ADVANCED ENGINEERING
Technical Data Sheet
Put-Ups
U
p To 20 Times Stronger
Than Steel
W
ill Not Melt, Burn Or
Support Combustion
S
tays Soft, Flexible And
Pliable Throughout -274°F
to 320°F
Expansion Range
Nominal
Size
Part
Min
Max
Bulk
Spool
Shop
Spool
1/4”
1/2”
3/4”
1”
1 1/4”
1 1/2”
2”
KVN0.25YL
KVN0.50YL
KVN0.75YL
KVN1.00YL
KVN1.25YL
KVN1.50YL
KVN2.00YL
1/8”
1/4”
1/2”
3/4”
1”
1 1/4”
1 3/4”
5/16”
5/8”
7/8”
1 1/4”
1 5/8”
2”
2 1/2”
500’
250’
250’
200’
125’
100’
100’
50’
50’
50’
25’
25’
25’
25’
Stronger Than Steel, Soft And Pliable
FLEXO ARAMID (FA) is a soft, flexible sleeving that’s
perfect for bundling and protecting vulnerable
components from the most extreme
environmental conditions. Flexo Aramid is
braided from aramid fibers and has all well-known
characteristics of durability, pliability and
extraordinary tensile strength. Flexo Aramid
fibers are up to 20 times stronger than steel fibers
of equal diameter.
Cut Cleanly
Flexo Aramid Shears
Material
*Kevlar® Aramid Fibers
Flexo Aramid has excellent thermal stability,
permitting long-term, continuous use at temperatures
as low as -274°F and as high as 320°F. Short term
exposure up to 572°F can be tolerated. Flexo Aramid
does not melt or support combustion. The sleeving
provides extreme strength and durability, yet
is lightweight and easy to install.
Grade
KVN
The properties that make Flexo Aramid so tough in
use also make the material a challenge to cut
to length. Use Flexo Aramid shears for cutting.
Wall Thickness
.020”
Drawing Number
TF001KV-WD
NEW- Ask about our high speed cutting service.
Cuts Flexo Aramid to precise, repeatable lengths!
*Kevlar® is a registered trademark of DuPontTM.
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 0787
Available
Colors
Yellow
Yellow
Yellow
Yellow
Yellow
Yellow
Yellow
(YL)
(YL)
(YL)
(YL)
(YL)
(YL)
(YL)
Lbs/
100’
0.30
0.80
1.20
1.92
2.40
2.90
3.60
Colors Available:
Yellow (YL)
ADVANCED
ENGINEERING
ADVANCED
ENGINEERING
Melt Point
572°F (300°C)
ABRASION
Maximum Continuous
320°F (160°C)
Medium
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
80°F
Humidity
70%
Scuffing And Pulling
Of Soft Fibers
20 Test Cycles
Of Fibers Continues
400 Test Cycles
Material Destroyed
700 Test Cycles
Pre-Test Weight
5,730.5 mg
Post-Test Weight
5,200.1 mg
Test End Loss Of Mass
Point Of Destruction
530.4 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 2
Aliphatic Solvents__________________ 2
Chlorinated Solvents_______________ 2
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 2
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 4
Petroleum________________________ 1
Fungus ASTM G-21_________________ 2
Halogen Free____________________ Yes
RoHS______________________________
SVHC______________________________
Minimum Continuous
-274°F (-170°C)
PHYSICAL
PROPERTIES
Monofilament Diameter_________ NA
ASTM D-204
Flammability Rating_________________
FMVSS-302 Approved
Cutting__________ Flexo Aramid Shears
Colors___________________________ 1
Wall Thickness___________________ .02”
Tensile Strength (Yarn)_____________ 39
ASTM D-2256 Lbs
Specific Gravity ASTM D-792_____ 1.44
Moisture Absorption%_______________
ASTM D-570
Hard Vacuum Data__________________
ASTM E-595 at 10-5 torr
TML__________________________3.13
CVCM_________________________ .19
WVR__________________________ 1.76
Smoke D-Max______________________
ASTM E-662
Outgassing____________________ High
Oxygen Index____________________ 29
ASTM D-2863
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
06/18
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Mil-I-23053
Abrasion Resistance
很抱歉,暂时无法提供与“KVN0.75YL”相匹配的价格&库存,您可以联系我们找货
