ADVANCED ENGINEERING
Technical Data Sheet
Put-Ups
F
AR 25 Approved
Nominal
Size
U
ltra-Light Weight
1/8”
1/4”
1/2”
3/4”
1 1/4”
1 3/4”
2”
10 Mil
1/8”
H
ighly Wear Resistant
E
xpands Up To 150%
R
esists Acids, Bases,
Solvents And Fuels
C
ut And Abrasion
Resistant
Expansion Range
Part
Min
Max
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
RYN0.13
RYN0.25
RYN0.50
RYN0.75
RYN1.25
RYN1.75
RYN2.00
3/32”
1/8”
1/4”
1/2”
3/4”
1 1/4”
1 5/16”
1/4”
3/8”
3/4”
1 1/4”
1 3/4”
2 1/2”
2 3/8”
1,000’
1,000’
500’
250’
250’
200’
200’
225’
200’
100’
75’
50’
50’
50’
2
2
2
2
2
2
2
0.21
0.36
0.59
0.75
1.30
1.60
2.00
RZH0.13NT
1/8”
9/32”
1,000’
225’
NT
0.26
Ultra Lightweight High-Temp
Tolerant And Virtually Impervious
To Chemical Degradation
Cut Cleanly
Hot Knife
Material
Polyethylene Sulphide
Grade
RYN
Monofilament Diameter
.008”
FLEXO PPS expandable sleeving is used
in high temperature, flame resistant wire
harnesses and cable assemblies. Flexo PPS is an
extremely lightweight sleeving, resistant
to high temperatures and virtually
impervious to solvents. This sleeving is ideal
for aerospace, telecom and military applications
and meets many engineering goals including;
chemical resistance, high temperature stability,
zero moisture absorption, excellent dimensional
stability and ultra-low wear.
Colors Available:
2 = NT and BK
Flexo PPS is braided from 8 mil flame resistant
PolyPhenylene Sulfide (PPS) monofilament fibers.
PPS offers the broadest resistance to chemicals
of any advanced engineering plastic. The material
resists all known solvents below 392°F (200°C)
and is inert to steam, strong bases, fuels and acids.
A true aerospace material, Flexo PPS is ideal
in satellite applications where weight
and stability are of primary importance.
Colors Available:
Drawing Number
TF001RY-WD
Natural (NT) and Black (BK).
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 0787
UL94 V-O
FAR-25
ADVANCED
ENGINEERING
ADVANCED
ENGINEERING
Melt Point
ASTM D-2117
ABRASION
Medium
Rating______________ FAR 25, UL94 V-O
Taber 5150
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
71°F
Humidity
59%
Very Visible Wear And
Several Filaments Broken
100 Test Cycles
Wear Continues
150 Test Cycles
Material Destroyed
450 Test Cycles
Pre-Test Weight
3,079.2 mg
Post-Test Weight
2,614.9mg
Test End Loss Of Mass
Point Of Destruction
464.3 mg
Mil-I-23053
392°F (200°C)
Minimum Continuous
-94°F (-70°C)
Abrasion Test Machine
Abrasion Test Wheel
Maximum Continuous
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 1
Salt Water 0-S-1926________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 1
Strong Oxidants___________________ 1
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC______________________________
PHYSICAL
PROPERTIES
Monofilament Diameter________ .008”
ASTM D-204
Flammability Rating___ FAR 25, UL94 V-O
Recommended Cutting_____ Hot Knife
Colors___________________________ 2
Wall Thickness__________________ .024”
Tensile Strength (Yarn)____________ 6.1
ASTM D-2256 Lbs
Specific Gravity ASTM D-792_____ 1.37
Moisture Absorption_____________ .02
% ASTM D-570
Hard Vacuum Data__________________
ASTM E-595 at 10-5 torr
TML___________________________.08
CVCM_________________________ .00
WVR___________________________ .04
Smoke D-Max_____________________
ASTM E-662
Outgassing____________________Low
Oxygen Index____________________40
ASTM D-2863
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
06/18
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
545°F (285°C)
很抱歉,暂时无法提供与“RYN0.25BK”相匹配的价格&库存,您可以联系我们找货
