CTP340STD
CTP340STD
    HELLERMAN(海尔曼太通)
CTP340STD 数据手册
CTP340STD Article Number: 169-60513 Convoluted Tubing, Slit, 3/4" Dia., PE, Black, 550ft/Carton Download drawing Download spec sheet Base Data Local Order Number CTP340STD Type CTP340 Color Black (BK) Features and Benefits • Split side is ideal for applications where braided tubing or spiral wrap may be difficult to install. • Tubing provides full coverage where spiral wrap or other coverings may not be suitable. • In harsh applications the tubing provides resistance to crushing, impact, and abrasion. • Tubing offers excellent protection against automotive fluids, vibration wear, water, snow, ice, and the effects of heat, cold, and sunlight on cables and wires. Product Description HellermannTyton’s Convoluted Tubing, also known at Split Loom Tubing, provides an efficient method of routing and protecting wire harness assemblies, while reducing the chance of installation damage. With a split down the side where you can insert your wire harness, you can just easily install Convoluted Tubing without removal of the entire assembly. It can also serve to protect valuable hoses and cables. Convoluted tubing offer’s excellent protection against vibration wear, water, snow, ice and the effects of heat, cold and sunlight on cables and wires. Short Description Convoluted Tubing, Slit, 3/4" Dia., PE, Black, 550ft/Carton Product Dimensions Length L (Imperial) 550.0 ft Length L (Metric) 167.6 m Inner Diameter D (Imperial) 0.759 " Inner Diameter D (metric) 19.28 mm Diameter D (imperial) 0.989 " Diameter D (metric) 25.12 mm Diameter D2 (imperial) 0.759 " Diameter D2 (metric) 19.28 mm Outside Diameter D (imperial) 0.989 " Outside Diameter D (metric) 25.12 mm Nominal Diameter (Imperial) 3/4 " Nominal Diameter (Metric) 19.05 mm Wall Thickness WT (Imperial) 0.005 " Wall Thickness WT (Metric) 0.127 mm Logistics and Packaging Quantity Per carton Package Quantity 550.0 ft Package Quantity (Metric) 167.6 m Carton Quantity 550 Material and Specifications Material Polyethylene (PE) Material Shortcut PE Flammability UL94 HB Operating Temperature -40°F to +199°F (-40°C to +93°C) ROHS Compliant Yes © HellermannTyton 2015
CTP340STD 价格&库存
很抱歉,暂时无法提供与“CTP340STD”相匹配的价格&库存,您可以联系我们找货
