ADVANCED ENGINEERING
HEAVY DUTY
Technical Data Sheet
Put-Ups
T
ightly Woven Ballistic
Nylon Construction
H
eavy Duty, Oversize Hook
And Loop Closure
R
epels Liquids
R
esists And Prevents Damage
From UV, Abrasion, Gasoline,
Engine Chemicals And Salt
Water
Nominal
Size
Part
Wall
Hook & Loop
Thickness
Width
1”
1 1/2”
2”
2 1/2”
3”
3 1/2”
4”
4 1/2”
6”
8”
DWN1.00BK
DWN1.50BK
DWN2.00BK
DWN2.50BK
DWN3.00BK
DWN3.50BK
DWN4.00BK
DWN4.50BK
DWN6.00BK
DWN8.00BK
.026”
.026”
.026”
.026”
.026”
.026”
.026”
.026”
.026”
.026”
1”
1”
1”
1”
1”
1”
1”
1”
1”
1"
Bulk
Spool
Shop
Spool
150’
150’
150’
150’
150’
150’
150’
150’
150’
50'
25’
25’
25’
25’
25’
25’
25’
25’
25’
25'
Available
Colors
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
BK
BK
BK
BK
BK
BK
BK
BK
BK
BK
Lbs/
100’
5.40
7.00
8.20
9.40
11.40
12.60
14.00
15.40
19.20
25.00
D
eflects High Pressure
Hose Ruptures
Harsh Environment Protection With Easy On, Easy Off Hook
& Loop Closure
DURA-WRAP (DW) is the answer to organizing and controlling wires, cables and
hoses that are subjected to constant and extreme use. The flexible sleeve is made
from tightly woven ballistic nylon with an aggressive, industrial strength hook
and loop closure. DURA-WRAP is used on wires to keep them together, on hoses
and cables to prevent abrasion damage and on chains to keep them
from ruining expensive finished surfaces. DW provides greater abrasion resistance
and water repellency compared to other nylon sleeves and is being tested for
certification under the U.S. Dept. of Labor’s MSHA.
Cut Cleanly
Scissor
DW is extremely flexible and easy to install over single or multiple hoses. In the
event of a hose rupture, the high strength sleeving helps prevent high pressure
fluid from becoming a danger to equipment operators and other personnel.
Colors Available:
Material
Polyamide 6
Black (BK)
Grade
DWN
Wall Thickness
.026”
Drawing Number
TF001DWN-WD
This is a non-expandable product. Be sure to
match your application diameter accurately.
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
HEAVY
DUTY ENGINEERING
ADVANCED
Melt Point
ABRASION
ASTM D-2117
410°F (210°C)
Mil-I-23053
Extreme
200°F (93.3°C)
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
84°F
Humidity
74%
First Signs Of Slight
Fraying
5,000 Test Cycles
Visible Small Hole In Material
7,500 Test Cycles
Material Destroyed
8,500 Test Cycles
Pre-Test Weight
6,903.10 mg
Post-Test Weight
5,911.80 mg
Test End Loss Of Mass
Point Of Destruction
991.30mg
CHEMICAL
RESISTANCE
1=No Effect
4=More Affected
2=Little Effect 5=Severely Affected
3=Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 4
Strong Oxidants___________________ 4
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 2
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC______________________________
Minimum Continuous
-60°F (-51.1°C)
PHYSICAL
PROPERTIES
Monofilament Diameter__________NA
Flammability Rating________________
Recommended Cutting________Scissor
Colors__________________________ 1
Wall Thickness_________________ .026”
Tensile Strength (Yarn)______________
ASTM D-2256 Lbs
Specific Gravity ASTM D-792______ 1.13
Moisture Absorption_____________ 2.7
% ASTM D-570
Hard Vacuum Data_________________
ASTM E-595 at 10-5 torr
TML__________________________ 1.10
CVCM_________________________ .01
WVR___________________________ .69
Smoke D-Max___________________ 56
ASTM E-662
Outgassing___________________ High
Oxygen Index___________________ 22
ASTM D-2863
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-28
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Maximum Continuous
Abrasion Resistance
很抱歉,暂时无法提供与“DWN2.00BK25”相匹配的价格&库存,您可以联系我们找货
