L6N0.38BK
L6N0.38BK
    TECHFLEX
    SELFWRAP3/8"X8'BLACK
L6N0.38BK 数据手册
ADVANCED ENGINEERING SPECIALTY Technical Data Sheet Technical Data Sheet 8’ Pcs. Put-Ups W  ater Repellent When Properly Sealed W  ill Not Support Growth Of Bacteria D  isinfects Easily Nominal Size Part # Wall Thickness Bulk Box Box 8x8 Box 6x6 Box 4x4 Available Colors Lbs/ 10Pcs. 3/8” 1/2” 3/4” 1” 1 1/4” L6N0.38 L6N0.50 L6N0.75 L6N1.00 L6N1.25 0.046” 0.046” 0.046” 0.046” 0.046” 250 250 125 88 63 90 70 50 30 20 50 40 30 20 10 30 25 15 9 6 BK BK BK BK BK 0.9 1.0 1.8 2.2 2.6 Adhesive Resists Most Cleaners And Disinfectants Stylish Fluid Protection For Wires & Cables Our new L6 Liquid Wrap semi-rigid wraparound sleeving is engineered from tough braided polyester, and laminated with a layer of strong Mylar sheeting. This combination provides a strong and lightweight solution for any application that requires protection from repeated exposure to the elements. Cut Cleanly Hot Knife Material Laminated Polyester The wraparound construction, with 12% edge overlap makes installation easy over existing assemblies or harnesses, and the extra wide adhesive strip ensures a positive, aggressive seal against damage from exposure. L6 is available in 8' pre-cut sticks in Black. Grade L6N Monofilament Diameter NA L6 is ideal for marine and automotive wiring harnesses, and also for cable management in medical applications. www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Mylar® is a registered trademark of DuPont Corporation. Colors Available: Black (BK) SPECIALTY ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ASTM D-2117 ABRASION 482°F (250°C) Maximum Continuous 257°F (125°C) Extreme Material DestroyedBraid Worn Through in Both Directions 10,338 Test Cycles CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 2 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 2 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 3 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC_________________________ None Minimum Continuous -94°F (-70°C) PHYSICAL PROPERTIES Monofilament Diameter__________NA ASTM D-204 Flammability Rating________________ FMVSS-302 Approved Recommended Cutting________Scissor Colors__________________________ 1 Wall Thickness_________________ .046” Tensile Strength (Yarn)______________ ASTM D-2256 Lbs Specific Gravity ASTM D-792______ 1.38 Moisture Absorption____________ .1-.2 % ASTM D-570 Hard Vacuum Data_________________ ASTM E-595 at 10-5 torr TML___________________________ .19 CVCM_________________________ .00 WVR___________________________ .16 Smoke D-Max___________________ 56 ASTM E-662 Outgassing___________________ Med Oxygen Index___________________ 21 ASTM D-2863 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-30 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Mil-I-23053 Abrasion Resistance
L6N0.38BK 价格&库存
很抱歉,暂时无法提供与“L6N0.38BK”相匹配的价格&库存,您可以联系我们找货
