous
Mil-I-23053
257°F (125°C)
Minimum Continuous
-94°F (-70°C)
PHYSICAL
PROPERTIES
Monofilament Diameter_________ .010
ASTM D-204
Flammability Rating____________ UL94
FMVSS-302 Approved
Recommended Cutting______Hot Knife
Colors__________________________ 5
Wall Thickness__________________ .025
Tensile Strength (Yarn)____________ 7.5
ASTM D-2256 Lbs
Specific Gravity ASTM D-792_______ .38
Moisture Absorption____________ 1-.2
% ASTM D- 570
Hard Vacuum Data _________________
ASTM E-595 at 10-5 torr
TML___________________________ .19
CVCM_________________________ 00
WVR___________________________ .16
Smoke D-Max___________________ 56
ASTM E-662
Outgassing_______________________ Med
Oxygen Index_ _____________________21
ASTM D-2863
© 2018 Techflex, Inc. - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex, Inc. is strictly forbidden.
Techflex product names and logos are registered trademarks of Techflex, Inc., unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s only obligations are those in standard terms of
sale for these products and Techflex will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
01-18
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
ASTM D-2117
482°F (250°C)
很抱歉,暂时无法提供与“PTT0.50BK”相匹配的价格&库存,您可以联系我们找货
