F6Z1.00BK25
F6Z1.00BK25
    TECHFLEX
    SELFWRAP1"X25'BLACK
F6Z1.00BK25 数据手册
ADVANCED ENGINEERING SPECIALTY Technical Data Sheet Technical Data Sheet Put-Ups L ightweight Nominal Size S  elf-Wrapping D  urable Woven Design M  aintains Wires in Flat Shape L ow Profile Part # Width Bulk Spool Shop Spool 1” F6Z1.00BK 30mm 50' 25' Black (BK) 3.26 F6Z1.50BK F6Z1.75BK F6Z2.25BK 40mm 50mm 60mm 50' 50' 50' 25' 25' 25' Black (BK) Black (BK) Black (BK) 4.34 5.42 6.51 Built on the same design as out Flexo® F6 and F6 Woven, Flexo® F6 Flat is a self-wrappable sleeve used to bundle and protect wire harnesses and cable assemblies in areas where space constraints restrict the use of traditional sleeving. Lightweight and durable, it maintains its flexibility for conforming to irregular shapes and bends during installation. Material Polyethylene terephthalate Grade F6Z Woven from monofilament and multifilament polyester yarn, Flexo® F6 Flat provides noise suppression and a high level of mechanical abrasion protection making it the perfect for use in automotive applications. The low-profile design is great for channeling and protecting wires that run under the carpet or in the headliner of automobiles. Great For Channeling and Protecting Wires That Run Under The Carpet or in the Headliner of Automobiles. www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Lbs/ 100’ 1 1/2” 1 3/4” 2 1/4” Self-Wrapping Flat Design Cut Cleanly Scissors Available Colors Colors Available: Black (BK) SPECIALTY ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet ABRASION Abrasion Resistance Melt Point Very High ASTM D-2117 493°F (256°C) Abrasion Test Machine Maximum Continuous Taber 5150 Calibrase H-18 Abrasion Test Load 500g Room Temperature 72°F Humidity 74% Slight Fraying On Multifilament - PET Unbroken 100 Test Cycles Holes Worn Through Multifilament - PET Unbroken 800 Test Cycles Holes Worn Through Multifilament - PET Unbroken 1,600 Test Cycles Material Destroyed 2,800 Test Cycles Pre-Test Weight 11,781.6 mg Post-Test Weight 9,279.1 mg Test End Loss Of Mass Point Of Destruction CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 2 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 3 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes Minimum Continuous -49°F (-45°C) PHYSICAL PROPERTIES Monofilament Diameter________ .015” ASTM D-204 Recommended Cutting_____ Hot-Knife Colors___________________________ 1 Wall Thickness__________________ .038” Specific Gravity ASTM D-79_______ 1.38 Moisture Absorption____________ .1-.2 % ASTM D-570 TML___________________________ .19 CVCM_________________________ .00 WVR___________________________ .16 Smoke D-Max____________________ 56 Outgassing____________________ Med Oxygen Index____________________ 21 2,502.5 mg © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-30 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Mil-I-23053 302°F (150°C) Abrasion Test Wheel
F6Z1.00BK25 价格&库存
很抱歉,暂时无法提供与“F6Z1.00BK25”相匹配的价格&库存,您可以联系我们找货
F6Z1.00BK25
  • 1+593.651411+76.89862
