F6N0.13CW100
F6N0.13CW100
    TECHFLEX
F6N0.13CW100 数据手册
ADVANCED ENGINEERING GENERAL PURPOSE Technical Data Sheet Technical Data Sheet Put-Ups E  asy, Cost And Labor Effective Installation M  ore Flexible Than Split Convoluted Or Spiral Wrap 2  5% Edge Overlap S  oft And Quiet In High Vibration Uses C  ut And Abrasion Resistant Nominal Size Part # Wall Thickness Monofilament Diameter Bulk Box Box A Box B Available Colors Lbs/ 100’ 1/8” 1/4” 3/8” 1/2” 3/4” 1” 1 1/4” 1 1/2” 2” F6N0.13 F6N0.25 F6N0.38 F6N0.50 F6N0.75 F6N1.00 F6N1.25 F6N1.50 F6N2.00 .024” .025” .025” .025” .025” .038” .038” .038” .038” .008” .010” .010” .010” .010” .015” .015” .015” .015” 8,000’ 3,000’ 1,500’ 1,200’ 500’ 400’ 250’ 250’ 200’ 400’ 200’ 150’ 150’ 100’ 100’ 75’ 75’ 50’ 100’ 100’ 75’ 75’ 50’ 50’ 25’ 25’ 25’ BK,OR,PG,CW 5 5 5 5 5 5 5 5 0.47 0.60 1.20 1.40 1.60 2.00 2.40 2.70 3.60 C  hemically Inert H  alogen Free Flexible, Semi-Rigid Wrappable Split Braided Tube F6’s unique split, semi-rigid braided construction makes it the ideal solution for situations where ease of installation is of primary importance. The lateral split allows the tube to open up to accommodate a wide variety of bundling requirements, and the semi-rigid braid configuration simply closes around the entire installation without the need for any additional fasteners (Velcro, tape, etc.) Cut Cleanly Hot Knife Material Polyethylene Terephthalate The PET braid is lightweight, quiet and flexible. The 25% edge overlap (at nominal diameter) allows coverage around inline plugs, connectors and splices. F6 will bend to a tight radius without distorting or splitting open and, unlike full rigid tubing, will not impair or affect the flexibility of harnesses. Colors Available: Grade F6N Monofilament Diameter .008” - .015” Black (BK), Orange (OR), Platinum Gray (PG), Clear/White (CW), & White (WH). Drawing Number TF001F6-WD The large overlap allows easy installation over splices and incline connectors without exposing wires and cables. Nominal Diameter www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 FAR-25 Colors Available: 5= BK, OR, PG, CW, and WH GENERAL PURPOSE ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ABRASION High FLAMMABILITY Rating______________________UL94VO FMVSS 302 and SAE J369_________Pass Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 80°F Humidity 74% Some Scuffing Visible 500 Test Cycles Significant Wear Is Visible With Several Braid Filaments Broken 1,200 Test Cycles Material Destroyed 1,950 Test Cycles Pre-Test Weight 5,365.1 mg Post-Test Weight 4,850 mg Test End Loss Of Mass Point Of Destruction 515.1 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 2 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 3 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC_________________________ None 482°F (250°C) Maximum Continuous Mil-I-23053 257°F (125°C) Minimum Continuous -94°F (-70°C) PHYSICAL PROPERTIES Monofilament Diameter___ .008”-.015” ASTM D-204 Flammability Rating____________ UL94 Recommended Cutting______Hot Knife Colors__________________________ 5 Wall Thickness____________.024”-.038”s Tensile Strength (Yarn)___________6-10 ASTM D-2256 Lbs Specific Gravity ASTM D-792______ 1.38 Moisture Absorption____________ .1-.2 % ASTM D-570 Hard Vacuum Data ASTM E-595 TML___________________________ .19 CVCM_________________________ .00 WVR___________________________ .16 Smoke D-Max___________________ 56 ASTM E-662 Outgassing___________________ Med Oxygen Index___________________ 21 ASTM D-2863 © 2023 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 03-07 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance ASTM D-2117
F6N0.13CW100 价格&库存
很抱歉,暂时无法提供与“F6N0.13CW100”相匹配的价格&库存,您可以联系我们找货
F6N0.13CW100
  • 1+397.750661+51.45967
