FGN1.00BK25
FGN1.00BK25
    TECHFLEX
    INSULTHERM 1" BLACK 25'
FGN1.00BK25 数据手册
EXTREME TEMPERATURE Technical Data Sheet ADVANCED ENGINEERING Technical Data Sheet Put-Ups UL Recognized R  esin Coated, Heavy Weight Fiberglass Won’t Burn, Melt Or Become Brittle E  asy To Install-Cuts With Scissors R  esists Gasoline And Engine Chemicals Nominal Size Part # Maximum Diameter Wall Thickness Bulk Spool Shop Spool Available Colors Lbs/ 100’ 1/4” 3/8” 1/2” 5/8” 3/4” 7/8” 1” 1 1/2” 2 1/2” FGN0.25 FGN0.38 FGN0.50 FGN0.63 FGN0.75 FGN0.88 FGN1.00 FGN1.50 FGN2.50 3/8” 5/8” 3/4” 7/8” 1 1/8” 1 1/4” 1 5/8” 2 5/8” 4 1/8" 0.031” 0.043” 0.046” 0.046” 0.046” 0.046” 0.057” 0.061” 0.071" 200’ 200’ 200’ 200’ 200’ 200’ 100’ 100’ 100' 50’ 50’ 50’ 50’ 50’ 50’ 25’ 25’ 25' 2 2 2 2 2 2 2 2 2 2.00 3.30 4.80 5.30 6.40 8.70 10.50 16.00 19.70 Cut And Abrasion Resistant Resin Coated Fiberglass Protects To 1,200°F INSULTHERM ® (FG) is an extremely high temperature resistant sleeve commonly used as thermal protection for wires, cables and hoses that are subjected to continuous and extreme high temperature environments, such as engine manifolds and exhaust systems. Cut Cleanly Scissors Material Resin Coated Fiberglass 2 = BK and SV FG is braided from fiberglass yarns and coated with high temperature resins. FG is tough and durable, maintaining its tight structure under extreme vibration, abrasion, mechanical stress and temperature variations. FG installs easily over a variety of applications to either deflect or retain heat in environments up to 1,200° F. “...will withstand extreme heat... provides the protection needed” Grade FGN Wall Thickness Refer to Chart Colors Available: Peter Mercier - Engineer Team Bucknum Racing www.bucknum.com Colors Available: Drawing Number TF001INS-WD Black (BK) and Silver (SV). www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 VW-1 EXTREME ADVANCED ENGINEERING TEMPERATURE Technical Data Sheet Technical Data Sheet Melt Point ASTM D-2117 ABRASION High Rating________________________ VW-1 Maximum Continuous Mil-I-23053 1,202°F (650°C) Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 73°F CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Humidity 55% Visible Minor Scuffing 200 Test Cycles Scuffing And Wear Continues 300 Test Cycles Scuffing And Wear Continues 500 Test Cycles Several Broken Strands 1,300 Test Cycles Material Destroyed 1,650 Test Cycles Pre-Test Weight 19,411.6 mg Post-Test Weight 17,154.5 mg Test End Loss Of Mass Point Of Destruction 2,257.1 mg Aromatic Solvents_________________ 1 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 1 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 1 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 2 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 2 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes Minimum Continuous -94°F (-70°C) PHYSICAL PROPERTIES Monofilament Diameter_________ NA ASTM D-204 Flammability Rating____________ VW-1 Recommended Cutting________ Scissor Colors___________________________ 2 Wall Thickness_____________ .031”-.061” Specific Gravity ASTM D-792____ 1.0-1.8 Moisture Absorption_____________ .01 % ASTM D-570 Hard Vacuum Data__________________ ASTM E-595 TML___________________________ .02 CVCM_________________________ .01 WVR___________________________ .00 Outgassing____________________Low SVHC_________________________ None © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 08-26 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance FLAMMABILITY 2,048°F (1,120°C)
FGN1.00BK25 价格&库存
很抱歉,暂时无法提供与“FGN1.00BK25”相匹配的价格&库存,您可以联系我们找货
FGN1.00BK25
    • 1+798.190261+103.39356
    • 2+734.091792+95.09056
    • 3+698.984143+90.54290
    • 5+657.186435+85.12863
    • 7+631.027617+81.74015
    • 10+624.0617710+80.83783
    库存:97
