DRN4.00BK25
DRN4.00BK25
    TECHFLEX
DRN4.00BK25 数据手册
ADVANCED ENGINEERING SPECIALTY Technical Data Sheet Technical Data Sheet Put-Ups T  ightly Woven Ballistic Nylon Construction H  eavy Duty Hook Closure For Carpet Installation R  epels Liquids R  esists And Prevents Damage From UV, Abrasion, And Chemicals Nominal Size Part # Bulk Spool Shop Spool Available Colors Lbs/ 100’ 3” DRN3.00BK 150’ 4” 5” DRN4.00 DRN5.00 150’ 150' 25’ GY, BR, BL, GN, YL, BK 4.29 25’ 25' SS, GY, BR, BL, GN, YL, BK SS, GY, BR, BL, GN, YL, BK 5.26 7.00 Abrasion Protection For High-Traffic Carpeting With Easy On, Easy Off Hook Closure DURA-RACE (DR) is the solution for hiding and protecting wires that are exposed on carpeted areas. Dura-Race is braided from a tightly woven ballistic nylon. With industrial strength hook closure, this covering will adhere to most industrial and high-traffic carpeting, making it easy to lay over wires, cables or hoses keeping them protected from abrasion. Dura-Race tightly holds the application close to the carpeting, avoiding trips or falls on free lying wires. DR provides greater abrasion resistance and water repellency compared to other nylon sleeves. Colors Available: 7=SS, GY, BR, BL, GN, YL, BK. Cut Cleanly Scissor Material Ballistic Nylon Best applied to: Cut & Loop Pile Loop Pile Grade DRN Patterned Loop Pile NOT recommended for: Wall Thickness .012” Cut Pile Dura Race Safety Stripe is a great safety enhancement for offices and other cable environments. Drawing Number TF100DR-WD Colors Available: www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 SS GY BR BL GN YL BK SPECIALTY ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet ABRASION Abrasion Resistance Melt Point Extreme ASTM D-2117 410°F (374°C) Abrasion Test Machine Maximum Continuous Mil-I-23053 Abrasion Test Wheel 200°F (93°C) Calibrase H-18 Abrasion Test Load 500g Room Temperature 77°F Humidity 72% Beginning Of Graying Abrasion Circle Pattern 100 Test Cycles Beginning Of “Roughing” Of Material 5% 13,000 Test Cycles Additional “Roughing” Of Material 20% 17,000 Test Cycles Additional “Roughing” Of Material 50% 19,000 Test Cycles Material Destroyed 20,000 Test Cycles Pre-Test Weight 5,082.20 mg Post-Test Weight 3,941.69 mg Test End Loss Of Mass Point Of Destruction CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 1 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 1 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 4 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 2 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes Minimum Continuous -60°F (-51°C) PHYSICAL PROPERTIES Monofilament Diameter__________NA ASTM D-204 Recommended Cutting________Scissor Colors__________________________ 7 Wall Thickness_________________ .012” Specific Gravity ASTM D-792______ 1.13 Moisture Absorption_____________ 2.7 % ASTM D-570 1,140.51 mg © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-30 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Taber 5150
DRN4.00BK25 价格&库存
很抱歉,暂时无法提供与“DRN4.00BK25”相匹配的价格&库存,您可以联系我们找货
