NRN0.38BK100
NRN0.38BK100
    TECHFLEX
    NOISE REDUCTION 3/8" BLACK 100'
NRN0.38BK100 数据手册
ADVANCED ENGINEERING SPECIALTY Technical Data Sheet Technical Data Sheet Put-Ups E  xcellent Noise Suppression A  brasion Resistant E  xtremely Lightweight A  ttractive Appearance D  oes Not Trap Heat Or Moisture Expansion Range Nominal Size Part # Min Max Bulk Spool Shop Spool Available Colors Lbs/ 100’ 1/8” 1/4” 3/8” 1/2” 5/8” 3/4” 1” NRN0.13BK NRN0.25BK NRN0.38BK NRN0.50BK NRN0.63BK NRN0.75BK NRN1.00BK 1/8” 1/4” 3/8” 1/2” 5/8” 3/4” 1” 3/16” 3/8” 1/2” 3/4” 1” 1 1/4” 1 5/8” 500’ 500’ 250’ 250’ 250’ 250’ 250’ 100’ 100’ 100’ 100’ 100’ 75’ 50’ Black Black Black Black Black Black Black 0.3 0.5 0.9 1.1 1.5 2.0 2.4 Self-Fitting Protective Oversleeve Cut Cleanly Hot Knife Material Polyethylene Terephthalate Flexo® Noise Reduction (NR) is a biaxially braided sleeving combining monofilament and multifilament PET yarns to create a full coverage expandable sleeve that substantially reduces noise on wires, tubes and hoses. The lightweight, rugged construction also provides protection from abrasion and vibration that is far superior to foam harness sleeves. NR expands for easy installation over splices and connectors and is flexible enough for tight radius applications. NR is used in body wiring harnesses, instrument panel and lighting wiring, cable and hose assemblies, and other limited access applications where noise reduction is desirable. Grade NRN Wall Thickness .025” www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 The braided construction will not hold moisture and drains quickly when immersed. Colors Available: Black (BK) SPECIALTY ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet ABRASION Medium Rating_______________________ *UL94 *UL 94 V-O Raw Material Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 2 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 3 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC_________________________ None ASTM D-2117 446°F (230°C) Maximum Continuous Mil-I-23053 257°F (125°C) Minimum Continuous -22°F (-30°C) PHYSICAL PROPERTIES Monofilament Diameter________ .010” ASTM D-204 Flammability Rating___________ *UL94 *UL 94 V-O Raw Material Recommended Cutting_____ Scissor/HK Colors___________________________ 1 Wall Thickness__________________ .025” Tensile Strength (Yarn)____________ 7.5 ASTM D-2256 Lbs Specific Gravity ASTM D-792_____ 1.38 Moisture Absorption____________ .1-.2 % ASTM D-570 Hard Vacuum Data__________________ ASTM E-595 at 10-5 torr TML___________________________.19 CVCM_________________________ .00 WVR___________________________ .16 Outgassing___________________ Med Oxygen Index____________________ 21 ASTM D-2863 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-30 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance FLAMMABILITY Melt Point
NRN0.38BK100 价格&库存
很抱歉,暂时无法提供与“NRN0.38BK100”相匹配的价格&库存,您可以联系我们找货
