NYN0.25BK200
NYN0.25BK200
    TECHFLEX
    NYLON MONO 1/4" BLACK 200'
NYN0.25BK200 数据手册
ADVANCED ENGINEERING SPECIALTY Technical Data Sheet Technical Data Sheet Put-Ups B  raided From .012” Nylon 6-6 Polyamide Monofilament Yarns R  esists Gasoline And Engine Chemicals E  conomical And Easy To Install E  xpands Up To 150% C  ut And Abrasion Resistant Expansion Range Nominal Size Part # Min Max Bulk Spool Shop Spool Available Colors Lbs/ 100’ 1/8” 1/4” 3/8” 1/2” 5/8” 3/4” 1” 1 1/4” 1 1/2” 2” NYN0.13BK NYN0.25BK NYN0.38BK NYN0.50BK NYN0.63BK NYN0.75BK NYN1.00BK NYN1.25BK NYN1.50BK NYN2.00BK 3/32” 1/8” 1/4” 3/8” 7/16” 1/2” 5/8” 3/4” 1” 1 1/2” 1/4” 3/8” 7/16” 3/4” 1” 1 1/4” 1 3/8” 1 1/2” 2” 3” 1,000’ 1,000’ 500’ 500’ 500’ 250’ 250’ 250’ 200’ 200’ 225’ 200’ 125’ 100’ 100’ 75’ 50’ 50’ 40’ 50’ Black Black Black Black Black Black Black Black Black Black 0.22 0.31 0.72 1.03 1.12 1.47 1.60 1.78 2.55 2.26 When The Spec Says Nylon And Only Nylon Will Do NY is commonly used in the automotive industry to protect hoses and wire harnesses from excessive wear. NY’s tough characteristics can increase hose life up to 300%. This lengthened life span is recognized in terms of reduced maintenance, a professional, attractive and durable appearance and greater customer satisfaction. With the additional protection that NY provides, it pays for itself throughout the life of your product. Cut Cleanly Hot Knife Grade NYN NY is braided from .012” nylon 6-6 Polyamide monofilament. The tight braid construction covers fully and provides excellent surface abrasion resistance for assemblies exposed to excessive wear. The smooth nylon fibers and tight construction also reduce abrasion damage caused by hoses and harnesses rubbing against the inside wall of the sleeving. Monofilament Diameter .012” NY resists all common automotive chemicals and UV damage. It won’t rot or retain moisture. Material Nylon 6-6 Polyamide Drawing Number TF001NY-WD www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Nylon Mono’s qualities of toughness and sound suppression make it the choice of auto manufacturers for protecting and managing cables routed through door and body cavities. Colors Available: Black (BK) SPECIALTY ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ASTM D-2117 ABRASION 493°F (256°C) Maximum Continuous Mil-I-23053 High 302°F (150°C) Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 72°F Humidity 48% Several Strands Broken 400 Test Cycles Several Small Holes Worn Through, Material Destroyed 1,200 Test Cycles Pre-Test Weight 4,637.0 mg Post-Test Weight 4,030.3 mg Test End Loss Of Mass Point Of Destruction 606.7 mg CHEMICAL RESISTANCE 1=No Effect 4=More Affected 2=Little Effect 5=Severely Affected 3=Affected Aromatic Solvents_________________ 1 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 1 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 5 Strong Oxidants___________________ 5 Esters/Ketones____________________ 1 UV Light_________________________ 2 Petroleum________________________ 3 Fungus ASTM G-21_________________ 2 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC_________________________ None Minimum Continuous -49°F (-45°C) PHYSICAL PROPERTIES Monofilament Diameter________ .012” ASTM D-204 Recommended Cutting_____ Hot Knife Colors___________________________ 1 Wall Thickness___________________ .03” Tensile Strength (Yarn)___________ 10.5 ASTM D-2256 Lbs Specific Gravity ASTM D-792_____ 1.14 Moisture Absorption_____________2.5 % ASTM D-570 Hard Vacuum Data_________________ ASTM E-595 at 10-5 torr TML__________________________1.10 CVCM_________________________ .01 WVR___________________________ .69 Outgassing___________________ High Oxygen Index____________________ 22 ASTM D-2863 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-30 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance
NYN0.25BK200 价格&库存
很抱歉,暂时无法提供与“NYN0.25BK200”相匹配的价格&库存,您可以联系我们找货
