TFN0.38NT125
TFN0.38NT125
    TECHFLEX
TFN0.38NT125 数据手册
ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Put-Ups P  lenum Suitable F  AR 25 Approved E  xpands Up To 150% R  esists Gasoline And Other Chemicals C  ut And Abrasion Resistant Nominal Size Part # 1/8” 1/4” 3/8” 1/2” 3/4” 1 1/4” 1 3/4” 2” TFN0.13 TFN0.25 TFN0.38 TFN0.50 TFN0.75 TFN1.25 TFN1.75 TFN2.00 Expansion Range Min Max Bulk Spool Shop Spool Available Colors Lbs/ 100’ 3/32” 3/16” 1/4” 3/8” 5/8” 1 1/8” 1 3/8” 1 11/16” 1/4” 3/8” 3/4” 7/8” 1 1/4” 1 1/2” 1 3/4” 2 1/8” 1,000’ 1,000’ 500’ 500’ 250’ 200’ 200’ 200’ 225’ 200’ 125’ 100’ 75’ 50’ 50’ 25’ NT NT NT NT NT NT NT NT 0.50 0.68 2.20 2.60 2.90 4.80 5.50 6.40 High Temp Stable, Abrasion Resistant, Low Outgassing FLEXO PFA (TFN) expandable sleeving is ideal in applications where flame, chemical and very high temperature resistance are significant considerations. Braided from 16 mil perfluoroalkoxy (TFN) polymer monofilament. The high temperature properties of Flexo PFA make it the ideal choice for aerospace, military and high-tech applications where thermal stability and low outgassing are critical. Flexo PFA is suitable for plenum applications. Cut Cleanly Hot Knife Material Perfluoroalkoxy Grade TFN & & & & & & & & BK BK BK BK BK BK BK BK Colors Available: Natural (NT) & Black(BK) What Makes Flexo PFA So Special? Flexo PFA is inert to virtually all chemicals and is considered the most slippery material on the planet. These properties have made it one of the most valuable and versatile technologies ever invented, contributing to advancements in areas such as aerospace, communications, electronics, industrial processes and architecture. Colors Available: Monofilament Diameter .016” Drawing Number TF001TF-WD Natural (NT) and Black (BK). High temperature resistance and low outgassing allows Flexo PFA sleeving to function in high-temp environments. www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 0787 FAR-25 ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ASTM D-2117 590°F (310°C) ABRASION Very High Taber 5150 Calibrase H-18 Abrasion Test Load 500g Room Temperature 71°F Humidity 59% Slight Rough Surface And A Few Filaments Broken 1,500 Test Cycles Visible Wear And Three Filaments Broken 2,000 Test Cycles Material Destroyed 3,000 Test Cycles Pre-Test Weight 13,955.5 mg Post-Test Weight 12,911.9 mg Test End Loss Of Mass Point Of Destruction 1,043.6 mg Mil-I-23053 550°F (280°C) Rating_______________________ FAR 25 Abrasion Test Machine Abrasion Test Wheel Maximum Continuous CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 1 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 1 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 1 Salt Water 0-S-1926________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 1 Strong Oxidants___________________ 1 Esters/Ketones____________________ 2 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ No RoHS___________________________ Yes SVHC______________________________ Minimum Continuous -94°F (-70°C) PHYSICAL PROPERTIES Monofilament Diameter________ .016” ASTM D-204 Flammability Rating___________ FAR 25 Recommended Cutting_____ Hot Knife Colors___________________________ 2 Wall Thickness___________________ .04” Tensile Strength (Yarn)____________ 2.1 ASTM D-2256 Lbs Specific Gravity ASTM D-792_____ 2.15 Moisture Absorption____________ 95 ASTM D-2863 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 06/18 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance FLAMMABILITY
TFN0.38NT125 价格&库存
很抱歉,暂时无法提供与“TFN0.38NT125”相匹配的价格&库存,您可以联系我们找货
TFN0.38NT125
    • 1+4903.599281+635.59983
