ADVANCED ENGINEERING
SPECIALTY
Technical Data Sheet
8’ Pcs. Put-Ups
W
ater Repellent When
Properly Sealed
W
ill Not Support Growth
Of Bacteria
D
isinfects Easily
Nominal
Size
Part
Wall
Thickness
Bulk
Box
Box
8x8
Box
6x6
Box
4x4
Available
Colors
Lbs/
10Pcs.
3/8”
1/2”
3/4”
1”
1 1/4”
L6N0.38
L6N0.50
L6N0.75
L6N1.00
L6N1.25
0.046”
0.046”
0.046”
0.046”
0.046”
250
250
125
88
63
90
70
50
30
40
30
30
25
15
9
6
BK
BK
BK
BK
BK
0.9
1.0
1.8
2.2
2.6
Adhesive Resists
Most Cleaners And
Disinfectants
Stylish Fluid Protection
For Wires & Cables
Our new L6 Liquid Wrap semi-rigid wraparound
sleeving is engineered from tough braided polyester, and laminated with a layer of strong Mylar
sheeting. This combination provides a strong
and lightweight solution for any application
that requires protection from repeated
exposure to the elements.
Cut Cleanly
Hot Knife
Material
Laminated Polyester
The wraparound construction, with 12% edge
overlap makes installation easy over existing
assemblies or harnesses, and the extra wide
adhesive strip ensures a positive, aggressive
seal against damage from exposure.
L6 is available in 8' pre-cut sticks in Black.
Grade
L6N
Monofilament Diameter
NA
L6 is ideal for marine and automotive wiring
harnesses, and also for cable management
in medical applications.
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
Mylar® is a registered trademark of DuPont Corporation.
Colors Available:
Black (BK)
SPECIALTY
ADVANCED
ENGINEERING
Melt Point
ASTM D-2117
ABRASION
482°F (250°C)
Maximum Continuous
257°F (125°C)
Extreme
Material DestroyedBraid Worn Through in
Both Directions
10,338 Test Cycles
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 2
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 2
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 3
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 3
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC_________________________ None
Minimum Continuous
-94°F (-70°C)
PHYSICAL
PROPERTIES
Monofilament Diameter__________NA
ASTM D-204
Flammability Rating________________
FMVSS-302 Approved
Recommended Cutting________Scissor
Colors__________________________ 1
Wall Thickness_________________ .046”
Tensile Strength (Yarn)______________
ASTM D-2256 Lbs
Specific Gravity ASTM D-792______ 1.38
Moisture Absorption____________ .1-.2
% ASTM D-570
Hard Vacuum Data_________________
ASTM E-595 at 10-5 torr
TML___________________________ .19
CVCM_________________________ .00
WVR___________________________ .16
Smoke D-Max___________________ 56
ASTM E-662
Outgassing___________________ Med
Oxygen Index___________________ 21
ASTM D-2863
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-30
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Mil-I-23053
Abrasion Resistance
很抱歉,暂时无法提供与“L6N0.50BK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+169.775201+21.96496
