HTN0.38TB125
HTN0.38TB125
    TECHFLEX
HTN0.38TB125 数据手册
ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Put-Ups M  eets UL 2024 V  W-1, FAR 25 Approved E  xpands Up To 150% R  esists Gasoline And Engine Chemicals C  ut And Abrasion Resistant Expansion Range Nominal Size Part # Min Max Bulk Spool Shop Spool Available Colors Lbs/ 100’ 1/8” 1/4” 3/8” 1/2” 3/4” 1” 1 1/4” 1 3/4” 2” HTN0.13 HTN0.25 HTN0.38 HTN0.50 HTN0.75 HTN1.00 HTN1.25 HTN1.75 HTN2.00 3/32” 1/8” 3/16” 1/4” 1/2” 5/8” 3/4” 1 1/4” 1 1/2” 1/4” 7/16” 5/8” 3/4” 1 1/4” 1 5/8” 1 3/4” 2 3/4” 3 1/2” 1,000’ 1,000’ 500’ 500’ 250’ 250’ 250’ 200’ 200’ 225’ 200’ 125’ 100’ 75’ 65’ 50’ 30’ 50’ 3 3 3 3 3 3 3 3 3 0.25 0.38 0.86 1.10 1.70 2.20 2.60 4.40 4.60 E  asy To Install Very Low Outgassing, Self-Extinguishing UL-2024 Plenum Rated Sleeving HALAR® (HT) self-extinguishing sleeving is used where flammability, high temperature endurance and low outgassing are primary concerns. HT is braided from 11 mil ethylene chlorotriflouroethylene (ECTFE) copolymer monofilament. Cut Cleanly Hot Knife Material HT Ethylene-chlorotrifluoroethylene Grade HTN Because of its low flame spread and smoke generation properties, HT has received UL 2024 and NFPA 262 plenum listings, UL flame resistance rating of VW-1 and exceeds automotive industry requirements of FMVSS 302, as well as aviation industry requirements of FAR 25. HT resists a wide range of corrosive chemicals and organic solvents, including strong acids, chlorine and aqueous caustics. HALAR® ECTFE also maintains useful properties on exposure to Cobalt 60 radiation at doses up to 200 megarads. Monofilament Diameter .011” Drawing Number TF001HT-WD Halar’s low outgassing, as well as its heat, chemical and radiation properties, make it ideal for use as a component in technologically advanced applications. Colors Available: Black, White with Black Tracer (TW), and Black with White Tracer (TB). www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 0787 Halar® is a registered trademark of the Solvay Solexis Corporation. VW-1 Plenum FAR-25 Colors Available: 3=BK, TW & TB ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ABRASION Medium Rating_________________ FAR 25, VW-1 482°F (250°C) Maximum Continuous Mil-I-23053 302°F (150°C) Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 71°F Humidity 58% Material Destroyed 600 Test Cycles Pre-Test Weight 6,354.9 mg Post-Test Weight 5,922.8 mg Test End Loss Of Mass Point Of Destruction 432.1 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 1 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 1 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 1 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808_________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 1 Strong Oxidants___________________ 1 Esters/Ketones____________________ 2 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC______________________________ Minimum Continuous -103°F (-75°C) PHYSICAL PROPERTIES Monofilament Diameter________ .011” ASTM D-204 Flammability Rating_____ FAR 25, VW-1 FMVSS-302 Approved Recommended Cutting______Hot Knife Colors__________________________ 3 Wall Thickness_________________ .028” Tensile Strength (Yarn)____________ 4.3 ASTM D-2256 Lbs Specific Gravity ASTM D-792______ 1.68 Moisture Absorption_____________ .02 % ASTM D-570 Hard Vacuum Data _________________ ASTM E-595 at 10-5 torr TML__________________________ .18 CVCM_________________________ .02 WVR____________________________ 0 Smoke D-Max___________________ 94 ASTM E-662 Outgassing___________________ Low Oxygen Index___________________ 64 ASTM D-2863 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 06/18 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance FLAMMABILITY ASTM D-2117
HTN0.38TB125 价格&库存
很抱歉,暂时无法提供与“HTN0.38TB125”相匹配的价格&库存,您可以联系我们找货
