CNN0.38BK125
CNN0.38BK125
    TECHFLEX
CNN0.38BK125 数据手册
ADVANCED ENGINEERING METAL & SHIELDING Technical Data Sheet Technical Data Sheet Put-Ups Expansion Range E  conomical And Easy To Install Nominal Size Part # Min Max Bulk Spool Shop Spool Available Colors Lbs/ 100’ E  xpands Up To 150% 1/8” 1/4” 3/8” 1/2” 5/8” 3/4” 1” 1 1/4” 1 1/2” CNN0.13BK CNN0.25BK CNN0.38BK CNN0.50BK CNN0.63BK CNN0.75BK CNN1.00BK CNN1.25BK CNN1.50BK 3/32” 1/8” 3/16” 1/4” 3/8” 1/2” 5/8” 3/4” 1” 1/4” 7/16” 5/8” 3/4” 1” 1 1/4” 1 5/8” 1 3/4” 2 1/2” 1,000’ 1,000’ 500’ 500’ 500’ 250’ 250’ 250’ 200’ 225’ 200’ 125’ 100’ 100’ 75’ 65’ 50’ 40’ Black Black Black Black Black Black Black Black Black 0.35 0.40 0.60 0.82 0.96 1.24 1.37 1.65 2.20 R  esists Gasoline And Engine Chemicals E  MI, RFI Protection S  uperior Static Dissipation C  ut And Abrasion Resistant C  ustom Lengths Available Conductive Carbon Infused Nylon For Static Protection And Shielding CN is braided from 11 mil carbonized nylon monofilament yarn. CN is designed to protect sensitive wiring from abrasion while shielding it from high frequency noise. Many successful applications have utilized CN for maintaining clean video signals, interference filtering in pro sound environments, and RF filtering on power cables and outputs. CN is also useful in static sensitive environments. Cut Cleanly Hot Knife Material Carbonized Nylon Grade CNN CN utilizes a patented carbonization process which infuses our braided sleeving with a microscopic carbon compound that is virtually indistinguishable from the base material. The result is a strong, long lasting jacket that is ready for the most sensitive applications. Monofilament Diameter .011” Drawing Number TF001CNN-WD www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Clean signals are achieved without excessive noise with properly isolated cables and wires. Colors Available: Black (BK) METAL & SHIELDING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ASTM D-2117 ABRASION 482ºF (250ºC) Maximum Continuous 302ºF (150ºC) Medium Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 73°F Humidity 51% Material Destroyed 800 Test Cycles Pre-Test Weight 8,822.3 mg Post-Test Weight 8,662.5 mg Test End Loss Of Mass Point Of Destruction 159.8 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 1 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 1 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 4 Strong Oxidants___________________ 4 Esters/Ketones____________________ 1 UV Light_________________________ 2 Petroleum________________________ 3 Fungus ASTM G-21_________________ 2 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC_________________________ None Minimum Continuous -49ºF (-45ºC) PHYSICAL PROPERTIES Monofilament Diameter________ .011” ASTM D-204 Recommended Cutting______Hot Knife Colors__________________________ 1 Wall Thickness_________________ .028” Tensile Strength (Yarn)______________ ASTM D-2256 Lbs Abrasion_____________________ Med Specific Gravity ASTM D-792______ 1.13 Moisture Absorption_____________ 2.5 % ASTM D-570 Hard Vacuum Data_________________ ASTM E-595 at 10-5 torr TML___________________________ .19 CVCM_________________________ .04 WVR___________________________ .06 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-28 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Mil-I-23053 Abrasion Resistance
CNN0.38BK125 价格&库存
很抱歉,暂时无法提供与“CNN0.38BK125”相匹配的价格&库存,您可以联系我们找货
CNN0.38BK125
    • 1+2836.219661+367.62807
