EXTREME
TEMPERATURE
Technical Data Sheet
ADVANCED ENGINEERING
4’ Put-Ups
Heat Reflective
Aluminum Laminated
Fiberglass
elf Wrap And Seal Overlap
S
With High Temperature
Adhesive Strip
R
eflects Radiant Heat
R
esists Gasoline And
Engine Chemicals
C
ut And Abrasion
Resistant
Nominal
Size
Part
Wall
Thickness
±0.007”
Bulk
Box
Box
8x8
Box
6x6
Box
4x4
Available
Colors
Lbs/
10Pcs.
1/4”
3/8”
1/2”
5/8”
3/4”
1”
1 1/4”
1 1/2”
2”
T6F0.25SV
T6F0.38SV
T6F0.50SV
T6F0.63SV
T6F0.75SV
T6F1.00SV
T6F1.25SV
T6F1.50SV
T6F2.00SV
0.042”
0.042”
0.042”
0.042”
0.042”
0.042”
0.042”
0.042”
0.042”
250
250
250
150
125
70
63
40
24
140
90
70
60
50
30
8
100
50
40
35
30
8
4
50
30
25
9
6
4
2
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
1.0
1.5
2.0
2.5
3.0
3.5
4.5
5.0
6.0
Reflective Aluminized Surface Bonded
To Insulating Self Wrapping Fiberglass
The newest item in the ThermaShield® line of aluminized fiberglass products, T6 is
designed for ease of installation when component disassembly isn’t practical.
Just wrap the pre-formed, split flexible tube around any component and seal the
sides with the high temperature adhesive strip to provide protection from hot
pipes and engine components.
The highly reflective aluminized exterior, combined with the insulating fiberglass
interior, protects delicate wire bundles, cables and lines from damage caused by
nearby exhaust pipes, headers or other heat generating components.
Cut Cleanly
Scissors
Aluminum Laminated Fiberglass
Grade
T6F
Temperature
Material
Colors Available:
Steel Braided Hose
Without T6 Protection
Silver (SV)
With T6
Protection
Time
Wall Thickness
.042”
Drawing Number
TF001TW-WD
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
When applied, the aluminum laminate
reflects heat away and the insulating
fiberglass backing protects the fragile
contents from thermal damage and failure.
T6 can reduce the heat transmission from
hot pipes or engine components into hoses
or harnesses by up to 50% or more.
HALOGEN
FREE
FAR-25
EXTREME
TEMPERATURE
Melt Point
ASTM D-2117
ABRASION
Extreme
Rating_______________ Non Flammable
Abrasion Test Machine
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
71°F
Humidity
53%
Most Foil Coating Worn
Away In Tested Area Of
Material
3,500 Test Cycles
Braid Worn Through In
Both Directions
Material Destroyed
6,000 Test Cycles
Pre-Test Weight
18,188.4 mg
Post-Test Weight
16,555.5 mg
Test End Loss Of Mass
Point Of Destruction
1,632.9 mg
Mil-I-23053
491°F (255°C)
Minimum Continuous
-76°F (-60°C)
Taber 5150
Abrasion Test Wheel
Maximum Continuous
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong __________________________ 1
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-78 08________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 2
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
PHYSICAL
PROPERTIES
Flammability Rating__Non Combustible
Recommended Cutting________Scissor
Colors__________________________ 1
Wall Thickness_________________ .042”
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
08-26
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
2,048°F (1,120°C)
很抱歉,暂时无法提供与“T6F0.63SV”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+151.353211+18.93082
- 2+139.182932+17.40860
- 3+132.549103+16.57886
- 5+124.608335+15.58565
- 7+119.648597+14.96530
- 10+114.6066210+14.33467
- 25+102.6049925+12.83354
- 50+94.3687050+11.80337
- 100+86.79637100+10.85624
